Komatsu Backhoe Loader WB142-5 Shop Manual CEBM018903
Type of Manual: Shop Manual
Model: Komatsu WB142-5 Backhoe Loader
Engine 4D102LE-2
Serial Number: A13001 and up
Publication Date: 06.2010
Form Number: CEBM018903
Number of Page: 506 Pages
Foreword
Safety
General
How To Read The Shop Manual
Hoisting Instructions
Explanation Of Terms For Maintenance Standard
Coating Materials
Standard Tightening Torque
Standard Tightening Torque Of Bolts And Nuts
Tightening Torque Of Hose Nuts
Tightening Torque Of Split Flange Bolts
Tightening Torque For Flared Nuts
Connecting Push-Pull Type Coupler.
Conversion Tables
Method Of Using The Conversion Table
01 General
Specification Drawing
Machine Systems Specifications
Weight Table
Fuel, Coolant, And Lubricants
Homologated (Hees) Synthetic Lubricants
Lubrication Diagrams
General View
10 Structure, Function And Maintenance Standard
Power Train
Front Axle Assembly
Rear Axle Assembly
Rear Brakes
Differential Lock
Solenoid Valve
Master Cylinder (Brakes)
Loader Cylinders
Backhoe Cylinders
Pin And Bushing Clearances
20 Standard Value Tables
Standard Value Table For Engine
Standard Value Table For Chassis
30 Testing And Adjusting
Bleed Air From Circuits
Accelerator Pedal And Throttle Lever
Parking Brake Adjustment
Hydraulic Circuit
Power Train
Hydraulic Drift
40 Troubleshooting
Points To Remember When Troubleshooting
Sequence Of Events In Troubleshooting
Precautions When Carrying Out Maintenance
Checks Before Troubleshooting
Troubleshooting Guide
50 Disassembly And Assembly
How To Use This Manual
Precautions When Carrying Out An Operation
Special Tool Ust.
Connector Repair Procedures
Engine Hood
Front Guard
Muffler
Air Filter
Exhaust Stack
Operators Seat
Side Panel And Instrument Group
Battery
Steering And Front Dash Assembly
Canopy
Hydraulic Oil Tank
Transmission Overhaul Procedures
Backhoe Control Valve
Front Axle Assembly
Front Axle Overhaul Procedures
Rear Axle Assembly
Rear Axle Overhaul Procedures
Front Loader Control Valve Assembly
Solenoid Valve Assembly
Front-End Loader Assembly
Backhoe Assembly
Work Equipment Cyunder Overhaul Procedures
90 Others
Electrical Schematic
