Kobelco Crawler Crane SL6000 Parts Manual S3JG00002ZO
Brand: Kobelco
Type of Machine: Crawler Crane
Type of Manual: Parts Catalog, Parts List
Model: Kobelco SL6000 Crawler Crane
Book Number: S3JG00002ZO
List of Files:
Hino Engine E13CUV-KSFA Parts Manual.pdf (79 Pages)
Kobelco Crawler Crane SL6000 Parts Manual S3JG00002ZO.pdf (1897 Pages)
Kobelco SL6000 Hydraulic Components Parts Manual S3JG50001ZO.pdf (137 Pages)
Detail Contents:
1. Control System
2. Winch System (Hi,-H2)
3. Winch System (Wi)
4. Winch System (W3)
5. Winch System
6. Swing System
7. Wne-S
8. Power Plant
9. Electric System
10. Cab Guard / Platform
11. Lower System
12. Crane Attachment
13. Cuffing Jib Attachment
14. Guy Cable / Rope / Hook Etc.
15. Crane Mast
16. Hl Mast
17. Reeving Winch
18. Over Hoist / Over Load Safety Device
19. Counterweight / Frame
20. 4bel (Englishs)
21. Cabel (Japanese)
22. Others
23. Option
Ventilator
Timing Gear Cover & Flywheel Housing
Main Moving Parts
Camshaft & Idle Gear
Valve System
Air Intake & Exhaust System
Exhaust Brake Cylinder
Engine Retarder
Lubrication System
Oil Filter
Oil Pump
Fuel System
Common-Rail
Pump, Common-Rail
Coolant Pump
Electrical Parts
Turbocharger
Engine Parts Set
Starting Motor
Gasket Kit (Engine Overhaul)
1. Pump Group
2. Motor Group
3. Cylinder Group
4. Valve Group
5. Others Group
Brand: Kobelco
List of Files:
Detail Contents:
1. Control System
5. Winch System
6. Swing System
7. Wne-S
8. Power Plant
9. Electric System
11. Lower System
15. Crane Mast
16. Hl Mast
17. Reeving Winch
20. 4bel (Englishs)
22. Others
23. Option
Ventilator
Main Moving Parts
Valve System
Engine Retarder
Lubrication System
Oil Filter
Oil Pump
Fuel System
Common-Rail
Pump, Common-Rail
Coolant Pump
Electrical Parts
Turbocharger
Engine Parts Set
Starting Motor
1. Pump Group
2. Motor Group
3. Cylinder Group
4. Valve Group
5. Others Group
- Kobelco RK250-3, RK350 and RK450-2 Crane Electrical Schematic
- Kobelco Crane RK250-II Shop Manual
- Kobelco Crane RK250-3 Shop Manual
- Kobelco RK450-2 Service training
- Kobelco CKE2500 Operation & Maintenance Manual
- Kobelco Crawler Crane 7055, 7065 Shop Manual
- Kobelco Crane RK250-3 Electric System
- Kobelco Crawler Crane CK2500-II,CKE2500-II Shop manual
- Kobelco Crane RK250-3 Hydraulic Circuit Diagram and Specifications of Components
- Kobelco Crawler Crane CKE1350 Parts Manual
- Kobelco Crawler Crane CKE600-1 Hydraulic Schematic
- Kobelco Crawler Crane CKE1350 Shop Manual
- Kobelco Crawler crane Parts Manual some models (see pictures)
- Kobelco Crawler Crane CKE1350 Operation Manual
- Kobelco Crawler Crane Operator & Maintenance Manual some models (see pictures)
