Hyundai
86
176,684
Kobelco Excavator SK380XDLC-10 Parts Catalog S3LCB0003ZE10 EN JP
Language: Japanese, English
Brand: Kobelco
Type of Machine: Excavator
Model: Kobelco SK380XDLC-10 Excavator
Serial Number:
YC14-B1001--B1560
YC14505001-
Part Number: S3LCB0003ZE10
Number of Pages: 1026 Pages
SK380XDLC-10 MINE INDIA (YC14B/YC145)
CONTENTS
PREFACE
GENERAL DRAWING
GENERAL MAINTENANCE ITEMS
FILTER LIST​
NUT PARTS No.​
SLEEVE PARTS No.​
PAINT COLOR​
UPPERSTRUCTURE
FRAME, UPP​
FRAME GROUP, UPP​
COUNTERWEIGHT INSTAL​
COUNTERWEIGHT ASSY​
SEAL ASSY​
ENGINE INSTAL​
RADIATOR GROUP​
RADIATOR INSTAL​
RADIATOR ASSY​
CLEANER ASSY, AIR​
CLEANER, AIR​
MUFFLER ASSY​
FUEL LINES​
FILTER, FUEL​
TANK INSTAL, FUEL​
TANK ASSY, FUEL​
CAP ASSY​
TANK INSTAL, HYD​
TANK ASSY, HYD​
TANK INSTAL, HYD​
POWER TAKE-OFF ASSY​
PUMP ASSY, HYD​
MOTOR INSTAL, SWING​
MOTOR ASSY, SWING​
VALVE INSTAL​
VALVE ASSY, CONTROL​
VALVE INSTAL​
HYD LINES, PUMP​
HYD LINES, UPP​
HYD LINES, UPP(BREAKER)​
VALVE, CONTROL​
HYD LINES, RETURN​
CONTROLS, OPERATORS​
SWITCH INSTAL​
LEVER ASSY, PROPEL​
RADIO INSTAL​
CONTROL BOX ASSY​
PEDAL ASSY​
PEDAL ASSY(1 PEDAL)​
GRIP ASSY​
NAME PLATE INSTAL(ENGINE EMERGENCY LESS)​
CONTROL LINES, MAIN​
CONTROL LINES, REMOTE(SENSOR BLOCK)​
VALVE INSTAL​
VALVE, PILOT​
CONTROL LINES,REMOTE​
CONTROL LINES,REMOTE(NIBBLER & BREAKER)​
VALVE, PILOT​
CONTROL LINES, VALVE​
VALVE INSTAL​
VALVE ASSY, SOLENOID​
VALVE INSTAL​
VALVE, SOLENOID​
HARNESS ASSY, UPP​
CONTROL LINES,PROPEL​
VALVE INSTAL​
VALVE, PILOT​
CONTROL LINES,PROPEL(OPTION)​
CONTROL LINES, PROPEL(OPTION)​
VALVE INSTAL​
VALVE, PILOT​
CONTROL LINES, BLOCK​
CONTROL LINES, PUMP​
FILTER, INLINE​
PLATE INSTAL, FLOOR​
INSULATION INSTAL​
CAB INSTAL​
DOOR ASSY, CAB​
WINDOW ASSY, FR.​
CATCH ASSY, DOOR​
CAB INSTAL​
MIRROR INSTAL(CAB)​
SWITCH INSTAL(CAB LIGHT)​
LIGHT INSTAL(CAB 2LIGHT)​
LIGHT INSTAL​
BRACKET INSTAL​
TANK ASSY, WASHER​
SEAT INSTAL(SUSPENSION AND HEIGHTRISER)​
SEAT ASSY​
SEAT INSTAL​
ARM REST​
BELT ASSY, SEAT​
GUARD INSTAL​
HANDRAIL INSTAL​
GUARD INSTAL​
MIRROR INSTAL​
LIGHT INSTAL, UPP​
COVER ASSY, UNDER​
PANEL ASSY, INSTRUM​
SWITCH INSTAL​
CONTROLLER INSTAL​
CONTROLLER INSTAL(ECU)​
CONTROLLER INSTAL(MECHATRO MAIN CONTROLLER)​
RELAY BOX ASSY​
BATTERY ASSY(BATTERY MODEL AX-1111(a))​
BATTERY INSTAL​
CONDITIONER, AIR​
CONDITIONER ASSY,AIR​
ELEC ASSY, UPP​
HARNESS ASSY, UPP(UPP)​
HARNESS ASSY, UPP(FLOOR)​
HARNESS ASSY, CAB​
HARNESS ASSY(BOOM LIGHT)​
HARNESS ASSY(IT KIT PORTABLE)​
HARNESS ASSY(GLOBAL IT KIT MOBILE COMMUNICATIONS, 4G)​
UNDERCARRIAGE
FRAME ASSY, LOW(LONG CRAWLER)​
LOW GROUP​
COVER ASSY, UNDER​
MOTOR INSTAL, PROPEL​
MOTOR ASSY, PROPEL​
JOINT INSTAL, SWIVEL​
JOINT, SWIVEL​
RING ASSY, SLEWING​
IDLER ASSY, CRAWLER​
ROLLER ASSY, TRACK(LONG CRAWLER)​
ROLLER ASSY, UPP​
SHOE ASSY(LONG CRAWLER, 600mm)​
SHOE ASSY(LONG CRAWLER 800mm)​
HYD LINES, LOW(LONG CRAWLER)​
HYD LINES, PROPEL​
HYD LINES, SWIVEL​
BOOM, HOE 6.5M​
BOOM GROUP​
BOOM INSTAL​
CAP ASSY(FILTER LESS)​
CYLINDER INSTAL(BOOM)​
CYLINDER INSTAL​
CYLINDER, BOOM​
CYLINDER INSTAL(ARM)​
CYLINDER INSTAL​
CYLINDER, ARM​
HYD LINES, BOOM 6.5M​
HYD LINES, BOOM​
HYD LINES, BOOM 6.5M(BREAKER)​
HYD LINES, BOOM​
ELEMENT, FILTER​
HYD LINES, CYLINDER(BOOM)​
HYD LINES, CYLINDER​
HYD LINES, CYLINDER(ARM)​
HARNESS ASSY, BOOM​
HARNESS ASSY, BOOM(BOOM CYLINDER)​
LIGHT INSTAL, BOOM​
LIGHT INSTAL​
ARM, SHORT 2.25M​
ARM, SHORT 2.6M​
ARM, 3.3M​
ARM GROUP, 2.25M(REINFORCED)​
ARM GROUP​
ARM GROUP, 2.6M(REINFORCED)​
ARM GROUP​
ARM INSTAL​
CAP ASSY(SHORT ARM)​
CYLINDER INSTAL(BUCKET)​
CYLINDER INSTAL​
CYLINDER, BUCKET​
HYD LINES, CYLINDER(BUCKET)​
HYD LINES, ARM 2.25M(BUCKET)​
HYD LINES, ARM 2.25M(NIBBLER & BREAKER)​
HYD LINES, ARM​
VALVE, STOP​
HYD LINES, ARM​
HYD LINES, ARM 2.6M​
HYD LINES, ARM 2.6M(NIBBLER & BREAKER)​
HYD LINES, ARM​
VALVE, STOP​
HYD LINES, ARM​
HYD LINES, ARM 3.3M​
HYD LINES, ARM 3.3M(NIBBLER & BREAKER)​
HYD LINES, ARM​
VALVE, STOP​
HYD LINES, ARM​
CONNECTOR ASSY(NIBBLER & BREAKER)​
BUCKET INSTAL​
BUCKET ASSY, 1.6M3​
TOOLS, SPARE PARTS
TOOL & ACCESSORY​
ELEMENT KIT​
ACCESSORIES​
OPTIONAL PARTS
GUARD ASSY​
CAB & GUARD ASSY(BOLT-FIXED)​
HARNESS ASSY(GLOBAL IT KIT MOBILE COMMUNICATIONS)​
SWITCH INSTAL​
ALARM ASSY​
HARNESS ASSY(FUEL SUPPLY PUMP)​
PUMP ASSY, FUEL​
BUCKET ASSY, 1.8M3​
BUCKET ASSY, 2.0M3​
BUCKET ASSY, 2.3M3​
NAME PLATES
NAME PL.INSTAL, BODY​
NAME PL.INSTAL, BODY(WITHOUT BATTERY INTERCEPTION SWITCH)​
NAME PL.INSTAL, CAB​
NAME PLATE INSTAL(LUBRICATION CHART)​
NAME PLATE INSTAL(CAUTION, ATTACHMENT)​
NAME PLATE INSTAL(MULTILESS, WITHOUT BHL)​
NAME PLATE INSTAL​
NAME PLATE INSTAL(MODEL NAME/SK380XDLC)​
NAME PL.INSTAL, EXT​
NAME PLATE INSTAL​
ENGINE COMPONENTS
HOW TO READ ENGINE PARTS CATALOG​
CYLINDER HEAD​
CYLINDER BLOCK​
TIMING GEAR COVER AND FLYWHEEL HOUSING​
MAIN MOVING PARTS​
CAMSHAFT AND IDLE GEAR​
VALVE SYSTEM​
AIR INTAKE AND EXHAUST SYSTEM​
LUBRICATION​
FUEL SYSTEM​
COOLING SYSTEM​
ELECTRICAL PARTS (ENGINE)​
TURBOCHARGER​
ENGINE ACCESSORY PARTS​
GASKET KIT (ENGINE OVERHAUL)​
INDEX OF PART NO.
