Kinze Ag Leader Firmware Version 9.0 Operators Manual PN2006395 2023
Brand: Kinze
Type of Document: Operators Manual
Model: Kinze Ag Leader Firmware Version 9.0
Part Number: PN2006395
Date: 2023
Number of Pages: 1094 Pages
Display
Startup
Initial Startup
Home screen Layout
Status Indicators
AgFiniti Status Indicators
Configurations
Equipment Setup
Management Setup
Management button
Display Setup
Video
Data Management
Data Transfer screen
.AGSETUP Files
.AGDATA files
Exporting Logged Data
Create Backup File (USB drive Only)
Restore Backup File
Upgrade Firmware.fw3
Export Reports
Manual Sync
AgFiniti
AgFiniti®
AgFiniti Mobile
AgFiniti Mobile Connection Types
Display Access Point Connection Type
InCommand Display
iPad
AgFiniti Mobile
AgFiniti Essentials - Cloud Sync
File Transfer
Remote Support
Cellular iPad as Personal Hotspot Connection
Shared Wi-Fi Network Connection
DisplayCast
DisplayCast
Network Diagnostics
DisplayCast Statistics
Field Operations
Events
Field Operations
Heading Detection
Vehicle Icon
Map Toolbox
Operator Selection
Menu Buttons
In-Field Functions
Automatic Swath Control
Create Boundary
Headlands
Satellite Imagery
GPS/Steering Setup
GPS Setup
TerraStar Settings
RTK Settings
Upgrade Receiver
Serial Port Settings
GPS Information
GPS Information - Receiver Tab
RTK/NTRIP Information (ParaDyme/GeoSteer Only)
GPS Information - NTRIP
Guidance and Steering
Guidance Tab on Mapping screen
New Pattern—Straight
New Pattern—Identical Curve
New Pattern—Pivot
New Pattern—SmartPath
TurnPath
TurnPath
TurnPath Requirements
TurnPath Single Turn Mode Toolbox
TurnPath Preview
TurnPath Options
Sequence Mode
Sequences
Summary Reports
Summary Report
Event Summary
Smart Reports™ (InCommand™ 1200 Only)
Ag Leader Display–Auxiliary Assignments
Enable the Universal Terminal
Auxiliary Module Support
ISO Retrofit Kit
ISOBUS Retrofit—No Modules
Retrofit Cable Kit (Generic Tractor) Wiring Diagram
Troubleshooting Step 1: Universal Terminal
Troubleshooting Step 2: Cables and Power
Troubleshooting Step 3: ISOBUS Retrofit Cable
Troubleshooting Step 4: High Current Relay Module
Troubleshooting Step 5: CAN Power Module LED 1
Troubleshooting Step 6: CAN Power Module LED 2
Troubleshooting Step 7: CAN Power Module LED 3
Troubleshooting Step 8: Reload Implement Object Pools
Intellislope® Tile Plow Control System
Create Configurations
Setup Tile Controller
Topography
Survey
Operating Modes
On-grade Indication
Grade Control
Target
Pitch Control
Planting Section Control
Map View
Load Configuration
Creating Products
Row Shutoff Look-Ahead Numbers
Clutch Diagnostics
TroubleShooting Planter Section Control
Hydraulic Seed Rate Control
Creating Products
Equipment Settings
Auxiliary Input
Stepper Seed Rate Control
Gear Ratio Calculations for Seed Rate Motors
Hydraulic Down Force–2 Channel
Setup Down Force Configuration
Down Force screen General tab
Down Force Channel 1 and Channel 2 tabs
ISOBUS Hydraulic Down Force
At a Glance – With Ag Leader InCommand™ 1200
ISOBUS Down Force Configuration
ISOBUS Down Force Operation
ISOBUS Down Force Settings
How to use Manual Override
FAQ
Troubleshooting
Implement Switch Adjustment Problems
Hydraulic Down Force–Individual Row
General tab
Uplift Force
FAQ
Troubleshooting
Ag Leader Seed Tube Monitoring Module
Creating Products
Seed Monitor Setup
Troubleshooting Ag Leader Seed Tube Monitoring Module
Standard KINZE Planter Module
Creating Products
Setup Steps
Troubleshooting
SureDrive®
Load Configuration
Map View
Sensor Configuration
Vacuum & Pressure Configuration
Troubleshooting Seed Monitor
SureSpeed
SureSpeed®
Load Configuration
Map View
Creating Products
Planter Options
Seed Rows
Configuring Offset Planter Sections
Fixing Overplanting and Underplanting in AutoSwath
Diagnostic Screens
Row Control Module
SureSpeed Indicator Lights
Planter Control Module 2 (PCM2)
RCM Errors
SureSpeed™ Operators Manual
Operation
Meter Speed RPMs
(30” Row Spacing 92 Cell Soybean Disc) or (15” Row Spacing 46 Cell Soybean Disc)
Recommended Vac Chart for Soybeans (Single Row and Dual Row)
Meter Speed RPMs - 20” Row Spacing 46 Cell Soybean, Cotton, Sugar beet/Milo Disc
Maintenance
Parts List
Hydraulic Down Force–SureForce
Advanced Seed Monitoring
General tab
Advanced tab
Down Force Alarms
FAQ
Troubleshooting
Liquid Rate Control
Map View
Product Control Toolbox
Rate Control Settings
Container Level Settings
Implement Offsets
Equipment Settings
Auxiliary Input
Hardi Safe Track
Liquid Application Controller Settings
Liquid Application Diagnostics
Troubleshooting DirectCommand Liquid Applications
Serial Communication
Load Configuration
Map View
Adjust Container Amount
Implement Offsets
Equipment Settings
Module Layouts
Serial Control - Supported Controllers
Troubleshooting Serial Control Applications—Liquid
Troubleshooting Serial Control Applications—Granular
ISO Liquid Rate Control
At a Glance—Universal Terminal
At a Glance—With Ag Leader Display
Loading Prescriptions
Implement Offsets
Hardi Safe Track
Nozzles
System Settings
ISO Liquid Module
Swath Module
ISOBUS Serial Communication
Load Configuration
Map View
Load Configuration
Implement Offsets
Equipment Settings
Configuration Setup
Status Screen
Settings Screen
Injection
Map View
Load Configuration
Setup Configuration
Priming an Injection Pump
Injection Diagnostics
Troubleshooting
Analog Pump Speed Sensor
OptRx
OptRx®
Map View
N Algorithm Setup
Create an OptRx V.I. Reference Value
Crop Sensor Settings
Override Serial Logging
Sensor Setup
Sensor Setup
Installation
Glossary of OptRx Terminology
Troubleshooting OptRx Error Messages
Norac UC5
Norac Unlock
Setup Configuration
Load Configuration
Engage button
Boom Height Control Options Button
Boom Height Control Options Screen
Boom Height Diagnostics
Spreader
Spinner Spreaders
Map View
Configure Product Mix
Container Sequencing
Equipment Settings
Auxiliary Input
Stepper Spreader Control
Run Time Operations—Spreader Control
Spreader Control: Routine Operations
Strip Till
Map View
Equipment Settings
Auxiliary Input
Controller Settings
Actuator/Clutch Logic
Run Time Operations
Strip Till Control Screen
Fertilizer Default Product Settings
Raven ISOBUS PWM Nozzle Control
DirectCommand® L2 Rate Controller
Anhydrous Ammonia (NH3)
Implement Offsets
Equipment Settings
Auxiliary Input
Implement Modeling
Vehicle Interface Diagnostics
Troubleshooting DirectCommand L2 Applications
RightSpot™
RightSpot™
RightSpot Toolbox
RightSpot™ Settings
Creating Products
Active Nozzles
Implement Offsets
Equipment Settings
Auxiliary Input
Implement Modeling
Rate Settings
RightSpot Diagnostics
Valve Control Modules
Troubleshooting RightSpot Application
Alarms
RightSpot™ Operator’s Manual
General Guidelines
RightSpot Universal Boom Layout
Safety and Notices
Operator Safety
Nozzle Selection
Pre-Season Checklist
Post-Season Checklist
Maintenance
Nozzle Valve Assembly Installation
Achieving Proper Coverage with Blended Pulse
Boom Flush
Cleaning Nozzle Valves
Parts List
Diagnostics
Troubleshooting
Alarms
Nozzle Charts
Harvest
Harvest Interface Module
Map View
Tracking Varieties and Changing Regions
Calibration Information
Manual Moisture Setting
Lexion Quantimeter
Map View
Lexion
Diagnostics for Quantimeter
Bridge Module
Troubleshooting Quantimeter Configurations
Jaguar Quantimeter
Map View
Jaguar
Bridge Module
Brand: Kinze
Date: 2023
Display
Startup
Initial Startup
Home screen Layout
Status Indicators
Configurations
Equipment Setup
Management Setup
Management button
Display Setup
Video
Data Management
.AGSETUP Files
.AGDATA files
Restore Backup File
Export Reports
Manual Sync
AgFiniti
AgFiniti®
AgFiniti Mobile
InCommand Display
iPad
AgFiniti Mobile
File Transfer
Remote Support
DisplayCast
DisplayCast
Network Diagnostics
Field Operations
Events
Field Operations
Heading Detection
Vehicle Icon
Map Toolbox
Operator Selection
Menu Buttons
In-Field Functions
Create Boundary
Headlands
Satellite Imagery
GPS/Steering Setup
GPS Setup
TerraStar Settings
RTK Settings
Upgrade Receiver
GPS Information
New Pattern—Pivot
TurnPath
TurnPath
TurnPath Preview
TurnPath Options
Sequence Mode
Sequences
Summary Reports
Summary Report
Event Summary
ISO Retrofit Kit
Topography
Survey
Operating Modes
On-grade Indication
Grade Control
Target
Pitch Control
Map View
Load Configuration
Creating Products
Clutch Diagnostics
Creating Products
Equipment Settings
Auxiliary Input
FAQ
Troubleshooting
General tab
Uplift Force
FAQ
Troubleshooting
Creating Products
Seed Monitor Setup
Creating Products
Setup Steps
Troubleshooting
SureDrive®
Load Configuration
Map View
SureSpeed
SureSpeed®
Load Configuration
Map View
Creating Products
Planter Options
Seed Rows
Diagnostic Screens
Row Control Module
RCM Errors
Operation
Meter Speed RPMs
Maintenance
Parts List
General tab
Advanced tab
Down Force Alarms
FAQ
Troubleshooting
Liquid Rate Control
Map View
Implement Offsets
Equipment Settings
Auxiliary Input
Hardi Safe Track
Load Configuration
Map View
Implement Offsets
Equipment Settings
Module Layouts
Implement Offsets
Hardi Safe Track
Nozzles
System Settings
ISO Liquid Module
Swath Module
Load Configuration
Map View
Load Configuration
Implement Offsets
Equipment Settings
Configuration Setup
Status Screen
Settings Screen
Injection
Map View
Load Configuration
Setup Configuration
Troubleshooting
OptRx
OptRx®
Map View
N Algorithm Setup
Sensor Setup
Sensor Setup
Installation
Norac UC5
Norac Unlock
Setup Configuration
Load Configuration
Engage button
Spreader
Spinner Spreaders
Map View
Equipment Settings
Auxiliary Input
Strip Till
Map View
Equipment Settings
Auxiliary Input
Controller Settings
Run Time Operations
Implement Offsets
Equipment Settings
Auxiliary Input
Implement Modeling
RightSpot™
RightSpot™
RightSpot Toolbox
RightSpot™ Settings
Creating Products
Active Nozzles
Implement Offsets
Equipment Settings
Auxiliary Input
Implement Modeling
Rate Settings
Alarms
General Guidelines
Safety and Notices
Operator Safety
Nozzle Selection
Maintenance
Boom Flush
Parts List
Diagnostics
Troubleshooting
Alarms
Nozzle Charts
Harvest
Map View
Lexion Quantimeter
Map View
Lexion
Bridge Module
Jaguar Quantimeter
Map View
Jaguar
Bridge Module
- Kinze Dual Auger Grain Carts 1321 1421 1521 1721 Operators Manual M0316-01 04.2024
- Kinze Dual Auger Grain Carts 1321 1421 1521 1721 Parts Manual M0316-02 04.2024
- Kinze Front Fold Planter 3700 Operators Manual M0261-01 07.2019
- Kinze Front Fold Planter 3700 Parts Manual M0261-02 11.2019
- Kinze Front Fold Planter 3705 Operators Manual M0305-01 02.2022
- Kinze Front Fold Planter 3705 Parts Manual M0305-02 02.2022
- Kinze Front Fold Planter 4700 Operators Manual M0295-01 03.2020
- Kinze Front Fold Planter 4700 Parts Manual M0295-02 03.2020
- Kinze Front Fold Planter 4705 Operators Manual M0306-01 02.2022
- Kinze Front Fold Planter 4705 Parts Manual M0306-02 02.2022
- Kinze Front Fold Planter 4900 Operators Manual M0290-01 08.2019
- Kinze Front Fold Planter 4900 Parts Manual M0290-02 08.2019
- Kinze Front Fold Planter 4905 Operators Manual M0307-01 11.2021
- Kinze Front Fold Planter 4905 Parts Manual M0307-02 11.2021
- Kinze Front Fold Planter 5700 Operators Manual M0320-01 03.2024
