Kalmar Forklift Truck DCF180-250 Workshop Manual VDCF06.01GB
Brand: Kalmar
Type of Machine: Forklift Truck
Type of Manual: Workshop Manual, Electric and Hydraulic Diagrams
Model: Kalmar DCF180-250 Forklift Truck
Part Number: VDCF06.01GB
Number of Pages: 718 Pages
Workshop Manua lDCF180-250
A Foreword
0 Complete machine
1 Engine
1 Engine
2 Transmission
8 Control system
9 Frame, body, cab and accessories
Common hydraulics
Common electrics
G Terminology and index
Brand: Kalmar
A Foreword
About the Workshop Manual
Reading instructions
About the documentation
Feedback
B SafetyGeneral safety information
Safety instructions
Environment
C Preventive maintenance0 Complete machine
1 Engine
1.1 Controls and instruments
1.1.1 Ignition
1.1.2 Accelerator
1.2 Fuel system
1.2.1 Fuel tank
1.2.2 Sensor fuel level
1.6 Air intake and exhaust outlet
1.6.1 Air cleaning system
1.6.3 Exhaust system
1.6.4 Intercooler
1.6.8 SCR system
1.6.9 Pipes and hoses
1.7 Cooling system
1.7.4 Radiator and expansion tank
1.7.5 Cooling fan
1.7.7 Coolant
1.7.8 Coolant level sensor
1.7.10 Engine heater
1.9 Control system, engine
1.9.1 Engine control unit
1.11 Start/stop
1.11.1 Starter motor
1.11.2 Stopping device
1.11.3 Automatic engine stop 5 minutes after driver's seat is em
1.11.5 Warning and engine power limitation
2 Transmission2.1 Controls and instruments
2.1.6 Gear and direction of travel selector
2.1.7 Inching
2.2 Torque converter/Clutch system
2.2.1 Flex plates
2.2.6 Break contact (opening switch) declutch
2.6 Lubrication system
2.7 Cooling system
2.7.3 Oil cooler
2.8 Control system, transmission
2.8.1 Transmission control unit (ECU 793)
2.8.2 Transmission cable harness
2.8.3 Display and menus
2.8.4 Reversing lock
2.8.5 Manual gear changing
2.8.6 Automatic gearing
2.8.7 Inching
2.8.9 Diagnostics
2.8.10 Calibration
2.8.11 Service menus
3 Power transmission3.2 Propeller shaft
3.3 Drive axle
4 Brakes4.1 Controls and instruments
4.1.1 Brake pedal
4.3 Power-assisted brake system
4.3.1 Hydraulic oil pump
4.3.2 High-pressure filter
4.3.4 Accumulator
4.3.5 Brake valve
4.3.6 Distribution block
4.3.7 Break contact (opening switch) declutch
4.3.8 Switch normally closed (NC), low brake pressure
4.3.9 Make-contact (closing switch) brake lights
4.3.10 Wheel brakes
4.3.11 Pipes and hoses
4.3.13 Accumulator charging valve
4.3.14 Shuttle valve dual brake pedals
4.5 Parking brake system
4.5.1 Hydraulic oil pump
4.5.2 High-pressure filter
4.5.3 Solenoid valve parking brake
4.5.4 Parking brake unit
4.5.5 Normally closed (NC) switch, parking brake
4.5.6 Pipes and hoses
4.8 Temperature control, cleaning and oil brake system
4.8.1 Hydraulic oil tank
4.8.2 Tank heater
4.8.3 Hydraulic oil pump
4.8.4 Accumulator charging valve
4.8.5 Distribution block
4.8.6 Wheel brakes
4.8.7 Oil cooler
4.8.12 High-pressure filter
4.8.13 Pipes and hoses
4.8.14 Hydraulic oil
5 Steering5.1 Controls and instruments
5.1.1 Steering wheel and steering wheel shaft
5.1.2 Mini-wheel
5.1.3 Joystick control
5.2 Power assisted system
5.2.1 Hydraulic oil pump
5.2.2 Priority valve
5.2.3 Steering valve
5.2.4 Steering cylinder
5.2.5 Steering axle cradle
5.2.6 Link arm
5.2.7 Wheel spindle
5.2.8 Wheel hub
5.2.11 Sensor, steering wheel movement
5.2.14 Control valve steering
5.2.15 Directional control valve, turnable driver's seat
5.2.16 Sensor turnable driver's seat
5.2.17 Pipes and hoses
6 Suspension6.2 Suspension
6.2.1 Steering axle cradle
6.2.2 Wheel spindle
6.2.3 Wheel hub
6.3 Tyres and rims
6.3.1 Tyres
6.3.2 Rim
6.3.3 Nut, washer and clamp
7 Load handling7.1 Controls and instruments
7.1.1 Control lever
7.2 Lift and lower
7.2.1 Hydraulic oil pump
7.2.3 Control valve load handling
7.2.4 Lift cylinder
7.2.5 Accumulator damping
7.2.6 Mast
7.2.7 Mast wheels
7.2.8 Chains
7.2.9 Chain wheels and hose wheels
7.2.10 Trolley
7.2.11 Load control valve
7.2.12 Pipes and hoses
7.2.14 Support roller
7.2.15 Top support roller
7.4 Side shift
7.4.1 Hydraulic oil pump
7.4.3 Control valve load handling
7.4.4 Side shift cylinder
7.4.6 Trolley
7.4.7 Pipes and hoses
7.5 Spreading (positioning)
7.5.1 Hydraulic oil pump
7.5.3 Control valve load handling
7.5.4 Flow divider
7.5.5 Spreading cylinder
7.5.6 Trolley
7.5.7 Pipes and hoses
7.7 Tilt
7.7.1 Hydraulic oil pump
7.7.3 Control valve load handling
7.7.4 Load holding valve (over-centre valve)
7.7.5 Tilt cylinder
7.7.6 Mast
7.7.7 Pipes and hoses
7.9 Load carrier
7.9.1 Lift forks
7.10 Other functions
7.10.1 Scale
8 Control system8.2 Monitoring
8.2.3 Speed limitation
8.3 Error codes
8.4 Diagnostics
8.4.1 ECU 790
8.4.2 ECU 792
8.4.4 ECU 796
8.4.5 Last alarms
8.5 Setup
8.5.1 ETC-Electronic Throttle Control (electronic throttle)
8.5.2 Automatic gearing
8.5.4 Joystick control
8.5.6 Mini-wheel
8.5.7 Electro-hydraulic servo
8.5.8 Scale
8.5.9 Monitoring
8.5.21 Turnable operator's station
8.6 Software
8.6.1 Kalmar Smart Link
9 Frame, body, cab and accessories9.1 Controls and instruments
9.1.1 Multi-function lever
9.2 Safety and emergency equipment
9.2.1 Control breaker
9.2.2 Seat belt
9.2.3 Fire extinguisher
9.2.4 Seat buzzer
9.2.5 Roof grating
9.3 Seat
9.3.1 Seat cushion
9.3.2 Back rest cushion
9.3.3 Heating coil
9.3.4 Bumper
9.3.5 Air suspension
9.3.6 Compressor air-suspension seat
9.3.7 Mechanical seat adjustment
9.3.8 Passenger seat
9.3.9 Reversible operator\qs seat
9.3.10 Rotating driver's seat
9.3.11 Arm rest
9.3.12 Directional control valve, turnable driver's seat
9.3.13 Sensor turnable driver's seat
9.3.17 Head rest
9.4 Heating, ventilation and air conditioning
9.4.1 Fresh air / recirculation valve
9.4.2 Defroster nozzles
9.4.3 Cab fan
9.4.4 Fresh air filter
9.4.5 Heat exchanger heat
9.4.6 Water valve
9.4.7 AC compressor
9.4.8 Thermostat
9.4.9 Condenser unit
9.4.10 Expansion valve
9.4.11 Evaporator
9.4.12 Sensor for ECC
9.4.13 Control unit ECC
9.4.14 Air distributor
9.4.15 Fine filter
9.4.16 Pause heater
9.4.18 Cab heater
9.4.20 Cooling unit
9.4.21 Particle and moisture filter
9.4.22 Actuator motor
9.5 Wiper/washer system
9.5.1 Wiper front
9.5.2 Wiper roof
9.5.3 Wiper rear
9.5.4 Washer motor and reservoir
9.5.5 Wiper motor front
9.5.6 Wiper motor roof
9.5.7 Wiper motor rear
9.6 Lighting system
9.6.1 Headlights
9.6.2 Running lights
9.6.3 Tail lights
9.6.4 Brake lights
9.6.5 Back-up lights
9.6.6 Direction indicators
9.6.7 Warning lamp, Hazard
9.6.8 Revolving beacon
9.6.9 Working lights, mast
9.6.10 Working lights, cab
9.6.11 Interior lighting
9.6.12 Working lights, fenders
9.6.13 Engine room lighting
9.7 Signalling system
9.7.1 Horn
9.7.2 Warning lamp, Hazard
9.7.3 Revolving beacon
9.7.4 Warning parking brake
9.7.5 Back-up alarm
9.7.6 Flashing brake light for reversing
9.8 Entertainment and communication
9.8.1 Radio with CD
9.8.2 Communication radio
9.8.3 Telephone
9.8.4 Terminal
9.8.5 Screen
9.8.6 Computer
9.8.7 Voltage converter
9.9 Glass/windows/mirrors
9.9.1 Windscreen
9.9.2 Side window
9.9.3 Roof window
9.9.4 Rear window
9.9.5 Rear view mirror
9.9.6 Protective panel in front of windscreen
9.9.8 Reversing camera
9.9.9 Monitor, reversing camera
9.10 Cab structure and suspension
9.10.1 Cab frame
9.10.2 Doors
9.10.3 Cab substructure
9.10.4 Cab tilting
9.10.5 Door stop
9.10.6 Roof and door mouldings
9.10.7 Cab tilting cylinder
9.11 Cab interior
9.11.1 Instrument and control panels
9.11.2 Interior fittings, plastic
9.11.3 Interior fittings, textile
9.11.4 Floor covering
9.11.5 Insulation
9.11.6 Sun visors
9.11.7 Terminal console
9.11.8 Writing desk
9.11.9 Compartment for A4 papers
9.11.10 Holder for pump lever
9.12 Frame
9.13 Body structure
9.13.1 Wings
9.13.2 Hood engine compartment
9.13.3 Footstep
9.13.4 Counterweight
9.13.5 Battery compartment
9.13.7 Mud guards
9.13.8 Tool kit
9.13.9 Lifting lugs
9.14 Central lubrication
9.14.1 Pump unit
9.14.2 Distribution block
9.14.3 Lines
9.14.4 Grease nipples
9.15 Paint/coatings
10 Common hydraulics10.2 Safety valves
10.2.1 Accumulator drain valve
10.2.2 Pipes and hoses
10.3 Tanks and accumulators
10.3.1 Tank
10.3.2 Accumulator
10.3.3 Sensor, low brake pressure
10.3.4 Pipes and hoses
10.4 Pumps
10.4.1 Gear pump with fixed displacement
10.4.2 Axial piston pump with variable displacement
10.4.3 Pipes and hoses
10.5 Hoses, pipes and valves
10.5.1 Pipes and hoses
10.5.3 Priority valve
10.5.4 Shuttle valve
10.5.5 Proportional valve
10.6 Temperature control, cleaning and hydraulic oil
10.6.1 Tank heater
10.6.2 Hydraulic oil cooler
10.6.3 Sensor hydraulic oil temperature
10.6.4 Make-contact (closing switch), cooling fan
10.6.5 Cooling fan
10.6.6 Thermal bypass valve
10.6.7 Breather filter hydraulic oil tank
10.6.8 High-pressure filter
10.6.9 Hydraulic oil
10.6.10 Hydraulic oil pump
10.6.11 Pipes and hoses
10.7 Other
10.7.1 Hydraulic cylinders
11 Common electrics11.1 Controls and instruments
11.1.1 Hour meter
11.2 Electric protection
11.2.1 Battery disconnector
11.2.2 Fuses
11.3 Batteries
11.3.1 Start battery
11.4 Alternator
11.4.1 Alternator
11.5 Distribution of electricity
11.5.1 Voltage feed
11.5.2 Electronic box
11.5.3 Control units
11.5.4 Operation, electrical system
11.5.5 Cable harness
11.6 Communication
11.6.1 CAN bus
11.6.2 Redundant CAN bus
11.6.3 CAN bus, driveline/axle
D Error codes1 Engine
2 Transmission
8 Control system
E SchematicsCommon hydraulics
Common electrics
A49842.0100
List of Components
F Technical dataG Terminology and index
Terminology
Index
- Kalmar DRF450 Mantenance Manual
- Kalmar DRF100 Parts Catalog
- KALMAR DCD200-300 Shop Manual
- KALMAR DRF 400-450 Maintenance Manual
- Kalmar Reach Stackers Workshop Manual,Technical Information,Parts Catalogue CD
- Kalmar Reachstackers 45t DRT450 Workshop Manual
- KALMAR DRS-4527 PARTS CATALOGUE
- Kalmar Reachstrakers 40-45t DRF 400-450 Workshop Manual
- Kalmar DCE90-180, DCE 70-23E3, 70-35E4 2006 Workshop Manual
- Kalmar Master Full Set Spare Parts Catalogue
- Kalmar DRT450 VDRT02_02GB Reachstackers Workshop Manual
- Kalmar DRF 400-450 Maintenance Manual UDRF01.02GB
- Kalmar DRF 400-450 UDRF01.04GB Maintenance Manual
- Kalmar DCE 90-180 Spare Parts Catalogue NR 138
- STILL KALMAR R70 Spare Parts Book
