Martin Welker
104
230,310
Kobelco Wheel Loader LK40Z-6 Parts Manual S3RW0005
Brand: Kobelco
Type of Machine: Wheel Loader
Model: Kobelco LK40Z-6 Wheel Loader
Part Number: S3RW0005
Number of Pages: 401 Pages
Preface
General Drawing
Paint Color
Dvehicle
Label(Exteriori
Label(Bonnet Inside)
Label(Canopy)
Label(Cabin)
Accessory
Silencer
Air Cleaner
Engine Accessories
Foot Accel
Engine Mount
Radiator Shroud
Radiator & Sub Tank
Duct
Fuel Piping
Harness(Battery)
Battery
Harness(Main)
Harness(Starter Switch)
Equipment(I)
Equipment(2)
Starter Switch
Starter Switch(Immobilizer)
Steering
Auto Leveller
Switch
Switch(Heater Spec.)
Instrument Panel(Canopy)
Instrument Panel(Cabini
Equipment(Rear)
Ducti Heater Spec.)
Drive Shaft
Transfer Case
Spiral Bevel Gear(Front)
Spiral Bevel Gear(Reari
Differential Gear
Axle Shaft
Final Gear
Front Axle Case
Rear Axle Case
Axle Holder
Swing Pin
Center Brake
Tire & Disc
Tire & Disc(Snow)
(46a)Tire & Disc(Plating Snow)
Inching Pedal
Brake Pedal
Floor Cover
Hydraulic Lever
Control Cable
Hydraulic Link
Lever Stand
Lock Lever
Cover(Lever)
(56a)P.T.O. Lever
(56b)P.T.O. Cable
Steering Wheel
Steering Column
Cover(Stand)
Front Frame
Articulate Stopper
Rear Frame
Rear Frame(Inner Parts)
Articulate Pin
Counter Weight
Hitch
Channel
Bulkhead Bracket
Steering Frame
Operation Cover & Rearview Mirror
Column Cover
Column Cover(Heater Spec.)
Front Fender
Front Cover
Side Cover(Left)
Side Cover(Right)
Cover(D.P.E)
Step
Under Cover
Steering Cover
Floor Mat(Canopy)
Floor Mat(Cabin)
Seat(To M02g2g1
&102930)
Seat & Seat Belt(To M02929)
(S6a)Seat & Seat M02930)
(S6b)Seat & Seat M02930)
Seat Mount
Tool Box
Bonnet
Bonnet Lock
Canopy
Cabin(Accessory)
Parts)
(92e)Cabin Door(Right)
(22e)Cabin Door(Left)
& Window Washer)
Hydraulic Pump Mount
Lift Cylinder
Dump Cylinder
Ps. Cylinder
Hydraulic Motor
Steering Ijnit
Hydraulic Filter
Control
(Icia)Control Valve(2l21
(Icib)Control Valve(3/3)
(Icic)Control Valve(P.T.O. Spec.L(Ilä)
(Icid)Control Valve(P.T.O.
(Icie)Control Valve(P.T.O.
Hyd. Oil Tank
Fitting(Control Valve)
Spec.)
Fitting(Hydraijlic Filter)
Fitting(Steering Unit)
Fitting(Hydraijlic Pump)
Fitting(Hydraijlic Motor)
Tank - Pump
Pump - Motor
Pump - Steering - P.S. Cylinder
Control Valve - Uft & Dump Cylinder (111a)P.T.O.
Greasing
Uft Arm
Loader
Eijcket(O.4)
Eijcket(O.5)
Euckel(Ls)
Dust Proof Net Kit(Optional)
Radio Kit(Optional)
Cabin(Sunvisor) Kit(Optionali
Inching Lever Kit(Optional)
Rt.O. Kit(Optional)
Immobilizer Kit(Optionali
Quick Holder Kit(Optional)
Kit(Optional)
Bucket(Qå) Kit(Optional)
Kit(Optional)
Holder) Kit(Optional)
Holderi(Plating) Kit(Optional)
Tire(Snow) Kit(Optional)
Tire(No Puncture) Kit(Optional)
Suspension Seat Kit(Optional)
Lock Kit(Lift
Radio Radio)
Snow Wiper(Optional)
Tire(Plating Snow) Kit(Optional)
Seat Kit(Optional)
Seat Kit & Seat
Seat Kit & Seat
Engine Components
