Jungheinrich Forklift EKX514 EKX516k EKX516 European version Service Manual
Brand: Jungheinrich
Type of Machine: Forklift
Model: Jungheinrich EKX514 EKX516k EKX516 European version Forklift
Date: 2015-2024
List of Files:
-1 Cover
Connectors
Battery
Drive motor
Cabin
Commissioning
Electrical system
Collision protection
Brand: Jungheinrich
Date: 2015-2024
List of Files:
-1 Cover
000 000 000 00095 EN.pdf
-2 Technical DataEKX 516k Reach speeds.pdf
EKX 516k speed profiles without power module (European version).pdf
EKX 516k Travel s eed reduction based on width of turret head.pdf
-3 BrakesBrakes I brake functions 001 000 000 00087 EN.pdf
Braking deceleration and braking system principle overview 001 000 000 00119 EN.pdf
Drive brake D 1002 - Setting instructions for magnetic brake (7 Y 3).pdf
Drive brake Magnetic brake (7Y3) 001 002 216 00001 EN.pdf
JUDIT — descriptions 009 000 000 00062 EN.pdf
Stopping distances in relation to speed 001 000 000 00117 EN.pdf
Wheel brake 7Y67Y7 load wheel magnetic brake 001 038 537 00001 EN.pdf
-4 Electrical SystemConnectors
CAN bus participants (node IDs and installation locations) 002 047 075 00003 EN.pdf
Connector assignment 002 047 303 00096 EN.pdf
Dia nostics and CAN bus anal sis 009 000 000 00065 EN.pdf
MQS connectors 002 047 303 00116 EN.pdf
SAAB connectors 002 047 303 00036 EN.pdf
VW connectors 002 047 303 00107 EN.pdf
Control elementsChanging the access type (key switch - electronic system) 002 041 540 00021 EN.pdf
Control panel 002 006 050 00002 EN.pdf
Control panel tilt adjusting unit 002 006 000 00014 EN.pdf
Deadman switch — rectangular version 002 006 318 00001 EN.pdf
ControllerController JET-MIF (A3) 002 000 000 00114 EN.pdf
Controller JET-PID (IJ8) 002 000 000 00113 EN.pdf
JET - emergency stop circuit 002 000 000 00109 EN.pdf
Switch-on routine 002 000 000 00108 EN.pdf
DisplayBattery discharge indicator 002 003 035 00001 EN.pdf
Jungheinrich fleet management systemsArrangement - ISM Online component assembly 002 053 000 00034 EN.pdf
ISM Online — adjusting the length of the access codes — Group display (EasyAccess) 002 003 020 00017 EN.pdf
Layout — assembly of the telematics components 002 053 553 00001 EN.pdf
Miscellaneous electricalFuses (control current fuses main current fuse) 002 044 294 00025 EN.pdf
Temperatures and DC intermediate circuit voltages 002 044 542 00019 EN.pdf
Service manual item 3 6900.08Colour coding key — wire colours 3690008g.pdf
-5 Power SupplyBattery
See section D Battery — Maintenance Recharging Replacement in the operating instructions 52374866_EN.pdf
Setting the sensor (2B52) for the comfort charging socket (lithium-ion battery) 003 004 504 00044 EN.pdf
JUDIT — descriptionsSetting and description in JUDIT 003 028 098 00015 EN.pdf
On-board chargerbus barsCurrent collectors bus bars and power transfer distributor boxes 003 028 098 00008 EN.pdf
On-board charger ATECH Zivan NG9 003 028 098 00004 EN.pdf
On-board charger GFTI D80-150 HRS - TOP 003 028 098 00007 EN.pdf
-6 TravelDrive motor
Drive motor 1M1 004 014 474 00006 EN.pdf
Electrical systemCombi sensor (speed and temperature) 004 013 000 00013 EN.pdf
Speed Sensors 1B10 and 1B11 004 013 000 00018 EN.pdf
JUDIT — descriptionsAdjustment and description of the travel behaviour in JUDI 004 101 000 00001 EN.pdf
Adjustment and description of the travel functions in JUDI 009 000 000 00062 EN.pdf
Description of the arameters and controller sets 009 000 000 00080 EN.pdf
SpeedProfile+ 004 101 000 00003 EN.pdf
TransmissionReplacing the wheel bolts 004 036 535 00002 EN.pdf
Single Wheel Transmission 004 036 140 00015 EN.pdf
Transmission oil re lacement 004 036 140 00005 EN.pdf
Wheelsdrive wheel 004 039 019 00020 EN.pdf
E1001G Vulkollan Wheel Wear Limits.pdf
Load wheels 004 039 198 00018 EN.pdf
Rail guidance rollers 004 039 273 00009 EN.pdf
-7 Truck DesignCabin
Cold store cabin (EKX 514 - EKX 516 005 026 269 00004 EN.pdf
Chassis basic unitStatic eliminator 005 040 539 00001 EN.pdf
Collision protectionDisassembling assembling and aligning the sensor head 009 058 552 00012 EN.pdf
Effect of drive wheel wear on the laser scanner beam height 009 058 552 00013 EN.pdf
Field kits monitoring cases 009 058 552 00007 EN.pdf
General descri tion 009 058 552 00001 EN.pdf
JUDIT settings during commissioning and FEM inspection of JET trucks 009 058 552 00010 EN.pdf
Position and number of reflectors 009 058 552 00002 EN.pdf
Retrofitting the collision protection function 009 058 552 00003 EN.pdf
SICK Flexi Soft PLC 009 058 552 00011 EN.pdf
SICK software description 009 058 552 00005 EN.pdf
Test specimen checklist 009 058 552 00006 EN.pdf
Hydraulic Operations\Auxiliary liftAdjusting the auxiliary mast mechanical 90 end stops 006 051 000 00002 EN.pdf
Auxiliary lift cylinder cylinder piston 006 051 362 00002 EN.pdf
Auxiliary lift height sensor (2B53) 006 051 290 00005 EN.pdf
Disassembly or assembly of the auxiliary mast 006 051 000 00007 EN.pdf
Replacing the seal kit on the auxiliary lift cylinder head 006 051 362 00001 EN.pdf
Replacing the sensor comb on the auxiliary lift 006 051 558 00001 EN.pdf
Hydraulic Operations\Electrical system3-channel height measurement sensor at operator position (2B43) 006 013 290 00022 EN.pdf
Deflection of spring on mast cable 006 013 000 00007 EN.pdf
Description of the 3-channel height measurement sensor 006 013 290 00009 EN.pdf
Main lift sensor bearing 006 013 290 00023 EN.pdf
Operator position carriage sensor bearing 006 013 290 00022 EN.pdf
Replacing the sensor bearing 006 013 290 00004 EN.pdf
Slack chain switch 006 013 274 00005 EN.pdf
Hydraulic Operations\Floor Pro Sideshift PlusComponent overview 006 043 541 00002 EN.pdf
Double rod cylinder 006 043 541 00006 EN.pdf
Floor Pro Sideshift Plus 006 043 541 00009 EN.pdf
Functional description 006 043 541 00001 EN.pdf
Initiators 006 043 541 00003 EN.pdf
Pull cylinder with bolt 006 043 541 00008 EN.pdf
Push rod 006 043 541 00007 EN.pdf
Swivel traverse frame in the operator position 006 043 541 00005 EN.pdf
Terminal diagram and hydraulic control block 006 043 541 00004 EN.pdf
Hydraulic Operations\Hydraulic systemAspirating or bleeding the hydraulic system 006 023 106 00012 EN.pdf
Bleeding the hydraulic cylinders 006 023 106 00003 EN.pdf
Bleeding the traverse oil motor and rotary drive 006 023 106 00013 EN.pdf
Changing the hydraulic oil filter 006 023 118 00002 EN.pdf
Checking the hydraulic hoses 006 023 160 00002 EN.pdf
Fittin s stem EO-3 with visible indication of assembl 006 023 160 00003 EN.pdf
Hydraulic control block H1 in drive compartment 006 023 332 00042 EN.pdf
Hydraulic control block H2 in the operator position 006 023 332 00043 EN.pdf
Hydraulic motor 2M1 006 023 244 00012 EN.pdf
Hydraulic oil volumes in the complete hydraulic system and hydraulic reservoir 006 023 000 00046 EN.pdf
Pressure relief valve on the hydraulic control block H1 in the drive compartment 006 023 000 00060 EN.pdf
Pressure relief valves on the hydraulic control block H2 in the operator position 006 023 000 00059 EN.pdf
Hydraulic Operations\JUDIT — descriptionsDescription and teach-in of the weigher weight measurement in JUDIT 006 057 000 00001 EN.pdf
Description of the parameters and controller sets for the combination controller (IJ8) 009 000 000 00080 EN.pdf
Rotate function 006 043 541 00011 EN.pdf
Rotate traverse function 006 043 541 00012 EN.pdf
Setpoints of hydraulic controller 009 000 000 00059 EN.pdf
Hydraulic Operations\Load handlerFork carriage 006 029 128 00008 EN.pdf
Fork positioner 006 029 355 00001 EN.pdf
Forks G140101G.pdf
Measuring and adjusting the clearance height (mechanical) 006 029 000 00017 EN.pdf
Secure the load handler (fork carriage) to the auxiliary mast 005 042 000 00024 EN.pdf
Telescopic tablel 006 029 528 00006 EN.pdf
Hydraulic Operations\Mast hydraulicReplacing the gasket set on the lift cylinder head 006 021 000 00002 EN.pdf
Hydraulic Operations\Mast mechanicalAssembly and disassembly of the mast on the truck chassis 006 022 000 00040 EN.pdf
Chains (for load-chain elongation testing see G 6355.01 ).pdf
Disassembling assembling the mast rollers 006 022 222 00005 EN.pdf
Mast rollers with eccentrics (eccentric rollers) 006 022 222 00007 EN.pdf
Mast rollers with plastic slide pieces 006 022 000 00005 EN.pdf
Operator position guide rollers 006 022 000 00041 EN.pdf
Replacement Of the pulleys 006 021 277 00001 EN.pdf
Replacing the lift chains 006 022 172 00013 EN.pdf
Setting the chain tensioner 006 022 172 00005 EN.pdf
Hydraulic Operations\Swivel traversePower supply chain 006 043 000 00021 EN.pdf
Replacing the support rollers 006 043 000 00004 EN.pdf
Rotary drive 006 043 000 00016 EN.pdf
Rotate actual value transmitter (8U28) 006 043 292 00005 EN.pdf
Swivel-traverse frame 006 043 000 00017 EN.pdf
Tool 006 043 541 00019 EN.pdf
Traverse actual value transmitter (8U29) 006 043 291 00006 EN.pdf
Traverse reference sensor 2B11 006 043 291 00007 EN.pdf
Turret head Disassembly Assembly Configuration 006 043 000 00019 EN.pdf
Turret head Replacing the self-aligning bearings 006 043 000 00020 EN.pdf
Lock washersNord-Lock lock washers 005 000 000 00013 EN.pdf
Operator platformHigh-tensile steel S700MC 005 016 112 00007 EN.pdf
Left and right fall-bar magnetic switches (7B1 - 7B2) 005 016 287 00006 EN.pdf
Removal and installation of the operator position (DZ mast) 005 016 112 00009 EN.pdf
Removal and installation of the operator position (Z T mast) 005 016 112 00008 EN.pdf
Removal and installation of the operator position driver's seat 005 016 178 00001 EN.pdf
Replacement of the operator position support rollers 005 016 112 00010 EN.pdf
Safety devicesFall Protection Equipment 005 042 000 00015 EN.pdf
Mast bracing - anchoring 005 042 156 00005 EN.pdf
Mechanical tilt safety device 005 042 309 00006 EN.pdf
Personal protection system (PPS) — checklist 005 042 000 00006 EN.pdf
Personal protection system (PPS) — disassembly or assembly general description 005 042 000 00009 EN.pdf
Personal protection system (PPS) — front window cleaning and replacement 005 042 000 00003 EN.pdf
Personal protection system (PPS) — protection field and warning field switching 005 042 000 00007 EN.pdf
Personal protection system (PPS) — seven-segment and indicator displays 005 042 000 00005 EN.pdf
Personal protection system (PPS) — software and parameterisation 005 042 000 00004 EN.pdf
Rescue Equipment 005 042 000 00047 EN.pdf
Securing the operator position and mast 005 042 000 00011 EN.pdf
Skylotec rescue equipment 005 042 000 00016 EN.pdf
-8 Commissioning Maintenance Customer Service DepartmentCommissioning
Assembl and disassembl of the mast on the truck chassis 006 022 000 00040 EN.pdf
Guided commissioning 007 025 559 00002 EN.pdf
Instruction 007 025 103 00001 EN.pdf
Miscellaneous maintenanceCrack inspection on weld seams (visual inspection) 007 050 549 00001 EN.pdf
SafetyJ690009g.pdf
Z000015g.pdf
-9 SteeringElectrical system
Steer an le sensor 3B19 008 013 208 00002 EN.pdf
Steering actual value transmitter (3U9) 008 013 166 00004 EN.pdf
Steering actual value transmitter (3U9) 008 013 166 00011 EN.pdf
JUDIT — descriptionsAdjustment and description of the steering functions in JUDIT 009 000 000 00060 EN.pdf
Description of the parameters and controller sets for the combination controller (U8) 009 000 000 00080 EN.pdf
Steering transmissionSteer motor (3M 1) steering transmission 008 032 000 00007 EN.pdf
-10 System componentsCollision protection
General description 009 058 552 00001 EN.pdf
EKX 514a - EKX 516a - automated moving truckApron field configuration 009 000 000 00076 EN.pdf
Automatic control 009 000 000 00041 EN.pdf
Fine positioning 009 000 000 00075 EN.pdf
Guide to commissioning 009 000 000 00079 EN.pdf
Settin and description in JUDIT 003 028 098 00015 EN.pdf
Setting up the calibration station 009 000 000 00045 EN.pdf
System interface 009 000 000 00077 EN.pdf
Update to the Siemens touch panel 009 000 000 00066 EN.pdf
Ground systemHorizontal osition detection RFID system 009 008 000 00004 EN.pdf
Horizontal position detection RFID system 009 008 000 00004 EN.pdf
Installing the RFID memory modules in the narrow aisle floor 009 008 000 00010 EN.pdf
L 2002 - WG frequency generator emergency power supply.pdf
Optical aisle recognition 009 008 130 00001 EN.pdf
RFID reader 009 008 000 00020 EN.pdf
WG sensors 009 008 000 00019 EN.pdf
JUDIT — descriptions(pararneter file) 009 000 000 00069 EN.pdf
Changing the access type (key switch electronic system) 002 041 540 00021 EN.pdf
Dia nostics and CAN bus analysis009 000 000 00065 EN.pdf
EasyAccess Standalone — connection between service computer and Maxi display 009 000 000 00085 EN.pdf
Error memory 009 000 000 00064 EN.pdf
Installing operating systems 009 000 000 00057 EN.pdf
Installing the configuration with formulation (from LS 10 09) 009 000 000 00096 EN.pdf
Installing the configuration with update files 009 000 000 00097 EN.pdf
Loading the configuration with formulation (to LS 10 09) 009 000 000 00068 EN.pdf
Node ID of CAN bus com onents 009 000 000 00058 EN.pdf
Opening JUDIT 009 000 000 00056 EN.pdf
Parameter assignment 009 000 000 00034 EN.pdf
Service parameters 009 000 000 00061 EN.pdf
Warehouse naviation 009 000 000 00005 EN.pdf
- Lexcom Security Control Client v1.4.4.0 KG
- Jungheinrich Forklift EJC M10 EJE M13 Electric & Hydraulic Schematic
- Jungheinrich ERE 120 51222183 Service Manual
- EJC 145 Part Manual
- Jungheinrich Forklift EJE 116 120 Electric & Hydraulic Schematic
- JUNGHEINRICH DFG 430 G105-310ZZ Operating Instructions & Spare Parts Manual
- Jungheinrich Forklift EJC 110 112 Electric & Hydraulic Schematic
- Jungheinrich EJD 220 51132781 Service Manual
- Jungheinrich Forklift SLH 40-300 Operating Manual_DE
- Jungheinrich Forklift EFG-Vac 22 25 30 Operating Manual
- Jungheinrich DFG/TFG 660-690 Service Manual
- Jungheinrich_ETV_214_Spare_Parts_And_Instruction_Manual
- Jungheinrich Forklift EFG Operating Manual_DE
- JUNGHEINRICH ERC 214 Operating Instructions & Spare Parts Manual
- Jungheinrich_ECE_225_Spare_Parts_And_Instruction_Manual
