Darylxd
3
22,058
Kia Optima (JFA) VIN 5XX L4-1.6L Turbo 2020 Electrical Wiring Diagrams
Brand: Kia
Type of machine: Automobile
Type of document: Electrical Wiring Diagrams
Model: 2020 Kia Optima (JFA) VIN 5XX L4-1.6L Turbo
Example VIN: 5xxgu4l11lg433067
Send an email to "gallons@autorepairmanuals.ws" or "admin@autorepairmanuals.ws" if the link doesn't work
Components (Locations)
Connector Views
Diagnostic Aids
Diagram Information and Instructions
Electrical (OE)
Electrical - Interactive Color (Non OE)
Fluid
Harness
Mechanical
Pinout Values and Diagnostic Parameters (Testing and Inspection)
Vacuum and Vapor Hose
Antilock Brakes Traction Control Systems
Antitheft and Alarm Systems
Body Control Module
Cruise Control
Doors, Hood and Trunk
Headlamp
Heating and Air Conditioning
Horn
Information Bus
Instrument Panel, Gauges and Warning Indicators
Lighting and Horns
Memory Positioning Systems
Mirrors
Navigation System
Power and Ground Distribution
Power Locks
Power Steering
Powertrain Management
Radiator Cooling Fan
Radio, Stereo, and Compact Disc
Rear Defogger
Restraints and Safety Systems
Seats
Starting and Charging
Steering Wheel
Sunroof Moonroof
Transmission and Drivetrain
Windows
Wiper and Washer Systems
Electrical (OE)
Accelerator Pedal Position Sensor
Accessories and Optional Equipment
Air Bypass Valve, Turbocharger
Air Temperature Sensor ( Ambient Intake )
Ambient Temperature Sensor Switch HVAC
Automatically Shifted Manual TransmissionTransaxle
Auxiliary Input Output Jack, Entertainment System
Blind Spot Module
Body Control Module
Body Control Systems
Brakes and Traction Control
Camshaft Position Sensor
Canister Purge Control Valve
Charging System
Cigarette Lighter
Clock
Clutch Actuator, ASMT
Collision Avoidance and Parking Assist Systems
Collision Avoidance Sensor
Control Module, ASMT
Coolant Temperature SensorSwitch (For Computer)
Crankshaft Position Sensor
Cruise Control
Cruise Control Switch
Data Link Connector
Door Locks
Door Module
Electronic Throttle Actuator
Entertainment Systems
Fuel Delivery and Air Induction
Fuel Door Release Actuator
Fuel Injector
Fuel Pressure Regulator
Fuel Pressure Sensor
Fuel Pressure SensorSwitch
Fuel Pump Control Unit
Fuel Tank Pressure Sensor
Fuse Block
Heated Glass Element
Ignition Coil
Instrument Cluster Carrier
Keyless Entry
Keyless Entry Module
Knock Sensor
Lane Departure System
Leak Detection Valve, Evaporative System
Lighting and Horns
Manifold PressureVacuum Sensor
Memory Positioning Module
Mirrors
Navigation System
Oxygen Sensor
Parking Brake System
Power Distribution Module
Power Locks
Power Mirror Switch
Power Seat Switch
Power Steering
Power Window Motor
Power Window Switch
Rain Sensor
Rear Vision Camera
Remote Start Control Module
Remote Starting System
Seat Temperature Control Module
Seats
Shift Actuator, ASMT
Shift Interlock, ASMT
Starter Motor
Starting System
Steering
Steering and Suspension
Steering Mounted Controls Assembly
Steering Wheel
Sunroof Moonroof
Tire Pressure Monitor Receiver Transponder
Traction Control Switch
Transmission Position SensorSwitch, ASMT
Transmission Speed Sensor, ASMT
Trunk Liftgate Switch
Turbo Boost Sensor
Wastegate Actuator
Windows and Glass
