John Deere Tractors 8R RW Series 8245R to 8400R Diagnosis and Tests Service Manual TM119019
Martin Welker
104
230,310
Brand: John Deere
Type of Machine: Tractors
Type of Manual: Diagnosis and Tests Service Manual, Circuit Diagrams
Model: John Deere 8R RW Series 8245R 8270R 8295R 8320R 8335R 8345R 8370R 8400R Tractors
Serial Number: (090001-119999), Russia (055001-058000), Brazil (000100-)
Number of Page: 7081 pages
Parts Number: TM119019
Introduction
Foreword
Contents
Safety
Recognize Safety Information
Understand Signal Words
Follow Safety Instructions
Wear Protective Clothing
Service Machines Safely
Stay Clear of Rotating Drivelines
Prevent Battery Explosions
Prepare for Emergencies
Handle Starting Fluid Safely
In Case of Fire
Avoid Static Electricity Risk When Refueling
Avoid Hot Exhaust
Clean Exhaust Filter Safely
Prevent Acid Burns
Clean Vehicle of Hazardous Pesticides
Handling Batteries Safely
Avoid Harmful Asbestos Dust
Avoid High-Pressure Fluids
Wait Before Opening High-Pressure Fuel System
Diesel Exhaust Fluid (DEF) — Use in Selective Catalytic Reduction (SCR) Equipped Engines
Disposal of Diesel Exhaust Fluid (DEF)
Refilling Diesel Exhaust Fluid (DEF) Tank
Storing Diesel Exhaust Fluid (DEF)
Testing Diesel Exhaust Fluid (DEF)
Protect Against High Pressure Spray
Service Cooling System Safely
Prevent Machine Runaway
Keep ROPS Installed Properly
Avoid Backover Accidents
Park Machine Safely
Support Machine Properly
Work in Clean Area
Work In Ventilated Area
Illuminate Work Area Safely
Use Proper Lifting Equipment
Service Tires Safely
Instructional Seat
Service Front-Wheel Drive Tractor Safely
Transport Tractor Safely
Practice Safe Maintenance
Use Proper Tools
Replace Safety Signs
Install All Guards
Live With Safety
General References
Trademarks
Information Available in Sections, Groups and Subgroups
Regions and Countries
References for Technical Information
Diagnostic Philosophy
Basic Diagnostic Philosophy
SEVEN BASIC STEPS
Know the System
Ask the Operator
Inspect the System
Operate the Machine (if possible)
List the Possible Causes
Reach a Conclusion
Test the Conclusion
TROUBLESHOOTING UNRESOLVED PROBLEMS
Problems Due to Specific Operating Conditions
Problems Due to Intermittent Electrical Failures
Problems Due to Control Unit Failures
Systematic Diagnostic Approach Overview
1—Verify Customer Concern
2—Visual Inspection
3—Recall DTCs
4—Perform DTAC Solution Search
5a—Active DTCs
5b—No DTCs
5c—Intermittent or Stored DTCs
5d—Operating as Designed
5e—No Published Diagnostics
6—Re-examine Concern
7—Repair and Verify Repair
Diagnostic Trouble Codes
Armrest Interface Control Software Diagnostic Trouble Codes (AIC)
AIC 000158.03— Switched Supply Voltage High
AIC 000158.04— Switched Supply Voltage Low
AIC 000168.03— AIC Unswitched Supply Voltage High
AIC 000168.04— AIC Unswitched Supply Voltage Low
AIC 000628.12— AIC Programming
AIC 000629.12— AIC Control Unit Fault
AIC 000639.12— Vehicle CAN Bus Fault
AIC 000639.14— CAN Bus Error Limit Exceeded
AIC 002007.09— RPT Message Missing
AIC 002036.09— PTF Message Missing
AIC 003509.03— AIC 5 V Sensor Supply 1 Voltage High
AIC 003509.04— AIC 5 V Sensor Supply 1 Voltage Low
AIC 003509.06— AIC 5 V Sensor Supply 1 Current High
AIC 003510.03— AIC 5 V Sensor Supply 2 Voltage High
AIC 003510.04— AIC 5 V Sensor Supply 2 Voltage Low
AIC 003510.06— AIC 5 V Sensor Supply 2 Current High
AIC 516315.09— Armrest Engine Speed Control Module Message Missing
AIC 516316.06— AIC 12 V Sensor Supply 1 Current High
AIC 516317.06— AIC 12 V Sensor Supply 2 Current High
AIC 516446.09— Armrest Multi-Function Lever Module Message Missing
AIC 516461.02— SCV XV Control Lever Switch/Sensor Conflict
AIC 520285.02— Armrest Hitch Controls Module Circuit Fault
AIC 520285.03— Armrest Hitch Controls Module Voltage High
AIC 520285.11— Armrest Hitch Controls Module Circuit Fault
AIC 520286.02— Armrest Hitch Controls Module Circuit Fault
AIC 520286.04— Armrest Hitch Controls Module Voltage Low
AIC 520286.11— Armrest Hitch Controls Module Circuit Fault
AIC 520425.07— Vehicle CAN Bus Error Counter High
AIC 520426.07— Vehicle CAN Bus Error Counter High
AIC 520542.03— Vehicle CAN Bus Circuit Voltage High
AIC 520543.04— Vehicle CAN Bus Circuit Voltage Low
AIC 520870.02— AIC Control Unit Fault
AIC 520871.02— AIC Control Unit Fault
AIC 520872.02— AIC Control Unit Fault
AIC 521133.02— e23™ Drive Lever Circuit Conflict
AIC 521133.08— e23™ Drive Lever Fault
AIC 521133.31— e23™ Drive Lever Conflict
AIC 521136.02— e23™/16 Speed PST Drive Lever Circuit Conflict
AIC 521136.08— e23™/16 Speed PST Drive Lever Fault
AIC 521136.31— e23™/16 Speed PST Drive Lever Conflict
AIC 521274.09— LIN Bus 1 Fault
AIC 521275.09— LIN Bus 2 Fault
AIC 521276.09— LIN Bus 3 Fault
AIC 521277.09— LIN Bus 4 Fault
AIC 521398.02— SCV VII Control Lever Switch/Sensor Conflict
AIC 521399.02— SCV VIII Control Lever Switch/Sensor Conflict
AIC 521401.02— Front Hitch Control Lever Switch/Sensor Conflict
AIC 521404.02— SCV XI Control Lever Switch/Sensor Conflict
AIC 521405.02— SCV XII Control Lever Switch/Sensor Conflict
AIC 521406.02— SCV XIII Control Lever Switch/Sensor Conflict
AIC 521407.02— SCV XIV Control Lever Switch/Sensor Conflict
AIC 521408.02— Armrest Hitch Controls Module Switch Conflict
AIC 521409.02— Armrest Multi-Function Lever Module Circuit Fault
AIC 521410.02— Armrest Multi-Function Lever Module Circuit Fault
AIC 521411.02— Armrest Multi-Function Lever Module Circuit Fault
AIC 521412.02— Armrest Multi-Function Lever Module Circuit Fault
AIC 521413.02— Armrest Multi-Function Lever Module Circuit Fault
AIC 521421.02— Armrest Hitch Controls Module Circuit Fault
AIC 521422.02— Armrest Hitch Controls Module Circuit Fault
AIC 521465.09— Armrest Engine Speed Control Module Message Missing
AIC 521475.02— Armrest Rear Hitch Setup Controls Module Circuit Fault
AIC 521476.02— Armrest Rear Hitch Setup Controls Module Circuit Fault
AIC 521480.02— Armrest Rear Hitch Setup Controls Module Circuit Fault
AIC 521570.09— Armrest Rear Hitch Setup Controls Module Message Missing
AIC 521571.09— Armrest Front Left Module Message Missing
AIC 521572.09— Armrest Front Middle Module Message Missing
AIC 521573.09— Armrest Front Right Module Message Missing
AIC 521574.09— Armrest Middle Right Module Message Missing
AIC 521577.09— Armrest Rear Right Module Message Missing
AIC 522189.02— iTEC™ Switch Circuit Fault
AIC 522549.02— Armrest Engine Speed Control Module Circuit Conflict
AIC 522551.02— Armrest Engine Speed Control Module Circuit Conflict
AIC 522553.02— Armrest Engine Speed Control Module Circuit Conflict
AIC 522769.09— Armrest Hitch Controls Module Message Missing
AIC 523349.02— AutoTrac™ Resume Switch Conflict
AIC 523652.09— Armrest Engine Speed Control Module Message Missing
AIC 523670.02— Speed Band 1 and 2 Switches Conflict
AIC 523670.11— Drive Lever in Gear at Startup
AIC 523671.02— Drive Lever Circuit Conflict
AIC 523671.07— Drive Lever Adjustment Fault
AIC 523671.13— AIC Calibration Fault/Not Calibrated
AIC 523775.02— Multi-Function Lever Hand Presence Switch Circuit Fault
AIC 523776.02— Multi-Function Lever Transport Lock Switch Circuit Fault
AIC 523804.02— Multi-Function Lever Lateral Detent Switch Circuit Fault
AIC 523804.03— Multi-Function Lever Lateral Sensor Circuit Voltage High
AIC 523923.02— SCV I Control Lever Switch/Sensor Conflict
AIC 523953.02— Speed Control Lever Sensor Circuit Conflict
AIC 523953.03— Speed Control Lever Sensor Voltage High
AIC 523953.04— Speed Control Lever Sensor Voltage Low
AIC 523954.11— Set Speed Adjuster Conflict
AIC 524017.31— Right-Hand Reverser Circuit Fault
AIC 524019.31— Right Hand Reverser Neutral/Not-Neutral Transition Fault
AIC 524020.31— Transmission in Gear at Power Up
AIC 524021.31— Multiple Reverser Switches Conflict
AIC 524096.02— Armrest Engine Speed Control Module Message Fault
AIC 524096.03— Armrest Engine Speed Control Module Voltage High
AIC 524096.04— Armrest Engine Speed Control Module Voltage Low
AIC 524101.02— SCV VI Control Lever Switch/Sensor Circuit Conflict
AIC 524102.02— SCV V Control Lever Switch/Sensor Circuit Conflict
AIC 524103.02— SCV IV Control Lever Switch/Sensor Circuit Conflict
AIC 524104.02— SCV III Control Lever Switch/Sensor Circuit Conflict
AIC 524104.09— SCV III Control Lever Switch/Sensor Circuit Conflict
AIC 524105.02— SCV II Control Lever Switch/Sensor Circuit Conflict
AIC 524212.02— Rear Hitch Control Lever Switch/Sensor Circuit Conflict
ActiveSeat Control Software Diagnostic Trouble Codes (ASU)
ASU 000628.02— EOL Data Fault
ASU 000628.12— ASU Programming
ASU 000920.03— Compressor Bleed Valve Circuit Voltage High
ASU 000920.06— Compressor Bleed Valve Circuit Current High
ASU 000921.03— Compressor Motor Relay Circuit Voltage High
ASU 000921.06— Compressor Motor Relay Circuit Current High
ASU 516802.03— Compressor Motor Relay Circuit Voltage High
ASU 516802.06— Compressor Motor Relay Circuit Current High
ASU 516803.03— Compressor Bleed Valve Circuit Voltage High
ASU 516803.06— Compressor Bleed Valve Circuit Current High
ASU 520870.02— ASU Control Unit Fault
ASU 524002.31— ActiveSeat™ Pressure Control Solenoid Fault
ASU 524003.02— ActiveSeat™ Firmness Control Switch Circuit Fault
ASU 524004.02— ActiveSeat™ Height Control Switch Circuit Fault
ASU 524006.08— ActiveSeat™ Vent ON Too Long
ASU 524007.08— ActiveSeat™ Compressor Assembly ON Too Long
ASU 524008.13— ASU Not Calibrated
ASU 524010.31— ActiveSeat™ Raise/Lower Solenoid Circuit Fault
ASU 524011.03— ActiveSeat™ Accelerometer Circuit Voltage High
ASU 524011.04— ActiveSeat™ Accelerometer Circuit Voltage Low
ASU 524011.08— ActiveSeat™ Accelerometer Circuit Fault
ASU 524012.03— ActiveSeat™ Position Sensor Circuit Voltage High
ASU 524012.04— ActiveSeat™ Position Sensor Circuit Voltage Low
Automatic Temperature Control Software Diagnostic Trouble Codes (ATC)
ATC 000158.03— Switched Supply Voltage High
ATC 000158.04— Switched Supply Voltage Low
ATC 000170.03— Cab Temperature Sensor Circuit Voltage High
ATC 000170.04— Cab Temperature Sensor Circuit Voltage Low
ATC 000628.12— ATC Programming
ATC 000639.14— ATC CAN Error Limit Exceeded
ATC 000871.03— Refrigerant Pressure Sensor Circuit Voltage High
ATC 000871.04— Refrigerant Pressure Sensor Circuit Voltage Low
ATC 000871.13— Refrigerant Pressure Out of Range Low
ATC 000871.18— Refrigerant Pressure Extremely Low
ATC 000876.03— Compressor Clutch Circuit Voltage High
ATC 000876.04— Compressor Clutch Circuit Voltage Low
ATC 000876.10— Excessive A/C Clutch Cycling
ATC 000876.14— Compressor Shutoff Due to Engine Overheat
ATC 000923.03— Circulation Blower Motor Circuit Voltage High
ATC 000923.04— Circulation Blower Motor Circuit Voltage Low
ATC 000923.12— Circulation Blower Motor Driver Circuit Fault
ATC 001546.03— Water Valve Position Sensor Circuit Voltage High
ATC 001546.04— Water Valve Position Sensor Circuit Voltage Low
ATC 001547.03— Evaporator Temperature Sensor Circuit Voltage High
ATC 001547.04— Evaporator Temperature Sensor Circuit Voltage Low
ATC 001548.03— Outlet Air Temperature Sensor Circuit Voltage High
ATC 001548.04— Outlet Air Temperature Sensor Circuit Voltage Low
ATC 001549.03— Water Valve Motor Circuit Voltage High
ATC 001549.04— Water Valve Motor Circuit Voltage Low
ATC 001549.07— Water Valve Motor Mechanical Fault
ATC 001549.13— Water Valve Motor Not Calibrated
ATC 001551.03— Pressurizer Blower Motor Circuit Voltage High
ATC 001551.04— Pressurizer Blower Motor Circuit Voltage Low
ATC 002000.09— ECU Message Missing
ATC 002071.09— CCU Message Missing
ATC 002139.09— CSM Message Missing
ATC 003509.03— ATC Sensor Supply Voltage High
ATC 003509.04— ATC Sensor Supply Voltage Low
ATC 003509.06— ATC Sensor Supply Current High
ATC 520870.02— ATC Calibration Fault/Data Invalid
ATC 520871.02— ATC Calibration Fault/Data Invalid
ATC 520872.02— ATC Calibration Fault/Data Invalid
ATC 523848.03— Air Flow Mode Motor Circuit Voltage High
ATC 523848.04— Air Flow Mode Motor Circuit Voltage Low
ATC 523848.05— Air Flow Mode Motor Circuit Current Low
ATC 523848.06— Air Flow Mode Motor Circuit Current High
ATC 523848.07— Air Flow Mode Motor Mechanical Fault
ATC 523848.13— Air Flow Mode Motor Not Calibrated
ATC 524202.03— Ambient Temperature Sensor Circuit Voltage High
ATC 524202.04— Ambient Temperature Sensor Circuit Voltage Low
ATC 524219.03— Fogging Sensor Circuit Voltage High
Chassis Control Software Diagnostic Trouble Codes (CCU)
CCU 000096.03— Fuel Level Sensor Circuit Voltage High
CCU 000096.04— Fuel Level Sensor Circuit Voltage Low
CCU 000096.17— Fuel Level Low
CCU 000126.00— Transmission Filter Restricted
CCU 000158.03— Switched Supply Voltage High
CCU 000158.04— Switched Supply Voltage Low
CCU 000168.03— Unswitched Supply Voltage High
CCU 000168.04— Unswitched Supply Voltage Low
CCU 000237.02— VIN Security Data Conflict
CCU 000237.12— VIN Security: more than one ECU address claimed
CCU 000237.14— VIN Security Not Enabled
CCU 000237.31— VIN Security Messages Missing
CCU 000567.03— Front Differential Lock Solenoid Supply Voltage High
CCU 000567.05— Front Differential Lock Solenoid Current Low
CCU 000567.06— Front Differential Lock Solenoid Current High
CCU 000569.03— Rear Differential Lock Solenoid Supply Voltage High
CCU 000569.06— Rear Differential Lock Solenoid Current High
CCU 000628.02— CCU EOL Data Fault
CCU 000628.12— CCU Programming
CCU 000630.13— CCU Calibration Fault/Not Calibrated
CCU 001069.02— SRI Tire Value Mismatch
CCU 001086.03— Air Trailer Brake Pressure Sensor Circuit Voltage High
CCU 001086.04— Air Trailer Brake Pressure Sensor Circuit Voltage Low
CCU 001086.16— Air Trailer Brake Pressure High
CCU 001086.18— Air Trailer Brake Pressure Low
CCU 001638.00— Hydraulic Oil Temperature Very Hot
CCU 001638.03— Hydraulic Oil Temperature Sensor Circuit Voltage High
CCU 001638.04— Hydraulic Oil Temperature Sensor Circuit Voltage Low
CCU 001638.16— Hydraulic Oil Temperature Hot
CCU 002019.09— XSC Messages Missing
CCU 002049.09— OIC Messages Missing
CCU 002139.09— CSM Messages Missing
CCU 002198.09— XMA Messages Missing
CCU 002602.01— Hydraulic Oil Level Extremely Low
CCU 003511.03— CCU Sensor Supply Voltage High
CCU 003511.04— CCU Sensor Supply Voltage Low
CCU 003512.03— CCU Sensor Supply Voltage High
CCU 003512.04— CCU Sensor Supply Voltage Low
CCU 003597.02— Wake up Signal Voltage Low
CCU 520870.02— CCU Control Unit Fault
CCU 522847.03— Air Trailer Brake Solenoid Circuit Voltage High
CCU 522847.06— Air Trailer Brake Solenoid Current High
CCU 523219.03— CCU Valve Power Unswitched Voltage High
CCU 523219.04— CCU Valve Power Unswitched Voltage Low
CCU 523916.02— Hydraulic Oil Filter Restriction Sensor Circuit Fault
CCU 523916.03— Hydraulic Oil Filter Restriction Sensor Circuit Voltage High
CCU 523916.04— Hydraulic Oil Filter Restriction Sensor Circuit Voltage Low
CCU 523916.15— Hydraulic Oil Filter Restricted
CCU 523916.16— Hydraulic Oil Filter Restriction Sensor Bypassed
CCU 524191.03— Air Trailer Brake Solenoid Circuit Voltage High
CCU 524191.05— Air Trailer Brake Solenoid Current Low
CCU 524191.06— Air Trailer Brake Solenoid Current High
CCU 524235.03— MFWD Solenoid Circuit Voltage High
CCU 524235.06— MFWD Solenoid Current High
Cab Load Center Software Diagnostic Trouble Codes (CLC)
CLC 000158.01— CLC Switched Supply Voltage Low With Engine On
CLC 000444.06— CLC Unswitched Supply Voltage Low
CLC 000628.02— CLC EOL Data Fault
CLC 000630.13— CLC Calibration Fault/Not Calibrated
CLC 000920.03— Warning Horn Circuit Voltage High
CLC 000920.06— Warning Horn Circuit Current High
CLC 001487.06— Backlight Circuit Current High
CLC 001865.09— ELX Message Missing
CLC 002000.09— ECU Message Missing
CLC 002025.09— ATC Message Missing
CLC 002040.09— PDU Message Missing
CLC 002050.06— CLC Circuit Current High
CLC 002055.09— RLC Message Missing
CLC 002071.09— CCU Message Missing
CLC 002140.09— AIC Message Missing
CLC 002145.09— FCC Message Missing
CLC 002240.09— TEC Message Missing
CLC 002368.03— Left Extremity Turn Signal Light Circuit Voltage High
CLC 002368.05— Left Extremity Turn Signal Light Circuit Current Low
CLC 002368.06— Left Extremity Turn Signal Light Circuit Current High
CLC 002370.03— Right Extremity Turn Signal Light Circuit Voltage High
CLC 002370.05— Right Extremity Turn Signal Light Circuit Current Low
CLC 002370.06— Right Extremity Turn Signal Light Circuit Current High
CLC 002372.03— Brake Lights Circuit Voltage High
CLC 002372.05— Brake Lights Circuit Current Low
CLC 002372.06— Brake Lights Circuit Current High
CLC 002376.06— Trailer Brake Lights Circuit Current High
CLC 002378.05— Tail Lights Circuit Current Low
CLC 002378.06— Tail Lights Circuit Current High
CLC 002392.03— Back Up Alarm Circuit Voltage High
CLC 002392.06— Back Up Alarm Circuit Current High
CLC 520490.03— Implement Power Relay Module Circuit Voltage High
CLC 520490.06— Implement Power Relay Module Circuit Current High
CLC 520491.03— Implement Electronic Control Unit Power Relay Voltage High
CLC 520491.06— Implement Electronic Control Unit Power Relay Current High
CLC 520870.02— CLC Control Unit Fault
CLC 521394.03— Right Window Wiper Circuit Voltage High
CLC 521394.06— Right Window Wiper Circuit Current High
CLC 521545.03— Left Rear Inner Flood Light Circuit Voltage High
CLC 521545.05— Left Rear Inner Flood Light Circuit Current Low
CLC 521545.06— Left Rear Inner Flood Light Circuit Current High
CLC 521546.03— Left Rear Outer Flood Light Circuit Voltage High
CLC 521546.05— Left Rear Outer Flood Light Circuit Current Low
CLC 5215456.06— Left Rear Outer Flood Light Circuit Current High
CLC 521563.03— Right Rear Inner Flood Light Circuit Voltage High
CLC 521563.05— Right Rear Inner Flood Light Circuit Current Low
CLC 521563.06— Right Rear Inner Flood Light Circuit Current High
CLC 521564.03— Right Rear Outer Flood Light Circuit Voltage High
CLC 521564.05— Right Rear Outer Flood Light Circuit Current Low
CLC 521564.06— Right Rear Outer Flood Light Circuit Current High
CLC 521565.03— Trailer Work Light Circuit Voltage High
CLC 521565.06— Trailer Work Light Circuit Current High
CLC 521835.20— Control Unit Ground Circuit Fault
CLC 522620.03— Horn Circuit Voltage High
CLC 522620.05— Horn Circuit Current Low
CLC 522620.06— Horn Circuit Current High
CLC 524162.09— Brake Switch Message Missing
CLC 524259.00— CLC Temperature Above 115 Degrees Celsius
CLC 524259.15— CLC Temperature Above 85 Degrees Celsius
CLC 524259.16— CLC Temperature Above 100 Degrees Celsius
Radio Software Diagnostic Trouble Codes (CRU)
CRU 000168.03— CRU Unswitched Supply Voltage High
CRU 000237.02— VIN Security Data Conflict
CRU 000639.12— Vehicle CAN Bus Fault
CRU 000639.14— CAN Bus Error Limit Exceeded
CRU 520194.02— VIN Security Messages Missing
CRU 520772.12— Radio MP3 Fault
CRU 521156.12— XM Satellite Radio Module Fault
CRU 521780.06— USB Circuit Fault
CRU 522453.12— Bluetooth Communication Fault
CRU 524259.00— CRU Temperature Above 115 Degrees Celsius
CRU 524259.31— CRU Temperature High
Cab Suspension Control Software Diagnostic Trouble Codes (CSC)
CSC 000084.15— Wheel Speed High in Diagnostic Mode
CSC 000084.19— Wheel Speed Fault Message Received
CSC 000190.17— Engine Speed Low in Diagnostic Mode
CSC 000190.19— Engine Speed Fault Message Received
CSC 000574.19— Shift in Process Fault Message Received
CSC 000629.12— CSC Programming
CSC 000898.19— Requested Engine Speed Fault Message Received
CSC 002000.09— ECU Message Missing
CSC 002003.09— PTI or PTP Message Missing
CSC 002005.09— TII or TIP Message Missing
CSC 002006.09— EIC Message Missing
CSC 002020.09— SFA Message Missing
CSC 002049.09— OIC Message Missing
CSC 002071.09— CCU Message Missing
CSC 002145.09— FCC Message Missing
CSC 003511.03— CSC Sensor Supply Voltage High
CSC 003511.04— CSC Sensor Supply Voltage Low
CSC 003511.06— CSC Sensor Supply Current High
CSC 520542.03— Vehicle CAN Bus High Circuit Voltage High
CSC 520543.04— Vehicle CAN Bus Low Circuit Voltage Low
CSC 520870.02— CSC Control Unit Fault
CSC 520870.13— CSC Control Unit Fault
CSC 520871.02— CSC Control Unit Fault
CSC 520871.13— Cab Suspension Settings Error
CSC 520892.02— CSC Memory Data Fault
CSC 522288.03— Cab Suspension Damping Solenoid Circuit Voltage High
CSC 522288.05— Cab Suspension Damping Solenoid Current Low
CSC 522288.06— Cab Suspension Damping Solenoid Current High
CSC 522457.19— Commanded Transmission Ratio Fault Message Received
CSC 522763.19— Left Hand Reverser Lever Position Fault Message Received
CSC 523666.03— Valve Power Voltage High
CSC 523666.04— Valve Power Voltage Low
CSC 523671.19— Right Hand Reverser Lever Position Fault Message Received
CSC 523948.03— Cab Suspension Lower Solenoid Circuit Voltage High
CSC 523948.05— Cab Suspension Lower Solenoid Current Low
CSC 523948.06— Cab Suspension Lower Solenoid Current High
CSC 523949.03— Cab Suspension Raise Solenoid Circuit Voltage High
CSC 523949.05— Cab Suspension Raise Solenoid Current Low
CSC 523949.06— Cab Suspension Raise Solenoid Current High
CSC 523973.02— Cab Suspension Center Position Incorrect
CSC 523973.03— Cab Suspension Position Sensor Circuit Voltage High
CSC 523973.04— Cab Suspension Position Sensor Circuit Voltage Low
CSC 523973.07— Cab Suspension Center Position Out of Adjustment
CSC 523973.10— Cab Suspension Calibration Fault
CSC 523973.13— Cab Suspension Calibration Fault
CSC 523973.14— Cab Suspension Position Sensor Has Never Been Calibrated
CSC 523973.15— Cab Suspension Calibration Fault
CSC 523973.16— Cab Suspension Pressure Discharge Fault
CSC 523973.17— Cab Suspension Calibration Fault
CSC 523973.18— Bleeding of Cab Suspension Fault
CSC 523973.31— Cab Suspension Calibration Fault
CSC 524157.19— Right Brake Pedal Fault Message Received
CSC 524162.19— Left Brake Pedal Fault Message Received
CSC 524165.19— Desired Clutch Torque Limit Fault Message Received
CSC 524167.19— Desired Transmission Ratio Fault Message Received
Cab Switch Module Software Diagnostic Trouble Codes (CSM)
CSM 000628.02— CSM Software Fault
CSM 000629.12— CSM Software Fault
CSM 000630.02— CSM Memory Error
CSM 521160.02— Stereo Volume Decrease Button Fault
CSM 521161.02— Stereo Volume Increase Button Fault
CSM 521162.02— Stereo Track Decrease Button Fault
CSM 521163.02— Stereo Track Increase Button Fault
CSM 521164.02— HVAC Fan Speed Increase Button Fault
CSM 521165.02— Stereo Mute Button Fault
CSM 521166.02— HVAC Temperature Increase Button Fault
CSM 521167.02— HVAC Fan Speed Decrease Button Fault
CSM 521168.02— Airflow Mode On/Off Button Fault
CSM 521169.02— HVAC Temperature Decrease Button Fault
CSM 522560.02— Beacon Light Button Fault
CSM 522564.02— ISB Button Fault
CSM 522565.02— SCV Lock Button Fault
CSM 522567.02— Armrest Navigation Bar Fault
CSM 522568.02— Armrest Navigation Bar Fault
CSM 522569.02— Armrest Navigation Bar Fault
CSM 522570.02— Armrest Navigation Bar Fault
CSM 522571.02— Armrest Navigation Bar Fault
CSM 522572.02— Armrest Navigation Bar Fault
CSM 522573.02— Armrest Navigation Bar Fault
CSM 522574.02— Armrest Navigation Bar Fault
CSM 522575.02— Armrest Navigation Bar Fault
CSM 522576.02— Armrest Navigation Bar Fault
CSM 522577.02— Armrest Navigation Bar Fault
CSM 522578.02— Armrest Navigation Bar Fault
CSM 522579.02— Armrest Navigation Bar Fault
CSM 522580.02— Armrest Navigation Bar Fault
CSM 522581.02— Armrest Navigation Bar Fault
CSM 522770.09— Armrest Navigation Bar Module Message Missing
CSM 522771.09— Cab Controls Module Message Missing
CSM 523804.04— Multi-Function Lever Lateral Sensor Circuit Voltage Low
CSM 523805.02— Multi-Function Lever Fore-Aft Detent Switch Circuit Fault
CSM 523805.03— Multi-Function Lever Fore-Aft Sensor Circuit Voltage High
CSM 523805.04— Multi-Function Lever Fore-Aft Sensor Circuit Voltage Low
Engine Control Software Diagnostic Trouble Codes (ECU)
ECU 000027.03— EGR Valve Position Signal Out of Range High
ECU 000027.04— EGR Valve Position Signal Out of Range Low
ECU 000027.07— EGR Valve Desired and Actual Position Mismatch
ECU 000051.03— Air Throttle Actuator Position Signal Out of Range High
ECU 000051.04— Air Throttle Actuator Position Signal Out of Range Low
ECU 000051.07— Air Throttle Actuator Desired and Actual Position Mismatch
ECU 000051.14— Air Throttle Actuator and EGR Valve Connectors Swapped
ECU 000094.03— Low Pressure Fuel Signal Out of Range High
ECU 000094.04— Low Pressure Fuel Signal Out of Range Low
ECU 000094.16— Low Pressure Fuel Signal Moderately High
ECU 000094.17— Low Pressure Fuel Signal Slightly Low
ECU 000094.18— Low Pressure Fuel Signal Moderately Low
ECU 000097.03— Water-in-Fuel Signal Out of Range High
ECU 000097.04— Water-in-Fuel Signal Out of Range Low
ECU 000097.16— Water In Fuel Level Moderately High
ECU 000100.01— Engine Oil Pressure Signal Extremely Low
ECU 000100.02— Engine Oil Pressure is not Zero with Engine Stopped
ECU 000100.03— Engine Oil Pressure Signal Out of Range High
ECU 000100.04— Engine Oil Pressure Signal Out of Range Low
ECU 000100.18— Engine Oil Pressure Signal Moderately Low
ECU 000102.03— Manifold Pressure Signal Out of Range High
ECU 000102.04— Manifold Pressure Signal Out of Range Low
ECU 000102.07— Manifold Air Pressure Signal In Range Invalid
ECU 000103.00— VGT Speed Signal Extremely High
ECU 000103.02— VGT Speed Signal Invalid
ECU 000103.05— VGT Speed Sensor Circuit Has High Resistance
ECU 000105.00— Manifold Air Temperature Signal Extremely High
ECU 000105.03— Manifold Air Temperature Signal Out of Range High
ECU 000105.04— Manifold Air Temperature Signal Out of Range Low
ECU 000105.15— Manifold Air Temperature Signal Slightly High
ECU 000105.16— Manifold Air Temperature Signal Moderately High
ECU 000107.00— Air Filter Pressure Differential Extremely High
ECU 000107.15— Air Filter Pressure Differential Slightly High
ECU 000107.16— Air Filter Pressure Differential Moderately High
ECU 000108.02— Barometric Pressure Signal Invalid
ECU 000108.07— Barometric Pressure Signal Mismatch
ECU 000109.01— Engine Coolant Pressure Signal Extremely Low
ECU 000109.03— Engine Coolant Pressure Signal Out of Range High
ECU 000109.04— Engine Coolant Pressure Signal Out of Range Low
ECU 000109.17— Engine Coolant Pressure Signal Slightly Low
ECU 000109.18— Engine Coolant Pressure Signal Moderately Low
ECU 000109.31— Engine Coolant Pressure Signal Fault
ECU 000110.00— Engine Coolant Temperature Signal Extremely High
ECU 000110.03— Engine Coolant Temperature Signal Out of Range High
ECU 000110.04— Engine Coolant Temperature Signal Out of Range Low
ECU 000110.15— Engine Coolant Temperature Signal Slightly High
ECU 000110.16— Engine Coolant Temperature Signal Moderately High
ECU 000110.17— Engine Coolant Temperature Signal Slightly Low
ECU 000111.01— Engine Coolant Level Alarm Switch Activated at High Coolant Temperature
ECU 000111.07— Engine Coolant Level Switch Mismatch
ECU 000111.17— Engine Coolant Level Information Switch Activated
ECU 000111.18— Engine Coolant Level Alarm Switch Activated at Moderate Coolant Temperature
ECU 000157.01— Fuel Rail Pressure Signal Extremely Low
ECU 000157.02— Fuel Rail Pressure Signal in Range Invalid
ECU 000157.03— Fuel Rail Pressure Signal Out of Range High
ECU 000157.04— Fuel Rail Pressure Signal Out of Range Low
ECU 000157.12— Fuel Rail Pressure Sensor Error
ECU 000157.16— Fuel Rail Pressure Signal Moderately High
ECU 000157.17— Fuel Rail Pressure Signal Slightly Low
ECU 000157.18— Fuel Rail Pressure Signal Moderately Low
ECU 000158.12— ECU Power Down Error
ECU 000158.31— ECU ELX and Start Input Mismatch
ECU 000168.01— Unswitched Battery Voltage Extremely Low
ECU 000168.16— Unswitched Battery Voltage Moderately High
ECU 000174.00— Fuel Temperature Signal Extremely High
ECU 000174.03— Fuel Temperature Signal Out of Range High
ECU 000174.04— Fuel Temperature Signal Out of Range Low
ECU 000174.16— Fuel Temperature Signal Moderately High
ECU 000189.31— Engine Speed Derate Condition Exists
ECU 000190.00— Engine Speed Extremely High
ECU 000237.02— VIN Security Data Invalid
ECU 000237.13— VIN Option Code Security Data Conflict
ECU 000237.31— VIN Security Data Missing
ECU 000412.00— EGR Temperature Signal Extremely High
ECU 000412.03— EGR Temperature Signal Out of Range High
ECU 000412.04— EGR Temperature Signal Out of Range Low
ECU 000412.15— EGR Temperature Signal Slightly High
ECU 000412.16— EGR Temperature Signal Moderately High
ECU 000611.03— Injector Drive #1 Shorted to Voltage Source
ECU 000611.04— Injector Drive #1 Shorted to Ground
ECU 000612.03— Injector Drive #2 Shorted to Voltage Source
ECU 000612.04— Injector Drive #2 Shorted to Ground
ECU 000613.03— Fuel Pressure Control Valve Drive Shorted to Voltage Source
ECU 000613.04— Fuel Pressure Control Valve Drive Shorted to Ground
ECU 000613.31— Fuel Pressure Control Valve Drive Fault
ECU 000629.11— ECU Binary Input Error
ECU 000629.12— ECU EEPROM Error
ECU 000636.02— Camshaft Position Signal Invalid
ECU 000636.05— Camshaft Position Circuit Has High Resistance
ECU 000636.06— Camshaft Position Circuit Has Low Resistance
ECU 000636.08— Camshaft Position Signal Missing
ECU 000636.10— Camshaft Position Rate of Change Abnormal
ECU 000637.02— Crankshaft Position Signal Invalid
ECU 000637.05— Crankshaft Position Circuit Has High Resistance
ECU 000637.06— Crankshaft Position Circuit Has Low Resistance
ECU 000637.07— Crankshaft Position and Camshaft Position Signals Out of Sync
ECU 000637.08— Crankshaft Position Signal Missing
ECU 000637.10— Crankshaft Position Signal Rate of Change Abnormal
ECU 000641.00— VGT Actuator Temperature Extremely High
ECU 000641.05— VGT Actuator Drive Circuit Fault
ECU 000641.06— VGT Actuator Drive Circuit Has Low Resistance
ECU 000641.07— VGT Actuator Learn Error
ECU 000641.13— VGT Actuator Calibration Error
ECU 000647.05— Engine Fan Speed Increase Circuit Fault
ECU 000647.07— Engine Fan Speed Decrease Circuit Fault
ECU 000651.02— Injector #1 Part Number Data Invalid
ECU 000651.05— Injector #1 Circuit Has High Resistance
ECU 000651.06— Injector #1 Circuit Has Low Resistance
ECU 000651.13— Injector #1 Calibration Fault
ECU 000651.18— Injector #1 Not Responding
ECU 000652.02— Injector #2 Part Number Data Invalid
ECU 000652.05— Injector #2 Circuit Has High Resistance
ECU 000652.06— Injector #2 Circuit Has Low Resistance
ECU 000652.13— Injector #2 Calibration Fault
ECU 000652.18— Injector #2 Not Responding
ECU 000653.02— Injector #3 Part Number Data Invalid
ECU 000653.05— Injector #3 Circuit Has High Resistance
ECU 000653.06— Injector #3 Circuit Has Low Resistance
ECU 000653.13— Injector #3 Calibration Fault
ECU 000653.18— Injector #3 Not Responding
ECU 000654.02— Injector #4 Part Number Data Invalid
ECU 000654.05— Injector #4 Circuit Has High Resistance
ECU 000654.06— Injector #4 Circuit Has Low Resistance
ECU 000654.13— Injector #4 Calibration Fault
ECU 000654.18— Injector #4 Not Responding
ECU 000655.02— Injector #5 Part Number Data Invalid
ECU 000655.05— Injector #5 Circuit Has High Resistance
ECU 000655.06— Injector #5 Circuit Has Low Resistance
ECU 000655.13— Injector #5 Calibration Fault
ECU 000655.18— Injector #5 Not Responding
ECU 000656.02— Injector #6 Part Number Data Invalid
ECU 000656.05— Injector #6 Circuit Has High Resistance
ECU 000656.06— Injector #6 Circuit Has Low Resistance
ECU 000656.13— Injector #6 Calibration Fault
ECU 000656.18— Injector #6 Not Responding
ECU 000695.19— Unapproved Engine Speed Request
ECU 000970.31— Key Authentication Invalid
ECU 001075.02— Low Pressure Fuel Pump Data Erratic
ECU 001075.04— Low Pressure Fuel Pump Supply Voltage Low
ECU 001075.06— Low Pressure Fuel Pump Circuit Has Low Resistance
ECU 001075.09— Low Pressure Fuel Pump Loss of Communication
ECU 001075.12— Low Pressure Fuel Pump Data Error
ECU 001075.15— Low Pressure Fuel Pump Temperature Slightly High
ECU 001110.31— Engine Protection System Activated
ECU 001136.00— ECU Temperature Signal Extremely High
ECU 001136.02— ECU Temperature Signal Invalid
ECU 001136.16— ECU Temperature Signal Moderately High
ECU 001172.12— Intake Air Temperature Error
ECU 001176.07— Intake Air Pressure Mismatch
ECU 001176.12— Intake Air Pressure Error
ECU 001180.00— Calculated VGT Turbine Inlet Temperature Extremely High
ECU 001180.16— Calculated VGT Turbine Inlet Temperature Moderately High
ECU 001209.03— Exhaust Manifold Pressure Signal Out of Range High
ECU 001209.04— Exhaust Manifold Pressure Signal Out of Range Low
ECU 001209.07— Exhaust Manifold Pressure Mismatch
ECU 001347.01— Fuel Pressure Extremely Low
ECU 001347.05— Fuel Pressure Control valve #1 Circuit has high Resistance
ECU 001347.06— Fuel Pressure Control valve #1 Circuit has Low Resistance
ECU 001347.16— Fuel Pressure Moderatly High
ECU 001347.18— Fuel Pressure Slightly Low
ECU 001348.05— Fuel Pressure Control valve #2 Circuit has high Resistance
ECU 001348.06— Fuel Pressure Control valve #2 Circuit has Low Resistance
ECU 001550.05— Air Conditioner Compressor Current Low
ECU 001550.06— Air Conditioner Compressor Current High
ECU 001569.31— Engine Power Derate Condition Exists
ECU 001639.01— Fan Speed Signal Extremely Low
ECU 001639.16— Fan Speed Signal Extremely High
ECU 001639.18— Fan Speed Signal Moderately Low
ECU 001761.01— DEF Tank Fluid Level Signal Extremely Low
ECU 001761.03— DEF Tank Fluid Level Signal Out of Range High
ECU 001761.04— DEF Tank Fluid Level Signal Out of Range Low
ECU 001761.17— DEF Tank Fluid Level Signal Slightly Low
ECU 001761.18— DEF Tank Fluid Level Signal Moderately Low
ECU 002006.09— EIC Message Missing
ECU 002006.14— Incorrect CAN Message Received From Source Address 6
ECU 002006.19— Communication Error
ECU 002040.09— PDU Message Missing
ECU 002071.09— CCU Message Missing
ECU 002629.03— Fixed Turbocharger Compressor Outlet Temperature Signal Out of Range High
ECU 002629.04— Fixed Turbocharger Compressor Outlet Temperature Signal Out of Range Low
ECU 002630.00— Charge Air Cooler Outlet Temperature Signal Extremely High
ECU 002630.03— Charge Air Cooler Outlet Temperature Signal Out of Range High
ECU 002630.04— Charge Air Cooler Outlet Temperature Signal Out of Range Low
ECU 002630.15— Charge Air Cooler Outlet Temperature Signal Slightly High
ECU 002630.16— Charge Air Cooler Outlet Temperature Signal Moderately High
ECU 002659.02— EGR Calculated flow Invalid
ECU 002659.03— EGR Flow Signal Out of Range High
ECU 002659.04— EGR Flow Signal Out of Range Low
ECU 002659.14— EGR Flow Signal Error
ECU 002659.15— EGR Flow Signal Slightly High
ECU 002659.17— EGR Flow Signal Slightly Low
ECU 002790.16— Calculated VGT Compressor Outlet Temperature Moderately High
ECU 002791.05— EGR Valve Drive Circuit Fault
ECU 002791.06— EGR Valve Drive Circuit Has Low Resistance
ECU 002791.07— EGR Valve Desired and Actual Position Mismatch During a Learn
ECU 002791.13— EGR Valve Calibration Error
ECU 002795.02— VGT Calibration Version Invalid
ECU 002795.03— VGT Vane Position Signal Out of Range High
ECU 002795.04— VGT Vane Position Signal Out of Range Low
ECU 002795.07— VGT Vane Desired and Actual Position Mismatch
ECU 002795.10— VGT Vane Position Signal Rate of Change Abnormal
ECU 002795.13— VGT Calibration Error
ECU 002797.03— Injector High Voltage Supply #1 Out of Range High
ECU 002797.05— Injector High Voltage Supply #1 Circuit Has High Resistance
ECU 002797.06— Injector High Voltage Supply #1 Circuit Has Low Resistance
ECU 002798.03— Injector High Voltage Supply #2 Out of Range High
ECU 002798.05— Injector High Voltage Supply #2 Circuit Has High Resistance
ECU 002798.06— Injector High Voltage Supply #2 Circuit Has Low Resistance
ECU 003031.03— DEF Tank Fluid Temperature Out of Range High
ECU 003031.04— DEF Tank Fluid Temperature Out of Range Low
ECU 003031.12— DEF Tank Fluid Tank Temperature Error
ECU 003216.09— Aftertreatment Inlet NOx Loss of Communication
ECU 003216.12— Aftertreatment Inlet NOx Sensor Fault
ECU 003216.14— Aftertreatment Outlet NOx Sensor Fault
ECU 003226.09— Aftertreatment Outlet NOx Loss of Communication
ECU 003226.12— Aftertreatment Outlet NOx Sensor Fault
ECU 003226.14— Aftertreatment Outlet NOx Sensor Fault
ECU 003246.00— DPF Outlet Temperature Extremely High
ECU 003246.12— DPF Outlet Temperature Error
ECU 003251.00— DPF Differential Pressure Signal Not Responding
ECU 003251.02— DPF Differential Pressure Signal Invalid
ECU 003251.03— DPF Differential Pressure Signal Out of Range High
ECU 003251.04— DPF Differential Pressure Signal Out of Range Low
ECU 003251.07— DPF Differential Pressure Signal Invalid
ECU 003353.31— Alternator Fault
ECU 003361.03— DEF Dosing Injector Signal Out of Range High
ECU 003361.04— DEF Dosing Injector Signal Out of Range Low
ECU 003361.05— DEF Dosing Injector Circuit Has High Resistance
ECU 003361.06— DEF Dosing Injector Circuit Has Low Resistance
ECU 003361.07— DEF Dosing Injector Position Invalid
ECU 003361.31— DEF Dosing Injector Supply Pressure Unstable
ECU 003464.05— Air Throttle Actuator Drive Circuit Fault
ECU 003464.06— Air Throttle Actuator Drive Circuit Has Low Resistance
ECU 003464.07— Air Throttle Actuator Desired and Actual Position Mismatch During a Learn
ECU 003464.13— Air Throttle Actuator Calibration Error
ECU 003471.03— Fuel Dosing Control Valve Signal Out of Range High
ECU 003471.04— Fuel Dosing Control Valve Signal Out of Range Low
ECU 003471.05— Fuel Dosing Control Valve Circuit Has High Resistance
ECU 003471.07— Fuel Dosing Valve Invalid
ECU 003471.11— Fuel Dosing Control Valve Circuit Fault
ECU 003480.01— Fuel Dosing Inlet Pressure Signal Extremely Low
ECU 003480.03— Fuel Dosing Inlet Pressure Signal Out of Range High
ECU 003480.04— Fuel Dosing Inlet Pressure Signal Out of Range Low
ECU 003480.07— Fuel Dosing Inlet Pressure Signal Invalid
ECU 003480.18— Fuel Dosing Inlet Pressure Signal Moderately Low
ECU 003482.03— Fuel Dosing Shutoff Valve Signal Out of Range High
ECU 003482.04— Fuel Dosing Shutoff Valve Signal Out of Range Low
ECU 003482.05— Fuel Dosing Shutoff Valve Circuit Has High Resistance
ECU 003482.16— Fuel Dosing Shutoff Valve Stuck Open
ECU 003509.03— Sensor Supply #1 Voltage Out of Range High
ECU 003509.04— Sensor Supply #1 Voltage Out of Range Low
ECU 003510.03— Sensor Supply #2 Voltage Out of Range High
ECU 003510.04— Sensor Supply #2 Voltage Out of Range Low
ECU 003511.03— Sensor Supply #3 Voltage Out of Range High
ECU 003511.04— Sensor Supply #3 Voltage Out of Range Low
ECU 003512.03— Sensor Supply #4 Voltage Out of Range High
ECU 003512.04— Sensor Supply #4 Voltage Out of Range Low
ECU 003513.03— Sensor Supply #5 Voltage Out of Range High
ECU 003513.04— Sensor Supply #5 Voltage Out of Range Low
ECU 003514.03— Sensor Supply #6 Voltage Out of Range High
ECU 003514.04— Sensor Supply #6 Voltage Out of Range Low
ECU 003516.01— Aftertreatment DEF Concentration Extremely Low
ECU 003516.07— Aftertreatment DEF Concentration Sensor Obstructed
ECU 003516.09— Aftertreatment DEF Concentration Sensor Loss of Communication
ECU 003516.12— Aftertreatment DEF Concentration Sensor Error
ECU 003516.14— Aftertreatment DEF Contaminated
ECU 003516.16— Aftertreatment DEF Concentration Moderately High
ECU 003517.07— DEF Tank Fluid Level Sensor Obstructed
ECU 003517.12— DEF Tank Fluid Level Error
ECU 003556.16— Fuel Dosing Injector Stuck Closed
ECU 003556.18— Fuel Dosing Injector Stuck Open
ECU 003597.01— Injector High Voltage Supply Extremely Low
ECU 003711.14— DOC Inlet temperature Target Not Reached During ETM With Parasitic Loading
ECU 003711.31— DOC Inlet temperature Target Not Reached During ETM
ECU 003719.00— Calculated Soot Level Extremely High
ECU 003719.10— Calculated Soot Loading Rate of Change Abnormal
ECU 003719.13— Excessive DPF Recovery Attempts
ECU 003719.14— Calculated Soot Level Most Severe
ECU 003719.16— Calculated Soot Level Moderately High
ECU 003720.15— Calculated Ash Level Slightly High
ECU 003720.16— Calculated Ash Level Moderately High
ECU 003936.00— Calculated Unintended Combustables In DPF Extremely High
ECU 003936.16— Calculated Unintended Combustables In DPF Moderately High
ECU 004077.03— Fuel Dosing Outlet Pressure Signal Out of Range High
ECU 004077.04— Fuel Dosing Outlet Pressure Signal Out of Range Low
ECU 004077.07— Fuel Dosing Outlet Pressure Signal Invalid
ECU 004334.00— DEF Dosing Unit Pressure Extremely High
ECU 004334.01— DEF Dosing Unit Pressure Extremely Low
ECU 004334.03— DEF Dosing Unit Pressure Signal Out of Range High
ECU 004334.04— DEF Dosing Unit Pressure Signal Out of Range Low
ECU 004334.11— DEF Dosing Unit Pressure Signal Fault
ECU 004334.16— DEF Dosing Unit Pressure Moderately High
ECU 004334.18— DEF Dosing Unit Pressure Moderately Low
ECU 004334.31— DEF Dosing Unit Pressure Fault
ECU 004341.05— DEF Dosing Unit Pressure Line Heater Circuit Has High Resistance
ECU 004341.06— DEF Dosing Unit Pressure Line Heater Circuit Has Low Resistance
ECU 004343.05— DEF Dosing Unit Supply Line Heater Circuit Has High Resistance
ECU 004343.06— DEF Dosing Unit Supply Line Heater Circuit Has Low Resistance
ECU 004345.05— DEF Dosing Unit Return Line Heater Circuit Has High Resistance
ECU 004345.06— DEF Dosing Unit Return Line Heater Circuit Has Low Resistance
ECU 004360.07— SCR Inlet Temperature Invalid
ECU 004360.12— SCR Inlet Temperature Error
ECU 004363.12— SCR Outlet Temperature Error
ECU 004364.01— SCR Conversion Efficiency Extremely Low
ECU 004364.17— SCR Conversion Efficiency Slightly Low
ECU 004364.18— SCR Conversion Efficiency Moderately Low
ECU 004366.05— DEF Tank Heater Coolant Valve Circuit Has High Resistance
ECU 004366.06— DEF Tank Heater Coolant Valve Circuit Has Low Resistance
ECU 004366.16— DEF Tank Fluid Temperature Moderately High
ECU 004366.18— DEF Tank Fluid Temperature Moderately Low
ECU 004376.05— DEF Dosing Unit Reversing Valve Circuit Has High Resistance
ECU 004376.06— DEF Dosing Unit Reversing Valve Circuit Has Low Resistance
ECU 004376.14— DEF Dosing Unit Reversing Valve
ECU 004490.12— Intake Air Humidity Error
ECU 004765.00— DOC Inlet Temperature Extremely High
ECU 004765.12— DOC Inlet Temperature Error
ECU 004766.12— DOC Outlet Temperature Error
ECU 004766.15— DOC Outlet Temperature Slightly High
ECU 004766.16— DOC Outlet Temperature Moderately High
ECU 004766.17— DOC Outlet Temperature Slightly Low
ECU 004766.18— DOC Outlet Temperature Moderately Low
ECU 004795.13— Exhaust Filter Calibration Fault
ECU 004795.31— DPF Missing
ECU 005018.00— Calculated Unintended Combustables In DOC Extremely High
ECU 005018.16— Calculated Unintended Combustables In DOC Moderately High
ECU 005125.03— Sensor Supply #7 Voltage Out of Range High
ECU 005125.04— Sensor Supply #7 Voltage Out of Range Low
ECU 005126.03— Sensor Supply #8 Voltage Out of Range High
ECU 005126.04— Sensor Supply #8 Voltage Out of Range Low
ECU 005127.03— Sensor Supply #9 Voltage Out of Range High
ECU 005127.04— Sensor Supply #9 Voltage Out of Range Low
ECU 005128.05— Sensor Supply #10 Has High Resistance
ECU 005128.06— Sensor Supply #10 Has Low Resistance
ECU 005246.00— SCR Operator Level #3 Derate Notification
ECU 005246.14— SCR Operator Level #4 Derate Notification
ECU 005246.15— SCR Operator Level #1 Derate Notification
ECU 005246.16— SCR Operator Level #2 Derate Notification
ECU 005246.31— SCR Operator Final Derate Notification
ECU 005298.01— DOC Effiency Extremely Low
ECU 005298.18— DOC Efficiency Moderately Low
ECU 005435.05— DEF Dosing Unit Pump Circuit Has High Resistance
ECU 005435.06— DEF Dosing Unit Pump Circuit Has Low Resistance
ECU 005435.09— DEF Dosing Unit Pump Loss of Communication
ECU 005435.11— DEF Dosing Unit Pump Circuit Fault
ECU 005435.14— DEF Dosing Unit Pump
ECU 005435.31— DEF Dosing Unit Pump Fault
ECU 005456.00— Fuel Dosing Inlet Temperature Signal Extremely High
ECU 005456.01— Fuel Dosing Inlet Temperature Signal Extremely Low
ECU 005456.03— Fuel Dosing Inlet Temperature Signal Out of Range High
ECU 005456.04— Fuel Dosing Inlet Temperature Signal Out of Range Low
ECU 005571.05— Fuel Rail Pressure Relief Valve Circuit Has High Resistance
ECU 005571.06— Fuel Rail Pressure Relief Valve Circuit Has Low Resistance
ECU 005743.09— SCR Temperature Module Loss of Communication
ECU 005745.05— DEF Dosing Unit Heater Circuit Has High Resistance
ECU 005745.06— DEF Dosing Unit Heater Circuit Has Low Resistance
ECU 005745.18— DEF Dosing Unit Heater Temperature Moderately Low
ECU 005745.31— DEF Dosing Unit Heater Fault
ECU 520629.31— ECU Data Fault
ECU 520956.06— Battery Disconnect LED Circuit Has Low Resistance
ECU 521192.11— Immobilizer Control Device Fault
ECU 521192.14— Immobilizer Control Device Fault
ECU 521192.31— Immobilizer Control Device Fault
ECU 521214.09— Immobilizer Control Device Fault
ECU 521214.14— Immobilizer Control Device Fault
ECU 522458.02— Fuel Dosing Pump Data Erratic
ECU 522458.03— Fuel Dosing Pump Supply Voltage High
ECU 522458.04— Fuel Dosing Pump Supply Voltage Low
ECU 522458.06— Fuel Dosing Pump Circuit Has Low Resistance
ECU 522458.09— Fuel Dosing Pump Loss of Communication
ECU 522458.15— Fuel Dosing Pump Temperature Slightly High
ECU 522494.09— Intake Air Sensor Communication Error
ECU 522495.09— Exhaust Filter Temperature Module Loss of Communication
ECU 523653.01— ECU Power Circuit #3 Open
ECU 523653.14— ECU Power Circuit #3 Fault
ECU 523665.01— ECU Power Circuit #2 Open
ECU 523666.01— ECU Power Circuit #1 Open
ECU 523744.09— A/C Clutch Message Not Received
Engine Interface Control Software Diagnostic Trouble Codes (EIC)
EIC 000628.02— EIC EOL Data Fault
EIC 000630.13— EIC Calibration Fault/Not Calibrated
EIC 002000.09— ECU Message Missing
EIC 002007.09— RPT Message Missing
EIC 002029.09— Immobilizer Message Missing
EIC 002029.12— EIC Control Unit Fault
EIC 002034.09— SCC Message Missing
EIC 002140.09— AIC Message Missing
EIC 002185.09— Immobilizer Message Missing
EIC 003695.14— Diesel Particulate Filter Regeneration Fault
EIC 003719.15— Diesel Particulate Filter Regeneration Fault
EIC 521192.11— Immobilizer Control Device Fault
EIC 521192.12— Immobilizer Control Device Fault
EIC 521192.13— Immobilizer Control Device Fault
EIC 521214.02— Immobilizer Control Device Fault
EIC 521214.11— Immobilizer Control Device Fault
EIC 521214.12— Immobilizer Control Device Fault
EIC 521214.31— EIC Control Software Fault
EIC 521321.09— Immobilizer Message Missing
EIC 521321.12— Immobilizer Control Device Fault
EIC 521322.07— Immobilizer Control Device Fault
EIC 521322.31— Immobilizer Control Device Fault
EIC 523702.14— EIC Control Unit Fault
EIC 523702.31— EIC Control Unit Fault
Front Console Control Software Diagnostic Trouble Codes (FCC)
FCC 000628.02— FCC EOL Data Fault
FCC 000630.02— Cab Control Unit Fault
FCC 002005.09— TII or TIP Message Missing
FCC 002825.13— Left-Hand Reverser Lever Type Not Selected
FCC 002825.31— Left-Hand Reverser Power Circuit Fault
FCC 002826.31— Left-Hand Reverser Lever Multiple Switch Circuit Fault
FCC 002828.31— Drive Lever Position Switch Circuit Fault
FCC 002829.31— Drive Lever Position Switch Circuit Fault
FCC 002863.02— Front Wiper Switch Conflict
FCC 002865.02— Rear Wiper Switch Circuit Fault
FCC 002872.02— Road Light Switch Circuit Fault
FCC 002876.02— Turn Signal Switch Conflict
FCC 522122.31— Left-Hand Reverser Message Missing
FCC 522123.31— Left-Hand Reverser Message Missing
FCC 522124.31— Left-Hand Reverser Message Missing
FCC 522125.31— Transmission Message Missing
FCC 522358.31— Left-Hand Reverser Message Missing
FCC 524020.31— Transmission in Gear at Power Up
FCC 524022.31— Reverser Message Fault
FCC 524264.02— LHR Circuit Conflict
Hitch Control Software Diagnostic Trouble Codes (HCC)
HCC 000158.04— HCC Switched Supply Voltage Low
HCC 000168.04— HCC Unswitched Supply Voltage Low
HCC 000190.02— Rear Hitch Calibration Fault/Engine Speed Low
HCC 000444.04— Switched Supply Voltage Low
HCC 000629.12— HCC Control Unit Fault
HCC 000630.13— HCC Calibration Fault/Not Calibrated
HCC 001638.02— HCC Calibration Fault/Hydraulic Oil Temperature Low
HCC 001873.02— Rear Hitch Position Sensor Circuit Voltage Fault
HCC 001873.03— Rear Hitch Position Sensor Circuit Voltage High
HCC 001873.04— Rear Hitch Position Sensor Circuit Voltage Low
HCC 001873.11— HCC Calibration Fault/Rear Hitch Position Sensor Circuit
HCC 001873.13— HCC Calibration Fault/Rear Hitch Position Sensor Circuit
HCC 001873.31— HCC Calibration Fault/Rear Hitch Position Sensor Circuit
HCC 001881.03— Rear Hitch Draft Sensor Circuit Voltage High
HCC 001881.04— Rear Hitch Draft Sensor Circuit Voltage Low
HCC 001881.13— HCC Calibration Fault/Rear Hitch Draft Sensor Circuit
HCC 002049.09— OIC Message Missing
HCC 002071.09— CCU Message Missing
HCC 002140.09— AIC Message Missing
HCC 002152.09— HV I Message Missing
HCC 002602.18— Hydraulic Oil Level Low
HCC 003509.03— HCC Sensor Supply Voltage High
HCC 003509.04— HCC Sensor Supply Voltage Low
HCC 003509.06— HCC Sensor Circuit Current High
HCC 520285.02— Rear Hitch Lock Button Fault
HCC 520285.09— Rear Hitch Lock Button CAN Message Missing
HCC 520286.02— Rear Hitch Set Lower Set Point Button Fault
HCC 520286.09— Rear Hitch Set Lower Set Point Button CAN Message Missing
HCC 520870.02— HCC Memory Error
HCC 520871.02— HCC Memory Error
HCC 521000.02— Rear Hitch External Switch Circuit Fault
HCC 521000.09— Rear Hitch External Switch CAN Message Missing
HCC 521000.31— Rear Hitch External Switch Circuit Conflict
HCC 521001.02— HCC Calibration Fault
HCC 521001.03— Rear Hitch Control Valve Circuit Voltage High
HCC 521001.04— Rear Hitch Control Valve Circuit Voltage Low
HCC 521001.05— Rear Hitch Control Valve Circuit Current Low
HCC 521001.06— Rear Hitch Control Valve Circuit Current High
HCC 521001.07— Rear Hitch Control Valve Circuit Fault
HCC 521001.11— Rear Hitch Control Valve Circuit Fault
HCC 521001.13— Rear Hitch Control Valve Calibration Fault
HCC 521002.03— Rear Hitch Control Valve Circuit Voltage High
HCC 521002.04— Rear Hitch Control Valve Circuit Voltage Low
HCC 521002.05— Rear Hitch Control Valve Circuit Current Low
HCC 521002.06— Rear Hitch Control Valve Circuit Current High
HCC 521002.07— Rear Hitch Control Valve Circuit Fault
HCC 521002.11— Rear Hitch Control Valve Circuit Fault
HCC 521002.13— Rear Hitch Control Valve Calibration Fault
HCC 521408.02— Rear Hitch Return to Lower Switch Fault
HCC 521408.09— Rear Hitch Return to Lower Switch Message Missing
HCC 521421.09— Rear Hitch Encoder Lower Message Missing
HCC 521421.19— Rear Hitch Encoder Lower Fault
HCC 521421.31— Rear Hitch Encoder Lower Data Fault
HCC 521422.09— Rear Hitch Encoder Raise Message Missing
HCC 521422.19— Rear Hitch Encoder Raise Fault
HCC 521422.31— Rear Hitch Encoder Raise Data Fault
HCC 521475.09— Rear Hitch Load Depth Encoder Increase Message Missing
HCC 521475.19— Rear Hitch Load Depth Encoder Increase Fault
HCC 521475.31— Rear Hitch Load Depth Encoder Increase Data Fault
HCC 521476.09— Rear Hitch Height Limit Encoder Increase Message Missing
HCC 521476.19— Rear Hitch Height Limit Encoder Increase Fault
HCC 521476.31— Rear Hitch Height Limit Encoder Increase Data Fault
HCC 521477.09— Rear Hitch Load Depth Encoder Decrease Message Missing
HCC 521477.19— Rear Hitch Load Depth Encoder Decrease Fault
HCC 521477.31— Rear Hitch Load Depth Encoder Decrease Data Fault
HCC 521478.09— Rear Hitch Drop Rate Encoder Decrease Message Missing
HCC 521478.19— Rear Hitch Drop Rate Encoder Decrease Fault
HCC 521478.31— Rear Hitch Drop Rate Encoder Decrease Data Fault
HCC 521479.09— Rear Hitch Height Limit Encoder Decrease Message Missing
HCC 521479.19— Rear Hitch Height Limit Encoder Decrease Fault
HCC 521479.31— Rear Hitch Height Limit Encoder Decrease Data Fault
HCC 521480.09— Rear Hitch Drop Rate Encoder Increase Message Missing
HCC 521480.19— Rear Hitch Drop Rate Encoder Increase Fault
HCC 521480.31— Rear Hitch Drop Rate Encoder Increase Data Fault
HCC 522390.09— Implement Communication Fault
HCC 522390.11— Vehicle Automation Fault
HCC 523703.03— Rear Hitch Draft Sensor Circuit Voltage High
HCC 523703.04— Rear Hitch Draft Sensor Circuit Voltage Low
HCC 523703.13— HCC Calibration Fault/Rear Hitch Draft Sensor Circuit
HCC 523788.02— Hydraulic Option Configuration Changed Since Power-up
HCC 523788.14— Hydraulic Option Configuration Change Not Allowed
HCC 523910.02— HCC Control Unit Fault
HCC 523950.13— Rear Hitch Position Sensor Circuit Fault/Out of Calibration
HCC 523952.31— Rear Hitch Disabled/HCC Configuration
HCC 524212.02— Rear Hitch Command Lever Switch/Sensor Circuit Conflict
HCC 524212.09— Rear Hitch Command Lever Message Missing
HCC 524212.15— Rear Hitch Command Lever Data Fault
HCC 524212.19— Rear Hitch Command Lever Fault Message Received
HCC 524212.31— Rear Hitch Lever Command Missing
Hitch Valve Software Diagnostic Trouble Codes (HV1)
HV1 000158.03— HV I Switched Supply Voltage High
HV1 000158.04— HV I Switched Supply Voltage Low
HV1 002035.09— HCC Message Missing
HV1 004084.07— HV I Not in FLOAT Position
HV1 004084.16— HV I Overshot Commanded Position
HV1 004084.18— HV I Failed to Reach Commanded Position
HV1 004085.07— HV I Not in NEUTRAL Position
HV1 004085.12— HV I Control Unit Fault
Vehicle Security Control Software Diagnostic Trouble Codes (ICA)
ICA 000628.02— ICA Control Unit Fault
ICA 002006.09— EIC Message Missing
ICA 521192.12— Immobilizer Control Device Fault
JDLink Software Diagnostic Trouble Codes (JDL)
JdL Codes
Operator Interface Control Software Diagnostic Trouble Codes (OIC)
OIC 000091.02— Foot Throttle Sensor Circuit Voltage Conflict
OIC 000091.03— Foot Throttle Sensor Circuit Voltage High
OIC 000091.04— Foot Throttle Sensor Circuit Voltage Low
OIC 000158.03— Switched Supply Voltage High
OIC 000158.04— Switched Supply Voltage Low
OIC 000168.03— Unswitched Supply Voltage High
OIC 000168.04— Unswitched Supply Voltage Low
OIC 000237.02— VIN Security Data Conflict
OIC 000237.12— VIN Security Data Conflict
OIC 000237.14— VIN Security Not Enabled
OIC 000237.31— VIN Security Messages Missing
OIC 000628.02— OIC EOL Data Fault
OIC 000629.12— Cab Control Unit Fault
OIC 001504.08— Operator Presence Switch Circuit Fault
OIC 003032.13— Right Brake Pedal Sensor Not Calibrated
OIC 003033.13— Left Brake Pedal Sensor Not Calibrated
OIC 003033.14— Left Brake Pedal Sensor Adjustment Fault
OIC 003510.03— Sensor Supply 2 Voltage High
OIC 003510.04— Sensor Supply 2 Voltage Low
OIC 003510.06— Sensor Supply 2 Current High
OIC 003511.03— Sensor Supply 3 Voltage High
OIC 003511.04— Sensor Supply 3 Voltage Low
OIC 003511.06— Sensor Supply 3 Current High
OIC 003597.03— ELX Output 1 Circuit Voltage High
OIC 003597.04— ELX Output 1 Circuit Voltage Low
OIC 003597.06— ELX Output 1 Circuit Current High
OIC 003598.03— Wakeup Output Circuit Voltage High
OIC 003598.06— Wakeup Output Circuit Current High
OIC 003599.03— Secondary ELX Output 1 Voltage High
OIC 003599.06— Secondary ELX Output 1 Current High
OIC 520425.07— Vehicle CAN Bus Error Counter High
OIC 520426.07— Vehicle CAN Bus Error Counter High
OIC 520542.03— Vehicle CAN Bus Circuit Voltage High
OIC 520543.04— Vehicle CAN Bus Circuit Voltage Low
OIC 520870.02— Cab Control Unit Fault
OIC 520872.02— Cab Control Unit Fault
OIC 521423.08— XMB/XMC Messages Missing
OIC 521423.09— XMB/XMC Messages Missing
OIC 522916.03— SCV External Switches Voltage High
OIC 522916.04— SCV External Switches Voltage Low
OIC 523690.03— Rear Hitch External Switch Voltage High
OIC 523690.04— Rear Hitch External Switch Voltage Low
OIC 523758.03— Rear PTO Right External Switch Voltage High
OIC 523758.04— Rear PTO Right External Switch Voltage Low
OIC 523759.03— Rear PTO Left External Switch Voltage High
OIC 523759.04— Rear PTO Left External Switch Voltage Low
OIC 524157.02— Right Brake Sensor Conflict
OIC 524173.02— Clutch Pedal Sensor Voltage Conflict
OIC 524173.03— Clutch Pedal Sensor Circuit Voltage High
OIC 524173.04— Clutch Pedal Sensor Circuit Voltage Low
OIC 524173.07— Clutch Pedal Sensor Circuit Conflict
OIC 524223.03— Differential Lock Switch Circuit Voltage High
Primary Display Software Diagnostic Trouble Codes (PDU)
PDU 000628.02— PDU EOL Data Fault
PDU 000628.12— PDU Programming
PDU 000629.12— PDU Control Unit Fault
PDU 000639.12— PDU CAN Error Limit Exceeded
PDU 000639.14— PDU CAN Error Limit Exceeded
PDU 002000.09— ECU Message Missing
PDU 002003.09— PTI or PTP Message Missing
PDU 002005.09— TIP or TII Message Missing
PDU 002006.09— EIC Message Missing
PDU 002007.09— RPT Message Missing
PDU 002019.09— XSA or XSC Message Missing
PDU 002019.12— XSA or XSC Message Missing
PDU 002020.09— SFA Message Missing
PDU 002025.09— ATC Message Missing
PDU 002029.09— ICD Message Missing
PDU 002030.09— VLC Message Missing
PDU 002034.09— SCC Message Missing
PDU 002035.09— HCC Message Missing
PDU 002036.09— PFS or PTF Message Missing
PDU 002038.09— VTI or VTV Message Missing
PDU 002040.09— PDU Message Missing
PDU 002047.09— CSC Message Missing
PDU 002049.09— OIC Message Missing
PDU 002050.09— CLC Message Missing
PDU 002054.09— ASU or ESU Message Missing
PDU 002055.09— RLC Message Missing
PDU 002071.09— CCU Message Missing
PDU 002077.09— RAD Message Missing
PDU 002128.09— GSD Message Missing
PDU 002129.09— GS4 Message Missing
PDU 002130.09— GS5 Message Missing
PDU 002131.09— GS6 Message Missing
PDU 002139.09— CSM Message Missing
PDU 002140.09— AIC Message Missing
PDU 002145.09— FCC Message Missing
PDU 002149.09— VLC Message Missing
PDU 002152.09— HV1 Message Missing
PDU 002161.09— SV1 Message Missing
PDU 002162.09— SV2 Message Missing
PDU 002163.09— SV3 Message Missing
PDU 002164.09— SV4 Message Missing
PDU 002165.09— SV5 Message Missing
PDU 002166.09— SV6 Message Missing
PDU 002170.09— SVJ Message Missing
PDU 002171.09— SVK Message Missing
PDU 002172.09— SVL Message Missing
PDU 002173.09— SVM Message Missing
PDU 002185.09— ICA Message Missing
PDU 002198.09— XMA or XMC Message Missing
PDU 002200.09— XMB Message Missing
PDU 002201.09— XSB Message Missing
PDU 002213.09— SCO Message Missing
PDU 002240.09— TEC or TEI Message Missing
PDU 002251.09— JDL Message Missing
PDU 523329.08— Steering Message Missing
PDU 523329.13— Steering Startup Checks
PDU 523330.02— Steering Message Missing
Front PTO Control Software Diagnostic Trouble Codes (PTF)
PTF 000090.00— Front PTO Oil Temperature High
PTF 000090.03— Front PTO Oil Temperature Sensor Circuit Voltage High
PTF 000090.04— Front PTO Oil Temperature Sensor Circuit Voltage Low
PTF 000090.15— Front PTO Oil Temperature High
PTF 000123.03— Front PTO Clutch Pressure Sensor Circuit Voltage High
PTF 000123.04— Front PTO Clutch Pressure Sensor Circuit Voltage Low
PTF 000123.16— Front PTO Clutch Pressure High
PTF 000123.18— Front PTO Clutch Pressure Low
PTF 000190.01— Front PTO Disengaged Due to Heavy Engine Load
PTF 000628.02— PTF EOL Data Fault
PTF 000629.12— Front PTO Control Unit Fault
PTF 000630.14— Front PTO Configuration Invalid
PTF 001882.00— Front PTO Overspeed
PTF 001882.01— Front PTO Underspeed
PTF 001882.13— Front PTO Not Calibrated
PTF 001882.18— Front PTO Output Speed Low
PTF 002000.09— ECU Message Missing
PTF 002003.09— PTP or PTI Message Missing
PTF 002034.09— SCC Message Missing
PTF 002049.09— OIC Message Missing
PTF 002071.09— CCU Message Missing
PTF 002140.09— AIC Message Missing
PTF 520542.03— Vehicle CAN Bus High Circuit Voltage High
PTF 520543.04— Vehicle CAN Bus Low Circuit Low
PTF 520634.01— Front PTO Lube Return Pressure Low
PTF 520634.03— Front PTO Return Oil Pressure Sensor Circuit Voltage High
PTF 520634.04— Front PTO Return Oil Pressure Sensor Circuit Voltage Low
PTF 522390.09— Implement Message Missing
PTF 522390.11— Automation Abort Message Received
PTF 523749.16— PTO Clutch Slipping Too Long
PTF 523904.31— Operator Not Present With Front PTO On
PTF 523905.03— Front PTO Actuator Circuit Voltage High
PTF 523905.04— Front PTO Actuator Circuit Voltage Low
PTF 523905.05— Front PTO Actuator Current Low
PTF 523905.06— Front PTO Actuator Current High
PTF 524163.03— Front PTO External Switch Circuit Voltage High
PTF 524163.04— Front PTO External Switch Circuit Voltage Low
PTF 524216.02— Front PTO Switch Circuit Fault
PTF 524255.31— PTO External Switch Enabled
AutoPowr / IVT Transmission Control Software Diagnostic Trouble Codes (PTI)
PTI 000127.01— Transmission Enable Pressure Very Low
PTI 000158.01— PTI Switched Supply Voltage Low
PTI 000158.03— PTI Switched Supply Voltage High
PTI 000168.01— PTI Unswitched Supply Voltage Extremely Low in Tow Mode
PTI 000168.03— PTI Unswitched Supply Voltage High
PTI 000168.18— PTI Unswitched Supply Voltage Low During Tow Mode
PTI 000177.17— Transmission Oil Temperature Low/Calibration Inhibited
PTI 000190.00— Engine Overspeed
PTI 000190.02— Speed Mismatch - ECU Message with PTI Calculation
PTI 000191.00— Transmission Overspeed
PTI 000191.02— Transmission Output Speed Mismatch
PTI 000619.05— Park Brake Solenoid Circuit Fault
PTI 000619.06— Park Brake Solenoid Circuit Fault
PTI 000628.02— PTI EOL Data Fault
PTI 000630.13— PTI Hydro Calibration Fault
PTI 000630.14— PTI Clutch Calibration Fault
PTI 000734.05— Low Clutch Solenoid Circuit Fault
PTI 000735.05— High Clutch Solenoid Circuit Fault
PTI 000736.05— Reverse Brake Solenoid Circuit Fault
PTI 000737.05— Clutch 1 (C1) Solenoid Circuit Fault
PTI 000738.05— Clutch 2 (C2) Solenoid Circuit Fault
PTI 000739.05— Clutch 3 (C3) Solenoid Circuit Fault
PTI 000754.18— Clutch Enable Pressure Low/Low Clutch Engaged
PTI 000755.18— Clutch Enable Pressure Low/High Clutch Engaged
PTI 000756.18— Clutch Enable Pressure Low/Reverse Brake Engaged
PTI 002000.09— ECU Message Missing
PTI 002005.09— TII Message Missing
PTI 002019.09— XSA or XSC Message Missing
PTI 002833.31— Vehicle Motion With Park Brake Engaged
PTI 003509.03— Sensor Supply Voltage High
PTI 003509.04— Sensor Supply Voltage Low
PTI 520589.02— Transmission Secondary Speed Sensor Fault
PTI 523219.04— Valve Supply Voltage Low
PTI 523219.16— Valve Supply Voltage High
PTI 523711.02— Transmission Primary Speed Sensor Fault
PTI 523911.05— Hydro Ring Unit (RU) Control Solenoid Circuit Fault
PTI 523911.13— Hydro Ring Unit (RU) Calibration Fault
PTI 523912.05— Hydro Clutch Unit (CU) Solenoid Circuit Fault
PTI 523912.13— Hydro Clutch Unit (CU) Calibration Fault
PTI 523913.05— Loop Flush Cut-Off Solenoid Circuit Fault
PTI 523917.07— Synchronizer Speed Mismatch
PTI 523917.08— Synchronizer Engagement Fault
PTI 523917.15— Synchronizer Speed Mismatch
PTI 523917.17— CU Idler Speed Low at Start-Up
PTI 524226.08— Direction Sensing Incorrect
PTI 524228.05— Park Sump Block Solenoid Circuit Fault
PTI 524228.06— Park Sump Block Solenoid Circuit Fault
PTI 524228.11— Park Sump Block Valve Fault
PTI 524230.03— Unexpected Enable Pressure
PTI 524230.05— Clutch Enable Solenoid Circuit Fault
PTI 524232.01— Park Brake Pressure Low/Gear Commanded
PTI 524232.02— Park Brake Pressure Sensor Fault
PTI 524232.03— Park Brake Pressure Sensor Voltage High
PTI 524232.04— Park Brake Pressure Sensor Circuit Voltage Low
PTI 524232.14— Park Brake Pressure Low in Come Home Mode
PTI 524232.16— Park Brake Pressure High/Park Commanded
PTI 524232.17— Park Brake Pressure Low/Park Not Commanded
PTI 524232.18— Park Brake Pressure Low
PTI 524233.00— Hydro Ring Unit (RU) Overspeed
PTI 524233.02— Ring Unit (RU) Speed Incorrect
PTI 524233.07— Hydro Speed Incorrect/PowerZero™
PTI 524233.15— Hydro Speed Incorrect/Park Engaged
PTI 524233.16— Hydro Speed Incorrect/Park Not Engaged
PTI 524233.17— Hydro Ring Unit (RU) Speed Low At Start-Up
PTI 524234.02— Clutch Enable Pressure Incorrect
PTI 524234.04— Clutch Enable Pressure Sensor Circuit Voltage Low
PTI 524237.31— Reverser Park and Neutral Switches On
PTI 524238.31— Reverser, Park and Neutral Signals Off
PTI 524239.31— No Motion/Engine Running
PTI 524240.14— No Motion/Come Home Mode
PTI 524241.02— Carrier Speed or Hydro Ring Gear Speed Incorrect
PTI 524241.11— Synchronizer Engagement Fault/Clutch Control
PTI 524242.00— Transmission Pressures High
PTI 524243.31— PTI Park/ACU Gear Command Conflict
PTI 524244.31— PTI Park/ACU Neutral Command Conflict
PTI 524245.31— PTI Neutral/ACU Gear Command Conflict
PTI 524247.02— Carrier Speed Incorrect
PTI 524247.17— Carrier Speed Low at Start-Up
PTI 524249.31— Operator Not Seated With Transmission In Neutral
PTI 524250.31— Park Brake Previously Failed/May Not Hold
PTI 524253.02— ACU Not Commanding Park At Power Up
PTI 524254.03— Transmission Enable Circuit Voltage High
PTI 524254.04— Transmission Enable Circuit Voltage Low
PTI 524281.12— Park Backup Circuit Failure
PTP_23SPD - e23 Transmission Control Software Diagnostic Trouble Codes (PTP)
PTP 000127.01— Transmission Oil Pressure Very Low
PTP 000127.03— System 2 Oil Pressure Sensor Voltage High
PTP 000127.04— System 2 Oil Pressure Sensor Voltage Low
PTP 000158.03— PTP Switched Supply Voltage High
PTP 000160.02— Transmission Counter Shaft B Speed Sensor Fault
PTP 000168.01— PTP Supply Voltage Extremely Low in Tow Mode
PTP 000168.03— PTP Unswitched Supply Voltage High
PTP 000168.04— PTP Unswitched Supply Voltage Low
PTP 000168.18— PTP Supply Voltage Low in Tow Mode
PTP 000619.05— Park Brake Solenoid Circuit Fault
PTP 000619.06— Park Brake Solenoid Circuit Fault
PTP 000628.12— PTP Control Unit Fault
PTP 000628.14— PTP EOL Data Fault
PTP 000629.12— PTP Control Unit Fault
PTP 000630.13— Transmission Not Calibrated
PTP 000630.14— PTP EOL Data Fault
PTP 000755.03— R2 Clutch Pressure Sensor Voltage High
PTP 000755.04— R2 Clutch Pressure Sensor Voltage Low
PTP 002000.09— ECU Message Missing
PTP 002005.09— TIP Message Missing
PTP 002005.12— Transmission Command Mismatch
PTP 002019.09— XSA Message Missing
PTP 002140.09— AIC Message Missing
PTP 002145.09— FCC Message Missing
PTP 002824.02— Reverser Lever Motion Interlock Conflict
PTP 002833.31— Vehicle Motion With Park Brake Engaged
PTP 002905.05— R3 Proportional Solenoid Circuit Fault
PTP 002905.06— R3 Proportional Solenoid Circuit Fault
PTP 003509.03— PTP Sensor Supply Voltage High
PTP 003509.04— PTP Sensor Supply Voltage Low
PTP 516189.05— R1 Proportional Solenoid Circuit Fault
PTP 516189.06— R1 Proportional Solenoid Circuit Fault
PTP 516190.05— R2 Proportional Solenoid Circuit Fault
PTP 516190.06— R2 Proportional Solenoid Circuit Fault
PTP 516340.02— Transmission Counter Shaft C Speed Sensor Fault
PTP 516342.05— S1 Proportional Solenoid Circuit Fault
PTP 516342.06— S1 Proportional Solenoid Circuit Fault
PTP 516343.05— S2 Proportional Solenoid Circuit Fault
PTP 516343.06— S2 Proportional Solenoid Circuit Fault
PTP 516344.05— S3 Proportional Solenoid Circuit Fault
PTP 516344.06— S3 Proportional Solenoid Circuit Fault
PTP 516345.05— S4 Proportional Solenoid Circuit Fault
PTP 516345.06— S4 Proportional Solenoid Circuit Fault
PTP 520589.02— Secondary Wheel Speed Sensor Fault
PTP 520778.00— S1 Clutch Slipping
PTP 520778.16— S1 Clutch Slipping
PTP 520780.00— S2 Clutch Slipping
PTP 520780.16— S2 Clutch Slipping
PTP 520781.00— S3 Clutch Slipping
PTP 520781.16— S3 Clutch Slipping
PTP 520788.00— S4 Clutch Slipping
PTP 520788.16— S4 Clutch Slipping
PTP 520789.00— R1 Clutch Slipping
PTP 520795.00— R2 Clutch Slipping
PTP 520800.00— R3 Clutch Slipping
PTP 520801.00— Reverse Clutch Slipping
PTP 520801.16— Reverse Clutch Slipping
PTP 521155.05— Lube Priority Solenoid Circuit Fault
PTP 521155.06— Lube Priority Solenoid Circuit Fault
PTP 521221.00— Low Clutch Slipping
PTP 521222.00— High Clutch Slipping
PTP 521233.05— Forward Low Proportional Solenoid Circuit Fault
PTP 521233.06— Forward Low Proportional Solenoid Circuit Fault
PTP 521234.05— Forward High Proportional Solenoid Circuit Fault
PTP 521234.06— Forward High Proportional Solenoid Circuit Fault
PTP 521235.05— Reverse Proportional Solenoid Circuit Fault
PTP 521235.06— Reverse Proportional Solenoid Circuit Fault
PTP 521386.01— Lube Pressure Low
PTP 521386.03— Lube Pressure Sensor Voltage High
PTP 521386.04— Lube Pressure Sensor Voltage Low
PTP 522439.05— Hydraulic Oil Cooler Control Solenoid Circuit Fault
PTP 522439.06— Hydraulic Oil Cooler Control Solenoid Circuit Fault
PTP 523219.03— Valve Supply Voltage High
PTP 523219.04— Valve Supply Voltage Low
PTP 523711.02— Transmission Primary Speed Sensor Fault
PTP 523953.02— Transmission Enable Conflict
PTP 524228.05— Park Sump Block Solenoid Circuit Fault
PTP 524228.06— Park Sump Block Solenoid Circuit Fault
PTP 524228.11— Park Sump Block Valve Fault
PTP 524232.01— Park Brake Pressure Low With Gear Commanded
PTP 524232.03— Park Brake Pressure Sensor Voltage High
PTP 524232.04— Park Brake Pressure Sensor Voltage Low
PTP 524232.14— Park Brake Pressure Low in Come Home Mode
PTP 524232.16— Park Brake Pressure High With Park Commanded
PTP 524232.17— Park Brake Pressure Low While Not in Park
PTP 524239.02— No Motion With Engine Running
PTP 524239.14— Measured Vehicle Direction Fault
PTP 524250.31— Park Brake Previously Failed
PTP 524254.02— Transmission Enable Circuit Fault
PTP 524281.12— Park Backup Circuit Failure
PTP_16SPD - 16-Speed Powershift Transmission Control Software Diagnostic Trouble Codes (PTP)
PTP 000084.07— Vehicle Motion During Calibration
PTP 000084.18— Engine Off With Transmission In Gear
PTP 000127.03— Transmision Oil Pressure Sensor Voltage High
PTP 000127.04— Transmission Oil Pressure Sensor Voltage Low
PTP 000158.01— PTP Switched Supply Voltage Low
PTP 000168.01— PTP Unswitched Supply Voltage Low
PTP 000177.17— Top Gear Limited Due to Cold Oil
PTP 000190.00— Engine Speed too High
PTP 000190.18— Engine Speed too Low for Transmission Conditions
PTP 000628.02— PTP EOL Data Fault
PTP 000628.16— PTP Calibration Fault/Data Invalid
PTP 000630.02— PTP Calibration Fault/Data Invalid
PTP 000630.14— Transmission Not Calibrated
PTP 000734.05— Clutch 1 (C1) Valve Circuit Fault
PTP 000734.06— Clutch 1 (C1) Valve Current High
PTP 000735.05— Clutch 2 (C2) Valve Circuit Fault
PTP 000735.06— Clutch 2 (C2) Valve Current High
PTP 000736.05— Clutch 3 (C3) Valve Circuit Fault
PTP 000736.06— Clutch 3 (C3) Valve Current High
PTP 000737.05— Clutch 4 (C4) Valve Circuit Fault
PTP 000737.06— Clutch 4 (C4) Valve Current High
PTP 000738.05— Clutch R (CR) Valve Circuit Fault
PTP 000738.06— Clutch R (CR) Valve Current High
PTP 000739.05— D Clutch (DC) Valve Circuit Fault
PTP 000739.06— D Clutch (DC) Valve Current High
PTP 000810.02— Countershaft Speed Sensor Fault
PTP 002020.09— SFA Message Missing
PTP 002049.09— OIC Message Missing
PTP 521936.05— Lube Cutoff Valve Circuit Fault
PTP 523219.16— Valve Supply Voltage High
PTP 523960.31— Operator Not Seated During Reverser Command
PTP 524020.31— Transmission In Gear at Power Up
PTP 524239.31— No Motion/Engine Running
PTP 524248.31— Vehicle Motion With Park Brake Engaged
PTP 524267.15— C Clutch (CC) or D Clutch (DC) Slipping Too Long
PTP 524267.16— Clutch Slipping Too Long
PTP 524267.31— A Brake (AB) or B Clutch (BC) Slipping Too Long
PTP 524271.05— C Clutch (CC) Valve Circuit Fault
PTP 524271.06— C Clutch (CC) Valve Current High
PTP 524272.05— B Clutch (BC) Valve Circuit Fault
PTP 524272.06— B Clutch (BC) Valve Current High
PTP 524273.05— A Brake (AB ) Valve Circuit Fault
PTP 524273.06— A Brake (AB) Valve Current High
PTP 524279.31— Operator Not Seated With Transmission In Neutral
PTP 524280.31— Vehicle Motion While Shifting to Park
Roof Lighting Control Software Diagnostic Trouble Codes (RLC)
RLC 000158.00— RLC Switched Supply Voltage High With Engine On
RLC 000158.01— RLC Switched Supply Voltage Low With Engine On
RLC 000158.03— RLC Switched Supply Voltage High
RLC 000158.04— RLC Switched Supply Voltage Low
RLC 000158.17— RLC Switched Supply Voltage Low With Engine Off
RLC 000158.18— RLC Switched Supply Voltage Low With Engine Below 1500 RPM
RLC 000444.03— RLC Unswitched Supply Voltage High
RLC 000444.04— RLC Unswitched Supply Voltage Low
RLC 000444.06— RLC Control Unit Current Too High
RLC 000628.02— RLC EOL Data Fault
RLC 000628.12— RLC Programming
RLC 000629.12— RLC Control Unit Fault
RLC 000630.02— RLC Calibration Fault
RLC 000630.13— RLC Calibration Fault/Not Calibrated
RLC 000630.14— RLC Calibration Fault
RLC 000639.12— Vehicle CAN Bus Fault
RLC 000639.14— Vehicle CAN Bus Fault
RLC 001231.12— Implement CAN Bus Message Overflow
RLC 001231.14— Implement CAN Bus Message Missing
RLC 001487.06— Roof Backlighting Current High
RLC 002000.09— ECU Message Missing
RLC 002007.09— RPT Message Missing
RLC 002025.09— ATC Message Missing
RLC 002036.09— PTF Message Missing
RLC 002040.09— PDU Message Missing
RLC 002049.09— OIC Message Missing
RLC 002050.09— CLC Message Missing
RLC 002055.06— RLC Circuit Current High
RLC 002071.09— CCU Message Missing
RLC 002139.09— CSM Message Missing
RLC 002145.09— FCC Message Missing
RLC 002149.09— VLC Message Missing
RLC 002240.09— TEC Message Missing
RLC 002352.03— Loader Flood Light Low Beam Voltage High
RLC 002352.05— Loader Flood Light Low Beam Current Low
RLC 002352.06— Loader Flood Light Low Beam Current High
RLC 002358.03— Loader Flood Light High Beam Voltage High
RLC 002358.05— Loader Flood Light High Beam Current Low
RLC 002358.06— Loader Flood Light High Beam Current High
RLC 002368.03— Left Turn Signal Voltage High
RLC 002368.05— Left Turn Signal Current Low
RLC 002368.06— Left Turn Signal Current High
RLC 002370.03— Right Turn Signal Voltage High
RLC 002370.05— Right Turn Signal Current Low
RLC 002370.06— Right Turn Signal Current High
RLC 002382.03— Front Clearance and Warning Light Voltage High (Eur Only)
RLC 002382.05— Front Clearance and Warning Light Current Low (Eur Only)
RLC 002382.06— Front Clearance and Warning Light Current High (Eur Only)
RLC 002386.03— Beacon Light Voltage High
RLC 002386.05— Beacon Light Current Low
RLC 002386.06— Beacon Light Current High
RLC 002390.03— License Plate Light Voltage High
RLC 002390.05— License Plate Light Current Low
RLC 002390.06— License Plate Light Current High
RLC 002865.02— Rear Wiper Switch Circuit Fault
RLC 520273.03— Right-Hand Console Lamp Voltage High
RLC 520273.05— Right-Hand Console Lamp Current Low
RLC 520273.06— Right-Hand Console Lamp Current High
RLC 520425.07— Vehicle CAN Bus Error Counter High
RLC 520426.07— Vehicle CAN Bus Error Counter High
RLC 520542.03— Vehicle CAN Bus High Circuit Voltage High
RLC 520543.04— Vehicle CAN Bus Low Circuit Low
RLC 520715.03— Pressurizer Blower Motor Voltage High
RLC 520715.05— Pressurizer Blower Motor Current Low
RLC 520715.06— Pressurizer Blower Motor Current High
RLC 521392.02— Right Window Wiper Switch Circuit Fault
RLC 521393.06— Front Wiper Park Feedback Current High
RLC 521535.03— Mid Body Flood Light Left Voltage High
RLC 521535.05— Mid Body Flood Light Left Current Low
RLC 521535.06— Mid Body Flood Light Left Current High
RLC 521537.03— Front Roof Warning (NA Only) or Front Corner Roof Light (Eur Only) Left Voltage High
RLC 521537.05— Front Roof Warning (NA Only) or Front Corner Roof Light (Eur Only) Left Current Low
RLC 521537.06— Front Roof Warning (NA Only) or Front Corner Roof Light (Eur Only) Left Current High
RLC 521539.03— Front Inner Roof Flood Light Left Voltage High
RLC 521539.05— Front Inner Roof Flood Light Left Current Low
RLC 521539.06— Front Inner Roof Flood Light Left Current High
RLC 521540.03— Front Side Roof Flood Light Left Voltage High
RLC 521540.05— Front Side Roof Flood Light Left Current Low
RLC 521540.06— Front Side Roof Flood Light Left Current High
RLC 521541.03— Rear Side Roof Flood Light Left Voltage High
RLC 521541.05— Rear Side Roof Flood Light Left Current Low
RLC 521541.06— Rear Side Roof Flood Light Left Current High
RLC 521542.03— Rear Roof Warning (NA Only) or Rear Corner Roof Light (Eur Only) Left Voltage High
RLC 521542.05— Rear Roof Warning (NA Only) or Rear Corner Roof Light (Eur Only) Left Current Low
RLC 521542.06— Rear Roof Warning (NA Only) or Rear Corner Roof Light (Eur Only) Left Current High
RLC 521544.03— Rear Inner Left Roof Flood Light Voltage High
RLC 521544.05— Rear Inner Left Roof Flood Light Current Low
RLC 521544.06— Rear Inner Left Roof Flood Light Current High
RLC 521553.03— Mid Body Flood Light Right Voltage High
RLC 521553.05— Mid Body Flood Light Right Current Low
RLC 521553.06— Mid Body Flood Light Right Current High
RLC 521555.03— Front Roof Warning (NA Only) or Front Corner Roof Light (Eur Only) Right Voltage High
RLC 521555.05— Front Roof Warning (NA Only) or Front Corner Roof Light (Eur Only) Right Current Low
RLC 521555.06— Front Roof Warning (NA Only) or Front Corner Roof Light (Eur Only) Right Current High
RLC 521557.03— Front Inner Roof Flood Light Right Voltage High
RLC 521557.05— Front Inner Roof Flood Light Right Current Low
RLC 521557.06— Front Inner Roof Flood Light Right Current High
RLC 521558.03— Front Side Roof Flood Light Right Voltage High
RLC 521558.05— Front Side Roof Flood Light Right Current Low
RLC 521558.06— Front Side Roof Flood Light Right Current High
RLC 521559.03— Rear Side Roof Flood Light Right Voltage High
RLC 521559.05— Rear Side Roof Flood Light Right Current Low
RLC 521559.06— Rear Side Roof Flood Light Right Current High
RLC 521560.03— Rear Roof Warning (NA Only) or Rear Corner Roof Light (Eur Only) Right Voltage High
RLC 521560.05— Rear Roof Warning (NA Only) or Rear Corner Roof Light (Eur Only) Right Current Low
RLC 521560.06— Rear Roof Warning (NA Only) or Rear Corner Roof Light (Eur Only) Right Current High
RLC 521562.03— Rear Inner Right Roof Flood Light Voltage High
RLC 521562.05— Rear Inner Right Roof Flood Light Current Low
RLC 521562.06— Rear Inner Right Roof Flood Light Current High
RLC 521567.06— Flasher Driver Current High
RLC 521835.20— Control Unit Ground Circuit Fault
RLC 522433.03— Rear Wiper Motor Low Speed Voltage High
RLC 522433.06— Rear Wiper Motor Low Speed Current High
RLC 522434.06— Front Wiper Motor Low Speed Current High
RLC 522435.06— Front Wiper Motor High Speed Current High
RLC 524259.00— RLC Temperature Above 115 Degrees Celsius
RLC 524259.15— RLC Temperature Above 85 Degrees Celsius
RLC 524259.16— RLC Temperature Above 100 Degrees Celsius
Rear PTO Control Software Diagnostic Trouble Codes (RPT)
RPT 000190.01— Rear PTO Disengaged Due to Heavy Engine Load
RPT 000628.02— RPT EOL Data Fault
RPT 000629.12— RPT Control Unit Fault
RPT 000630.14— Rear PTO Configuration Invalid
RPT 001883.00— Rear PTO Overspeed
RPT 001883.01— Rear PTO Underspeed
RPT 001883.13— Rear PTO Not Calibrated
RPT 002000.09— ECU Message Missing
RPT 002034.09— SCC Message Missing
RPT 002049.09— OIC Message Missing
RPT 002139.09— CSM Message Missing
RPT 002140.09— AIC Message Missing
RPT 002149.09— VLC Message Missing
RPT 520542.03— Vehicle CAN Bus High Circuit Voltage High
RPT 520543.04— Vehicle CAN Bus Low Circuit Low
RPT 521425.03— Rear PTO Speed Select Solenoid Circuit Voltage High
RPT 521425.06— Rear PTO Speed Select Solenoid Circuit Current High
RPT 522384.14— 4R/5R PTO Inhibited
RPT 522390.09— Implement Message Missing
RPT 522390.11— Automation Abort Message Received
RPT 523749.16— PTO Clutch Slipping Too Long
RPT 524224.02— PTO Switch Voltage Mismatch
RPT 524251.31— Operator Not Present With Rear PTO On
RPT 524252.03— Rear PTO Solenoid Circuit Voltage High
RPT 524252.04— Rear PTO Solenoid Circuit Voltage Low
RPT 524252.05— Rear PTO Solenoid Current Low
RPT 524252.06— Rear PTO Solenoid Current High
RPT 524255.31— Rear PTO Remote Switch Enabled
SCV Control Software Diagnostic Trouble Codes (SCC)
SCC 000158.04— SCC Switched Supply Voltage Low
SCC 000168.03— SCC Unswitched Supply Voltage High
SCC 000168.04— SCC Unswitched Supply Voltage Low
SCC 000177.01— Hydraulic Oil Temperature Too Low
SCC 000237.02— VIN Security Data Conflict
SCC 000237.12— VIN Security Data Conflict
SCC 000237.14— VIN Security Not Enabled
SCC 000237.31— VIN Security Messages Missing
SCC 000629.12— SCC Software Fault
SCC 002000.09— ECU Message Missing
SCC 002003.09— Transmission Control Unit Message Missing
SCC 002006.09— EIC Message Missing
SCC 002049.09— OIC Message Missing
SCC 002071.09— CCU Message Missing
SCC 002139.09— CSM Message Missing
SCC 002140.09— AIC Message Missing
SCC 002161.09— SV I Message Missing
SCC 002162.09— SV II Message Missing
SCC 002163.09— SV III Message Missing
SCC 002164.09— SV IV Message Missing
SCC 002165.09— SV V Message Missing
SCC 002166.09— SV VI Message Missing
SCC 002213.09— SCO Message Missing
SCC 002602.01— Hydraulic Oil Level Extremely Low
SCC 002602.02— Hydraulic Oil Level Sensor Fault
SCC 002602.03— Hydraulic Oil Level Presence Sensor Voltage High
SCC 002602.04— Hydraulic Oil Level Presence Sensor Voltage Low
SCC 002602.12— Hydraulic Oil Level Presence Sensor Internal Fault
SCC 002602.14— Operator Not Present with Hydraulic Oil Level Very Low
SCC 002602.18— Hydraulic Oil Level Low
SCC 003509.03— SCC Sensor Supply Voltage High
SCC 003509.04— SCC Sensor Supply Voltage Low
SCC 516456.03— Hydraulic Charge Pressure Sensor Circuit Voltage High
SCC 516456.04— Hydraulic Charge Pressure Sensor Circuit Voltage Low
SCC 516456.18— Hydraulic Oil Charge Pressure Low
SCC 516457.14— Incompatible Controller Software
SCC 517342.31— Control Lever Fault
SCC 520542.03— Vehicle CAN Bus High Circuit Voltage High
SCC 520543.04— Vehicle CAN Bus Low Circuit Low
SCC 521000.02— External Switch Circuit Fault
SCC 522390.09— Lost Automation Command From Implement
SCC 522390.11— Vehicle Automation Fault
SCC 523216.03— SCC Unswitched Supply Voltage High
SCC 523216.04— SCC Unswitched Supply Voltage Low
SCC 523217.03— SCC Unswitched Supply Voltage High
SCC 523217.04— SCC Unswitched Supply Voltage Low
SCC 523218.03— SCC Unswitched Supply Voltage High
SCC 523218.04— SCC Unswitched Supply Voltage Low
SCC 523219.03— SCC Unswitched Supply Voltage High
SCC 523219.04— SCC Unswitched Supply Voltage Low
SCC 523343.19— Armrest Multi-Function Lever Trigger Switch Fault
SCC 523693.02— Missing SCV I External Control Message for 10 Seconds
SCC 523693.09— Missing SCV I External Control Message for 1 Second
SCC 523693.19— SCV I External Control Fault Message Received
SCC 523694.02— Missing SCV II External Control Message for 10 Seconds
SCC 523694.09— Missing SCV II External Control Message for 1 Second
SCC 523694.19— SCV II External Control Fault Message Received
SCC 523695.02— Missing SCV V External Control Message for 10 Seconds
SCC 523695.09— Missing SCV V External Control Message for 1 Second
SCC 523695.19— SCV V External Control Fault Message Received
SCC 523696.02— Missing SCV VI External Control Message for 10 Seconds
SCC 523696.09— Missing SCV VI External Control Message for 1 Second
SCC 523696.19— SCV VI External Control Fault Message Received
SCC 523776.19— Multi-Function Lever Transport Lock Switch Fault Message Received
SCC 523783.03— SCV Remote Position Sensor 4 Circuit Voltage High
SCC 523783.04— SCV Remote Position Sensor 4 Circuit Voltage Low
SCC 523783.07— SCV Remote Position Sensor 4 Fault/Unexpected Response
SCC 523784.03— SCV Remote Position Sensor 3 Circuit Voltage High
SCC 523784.04— SCV Remote Position Sensor 3 Circuit Voltage Low
SCC 523784.07— SCV Remote Position Sensor 3 Fault/Unexpected Response
SCC 523785.01— Lost Laser/Electro-Hydraulic External Control Not Available for SV III
SCC 523785.03— SCV Remote Position Sensor 2 Circuit Voltage High
SCC 523785.04— SCV Remote Position Sensor 2 Circuit Voltage Low
SCC 523785.07— SCV Remote Position Sensor 2 Fault/Unexpected Response
SCC 523786.01— Lost Laser/Electro-Hydraulic External Control Not Available for SV I
SCC 523786.03— SCV Remote Position Sensor 1 Circuit Voltage High
SCC 523786.04— SCV Remote Position Sensor 1 Circuit Voltage Low
SCC 523786.07— SCV Remote Position Sensor 1 Fault/Unexpected Response
SCC 523788.02— Hydraulic Option Configuration Changed Since Power-Up
SCC 523788.14— Hydraulic Option Configuration Changed Without Disconnect
SCC 523788.31— Hydraulic Option Configuration Invalid
SCC 523804.19— Multi-Function Lever Lateral Sensor Fault Message Received
SCC 523805.19— Multi-Function Lever Fore-Aft Sensor Fault Message Received
SCC 523910.02— SCC Control Unit Fault
SCC 523923.19— SCV I Control Lever Fault Message Received
SCC 523923.31— SCV I Control Lever Command Missing
SCC 523942.31— Operator Out of Seat With SCV VI ON
SCC 523943.31— Operator Out of Seat With SCV V ON
SCC 523944.31— Operator Out of Seat With SCV IV ON
SCC 523945.31— Operator Out of Seat With SCV III ON
SCC 523946.31— Operator Out of Seat With SCV II ON
SCC 523947.31— Operator Out of Seat With SCV I ON
SCC 524015.02— Missing SCV III External Control Message for 10 Seconds
SCC 524015.09— Missing SCV III External Control Message for 1 Second
SCC 524015.19— SCV III External Control Fault Message Received
SCC 524038.02— Missing SCV IV External Control Message for 10 Seconds
SCC 524038.09— Missing SCV IV External Control Message for 1 Second
SCC 524038.19— SCV IV External Control Fault Message Received
SCC 524101.19— SCV VI Control Lever Fault Message Received
SCC 524101.31— SCV VI Control Lever Command Missing
SCC 524102.19— SCV V Control Lever Fault Message Received
SCC 524102.31— SCV V Control Lever Command Missing
SCC 524103.19— SCV IV Control Lever Fault Message Received
SCC 524103.31— SCV IV Control Lever Command Missing
SCC 524104.19— SCV III Control Lever Fault Message Received
SCC 524104.31— SCV III Control Lever Command Missing
SCC 524105.19— SCV II Control Lever Fault Message Received
SCC 524105.31— SCV II Control Lever Command Missing
SCC 524185.03— Remote Position Sensor 5 Circuit Voltage High
SCC 524185.04— Remote Position Sensor 5 Circuit Voltage Low
SCC 524185.07— Remote Position Sensor 5 Fault/Unexpected Response
Secondary Hydraulic Control Software Diagnostic Trouble Codes (SCO)
SCO 000158.04— SCO Switched Supply Voltage Low
SCO 000168.03— SCO Unswitched Supply Voltage High
SCO 000168.04— SCO Unswitched Supply Voltage Low
SCO 000177.01— Hydraulic Oil Temperature Too Low
SCO 000177.02— Hydraulic Oil Temperature Too Low For Front Hitch Calibration
SCO 000190.02— Front Hitch Calibration Fault/ Engine Speed Slow
SCO 000629.12— SCO Software Fault
SCO 000630.13— SCO Calibration Fault/Not Calibrated
SCO 001872.02— Front Hitch Calibration Fault
SCO 001872.03— Front Hitch Position Sensor Circuit Supply Voltage High
SCO 001872.04— Front Hitch Position Sensor Circuit Supply Voltage Low
SCO 001872.07— Front Hitch Blocked or Cylinder Stuck
SCO 001872.16— Front Hitch Position Sensor Circuit Voltage High
SCO 001872.18— Front Hitch Position Sensor Circuit Voltage Low
SCO 002000.09— ECU Message Missing
SCO 002003.09— Transmission Control Unit Message Missing
SCO 002006.09— EIC Message Missing
SCO 002034.09— SCC Message Missing
SCO 002049.09— OIC Message Missing
SCO 002071.09— CCU Message Missing
SCO 002139.09— CSM Message Missing
SCO 002140.09— AIC Message Missing
SCO 002170.09— SVJ Message Missing
SCO 002174.09— SVN Message Missing
SCO 002175.09— SVO Message Missing
SCO 002646.03— SCV XIV Driver Circuit Voltage High
SCO 002646.04— SCV XIV Driver Circuit Voltage Low
SCO 002647.03— SCV XV Driver Circuit Voltage High
SCO 002647.04— SCV XV Driver Circuit Voltage Low
SCO 003509.03— SCO Sensor Supply Voltage High
SCO 003509.04— SCO Sensor Supply Voltage Low
SCO 516122.03— Front Hitch Single Acting Valve Circuit Fault
SCO 516122.05— Front Hitch Single Acting Valve Circuit Fault
SCO 516122.06— Front Hitch Single Acting Valve Circuit Fault
SCO 516451.19— SCV XV Control Lever Fault Message Received
SCO 516451.31— SCV XV Control Lever Command Missing
SCO 516454.03— Front Hitch Calibration Fault
SCO 516454.04— Front Hitch Calibration Fault
SCO 516454.12— Front Hitch Calibration Fault
SCO 516454.13— Front Hitch Calibration Fault
SCO 516454.14— Front Hitch Communication Fault
SCO 516455.00— Front Hitch Actuator Temperature High
SCO 516455.01— Front Hitch Actuator Temperature Low
SCO 516455.18— Front Hitch Actuator Voltage and Temperature Low
SCO 516457.14— Incompatible Controller Software
SCO 516458.00— Front Hitch Actuator Voltage High
SCO 516458.01— Front Hitch Actuator Voltage Low
SCO 516459.31— Operator Out of Seat with SCV XV On
SCO 516460.03— Front Hitch Driver Circuit Voltage High
SCO 516460.04— Front Hitch Driver Circuit Voltage Low
SCO 520451.31— Operator Out of Seat with SCV XIV On
SCO 520542.03— Vehicle CAN Bus High Circuit Voltage High
SCO 520543.04— Vehicle CAN Bus Low Circuit Low
SCO 521401.19— Front Hitch Control Lever Fault Message Received
SCO 521401.31— Front Hitch Control Lever Command Missing
SCO 521407.19— SCV XIV Control Lever Fault Message Received
SCO 521407.31— SCV XIV Control Lever Command Missing
SCO 521468.14— SCV XIV Actuator Not Receiving SCO Message
SCO 521469.14— SCV XV Actuator Not Receiving SCO Message
SCO 521470.00— SCV XIV Actuator Temperature High
SCO 521470.01— SCV XIV Actuator Temperature Low
SCO 521470.18— SCV XIV Actuator Voltage and Temperature Low
SCO 521471.00— SCV XV Actuator Temperature High
SCO 521471.01— SCV XV Actuator Temperature Low
SCO 521471.18— SCV XV Actuator Voltage and Temperature Low
SCO 521472.00— SCV XIV Actuator Voltage High
SCO 521472.01— SCV XIV Actuator Voltage Low
SCO 521473.00— SCV XV Actuator Voltage High
SCO 521473.01— SCV XV Actuator Voltage Low
SCO 522390.09— Lost Automation Command From Implement
SCO 522390.11— Vehicle Automation Fault
SCO 523216.03— SCO Unswitched Supply Voltage High to Front SCVs
SCO 523216.04— SCO Unswitched Supply Voltage Low to Front SCVs
SCO 523217.03— SCO Unswitched Supply Voltage High to Front SCVs
SCO 523217.04— SCO Unswitched Supply Voltage Low to Front SCVs
SCO 523218.03— SCO Unswitched Supply Voltage High to Front SCVs
SCO 523218.04— SCO Unswitched Supply Voltage Low to Front SCVs
SCO 523219.03— SCO Unswitched Supply Voltage High to Front SCVs
SCO 523219.04— SCO Unswitched Supply Voltage Low to Front SCVs
SCO 523272.02— Front Hitch External Switch Circuit Fault
SCO 523343.19— Armrest Multi-Function Lever Trigger Switch Fault
SCO 523775.19— Multi-Function Lever Hand Presence Switch Fault Message Received
SCO 523775.31— Multi-Function Lever Hand Presence Switch Fault Message Received
SCO 523776.19— Multi-Function Lever Transport Lock Switch Fault Message Received
SCO 523783.03— SCV Remote Position Sensor 4 Circuit Voltage High
SCO 523783.04— SCV Remote Position Sensor 4 Circuit Voltage Low
SCO 523783.07— SCV Remote Position Sensor 4 Fault/Unexpected Response
SCO 523784.03— SCV Remote Position Sensor 3 Circuit Voltage High
SCO 523784.04— SCV Remote Position Sensor 3 Circuit Voltage Low
SCO 523784.07— SCV Remote Position Sensor 3 Fault/Unexpected Response
SCO 523785.03— Remote Position Sensor 2 Circuit Voltage High
SCO 523785.04— Remote Position Sensor 2 Circuit Voltage Low
SCO 523785.07— Remote Position Sensor 2 Fault/Unexpected Response
SCO 523786.03— Remote Position Sensor 1 Circuit Voltage High
SCO 523786.04— Remote Position Sensor 1 Circuit Voltage Low
SCO 523786.07— Remote Position Sensor 1 Fault/Unexpected Response
SCO 523788.02— Hydraulic Option Configuration Changed Since Power-Up
SCO 523788.14— Hydraulic Option Configuration Changed Without Disconnect
SCO 523788.31— Hydraulic Option Configuration Invalid
SCO 523804.19— Multi-Function Lever Lateral Sensor Fault Message Received
SCO 523805.19— Multi-Function Lever Fore-Aft Sensor Fault Message Received
SCO 523910.02— SCO Control Unit Fault
SCO 524185.03— Remote Position Sensor 5 Circuit Voltage High
SCO 524185.04— Remote Position Sensor 5 Circuit Voltage Low
SCO 524185.07— Remote Position Sensor 5 Fault/Unexpected Response
Suspended Front Axle Control Software Diagnostic Trouble Codes (SFA)
SFA 000158.04— SFA Switched Supply Voltage Low
SFA 000168.04— SFA Switched Supply Voltage Low
SFA 000237.02— VIN Security Data Conflict
SFA 000237.12— Data Fault
SFA 000237.14— VIN Security Not Enabled
SFA 000237.31— VIN Security Message Missing
SFA 000628.12— SFA Programming
SFA 000629.12— SFA Control Unit Fault
SFA 000630.02— Suspension Calibration Fault/Data Invalid
SFA 000630.13— SFA Control Unit Fault
SFA 002003.09— PTI or PTP Message Missing
SFA 002005.09— ACU Message Missing
SFA 002035.09— HCC Message Missing
SFA 002049.09— OIC Message Missing
SFA 002071.09— CCU Message Missing
SFA 003509.03— Suspension Sensor Supply Voltage High
SFA 003509.04— Suspension Sensor Supply Voltage Low
SFA 520542.03— Vehicle CAN Bus High Circuit Voltage High
SFA 520543.04— Vehicle CAN Bus Low Circuit Voltage Low
SFA 522287.05— Front Suspension Dampening Solenoid ‘B” Circuit Current Low
SFA 522287.06— Front Suspension Dampening Solenoid ‘B: Circuit Current High
SFA 522287.17— Front Suspension Dampening Solenoid ‘B” Circuit Current Low
SFA 522288.05— Front Suspension Dampening Solenoid ‘A” Circuit Current Low
SFA 522288.06— Front Suspension Dampening Solenoid ‘A” Circuit Current High
SFA 522288.17— Front Suspension Dampening Solenoid ‘A” Circuit Current Low
SFA 522290.02— Front Suspension Right Position Sensor Calibration Fault
SFA 522290.03— Front Suspension Right Position Sensor Circuit Voltage High
SFA 522290.04— Front Suspension Right Position Sensor Circuit Voltage Low
SFA 523368.02— SFA Control Unit Fault
SFA 523847.05— Front Suspension Spring Rate Decrease Solenoid Circuit Current Low
SFA 523847.06— Front Suspension Spring Rate Decrease Solenoid Circuit Current High
SFA 523847.17— Front Suspension Spring Rate Decrease Solenoid Circuit Current Low
SFA 523902.07— Front Suspension Not Responding To Raise Command
SFA 523903.07— Front Suspension Not Responding To Lower Command
SFA 523910.02— SFA Control Unit Fault
SFA 523948.05— Suspension Raise Circuit Current Low
SFA 523948.06— Suspension Raise Circuit Current High
SFA 523948.17— Suspension Raise Circuit Current Low
SFA 523949.05— Suspension Lower Circuit Current Low
SFA 523949.06— Suspension Lower Circuit Current High
SFA 523949.17— Front Suspension Lower Solenoid Circuit Current Low
SFA 523950.02— Front Suspension Left Position Sensor Calibration Fault
SFA 523950.03— Front Suspension Left Position Sensor Circuit Voltage High
SFA 523950.04— Front Suspension Left Position Sensor Circuit Voltage Low
SFA 523950.13— Front Suspension Left Position Sensor Calibration Fault
SFA 523951.14— Suspension Not Calibrated
SFA 523964.05— Front Suspension Spring Rate Increase Solenoid Circuit Current Low
SFA 523964.06— Front Suspension Spring Rate Increase Solenoid Circuit Current High
SFA 523964.17— Front Suspension Spring Rate Increase Solenoid Circuit Current Low
SFA 523974.03— Front Suspension Pressure Sensor Circuit Voltage High
SFA 523974.04— Front Suspension Pressure Sensor Circuit Voltage Low
SCV I Control Software Diagnostic Trouble Codes (SV1)
SV1 000158.03— SV I Switched Supply Voltage High
SV1 000158.04— SV I Switched Supply Voltage Low
SV1 002034.09— SCC Message Missing
SV1 004084.07— SV I Is Not Going Into Float Position
SV1 004084.16— SV I Overshot Commanded Position
SV1 004084.18— SV I Failed to Reach Commanded Position
SV1 004085.07— SV I Not in NEUTRAL Position
SV1 004085.12— SV I Control Unit Fault
SCV II Control Software Diagnostic Trouble Codes (SV2)
SV2 000158.03— SV II Switched Supply Voltage High
SV2 000158.04— SV II Switched Supply Voltage Low
SV2 002034.09— SCC Message Missing
SV2 004084.07— SV II Is Not Going Into Float Position
SV2 004084.16— SV II Overshot Commanded Position
SV2 004084.18— SV II Failed to Reach Commanded Position
SV2 004085.07— SV II Not in NEUTRAL Position
SV2 004085.12— SV II Control Unit Fault
SCV III Control Software Diagnostic Trouble Codes (SV3)
SV3 000158.03— SV III Switched Supply Voltage High
SV3 000158.04— SV III Switched Supply Voltage Low
SV3 002034.09— SCC Message Missing
SV3 004084.07— SV III Is Not Going Into Float Position
SV3 004084.16— SV III Overshot Commanded Position
SV3 004084.18— SV III Failed to Reach Commanded Position
SV3 004085.07— SV III Not in NEUTRAL Position
SV3 004085.12— SV III Control Unit Fault
SCV IV Control Software Diagnostic Trouble Codes (SV4)
SV4 000158.03— SV IV Switched Supply Voltage High
SV4 000158.04— SV IV Switched Supply Voltage Low
SV4 002034.09— SCC Message Missing
SV4 004084.07— SV IV Is Not Going Into Float Position
SV4 004084.16— SV IV Overshot Commanded Position
SV4 004084.18— SV IV Failed to Reach Commanded Position
SV4 004085.07— SV IV Not in NEUTRAL Position
SV4 004085.12— SV IV Control Unit Fault
SCV V Control Software Diagnostic Trouble Codes (SV5)
SV5 000158.03— SV V Switched Supply Voltage High
SV5 000158.04— SV V Switched Supply Voltage Low
SV5 002034.09— SCC Message Missing
SV5 004084.07— SV V Is Not Going Into Float Position
SV5 004084.16— SV V Overshot Commanded Position
SV5 004084.18— SV V Failed to Reach Commanded Position
SV5 004085.07— SV V Not in NEUTRAL Position
SV5 004085.12— SV V Control Unit Fault
SCV VI Control Software Diagnostic Trouble Codes (SV6)
SV6 000158.03— SV VI Switched Supply Voltage High
SV6 000158.04— SV VI Switched Supply Voltage Low
SV6 002034.09— SCC Message Missing
SV6 004084.07— SV VI Is Not Going Into Float Position
SV6 004084.16— SV VI Overshot Commanded Position
SV6 004084.18— SV VI Failed to Reach Commanded Position
SV6 004085.07— SV VI Not in NEUTRAL Position
SV6 004085.12— SV VI Control Unit Fault
Front Hitch SCV Control Software Diagnostic Trouble Codes (SVJ)
SVJ 000158.03— SV J Switched Supply Voltage High
SVJ 000158.04— SV J Switched Supply Voltage Low
SVJ 002213.09— SCO Message Missing
SVJ 004084.07— SV J Front Hitch Is Not Going Into Float Position
SVJ 004084.16— SV J Overshot Commanded Position
SVJ 004084.18— SV J Failed to Reach Commanded Position
SVJ 004085.07— SV J Not in NEUTRAL Position
SVJ 004085.12— SV J Control Unit Fault
Front SCV XIV Control Software Diagnostic Trouble Codes (SVN)
SVN 000158.03— SVN Switched Supply Voltage High
SVN 000158.04— SVN Switched Supply Voltage Low
SVN 002213.09— SCO Message Missing
SVN 004084.07— SVN Is Not Going Into Float Position
SVN 004084.16— SVN Overshot Commanded Position
SVN 004084.18— SVN Failed to Reach Commanded Position
SVN 004085.07— SVN Not in NEUTRAL Position
SVN 004085.12— SVN Control Unit Fault
Front SCV XV Control Software Diagnostic Trouble Codes (SVO)
SVO 000158.03— SVO Switched Supply Voltage High
SVO 000158.04— SVO Switched Supply Voltage Low
SVO 002213.09— SCO Message Missing
SVO 004084.07— SVO is not going into float position
SVO 004084.16— SVO Overshot Commanded Position
SVO 004084.18— SVO Failed to Reach Commanded Position
SVO 004085.07— SVO Not in NEUTRAL Position
SVO 004085.12— SVO Control Unit Fault
TEI - Tractor Equipment Control Software Diagnostic Trouble Codes (TEC/TEI)
TEC/TEI 000629.12— TEC Control Unit Fault
TEC/TEI 000630.02— TEC Calibration Fault/Data Invalid
TEC/TEI 000630.14— TEC User Data Memory/Data Invalid
TEC/TEI 0003213.12— TEC Control Unit Fault
TEC/TEI 522550.14— ISO Compliant and Non-ISO Compliant Devices on Implement CAN Bus
TEC/TEI 523698.09— GreenStar Display Message Missing
AutoPowr / IVT Transmission Shift Control Software Diagnostic Trouble Codes (TII)
TII 000177.17— Engine Speed Limited Due to Cold Oil
TII 000190.01— Transmission Disengaged Due to Heavy Engine Load
TII 000581.07— Transmission Not Responding to Command
TII 000628.02— TII EOL Data Fault
TII 000629.12— TII Control Unit Fault
TII 000630.02— TII Calibration Fault/Data Invalid
TII 000630.13— TII Calibration Fault/Not Calibrated
TII 001504.31— Operator Not Seated With PowerZero Preselected
TII 001745.14— Initial Start Up Checks Not Complete
TII 001845.31— Engine Overload In Manual Mode
TII 002000.09— ECU Message Missing
TII 002003.09— PTI Message Missing
TII 002019.09— XSA Message Missing
TII 002020.09— SFA Message Missing
TII 002049.09— OIC Message Missing
TII 002140.09— AIC Message Missing
TII 002145.09— FCC Message Missing
TII 002820.31— Operator Not Seated During Reverser Command
TII 004310.09— Vehicle Automation Communication Fault
TII 004310.11— Vehicle Automation Fault
TII 004310.14— Operator Not Present During Vehicle Automation
TII 520283.14— Automation Suspend State
TII 522149.14— Wheel Speed Limited
TII 522149.31— Wheel Speed Limited
TII 522187.14— Controller Configuration
TII 522390.09— Implement Message Missing
TII 522390.11— Automation Abort Message Received
TII 523922.31— Secondary Brake On While Tractor Not In Neutral Or Moving
TII 523957.31— Engine Start With Vehicle In Gear
TII 523958.31— Ratio Between Forward And Reverse Speeds is Incorrect.
TII 523960.17— Operator Not Present At Low Speeds
TII 523960.31— Operator Not Seated During Reverser Command
TII 523961.02— Park Engaged While In Gear
TII 523961.07— Park Lock Engagement Fault
TII 523962.31— MFWD Speed Incorrect
TII 523966.31— Transmission Come Home Mode
TII 524020.31— Transmission In Gear at Power Up
TII 524279.31— Operator Not Seated With Transmission In Neutral
Powershift Transmission Shift Control Software Diagnostic Trouble Codes (TIP)
TIP 000190.01— Transmission Disengaged Due to Heavy Engine Load
TIP 000628.02— TIP EOL Data Fault
TIP 000628.12— TIP Programming
TIP 000629.12— TIP Control Unit Fault
TIP 001745.14— TIP Start Up Checks Incomplete
TIP 002000.09— ECU Message Missing
TIP 002003.09— PTP Message Missing
TIP 002006.09— EIC Message Missing
TIP 002007.09— RPT Message Missing
TIP 002019.09— XMC Message Missing
TIP 002020.09— SFA Message Missing
TIP 002035.09— HCC Message Missing
TIP 002036.09— PTF Message Missing
TIP 002049.09— OIC Message Missing
TIP 002071.09— CCU Message Missing
TIP 002139.09— ATC Message Missing
TIP 002140.09— AIC Message Missing
TIP 002145.09— FCC Message Missing
TIP 002161.09— SV1 Message Missing
TIP 002820.31— Operator Not Seated During Reverser Command
TIP 520576.31— Transmission Auto Mode Disabled
TIP 520870.02— TIP EOL Data Fault
TIP 520871.02— TIP EOL Data Fault
TIP 520958.14— Wheel Speed Limited
TIP 520958.31— Speed Selection Invalid
TIP 520959.14— Operator Not Seated During Speed Selection Change
TIP 522149.14— Wheel Speed Limited
TIP 522149.31— Wheel Speed Limited
TIP 522390.09— Implement Message Missing
TIP 522390.11— Automation Abort Message Received
TIP 523922.31— Secondary Brake On While Moving
TIP 523966.31— Transmission Come Home Mode
TIP 524020.31— Transmission In Gear at Power Up
TIP 524173.18— Shift Commanded With Clutch Partially Depressed
TIP 524277.00— Engine Speed Too High To Start a Downshift
TIP 524279.31— Operator Not Seated With Transmission In Neutral
Vehicle Load Center Control Software Diagnostic Trouble Codes (VLC)
VLC 000444.03— Rear Control Unit Unswitched Supply Voltage High
VLC 000444.04— Rear Control Unit Unswitched Supply Voltage Low
VLC 000444.06— Rear Control Unit Unswitched Supply Current High
VLC 000628.02— VLC EOL Data Fault
VLC 000628.12— VLC Programming
VLC 000629.12— VLC Control Unit Fault
VLC 000630.13— VLC Calibration Fault/Not Calibrated
VLC 000630.31— VLC Calibration Fault
VLC 002000.09— ECU Message Missing
VLC 002040.09— PDU Message Missing
VLC 002047.09— CCU Message Missing
VLC 002049.09— OIC Message Missing
VLC 002050.09— CLC Message Missing
VLC 002055.09— RLC Message Missing
VLC 002145.09— FCC Message Missing
VLC 002149.06— VLC Circuit Current High
VLC 002240.09— TEC Message Missing
VLC 002348.03— High Beam Lights Circuit Voltage High
VLC 002348.05— High Beam Lights Circuit Current Low
VLC 002348.06— High Beam Lights Circuit Current High
VLC 002350.03— Low Beam Lights Circuit Voltage High
VLC 002350.05— Low Beam Lights Circuit Current Low
VLC 002350.06— Low Beam Lights Circuit Current High
VLC 002368.06— Trailer Left Turn Signal Lights Circuit Current High
VLC 002370.06— Trailer Right Turn Signal Lights Circuit Current High
VLC 003598.04— Wake Up Signal Voltage Low
VLC 520542.03— Vehicle CAN Bus High Circuit Voltage High
VLC 520543.04— Vehicle CAN Bus Low Circuit Low
VLC 520870.02— VLC Control Unit Fault
VLC 521391.03— Right Washer Pump Circuit Voltage High
VLC 521391.05— Right Washer Pump Circuit Current Low
VLC 521391.06— Right Washer Pump Circuit Current High
VLC 521533.03— Front Outer Hood Flood Lights Left Circuit Voltage High
VLC 521533.05— Front Outer Hood Flood Lights Left Circuit Current Low
VLC 521533.06— Front Outer Hood Flood Lights Left Circuit Current High
VLC 521534.03— Front Inner Hood Flood Lights Left Circuit Voltage High
VLC 521534.05— Front Inner Hood Flood Lights Left Circuit Current Low
VLC 521534.06— Front Inner Hood Flood Lights Left Circuit Current High
VLC 521550.03— Front Outer Hood Flood Lights Right Circuit Voltage High
VLC 521550.05— Front Outer Hood Flood Lights Right Circuit Current Low
VLC 521550.06— Front Outer Hood Flood Lights Right Circuit Current High
VLC 521552.03— Front Inner Hood Flood Lights Right Circuit Voltage High
VLC 521552.05— Front Inner Hood Flood Lights Right Circuit Current Low
VLC 521552.06— Front Inner Hood Flood Lights Right Circuit Current High
VLC 521835.20— Control Unit Ground Circuit Fault
VLC 522311.03— Rear Washer Pump Circuit Voltage High
VLC 522311.05— Rear Washer Pump Circuit Current Low
VLC 522311.06— Rear Washer Pump Circuit Current High
VLC 522312.03— Front Washer Pump Circuit Voltage High
VLC 522312.05— Front Washer Pump Circuit Current Low
VLC 522312.06— Front Washer Pump Circuit Current High
VLC 524259.00— VLC Temperature Above 115 Degrees Celsius
VLC 524259.16— VLC Temperature Above 100 Degrees Celsius
Virtual Terminal Implement Control Software Diagnostic Trouble Codes (VTI)
VTI 000609.12— CAN Bus Communication Failure
VTI 002040.09— PDU Message Missing
VTI 521780.12— USB Internal Failure
VTI 523310.12— Flash Memory Read/Write Failure
VTI 524050.12— Clock Functionality May Be Invalid
Virtual Terminal Vehicle Control Software Diagnostic Trouble Codes (VTV)
VTV 000158.03— Switched Supply Voltage High
VTV 000158.04— Switched Supply Voltage Low
VTV 000158.05— Power Loss During Software Installation
VTV 000168.03— CommandCenter™ (VTV) Unswitched Supply Voltage High
VTV 000441.00— CommandCenter™ Temperature High
VTV 000441.01— CommandCenter™ Temperature Low
VTV 000442.00— CommandCenter™ Processor Temperature High
VTV 000609.12— CAN bus Communication Failure
VTV 516776.31— CommandCenter™ Processor Does Not Have Basics Activation
VTV 516843.09— CommandCenter™ Communication Error
VTV 516849.09— CommandCenter™ Error
VTV 520211.05— USB Drive Removed To Soon
VTV 522976.02— USB Drive Error
VTV 522976.11— Software Installation Error
VTV 522976.13— Software Installation Error
VTV 522976.14— Software Installation Error
VTV 522976.19— Software Download Error
VTV 523436.00— Display Processor System Error
VTV 523436.08— Display Processor System Error
VTV 523436.09— Display Processor System Error
VTV 523436.12— Display Processor System Error
VTV 523436.14— Display Processor System Error
VTV 523773.03— Vehicle CAN bus Circuit Voltage High
VTV 523773.04— Vehicle CAN bus Circuit Voltage Low
VTV 523774.03— Vehicle CAN bus Circuit Voltage High
VTV 523774.04— Vehicle CAN bus Circuit Voltage Low
VTV 524055.00— No Data Storage Space Remaining
VTV 524055.15— Data Storage Space Low
VTV 524055.16— Data Storage Space Low
VTV 524215.03— Implement CAN Bus Circuit Voltage High
VTV 524215.04— Implement CAN Bus Circuit Voltage Low
VTV 524217.03— Implement CAN Bus Circuit Voltage High
VTV 524217.04— Implement CAN Bus Circuit Voltage Low
VTV 524259.00— Secondary Display Monitor Temperature High
VTV 524259.01— Secondary Display Monitor Temperature Low
ActiveCommand Steering (ACS) A-Box Main Control Software Diagnostic Trouble Codes (XMA)
XMA 000168.01— ActiveCommand Steering A-Box Supply Voltage Low
XMA 000609.12— Incorrect Software
XMA 000628.12— ActiveCommand Steering Control Units Programming
XMA 000629.02— ActiveCommand Steering A-Box Control Unit Fault
XMA 000629.12— ActiveCommand Steering A-Box Control Unit Fault
XMA 000639.08— Vehicle CAN Bus Fault
XMA 000639.12— Vehicle CAN Bus Fault
XMA 000639.14— CAN Bus Error Limit Exceeded
XMA 000701.02— Incompatible Harness on ActiveCommand Steering A-Box Control Unit
XMA 000702.12— Hardware Self-Test Failed
XMA 000704.09— System Start-up Checks Failed
XMA 000705.09— System Motion Checks Failed
XMA 000708.08— ActiveCommand Steering A-Box Control Unit Fault
XMA 000708.10— ActiveCommand Steering A-Box Control Unit Fault
XMA 000708.16— ActiveCommand Steering A-Box Control Unit Fault
XMA 000708.18— ActiveCommand Steering A-Box Control Unit Fault
XMA 000708.20— ActiveCommand Steering A-Box Control Unit Fault
XMA 000708.21— ActiveCommand Steering A-Box Control Unit Fault
XMA 000709.08— ActiveCommand Steering A-Box Control Unit Fault
XMA 000709.10— ActiveCommand Steering A-Box Control Unit Fault
XMA 000709.16— ActiveCommand Steering A-Box Control Unit Fault
XMA 000709.18— ActiveCommand Steering A-Box Control Unit Fault
XMA 000709.20— ActiveCommand Steering A-Box Control Unit Fault
XMA 000709.21— ActiveCommand Steering A-Box Control Unit Fault
XMA 000710.08— ActiveCommand Steering A-Box Control Unit Fault
XMA 000710.10— ActiveCommand Steering A-Box Control Unit Fault
XMA 000710.16— ActiveCommand Steering A-Box Control Unit Fault
XMA 000710.18— ActiveCommand Steering A-Box Control Unit Fault
XMA 000710.20— ActiveCommand Steering A-Box Control Unit Fault
XMA 000710.21— ActiveCommand Steering A-Box Control Unit Fault
XMA 000711.08— ActiveCommand Steering A-Box Control Unit Fault
XMA 000711.10— ActiveCommand Steering A-Box Control Unit Fault
XMA 000711.16— ActiveCommand Steering A-Box Control Unit Fault
XMA 000711.18— ActiveCommand Steering A-Box Control Unit Fault
XMA 000711.20— ActiveCommand Steering A-Box Control Unit Fault
XMA 000711.21— ActiveCommand Steering A-Box Control Unit Fault
XMA 001058.00— Air Trailer Pre-Brake Pressure Higher Than Commanded
XMA 001058.01— Air Trailer Pre-Brake Pressure Lower Than Commanded
XMA 001231.08— ActiveCommand Steering CAN Bus Fault
XMA 001231.12— ActiveCommand Steering CAN Bus Fault
XMA 001231.14— ActiveCommand Steering CAN Bus Fault
XMA 002000.09— ECU Messages Missing
XMA 002003.09— PTI/PTP Messages Missing
XMA 002005.09— TII/TIP Messages Missing
XMA 002019.09— XSA Messages Missing on ActiveCommand Steering CAN Bus
XMA 002049.09— OIC Messages Missing
XMA 002071.09— CCU Messages Missing
XMA 002200.09— XMB Messages Missing on ActiveCommand Steering CAN Bus
XMA 002201.09— XSB Messages Missing on ActiveCommand Steering CAN Bus
XMA 002240.09— TEC Messages Missing
XMA 003841.08— ActiveCommand Steering A-Box Control Unit Fault
XMA 003841.16— ActiveCommand Steering A-Box Control Unit Fault
XMA 003841.18— ActiveCommand Steering A-Box Control Unit Fault
XMA 003841.20— ActiveCommand Steering A-Box Control Unit Fault
XMA 003841.21— ActiveCommand Steering A-Box Control Unit Fault
XMA 003842.08— ActiveCommand Steering A-Box Control Unit Fault
XMA 003842.16— ActiveCommand Steering A-Box Control Unit Fault
XMA 003842.18— ActiveCommand Steering A-Box Control Unit Fault
XMA 003842.20— ActiveCommand Steering A-Box Control Unit Fault
XMA 003842.21— ActiveCommand Steering A-Box Control Unit Fault
XMA 003843.08— ActiveCommand Steering A-Box Control Unit Fault
XMA 003843.16— ActiveCommand Steering A-Box Control Unit Fault
XMA 003843.18— ActiveCommand Steering A-Box Control Unit Fault
XMA 003843.20— ActiveCommand Steering A-Box Control Unit Fault
XMA 003843.21— ActiveCommand Steering A-Box Control Unit Fault
XMA 003844.08— ActiveCommand Steering A-Box Control Unit Fault
XMA 003844.16— ActiveCommand Steering A-Box Control Unit Fault
XMA 003844.18— ActiveCommand Steering A-Box Control Unit Fault
XMA 003844.20— ActiveCommand Steering A-Box Control Unit Fault
XMA 003844.21— ActiveCommand Steering A-Box Control Unit Fault
XMA 003850.03— ActiveCommand Steering A-Box Control Unit Fault
XMA 003850.04— ActiveCommand Steering A-Box Control Unit Fault
XMA 003851.03— ActiveCommand Steering A-Box Control Unit Fault
XMA 003851.04— ActiveCommand Steering A-Box Control Unit Fault
XMA 003852.02— ActiveCommand Steering A-Box Control Unit Fault
XMA 003852.03— ActiveCommand Steering A-Box Control Unit Fault
XMA 003852.04— ActiveCommand Steering A-Box Control Unit Fault
XMA 003857.08— ActiveCommand Steering A-Box Control Unit Fault
XMA 003857.16— ActiveCommand Steering A-Box Control Unit Fault
XMA 003857.18— ActiveCommand Steering A-Box Control Unit Fault
XMA 003858.08— ActiveCommand Steering A-Box Control Unit Fault
XMA 003858.16— ActiveCommand Steering A-Box Control Unit Fault
XMA 003858.18— ActiveCommand Steering A-Box Control Unit Fault
XMA 003859.09— XMB and XSB Messages Missing on ActiveCommand Steering CAN Bus
XMA 003861.03— ActiveCommand Steering B-Box Control Unit Fault
XMA 003861.04— ActiveCommand Steering B-Box Control Unit Fault
XMA 003861.08— ActiveCommand Steering B-Box Control Unit Fault
XMA 003862.03— ActiveCommand Steering B-Box Control Unit Fault
XMA 003862.04— ActiveCommand Steering B-Box Control Unit Fault
XMA 003862.08— ActiveCommand Steering B-Box Control Unit Fault
XMA 003863.03— Secondary Brake Lever Sensor 3 Voltage High
XMA 003863.04— Secondary Brake Lever Sensor 3 Voltage Low
XMA 003863.08— Secondary Brake Lever Sensor 3 Out of Range
XMA 003867.03— ActiveCommand Steering A-Box Control Unit Fault
XMA 003867.04— ActiveCommand Steering A-Box Control Unit Fault
XMA 003869.14— ActiveCommand Steering B-Box Control Unit Fault
XMA 003870.03— ActiveCommand Steering A-Box Control Unit Fault
XMA 003870.04— ActiveCommand Steering A-Box Control Unit Fault
XMA 003870.15— ActiveCommand Steering A-Box Control Unit Fault
XMA 003872.03— ActiveCommand Steering A-Box Control Unit Fault
XMA 003872.04— ActiveCommand Steering A-Box Control Unit Fault
XMA 003873.00— ActiveCommand Steering A-Box Control Unit Fault
XMA 003873.01— ActiveCommand Steering A-Box Control Unit Fault
XMA 003873.03— ActiveCommand Steering A-Box Control Unit Fault
XMA 003873.04— ActiveCommand Steering A-Box Control Unit Fault
XMA 003874.03— ActiveCommand Steering A-Box Control Unit Fault
XMA 003874.04— ActiveCommand Steering A-Box Control Unit Fault
XMA 003874.15— ActiveCommand Steering A-Box Control Unit Fault
XMA 003882.02— ActiveCommand Steering A-Box Control Unit Fault
XMA 004085.07— Air Trailer Pre-Brake Valve Stuck Open
XMA 004085.13— Air Trailer Pre-Brake Valve Not Calibrated
XMA 522269.07— Steer Right Valve 1 Stuck Open
XMA 522270.07— Steer Left Valve 1 Stuck Open
XMA 522777.13— Steering Wheel Module Not Calibrated
XMA 522791.13— Gyroscope Not Calibrated
XMA 522807.01— ActiveCommand Steering A-Box Control Unit Fault
XMA 522837.16— Front Brake Solenoid Current High
XMA 522837.18— Front Brake Solenoid Current Low
XMA 522838.03— Front Brake Solenoid Short To Voltage Source
XMA 522838.05— Front Brake Solenoid Open Circuit
XMA 522838.06— Front Brake Solenoid Short To Ground
XMA 522838.16— Front Brake Solenoid Current High
XMA 522838.18— Front Brake Solenoid Current Low
XMA 522841.16— Air Trailer Pre-Brake Solenoid Current High
XMA 522841.18— Air Trailer Pre-Brake Solenoid Current Low
XMA 522842.03— Air Trailer Pre-Brake Solenoid Short To Voltage Source
XMA 522842.05— Air Trailer Pre-Brake Solenoid Open Circuit
XMA 522842.06— Air Trailer Pre-Brake Solenoid Short To Ground
XMA 522842.16— Air Trailer Pre-Brake Solenoid Current High
XMA 522842.18— Air Trailer Pre-Brake Solenoid Current Low
XMA 522845.16— Steer Right Solenoid 1 Current High
XMA 522845.18— Steer Right Solenoid 1 Current Low
XMA 522846.03— Steer Right Solenoid 1 Short To Voltage Source
XMA 522846.05— Steer Right Solenoid 1 Open Circuit
XMA 522846.06— Steer Right Solenoid 1 Short To Ground
XMA 522846.16— Steer Right Solenoid 1 Current High
XMA 522846.18— Steer Right Solenoid 1 Current Low
XMA 522847.16— Steer Left Solenoid 1 Current High
XMA 522847.18— Steer Left Solenoid 1 Current Low
XMA 522848.03— Steer Left Solenoid 1 Short To Voltage Source
XMA 522848.05— Steer Left Solenoid 1 Open Circuit
XMA 522848.06— Steer Left Solenoid 1 Short To Ground
XMA 522848.16— Steer Left Solenoid 1 Current High
XMA 522848.18— Steer Left Solenoid 1 Current Low
XMA 522920.09— XMA Timed Out Waiting for XSA
XMA 522976.12— ActiveCommand Steering A-Box Control Unit Fault
XMA 523137.14— Steering System Fault
XMA 523329.09— XMB and XSB Messages Missing on ActiveCommand Steering CAN Bus
XMA 523329.14— Steering System Fault
XMA 523789.13— Wheel Angle Sensors Not Calibrated
XMA 523795.13— Steering Valve Not Calibrated
XMA 523840.00— Front Brake Pressure High
XMA 523840.01— Front Brake Pressure Low
XMA 523844.07— Front Brake Valve Stuck Open
XMA 523844.13— Front Brake Not Calibrated
XMA 523844.14— Front Brake Valve Failure
XMA 523925.09— XMA Messages Missing on ActiveCommand Steering CAN Bus
XMA 524055.02— ActiveCommand Steering A-Box Control Unit Fault
XMA 524055.12— ActiveCommand Steering A-Box Control Unit Fault
ActiveCommand Steering (ACS) B-Box Main Control Software Diagnostic Trouble Codes (XMB)
XMB 000168.01— ActiveCommand Steering B-Box Supply Voltage Low
XMB 000609.12— Incorrect Software
XMB 000628.12— ActiveCommand Steering Control Units Programming
XMB 000629.02— ActiveCommand Steering B-Box Control Unit Fault
XMB 000629.12— ActiveCommand Steering B-Box Control Unit Fault
XMB 000639.08— Vehicle CAN Bus Fault
XMB 000639.12— Vehicle CAN Bus Fault
XMB 000639.14— CAN Bus Error Limit Exceeded
XMB 000701.02— Incompatible Harness on ActiveCommand Steering B-Box Control Unit
XMB 000702.12— Hardware Self-Test Failed
XMB 000704.09— System Start-up Checks Failed
XMB 000705.09— System Motion Checks Failed
XMB 000708.08— ActiveCommand Steering B-Box Control Unit Fault
XMB 000708.10— ActiveCommand Steering B-Box Control Unit Fault
XMB 000708.16— ActiveCommand Steering B-Box Control Unit Fault
XMB 000708.18— ActiveCommand Steering B-Box Control Unit Fault
XMB 000708.20— ActiveCommand Steering B-Box Control Unit Fault
XMB 000708.21— ActiveCommand Steering B-Box Control Unit Fault
XMB 000709.08— ActiveCommand Steering B-Box Control Unit Fault
XMB 000709.10— ActiveCommand Steering B-Box Control Unit Fault
XMB 000709.16— ActiveCommand Steering B-Box Control Unit Fault
XMB 000709.18— ActiveCommand Steering B-Box Control Unit Fault
XMB 000709.20— ActiveCommand Steering B-Box Control Unit Fault
XMB 000709.21— ActiveCommand Steering B-Box Control Unit Fault
XMB 000710.08— ActiveCommand Steering B-Box Control Unit Fault
XMB 000710.10— ActiveCommand Steering B-Box Control Unit Fault
XMB 000710.16— ActiveCommand Steering B-Box Control Unit Fault
XMB 000710.18— ActiveCommand Steering B-Box Control Unit Fault
XMB 000710.20— ActiveCommand Steering B-Box Control Unit Fault
XMB 000710.21— ActiveCommand Steering B-Box Control Unit Fault
XMB 000711.08— ActiveCommand Steering B-Box Control Unit Fault
XMB 000711.10— ActiveCommand Steering B-Box Control Unit Fault
XMB 000711.16— ActiveCommand Steering B-Box Control Unit Fault
XMB 000711.18— ActiveCommand Steering B-Box Control Unit Fault
XMB 000711.20— ActiveCommand Steering B-Box Control Unit Fault
XMB 000711.21— ActiveCommand Steering B-Box Control Unit Fault
XMB 001231.08— ActiveCommand Steering CAN Bus Fault
XMB 001231.12— ActiveCommand Steering CAN Bus Fault
XMB 001231.14— ActiveCommand Steering CAN Bus Fault
XMB 002000.09— ECU Messages Missing
XMB 002003.09— PTI or PTP Messages Missing
XMB 002005.09— TII or TIP Messages Missing
XMB 002019.09— XSA Messages Missing on ActiveCommand Steering CAN Bus
XMB 002049.09— OIC Messages Missing
XMB 002071.09— CCU Messages Missing
XMB 002198.09— XMA Messages Missing on ActiveCommand Steering CAN Bus
XMB 002201.09— XSB Messages Missing on ActiveCommand Steering CAN Bus
XMB 002240.09— TEC Messages Missing
XMB 003032.02— Right Brake Pedal Position Sensor Circuit Fault
XMB 003032.03— Right Brake Pedal Position Sensor Circuit Fault
XMB 003032.04— Right Brake Pedal Position Sensor Circuit Fault
XMB 003032.13— Right Brake Pedal Position Sensor Not Calibrated
XMB 003033.02— Left Brake Pedal Position Sensor Circuit Fault
XMB 003033.03— Left Brake Pedal Position Sensor Circuit Fault
XMB 003033.04— Left Brake Pedal Position Sensor Circuit Fault
XMB 003033.13— Left Brake Pedal Position Sensor Not Calibrated
XMB 003841.08— ActiveCommand Steering B-Box Control Unit Fault
XMB 003841.16— ActiveCommand Steering B-Box Control Unit Fault
XMB 003841.18— ActiveCommand Steering B-Box Control Unit Fault
XMB 003841.20— ActiveCommand Steering B-Box Control Unit Fault
XMB 003841.21— ActiveCommand Steering B-Box Control Unit Fault
XMB 003842.08— ActiveCommand Steering B-Box Control Unit Fault
XMB 003842.16— ActiveCommand Steering B-Box Control Unit Fault
XMB 003842.18— ActiveCommand Steering B-Box Control Unit Fault
XMB 003842.20— ActiveCommand Steering B-Box Control Unit Fault
XMB 003842.21— ActiveCommand Steering B-Box Control Unit Fault
XMB 003843.08— ActiveCommand Steering B-Box Control Unit Fault
XMB 003843.16— ActiveCommand Steering B-Box Control Unit Fault
XMB 003843.18— ActiveCommand Steering B-Box Control Unit Fault
XMB 003843.20— ActiveCommand Steering B-Box Control Unit Fault
XMB 003843.21— ActiveCommand Steering B-Box Control Unit Fault
XMB 003844.08— ActiveCommand Steering B-Box Control Unit Fault
XMB 003844.16— ActiveCommand Steering B-Box Control Unit Fault
XMB 003844.18— ActiveCommand Steering B-Box Control Unit Fault
XMB 003844.20— ActiveCommand Steering B-Box Control Unit Fault
XMB 003844.21— ActiveCommand Steering B-Box Control Unit Fault
XMB 003849.01— ActiveCommand Steering B-Box Control Unit Fault
XMB 003850.03— ActiveCommand Steering B-Box Control Unit Fault
XMB 003850.04— ActiveCommand Steering B-Box Control Unit Fault
XMB 003851.03— ActiveCommand Steering B-Box Control Unit Fault
XMB 003851.04— ActiveCommand Steering B-Box Control Unit Fault
XMB 003853.03— ActiveCommand Steering B-Box Control Unit Fault
XMB 003853.04— ActiveCommand Steering B-Box Control Unit Fault
XMB 003854.03— ActiveCommand Steering B-Box Control Unit Fault
XMB 003854.04— ActiveCommand Steering B-Box Control Unit Fault
XMB 003855.03— ActiveCommand Steering B-Box Control Unit Fault
XMB 003855.04— ActiveCommand Steering B-Box Control Unit Fault
XMB 003856.01— ActiveCommand Steering B-Box Control Unit Fault
XMB 003857.08— ActiveCommand Steering B-Box Control Unit Fault
XMB 003857.16— ActiveCommand Steering B-Box Control Unit Fault
XMB 003857.18— ActiveCommand Steering B-Box Control Unit Fault
XMB 003858.08— ActiveCommand Steering B-Box Control Unit Fault
XMB 003858.16— ActiveCommand Steering B-Box Control Unit Fault
XMB 003858.18— ActiveCommand Steering B-Box Control Unit Fault
XMB 003859.09— XMA and XSA Messages Missing on ActiveCommand Steering CAN Bus
XMB 003861.02— ActiveCommand Steering B-Box Control Unit Fault
XMB 003861.03— ActiveCommand Steering B-Box Control Unit Fault
XMB 003861.04— ActiveCommand Steering B-Box Control Unit Fault
XMB 003861.08— ActiveCommand Steering B-Box Control Unit Fault
XMB 003862.03— ActiveCommand Steering B-Box Control Unit Fault
XMB 003862.04— ActiveCommand Steering B-Box Control Unit Fault
XMB 003862.08— ActiveCommand Steering B-Box Control Unit Fault
XMB 003863.03— Secondary Brake Lever Sensor 3 Voltage High
XMB 003863.04— Secondary Brake Lever Sensor 3 Voltage Low
XMB 003863.08— Secondary Brake Lever Sensor 3 Out of Range
XMB 003869.14— ActiveCommand Steering B-Box Control Unit Fault
XMB 003870.03— ActiveCommand Steering B-Box Control Unit Fault
XMB 003870.04— ActiveCommand Steering B-Box Control Unit Fault
XMB 003870.15— ActiveCommand Steering B-Box Control Unit Fault
XMB 003872.03— ActiveCommand Steering B-Box Control Unit Fault
XMB 003872.04— ActiveCommand Steering B-Box Control Unit Fault
XMB 003874.03— ActiveCommand Steering B-Box Control Unit Fault
XMB 003874.04— ActiveCommand Steering B-Box Control Unit Fault
XMB 003874.15— ActiveCommand Steering B-Box Control Unit Fault
XMB 003882.02— ActiveCommand Steering B-Box Control Unit Fault
XMB 003888.03— ActiveCommand Steering B-Box Control Unit Fault
XMB 003888.04— ActiveCommand Steering B-Box Control Unit Fault
XMB 003888.08— ActiveCommand Steering B-Box Control Unit Fault
XMB 003888.13— ActiveCommand Steering B-Box Control Unit Fault
XMB 003889.03— ActiveCommand Steering B-Box Control Unit Fault
XMB 003889.04— ActiveCommand Steering B-Box Control Unit Fault
XMB 003889.08— ActiveCommand Steering B-Box Control Unit Fault
XMB 003889.13— ActiveCommand Steering B-Box Control Unit Fault
XMB 521531.09— Secondary Brake CAN Message Missing
XMB 522269.07— Steer Right Valve 2 Stuck Open
XMB 522270.07— Steer Left Valve 2 Stuck Open
XMB 522279.07— Secondary Brake Valve Stuck Open
XMB 522279.13— Secondary Brake Not Calibrated
XMB 522279.14— Secondary Brake Valve Failure
XMB 522280.00— Secondary Brake Pressure High
XMB 522280.01— Secondary Brake Pressure Low
XMB 522777.13— Steering Wheel Module Not Calibrated
XMB 522807.01— ActiveCommand Steering B-Box Control Unit Switched Voltage Low
XMB 522837.16— Steering Wheel Brake Solenoid Current High
XMB 522837.18— Steering Wheel Brake Solenoid Current Low
XMB 522838.03— Steering Wheel Brake Solenoid Short to Voltage Source
XMB 522838.05— Steering Wheel Brake Solenoid Open Circuit
XMB 522838.06— Steering Wheel Brake Solenoid Short To Ground
XMB 522838.13— Steering Wheel Brake Not Calibrated
XMB 522838.16— Steering Wheel Brake Solenoid Current High
XMB 522838.18— Steering Wheel Brake Solenoid Current Low
XMB 522843.16— Secondary Brake Solenoid Current High
XMB 522843.18— Secondary Brake Solenoid Current Low
XMB 522844.03— Secondary Brake Solenoid Short To Voltage Source
XMB 522844.05— Secondary Brake Solenoid Open Circuit
XMB 522844.06— Secondary Brake Solenoid Short To Ground
XMB 522844.16— Secondary Brake Solenoid Current High
XMB 522844.18— Secondary Brake Solenoid Current Low
XMB 522845.16— Steer Right Solenoid 2 Current High
XMB 522845.18— Steer Right Solenoid 2 Current Low
XMB 522846.03— Steer Right Solenoid 2 Short To Voltage Source
XMB 522846.05— Steer Right Solenoid 2 Open Circuit
XMB 522846.06— Steer Right Solenoid 2 Short To Ground
XMB 522846.16— Steer Right Solenoid 2 Current High
XMB 522846.18— Steer Right Solenoid 2 Current Low
XMB 522847.16— Steer Left Solenoid 2 Current High
XMB 522847.18— Steer Left Solenoid 2 Current Low
XMB 522848.03— Steer Left Solenoid 2 Short To Voltage Source
XMB 522848.05— Steer Left Solenoid 2 Open Circuit
XMB 522848.06— Steer Left Solenoid 2 Short To Ground
XMB 522848.16— Steer Left Solenoid 2 Current High
XMB 522848.18— Steer Left Solenoid 2 Current Low
XMB 522920.09— XMB Timed Out Waiting for XSB
XMB 522976.12— ActiveCommand Steering B-Box Control Unit Fault
XMB 523137.14— Steering System Fault
XMB 523329.09— XMA and XSA Messages Missing on ActiveCommand Steering CAN Bus
XMB 523329.14— Steering System Fault
XMB 523789.13— Wheel Angle Sensors Not Calibrated
XMB 523795.13— Steering Valve Not Calibrated
XMB 523925.09— XMA Messages Missing on ActiveCommand Steering CAN Bus
XMB 524055.02— ActiveCommand Steering B-Box Control Unit Fault
XMB 524055.12— ActiveCommand Steering B-Box Control Unit Fault
XMB 524166.08— Right Brake Pedal Switch Circuit Fault
XMB 524169.08— Left Brake Pedal Switch Circuit Fault
AutoTrac Main Control Software Diagnostic Trouble Codes (XMC)
XMC 000168.01— Steering System Control Unit Supply Voltage Low
XMC 000609.12— Incorrect Software
XMC 000628.12— Steering System Control Units Programming
XMC 000629.02— Steering System Control Unit Fault
XMC 000629.12— Steering System Control Unit Fault
XMC 000639.08— Vehicle CAN Bus Fault
XMC 000701.02— Incompatible Harness on Steering System Control Unit
XMC 000702.12— Hardware Self-Test Failed
XMC 000704.09— System Start-up Checks Failed
XMC 000705.09— System Motion Checks Failed
XMC 000708.08— Steering System Control Unit Fault
XMC 000708.10— Steering System Control Unit Fault
XMC 000708.16— Steering System Control Unit Fault
XMC 000708.18— Steering System Control Unit Fault
XMC 000708.20— Steering System Control Unit Fault
XMC 000708.21— Steering System Control Unit Fault
XMC 000709.08— Steering System Control Unit Fault
XMC 000709.10— Steering System Control Unit Fault
XMC 000709.16— Steering System Control Unit Fault
XMC 000709.18— Steering System Control Unit Fault
XMC 000709.20— Steering System Control Unit Fault
XMC 000709.21— Steering System Control Unit Fault
XMC 001058.00— Air Trailer Pre-Brake Pressure Higher Than Commanded
XMC 001058.01— Air Trailer Pre-Brake Pressure Lower Than Commanded
XMC 001231.08— Steering System Control Unit Fault
XMC 001231.12— Steering System Control Unit Fault
XMC 001231.14— Steering System Control Unit Fault
XMC 002000.09— ECU Messages Missing
XMC 002003.09— PTI or PTP Messages Missing
XMC 002005.09— TII or TIP Messages Missing
XMC 002019.09— Steering System Control Unit Fault
XMC 002049.09— OIC Messages Missing
XMC 002071.09— CCU Messages Missing
XMC 002240.09— TEC Messages Missing
XMC 003032.02— Right Brake Pedal Position Sensor Circuit Fault
XMC 003032.03— Right Brake Pedal Position Sensor Circuit Fault
XMC 003032.04— Right Brake Pedal Position Sensor Circuit Fault
XMC 003032.13— Right Brake Pedal Position Sensor Not Calibrated
XMC 003033.02— Left Brake Pedal Position Sensor Circuit Fault
XMC 003033.03— Left Brake Pedal Position Sensor Circuit Fault
XMC 003033.04— Left Brake Pedal Position Sensor Circuit Fault
XMC 003033.13— Left Brake Pedal Position Sensor Not Calibrated
XMC 003841.00— Steering System Control Unit Fault
XMC 003841.01— Steering System Control Unit Fault
XMC 003841.02— Steering System Control Unit Fault
XMC 003842.00— Steering System Control Unit Fault
XMC 003842.01— Steering System Control Unit Fault
XMB 003849.01— Steering System Control Unit Fault
XMC 003853.03— Steering System Control Unit Fault
XMC 003853.04— Steering System Control Unit Fault
XMC 003854.03— Steering System Control Unit Fault
XMC 003854.04— Steering System Control Unit Fault
XMC 003855.03— Steering System Control Unit Fault
XMC 003855.04— Steering System Control Unit Fault
XMC 003856.01— Steering System Control Unit Fault
XMC 003857.08— Steering System Control Unit Fault
XMC 003857.16— Steering System Control Unit Fault
XMC 003857.18— Steering System Control Unit Fault
XMC 003858.08— Steering System Control Unit Fault
XMC 003858.16— Steering System Control Unit Fault
XMC 003858.18— Steering System Control Unit Fault
XMC 003861.02— Steering System Control Unit Fault
XMC 003861.03— Steering System Control Unit Fault
XMC 003861.04— Steering System Control Unit Fault
XMC 003861.08— Steering System Control Unit Fault
XMC 003862.03— Steering System Control Unit Fault
XMC 003862.04— Steering System Control Unit Fault
XMC 003867.00— Steering System Control Unit Fault
XMC 003867.01— Steering System Control Unit Fault
XMC 003867.03— Steering System Control Unit Fault
XMC 003867.04— Steering System Control Unit Fault
XMC 003869.14— Steering System Control Unit Fault
XMC 003870.03— Steering System Control Unit Fault
XMC 003870.04— Steering System Control Unit Fault
XMC 003870.15— Steering System Control Unit Fault
XMC 003872.03— Steering System Control Unit Fault
XMC 003872.04— Steering System Control Unit Fault
XMC 003873.03— Steering System Control Unit Fault
XMC 003873.04— Steering System Control Unit Fault
XMC 003874.03— Steering System Control Unit Fault
XMC 003874.04— Steering System Control Unit Fault
XMC 003874.15— Steering System Control Unit Fault
XMC 003882.02— Steering System Control Unit Fault
XMC 003888.03— Steering System Control Unit Fault
XMC 003888.04— Steering System Control Unit Fault
XMC 003888.08— Steering System Control Unit Fault
XMC 003888.13— Steering System Control Unit Fault
XMC 003889.03— Steering System Control Unit Fault
XMC 003889.04— Steering System Control Unit Fault
XMC 003889.08— Steering System Control Unit Fault
XMC 003889.13— Steering System Control Unit Fault
XMC 004085.07— Air Trailer Pre-Brake Valve Stuck Open
XMC 004085.13— Air Trailer Pre-Brake Valve Not Calibrated
XMC 004085.14— Air Trailer Pre-Brake Valve Failure
XMC 522269.07— Steer Right Valve Stuck Open
XMC 522270.07— Steer Left Valve Stuck Open
XMC 522279.07— Secondary Brake Valve Stuck Open
XMC 522279.13— Secondary Brake Valve Not Calibrated
XMC 522279.14— Secondary Brake Valve Failure
XMC 522280.00— Secondary Brake Pressure High
XMC 522280.01— Secondary Brake Pressure Low
XMC 522777.02— Steering Wheel Sensors Disagree
XMC 522835.16— Front Brake Solenoid Current High
XMC 522835.18— Front Brake Solenoid Current Low
XMC 522836.03— Front Brake Solenoid Short To Voltage Source
XMC 522836.05— Front Brake Solenoid Open Circuit
XMC 522836.06— Front Brake Solenoid Short To Ground
XMC 522836.16— Front Brake Solenoid Current High
XMC 522836.18— Front Brake Solenoid Current Low
XMC 522841.16— Air Trailer Pre-Brake Solenoid Current High
XMC 522841.18— Air Trailer Pre-Brake Solenoid Current Low
XMC 522842.03— Air Trailer Pre-Brake Solenoid Short To Voltage Source
XMC 522842.05— Air Trailer Pre-Brake Solenoid Open Circuit
XMC 522842.06— Air Trailer Pre-Brake Solenoid Short To Ground
XMC 522842.16— Air Trailer Pre-Brake Solenoid Current High
XMC 522842.18— Air Trailer Pre-Brake Solenoid Current Low
XMC 522843.16— Secondary Brake Solenoid Current High
XMC 522843.18— Secondary Brake Solenoid Current Low
XMC 522844.03— Secondary Brake Solenoid Short To Voltage Source
XMC 522844.05— Secondary Brake Solenoid Open Circuit
XMC 522844.06— Secondary Brake Solenoid Short To Ground
XMC 522844.16— Secondary Brake Solenoid Current High
XMC 522844.18— Secondary Brake Solenoid Current Low
XMC 522845.16— Steer Right Solenoid Current High
XMC 522845.18— Steer Right Solenoid Current Low
XMC 522846.03— Steer Right Solenoid Short To Voltage Source
XMC 522846.05— Steer Right Solenoid Open Circuit
XMC 522846.06— Steer Right Solenoid Short To Ground
XMC 522846.16— Steer Right Solenoid Current High
XMC 522846.18— Steer Right Solenoid Current Low
XMC 522847.16— Steer Left Solenoid Current High
XMC 522847.18— Steer Left Solenoid Current Low
XMC 522848.03— Steer Left Solenoid Short To Voltage Source
XMC 522848.05— Steer Left Solenoid Open Circuit
XMC 522848.06— Steer Left Solenoid Short To Ground
XMC 522848.16— Steer Left Solenoid Current High
XMC 522848.18— Steer Left Solenoid Current Low
XMC 522920.09— XMC Timed Out Waiting for XSC
XMC 522976.12— Steering System Control Unit Fault
XMC 523137.14— Steering System Fault
XMC 523329.14— Steering System Fault
XMC 523789.13— Wheel Angle Sensor Not Calibrated
XMC 523795.13— Steering Valve Not Calibrated
XMC 523840.00— Front Brake Pressure High
XMC 523840.01— Front Brake Pressure Low
XMC 523844.07— Front Brake Enable Valve Stuck Open
XMC 523844.13— Front Brake Solenoid Not Calibrated
XMC 523844.14— Front Brake Valve Failure
XMC 524055.02— Steering System Control Unit Fault
XMC 524055.12— Steering System Control Unit Fault
XMC 524166.08— Right Brake Pedal Switch Circuit Fault
XMC 524169.08— Left Brake Pedal Switch Circuit Fault
ActiveCommand Steering (ACS) A-Box Supervisor Control Software Diagnostic Trouble Codes (XSA)
XSA 000084.02— Wheel Speed Input Low While CAN Wheel Speed Above 0.5 km/h
XSA 000158.01— ActiveCommand Steering A-Box Control Unit Switched Voltage Low
XSA 000609.12— Incorrect Software
XSA 000611.09— Start-up Checks Timed Out
XSA 000622.12— System Executing Diagnostic Procedure
XSA 000628.12— ActiveCommand Steering Control Units Programming
XSA 000629.02— ActiveCommand Steering A-Box Control Unit Fault
XSA 000629.12— ActiveCommand Steering A-Box Control Unit Fault
XSA 000629.31— ActiveCommand Steering A-Box Control Unit Fault
XSA 000639.08— Vehicle CAN Bus Fault
XSA 000639.12— Vehicle CAN Bus Fault
XSA 000639.14— Vehicle CAN Bus Fault
XSA 000701.02— Incompatible Harness on ActiveCommand Steering A-Box Control Unit
XSA 000702.12— Hardware Self-Test Failed
XSA 000703.12— System Executing Diagnostic Procedure
XSA 000704.09— System Start-up Checks Failed
XSA 000705.09— System Motion Checks Failed
XSA 000708.08— ActiveCommand Steering A-Box Control Unit Fault
XSA 000708.10— ActiveCommand Steering A-Box Control Unit Fault
XSA 000708.16— ActiveCommand Steering A-Box Control Unit Fault
XSA 000708.18— ActiveCommand Steering A-Box Control Unit Fault
XSA 000708.20— ActiveCommand Steering A-Box Control Unit Fault
XSA 000708.21— ActiveCommand Steering A-Box Control Unit Fault
XSA 000709.08— ActiveCommand Steering A-Box Control Unit Fault
XSA 000709.10— ActiveCommand Steering A-Box Control Unit Fault
XSA 000709.16— ActiveCommand Steering A-Box Control Unit Fault
XSA 000709.18— ActiveCommand Steering A-Box Control Unit Fault
XSA 000709.20— ActiveCommand Steering A-Box Control Unit Fault
XSA 000709.21— ActiveCommand Steering A-Box Control Unit Fault
XSA 000710.08— ActiveCommand Steering A-Box Control Unit Fault
XSA 000710.10— ActiveCommand Steering A-Box Control Unit Fault
XSA 000710.16— ActiveCommand Steering A-Box Control Unit Fault
XSA 000710.18— ActiveCommand Steering A-Box Control Unit Fault
XSA 000710.20— ActiveCommand Steering A-Box Control Unit Fault
XSA 000710.21— ActiveCommand Steering A-Box Control Unit Fault
XSA 000711.08— ActiveCommand Steering A-Box Control Unit Fault
XSA 000711.10— ActiveCommand Steering A-Box Control Unit Fault
XSA 000711.16— ActiveCommand Steering A-Box Control Unit Fault
XSA 000711.18— ActiveCommand Steering A-Box Control Unit Fault
XSA 000711.20— ActiveCommand Steering A-Box Control Unit Fault
XSA 000711.21— ActiveCommand Steering A-Box Control Unit Fault
XSA 000714.08— Steering Wheel Module Position Sensor 3 Out of Range
XSA 000714.10— Steering Wheel Module Position Sensor 3 Delta High
XSA 000714.16— Steering Wheel Module Position Sensor 3 Frequency High
XSA 000714.18— Steering Wheel Module Position Sensor 3 Frequency Low
XSA 000714.20— Steering Wheel Module Position Sensor 3 Duty Cycle High
XSA 000714.21— Steering Wheel Module Position Sensor 3 Duty Cycle Low
XSA 000715.08— Steering Wheel Module Position Sensor 4 Out of Range
XSA 000715.10— Steering Wheel Module Position Sensor 4 Out of Range
XSA 000715.16— Steering Wheel Module Position Sensor 4 Frequency High
XSA 000715.18— Steering Wheel Module Position Sensor 4 Frequency Low
XSA 000715.20— Steering Wheel Module Position Sensor 4 Duty Cycle High
XSA 000715.21— Steering Wheel Module Position Sensor 4 Duty Cycle Low
XSA 001044.09— First Motion Checks Timed Out
XSA 001058.01— Air Trailer Pre-Brake Pressure Lower Than Commanded
XSA 001058.03— Air Trailer Pre-Brake Pressure Sensor Voltage High
XSA 001058.04— Air Trailer Pre-Brake Pressure Sensor Voltage Low
XSA 001093.03— Left Rear Brake Pressure Sensor Voltage High
XSA 001093.04— Left Rear Brake Pressure Sensor Voltage Low
XSA 001093.15— Left Rear Brake Pressure High with No Command
XSA 001094.03— Right Rear Brake Pressure Sensor Voltage High
XSA 001094.04— Right Rear Brake Pressure Sensor Voltage Low
XSA 001094.15— Right Rear Brake Pressure High with No Command
XSA 001231.08— ActiveCommand Steering CAN Bus Fault
XSA 001231.12— ActiveCommand Steering CAN Bus Fault
XSA 001231.14— ActiveCommand Steering CAN Bus Fault
XSA 001504.14— Operator Out of Seat While AutoTrac™ is Active
XSA 001504.31— Operator Out of Seat While AutoTrac™ is Active
XSA 001807.08— Steering Wheel Module Position Sensor 1 Out of Range
XSA 001807.10— Steering Wheel Module Position Sensor 1 Delta Too High
XSA 001807.16— Steering Wheel Module Position Sensor 1 Frequency High
XSA 001807.18— Steering Wheel Module Position Sensor 1 Frequency Low
XSA 001807.20— Steering Wheel Module Position Sensor 1 Duty Cycle High
XSA 001807.21— Steering Wheel Module Position Sensor 1 Duty Cycle Low
XSA 002000.09— ECU Messages Missing
XSA 002003.09— PTI or PTP Messages Missing
XSA 002005.09— TII or TIP Messages Missing
XSA 002013.09— PDU Messages Missing
XSA 002028.09— StarFire™ Receiver Messages Missing
XSA 002042.09— GreenStar™ Display Messages Missing
XSA 002049.09— CAB Messages Missing
XSA 002071.09— CCU Messages Missing
XSA 002198.09— XMA Messages Missing on ActiveCommand Steering CAN Bus
XSA 002200.09— XMB Messages Missing on ActiveCommand Steering CAN Bus
XSA 002201.09— XSB Messages Missing on ActiveCommand Steering CAN Bus
XSA 002240.09— TEC Messages Missing
XSA 003509.03— Sensor Supply 1 Voltage High
XSA 003509.04— Sensor Supply 1 Voltage Low
XSA 003510.03— Sensor Supply 2 Voltage High
XSA 003510.04— Sensor Supply 2 Voltage Low
XSA 003511.03— Sensor Supply 3 Voltage High
XSA 003511.04— Sensor Supply 3 Voltage Low
XSA 003512.03— Sensor Supply 4 Voltage High
XSA 003512.04— Sensor Supply 4 Voltage Low
XSA 003841.08— ActiveCommand Steering A-Box Control Unit Fault
XSA 003841.16— ActiveCommand Steering A-Box Control Unit Fault
XSA 003841.18— ActiveCommand Steering A-Box Control Unit Fault
XSA 003841.20— ActiveCommand Steering A-Box Control Unit Fault
XSA 003841.21— ActiveCommand Steering A-Box Control Unit Fault
XSA 003842.08— ActiveCommand Steering A-Box Control Unit Fault
XSA 003842.16— ActiveCommand Steering A-Box Control Unit Fault
XSA 003842.18— ActiveCommand Steering A-Box Control Unit Fault
XSA 003842.20— ActiveCommand Steering A-Box Control Unit Fault
XSA 003842.21— ActiveCommand Steering A-Box Control Unit Fault
XSA 003843.08— ActiveCommand Steering A-Box Control Unit Fault
XSA 003843.16— ActiveCommand Steering A-Box Control Unit Fault
XSA 003843.18— ActiveCommand Steering A-Box Control Unit Fault
XSA 003843.20— ActiveCommand Steering A-Box Control Unit Fault
XSA 003843.21— ActiveCommand Steering A-Box Control Unit Fault
XSA 003844.08— ActiveCommand Steering A-Box Control Unit Fault
XSA 003844.16— ActiveCommand Steering A-Box Control Unit Fault
XSA 003844.18— ActiveCommand Steering A-Box Control Unit Fault
XSA 003844.20— ActiveCommand Steering A-Box Control Unit Fault
XSA 003844.21— ActiveCommand Steering A-Box Control Unit Fault
XSA 003847.08— Right Wheel Angle Sensor (Primary) Out of Range
XSA 003847.16— Right Wheel Angle Sensor (Primary) Frequency High
XSA 003847.18— Right Wheel Angle Sensor (Primary) Frequency Low
XSA 003847.20— Right Wheel Angle Sensor (Primary) Duty Cycle High
XSA 003847.21— Right Wheel Angle Sensor (Primary) Duty Cycle Low
XSA 003848.08— Right Wheel Angle Sensor (Secondary) Out of Range
XSA 003848.16— Right Wheel Angle Sensor (Secondary) Frequency High
XSA 003848.18— Right Wheel Angle Sensor (Secondary) Frequency Low
XSA 003848.20— Right Wheel Angle Sensor (Secondary) Duty Cycle High
XSA 003848.21— Right Wheel Angle Sensor (Secondary) Duty Cycle Low
XSA 003850.03— ActiveCommand Steering A-Box Control Unit Fault
XSA 003850.04— ActiveCommand Steering A-Box Control Unit Fault
XSA 003851.03— ActiveCommand Steering A-Box Control Unit Fault
XSA 003851.04— ActiveCommand Steering A-Box Control Unit Fault
XSA 003852.02— ActiveCommand Steering A-Box Control Unit Fault
XSA 003852.03— ActiveCommand Steering A-Box Control Unit Fault
XSA 003852.04— ActiveCommand Steering A-Box Control Unit Fault
XSA 003857.08— ActiveCommand Steering A-Box Control Unit Fault
XSA 003857.16— ActiveCommand Steering A-Box Control Unit Fault
XSA 003857.18— ActiveCommand Steering A-Box Control Unit Fault
XSA 003858.08— ActiveCommand Steering A-Box Control Unit Fault
XSA 003858.16— ActiveCommand Steering A-Box Control Unit Fault
XSA 003858.18— ActiveCommand Steering A-Box Control Unit Fault
XSA 003859.09— XMB and XSB Messages Missing on ActiveCommand Steering CAN Bus
XSA 003860.09— XMB and XSB Messages Missing on ActiveCommand Steering CAN Bus
XSA 003861.03— ActiveCommand Steering A-Box Control Unit Fault
XSA 003861.04— ActiveCommand Steering A-Box Control Unit Fault
XSA 003861.08— ActiveCommand Steering A-Box Control Unit Fault
XSA 003862.03— ActiveCommand Steering A-Box Control Unit Fault
XSA 003862.04— ActiveCommand Steering A-Box Control Unit Fault
XSA 003862.08— ActiveCommand Steering A-Box Control Unit Fault
XSA 003863.03— Secondary Brake Lever Sensor 3 Voltage High
XSA 003863.04— Secondary Brake Lever Sensor 3 Voltage Low
XSA 003863.08— Secondary Brake Lever Sensor 3 Out of Range
XSA 003866.03— Secondary Brake Lever Sensor 3 Voltage High
XSA 003866.04— Secondary Brake Lever Sensor 3 Voltage Low
XSA 003866.08— Secondary Brake Lever Sensor 3 Out of Range
XSA 003867.00— ActiveCommand Steering A-Box Control Unit Fault
XSA 003867.01— ActiveCommand Steering A-Box Control Unit Fault
XSA 003867.03— ActiveCommand Steering A-Box Control Unit Fault
XSA 003867.04— ActiveCommand Steering A-Box Control Unit Fault
XSA 003869.14— ActiveCommand Steering B-Box Control Unit Fault
XSA 003870.03— ActiveCommand Steering A-Box Control Unit Fault
XSA 003870.04— ActiveCommand Steering A-Box Control Unit Fault
XSA 003870.15— ActiveCommand Steering A-Box Control Unit Fault
XSA 003872.03— ActiveCommand Steering A-Box Control Unit Fault
XSA 003872.04— ActiveCommand Steering A-Box Control Unit Fault
XSA 003873.00— ActiveCommand Steering A-Box Control Unit Fault
XSA 003873.01— ActiveCommand Steering A-Box Control Unit Fault
XSA 003873.03— ActiveCommand Steering A-Box Control Unit Fault
XSA 003873.04— ActiveCommand Steering A-Box Control Unit Fault
XSA 003874.03— ActiveCommand Steering A-Box Control Unit Fault
XSA 003874.04— ActiveCommand Steering A-Box Control Unit Fault
XSA 003874.15— ActiveCommand Steering A-Box Control Unit Fault
XSA 003878.03— Secondary Brake Pressure Sensor Voltage High
XSA 003878.04— Secondary Brake Pressure Sensor Voltage Low
XSA 003879.03— Right Rear Brake Pressure Sensor Voltage High
XSA 003879.04— Right Rear Brake Pressure Sensor Voltage Low
XSA 003879.15— Right Rear Brake Pressure High with No Command
XSA 003882.02— ActiveCommand Steering A-Box Control Unit Fault
XSA 003883.02— Wheel Speed Input Low While CAN Wheel Speed Above 0.5 km/h
XSA 004085.07— Air Trailer Pre-Brake Valve Stuck Open
XSA 004085.13— Trailer Brake Valve Not Calibrated
XSA 005237.09— External Guidance System Messages Missing
XSA 520193.02— Incompatible Harness on ActiveCommand Steering A-Box and B-Box
XSA 522390.09— AutoTrac™ Messages Missing or Security Not Satisfied
XSA 522390.11— AutoTrac™ Stop Message Received
XSA 522390.12— AutoTrac™ Messages Missing or Security Not Satisfied
XSA 522765.05— ActiveCommand Steering A-Box Control Unit Valve Ground 4 Open Circuit
XSA 522766.05— ActiveCommand Steering A-Box Control Unit Valve Ground 3 Open Circuit
XSA 522767.05— ActiveCommand Steering A-Box Control Unit Valve Ground 2 Open Circuit
XSA 522768.05— ActiveCommand Steering A-Box Control Unit Valve Ground 1 Open Circuit
XSA 522770.05— ActiveCommand Steering A-Box Control Unit J3 Connector Disconnected
XSA 522776.08— Left Wheel Angle Sensor (Secondary) Out of Range
XSA 522776.16— Left Wheel Angle Sensor (Secondary) Frequency High
XSA 522776.18— Left Wheel Angle Sensor (Secondary) Frequency Low
XSA 522776.20— Left Wheel Angle Sensor (Secondary) Duty Cycle High
XSA 522776.21— Left Wheel Angle Sensor (Secondary) Duty Cycle Low
XSA 522777.05— Steering Wheel Harness Disconnected
XSA 522777.13— Steering Wheel Position Sensors Not Calibrated
XSA 522784.08— Handshaking Duty Cycle From XSB Out of Range
XSA 522784.16— Handshaking Frequency From XSB High
XSA 522784.18— Handshaking Frequency From XSB Low
XSA 522785.08— Handshaking Duty Cycle From XMB Out of Range
XSA 522785.16— Handshaking Frequency From XMB High
XSA 522785.18— Handshaking Frequency From XMB Low
XSA 522789.14— Tow Mode Not Allowed
XSA 522791.02— Gyroscope Failed In Range
XSA 522791.03— Gyroscope Voltage High
XSA 522791.04— Gyroscope Voltage Low
XSA 522791.13— Gyroscope Not Calibrated
XSA 522792.00— Steer Right Valve 1 Stuck Open
XSA 522792.01— Steer Right Valve 1 Stuck Closed
XSA 522792.03— Steer Right Valve 1 Position Sensor Voltage High
XSA 522792.04— Steer Right Valve 1 Position Sensor Voltage Low
XSA 522793.00— Steer Left Valve 1 Stuck Open
XSA 522793.01— Steer Left Valve 1 Stuck Closed
XSA 522793.03— Steer Left Valve 1 Position Sensor Voltage High
XSA 522793.04— Steer Left Valve 1 Position Sensor Voltage Low
XSA 522807.01— ActiveCommand Steering A-Box Control Unit Switched Voltage Low
XSA 522852.03— Front Brake Enable Solenoid Voltage High
XSA 522852.04— Front Brake Enable Solenoid Voltage Low
XSA 522852.05— Front Brake Enable Solenoid Current Low
XSA 522852.06— Front Brake Enable Solenoid Current High
XSA 522920.09— XSA Timed Out Waiting for XMA
XSA 522976.12— ActiveCommand Steering A-Box Control Unit Fault
XSA 523137.14— Steering System Fault
XSA 523137.19— XSA Command Disagrees With XMA Command
XSA 523216.04— ActiveCommand Steering A-Box Control Unit Valve Power 4 Unswitched Voltage Low
XSA 523217.04— ActiveCommand Steering A-Box Control Unit Valve Power 3 Unswitched Voltage Low
XSA 523218.04— ActiveCommand Steering A-Box Control Unit Valve Power 2 Unswitched Voltage Low
XSA 523219.04— ActiveCommand Steering A-Box Control Unit Valve Power 1 Unswitched Voltage Low
XSA 523329.09— XMB and XSB Messages Missing on ActiveCommand Steering CAN Bus
XSA 523329.14— Steering System Fault
XSA 523789.05— Left Wheel Angle Sensor Disconnected
XSA 523789.13— Wheel Angle Sensors Not Calibrated
XSA 523794.03— Air Trailer Pre-Brake Enable Solenoid Voltage High
XSA 523794.04— Air Trailer Pre-Brake Enable Solenoid Voltage Low
XSA 523794.05— Air Trailer Pre-Brake Enable Solenoid Current Low
XSA 523794.06— Air Trailer Pre-Brake Enable Solenoid Current High
XSA 523795.01— Steer Enable Valve 1 Stuck Closed
XSA 523795.07— Steer Enable Valve 1 Stuck Open
XSA 523795.13— Steering Valve Not Calibrated
XSA 523795.14— Steering Valve One and Two Are Swapped
XSA 523795.31— Steering Valve Phasing Is Not Calibrated
XSA 523815.03— Steer Enable Solenoid 1 Voltage High
XSA 523815.04— Steer Enable Solenoid 1 Voltage Low
XSA 523815.05— Steer Enable Solenoid 1 Current Low
XSA 523815.06— Steer Enable Solenoid 1 Current High
XSA 523821.02— Incompatible Harness on ActiveCommand Steering A-Box Control Unit
XSA 523824.08— Steering Wheel Module Position Sensor 2 Out of Range
XSA 523824.10— Steering Wheel Module Position Sensor 2 Delta High
XSA 523824.16— Steering Wheel Module Position Sensor 2 Frequency High
XSA 523824.18— Steering Wheel Module Position Sensor 2 Frequency Low
XSA 523824.20— Steering Wheel Module Position Sensor 2 Duty Cycle High
XSA 523824.21— Steering Wheel Module Position Sensor 2 Duty Cycle Low
XSA 523826.08— Left Wheel Angle Sensor (Primary) Out of Range
XSA 523826.16— Left Wheel Angle Sensor (Primary) Frequency High
XSA 523826.18— Left Wheel Angle Sensor (Primary) Frequency Low
XSA 523826.20— Left Wheel Angle Sensor (Primary) Duty Cycle High
XSA 523826.21— Left Wheel Angle Sensor (Primary) Duty Cycle Low
XSA 523840.01— Front Brake Pressure Lower Than Commanded
XSA 523840.03— Front Brake Pressure Sensor Voltage High
XSA 523840.04— Front Brake Pressure Sensor Voltage Low
XSA 523844.07— Front Brake Enable Valve Stuck Open
XSA 523844.13— Front Brake Solenoid Not Calibrated
XSA 523925.09— XMA Messages Missing on ActiveCommand Steering CAN Bus
XSA 524055.02— ActiveCommand Steering A-Box Control Unit Fault
XSA 524055.12— ActiveCommand Steering A-Box Control Unit Fault
XSA 524169.14— Tow Mode Requested Before Brake Pedals Validated
ActiveCommand Steering (ACS) B-Box Supervisor Control Software Diagnostic Trouble Codes (XSB)
XSB 000158.01— ActiveCommand Steering B-Box Control Unit Voltage Low While Normal on A-Box
XSB 000168.01— ActiveCommand Steering B-Box Supply Voltage Low
XSB 000609.12— Incorrect Software
XSB 000628.12— ActiveCommand Steering Control Units Programming
XSB 000629.02— ActiveCommand Steering B-Box Control Unit Fault
XSB 000629.12— ActiveCommand Steering B-Box Control Unit Fault
XSB 000629.31— ActiveCommand Steering A-Box Control Unit Fault
XSB 000639.08— Vehicle CAN Bus Fault
XSB 000639.12— Vehicle CAN Bus Fault
XSB 000639.14— CAN Bus Error Limit Exceeded
XSB 000701.02— Incompatible Harness on ActiveCommand Steering B-Box Control Unit
XSB 000702.12— Hardware Self-Test Failed
XSB 000703.12— System Executing Diagnostic Procedure
XSB 000704.09— System Start-up Checks Failed
XSB 000705.09— System Motion Checks Failed
XSB 000708.08— ActiveCommand Steering B-Box Control Unit Fault
XSB 000708.10— ActiveCommand Steering B-Box Control Unit Fault
XSB 000708.16— ActiveCommand Steering B-Box Control Unit Fault
XSB 000708.18— ActiveCommand Steering B-Box Control Unit Fault
XSB 000708.20— ActiveCommand Steering B-Box Control Unit Fault
XSB 000708.21— ActiveCommand Steering B-Box Control Unit Fault
XSB 000709.08— ActiveCommand Steering B-Box Control Unit Fault
XSB 000709.10— ActiveCommand Steering B-Box Control Unit Fault
XSB 000709.16— ActiveCommand Steering B-Box Control Unit Fault
XSB 000709.18— ActiveCommand Steering B-Box Control Unit Fault
XSB 000709.20— ActiveCommand Steering B-Box Control Unit Fault
XSB 000709.21— ActiveCommand Steering B-Box Control Unit Fault
XSB 000710.08— ActiveCommand Steering B-Box Control Unit Fault
XSB 000710.10— ActiveCommand Steering B-Box Control Unit Fault
XSB 000710.16— ActiveCommand Steering B-Box Control Unit Fault
XSB 000710.18— ActiveCommand Steering B-Box Control Unit Fault
XSB 000710.20— ActiveCommand Steering B-Box Control Unit Fault
XSB 000710.21— ActiveCommand Steering B-Box Control Unit Fault
XSB 000711.08— ActiveCommand Steering B-Box Control Unit Fault
XSB 000711.10— ActiveCommand Steering B-Box Control Unit Fault
XSB 000711.16— ActiveCommand Steering B-Box Control Unit Fault
XSB 000711.18— ActiveCommand Steering B-Box Control Unit Fault
XSB 000711.20— ActiveCommand Steering B-Box Control Unit Fault
XSB 000711.21— ActiveCommand Steering B-Box Control Unit Fault
XSB 000712.08— Steering Wheel Module Position Sensor 1 Out of Range
XSB 000712.10— Steering Wheel Module Position Sensor 1 Delta High
XSB 000712.16— Steering Wheel Module Position Sensor 1 Frequency High
XSB 000712.18— Steering Wheel Module Position Sensor 1 Frequency Low
XSB 000712.20— Steering Wheel Module Position Sensor 1 Duty Cycle High
XSB 000712.21— Steering Wheel Module Position Sensor 1 Duty Cycle Low
XSB 000713.08— Steering Wheel Module Position Sensor 2 Out of Range
XSB 000713.10— Steering Wheel Module Position Sensor 2 Delta High
XSB 000713.16— Steering Wheel Module Position Sensor 2 Frequency High
XSB 000713.18— Steering Wheel Module Position Sensor 2 Frequency Low
XSB 000713.20— Steering Wheel Module Position Sensor 2 Duty Cycle High
XSB 000713.21— Steering Wheel Module Position Sensor 2 Duty Cycle Low
XSB 000818.05— Alternator/Battery Relay Stuck Open
XSB 000818.06— Alternator/Battery Relay Stuck Closed
XSB 001044.07— Low Pressure From Backup Hydraulic Pump
XSB 001044.14— Backup Hydraulic Pump Running Too Long
XSB 001094.03— Right Rear Brake Pressure Sensor Voltage High
XSB 001094.04— Right Rear Brake Pressure Sensor Voltage Low
XSB 001094.15— Right Rear Brake Pressure High with No Command
XSB 001231.08— ActiveCommand Steering CAN Bus Fault
XSB 001231.12— ActiveCommand Steering CAN Bus Fault
XSB 001231.14— ActiveCommand Steering CAN Bus Fault
XSB 002000.09— ECU Messages Missing
XSB 002003.09— PTI or PTP Messages Missing
XSB 002005.09— TII or TIP Messages Missing
XSB 002013.09— XMA and XSA Messages Missing on ActiveCommand Steering CAN Bus
XSB 002019.09— XSA Messages Missing on ActiveCommand Steering CAN Bus
XSB 002049.09— OIC Messages Missing
XSB 002071.09— CCU Messages Missing
XSB 002198.09— XMA Messages Missing on ActiveCommand Steering CAN Bus
XSB 002200.09— XMB Messages Missing on ActiveCommand Steering CAN Bus
XSB 002240.09— TEC Messages Missing
XSB 003509.03— Sensor Supply 1 Voltage High
XSB 003509.04— Sensor Supply 1 Voltage Low
XSB 003510.03— Sensor Supply 2 Voltage High
XSB 003510.04— Sensor Supply 2 Voltage Low
XSB 003511.03— Sensor Supply 3 Voltage High
XSB 003511.04— Sensor Supply 3 Voltage Low
XSB 003512.03— Sensor Supply 4 Voltage High
XSB 003512.04— Sensor Supply 4 Voltage Low
XSB 003841.08— ActiveCommand Steering B-Box Control Unit Fault
XSB 003841.16— ActiveCommand Steering B-Box Control Unit Fault
XSB 003841.18— ActiveCommand Steering B-Box Control Unit Fault
XSB 003841.20— ActiveCommand Steering B-Box Control Unit Fault
XSB 003841.21— ActiveCommand Steering B-Box Control Unit Fault
XSB 003842.08— ActiveCommand Steering B-Box Control Unit Fault
XSB 003842.16— ActiveCommand Steering B-Box Control Unit Fault
XSB 003842.18— ActiveCommand Steering B-Box Control Unit Fault
XSB 003842.20— ActiveCommand Steering B-Box Control Unit Fault
XSB 003842.21— ActiveCommand Steering B-Box Control Unit Fault
XSB 003843.08— ActiveCommand Steering B-Box Control Unit Fault
XSB 003843.16— ActiveCommand Steering B-Box Control Unit Fault
XSB 003843.18— ActiveCommand Steering B-Box Control Unit Fault
XSB 003843.20— ActiveCommand Steering B-Box Control Unit Fault
XSB 003843.21— ActiveCommand Steering B-Box Control Unit Fault
XSB 003844.08— ActiveCommand Steering B-Box Control Unit Fault
XSB 003844.16— ActiveCommand Steering B-Box Control Unit Fault
XSB 003844.18— ActiveCommand Steering B-Box Control Unit Fault
XSB 003844.20— ActiveCommand Steering B-Box Control Unit Fault
XSB 003844.21— ActiveCommand Steering B-Box Control Unit Fault
XSB 003845.08— Left Wheel Angle Sensor (Primary) Out of Range
XSB 003845.16— Left Wheel Angle Sensor (Primary) Frequency High
XSB 003845.18— Left Wheel Angle Sensor (Primary) Frequency Low
XSB 003845.20— Left Wheel Angle Sensor (Primary) Duty Cycle High
XSB 003845.21— Left Wheel Angle Sensor (Primary) Duty Cycle Low
XSB 003846.08— Left Wheel Angle Sensor (Secondary) Out of Range
XSB 003846.16— Left Wheel Angle Sensor (Secondary) Frequency High
XSB 003846.18— Left Wheel Angle Sensor (Secondary) Frequency Low
XSB 003846.20— Left Wheel Angle Sensor (Secondary) Duty Cycle High
XSB 003846.21— Left Wheel Angle Sensor (Secondary) Duty Cycle Low
XSB 003849.01— ActiveCommand Steering B-Box Control Unit Fault
XSB 003850.03— ActiveCommand Steering B-Box Control Unit Fault
XSB 003850.04— ActiveCommand Steering B-Box Control Unit Fault
XSB 003851.03— ActiveCommand Steering B-Box Control Unit Fault
XSB 003851.04— ActiveCommand Steering B-Box Control Unit Fault
XSB 003853.03— ActiveCommand Steering B-Box Control Unit Fault
XSB 003853.04— ActiveCommand Steering B-Box Control Unit Fault
XSB 003854.03— ActiveCommand Steering B-Box Control Unit Fault
XSB 003854.04— ActiveCommand Steering B-Box Control Unit Fault
XSB 003855.03— ActiveCommand Steering B-Box Control Unit Fault
XSB 003855.04— ActiveCommand Steering B-Box Control Unit Fault
XSB 003856.01— ActiveCommand Steering B-Box Control Unit Fault
XSB 003857.08— ActiveCommand Steering B-Box Control Unit Fault
XSB 003857.16— ActiveCommand Steering B-Box Control Unit Fault
XSB 003857.18— ActiveCommand Steering B-Box Control Unit Fault
XSB 003858.08— ActiveCommand Steering B-Box Control Unit Fault
XSB 003858.16— ActiveCommand Steering B-Box Control Unit Fault
XSB 003858.18— ActiveCommand Steering B-Box Control Unit Fault
XSB 003859.09— XMA and XSA Messages Missing on ActiveCommand Steering CAN Bus
XSB 003860.09— XMA and XSA Messages Missing on ActiveCommand Steering CAN Bus
XSB 003861.02— ActiveCommand Steering B-Box Control Unit Fault
XSB 003861.03— ActiveCommand Steering B-Box Control Unit Fault
XSB 003861.04— ActiveCommand Steering B-Box Control Unit Fault
XSB 003861.08— ActiveCommand Steering B-Box Control Unit Fault
XSB 003862.03— ActiveCommand Steering B-Box Control Unit Fault
XSB 003862.04— ActiveCommand Steering B-Box Control Unit Fault
XSB 003862.08— ActiveCommand Steering B-Box Control Unit Fault
XSB 003863.03— Secondary Brake Lever Sensor 3 Voltage High
XSB 003863.04— Secondary Brake Lever Sensor 3 Voltage Low
XSB 003863.08— Secondary Brake Lever Sensor 3 Out of Range
XSB 003864.03— Secondary Brake Lever Sensor 1 Voltage High
XSB 003864.04— Secondary Brake Lever Sensor 1 Voltage Low
XSB 003864.08— Secondary Brake Lever Sensor 1 Out of Range
XSB 003865.03— Secondary Brake Lever Sensor 2 Voltage High
XSB 003865.04— Secondary Brake Lever Sensor 2 Voltage Low
XSB 003865.08— Secondary Brake Lever Sensor 2 Out of Range
XSB 003869.14— ActiveCommand Steering B-Box Control Unit Fault
XSB 003870.03— ActiveCommand Steering B-Box Control Unit Fault
XSB 003870.04— ActiveCommand Steering B-Box Control Unit Fault
XSB 003870.15— ActiveCommand Steering B-Box Control Unit Fault
XSB 003872.03— ActiveCommand Steering B-Box Control Unit Fault
XSB 003872.04— ActiveCommand Steering B-Box Control Unit Fault
XSB 003874.03— ActiveCommand Steering B-Box Control Unit Fault
XSB 003874.04— ActiveCommand Steering B-Box Control Unit Fault
XSB 003874.15— ActiveCommand Steering B-Box Control Unit Fault
XSB 003876.03— Left Rear Brake Pressure Sensor Voltage High
XSB 003876.04— Left Rear Brake Pressure Sensor Voltage Low
XSB 003876.15— Left Rear Brake Pressure High with No Command
XSB 003879.03— Right Rear Brake Pressure Sensor Voltage High
XSB 003879.04— Right Rear Brake Pressure Sensor Voltage Low
XSB 003879.15— Right Rear Brake Pressure High with No Command
XSB 003882.02— ActiveCommand Steering B-Box Control Unit Fault
XSB 003888.03— ActiveCommand Steering B-Box Control Unit Fault
XSB 003888.04— ActiveCommand Steering B-Box Control Unit Fault
XSB 003888.08— ActiveCommand Steering B-Box Control Unit Fault
XSB 003888.13— ActiveCommand Steering B-Box Control Unit Fault
XSB 003889.03— ActiveCommand Steering B-Box Control Unit Fault
XSB 003889.04— ActiveCommand Steering B-Box Control Unit Fault
XSB 003889.08— ActiveCommand Steering B-Box Control Unit Fault
XSB 003889.13— ActiveCommand Steering B-Box Control Unit Fault
XSB 520802.08— Right Wheel Angle Sensor (Primary) Out of Range
XSB 520802.16— Right Wheel Angle Sensor (Primary) Frequency High
XSB 520802.18— Right Wheel Angle Sensor (Primary) Frequency Low
XSB 520802.20— Right Wheel Angle Sensor (Primary) Duty Cycle High
XSB 520802.21— Right Wheel Angle Sensor (Primary) Duty Cycle Low
XSB 520803.08— Right Wheel Angle Sensor (Secondary) Out of Range
XSB 520803.16— Right Wheel Angle Sensor (Secondary) Frequency High
XSB 520803.18— Right Wheel Angle Sensor (Secondary) Frequency Low
XSB 520803.20— Right Wheel Angle Sensor (Secondary) Duty Cycle High
XSB 520803.21— Right Wheel Angle Sensor (Secondary) Duty Cycle Low
XSB 522279.07— Secondary Brake Enable Valve Stuck Open
XSB 522279.13— Secondary Brake Not Calibrated
XSB 522280.01— Secondary Brake Pressure is Lower Than Command
XSB 522280.03— Secondary Brake Pressure Sensor Voltage High
XSB 522280.04— Secondary Brake Pressure Sensor Voltage Low
XSB 522391.03— Secondary Brake Lever Sensor 3 Voltage High
XSB 522391.04— Secondary Brake Lever Sensor 3 Voltage Low
XSB 522391.08— Secondary Brake Lever Sensor 3 Out of Range
XSB 522393.03— Secondary Brake Lever Sensor 2 Voltage High
XSB 522393.04— Secondary Brake Lever Sensor 2 Voltage Low
XSB 522393.08— Secondary Brake Lever Sensor 2 Out of Range
XSB 522396.02— Secondary Brake Lever Sensor 1 and 2 Disagree
XSB 522396.03— Secondary Brake Lever Sensor 1 Voltage High
XSB 522396.04— Secondary Brake Lever Sensor 1 Voltage Low
XSB 522396.08— Secondary Brake Lever Sensor 1 Out of Range
XSB 522429.01— Pilot Pressure to Steering Valve Low
XSB 522765.05— ActiveCommand Steering B-Box Control Unit Valve Ground 4 Open Circuit
XSB 522766.05— ActiveCommand Steering B-Box Control Unit Valve Ground 3 Open Circuit
XSB 522767.05— ActiveCommand Steering B-Box Control Unit Valve Ground 2 Open Circuit
XSB 522768.05— ActiveCommand Steering B-Box Control Unit Valve Ground 1 Open Circuit
XSB 522770.05— ActiveCommand Steering B-Box Control Unit J3 Connector Disconnected
XSB 522772.08— Steering Wheel Module Position Sensor 4 Out of Range
XSB 522772.10— Steering Wheel Module Position Sensor 4 Delta High
XSB 522772.16— Steering Wheel Module Position Sensor 4 Frequency High
XSB 522772.18— Steering Wheel Module Position Sensor 4 Frequency Low
XSB 522772.20— Steering Wheel Module Position Sensor 4 Duty Cycle High
XSB 522772.21— Steering Wheel Module Position Sensor 4 Duty Cycle Low
XSB 522773.08— Steering Wheel Module Position Sensor 3 Out of Range
XSB 522773.10— Steering Wheel Module Position Sensor 3 Delta High
XSB 522773.16— Steering Wheel Module Position Sensor 3 Frequency High
XSB 522773.18— Steering Wheel Module Position Sensor 3 Frequency Low
XSB 522773.20— Steering Wheel Module Position Sensor 3 Duty Cycle High
XSB 522773.21— Steering Wheel Module Position Sensor 3 Duty Cycle Low
XSB 522777.13— Steering Wheel Position Sensors Not Calibrated
XSB 522784.08— Handshaking Duty Cycle From XSA Out of Range
XSB 522784.16— Handshaking Frequency From XSA High
XSB 522784.18— Handshaking Frequency From XSA Low
XSB 522785.08— Handshaking Duty Cycle From XMA Out of Range
XSB 522785.16— Handshaking Frequency From XMA High
XSB 522785.18— Handshaking Frequency From XMA Low
XSB 522786.01— Main Hydraulic Pump Pressure Below Nominal Operating Level
XSB 522787.01— Main Hydraulic Pump Pressure Below Nominal Operating Level
XSB 522787.03— Main Hydraulic Pump Pressure Sensor 2 Voltage High
XSB 522787.04— Main Hydraulic Pump Pressure Sensor 2 Voltage Low
XSB 522787.15— Main Hydraulic Pump Pressure Sensor 2 Higher Than Nominal
XSB 522787.17— Main Hydraulic Pump Pressure Sensor 2 Lower Than Nominal
XSB 522789.03— Backup Hydraulic Pump Pressure Sensor Voltage High
XSB 522789.04— Backup Hydraulic Pump Pressure Sensor Voltage Low
XSB 522789.14— Hydraulic Oil Less Than -10° C
XSB 522789.15— Backup Hydraulic Pump Pressure Sensor Reporting Higher Than Expected Pressure
XSB 522790.01— Main Hydraulic Pump Pressure Below Nominal Operating Level
XSB 522790.03— Main Hydraulic Pump Pressure Sensor 1 Voltage High
XSB 522790.04— Main Hydraulic Pump Pressure Sensor 1 Voltage Low
XSB 522790.15— Main Hydraulic Pump Pressure Sensor 1 Higher Than Nominal
XSB 522790.17— Main Hydraulic Pump Pressure Sensor 1 Lower Than Nominal
XSB 522792.00— Steer Right Valve 2 Stuck Open
XSB 522792.01— Steer Right Valve 2 Stuck Closed
XSB 522792.03— Steer Right Valve 2 Position Sensor Voltage High
XSB 522792.04— Steer Right Valve 2 Position Sensor Voltage Low
XSB 522793.00— Steer Left Valve 2 Stuck Open
XSB 522793.01— Steer Left Valve 2 Stuck Closed
XSB 522793.03— Steer Left Valve 2 Position Sensor Voltage High
XSB 522793.04— Steer Left Valve 2 Position Sensor Voltage Low
XSB 522807.01— ActiveCommand Steering B-Box Control Unit Switched Voltage Low
XSB 522852.03— Backup Hydraulic Pump Relay Voltage High
XSB 522852.04— Backup Hydraulic Pump Relay Voltage Low
XSB 522852.05— Backup Hydraulic Pump Relay Current Low
XSB 522852.06— Backup Hydraulic Pump Relay Current High
XSB 522853.03— Alternator/Battery Relay Voltage High
XSB 522853.04— Alternator/Battery Relay Voltage Low
XSB 522853.05— Alternator/Battery Relay Current Low
XSB 522853.06— Alternator/Battery Relay Current High
XSB 522920.09— XSB Timed Out Waiting for XMB
XSB 522976.12— ActiveCommand Steering B-Box Control Unit Fault
XSB 523137.14— Steering System Fault
XSB 523216.04— ActiveCommand Steering B-Box Control Unit Valve Power 4 Unswitched Voltage Low
XSB 523217.04— ActiveCommand Steering B-Box Control Unit Valve Power 3 Unswitched Voltage Low
XSB 523218.04— ActiveCommand Steering B-Box Control Unit Valve Power 2 Unswitched Voltage Low
XSB 523219.04— ActiveCommand Steering B-Box Control Unit Valve Power 1 Unswitched Voltage Low
XSB 523329.02— Steer By Wire System Error
XSB 523329.09— XMA and XSA Messages Missing on ActiveCommand Steering CAN Bus
XSB 523329.14— Steering System Fault
XSB 523789.05— Right Wheel Angle Sensor Disconnected
XSB 523789.13— Wheel Angle Sensors Not Calibrated
XSB 523795.01— Steer Enable Valve 2 Stuck Closed
XSB 523795.07— Steer Enable Valve 2 Stuck Open
XSB 523795.13— Steering Valve Not Calibrated
XSB 523814.03— Secondary Brake Enable Solenoid Voltage High
XSB 523814.04— Secondary Brake Enable Solenoid Voltage Low
XSB 523814.05— Secondary Brake Enable Solenoid Current Low
XSB 523814.06— Secondary Brake Enable Solenoid Current High
XSB 523815.03— Steer Enable Solenoid 2 Voltage High
XSB 523815.04— Steer Enable Solenoid 2 Voltage Low
XSB 523815.05— Steer Enable Solenoid 2 Current Low
XSB 523815.06— Steer Enable Solenoid 2 Current High
XSB 523821.02— Incompatible Harness on ActiveCommand Steering B-Box Control Unit
XSB 523839.14— Secondary Brake Lever Engaged at Start-up
XSB 523925.09— XMA Messages Missing on ActiveCommand Steering CAN Bus
XSB 524055.02— ActiveCommand Steering B-Box Control Unit Fault
XSB 524055.12— ActiveCommand Steering B-Box Control Unit Fault
AutoTrac Supervisor Control Software Diagnostic Trouble Codes (XSC)
XSC 000084.02— Wheel Speed Input Low
XSC 000609.12— Incorrect Software
XSC 000611.09— Start-up Checks Timed Out
XSC 000628.12— Steering System Control Units Programming
XSC 000629.02— Steering System Control Unit Fault
XSC 000629.12— Steering System Control Unit Fault
XSC 000629.31— Steering System Control Unit Fault
XSC 000639.08— Vehicle CAN Bus Fault
XSC 000701.02— Incompatible Harness on Steering System Control Unit
XSC 000702.12— Hardware Self-Test Failed
XSC 000704.09— System Start-up Checks Failed
XSC 000705.09— System Motion Checks Failed
XSC 000708.08— Steering System Control Unit Fault
XSC 000708.10— Steering System Control Unit Fault
XSC 000708.16— Steering System Control Unit Fault
XSC 000708.18— Steering System Control Unit Fault
XSC 000708.20— Steering System Control Unit Fault
XSC 000708.21— Steering System Control Unit Fault
XSC 000709.08— Steering System Control Unit Fault
XSC 000709.10— Steering System Control Unit Fault
XSC 000709.16— Steering System Control Unit Fault
XSC 000709.18— Steering System Control Unit Fault
XSC 000709.20— Steering System Control Unit Fault
XSC 000709.21— Steering System Control Unit Fault
XSC 000818.05— Alternator/Battery Relay Stuck Open
XSC 000818.06— Alternator/Battery Relay Stuck Closed
XSC 001044.07— Low Pressure From Backup Hydraulic Pump
XSC 001044.09— First Motion Checks Timed Out
XSC 001044.14— Backup Hydraulic Pump Running Too Long
XSC 001058.01— Air Trailer Pre-Brake Pressure Lower Than Commanded
XSC 001058.03— Air Trailer Pre-Brake Pressure Sensor Voltage High
XSC 001058.04— Air Trailer Pre-Brake Pressure Sensor Voltage Low
XSC 001093.03— Left Rear Brake Pressure Sensor Voltage High
XSC 001093.04— Left Rear Brake Pressure Sensor Voltage Low
XSC 001093.15— Left Rear Brake Pressure High with No Command
XSC 001094.03— Right Rear Brake Pressure Sensor Voltage High
XSC 001094.04— Right Rear Brake Pressure Sensor Voltage Low
XSC 001094.15— Right Rear Brake Pressure High with No Command
XSC 001231.08— Steering System Control Unit Fault
XSC 001231.12— Steering System Control Unit Fault
XSC 001231.14— Steering System Control Unit Fault
XSC 001504.14— Operator Out of Seat While AutoTrac™ is Active
XSC 001504.31— Operator Out of Seat While AutoTrac™ is Active
XSC 001807.02— Steering Wheel Motion Not Detected
XSC 001807.08— Steering Wheel Position Sensor 1 Out of Range
XSC 001807.10— Steering Wheel Position Sensor 1 Delta High
XSC 001807.16— Steering Wheel Position Sensor 1 Frequency High
XSC 001807.18— Steering Wheel Position Sensor 1 Frequency Low
XSC 001807.20— Steering Wheel Position Sensor 1 Duty Cycle High
XSC 001807.21— Steering Wheel Position Sensor 1 Duty Cycle Low
XSC 001807.31— Steering Wheel Motion Not Detected
XSC 002000.09— ECU Messages Missing
XSC 002003.09— PTI or PTP Messages Missing
XSC 002005.09— TII or TIP Messages Missing
XSC 002028.09— StarFire™ Receiver Messages Missing
XSC 002042.09— GreenStar™ Display Messages Missing
XSC 002049.09— OIC Messages Missing
XSC 002071.09— CCU Messages Missing
XSC 002198.09— Steering System Control Unit Fault
XSC 002240.09— TEC Messages Missing
XSC 003509.03— Sensor Supply 1 Voltage High
XSC 003509.04— Sensor Supply 1 Voltage Low
XSC 003510.03— Sensor Supply 2 Voltage High
XSC 003510.04— Sensor Supply 2 Voltage Low
XSC 003511.03— Sensor Supply 3 Voltage High
XSC 003511.04— Sensor Supply 3 Voltage Low
XSC 003512.03— Sensor Supply 4 Voltage High
XSC 003512.04— Sensor Supply 4 Voltage Low
XSC 003841.00— Steering System Control Unit Fault
XSC 003841.01— Steering System Control Unit Fault
XSC 003841.02— Steering System Control Unit Fault
XSC 003842.00— Steering System Control Unit Fault
XSC 003842.01— Steering System Control Unit Fault
XSC 003849.01— Steering System Control Unit Fault
XSC 003853.03— Steering System Control Unit Fault
XSC 003853.04— Steering System Control Unit Fault
XSC 003854.03— Steering System Control Unit Fault
XSC 003854.04— Steering System Control Unit Fault
XSC 003855.03— Steering System Control Unit Fault
XSC 003855.04— Steering System Control Unit Fault
XSC 003856.01— Steering System Control Unit Fault
XSC 003857.08— Steering System Control Unit Fault
XSC 003857.16— Steering System Control Unit Fault
XSC 003857.18— Steering System Control Unit Fault
XSC 003858.08— Steering System Control Unit Fault
XSC 003858.16— Steering System Control Unit Fault
XSC 003858.18— Steering System Control Unit Fault
XSC 003861.02— Steering System Control Unit Fault
XSC 003861.03— Steering System Control Unit Fault
XSC 003861.04— Steering System Control Unit Fault
XSC 003862.03— Steering System Control Unit Fault
XSC 003862.04— Steering System Control Unit Fault
XSC 003867.03— Steering System Control Unit Fault
XSC 003867.04— Steering System Control Unit Fault
XSC 003869.14— Steering System Control Unit Fault
XSC 003870.03— Steering System Control Unit Fault
XSC 003870.04— Steering System Control Unit Fault
XSC 003870.15— Steering System Control Unit Fault
XSC 003872.03— Steering System Control Unit Fault
XSC 003872.04— Steering System Control Unit Fault
XSC 003873.03— Steering System Control Unit Fault
XSC 003873.04— Steering System Control Unit Fault
XSC 003874.03— Steering System Control Unit Fault
XSC 003874.04— Steering System Control Unit Fault
XSC 003874.15— Steering System Control Unit Fault
XSC 003882.02— Steering System Control Unit Fault
XSC 003888.03— Steering System Control Unit Fault
XSC 003888.04— Steering System Control Unit Fault
XSC 003888.08— Steering System Control Unit Fault
XSC 003888.13— Steering System Control Unit Fault
XSC 003889.03— Steering System Control Unit Fault
XSC 003889.04— Steering System Control Unit Fault
XSC 003889.08— Steering System Control Unit Fault
XSC 003889.13— Steering System Control Unit Fault
XSC 004085.07— Air Trailer Pre-Brake Valve Stuck Open
XSC 004085.13— Trailer Brake Valve Not Calibrated
XSC 522279.07— Secondary Brake Enable Valve Stuck Open
XSC 522279.13— Secondary Brake Not Calibrated
XSC 522280.01— Secondary Brake Pressure is Low
XSC 522280.03— Secondary Brake Pressure Sensor Voltage High
XSC 522280.04— Secondary Brake Pressure Sensor Voltage Low
XSC 522387.07— No Movement Detected From Wheel Angle Sensor
XSC 522390.09— AutoTrac™ Messages Missing or Security Not Satisfied
XSC 522390.11— AutoTrac™ Stop Message Received
XSC 522393.03— Secondary Brake Lever Sensor 2 Voltage High
XSC 522393.04— Secondary Brake Lever Sensor 2 Voltage Low
XSC 522396.02— Secondary Brake Lever Sensor 1 and 2 Disagree
XSC 522396.03— Secondary Brake Lever Sensor 1 Voltage High
XSC 522396.04— Secondary Brake Lever Sensor 1 Voltage Low
XSC 522451.00— Wheel Angle Sensor (Secondary) Voltage High
XSC 522451.01— Wheel Angle Sensor (Secondary) Voltage Low
XSC 522451.02— Wheel Angle Sensors Disagree
XSC 522765.05— Steering System Control Unit Valve Ground 4 Open Circuit
XSC 522766.05— Steering System Control Unit Valve Ground 3 Open Circuit
XSC 522767.05— Steering System Control Unit Valve Ground 2 Open Circuit
XSC 522768.05— Steering System Control Unit Valve Ground 1 Open Circuit
XSC 522777.02— Steering Wheel Sensors Disagree
XSC 522777.05— Steering Wheel Sensor Disconnected
XSC 522784.08— Steering System Control Unit Fault
XSC 522784.16— Steering System Control Unit Fault
XSC 522784.18— Steering System Control Unit Fault
XSC 522785.08— Steering System Control Unit Fault
XSC 522785.16— Steering System Control Unit Fault
XSC 522785.18— Steering System Control Unit Fault
XSC 522786.01— Main Hydraulic Pump Pressure Below Nominal Operating Level
XSC 522787.01— Main Hydraulic Pump Pressure Below Nominal Operating Level
XSC 522787.03— Main Hydraulic Pump Pressure Sensor 2 Voltage High
XSC 522787.04— Main Hydraulic Pump Pressure Sensor 2 Voltage Low
XSC 522787.15— Main Hydraulic Pump Pressure Sensor 2 Higher Than Nominal
XSC 522787.17— Main Hydraulic Pump Pressure Sensor 2 Lower Than Nominal
XSC 522789.03— Backup Hydraulic Pump Pressure Sensor Voltage High
XSC 522789.04— Backup Hydraulic Pump Pressure Sensor Voltage Low
XSC 522789.14— Tow Mode Not Allowed
XSC 522789.15— Backup Hydraulic Pump Pressure Sensor Reporting Higher Than Expected Pressure
XSC 522790.01— Main Hydraulic Pump Pressure Below Nominal Operating Level
XSC 522790.03— Main Hydraulic Pump Pressure Sensor 1 Voltage High
XSC 522790.04— Main Hydraulic Pump Pressure Sensor 1 Voltage Low
XSC 522790.15— Main Hydraulic Pump Pressure Sensor 1 High
XSC 522790.17— Main Hydraulic Pump Pressure Sensor 1 Low
XSC 522851.03— Front Brake Enable Solenoid Voltage High
XSC 522851.04— Front Brake Enable Solenoid Voltage Low
XSC 522851.05— Front Brake Enable Solenoid Current Low
XSC 522851.06— Front Brake Enable Solenoid Current High
XSC 522852.03— Backup Hydraulic Pump Relay Voltage High
XSC 522852.04— Backup Hydraulic Pump Relay Voltage Low
XSC 522852.05— Backup Hydraulic Pump Relay Current Low
XSC 522852.06— Backup Hydraulic Pump Relay Current High
XSC 522853.03— Alternator/Battery Relay Voltage High
XSC 522853.04— Alternator/Battery Relay Voltage Low
XSC 522853.05— Alternator/Battery Relay Current Low
XSC 522853.06— Alternator/Battery Relay Current High
XSC 522920.09— XSC Timed Out Waiting for XMC
XSC 522976.12— Steering System Control Unit Fault
XSC 523137.14— Steering System Fault
XSC 523137.19— XSC Command Disagrees With XMC Command
XSC 523216.04— Steering System Control Unit Valve Power 4 Unswitched Voltage Low
XSC 523217.04— Steering System Control Unit Valve Power 3 Unswitched Voltage Low
XSC 523218.04— Steering System Control Unit Valve Power 2 Unswitched Voltage Low
XSC 523219.04— Steering System Control Unit Valve Power 1 Unswitched Voltage Low
XSC 523329.14— Steering System Fault
XSC 523789.05— Wheel Angle Sensor Disconnected
XSC 523789.13— Wheel Angle Sensors Not Calibrated
XSC 523794.03— Air Trailer Pre-Brake Enable Solenoid Voltage High
XSC 523794.04— Air Trailer Pre-Brake Enable Solenoid Voltage Low
XSC 523794.05— Air Trailer Pre-Brake Enable Solenoid Current Low
XSC 523794.06— Air Trailer Pre-Brake Enable Solenoid Current High
XSC 523795.07— Steer Enable Valve Stuck Open
XSC 523795.13— Steering Valve Not Calibrated
XSC 523814.03— Secondary Brake Enable Solenoid Voltage High
XSC 523814.04— Secondary Brake Enable Solenoid Voltage Low
XSC 523814.05— Secondary Brake Enable Solenoid Current Low
XSC 523814.06— Secondary Brake Enable Solenoid Current High
XSC 523815.03— AutoTrac™ Steer Enable Solenoid Voltage High
XSC 523815.04— AutoTrac™ Steer Enable Solenoid Voltage Low
XSC 523815.05— AutoTrac™ Steer Enable Solenoid Current Low
XSC 523815.06— AutoTrac™ Steer Enable Solenoid Current High
XSC 523821.02— Incompatible Harness on Steering System Control Unit
XSC 523824.08— Steering Wheel Position Sensor 1 Out of Range
XSC 523824.10— Steering Wheel Position Sensor 1 Delta High
XSC 523824.16— Steering Wheel Position Sensor 1 Frequency High
XSC 523824.18— Steering Wheel Position Sensor 1 Frequency Low
XSC 523824.20— Steering Wheel Position Sensor 1 Duty Cycle High
XSC 523824.21— Steering Wheel Position Sensor 1 Duty Cycle Low
XSC 523826.00— Wheel Angle Sensor (Primary) Voltage High
XSC 523826.01— Wheel Angle Sensor (Primary) Voltage Low
XSC 523826.14— Wheel Angle Sensor Movement Not Detected
XSC 523839.14— Secondary Brake Lever Engaged within 1 Second of Vehicle Start-up
XSC 523840.01— Front Brake Pressure Lower Than Commanded
XSC 523840.03— Front Brake Pressure Sensor Voltage High
XSC 523840.04— Front Brake Pressure Sensor Voltage Low
XSC 523844.07— Front Brake Enable Valve Stuck Open
XSC 523844.13— Front Brake Solenoid Not Calibrated
XSC 523925.09— Steering System Control Unit Fault
XSC 524055.02— Steering System Control Unit Fault
XSC 524055.12— Steering System Control Unit Fault
XSC 524169.14— Tow Mode Requested Before Brake Pedals Validated
Observable Symptom and System Diagnostics
General References
Observable Symptom and System Diagnostics—Summary of References
Fuel, Air Intake, Exhaust, and Cooling
Vari-Cool™ Fan Drive System Diagnosis
Electrical
Generation 4 CommandCenter™ System Diagnosis
Interior Lighting System Diagnosis
Radar System Diagnosis
Radio and Subwoofer System Diagnosis
Remote Mirror and Heated Mirror System Diagnosis
Standard Seat and Heated Seat System Diagnosis
Steering Column Module System Diagnosis
Electronic Control Units
CAN System Diagnosis
Implement CAN bus Diagnosis
AutoPowr / IVT Transmission
AutoPowr™ / IVT™ Transmission System Diagnosis
AutoPowr™ / IVT™ Transmission Hydraulic Cooling System Diagnosis
e23 Transmission
e23™ Transmission System Pressure and Element Diagnosis
e23™ Transmission Lube System Diagnosis
e23™ Transmission Hydraulic Cooling System Diagnosis
16-Speed Powershift Transmission (PST)
16-Speed PowerShift Transmission System Pressure and Element Diagnosis
16-Speed PowerShift Transmission Lube System Diagnosis
16-Speed PowerShift Transmission Hydraulic Cooling System Diagnosis
Drivetrain
MFWD System Diagnosis
Differential Lock System Diagnosis
Front PTO System Diagnosis
Rear PTO System Diagnosis
Brakes
Rear Brake System Diagnosis
Front Brake System Diagnosis
Secondary Brake (EUR) System Diagnosis
Hydraulic Trailer Brake System Diagnosis
Air Trailer Brake System Diagnosis
Steering
Steering—Standard Steering and AutoTrac™ System Diagnosis
ActiveCommand Steering System Diagnosis
Auto Trac System Disengages with No Codes
Backup Hydraulic System Diagnosis
Hydraulics
Hydraulic High Flow System Diagnosis
SCV / Hitch System Diagnosis
Front Hitch System Diagnosis
Front SCV System Diagnosis
Hitch Moves Up and Down
Suspension
ILS™ Raise and Lower Diagnosis
ILS™ Suspension Dampening Diagnosis
ILS™ Settles During Periods of Non-Use
ILS™ Constantly Raising and Lowering
Operator Station
ATC System Diagnosis
ActiveSeat™ System Diagnosis
Seat—Heated Seat System Diagnosis
Seat—Standard Seat System Diagnosis
Engine—Summary of References
Theory of Operation
Intelligent Power Management
Engine Protection
Diagnostic Tests and Adjustments
Performance Testing
Performance Variables
Torque and Power Curve Explanation and Interpretation
Torque Curve Explanation and Interpretation
Engine Component Information
Engine Component Location-Summary of References
Fuel, Air Intake, Exhaust and Cooling—Summary of References
Theory of Operation
Fuel System Theory of Operation
FT4 / Stage 3b Fuel System Theory
Stage 3a Fuel System Theory
Stage 2 Fuel System Theory
Air Intake and Exhaust System Theory of Operation
FT4/3b Engine Air Intake and Exhaust Theory
Stage 3a Engine Air Intake and Exhaust Theory
Stage 2 Engine Air Intake and Exhaust Theory
Engine Cooling System Theory of Operation
FT4 / Stage 3b Cooling System Theory
Stage 3a Cooling System Theory
Stage 2 Cooling System Theory
Vari-Cool™ Fan Drive Theory of Operation
Exhaust Aftertreatment System Theory of Operation (Final Tier 4/Stage IV)
Schematic
Vari-Cool™ Fan Drive Hydraulic Schematic
Fuel, Air Intake, Exhaust, and Cooling Component Information
Fuel, Air Intake and Exhaust System-Summary of References
Cooling System Component Location-Summary of References
Fuel, Air Intake and Exhaust System Component Location
J5020 Decomposition Tube
J5502 DIesel Oxidation Catalyst/ Diesel Particulate Filter (DOC/DPF)
J5021 Selective Catalyst Reduction (SCR)
C5013 Fan Drive Unit
W5013 Fan Driven Unit
V5013 Fan Drive Control Valve
Electrical
Electrical General Information—Summary of References
Electrical Designators
Wiring Diagram and Schematic Information
Component Identification Table
System Functional Schematic
System Circuit Diagram
Subsystem Circuit Diagram
Visually Inspect Electrical System
Standard Electrical Symbols
Circuit Types
Electrical Circuit
Electronic Circuit
Open Circuit Load Test
Testing Isolated Circuits Using Open Circuit Load Tester
Testing Control Unit Power Circuits Using Open Circuit Load Tester
Testing Control Unit Ground Circuits Using Open Circuit Load Tester (Chassis or Single Point Ground)
Testing Component Ground Circuits That Go To Chassis or Single Point Ground
Troubleshooting Unresolved Electrical/Electronic Problems
Problems due to specific operating conditions
Problems due to intermittent electrical failures
Problems due to control unit failures
Theory—Summary of References
Electrical System Wiring Diagrams—Summary of References
Starting and Charging—Summary of References
Road Lighting—Summary of References
Field Lighting—Summary of References
Interior Lighting—Summary of References
ActiveSeat™—Summary of References
Standard and Heated Seat—Summary of References
Audible Alerts—Summary of References
Windshield Wipers—Summary of References
Operator Station—Summary of References
Remote Mirrors—Summary of References
Radio—Summary of References
Accessory Power Connectors—Summary of References
AutoPowr / IVT Transmission—Summary of References
e23™ Transmission—Summary of References
16-Speed Powershift Transmission—Summary of References
Differential Lock—Summary of References
MFWD—Summary of References
PTO—Summary of References
Front PTO—Summary of References
Engines—Summary of References
GreenStar™ Display and Implement CAN Bus—Summary of References
AMS Technology—Summary of References
Rear SCV’s and Rear Hitch—Summary of References
Front Hitch and Front SCV’s—Summary of References
Suspended Front Axle—Summary of References
Cab Suspension—Summary of References
Air Trailer Brakes—Summary of References
Secondary Brakes—Summary of References
Front Brakes—Summary of References
HVAC (Automatic)—Summary of References
Steering—Summary of References
Controller Area Network—Summary of References
Theory
Cab Control Unit Theory of Operation
CAN Communication System Theory Of Operation
Chassis Control Unit Theory of Operation
CommandArm™ Theory of Operation
Engine Control Unit Theory of Operation
Roof Control Unit Theory of Operation
Vehicle Load Center Control Unit Theory of Operation
Starting and Charging Theory of Operation
Power Supply, Starting and Charging Circuit Diagram
Charging System Voltage Test
Battery Disconnect Switch Circuit Test
Battery Inspection Test
Starting System Circuit Test
Starting Aid Circuit Test
Key Switch Control Circuit Test
Non ACS™—Alternator/Battery Relay Circuit Test
OIC—Wakeup Output Circuit Test
OIC—Wakeup Output 1 Circuit Test
OIC—ELX Output 0 Circuit Test
OIC—ELX Output 1 Circuit Test
Key Switch Ignition Circuit Test
Key Switch ELX Circuit Test
Road Lighting
Road Lighting Circuit Diagram
CLC—Vehicle and Trailer Brake Light Circuit Test
CLC—Left/Right Extremity Turn Signal Light Circuit Test
CLC—Vehicle and Trailer Tail Light Circuit Test
FCC—High/Low Beam Head Light Switch Circuit Test
FCC—Road Light Switch Circuit Test
FCC—Turn Signal Switch Circuit Test
RLC—Beacon Light Circuit Test
RLC—Left/Right Front Clearance and Warning Light Circuit Test (Eur Only)
RLC—Left/Right Front Roof Warning (NA Only) Circuit Test
RLC—Left/Right Loader Flood Light Circuit Test
RLC—Left/Right Rear Roof Warning (NA Only) Circuit Test
RLC—Left/Right Turn Signal Circuit Test
RLC—License Plate Light Circuit Test
VLC—Left/Right High-Beam Driving Light Circuit Test
VLC—Left/Right Low-Beam Driving Light Circuit Test
VLC—Left/Right Trailer Turn Signal Light Circuit Test
Field Lighting
Field Lighting Circuit Diagram
CLC—Left/Right Rear Inner Flood Lights Circuit Test
CLC—Trailer Flood Light Circuit Test
RLC—Left/Right Front Inner Roof Flood Light Circuit Test
RLC—Left/Right Front Corner Roof Light (Eur Only) Circuit Test
RLC—Left/Right Front Side Roof Flood Light Circuit Test
RLC—Left/Right Mid Body Flood Light Circuit Test
RLC—Left/Right Rear Inner Roof Flood Light Circuit Test
RLC—Left/Right Rear Corner Roof Light (Eur Only) Circuit Test
RLC—Left/Right Rear Side Roof Flood Light Circuit Test
VLC—Front Inner Hood Flood Lights (Left/Right) Circuit Test
VLC—Front Outer Hood Flood Lights (Left/Right) Circuit Test
Programmable Lighting Operational Check
Interior Lighting
Interior Lighting Circuit Diagram
CLC—Steering Column Backlighting Circuit Test
RLC—Right and Rear Wiper Backlighting Circuit Test
RLC—Right-Hand Console Lamp Circuit Test
Dome and Map Lamp Circuit Test
Left Door Switch Circuit Test
ActiveSeat
ActiveSeat™ Circuit Diagram
ASU— Pressure Control Solenoid Circuit Test
ASU—ActiveSeat™ Firmness Control Switch Circuit Test
ASU—ActiveSeat™ Height Control Switch Circuit Test
ASU—ActiveSeat™ Vent (Bleed) Valve Solenoid Circuit Test
ASU—ActiveSeat™ Compressor Assembly Circuit Test
ASU—ActiveSeat™ Raise-Lower Solenoid Circuit Test
ASU—ActiveSeat™ Accelerometer Sensor Circuit Test
ASU—ActiveSeat™ Position Sensor Circuit Test
OIC—Operator Presence Switch Circuit Test
Standard Seat and Heated Seat Circuit Diagram
Standard Seat Height Control System Test
Standard Seat Diode Circuit Test
Heated Seat System Test
Audible Alerts
Audible Alerts Circuit Diagram
CLC—Back Up Alarm Circuit Test
CLC—Horn Circuit Test
CLC—Warning Horn Circuit Test
Windshield Wipers
Windshield Wipers Circuit Diagram
FCC—Front Wiper Switch Circuit Test
RLC—Rear Wiper Switch Circuit Test
RLC—Right Wiper Switch Circuit Test
RLC—Front Wiper Motor Circuit Test
RLC—Rear Wiper Motor Circuit Test
CLC—Right Wiper Motor Circuit Test
VLC—Front Washer Pump Circuit Test
VLC—Rear Washer Pump Circuit Test
VLC—Right Washer Pump Circuit Test
Operator Station
Operator Station Circuit Diagram
AIC—Cab Controls Module Circuit Test
AIC—Armrest Navigation Bar Module Circuit Test
Remote Mirrors
Remote and Heated Mirror Circuit Diagram
Mirror Adjustment System Test (Without Power Extend)
Mirror Adjustment System Test (With Power Extend)
Mirror Power Extend and Retract System Test
Heated Mirror System Test
Radio
Radio Circuit Diagram
CRU—SiriusXM® Satellite Radio Module Circuit Test
Radio Circuit Test
Subwoofer Circuit Test
Accessory Power Connectors Circuit Diagram
Auxiliary Power Strip Circuit Test
Auxiliary Power Outlet Circuit Test
Business Band/CB Radio Prewire Test
Convenience Outlet #1 Circuit Test
Convenience Outlet #2 Circuit Test
Lighter Circuit Test
Refrigerator Circuit Test
Right Junction Block Circuit Test
AutoPowr™ / IVT™ Transmission Circuit Diagram
AIC—Speed Control Lever Sensor Circuit Test (AutoPowr™/IVT™)
AIC—Right-Hand Reverser (AutoPowr™/IVT™) Circuit Test
FCC—Left-Hand Reverser Circuit Test (AutoPowr™/IVT™)
OIC—Clutch Pedal Position Sensor Circuit Test (AutoPowr™/IVT™)
TII—Transmission Come Home Mode Enable Circuit Test
TII—Transmission Enable Circuit Test
PTI—Primary Transmission Speed Sensor Circuit Test
PTI—Secondary Transmission Speed Sensor Circuit Test
PTI—Carrier Speed Sensor Circuit Test
PTI—Clutch Enable Pressure Sensor Circuit Test
PTI—Clutch Enable Solenoid Circuit Test
PTI—Clutch 1 (C1) Solenoid Circuit Test
PTI—Clutch 2 (C2) Solenoid Circuit Test
PTI—Clutch 3 (C3) Solenoid Circuit Test
PTI—CU Idler Speed Sensor Circuit Test
PTI—Diagnostic Hydraulic Pressure Sensor Circuit Test
PTI—High Clutch Solenoid Circuit Test
PTI—Hydro Clutch Unit (CU) Solenoid Circuit Test
PTI—Hydro Ring Gear Speed Sensor Circuit Test
PTI—Loop Flush Cutoff Solenoid Circuit Test
PTI—Low Clutch Solenoid Circuit Test
PTI—Park Brake Pressure Sensor Circuit Test
PTI—Park Brake Supply Solenoid Circuit Test
PTI—Park Sump Block Solenoid Circuit Test
PTI—Reverse Brake Solenoid Circuit Test
PTI—Ring Unit (RU) Hydro Control Solenoid Circuit Test
PTI—System 1 Pressure Sensor Circuit Test (—100000)
e23 Transmission
e23™ Transmission Circuit Diagram
FCC—Left-Hand Reverser Circuit Test (e23™)
AIC—e23™ Drive Lever Circuit Test (e23™)
OIC—Clutch Pedal Position Sensor Circuit Test (e23™)
PTP—Counter Shaft B Speed Sensor Circuit Test (e23™)
PTP—Counter Shaft C Speed Sensor Circuit Test (e23™)
PTP—Forward Low Proportional Solenoid Circuit Test (e23™)
PTP—Forward High Proportional Solenoid Circuit Test (e23™)
PTP—Hydraulic Oil Cooler Control Solenoid Circuit Test (e23™)
PTP—Lube Pressure Sensor Circuit Test (e23™)
PTP—Lube Priority Solenoid Circuit Test (e23™)
PTP—Not Neutral/Park Switch Circuit Test
PTP—Park Brake Pressure Sensor Circuit Test (e23™)
PTP—Park Brake Supply Solenoid Circuit Test (e23™)
PTP—Park Sump Block Solenoid Circuit Test (e23™)
PTP—R1 Proportional Solenoid Circuit Test (e23™)
PTP—R2 Clutch Pressure Sensor Circuit Test (e23™)
PTP—R2 Proportional Solenoid Circuit Test (e23™)
PTP—R3 Proportional Solenoid Circuit Test (e23™)
PTP—Reverse Proportional Solenoid Circuit Test (e23™)
PTP—S1 Proportional Solenoid Circuit Test (e23™)
PTP—S2 Proportional Solenoid Circuit Test (e23™)
PTP—S3 Proportional Solenoid Circuit Test (e23™)
PTP—S4 Proportional Solenoid Circuit Test (e23™)
PTP—System 2 Pressure Sensor Circuit Test (e23™)
PTP—Transmission Primary Speed Sensor Circuit Test (e23™)
PTP—Transmission Secondary Speed Sensor Circuit Test (e23™)
TIP—Transmission Enable Circuit Test (e23™)
16 Speed Powershift Transmission (PST) Circuit Diagram (16 Speed)
AIC—Drive Lever Circuit Test (16 Speed PST)
OIC—Clutch Pedal Position Sensor Circuit Test (16 Speed)
PTP/PTI—Primary Transmission Speed Sensor Circuit Test (16 Speed)
PTP/PTI—Secondary Transmission Speed Sensor Circuit Test (16 Speed)
PTP—System 2 Pressure Sensor Circuit Test (16 Speed)
PTP—Diagnostic Hydraulic Pressure Sensor Circuit Test (16 Speed)
PTP—Park Brake Supply Solenoid Circuit Test (16 Speed)
PTP—Clutch 1 (C1) Solenoid Circuit Test (16 Speed)
PTP—Clutch 2 (C2) Solenoid Circuit Test (16 Speed)
PTP—Clutch 3 (C3) Solenoid Circuit Test (16 Speed)
PTP—Clutch 4 (C4) Solenoid Circuit Test (16 Speed)
PTP—Reverse Clutch (CR) Solenoid Circuit Test (16 Speed)
PTP—D Clutch (DC) Solenoid Circuit Test (16 Speed)
PTP—Countershaft Speed Sensor Circuit Test (16 Speed)
PTP—Park Sump Block Solenoid Circuit Test (16 Speed)
PTP—Park Brake Pressure Sensor Circuit Test (16 Speed)
PTP—C Clutch (CC) Solenoid Circuit Test (16 Speed)
PTP—B Clutch (BC) Solenoid Circuit Test (16 Speed)
PTP—A Brake (AB) Solenoid Circuit Test (16 Speed)
PTP—Lube Cutoff Solenoid Circuit Test (16 Speed)
TIP—Transmission Enable Circuit Test (16 Speed PST)
Differential Lock
Differential Lock Circuit Diagram
CCU—Differential Lock Switch Circuit Test
CCU—Rear Differential Lock Solenoid Circuit Test
CCU—Front Differential Lock Solenoid Circuit Test
MFWD
MFWD Circuit Diagram
CCU—MFWD Solenoid Circuit Test
PTI—MFWD Speed Sensor Circuit Test
PTO
PTO Circuit Diagram
AIC—Rear PTO Switch Circuit Test
OIC—Rear PTO Left External Switch Circuit Test
OIC—Rear PTO Right External Switch Circuit Test
RPT—Rear PTO Speed Sensor Circuit Test
RPT—Rear PTO Solenoid Circuit Test
RPT—Rear PTO Speed Select Solenoid Circuit Test
Front PTO
Front PTO Circuit Diagram
AIC—Front PTO Switch Circuit Test
PTF—Front PTO Diagnostic Pressure Sensor Circuit Test
PTF—Front PTO External Switch Circuit Test
PTF—Front PTO Return Oil Pressure Sensor Circuit Test
PTF—Front PTO Oil Temperature Sensor Circuit Test
PTF—Front PTO Solenoid Circuit Test
PTF—Front PTO Speed Sensor Circuit Test
PTF—Front PTO Clutch Pressure Sensor Circuit Test
Engines
Engines Circuit Diagram
AIC—Armrest Engine Speed Control Module Circuit Test
CCU—Fuel Level Sensor Circuit Test
ECU—Engine Coolant Loss Sensor Circuit Test
ECU—Engine Coolant Level Sensor Circuit Test
ECU—Vari-Cool™ Fan Drive Solenoid Circuit Test
ECU—Vari-Cool™ Fan Drive Speed Sensor Circuit Test
ECU—Battery Disconnect LED Circuit Test
ECU—Engine Air Filter Restriction Switch Circuit Test (Stage II / 3A Only)
OIC—Foot Throttle Position Sensor Circuit Test
GreenStar Display and Implement CAN Bus
GreenStar™ Display and Implement CAN Bus Circuit Diagram
CLC—Implement Electronic Control Unit Power Relay Circuit Test
CLC—Implement Power Relay Module Circuit Test
Radar Speed Sensor Circuit Test
Implement CAN bus Circuit Test
AMS Technology
AMS Technology Circuit Diagram
Rear SCV`s and Rear Hitch
Rear SCV’s and Rear Hitch Circuit Diagram
AIC—Armrest Front Left Module Circuit Test
AIC—Armrest Front Middle Module Circuit Test
AIC—Armrest Front Right Module Circuit Test
AIC—Armrest Hitch Controls Module Circuit Test
AIC—Armrest Rear Hitch Setup Controls Module Circuit Test
AIC—Armrest Rear Right Module Circuit Test
AIC—Armrest SCV Lock Module Circuit Test
SCC—Hydraulic Charge Pump Pressure Sensor Circuit Test
SCC—Hydraulic Oil Level Presence Sensor Circuit Test (100001— )
CCU—Hydraulic Oil Filter Restriction Sensor Circuit Test
CCU—Hydraulic Oil Temperature Sensor Circuit Test
HCC—Rear Hitch Draft Sensor Circuit Test
HCC—Rear Hitch Position Sensor Circuit Test
OIC—Rear Hitch External Switches Circuit Test
OIC—SCV External Switches Circuit Test
Rear SCV’s and Rear Hitch CAN Bus Communication Fault Test
SCC—Hitch Control Valve Power and Ground Circuit Test
SCC—Option Configuration Connector Circuit Test
SCC—SV I, III and V Power and Ground Circuit Test
SCC—SV II, IV and VI Power and Ground Circuit Test
Front Hitch and Front SCV`s
Front Hitch and Front SCV’s Circuit Diagram
AIC—Armrest Middle Right Module Circuit Test
AIC—Armrest Multi-Function Lever Module Circuit Test
Front SCV CAN Bus Communication Fault Test
SCO—Option Configuration Connector Circuit Test
SCO—Front Hitch External Switch Circuit Test
SCO—Front Hitch Mode Select Solenoid Circuit Test
SCO—Front Hitch Position Sensor Circuit Test
SCO—Front Hitch Selective Control Valve Unit (SVJ) Power and Ground Circuit Test
SCO—Front Selective Control Valve Unit XIV (SVN) Power and Ground Circuit Test
SCO—Front Selective Control Valve Unit XV (SVO) Power and Ground Circuit Test
SCO—Front SCV/Hitch Selective Control Valve Stepper Motor/Driver Problem Identification Test
Suspended Front Axle Circuit Diagrams
SFA—Front Suspension Left Position Sensor Circuit Test
SFA—Front Suspension Right Position Sensor Circuit Test
SFA—Front Suspension Pressure Sensor Circuit Test
SFA—Front Suspension Raise/Lower Solenoids Circuit Test
SFA—Front Suspension Spring Rate Increase/Decrease Solenoids Circuit Test
SFA—Front Suspension Dampening Solenoids Circuit Test
Cab Suspension
Cab Suspension Circuit Diagram
CSC—Cab Suspension Damping Solenoid Circuit Test
CSC—Cab Suspension Lower Solenoid Circuit Test
CSC—Cab Suspension Position Sensor Circuit Test
CSC—Cab Suspension Raise Solenoid Circuit Test
Air Trailer Brakes
Air Trailer Brakes Circuit Diagrams
CCU—Air Trailer Brake Pressure Sensor Circuit Test
CCU—Air Trailer Brake Solenoid Circuit Test
Non ACS™—Air Trailer Pre-Brake Enable Solenoid Circuit Test
Non ACS™—Air Trailer Pre-Brake Solenoid Circuit Test
Non ACS™—Air Trailer Pre-Brake Pressure Sensor Circuit Test
Secondary Brakes
Secondary Brakes Circuit Diagram
Non ACS™—Secondary Brake Lever Sensor Circuit Test
Non ACS™—Secondary Brake Enable Solenoid Circuit Test
Non ACS™—Secondary Brake Solenoid Circuit Test
Non ACS™—Secondary Brake Pressure Sensor Circuit Test
Front Brakes
Front Brake Circuit Diagrams
Non ACS™—Brake Pedal Sensor & Switch Circuit Test
Non ACS™—Front Brake Enable Solenoid Circuit Test
Non ACS™—Front Brake Solenoid Circuit Test
Non ACS™—Front Brake Pressure Sensor Circuit Test
Non ACS™—Left Rear Brake Pressure Sensor Circuit Test
Non ACS™—Right Rear Brake Pressure Sensor Circuit Test
HVAC (Automatic)
HVAC (Automatic) Circuit Diagram
ATC—Circulation Blower Motor Circuit Test
ATC—Air Flow Mode Motor Circuit Test
ATC—Water Valve Motor Circuit Test
ATC—Cab Temperature Sensor Circuit Test
ATC—Refrigerant Pressure Sensor Circuit Test
ATC—Evaporator Temperature Sensor Circuit Test
ATC—Outlet Air Temperature Sensor Circuit Test
ATC—Ambient Temperature Sensor Circuit Test
ECU—A/C Compressor Clutch Circuit Test
RLC—Pressurizer Blower Motor Circuit Test
Steering
Steering Circuit Diagrams
Non ACS™—Steering Wheel Module Circuit Test
Non ACS™—Wheel Angle Sensor Circuit Test
Non ACS™—AutoTrac™ Steer Enable Solenoid Circuit Test
Non ACS™—Steer Right Solenoid Circuit Test
Non ACS™—Steer Left Solenoid Circuit Test
Non ACS™—Main Hydraulic Pump Pressure Sensor 1 Circuit Test
Non ACS™—Main Hydraulic Pump Pressure Sensor 2 Circuit Test
Non ACS™—Backup Hydraulic Pump Circuit Test
Non ACS™—Backup Hydraulic Pump Pressure Sensor Circuit Test
Non ACS™—Wheel Speed Circuit Test
ACS™—Steer Enable Solenoid 1 Circuit Test
ACS™—Steer Right Solenoid 1 Circuit Test
ACS™—Steer Left Solenoid 1 Circuit Test
ACS™—Steer Enable Solenoid 2 Circuit Test
ACS™—Steer Right Solenoid 2 Circuit Test
ACS™—Steer Left Solenoid 2 Circuit Test
ACS™—Steer Right Valve 1 Position Sensor Circuit Test
ACS™—Steer Left Valve 1 Position Sensor Circuit Test
ACS™—Steer Right Valve 2 Position Sensor Circuit Test
ACS™—Steer Left Valve 2 Position Sensor Circuit Test
ACS™—Steering Wheel Brake Solenoid Circuit Test
ACS™—Right Wheel Angle Sensor Circuit Test
ACS™—Left Wheel Angle Sensor Circuit Test
ACS™—Gyroscope Circuit Test
Controller Area Network (CAN)
CAN Communication System Circuit Diagrams
CAN Communication Fault Checks
CAN Circuit Interconnections and Splice Locations
CAN Network Voltage and Resistance Checks
Access Control Unit Addresses
Control Unit ”Beep” Mode Test
Control Unit Locations and Identification
Recall, Record, and Clear Codes
Programming Control Units
Programming CommandCenter™
Update Display and Control Unit Software
USB Drive
Servicing Electronic Control Units
Welding Near Electronic Control Units
Keep Electronic Control Unit Connectors Clean
SCV Reassignment
Electronic Control Units General Information—Summary of References
Interactive Tests and Calibrations—Summary of References
Control Unit Schematics—Summary of References
Armrest Control Unit Tests—Summary of References
Automatic Temperature Control Unit Tests—Summary of References
Cab Control Unit Tests—Summary of References
Generation 4 CommandCenter™ Control Unit Tests—Summary of References
Corner Post Display Control Unit Tests—Summary of References
Engine Control Unit Tests—Summary of References
4100 and 4600 Processor Control Unit Tests—Summary of References
Front Chassis Control Unit Tests—Summary of References
Rear Chassis Control Unit Tests—Summary of References
Roof Control Unit Tests—Summary of References
Steering Control Unit Tests—Summary of References
Armrest Interface Control Software Addresses (AIC)—Summary of References
ActiveSeat™ Control Software Addresses (ASU)—Summary of References
Automatic Temperature Control Software Addresses (ATC)—Summary of References
Chassis Control Software Addresses (CCU)—Summary of References
Cab Load Center Software Addresses (CLC)—Summary of References
Radio Software Addresses (CRU)—Summary of References
Cab Suspension Control Software Addresses (CSC)—Summary of References
Cab Switch Module Software Addresses (CSM)—Summary of References
Engine Control Software Addresses (ECU)—Summary of References
Engine Interface Control Software Addresses (EIC)—Summary of References
Front Console Control Software Addresses (FCC)—Summary of References
Hitch Control Software Addresses (HCC)—Summary of References
Hitch Valve Control Software Addresses (HV1)—Summary of References
Vehicle Security Control Software Addresses (ICA)—Summary of References
JDLink™ Control Software Addresses (JDL)—Summary of References
Operator Interface Control Software Addresses (OIC)—Summary of References
Primary Display Software Addresses (PDU)—Summary of References
Front PTO Control Software Addresses (PTF)—Summary of References
AutoPowr™ / IVT™ Transmission Control Software Addresses (PTI)—Summary of References
e23™ Transmission Control Software Addresses (PTP)—Summary of References
16-Speed Powershift Transmission Control Software Addresses (PTP)—Summary of References
Roof Lighting Control Software Addresses (RLC)—Summary of References
Rear PTO Control Software Addresses (RPT)—Summary of References
SCV Control Software Addresses (SCC)—Summary of References
Secondary Hydraulic Control Software Addresses (SCO)—Summary of References
Suspended Front Axle Control Software Addresses (SFA)—Summary of References
SCV I Control Software Addresses (SV1)—Summary of References
SCV II Control Software Addresses (SV2)—Summary of References
SCV III Control Software Addresses (SV3)—Summary of References
SCV IV Control Software Addresses (SV4)—Summary of References
SCV V Control Software Addresses (SV5)—Summary of References
SCV VI Control Software Addresses (SV6)—Summary of References
Front Hitch SCV Control Software Addresses (SVJ)—Summary of References
Front SCV XIV Control Software Addresses (SVN)—Summary of References
Front SCV XV Control Software Addresses (SVO)—Summary of References
Tractor Equipment Control Software Addresses (TEC/TEI)—Summary of References
AutoPowr™ / IVT™ Transmission Shift Control Software Addresses (TII)—Summary of References
Powershift Transmission Shift Control Software Addresses (TIP)—Summary of References
Vehicle Load Center Control Software Addresses (VLC)—Summary of References
Virtual Terminal Implement Control Software Addresses (VTI)—Summary of References
Virtual Terminal Vehicle Control Software Addresses (VTV)—Summary of References
ActiveCommand Steering (ACS™) A-Box Main Control Software Addresses (XMA)—Summary of References
ActiveCommand Steering (ACS™) B-Box Main Control Software Addresses (XMB)—Summary of References
AutoTrac™ Main Control Software Addresses (XMC)—Summary of References
ActiveCommand Steering (ACS™) A-Box Supervisor Control Software Addresses (XSA)—Summary of References
ActiveCommand Steering (ACS™) B-Box Supervisor Control Software Addresses (XSB)—Summary of References
AutoTrac™ Supervisor Control Software Addresses (XSC)—Summary of References
VIN Security Fault Diagnosis
Address 200—251—General Control Unit Data
Address 211—Calibration Data Part Number
Address 212—Calibration Data Part Number
Address 213—Calibration Data Part Number
Address 214—Calibration Data Version Number
Address 217—Calibration Data Part Number
Address 218—Calibration Data Version Number
Address 219—Control Unit Configuration Data Part Number
Address 220—Control Unit Configuration Data Version Number
Address 221—Second Application Part Number
Address 222—Second Application Version Number
Address 223—Second EOL Data Software Part Number
Address 224—Second EOL Data Software Version Number
Address 225—Configuration Data Software Part Number
Address 226—Configuration Data Software Version Number
Address 227—Boot Block Program Software Part Number
Address 228—Boot Block Program Software Version Number
Address 229—EOL Data Software Part Number
Address 230—EOL Data Software Version Number
Address 231—Operating System Part Number
Address 232—Operating System Version Number
Address 233—Base Program Software Part Number
Address 234—Base Program Software Version Number
Address 235—Control Unit Hardware Part Number
Address 236—Control Unit Hardware Serial Number
Address 237—Software Assembly Part Number
Address 238—Software Assembly Version Number
Address 245—Number of CAN Bus OFF Counts Before Shutting CAN Bus Down
Address 246—Interval When the Counts Must Shut CAN Bus Down
Address 251—Current Vehicle Identification Number / Serial Number
SE01—Starting and Charging Schematic
SE02—Key Switch Control Schematic
SE03—HVAC Schematic
SE04—Remote Mirror Schematic
SE05—Radio Schematic
SE06—Cab Control Unit Schematic
SE07—Accessory Connectors Schematic
SE08—CAN Bus Termination Schematic
SE09—Corner Post Display Schematic
SE10—Rear Chassis Control Unit Schematic
SE11—Engine Control Unit Schematic
SE13—AMS Technology Schematic
SE14—Roof Control Unit Schematic
SE16—Armrest Control Unit Schematic
SE17—GreenStar™ Display Schematic
SE18—ActiveCommand Steering Control Units Schematic
SE19—Steering Control Unit Schematic
SE20—Front Chassis Control Unit Schematic
SE22—Seat Schematic
Armrest Control Unit Power and Ground Circuit Test
Armrest Control Unit 5 V Sensor Supply 1 Power and Ground Circuit Test
Armrest Control Unit 5 V Sensor Supply 2 Power and Ground Circuit Test
Armrest Control Unit 12 V Sensor Supply 1 Power and Ground Circuit Test
Armrest Control Unit 12 V Sensor Supply 2 Power and Ground Circuit Test
Automatic Temperature Control Unit Test (ATC)
CAB Control Unit Test
CAB Control Unit Power and Ground Circuit Test
CAB Control Unit Sensor 2 Supply Power and Ground Circuit Test
CAB Control Unit Sensor 3 Supply Power and Ground Circuit Test
Generation 4 CommandCenter Control Unit Tests
Generation 4 CommandCenter™ Control Unit Power and Ground Circuit Test
Generation 4 CommandCenter™ Display Screen is Black Test
Generation 4 CommandCenter™ Display Will Not Boot Test
Value 4100 or Premium 4600 Processor Control Unit Test
Value 4100 or Premium 4600 Processor Control Unit Power and Ground Circuit Test
Front Chassis Control Unit Power and Ground Circuit Test
Front Chassis Control Unit Sensor Supply 1 Power and Ground Circuit Test
Front Chassis Control Unit Sensor Supply 3 Power and Ground Circuit Test
Rear Chassis Control Unit Power and Ground Circuit Test
Rear Chassis Control Unit Sensor Supply 1 Power and Ground Circuit Test
Rear Chassis Control Unit Sensor Supply 2 Power and Ground Circuit Test
Rear Chassis Control Unit Sensor Supply 3 Power and Ground Circuit Test
Rear Chassis Control Unit Sensor Supply 4 Power and Ground Circuit Test
Roof Control Unit Power and Ground Circuit Test
Steering System Control Unit Test
Non ACS™—Steering System Control Unit Power and Ground Circuit Test
Non ACS™—Sensor Supply 1 Circuit Test
Non ACS™—Sensor Supply 2 Circuit Test
Non ACS™—Sensor Supply 3 Circuit Test
Non ACS™—Sensor Supply 4 Circuit Test
ActiveCommand Steering A-Box Control Unit Test
ActiveCommand Steering B-Box Control Unit Test
ACS™—ActiveCommand Steering A-Box Power and Ground Circuit Test
ACS™—ActiveCommand Steering B-Box Power and Ground Circuit Test
ActiveCommand Steering CAN Bus Circuit Test
ACS™—Handshaking Circuit Test
ACS™—A-Box Harness Identification Circuit Test
ACS™—B-Box Harness Identification Circuit Test
ACS™—A-Box Sensor Supply 1 Circuit Test
ACS™—A-Box Sensor Supply 2 Circuit Test
ACS™—A-Box Sensor Supply 3 Circuit Test
ACS™—A-Box Sensor Supply 4 Circuit Test
ACS™—B-Box Sensor Supply 1 Circuit Test
ACS™—B-Box Sensor Supply 2 Circuit Test
ACS™—B-Box Sensor Supply 3 Circuit Test
ACS™—B-Box Sensor Supply 4 Circuit Test
Armrest Interface Control Unit (AIC) Configuration and Calibration
000—Device ID Address
AIC 001—Control Unit Stored Codes
AIC 002—Armrest System Beep Mode
AIC 004—Index to CAN Debug Request Record
AIC 005—Contents of CAN Debug Request Record
AIC 010—Right Hand Reverser Inputs Status
AIC 011—Drive Lever (RHR/ RHDL) Channel A Voltage
AIC 012—Drive Lever (RHR/ RHDL) Channel B Voltage
AIC 013—Drive Lever Slot Switch Inputs Status
AIC 016—e23™ Drive Lever Inputs Status
AIC 017—e23™ Drive Lever Inputs Status
AIC 018—Set Speed Encoder Clockwise Rotation Count
AIC 019—Set Speed Encoder Counter Clockwise Rotation Count
AIC 021—PST Shift Lever Inputs Status
AIC 025—Engine Speed Control Lever Status
AIC 026—iTEC™ and AutoTrac™ Resume Push Buttons Status
AIC 027—Engine Speed Push Buttons Status
AIC 028—Armrest Rear Hitch Controls Module Status
AIC 029—Armrest Rear Hitch Setup Controls Module Inputs Count
AIC 030—Multi-Function Lever Direction Status
AIC 031—Multi-Function Lever Trigger and Hand Detection Status
AIC 032—Multi-Function Lever Inputs Status
AIC 040—Armrest Front Left Module (Left Control Lever) Status
AIC 041—Armrest Front Left Module (Right Control Lever) Status
AIC 042—Armrest Front Middle Module (Left Control Lever) Status
AIC 043—Armrest Front Middle Module (Right Control Lever) Status
AIC 044—Armrest Front Right Module (Left Control Lever) Status
AIC 045—Armrest Front Right Module (Right Control Lever) Status
AIC 046—Armrest Middle Right Module (Left Control Lever) Status
AIC 047—Armrest Middle Right Module (Right Control Lever) Status
AIC 048—Armrest Rear Right Module (Left Control Lever) Status
AIC 049—Armrest Rear Right Module (Right Control Lever) Status
AIC 050—Backlight Brightness Level
AIC 051—Engine Speed CAN Messages
AIC 053—Rear Hitch Controls Module Status CAN Messages
AIC 060—Rear PTO Switch Status
AIC 061—Front PTO Switch Status
AIC 070—Backlight Brightness Level
AIC 074—Engine Speed Messages
AIC 075—Rear Hitch Controls Module Status Messages
AIC 076—Multi-Function Lever Lock Status Message
AIC 090—Battery Voltage
AIC 091—Switched Power (ELX) Voltage
AIC 092—AIC 12 V Sensor Supply 1 Inputs Status
AIC 093—AIC 12 V Sensor Supply 2 Inputs Status
AIC 094—AIC 5 V Sensor Supply 1 Inputs Status
AIC 095—AIC 5 V Sensor Supply 2 Inputs Status
AIC 140—SCV Lever Deadband Low Side Configuration
AIC 141—SCV Lever Deadband High Side Configuration
AIC 159—Factory Use Only
AIC 160—Factory Use Only
AIC 161—Factory Use Only
AIC 162—Factory Use Only
AIC 163—Factory Use Only
AIC 164—Factory Use Only
AIC 165—Factory Use Only
AIC 166—Factory Use Only
AIC 167—Factory Use Only
AIC 168—Factory Use Only
AIC 169—Factory Use Only
AIC 170—Factory Use Only
AIC 171—Factory Use Only
AIC 172—Factory Use Only
AIC 173—Factory Use Only
AIC 174—Factory Use Only
AIC 175—Factory Use Only
AIC 176—Factory Use Only
AIC 177—Factory Use Only
AIC 178—Factory Use Only
AIC 179—Factory Use Only
AIC 180—Factory Use Only
AIC 181—Factory Use Only
AIC 182—Factory Use Only
AIC 183—Factory Use Only
AIC 184—Factory Use Only
AIC 185—Factory Use Only
AIC 186—Factory Use Only
AIC 187—Factory Use Only
AIC 188—Factory Use Only
AIC 189—Factory Use Only
AIC 190—Factory Use Only
AIC 191—Factory Use Only
AIC 192—Factory Use Only
AIC 193—Factory Use Only
AIC 194—Factory Use Only
AIC 195—Factory Use Only
AIC 196—Factory Use Only
AIC 197—Factory Use Only
AIC 198—Factory Use Only
AIC 199—Factory Use Only
200—251—Control Unit General Data
ActiveSeat Control Software Addresses (ASU)
ActiveSeat™ Unit (ASU) Configuration and Calibration
ASU 001—Recall Diagnostic Trouble Codes
ASU 002—ASU System Beep Mode
ASU 004—Index to CAN Debug Request Record
ASU 005—Contents of CAN Debug Request Record
ASU 030—ActiveSeat™ Firmness Control and Seat Height Switches
ASU 031—ActiveSeat™ Position Sensor Voltage
ASU 032—ActiveSeat™ Accelerometer Sensor Voltage
ASU 046—ASU Sensor Supply Voltage
ASU 048—ASU System Voltage
ASU 060—ActiveSeat™ Enable Configuration
ASU 061—ActiveSeat™ Filter Setting
ASU 062—Upper Ride Zone Limit Offset
ASU 063—Lower Ride Zone Limit Offset
ASU 070—ActiveSeat™ Raise/Lower Solenoid Null Current Calibration
ASU 071—Manual Flow Valve Operation Configuration
ASU 072—ActiveSeat™ Position Sensor Calibration
ASU 073—Lower Bumper Position Sensor Voltage
ASU 074—Upper Bumper Position Sensor Voltage
ASU 075—Raise-Lower Solenoid Current
ASU 076—Pressure Control Solenoid Current
ASU 077—ActiveSeat™ Control Status
ASU 078—Hydraulic Oil Temperature
ASU 199—TLA Disable Configuration
Automatic Temperature Control (ATC) Configuration and Calibration
ATC 001—Recall Diagnostic Trouble Codes
ATC 002—ATC System Beep Mode
ATC 003—ATC Circulation Blower Motor Mode Status
ATC 004—ATC Compressor Clutch Status
ATC 005—ATC Circulation Blower Motor Duty Cycle
ATC 006—Cab Temperature Set Point
ATC 007—Air Flow Mode Motor Setting
ATC 008—Cab Air Temperature
ATC 009—Target Outlet Air Temperature
ATC 010—Outlet Air Temperature
ATC 011—Water Valve Motor Position
ATC 012—Engine Coolant Temperature
ATC 013—Factory Use Only
ATC 014—Second Ambient Air Temperature
ATC 017—Refrigerant Pressure
ATC 018—Factory Use Only
ATC 019—Pressurizer Blower Motor Status
ATC 020—Evaporator Temperature
ATC 022—Water Valve Motor Calibration
ATC 023—Air Flow Mode Motor Calibration
ATC 026—Factory Use Only
ATC 027—Rear Ambient Temperature Sensor Enable
ATC 028—Factory Use Only
ATC 029—Refrigerant Pressure Sensor Enable
ATC 030—Pressurizer Fan Control Setting
ATC 032—A/C Clutch Control Configuration
ATC 033—Display Ambient/Set Temperature
ATC 035—Recirculation Blower Setting Status
ATC 038—Display Temperature Offset
ATC 040—Cab Temperature Sensor Voltage
ATC 041—Outlet Temperature Sensor Voltage
ATC 042—Factory Use Only
ATC 043—Rear Ambient Temperature Sensor Voltage
ATC 044—Refrigerant Pressure Sensor Voltage
ATC 045—Evaporator Temperature Sensor Voltage
ATC 046—PWM Output Polarity
ATC 047—PWM Output Period
ATC 048—Minimum Evaporator Set Temperature
ATC 049—Discharge Set Temperature
ATC 050—Minimum Fan Voltage in Fan Auto Mode
ATC 051—Minimum Duty Cycle in Manual Fan Mode
ATC 052—Default Backlighting Brightness
ATC 053—Outside Air Threshold 1
ATC 054—Outside Air Threshold 2
ATC 055—Outside Air Threshold 3
ATC 056—Outside Air Threshold 4
ATC 057—Evaporator Cut Off Temperature 1
ATC 058—Evaporator Cut Off Temperature 2
ATC 059—Evaporator Cut Off Temperature 3
ATC 060—Evaporator Cut Off Temperature 4
ATC 061—Evaporator Cut Off Temperature 5
ATC 062—Blower Speed Maximum
ATC 063—Blower Speed Minimum in Auto Mode
ATC 064—Blower Speed Maximum in Auto Mode
ATC 065— Water Valve Deadband Closed Side
ATC 066— Water Valve Deadband Opened Side
ATC 193—199—Factory Use Only
Chassis Control Unit (CCU) Configuration and Calibration
CCU 001—Control Unit Stored Codes
CCU 002—CCU System Beep Mode With Speed Sensors
CCU 003—CCU System Beep Mode Without Speed Sensors
CCU 004—CCU Supply Voltage Status
CCU 005—Radar Speed Sensor Status
CCU 006—Primary Wheel Speed Sensor and Secondary Wheel Speed Sensor Status
CCU 010—Hydraulic Oil Temperature Sensor Voltage Status
CCU 013—Primary Fuel Level Sensor Voltage Status
CCU 014—Primary Fuel Level Sensor Resistance Status
CCU 015—Wake-up Voltage Status
CCU 016—Hydraulic Oil Filter Restriction Sensor Voltage Status
CCU 025—Diagnostic Hydraulic Pressure Sensor Voltage Status
CCU 030—Air Trailer Brake Pressure Sensor Voltage Status
CCU 031—Implement Switch Status
CCU 038—Differential Lock Mode Configuration
CCU 039—Differential Lock Technician Mode Configuration
CCU 040—CSM Input Message Status
CCU 041—Brake and Decelerator Input Message Status
CCU 042—MFWD Command Status
CCU 043—Differential Lock Command Status
CCU 044—MFWD Technician Mode Configuration
CCU 045—MFWD Mode Configuration
CCU 048—MFWD Configuration
CCU 049—Differential Lock Configuration
CCU 050—CCU Sensor Reference Voltage 3 Status
CCU 051—CCU Sensor Reference Voltage 4 Status
CCU 052—Hydraulic Oil Temperature Status
CCU 054—Fuel Level Percentage Status
CCU 055—Primary Wheel Speed Status
CCU 056—Current Radar Speed Status
CCU 057—Secondary Wheel Speed Status
CCU 064—Air Brake Pressure Status
CCU 065—CCU Battery Voltage Status
CCU 066—CCU Switched ELX Voltage Status
CCU 067—Valve Power Voltage Status
CCU 083—SRI Rear Tire Size Maximum
CCU 084—SRI Rear Tire Size Minimum
CCU 085—SRI Rear Tire Size Configuration
CCU 086—SRI Rear Tire Size Display
CCU 087—SRI Front Tire Size Maximum
CCU 088—SRI Front Tire Size Minimum
CCU 089—Factory Use Only
CCU 095—Freeze Frame Data Configuration
CCU 099—Factory Use Only
CCU 100—Factory Use Only
CCU 102—Fuel Level Setting Configuration #1
CCU 103—Fuel Level Setting Configuration #2
CCU 105—Diagnostic Sensor Pressure Status
CCU 112—Radar Sensor Speed Configuration
CCU 113—Interactive Radar Calibration
CCU 114—Air Trailer Brake Pressure Configuration
CCU 116—Air Trailer Brake Configuration
CCU 117—Diagnostic Pressure Sensor Configuration
CCU 126—Oil Filter Restriction Configuration
CCU 128—Radar Speed Configuration
CCU 129—Enable Debug Messages Configuration
CCU 135—Switch or Sensor Configuration
CCU 140—Hydraulic Oil Level Reservoir Configuration
CCU 143—Wheel Angle Curvature Status
CCU 145—Factory Use Only
CCU 146—Factory Use Only
CCU 147—Factory Use Only
CCU 168—Wheel Angle Sensor Configuration
CCU 169—Decelerator Switch Configuration
CCU 170—Secondary Brake Configuration
Cab Load Center (CLC) Configuration and Calibration
CLC 001—Recall Diagnostic Trouble Codes
CLC 002—CLC System Beep Mode
CLC 004—Index to CAN Debug Request Record
CLC 005—Contents of CAN Debug Request Record
CLC 015—Right Wiper Out of Park Status
CLC 019—Control Unit Board Temperature
CLC 020—Flasher Sync Input Status
CLC 021—Buzzer 1 Driver Status and Current
CLC 022—Left Tail/Trailer Tail Lamps Driver Status and Current
CLC 023—Right Tail/Trailer Tail Lamps Driver Status and Current
CLC 024—Trailer Brake Light Driver #2 Status and Current
CLC 025—Brake Light Driver Status and Current
CLC 026—Trailer Brake light Driver #1 Status and Current
CLC 027—Left Fender Turn Signal Driver Status and Current
CLC 028—Right Fender Turn Signal Driver Status and Current
CLC 029—Backup Alarm Driver Status and Current
CLC 030—Left Rear Fender Flood Light Driver Status and Current
CLC 031—Right Rear Fender Flood Light Driver Status and Current
CLC 033—Horn Driver Status and Current
CLC 038—Range Lever Backlight Status
CLC 039—Hitch Lever Backlight Status
CLC 041—Right Window Wiper Driver Status and Current
CLC 043—Trailer Work Light Driver Status and Current
CLC 045—Control Unit Current
CLC 046—Sensor Reference Voltage
CLC 053—Lighting Configuration 1
CLC 054—Buzzer Timer Adjustment
CLC 056—Vehicle Model Configuration
CLC 060—Work Light Shutdown Time (Communication)
CLC 061—Backlight Configuration
CLC 063—Right Wiper Configuration
CLC 099—Maximum Control Unit Board Temperature
CLC 102—Percent of Time Control Unit Board Temperature Was Less Than -40° C
CLC 103—Percent of Time Control Unit Board Temperature Was Between -39 and 24° C
CLC 104—Percent of Time Control Unit Board Temperature Was Between 25 and 50° C
CLC 105—Percent of Time Control Unit Board Temperature Was Between 51 and 69° C
CLC 106—Percent of Time Control Unit Board Temperature Was Between 70 and 84° C
CLC 107—Percent of Time Control Unit Board Temperature Was Between 85 and 104° C
CLC 108—Percent of Time Control Unit Board Temperature Was More Than 105° C
CLC 120—Maximum Control Unit Current Output
CLC 121—Maximum Control Unit Current Output Voltage
Radio Control Software (CRU)
Radio Software (CRU) Configuration and Calibration
CRU 001—Control Unit Stored Codes
CRU 002—CRU System Beep Mode With Speed Sensors
CRU 003—CRU Supply Voltage
CRU 004—Internal Radio Temperature
CRU 005—Dimming Offset
CRU 006—Minutes Per Hour Configuration
CRU 007—Speaker Configuration
CRU 008—Speaker Test
CRU 009—Country Configuration
CRU 010—Auxiliary Connection Status
CRU 011—Hands Free Cab Configuration
Cab Suspension Control Unit (CSC) Configuration and Calibration
CSC 001—Control Unit Stored Codes
CSC 002—System Beep Mode
CSC 003—Control Unit Unswitched Supply Voltage
CSC 004—CSC Sensor Supply Voltage
CSC 005—CSC Position Sensor Voltage
CSC 006—CSC Solenoid Valve States
CSC 010—Cab Suspension Solenoid Valve UP Actual Current
CSC 011—Cab Suspension Solenoid Valve DOWN Actual Current
CSC 012—Cab Suspension Commanded Damping
CSC 013—Cab Suspension Proportional Valve Actual Current Setpoint
CSC 014—Cab Suspension Proportional Valve Actual Current
CSC 020—CSC Cab Suspension Position Sensor Calibration
CSC 021—Cab Suspension Bleeding Calibration
CSC 022—Cab Suspension Pressure Discharge
CSC 023—Cab Suspension Manual Cab Lifting
CSC 024—Cab Suspension Manual Damping Control
CSC 030—Position Sensor Calibration Value - Upper Endstop
CSC 031—Position Sensor Calibration Value - Center Position
CSC 032—Position Sensor Calibration Value - Lower Endstop
CSC 040—Medium Mode Damping Value
CSC 041—Proportional Valve Current Setpoint
CSC 042—Proportional Valve Current Setpoint - Lower Limit
CSC 043—Proportional Valve Current Setpoint - Upper Limit
CSC 099—Technician Password
Cab Switch Module (CSM) Software Configuration and Calibration
CSM 001—CSM Control Unit Stored Codes
CSM 002—System Beep Mode
CSM 010—Cab Controls Module HVAC Inputs Status
CSM 011—Cab Controls Module Stereo Inputs Status
CSM 012—Cab Controls Module Lights, SCV Lock, and ISB Inputs Status
CSM 020—MFWD and Diff Lock Push Buttons Status
CSM 030—Armrest Navigation Bar Inputs Status
CSM 031—Armrest Navigation Bar Shortcut Inputs Status
CSM 032—Armrest Navigation Bar Shortcut Inputs Status
CSM 050—Backlight Brightness Level
CSM 051—Cab Controls Module CAN Messages
CSM 052—MFWD and Diff Lock Status CAN Messages
CSM 070—Backlight Brightness Level
CSM 074—Cab Controls Module Messages
CSM 075—MFWD and Diff Lock Status Messages
CSM 090—Battery Voltage
CSM 091—Switched Power (ELX) Voltage
CSM 092—Armrest 12 V Sensor Supply 1 Inputs Status
CSM 093—Armrest 12 V Sensor Supply 2 Inputs Status
CSM 094—Armrest 5 V Sensor Supply 1 Inputs Status
CSM 095—Armrest 5 V Sensor Supply 2 Inputs Status
CSM 159—Factory Use Only
CSM 160—Factory Use Only
CSM 161—Factory Use Only
CSM 162—Factory Use Only
CSM 163—Factory Use Only
CSM 164—Factory Use Only
CSM 165—Factory Use Only
CSM 166—Factory Use Only
CSM 167—Factory Use Only
Engine Control Unit (ECU) Address List
ECU 040—Actual Fan Speed
ECU 041—Desired Fan Speed
ECU 060—Fan Speed Diagnostic Input
ECU 061—Fan Ratio Diagnostic Input
ECU 108—Engine Coolant Level Sensor
ECU 150—Engine Coolant Loss Sensor
ECU 157—Fan Speed Beep Mode
ECU 180—AC Clutch Driver Status
Engine Interface Control Unit (EIC) Configuration and Calibration
EIC 001—Recall Diagnostic Trouble Codes
EIC 002—EIC System Beep Mode
EIC 004—Index to CAN Debug Request Record
EIC 005—Contents of CAN Debug Request Record
EIC 040—After Treatment Service Cleaning Enable
EIC 041—Save Aftertreatment Inhibit Setting
EIC 050—Hand Throttle Scaled Percent
EIC 051—Foot Throttle Scaled Percent
EIC 052—Hand Throttle Basic Engine Speed
EIC 053—Foot Throttle Basic Engine Speed
EIC 058—Final Commanded Engine Speed
EIC 059—Actual Engine Speed
EIC 060—Engine Hours
EIC 061—Vehicle Hours
EIC 070—Intelligent Power Management Status
EIC 072—Unfiltered Rear PTO Power
EIC 073—Unfiltered Front PTO Power
EIC 075—Intelligent Power Management PTO Boost Status
EIC 076—Intelligent Power Management PTO Boost Percent
EIC 077—Intelligent Power Management PTO Boost Power
EIC 078—Intelligent Power Management Filtered Rear PTO Power
EIC 079—Intelligent Power Management Filtered Front PTO Power
EIC 080—Intelligent Power Management Transport Boost Status
EIC 081—Intelligent Power Management Transport Boost Percent
EIC 082—Intelligent Power Management Transport Boost Power
EIC 100—Current Key ID
EIC 101—Key ID #1
EIC 102—Key ID #2
EIC 103—Key ID #3
EIC 104—Key ID #4
EIC 105—Key ID #5
EIC 106—Key Identification Request
EIC 110—Number of Programmed Keys
EIC 111—Key Number 1—5
EIC 112—Immobilizer Control Device Secure Code Status
EIC 113—Immobilizer Control Device CAN Speed Rate
EIC 114—Immobilizer Control Device Error Code
EIC 115—Immobilizer Control Device Hardware Version Number
EIC 116—Immobilizer Control Device Software Version Number
EIC 178—Field Cruise 2 On/Off
EIC 179—Field Cruise 2 Engine Speed Limit
EIC 180—Field Cruise On/Off
EIC 181—Field Cruise Engine Speed Limit
EIC 182—IPM On/Off
EIC 183—Aftertreatment Operator Setting Disabled/Inhibited
Front Console Control Unit (FCC) Configuration and Calibration
FCC 001—Recall Diagnostic Trouble Codes
FCC 002—FCC System Beep Mode
FCC 003—Index to CAN Debug Request Record
FCC 004—Contents of CAN Debug Request Record
FCC 005—Left Hand Reverser Lever Switch Status
FCC 006—Top Left Switch Status
FCC 007—Reverse Switch Status
FCC 008—Turn Signal Switch Status
FCC 009—Light Switch Status
FCC 010—Horn and Hi Beam Switch Status
FCC 011—Front Wiper Switch Status
FCC 015—LHR Position Status
FCC 050—Transmission Type Configuration
FCC 051—Reverser Type Configuration
FCC 052—Turn Signal Configuration
FCC 053—Light Switch Configuration
FCC 054—Hi Beam Switch Configuration
FCC 055—Front Wiper Switch Configuration
FCC 057—Horn Switch Configuration
FCC 058—Hazard Switch Configuration
Hitch CAN Controler (HCC) Calibration, and Configuration
HCC 001—HCC Control Software Stored Codes
HCC 002—System Beep Mode
HCC 003—Option Jumper Status
HCC 004—Rear Hitch Position Sensor Voltage
HCC 005—Rear Hitch Draft Sensor Voltage
HCC 007—Rear Hitch External Switch
HCC 013—Rear Hitch Sensor Supply Voltage
HCC 014—Control Unit Switched Supply Voltage
HCC 015—Control Unit Unswitched Supply Voltage
HCC 016—Hitch CAN Valve Supply Voltage
HCC 019—HCC Hydraulic Oil Temperature
HCC 020—Rear Hitch Calibration
HCC 021—Rear Hitch Option Configuration
HCC 022—Rear Hitch Operator Command
HCC 023—Rear Hitch Valve Command as a Percent
HCC 024—Rear Hitch Raise Rate Adjustment
HCC 026—Rear Hitch Draft Sensor Voltage Adjustment
HCC 027—Rear Hitch Draft Sensor Gain Adjustment
HCC 028—Rear Hitch Position Minimum Voltage
HCC 029—Rear Hitch Position Maximum Voltage
HCC 030—Rear Hitch Valve Command
HCC 031—Rear Hitch Valve Flow
HCC 033—Rear Hitch Maximum Raise Valve Command
HCC 034—Rear Hitch Raise Valve Deadband Current
HCC 035—Rear Hitch Lower Valve Deadband Current
HCC 080—Rear Hitch Cylinder Speed
HCC 087—Rear Hitch Slip Setting
HCC 088—Rear Hitch Slip Threshold Setting
HCC 091—Rear Hitch Transport Damping Enable
HCC 093—Hitch Command Offset
HCC 094—Hitch Command Offset Distance
HCC 149—CAN Bus TLAs
HCC 200—251—General Control Software Data
Hitch Valve Software Addresses (HV1)
Rear Hitch Valve (HV1) Configuration and Calibration
HV1 001—HV I Control Unit Stored Codes
HV1 011—HV I Supply Voltage
HV1 030—Spool Position Temperature Compensation for Extend
HV1 031—Spool Position Temperature Compensation/Retract
HV1 033—Raise/Lower Ramp Time ON
HV1 034—Raise/Lower Ramp Time OFF
HV1 180—Current Active Internal Fault Code
HV1 181—186—Factory Use Only
HV1 190—191—Factory Use Only
Vehicle Security Control Software (ICA) Configuration and Calibration
ICA 001—Control Unit Stored Codes
ICA 002—System Beep Mode
JDLink Software Addresses (JDL)
JDL Addresses
Operator Interface Control Unit (OIC) Configuration and Calibration
OIC 001—Recall Diagnostic Trouble Codes
OIC 002—OIC System Beep Mode
OIC 004—Brake Status
OIC 005—Differential Lock Switch Status
OIC 006—Right Fender PTO Switch Status
OIC 007—Left Fender PTO Switch Status
OIC 008—Wakeup Input Voltage Status
OIC 009—Fender Hitch Raise Switch Status
OIC 010—Wakeup and ELX Output Voltage Status
OIC 011—Fender Hitch Lower Switch Status
OIC 013—Fender SCV Extend Switch Status
OIC 014—Fender SCV Retract Switch Status
OIC 015—AGT Shift Switch Status
OIC 016—AGT Shift Switch Flag Status
OIC 018—Rear Window and Decel Switch Status
OIC 019—Range Lever Status
OIC 020—Range Lever Count
OIC 021—Key and Miscellaneous Switches
OIC 030—ELX Output Driver
OIC 031—Wakeup Output Driver
OIC 032—CAN Terminator Power Driver
OIC 033—Automatic Battery Disconnect Driver
OIC 050—Clutch Pedal Position Potentiometer 1
OIC 051—Clutch Pedal Position Potentiometer 2
OIC 053—Foot Throttle Potentiometer 1
OIC 054—Foot Throttle Potentiometer 2
OIC 055—Left Brake Sensor
OIC 056—Right Brake Sensor
OIC 057—ELX System Voltage
OIC 058—Sensor Reference Voltage
OIC 059—System Sensor Voltage 1
OIC 060—System Sensor Voltage 2
OIC 061—System Sensor Voltage 3
OIC 063—System Sensor Current 1
OIC 064—System Sensor Current 2
OIC 065—System Sensor Current 3
OIC 066—Hand Clutch Voltage
OIC 067—Hand Clutch Voltage Ratio
OIC 068—Brake Calibration
OIC 069—Left Brake Calibration Results
OIC 070—Right Brake Calibration Results
OIC 071—Brakes Calibrated Status
OIC 072—Clutch Pedal Current Minimum Voltage
OIC 073—Clutch Pedal Current Maximum Voltage
OIC 074—Foot Throttle Current Minimum Voltage
OIC 075—Foot Throttle Current Maximum Voltage
OIC 076—Left Brake Current Minimum Voltage
OIC 077—Left Brake Current Maximum Voltage
OIC 078—Right Brake Current Minimum Voltage
OIC 079—Right Brake Current Maximum Voltage
OIC 101—TLA Disable 1
OIC 102—TLA Disable 2
OIC 103—Secondary Brake Configuration Status
OIC 104—Rear Window Switch Configuration Status
OIC 106—Transmission Type Configuration Status
OIC 107—Hitch Fender Switch Configuration Status
OIC 108—SCV Fender Switch Configuration Status
OIC 109—PTO Fender Switch Configuration Status
OIC 110—Seat Switch Configuration Status
OIC 111—Decelerator Switch Configuration Status
OIC 112—Key Switch Configuration Status
OIC 113—Come Home Fuse Configuration Status
OIC 115—Foot Throttle Configuration Status
OIC 116—Brake Configuration 1 Status
OIC 118—Clutch Pedal Configuration Status
OIC 119—Differential Lock Configuration Status
Corner Post Display (PDU) Control Unit Configuration and Calibration
PDU 001—PDU Control Unit Stored Codes
PDU 002—System Beep Mode
PDU 020—Backlight Brightness Level Configuration
PDU 021—MPH Mode Configuration
PDU 022—Auto Clear DTC Hours
PDU 023—Transmission Type Configuration
PDU 024—Audible Alarm Mode
PDU 050—CAN High Voltage Status
PDU 051—CAN Low Voltage Status
PDU 052—Control Unit Switched Supply Voltage Status
PDU 053—Control Unit Unswitched Voltage Status
PDU 054—Sensor Supply Voltage Status
PDU 055—LED Backlighting Voltage Status
PDU 056—J6-9 Voltage Status
PDU 057—J6-10 Voltage Status
PDU 120—Add Required Control Units
PDU 121—Delete Required Control Units
PDU 137—Automatic Engine Shutdown Configuration
PDU 138—ActiveCommand™ Steering Status Message Configuration
PDU 139—Steering Message Required Configuration
PDU 140—Engine Coolant Gauge Type
Front PTO Control Software (PTF) Configuration and Calibration
PTF 001—Control Unit Stored Codes
PTF 002—PTF System Beep Mode With Speed Sensors
PTF 003—PTF System Beep Mode Without Speed Sensors
PTF 004—PTF Supply Voltage
PTF 005—Front PTO Speed Sensor Status
PTF 006—Front PTO Remote Switch Status
PTF 007—Front PTO Switch and Enable Line Status
PTF 009—Front PTO Oil Temperature Sensor Voltage
PTF 010—Front PTO Clutch Pressure Sensor Voltage
PTF 011—Front PTO Return Oil Pressure Sensor Voltage
PTF 025—Front PTO Diagnostic Pressure Sensor Voltage
PTF 050—PTF Unswitched Supply Voltage
PTF 051—PTF Sensor Supply Voltage
PTF 053—Front PTO Oil Temperature
PTF 054—Front PTO Clutch Pressure
PTF 055—Front PTO Return Oil Pressure
PTF 058—Front PTO Speed
PTF 059—Front PTO Solenoid Power Status
PTF 060—Engine Speed
PTF 071—Last Automation Exit Code
PTF 100—Factory Use Only
PTF 101—Front PTO Remote Operation and Overspeed Shutdown Status
PTF 102—Front PTO Speeds Configuration
PTF 104—Front PTO Setup 1
PTF 105—Front PTO Setup 2
PTF 107—Front PTO Speed Sensor Pulses Per Revolution
PTF 108—Front PTO Unloaded Calibration
PTF 109—Front PTO Fill Pressure
PTF 110—Front PTO Pressure Gain
PTF 111—Front PTO Open Loop Offset
PTF 116—Front PTO Calibration Error
PTF 117—Front PTO Fill TIme
PTF 118—Front PTO Brake Fill Pressure
PTF 119—Front PTO Valve Command
PTF 120—Front PTO Valve Current
PTF 121—Front PTO Torque
PTF 122—Front PTO Oil Type Configuration
PTF 123—Front PTO Setup 3
PTF 124—Front PTO Setup 4
PTF 126—Front PTO Base Clutch Pressure
PTF 127—Front PTO Temperature Based Clutch Pressure Adjustment
PTF 129—Enable Debug Data Configuration
PTF 130—Platform Configuration
PTF 131—Transmission Type Configuration
PTF 135—Diagnostic Pressure Sensor Configuration
PTF 136—Diagnostic Pressure
PTF 140—Front PTO Hours
PTF 141—Front PTO Number of Engagements
PTF 142—Front PTO Number of Overpower Shutdowns
PTF 143—Front PTO Average Power
PTF 148—Factory Use Only
PTF 149—Front PTO Data Mode Min Temp
PTF 150—Front PTO Data Mode Max Temp
AutoPowr / IVT Transmission Control Software Addresses (PTI)
AutoPowr™ / IVT™ Transmission Control Unit (PTI) Calibration and Configuration
PTI 001—Control Unit Stored Codes
PTI 002—PTI System Beep Mode With Speed Sensors
PTI 003—PTI System Beep Mode Without Speed Sensors
PTI 004—Transmission Enable Low Status
PTI 005—Carrier Speed Sensor Status
PTI 006—Ring Gear 2 Primary Speed Sensor Status
PTI 007—Primary Transmission Output Speed Sensor Status
PTI 008—Secondary Transmission Output Speed Sensor Status
PTI 009—MFWD Speed Sensor Status
PTI 010—Hydro Clutch Unit (CU) Idler Speed Sensor Status
PTI 012—System 1 Pressure Sensor Voltage (—100000)
PTI 013—Park Brake Pressure Sensor Voltage
PTI 014—Clutch Enable Pressure Sensor Voltage
PTI 015—Diagnostic Pressure Sensor Voltage
PTI 017—Carrier Speed
PTI 018—Ring Gear 2 Primary Speed
PTI 019—CU Idler Speed
PTI 020—Hydro Control Test
PTI 021—Clutch Element Test
PTI 022—System 1 Pressure
PTI 023—Park Brake Pressure
PTI 024—Clutch Enable Pressure
PTI 025—Diagnostic Sensor Pressure
PTI 026—Transmission Oil Temperature
PTI 027—Clutch Calibration Values
PTI 028—Clutch Pedal Command Status
PTI 029—Calibration Reset Command
PTI 031—Hydro Calibration Values
PTI 032—Hydro Control Valve Command Status
PTI 033—Direction Display
PTI 036—Diagnostic Pressure Sensor Configuration
PTI 037—Calibration Failed Step Display
PTI 044—Primary Transmission Output Speed
PTI 045—Secondary Transmission Output Speed
PTI 046—MFWD Shaft Speed
PTI 047—Factory Use Only
PTI 070—Factory Use Only
PTI 071—Factory Use Only
PTI 072—Factory Use Only
PTI 073—Factory Use Only
PTI 074—Factory Use Only
PTI 075—Factory Use Only
PTI 076—Factory Use Only
PTI 100—RU Minimum Calibration Current
PTI 101—RU Zero Calibration Current
PTI 102—RU Shift Calibration Current
PTI 103—RU Maximum Calibration Current
PTI 104—CU Minimum Calibration Current
PTI 105—CU Zero Calibration Current
PTI 106—CU Maximum Calibration Current
PTI 107—Low Clutch Kissup Current
PTI 108—High Clutch Kissup Current
PTI 109—Reverse Brake Kissup Current
23SPD - e23 Transmission Control Software Addresses (PTP)
e23™ Transmission Control Unit (PTP) Calibration and Configuration
PTP 001—Control Unit Stored Codes (e23™)
PTP 002—System Beep Mode With Speed Sensors (e23™)
PTP 003—System Beep Mode Without Speed Sensors (e23™)
PTP 010—Control Unit Unswitched Supply Voltage (e23™)
PTP 011—Switched Power (ELX) Voltage (e23™)
PTP 012—Valve Power Voltage (e23™)
PTP 013—Park Brake Pressure Sensor Voltage (e23™)
PTP 014—PTP Sensor Reference Voltage 3 (e23™)
PTP 016—Lube Pressure Sensor Voltage (e23™)
PTP 017—System 2 Pressure Sensor Voltage (e23™)
PTP 018—Diagnostic Pressure Sensor Voltage (e23™)
PTP 019—Hydraulic Oil Temperature Sensor Voltage (e23™)
PTP 020—Counter Shaft B Speed Sensor Voltage (e23™)
PTP 021—Counter Shaft C Speed Sensor Voltage (e23™)
PTP 022—Transmission Primary Speed Sensor Voltage (e23™)
PTP 023—Transmission Secondary Speed Sensor Voltage (e23™)
PTP 025—R2 Clutch Pressure Sensor Voltage (e23™)
PTP 030—Transmission Enable Circuit Status (e23™)
PTP 031—Reverser Status (e23™)
PTP 032—Reverser Type (e23™)
PTP 037—Transmission Oil Temperature (e23™)
PTP 040—Counter Shaft B Speed Sensor Frequency Status (e23™)
PTP 041—Counter Shaft C Speed Sensor Frequency Status (e23™)
PTP 042—Primary Wheel Speed Sensor Frequency Status (e23™)
PTP 043—Secondary Wheel Speed Sensor Frequency Status (e23™)
PTP 044—Counter Shaft B Speed (e23™)
PTP 045—Counter Shaft C Speed (e23™)
PTP 046—Primary Wheel Speed (e23™)
PTP 047—Secondary Wheel Speed (e23™)
PTP 050—Lube Pressure (e23™)
PTP 051—System 2 Pressure (e23™)
PTP 052—Diagnostic Pressure Sensor Configuration (e23™)
PTP 053—Diagnostic Sensor Pressure (e23™)
PTP 055—Park Brake Pressure (e23™)
PTP 057—R2 Clutch Pressure (e23™)
PTP 070—Engine Speed (e23™)
PTP 071—Engine Brake Torque (e23™)
PTP 072—Clutch Engagement Command Status (e23™)
PTP 073—Requested Gear Status (e23™)
PTP 074—Desired Direction of Travel Status (e23™)
PTP 075—Desired Park Lock Status (e23™)
PTP 076—TIP Fault Status (e23™)
PTP 080—Counter Shaft B Slip Status (e23™)
PTP 081—Counter Shaft C Slip Status (e23™)
PTP 082—Output Shaft D Slip Status (e23™)
PTP 100—Transmission Calibration (e23™)
PTP 101—Clutch Element Test (e23™)
PTP 103—Hydraulic Oil Cooler Control Solenoid Override (e23™)
PTP 104—Lube Priority Solenoid Override (e23™)
PTP 108—Oil Type Configuration (e23™)
PTP 109—Alternate Oil Temperature Configuration (e23™)
PTP 128—Last Calibration Engine Hours (e23™)
PTP 129—Enable Debug Data Configuration (e23™)
PTP 130—Low Clutch Fill Time Adjustment (e23™)
PTP 131—High Clutch Fill Time Adjustment (e23™)
PTP 132—Reverse Clutch Fill Time Adjustment (e23™)
PTP 133—S1 Clutch Fill Time Adjustment (e23™)
PTP 134—S2 Clutch Fill Time Adjustment (e23™)
PTP 135—S3 Clutch Fill Time Adjustment (e23™)
PTP 136—S4 Clutch Fill Time Adjustment (e23™)
PTP 137—R1 Clutch Fill Time Adjustment (e23™)
PTP 138—R2 Clutch Fill Time Adjustment (e23™)
PTP 139—R3 Clutch Fill Time Adjustment (e23™)
PTP 140—Low Clutch Kissup Pressure Adjustment (e23™)
PTP 141—High Clutch Kissup Pressure Adjustment (e23™)
PTP 142—Reverse Clutch Kissup Pressure Adjustment (e23™)
PTP 143—S1 Clutch Kissup Pressure Adjustment (e23™)
PTP 144—S2 Clutch Kissup Pressure Adjustment (e23™)
PTP 145—S3 Clutch Kissup Pressure Adjustment (e23™)
PTP 146—S4 Clutch Kissup Pressure Adjustment (e23™)
PTP 147—R1 Clutch Kissup Pressure Adjustment (e23™)
PTP 148—R2 Clutch Kissup Pressure Adjustment (e23™)
PTP 149—R3 Clutch Kissup Pressure Adjustment (e23™)
PTP 150—Last Calibration Engine Hours (e23™)
PTP 160—Forward Low Proportional Solenoid Valve Current (e23™)
PTP 161—Forward High Proportional Solenoid Valve Current (e23™)
PTP 162—Reverse Proportional Solenoid Valve Current (e23™)
PTP 163—S1 Proportional Solenoid Valve Current (e23™)
PTP 164—S2 Proportional Solenoid Valve Current (e23™)
PTP 165—S3 Proportional Solenoid Valve Current (e23™)
PTP 166—S4 Proportional Solenoid Valve Current (e23™)
PTP 167—R1 Proportional Solenoid Valve Current (e23™)
PTP 168—R2 Proportional Solenoid Valve Current (e23™)
PTP 169—R3 Proportional Solenoid Valve Current (e23™)
PTP 170—Lube Priority Solenoid Valve Current (e23™)
PTP 171—Hydraulic Oil Cooler Control Solenoid Current (e23™)
PTP 173—Park Brake Supply Solenoid Status (e23™)
PTP 174—Park Sump Block Solenoid Current (e23™)
PTP 180—Current Gear Status (e23™)
PTP 181—Selected Gear Status (e23™)
PTP 182—Shift In Process Status (e23™)
PTP 183—Direction of Travel Status (e23™)
PTP 184—Possible Powered Motion Status (e23™)
PTP 185—Park Lock Status (e23™)
16SPD - 16-Speed Powershift Transmission Control Software Addresses (PTP)
Power Train Control Unit (PTP) Configuration and Calibration
PTP 001—Control Unit Stored Codes (16 Speed)
PTP 002—PTP System Beep Mode With Speed Sensors (16 Speed)
PTP 003—PTP System Beep Mode Without Speed Sensors (16 Speed)
PTP 004—Countershaft Speed Sensor (16 Speed)
PTP 005—ELX Relay Voltage Status (16 Speed)
PTP 006—Transmission Enable Signal From TIP Status (16 Speed)
PTP 007—Shift Lever Direction Status (16 Speed)
PTP 008—Park and Not-Neutral Status (16 Speed)
PTP 011—Sensor Excitation Status (16 Speed)
PTP 013—Park Brake Pressure Sensor Voltage (16 Speed)
PTP 014—System Pressure Sensor Voltage (16 Speed)
PTP 020—Shift Valve Circuit Test (16 Speed)
PTP 021—Engine Coolant Temperature (16 Speed)
PTP 022—Hydraulic Oil Temperature (16 Speed)
PTP 023—Hydraulic Oil Type Setting (16 Speed)
PTP 024—Air Auto Purge (16 Speed)
PTP 025—PowerShift Transmission Calibration (16 Speed)
PTP 026—No-Load Torque Calibration (16 Speed)
PTP 027—Transmission Fill Pressure and Volume Result (16 Speed)
PTP 028—Factory Use Only
PTP 029—Load Compensation Configuration (16 Speed)
PTP 030—Top Reverse Gear Setting (16 Speed)
PTP 034—C-Clutch (CC) Empty Rate Adjustment (16 Speed)
PTP 035—Temperature Factor for Non-J20C Oil (16 Speed)
PTP 037—SCV Load Compensation (16 Speed)
PTP 038—Diagnostic Pressure Sensor Configuration (16 Speed)
PTP 039—Diagnostic Sensor Pressure (16 Speed)
PTP 040—Suspension Configuration (16 Speed)
PTP 042—SCV Load Compensation Enable (16 Speed)
PTP 043—Engine Stall Prevention Configuration (16 Speed)
PTP 050—System Supply Voltage (16 Speed)
PTP 051—PTP Sensor Supply Voltage (16 Speed)
PTP 053—Countershaft Speed (16 Speed)
PTP 054—System Pressure (16 Speed)
PTP 055—Park Brake Pressure (16 Speed)
PTP 080—Secondary Wheel Speed Frequency (16 Speed)
PTP 081—Valve Power Voltage Status (16 Speed)
PTP 083—ELX Voltage Status (16 Speed)
PTP 084—Park Brake Voltage Status (16 Speed)
PTP 085—Primary Wheel Speed Voltage Status (16 Speed)
PTP 089—Primary Wheel Speed Frequency (16 Speed)
PTP 152—A Brake (AB) Pressure Adjustment (16 Speed)
PTP 153—B Clutch (BC) Pressure Adjustment (16 Speed)
PTP 154—C Clutch (CC) Pressure Adjustment (16 Speed)
PTP 155—D Clutch (DC) Pressure Adjustment (16 Speed)
Roof Lighting Control Unit (RLC) Configuration and Calibration
RLC 001—RLC Control Unit Stored Codes
RLC 002—System Beep Mode
RLC 006—Vehicle CAN Bus Low Voltage
RLC 007—Vehicle CAN Bus High Voltage
RLC 008—Implement CAN Bus Low Voltage
RLC 009—Implement CAN Bus High Voltage
RLC 012—ELX Wake UP Voltage
RLC 013—Flasher Sync Output Driver Status
RLC 014—Valve Power Status
RLC 015—RLC Control Unit Board Temperature Status
RLC 016—Left Fender Turn Signal Status
RLC 017—Right Fender Turn Signal Status
RLC 018—Dome Light Status
RLC 019—License Plate Light Status
RLC 020—Left Mid Body Flood Light Status
RLC 021—Right Mid Body Flood Light Status
RLC 022—Left Rear Side Roof Flood Light Status
RLC 023—Right Rear Side Roof Flood Light Status
RLC 024—Left Rear Inner Roof Flood Light Status
RLC 025—Right Rear Inner Roof Flood Light Status
RLC 026—Left Front Side Roof Flood Light Status
RLC 027—Right Front Side Roof Flood Light Status
RLC 028—Left Front Roof Warning (NA Only) or Left Front Corner Roof Light (Eur Only) Status
RLC 029—Right Front Roof Warning (NA Only) or Right Front Corner Roof Light (Eur Only) Status
RLC 030—Left Rear Roof Warning (NA Only) or Left Rear Corner Roof Light (Eur Only) Status
RLC 031—Right Rear Roof Warning (NA Only) or Right Rear Corner Roof Light (Eur Only) Status
RLC 032—Left Front Inner Roof Flood Light Status
RLC 033—Right Front Inner Roof Flood Light Status
RLC 034—Left Front Clearance Light (Eur Only) Status
RLC 035—Right Front Clearance Light (Eur Only) Status
RLC 036—Left Front Warning Light (Eur Only) Status
RLC 037—Right Front Warning Light (Eur Only) Status
RLC 038—Front Wiper Motor High Speed Status
RLC 039—Front Wiper Motor Low Speed Status
RLC 040—Rear Wiper Motor Low Speed Status
RLC 041—Right Loader Flood Light Low Beam Status
RLC 042—Left Loader Flood Light Low Beam Status
RLC 043—Right Loader Flood Light High Beam Status
RLC 044—Left Loader Flood Light High Beam Status
RLC 045—RLC Total Current
RLC 046—Amber Console Light Status
RLC 047—Beacon Light 1 Status
RLC 048—Beacon Light 2 Status
RLC 049—Wiper Park Feedback Power Status
RLC 050—Pressurizer Blower Motor Status
RLC 051—HVAC Controls Backlighting Status
RLC 052—Front and Rear Wiper Park Position and Wake Up Status
RLC 053—Wiper Switches Status
RLC 054—Miscellaneous Cab Input Status
RLC 056—Beacon and Strobe Light Configuration
RLC 057—Turn Signal Configuration
RLC 058—Park Input For Rear Wiper Configuration
RLC 059—Day Time Brightness Configuration
RLC 060—Night Time Brightness Configuration
RLC 061—Backlight Configuration
RLC 062—Front Wiper Configuration
RLC 063—Rear Wiper Configuration
RLC 064—Hood Light Configuration
RLC 065—Rear Roof Light Configuration
RLC 066—Front Roof Light Configuration
RLC 067—Road Light Configuration
RLC 068—Mid Body Work Light Configuration
RLC 069—Lighting Screen Display Hold Time Configuration
RLC 070—Lights Auto OFF Low Voltage Configuration
RLC 071—Lights Auto OFF Under Voltage Time Configuration
RLC 072—Lights Auto OFF Ignition OFF Time Configuration
RLC 073—Lights Auto OFF Ignition ON Time Configuration
RLC 074—Road Lights In Park Configuration
RLC 075—Pressurizer Fan Configuration
RLC 076—Lighting Test Mode Configuration
RLC 077—Manual A/C Switch Configuration
RLC 078—Remote PTO Configuration
RLC 079—Vehicle Model Configuration
RLC 080—High Voltage Protection Configuration
RLC 081—Amber Console Light Configuration
RLC 082—Rear Fender Bulb Type Configuration
RLC 084—Freeze Frame Data Configuration
RLC 085—Trailer Work Light Button Configuration
RLC 086—Work Light Shutdown Time Configuration
RLC 087—Operator Warning Configuration
RLC 088—Self Canceling Turn Signal Configuration
RLC 089—License Plate Light Configuration
RLC 090—Clearance Light Configuration
RLC 091—Vehicle Lighting Configuration
RLC 092—Dome Light Control Configuration
RLC 099—Maximum Control Unit Board Temperature
RLC 102—Percent Of Time Control Unit Temperature Was Less Than -40° C
RLC 103—Percent Of Time Control Unit Temperature Was Between -39 and 24° C
RLC 104—Percent Of Time Control Unit Temperature Was Between 25 and 50° C
RLC 105—Percent Of Time Control Unit Temperature Was Between 51 and 69° C
RLC 106—Percent Of Time Control Unit Temperature Was Between 70 and 84° C
RLC 107—Percent Of Time Control Unit Temperature Was Between 85 and 104° C
RLC 108—Percent Of Time Control Unit Temperature Was More Than 105° C
RLC 120—Maximum Control Unit Current Output
RLC 121—Maximum Control Unit Current Output Voltage
Rear PTO Control Software (RPT) Configuration and Calibration
RPT 001—Control Unit Stored Codes
RPT 002—RPT System Beep Mode With Speed Sensors
RPT 003—RPT System Beep Mode Without Speed Sensors
RPT 004—RPT Supply Voltage
RPT 005—Rear PTO Speed Sensor Status
RPT 006—Rear PTO Remote Switch Status
RPT 007—Rear PTO Switch and Enable Line Status
RPT 025—Diagnostic Pressure Sensor Voltage
RPT 050—RPT Unswitched Supply Voltage
RPT 051—RPT 5V Sensor Supply 4 Voltage
RPT 053—Rear PTO Oil Temperature
RPT 058—Rear PTO Speed
RPT 059—Valve Power Status
RPT 060—Engine Speed
RPT 063—High Reverse Gear Prevention Configuration
RPT 066—Minimum Engine Speed Requested
RPT 071—Last Automation Exit Code
RPT 085—Brake Fill Method
RPT 100—Factory Use Only
RPT 101—Rear PTO Remote Operation and Overspeed Shutdown Status
RPT 102—Rear PTO Speeds Configuration
RPT 103—PTO Brake Fill Pressure Calibration
RPT 104—Rear PTO Setup 1
RPT 105—Rear PTO Setup 2
RPT 107—Rear PTO Pulses Per Axle Revolution Configuration
RPT 108—Rear PTO Unloaded Calibration
RPT 109—Rear PTO Fill Pressure Adjustment
RPT 116—Rear PTO Calibration Error
RPT 117—Rear PTO Fill Time
RPT 118—Rear PTO Brake Fill Pressure
RPT 119—Rear PTO Valve Command
RPT 120—Rear PTO Valve Current
RPT 121—Rear PTO Torque
RPT 122—Rear PTO Oil Type Configuration
RPT 123—Rear PTO Setup 3
RPT 124—Rear PTO Setup 4
RPT 129—Enable Debug Data Configuration
RPT 130—Platform Configuration
RPT 131—Transmission Type Configuration
RPT 135—Diagnostic Pressure Sensor Configuration
RPT 136—Diagnostic Pressure
RPT 140—Rear PTO Hours
RPT 141—Rear PTO Number of Engagements
RPT 142—Rear PTO Number of Overpower Shutdowns
RPT 143—Rear PTO Average Power
RPT 148—Factory Use Only
RPT 149—Rear PTO Data Mode Min Temp
RPT 150—Rear PTO Data Mode Max Temp
Selective Control Valve Control Unit (SCC) Configuration and Calibration
SCC 001—Control Unit Stored Codes
SCC 002—System Beep Mode
SCC 003—Control Unit Switched Supply Voltage
SCC 004—Control Unit Unswitched Supply Voltage
SCC 005—Valve Power 1 Voltage
SCC 006—Valve Power 2 Voltage
SCC 007—Valve Power 3 Voltage
SCC 008—Valve Power 4 Voltage
SCC 010—SCV I—IX Presence
SCC 011—SCV I Status
SCC 012—SCV I Valve Command
SCC 013—SCV I Flow Estimate
SCC 014—SCV I Max Flow Rate Extend Setting
SCC 015—SCV I Max Flow Rate Retract Setting
SCC 016—SCV I Extend Detent Time
SCC 017—SCV I Retract Detent Time
SCC 018—SCV I Settings
SCC 019—SCV I Quick Raise/Lower Function Configuration
SCC 020—SCV Configuration
SCC 021—SCV II Status
SCC 022—SCV II Valve Command
SCC 023—SCV II Flow Estimate
SCC 024—SCV II Max Flow Rate Extend Setting
SCC 025—SCV II Max Flow Rate Retract Setting
SCC 026—SCV II Extend Detent Time
SCC 027—SCV II Retract Detent Time
SCC 028—SCV II Settings
SCC 029—SCV II Quick Raise/Lower Function Configuration
SCC 030—SCV Lock Status
SCC 031—SCV III Status
SCC 032—SCV III Valve Command
SCC 033—SCV III Flow Estimate
SCC 034—SCV III Max Flow Rate Extend Setting
SCC 035—SCV III Max Flow Rate Retract Setting
SCC 036—SCV III Extend Detent Time
SCC 037—SCV III Retract Detent Time
SCC 038—SCV III Settings
SCC 039—SCV III Quick Raise/Lower Function Configuration
SCC 040—SCV Lever Status
SCC 041—SCV IV Status
SCC 042—SCV IV Valve Command
SCC 043—SCV IV Flow Estimate
SCC 044—SCV IV Max Flow Rate Extend Setting
SCC 045—SCV IV Max Flow Rate Retract Setting
SCC 046—SCV IV Extend Detent Time
SCC 047—SCV IV Retract Detent Time
SCC 048—SCV IV Settings
SCC 049—SCV IV Quick Raise/Lower Function Configuration
SCC 051—SCV V Status
SCC 052—SCV V Valve Command
SCC 053—SCV V Flow Estimate
SCC 054—SCV V Max Flow Rate Extend Setting
SCC 055—SCV V Max Flow Rate Retract Setting
SCC 056—SCV V Extend Detent Time
SCC 057—SCV V Retract Detent Time
SCC 058—SCV V Settings
SCC 059—SCV V Quick Raise/Lower Function
SCC 060—External Switch Status
SCC 061—SCV VI Status
SCC 062—SCV VI Valve Command
SCC 063—SCV VI Flow Estimate
SCC 064—SCV VI Max Flow Rate Extend Setting
SCC 065—SCV VI Max Flow Rate Retract Setting
SCC 066—SCV VI Extend Detent Time
SCC 067—SCV VI Retract Detent Time
SCC 068—SCV VI Settings
SCC 069—SCV VI Quick Raise/Lower Function
SCC 100—SCV X—XIV Presence
SCC 160—Option Jumper Status
SCC 161—Option Connector Pin 1 Voltage
SCC 162—Option Connector Pin 2 Voltage
SCC 163—Option Connector Pin 3 Voltage
SCC 164—Option Connector Pin 4 Voltage
SCC 165—Option Connector Pin 5 Voltage
SCC 166—Option Connector Sensor 5 V Reference Voltage
SCC 167—Hydraulic Oil Level Sensor Status / Voltage (100001— )
SCC 168—Hydraulic Charge Pressure
SCC 169—Hydraulic Charge Pressure Sensor Voltage
SCC 170—Multi-Function Lever Status
SCC 171—Multi-Function Lever Enable Configuration
SCC 172—Multi-Function Lever Left/Right Range
SCC 173—Multi-Function Lever Fore/Aft Range
SCC 174—Multi-Function Lever Trigger Range
SCC 175—Multi-Function Lever Lock
SCC 176—Laser Scraper Setup Mode
SCC 177—SCV Draft Gain Setting
SCC 178—CAN Bus Voltage
Secondary Hydraulic Control Unit (SCO) Configuration and Calibration
SCO 001—Control Unit Stored Codes
SCO 002—System Beep Mode
SCO 003—Control Unit Switched Supply Voltage
SCO 004—Control Unit Unswitched Supply Voltage
SCO 005—Valve Power 1 Voltage
SCO 006—Valve Power 2 Voltage
SCO 007—Valve Power 3 Voltage
SCO 008—Valve Power 4 Voltage
SCO 010—SCV Presence
SCO 020—SCV Configuration/Calibration
SCO 030—SCV Lock Status
SCO 040—Lever Status
SCO 060—External Switch Status
SCO 100—SCV Presence
SCO 101—Front Hitch Status
SCO 102—Front Hitch Valve Command
SCO 103—Front Hitch Flow Estimate
SCO 104—Front Hitch Max Flow Rate Extend Setting
SCO 105—Front Hitch Max Flow Rate Retract Setting
SCO 106—Front Hitch Extend Detent Time
SCO 107—Front Hitch Retract Detent Time
SCO 108—Front Hitch Settings
SCO 109—Front Hitch Quick Raise/Lower Function
SCO 110—Front Hitch Position Sensor Voltage
SCO 141—Front SCV XIV (SVN) Status
SCO 142—Front SCV XIV (SVN) Valve Command
SCO 143—Front SCV XIV (SVN) Flow Estimate
SCO 144—Front SCV XIV (SVN) Max Flow Rate Extend Setting
SCO 145—Front SCV XIV (SVN) Max Flow Rate Retract Setting
SCO 146—Front SCV XIV (SVN) Extend Detent Time
SCO 147—Front SCV XIV (SVN) Retract Detent Time
SCO 148—Front SCV XIV (SVN) Settings
SCO 149—Front SCV XIV (SVN) Quick Raise/Lower Setting
SCO 151—Front SCV XV (SVO) Status
SCO 152—Front SCV XV (SVO) Valve Command
SCO 153—Front SCV XV (SVO) Flow Estimate
SCO 154—Front SCV XV (SVO) Max Flow Rate Extend Setting
SCO 155—Front SCV XV (SVO) Max Flow Rate Retract Setting
SCO 156—Front SCV XV (SVO) Extend Detent Time
SCO 157—Front SCV XV (SVO) Retract Detent Time
SCO 158—Front SCV XV (SVO) Settings
SCO 160—Option Jumper Status
SCO 161—Option Connector Pin 1 Voltage
SCO 162—Option Connector Pin 2 Voltage
SCO 163—Option Connector Pin 3 Voltage
SCO 164—Option Connector Pin 4 Voltage
SCO 165—Option Connector Pin 5 Voltage
SCO 166—Option Connector Sensor 5 V Reference Voltage
SCO 170—Multi-Function Lever Status
SCO 171—Multi-Function Lever Enable Configuration
SCO 172—Multi-Function Lever Left/Right Range
SCO 173—Multi-Function Lever Fore/Aft Range
SCO 174—Multi-Function Lever Trigger Range
SCO 175—Multi-Function Lever Lock Status
SCO 178—CAN Bus Voltage
SCO 179—Loader Mode Configuration
Suspension Control Unit (SFA) Configuration and Calibration
SFA 001—SFA Control Unit Stored Codes
SFA 002—SFA System Beep Mode
SFA 003—Front Suspension Left Position Sensor Voltage
SFA 004—Front Suspension Right Position Sensor Voltage
SFA 007—Front Suspension Pressure Sensor Voltage
SFA 010—SFA Sensor Supply Voltage
SFA 011—Front Suspension Lower Solenoid Supply Voltage
SFA 013—Front Suspension Raise Solenoid Command Current
SFA 014—Front Suspension Lower Solenoid Command Current
SFA 015—Front Suspension Spring Rate Increase Command Current
SFA 016—Front Suspension Spring Rate Decrease Command Current
SFA 017—Front Suspension Dampening ‘A” Solenoid Command Current
SFA 018—Front Suspension Dampening ‘B” Solenoid Command Current
SFA 020—Suspension Calibration
SFA 021—Suspension Draining
SFA 022—Front Suspension Level Set Point Adjustment
SFA 024—Front Suspension Leveling Modes Selection
SFA 025—Front Suspension Manual Positioning
SFA 027—Front Suspension Pressure Adaptation Mode Display
SFA 028—Front Suspension Pressure Adaptation Level
SFA 029—Front Suspension Dampening Mode Selection
SFA 030—Front Suspension Raise Solenoid Current
SFA 031—Front Suspension Lower Solenoid Current
SFA 032—Front Suspension Spring Rate Increase Solenoid Current
SFA 033—Front Suspension Spring Rate Decrease Solenoid Current
SFA 034—Front Suspension Dampening Solenoid ‘A” Current
SFA 035—Front Suspension Dampening Solenoid ‘B” Current
SFA 038—Front Suspension Lower Valve Pull-in Current Adjustment
SFA 039—Front Suspension Lower Valve Hold-in Current Adjustment
SFA 040—Front Suspension Raise Valve Pull-in Current Adjustment
SFA 041—Front Suspension Raise Valve Hold-in Current Adjustment
SFA 042—Front Suspension Spring Rate Increase Valve Pull-in Current Adjustment
SFA 043—Front Suspension Spring Rate Increase Valve Hold-in Current Adjustment
SFA 044—Front Suspension Spring Rate Decrease Valve Pull-in Current Adjustment
SFA 045—Front Suspension Spring Rate Decrease Valve Hold-in Current Adjustment
SFA 046—Front Suspension Dampening Valve Pull-in Current Adjustment
SFA 047—Front Suspension Damping Valve Hold-in Current Adjustment
SFA 048—Front Suspension Deadband On Adjustment
SFA 049—Front Suspension Deadband Off Adjustment when Lowering
SFA 050—Front Suspension Deadband Off Adjustment when Raising
SFA 060—Front Suspension Damping Valve Enable/Disable
SFA 200—251—SFA Control Unit Data
SV1 Configuration and Calibration
SV1 001—Control Unit Stored Codes
SV1 002—System Beep Mode
SV1 011—Supply Voltage
SV1 020—Neutral Position
SV1 021—Limit Command Status
SV1 022—Extend Calibration Curve Shift
SV1 023—Retract Calibration Curve Shift
SV1 030—Spool Position Temperature Compensation/Extend
SV1 031—Spool Position Temperature Compensation/Retract
SV1 033—Raise/Lower Ramp Time ON
SV1 034—Raise/Lower Ramp Time OFF
SV1 040—Spool Shake Mode
SV1 050—Command Source Configuration
SV1 051—OBE Assignment Configuration
SV1 180—Current Active Internal Fault Code
SV1 181—186—Factory Use Only
SV1 190—191—Factory Use Only
SV2 Configuration and Calibration
SV2 001—Control Unit Stored Codes
SV2 002—System Beep Mode
SV2 011—Supply Voltage
SV2 020—Neutral Position
SV2 021—Limit Command Status
SV2 022—Extend Calibration Curve Shift
SV2 023—Retract Calibration Curve Shift
SV2 030—Spool Position Temperature Compensation/Extend
SV2 031—Spool Position Temperature Compensation/Retract
SV2 033—Raise/Lower Ramp Time ON
SV2 034—Raise/Lower Ramp Time Off
SV2 040—Spool Shake Mode
SV2 050—Command Source Configuration
SV2 051—OBE Assignment Configuration
SV2 180—Current Active Internal Fault Code
SV2 181—186—Factory Use Only
SV2 190—191—Factory Use Only
SV3 Configuration and Calibration
SV3 001—Control Unit Stored Codes
SV3 002—System Beep Mode
SV3 011—Supply Voltage
SV3 020—Neutral Position
SV3 021—Limit Command Status
SV3 022—Extend Calibration Curve Shift
SV3 023—Retract Calibration Curve Shift
SV3 030—Spool Position Temperature Compensation/Extend
SV3 031—Spool Position Temperature Compensation/Retract
SV3 033—Raise/Lower Ramp Time ON
SV3 034—Raise/Lower Ramp Time OFF
SV3 040—Spool Shake Mode
SV3 050—Command Source Configuration
SV3 051—OBE Assignment Configuration
SV3 180—Current Active Internal Fault Code
SV3 181—186—Factory Use Only
SV3 190—191—Factory Use Only
SV4 Configuration and Calibration
SV4 001—Control Unit Stored Codes
SV4 002—System Beep Mode
SV4 011—Supply Voltage
SV4 020—Neutral Position
SV4 021—Limit Command Status
SV4 022—Extend Calibration Curve Shift
SV4 023—Retract Calibration Curve Shift
SV4 030—Spool Position Temperature Compensation/Extend
SV4 031—Spool Position Temperature Compensation/Retract
SV4 033—Raise/Lower Ramp Time ON
SV4 034—Raise/Lower Ramp Time OFF
SV4 040—Spool Shake Mode
SV4 050—Command Source Configuration
SV4 051—OBE Assignment Configuration
SV4 180—Current Active Internal Fault Code
SV4 181—186—Factory Use Only
SV4 190—191—Factory Use Only
SV5 Configuration and Calibration
SV5 001—Control Unit Stored Codes
SV5 002—System Beep Mode
SV5 011—Supply Voltage
SV5 020—Neutral Position
SV5 021—Limit Command Status
SV5 022—Extend Calibration Curve Shift
SV5 023—Retract Calibration Curve Shift
SV5 030—Spool Position Temperature Compensation/Extend
SV5 031—Spool Position Temperature Compensation/Retract
SV5 033—Raise/Lower Ramp Time ON
SV5 034—Raise/Lower Ramp Time OFF
SV5 040—Spool Shake Mode
SV5 050—Command Source Configuration
SV5 051—OBE Assignment Configuration
SV5 180—Current Active Internal Fault Code
SV5 181—186—Factory Use Only
SV5 190—191—Factory Use Only
SV6 Configuration and Calibration
SV6 001—Control Unit Stored Codes
SV6 002—System Beep Mode
SV6 011—Supply Voltage
SV6 020—Neutral Position
SV6 021—Limit Command Status
SV6 022—Extend Calibration Curve Shift
SV6 023—Retract Calibration Curve Shift
SV6 030—Spool Position Temperature Compensation/Extend
SV6 031—Spool Position Temperature Compensation/Retract
SV6 033—Raise/Lower Ramp Time ON
SV6 034—Raise/Lower Ramp Time OFF
SV6 040—Spool Shake Mode
SV6 050—Command Source Configuration
SV6 051—OBE Assignment Configuration
SV6 180—Current Active Internal Fault Code
SV6 181—186—Factory Use Only
SV6 190—191—Factory Use Only
SVJ Configuration and Calibration
SVJ 001—Control Unit Stored Codes
SVJ 002—System Beep Mode
SVJ 011—Supply Voltage
SVJ 025—Enable/Disable Pressure Message
SVJ 026—Enable/Disable Pressure Measurement
SVJ 030—Spool Position Temperature Compensation/Extend
SVJ 031—Spool Position Temperature Compensation/Retract
SVJ 033—Raise/Lower Ramp Time ON
SVJ 034—Raise/Lower Ramp Time OFF
SVJ 180—186—Factory Use Only
SVJ 190—191—Factory Use Only
SVN Configuration and Calibration
SVN 001—Control Unit Stored Codes
SVN 002—System Beep Mode
SVN 011—Supply Voltage
SVN 025—Enable/Disable Pressure Message
SVN 026—Enable/Disable Pressure Measurement
SVN 030—Spool Position Temperature Compensation/Extend
SVN 031—Spool Position Temperature Compensation/Retract
SVN 033—Raise/Lower Ramp Time ON
SVN 034—Raise/Lower Ramp Time OFF
SVN 180—186—Factory Use Only
SVN 190—191—Factory Use Only
SVO Configuration and Calibration
SVO 001—Control Unit Stored Codes
SVO 002—System Beep Mode
SVO 011—Supply Voltage
SVO 025—Enable/Disable Pressure Message
SVO 026—Enable/Disable Pressure Measurement
SVO 030—Spool Position Temperature Compensation/Extend
SVO 031—Spool Position Temperature Compensation/Retract
SVO 033—Raise/Lower Ramp Time ON
SVO 034—Raise/Lower Ramp Time OFF
SVO 180—186—Factory Use Only
SVO 190—191—Factory Use Only
TEI - Tractor Equipment Control Software Addresses (TEC/TEI)
Tractor Equipment Control Unit (TEC/TEI) Configuration and Calibration
TEC/TEI 001—TEC/TEI Control Unit Stored Codes
TEC/TEI 002—TEC/TEI System Beep Mode
TEC/TEI 005—Vehicle CAN Bus Low Voltage
TEC/TEI 006—Vehicle CAN Bus High Voltage
TEC/TEI 007—Implement CAN Bus Low Voltage
TEC/TEI 008—Implement CAN Bus High Voltage
TEC/TEI 009—Switched Power (ELX) Voltage
TEC/TEI 031—Implement Work Light 1
TEC/TEI 032—Implement Work Light 2
TEC/TEI 033—Implement Work Light 3
TEC/TEI 034—Implement Work Light 4
TEC/TEI 050—Steering Control Identification
TEC/TEI 051—SCV I Control Identification
TEC/TEI 052—SCV II Control Identification
TEC/TEI 053—SCV III Control Identification
TEC/TEI 054—SCV IV Control Identification
TEC/TEI 055—SCV V Control Identification
TEC/TEI 056—SCV VI Control Identification
TEC/TEI 057—SCV VII Control Identification
TEC/TEI 058—SCV VIII Control Identification
TEC/TEI 059—SCV IX Control Identification
TEC/TEI 060—SCV X Control Identification
TEC/TEI 061—SCV XI Control Identification
TEC/TEI 062—SCV XII Control Identification
TEC/TEI 063—SCV XIII Control Identification
TEC/TEI 064—SCV XIV Control Identification
TEC/TEI 065—SCV XV Control Identification
TEC/TEI 066—SCV XVI Control Identification
TEC/TEI 067—Vehicle Speed Identification
TEC/TEI 068—MFWD Control Identification
TEC/TEI 069—Difflock Control Identification
TEC/TEI 070—Front Hitch Control Identification
TEC/TEI 071—Rear Hitch Control Identification
TEC/TEI 072—Front PTO Control Identification
TEC/TEI 073—Rear PTO Control Identification
TEC/TEI 074—APS Resume Control Identification
TEC/TEI 075—Vehicle Gear Control Identification
TEC/TEI 076—Field Cruise Control Identification
TEC/TEI 077—Drive Strategy Control Identification
AutoPowr / IVT Transmission Shift Control Software Addresses (TII)
AutoPowr™ / IVT™ Transmission Shift Control Unit (TII) Configuration and Calibration
TII 001—Recall Diagnostic Trouble Codes
TII 002—TII System Beep Mode
TII 040—Commanded Direction Status
TII 042—Wheel Dynamic Rolling Radius
TII 051—Reverse Lever Configuration
TII 052—Vehicle Configuration
TII 053—Vehicle Speed Limit Dealer
TII 054—Vehicle Speed Limit Max
TII 055—Tire Group Size
TII 057—Suspension Configuration Status
TII 059—Auto Mode Configuration
TII 063—IVT Mode Configuration
TII 071—Vehicle Automation Exit Reason
TII 077—Auto-Clutch Disabling Configuration
TII 088—Manually Override Acceleration Settings
TII 099—Service Advisor Access
TII 100—Load Control Fuel Economy Transition
TII 111—Set Speed Pop-Up on Secondary Display
Powershift Transmission Shift Control Software Addresses (TIP)
Powershift Transmission Shift Control Software (TIP) Calibration and Configuration
TIP 000—Device ID Address
TIP 001—Recall Diagnostic Trouble Codes
TIP 002—System Beep Mode
TIP 029—SoftShift Configuration
TIP 030—Factory Use Only
TIP 031—Factory Use Only
TIP 032—Factory Use Only
TIP 033—Factory Use Only
TIP 034—Factory Use Only
TIP 035—Factory Use Only
TIP 036—Factory Use Only
TIP 037—Factory Use Only
TIP 042—Wheel Dynamic Rolling Radius
TIP 053—Vehicle Speed Limit Configuration
TIP 054—Maximum Vehicle Speed Configuration
TIP 059—Auto Mode Configuration
TIP 077—Auto Clutch Configuration
TIP 099—Service Advisor Access
TIP 111—Set Speed Pop-Up Configuration
TIP 160—Factory Use Only
TIP 184—Factory Use Only
TIP 200—251—Control Unit General Data
Vehicle Load Center Control Software Addresses (VLC)
Vehicle Load Center (VLC) Configuration and Calibration
VLC 001—Control Unit Stored Codes
VLC 002—VLC System Beep Mode
VLC 015—Wake Up Signal Status
VLC 020—Left High Beam Light
VLC 021—Right High Beam Light
VLC 022—Left Low Beam Light
VLC 023—Right Low Beam Light
VLC 024—Left Front Outer Flood Light
VLC 025—Right Front Outer Flood Light
VLC 026—Left Front Inner Flood Light
VLC 027—Right Front Inner Flood Light
VLC 036—Front Washer Pump
VLC 037—Rear Washer Pump
VLC 038—Right Window Washer Pump
VLC 045—VLC Total Current
VLC 046—VLC Unswitched Supply Voltage
VLC 047—Flasher Sync Input Status
VLC 048—Left Trailer Turn Signal
VLC 049—Right Trailer Turn Signal
VLC 050—Vehicle Type
VLC 051—Turn Signal and Washer Configuration
VLC 060—Work Light Shut Down Time
VLC 099—Maximum Control Unit Board Temperature Ever Recorded
VLC 102—Percent of Time Control Unit Temperature was Below -40 °C
VLC 103—Percent of Time Control Unit Temperature was Between -39 °C and 24 °C
VLC 104—Percent of Time Control Unit Temperature was Between 25 °C and 50 °C
VLC 105—Percent of Time Control Unit Temperature was Between 51 °C and 69 °C
VLC 106—Percent of Time Control Unit Temperature was Between 70 °C and 84 °C
VLC 107—Percent of Time Control Unit Temperature was Between 85 °C and 104 °C
VLC 108—Percent of Time Control Unit Temperature was Above 105 °C
VLC 120—Maximum Control Unit Current Output
VLC 121—Voltage of Maximum Control Unit Current Output
Virtual Terminal Implement Control Software Addresses (VTI)
COMMANDCENTER™ (VTI) Control Unit Configuration and Calibration
VTI 001—VTI Control Unit Stored Codes
VTI 002—System Beep Mode
VTI 003—VTI System Beep Mode Without Speed Sensors
VTI 008—VTI Unswitched Power Supply Voltage
VTI 009—VTI Switched Power Supply Voltage
VTI 010—COMMANDCENTER™ Internal Temperature
VTI 011—Vehicle CAN Bus Status
VTI 012—Vehicle CAN High Voltage Status
VTI 013—Vehicle CAN Low Voltage Status
VTI 015—Implement CAN Bus Status
VTI 016—Implement CAN High Voltage Status
VTI 017—Implement CAN Low Voltage Status
VTI 018—Flash Wear Count
VTI 019—Hours of Operation
VTI 032—Real Time Clock Status
VTI 033—Maximum Sleep Time
VTI 035—Flash Drive Status
VTI 036—Maximum Number of Warm Boots
VTI 038—Brightness Synchronization
VTI 039—Daytime Luminance
VTI 040—Daytime Luminance Balance Ratio
VTI 041—Nighttime Luminance
VTI 042—Nighttime Luminance Balance Ratio
VTI 043—Internal Speaker Volume
VTI 045—Country Code Settings
VTI 046—Language Code Setting
VTI 047—Numeric Format Setting
VTI 048—Date Format Setting
VTI 049—Time Format Setting
VTI 050—Units of Distance Settings
VTI 051—Units of Area Settings
VTI 052—Units of Volume Settings
VTI 053—Units of Mass Settings
VTI 054—Units of Temperature Settings
VTI 055—Units of Pressure Settings
VTI 056—Units of Force Settings
VTI 057—GPS Time Sync Option
VTI 058—Current Date Setting
VTI 059—Current Time Setting
VTI 061—UIM Accepts Global Messages
VTI 062—Access Manager Password
VTI 072—Tractor Bus Function Instance Configuration
Virtual Terminal Vehicle Control Software Addresses (VTV)
COMMANDCENTER™ (VTV) Control Unit Configuration and Calibration
VTV 001—Control Unit Stored Codes
VTV 008—VTV Unswitched Power Supply Voltage
VTV 009—VTV Switched Power Supply Voltage
VTV 010—CommandCenter™ Internal Temperature
VTV 012—Vehicle CAN High Voltage Status
VTV 013—Vehicle CAN Low Voltage Status
VTV 016—Implement CAN High Voltage Status
VTV 017—Implement CAN Low Voltage Status
VTV 019—Hours of Operation
VTV 027—Factory Use Only
VTV 033—Maximum Sleep Time
VTV 036—Maximum Number of Warm Boots
VTV 045—Country Code Settings
VTV 046—Language Code Setting
VTV 062—Factory Use Only
VTV 063—Display Configurator
ActiveCommand Steering (ACS) A-Box Main Control Software Addresses (XMA)
Steering System Unit (XMA) Configuration and Calibration
XMA 000—Initial Address
XMA 001—XMA Control Unit Stored Codes
XMA 002—XMA System Beep Mode
XMA 003—Control Unit Unswitched Supply Voltage Status
XMA 004—Control Unit Switched Supply Voltage Status
XMA 005—Sensor Supply 1 Voltage Status
XMA 006—Sensor Supply 2 Voltage Status
XMA 007—Sensor Supply 3 Voltage Status
XMA 008—Sensor Supply 4 Voltage Status
XMA 009—Watchdog 5V Regulator Voltage Status
XMA 010—Valve Power 1 Supply Voltage Status
XMA 011—Valve Power 2 Supply Voltage Status
XMA 012—Valve Power 3 Supply Voltage Status
XMA 014—ActiveCommand Steering CAN Bus High Voltage Status
XMA 015—ActiveCommand Steering CAN Bus Low Voltage Status
XMA 016—Handshaking Duty Cycle From XMB Status
XMA 017—Handshaking Duty Cycle From XSB Status
XMA 018—Handshaking Frequency From XMB Status
XMA 019—Handshaking Frequency From XSB Status
XMA 021—Front Brake Calibration
XMA 023—Air Trailer Pre-Brake Calibration
XMA 025—Air Trailer Pre-Brake Adjustment
XMA 030—Steering Wheel Module Position Address Display Format
XMA 031—Steering Wheel Module Position Sensor 1 Status
XMA 032—Steering Wheel Module Position Sensor 2 Status
XMA 033—Steering Wheel Module Position Sensor 3 Status
XMA 034—Steering Wheel Module Position Sensor 4 Status
XMA 035—Steering Wheel Module Position and Status
XMA 036—Wheel Angle Address Display Format
XMA 037—Left Wheel Angle Sensor (Primary) Status
XMA 038—Left Wheel Angle Sensor (Secondary) Status
XMA 039—Right Wheel Angle Sensor (Primary) Status
XMA 040—Right Wheel Angle Sensor (Secondary) Status
XMA 041—Wheel Angle Steering Stops
XMA 042—Wheel Angle and Status
XMA 052—Proportional Solenoid Address Display Format
XMA 053—Steer Left Solenoid 1 Status
XMA 054—Steer Right Solenoid 1 Status
XMA 056—Air Trailer Pre-Brake Solenoid Status
XMA 058—Front Brake Solenoid Status
XMA 061—Steer Left and Right Valve Position Sensor Address Display Format
XMA 062—Steer Left Valve 1 Position Sensor Status
XMA 063—Steer Right Valve 1 Position Sensor Status
XMA 130—Pressure Sensor Address Display Format
XMA 134—Left Rear Brake Pressure Sensor Status
XMA 136—Right Rear Brake Pressure Sensor Status
XMA 138—Front Brake Pressure Sensor Status
XMA 140—Air Trailer Pre-Brake Pressure Sensor Status
XMA 150—Control Unit Configuration
XMA 153—Brake Pedal Status
XMA 155—Switched Power Status
XMA 156—Engine Information
XMA 157—Harness ID Status
XMA 158—Operator Presence Status
XMA 159—Steering Oil Temperature
XMA 160—Transmission Information
XMA 161—GPS-based Vehicle Speed
XMA 162—Buffered Wheel Speed
XMA 163—Wheel-based Vehicle Speed
XMA 164—Vehicle Stopped State
XMA 165—Gyroscope Sensor Address Display Format
XMA 166—Gyroscope Sensor Status
XMA 167—GreenStar™ Yaw Rate
XMA 168—Steering Control Mode
XMA 169—Front Braking Control Mode
XMA 171—Air Trailer Pre-Braking Control Mode
XMA 172—Auxiliary Steering Exit Code
XMA 185—GreenStar™ Lateral Error
XMA 186—GreenStar™ Heading Error
XMA 187—GreenStar™ Curvature
XMA 188—AutoTrac™ Lateral Integrator
XMA 189—AutoTrac™ Information
XMA 190—AutoTrac™ Exit Code
XMA 191—AutoTrac™ Hours
XMA 192—GPS-based Wheel Slip
ActiveCommand Steering (ACS) B-Box Main Control Software Addresses (XMB)
Steering System Unit (XMB) Configuration and Calibration
XMB 000—Initial Address
XMB 001—XMB Control Unit Stored Codes
XMB 002—XMB System Beep Mode
XMB 003—Control Unit Unswitched Supply Voltage Status
XMB 004—Control Unit Switched Supply Voltage Status
XMB 005—Sensor Supply 1 Voltage Status
XMB 006—Sensor Supply 2 Voltage Status
XMB 007—Sensor Supply 3 Voltage Status
XMB 008—Sensor Supply 4 Voltage Status
XMB 009—Watchdog 5V Regulator Voltage Status
XMB 010—Valve Power 1 Supply Voltage Status
XMB 011—Valve Power 2 Supply Voltage Status
XMB 012—Valve Power 3 Supply Voltage Status
XMB 014—ActiveCommand Steering CAN Bus High Voltage Status
XMB 015—ActiveCommand Steering CAN Bus Low Voltage Status
XMB 016—Handshaking Duty Cycle From XMA Status
XMB 017—Handshaking Duty Cycle From XSA Status
XMB 018—Handshaking Frequency From XMA Status
XMB 019—Handshaking Frequency From XSA Status
XMB 020—Steering Wheel Brake Calibration
XMB 021—Steering Wheel Brake Adjustment
XMB 022—Secondary Brake Calibration
XMB 024—Brake Pedals Calibration
XMB 030—Steering Wheel Module Position Address Display Format
XMB 031—Steering Wheel Module Position Sensor 1 Status
XMB 032—Steering Wheel Module Position Sensor 2 Status
XMB 033—Steering Wheel Module Position Sensor 3 Status
XMB 034—Steering Wheel Module Position Sensor 4 Status
XMB 035—Steering Wheel Position and Status
XMB 036—Wheel Angle Address Display Format
XMB 037—Left Wheel Angle Sensor (Primary) Status
XMB 038—Left Wheel Angle Sensor (Secondary) Status
XMB 039—Right Wheel Angle Sensor (Primary) Status
XMB 040—Right Wheel Angle Sensor (Secondary) Status
XMB 041—Wheel Angle Steering Stops
XMB 042—Wheel Angle and Status
XMB 052—Proportional Solenoid Address Display Format
XMB 053—Steer Left Solenoid 2 Status
XMB 054—Steer Right Solenoid 2 Status
XMB 055—Secondary Brake Solenoid Status
XMB 058—Steering Wheel Brake Solenoid Status
XMB 061—Steer Left and Right Valve Position Sensor Address Display Format
XMB 062—Steer Left Valve 2 Position Sensor Status
XMB 063—Steer Right Valve 2 Position Sensor Status
XMB 064—Secondary Brake Lever Address Display Format
XMB 065—Secondary Brake Lever Sensor 1 Status
XMB 066—Secondary Brake Lever Sensor 2 Status
XMB 068—Secondary Brake Lever Position and Status
XMB 075—Brake Pedal Position Sensors Address Display Format
XMB 076—Left Brake Pedal Position Sensor Status
XMB 077—Right Brake Pedal Position Sensor Status
XMB 080—Brake Pedal Switch Address Display Format
XMB 081—Left Brake Pedal Switch Status
XMB 082—Right Brake Pedal Switch Status
XMB 128—Backup Hydraulic Pump Pressure Status
XMB 129—Main Hydraulic Pump Pressure Status
XMB 130—Pressure Sensor Address Display Format
XMB 131—Main Hydraulic Pump Pressure Sensor 1 Status
XMB 132—Main Hydraulic Pump Pressure Sensor 2 Status
XMB 133—Backup Hydraulic Pump Pressure Sensor Status
XMB 134—Left Rear Brake Pressure Sensor Status
XMB 136—Right Rear Brake Pressure Sensor Status
XMB 139—Secondary Brake Pressure Sensor Status
XMB 150—Control Unit Configuration
XMB 153—Brake Pedal Status
XMB 155—Switched Power Status
XMB 156—Engine Information
XMB 157—Harness ID Status
XMB 158—Operator Presence Status
XMB 159—Steering Oil Temperature
XMB 160—Transmission Information
XMB 161—GPS-based Vehicle Speed
XMB 162—Buffered Wheel Speed
XMB 163—Wheel-based Vehicle Speed
XMB 164—Vehicle Stopped State
XMB 167—GreenStar™ Yaw Rate
XMB 168—Steering Control Mode
XMB 170—Secondary Braking Control Mode
XMB 172—Auxiliary Steering Exit Code
XMB 173—Secondary Brake Exit Code
XMB 185—GreenStar™ Lateral Error
XMB 186—GreenStar™ Heading Error
XMB 187—GreenStar™ Curvature
XMB 188—AutoTrac™ Lateral Integrator
XMB 189—AutoTrac™ Information
XMB 190—AutoTrac™ Exit Code
XMB 191—AutoTrac™ Hours
XMB 192—GPS-based Wheel Slip
AutoTrac Main Control Software Addresses (XMC)
Steering System Unit (XMC) Configuration and Calibration
XMC 000—Initial Address
XMC 001—XMC Control Unit Stored Codes
XMC 002—XMC System Beep Mode
XMC 003—Control Unit Unswitched Supply Voltage Status
XMC 004—Control Unit Switched Supply Voltage Status
XMC 005—Sensor Supply 1 Voltage Status
XMC 006—Sensor Supply 2 Voltage Status
XMC 007—Sensor Supply 3 Voltage Status
XMC 008—Sensor Supply 4 Voltage Status
XMC 009—Watchdog 5V Regulator Voltage Status
XMC 010—Valve Power 1 Supply Voltage Status
XMC 011—Valve Power 2 Supply Voltage Status
XMC 012—Valve Power 3 Supply Voltage Status
XMC 013—Valve Power 4 Supply Voltage Status
XMC 014—Steering CAN Bus High Voltage Status
XMC 015—Steering CAN Bus Low Voltage Status
XMC 021—Front Brake Calibration
XMC 022—Secondary Brake Calibration
XMC 023—Air Trailer Pre-Brake Calibration
XMC 024—Brake Pedals Calibration
XMC 025—Air Trailer Pre-Brake Adjustment
XMC 030—Steering Wheel Position Address Display Format
XMC 031—Steering Wheel Position Sensor 1 Status
XMC 032—Steering Wheel Position Sensor 2 Status
XMC 035—Steering Wheel Position and Status
XMC 036—Wheel Angle Address Display Format
XMC 037—Wheel Angle Sensor (Primary) Status
XMC 038—Wheel Angle Sensor (Secondary) Status
XMC 041—Wheel Angle Steering Stops
XMC 042—Wheel Angle and Status
XMC 052—Proportional Solenoid Address Display Format
XMC 053—Steer Left Solenoid Status
XMC 054—Steer Right Solenoid Status
XMC 055—Secondary Brake Solenoid Status
XMC 056—Air Trailer Pre-Brake Solenoid Status
XMC 059—Front Brake Solenoid Status
XMC 064—Secondary Brake Lever Address Display Format
XMC 065—Secondary Brake Lever Sensor 1 Status
XMC 066—Secondary Brake Lever Sensor 2 Status
XMC 068—Secondary Brake Lever Position and Status
XMC 075—Brake Pedal Position Sensors Address Display Format
XMC 076—Left Brake Pedal Position Sensor Status
XMC 077—Right Brake Pedal Position Sensor Status
XMC 080—Brake Pedal Switch Address Display Format
XMC 081—Left Brake Pedal Switch Status
XMC 082—Right Brake Pedal Switch Status
XMC 128—Backup Hydraulic Pump Pressure Status
XMC 129—Main Hydraulic Pump Pressure Status
XMC 130—Pressure Sensor Address Display Format
XMC 131—Main Hydraulic Pump Pressure Sensor 1 Status
XMC 132—Main Hydraulic Pump Pressure Sensor 2 Status
XMC 133—Backup Hydraulic Pump Pressure Sensor Status
XMC 134—Left Rear Brake Pressure Sensor Status
XMC 136—Right Rear Brake Pressure Sensor 1 Status
XMC 138—Front Brake Pressure Sensor Status
XMC 139—Secondary Brake Pressure Sensor Status
XMC 140—Air Trailer Pre-Brake Pressure Sensor Status
XMC 150—Control Unit Configuration
XMC 153—Brake Pedal Status
XMC 155—Switched Power Status
XMC 156—Engine Information
XMC 157—Harness ID Status
XMC 158—Operator Presence Status
XMC 159—Steering Oil Temperature
XMC 160—Transmission Information
XMC 161—GPS-based Vehicle Speed
XMC 162—Buffered Wheel Speed
XMC 163—Wheel-based Vehicle Speed
XMC 164—Vehicle Stopped State
XMC 167—GreenStar™ Yaw Rate
XMC 168—Steering Control Mode
XMC 169—Front Braking Control Mode
XMC 170—Secondary Braking Control Mode
XMC 171—Air Trailer Pre-Braking Control Mode
XMC 172—Auxiliary Steering Exit Code
XMC 173—Secondary Brake Exit Code
XMC 185—GreenStar™ Lateral Error
XMC 186—GreenStar™ Heading Error
XMC 187—GreenStar™ Curvature
XMC 188—AutoTrac™ Lateral Integrator
XMC 189—AutoTrac™ Information
XMC 190—AutoTrac™ Exit Code
XMC 191—AutoTrac™ Hours
XMC 192—GPS-based Wheel Slip
ActiveCommand Steering (ACS) A-Box Supervisor Control Software Addresses (XSA)
Steering System Unit (XSA) Configuration and Calibration
XSA 000—Initial Address
XSA 001—XSA Control Unit Stored Codes
XSA 002—XSA System Beep Mode
XSA 003—Control Unit Unswitched Supply Voltage Status
XSA 004—Control Unit Switched Supply Voltage Status
XSA 005—Sensor Supply 1 Voltage Status
XSA 006—Sensor Supply 2 Voltage Status
XSA 007—Sensor Supply 3 Voltage Status
XSA 008—Sensor Supply 4 Voltage Status
XSA 009—Watchdog 5V Regulator Voltage Status
XSA 010—Valve Power 1 Supply Voltage Status
XSA 011—Valve Power 2 Supply Voltage Status
XSA 012—Valve Power 3 Supply Voltage Status
XSA 014—ActiveCommand Steering CAN Bus High Voltage Status
XSA 015—ActiveCommand Steering CAN Bus Low Voltage Status
XSA 016—Handshaking Duty Cycle From XMB Status
XSA 017—Handshaking Duty Cycle From XSB Status
XSA 018—Handshaking Frequency From XMB Status
XSA 019—Handshaking Frequency From XSB Status
XSA 021—Steering Wheel Module Calibration
XSA 022—Wheel Angle Sensors Calibration
XSA 023—Steering Valve Calibration
XSA 025—ACS Fixed Ratio Enable
XSA 026— Steering Diagnostic Tests
XSA 029—Enable Debug Messages Configuration
XSA 030—Steering Wheel Module Position Address Display Format
XSA 031—Steering Wheel Module Position Sensor 1 Status
XSA 032—Steering Wheel Module Position Sensor 2 Status
XSA 033—Steering Wheel Module Position Sensor 3 Status
XSA 034—Steering Wheel Module Position Sensor 4 Status
XSA 035—Steering Wheel Module Position and Status
XSA 036—Wheel Angle Address Display Format
XSA 037—Left Wheel Angle Sensor (Primary) Status
XSA 038—Left Wheel Angle Sensor (Secondary) Status
XSA 039—Right Wheel Angle Sensor (Primary) Status
XSA 040—Right Wheel Angle Sensor (Secondary) Status
XSA 041—Wheel Angle Steering Stops
XSA 042—Wheel Angle and Status
XSA 043—Enable Solenoid Address Display Format
XSA 044—Air Trailer Pre-Brake Enable Solenoid Status
XSA 046—Steer Enable 1 Solenoid Status
XSA 049—Front Brake Enable Solenoid Status
XSA 052—Proportional Solenoid Address Display Format
XSA 053—Steer Left Solenoid 1 Status
XSA 054—Steer Right Solenoid 1 Status
XSA 056—Air Trailer Pre-Brake Solenoid Status
XSA 058—Front Brake Solenoid Status
XSA 061—Steer Left and Right Position Sensor Address Display Format
XSA 062—Steer Left Valve 1 Position Sensor Status
XSA 063—Steer Right Valve 1 Position Sensor Status
XSA 130—Pressure Sensor Address Display Format
XSA 134—Left Rear Brake Pressure Sensor Status
XSA 136—Right Rear Brake Pressure Sensor Status
XSA 138—Front Brake Pressure Sensor Status
XSA 140—Air Trailer Pre-Brake Pressure Sensor Status
XSA 150—Control Unit Configuration
XSA 153—Brake Pedal Status
XSA 155—Switched Power Status
XSA 156—Engine Information
XSA 157—Harness ID Status
XSA 158—Operator Presence Status
XSA 159—Steering Oil Temperature
XSA 160—Transmission Information
XSA 161—GPS-based Vehicle Speed
XSA 162—Buffered Wheel Speed
XSA 163—Wheel-based Vehicle Speed
XSA 164—Vehicle Stopped State
XSA 165—Gyroscope Sensor Address Display Format
XSA 166—Gyroscope Sensor Status
XSA 167—GreenStar™ Yaw Rate
XSA 168—Steering Control Mode
XSA 169—Front Braking Control Mode
XSA 171—Air Trailer Pre-Braking Control Mode
XSA 172—Auxiliary Steering Exit Code
XSA 178—AutoTrac™ Valve Deadband Offset
XSA 180—AutoTrac™ Faster Speed Threshold
XSA 181—AutoTrac™ Slower Speed Threshold
XSA 185—GreenStar™ Lateral Error
XSA 186—GreenStar™ Heading Error
XSA 187—GreenStar™ Curvature
XSA 188—AutoTrac™ Lateral Integrator
XSA 189—AutoTrac™ Information
XSA 190—AutoTrac™ Exit Code
XSA 191—AutoTrac™ Hours
XSA 192—GPS-based Wheel Slip
XSA 193—AutoTrac™ Sensitivity
XSA 194—AutoTrac™ Heading Lead
XSA 195—AutoTrac™ Heading Gain
XSA 196—AutoTrac™ Curve Sensitivity
XSA 197—AutoTrac™ Acquisition Sensitivity
XSA 198—AutoTrac™ Lateral Gain
XSA 199—AutoTrac™ Inner Loop Scale Factor
ActiveCommand Steering (ACS) B-Box Supervisor Control Software Addresses (XSB)
Steering System Unit (XSB) Configuration and Calibration
XSB 000—Initial Address
XSB 001—XSB Control Unit Stored Codes
XSB 002—XSB System Beep Mode
XSB 003—Control Unit Unswitched Supply Voltage Status
XSB 004—Control Unit Switched Supply Voltage Status
XSB 005—Sensor Supply 1 Voltage Status
XSB 006—Sensor Supply 2 Voltage Status
XSB 007—Sensor Supply 3 Voltage Status
XSB 008—Sensor Supply 4 voltage Status
XSB 009—Watchdog 5V Regulator Voltage Status
XSB 010—Valve Power 1 Supply Voltage Status
XSB 011—Valve Power 2 Supply Voltage Status
XSB 012—Valve Power 3 Supply Voltage Status
XSB 014—ActiveCommand Steering CAN Bus High Voltage Status
XSB 015—ActiveCommand Steering CAN Bus Low Voltage Status
XSB 016—Handshaking Duty Cycle From XMA Status
XSB 017—Handshaking Duty Cycle From XSA Status
XSB 018—Handshaking Frequency From XMA Status
XSB 019—Handshaking Frequency From XSA Status
XSB 025—Tow Mode Enable Configuration
XSB 030—Steering Wheel Module Position Address Display Format
XSB 031—Steering Wheel Module Position Sensor 1 Status
XSB 032—Steering Wheel Module Position Sensor 2 Status
XSB 033—Steering Wheel Module Position Sensor 3 Status
XSB 034—Steering Wheel Module Position Sensor 4 Status
XSB 035—Steering Wheel Module Position and Status
XSB 036—Wheel Angle Address Display Format
XSB 037—Left Wheel Angle Sensor (Primary) Status
XSB 038—Left Wheel Angle Sensor (Secondary) Status
XSB 039—Right Wheel Angle Sensor (Primary) Status
XSB 040—Right Wheel Angle Sensor (Secondary) Status
XSB 041—Wheel Angle Steering Stops
XSB 042—Wheel Angle and Status
XSB 043—Enable Solenoid Address Display Format
XSB 046—Steer Enable 2 Solenoid Status
XSB 047—Secondary Brake Enable Solenoid Status
XSB 048—Alternator/Battery Relay Status
XSB 049—Backup Hydraulic Pump Motor Relay Status
XSB 052—Proportional Solenoid Address Display Format
XSB 053—Steer Left Solenoid 2 Status
XSB 054—Steer Right Solenoid 2 Status
XSB 055—Secondary Brake Solenoid Status
XSB 061—Steer Left and Right Valve Position Sensor Address Display Format
XSB 062—Steer Left Valve 2 Position Sensor Status
XSB 063—Steer Right Valve 2 Position Sensor Status
XSB 064—Secondary Brake Lever Address Display Format
XSB 065—Secondary Brake Lever Sensor 1 Status
XSB 066—Secondary Brake Lever Sensor 2 Status
XSB 068—Secondary Brake Lever Position and Status
XSB 075—Brake Pedal Position Sensors Address Display Format
XSB 076—Left Brake Pedal Position Sensor Status
XSB 077—Right Brake Pedal Position Sensor Status
XSB 080—Brake Pedal Switch Address Display Format
XSB 081—Left Brake Pedal Switch Status
XSB 082—Right Brake Pedal Switch Status
XSB 128—Backup Hydraulic Pump Pressure Status
XSB 129—Main Hydraulic Pump Pressure Status
XSB 130—Pressure Sensor Address Display Format
XSB 131—Main Hydraulic Pump Pressure Sensor 1 Status
XSB 132—Main Hydraulic Pump Pressure Sensor 2 Status
XSB 133—Backup Hydraulic Pump Pressure Sensor Status
XSB 134—Left Rear Brake Pressure Sensor Status
XSB 136—Right Rear Brake Pressure Sensor Status
XSB 139—Secondary Brake Pressure Sensor Status
XSB 150—Control Unit Configuration
XSB 153—Brake Pedal Status
XSB 155—Switched Power Status
XSB 156—Engine Information
XSB 157—Harness ID Status
XSB 158—Operator Presence Status
XSB 159—Steering Oil Temperature
XSB 160—Transmission Information
XSB 161—GPS-based Vehicle Speed
XSB 162—Buffered Wheel Speed
XSB 163—Wheel-based Vehicle Speed
XSB 164—Vehicle Stopped State
XSB 167—GreenStar™ Yaw Rate
XSB 168—Steering Control Mode
XSB 170—Secondary Braking Control Mode
XSB 172—Auxiliary Steering Exit Code
XSB 185—GreenStar™ Lateral Error
XSB 186—GreenStar™ Heading Error
XSB 187—GreenStar™ Curvature
XSB 188—AutoTrac™ Lateral Integrator
XSB 189—AutoTrac™ Information
XSB 190—AutoTrac™ Exit Code
XSB 191—AutoTrac™ Hours
XSB 192—GPS-based Wheel Slip
AutoTrac Supervisor Control Software Addresses (XSC)
Steering System Unit (XSC) Configuration and Calibration
XSC 000—Initial Address
XSC 001—XSC Control Unit Stored Codes
XSC 002—XSC System Beep Mode
XSC 003—Control Unit Unswitched Supply Voltage Status
XSC 004—Control Unit Switched Supply Voltage Status
XSC 005—Sensor Supply 1 Voltage Status
XSC 006—Sensor Supply 2 Voltage Status
XSC 007—Sensor Supply 3 Voltage Status
XSC 008—Sensor Supply 4 Voltage Status
XSC 009—Watchdog 5V Regulator Voltage Status
XSC 010—Valve Power 1 Supply Voltage Status
XSC 011—Valve Power 2 Supply Voltage Status
XSC 012—Valve Power 3 Supply Voltage Status
XSC 013—Valve Power 4 Supply Voltage Status
XSC 014—Steering CAN Bus High Voltage Status
XSC 015—Steering CAN Bus Low Voltage Status
XSC 022—Wheel Angle Sensor Calibration
XSC 023—Steering Valve Calibration
XSC 025—Tow Mode Enable Configuration
XSC 026— Steering Diagnostic Tests
XSC 030—Steering Wheel Position Address Display Format
XSC 031—Steering Wheel Position Sensor 1 Status
XSC 032—Steering Wheel Position Sensor 2 Status
XSC 035—Steering Wheel Position and Status
XSC 036—Wheel Angle Address Display Format
XSC 037—Wheel Angle Sensor (Primary) Status
XSC 038—Wheel Angle Sensor (Secondary) Status
XSC 041—Wheel Angle Steering Stops
XSC 042—Wheel Angle and Status
XSC 043—Enable Solenoid Address Display Format
XSC 044—Air Trailer Pre-Brake Enable Solenoid Status
XSC 046—Steer Enable Solenoid Status
XSC 047—Secondary Brake Enable Solenoid Status
XSC 048—Alternator/Battery Relay Status
XSC 049—Backup Hydraulic Pump Motor Relay Status
XSC 050—Front Brake Enable Solenoid Status
XSC 052—Proportional Solenoid Address Display Format
XSC 053—Steer Left Solenoid Status
XSC 054—Steer Right Solenoid Status
XSC 055—Secondary Brake Solenoid Status
XSC 056—Air Trailer Pre-Brake Solenoid Status
XSC 059—Front Brake Solenoid Status
XSC 064—Secondary Brake Lever Address Display Format
XSC 065—Secondary Brake Lever Sensor 1 Status
XSC 066—Secondary Brake Lever Sensor 2 Status
XSC 068—Secondary Brake Lever Position and Status
XSC 075—Brake Pedal Position Sensors Address Display Format
XSC 076—Left Brake Pedal Position Sensor Status
XSC 077—Right Brake Pedal Position Sensor Status
XSC 080—Brake Pedal Switch Address Display Format
XSC 081—Left Brake Pedal Switch Status
XSC 082—Right Brake Pedal Switch Status
XSC 128—Backup Hydraulic Pump Pressure Status
XSC 129—Main Hydraulic Pump Pressure Status
XSC 130—Pressure Sensor Address Display Format
XSC 131—Main Hydraulic Pump Pressure Sensor 1 Status
XSC 132—Main Hydraulic Pump Pressure Sensor 2 Status
XSC 133—Backup Hydraulic Pump Pressure Sensor Status
XSC 134—Left Rear Brake Pressure Sensor Status
XSC 136—Right Rear Brake Pressure Sensor Status
XSC 138—Front Brake Pressure Sensor Status
XSC 139—Secondary Brake Pressure Sensor Status
XSC 140—Air Trailer Pre-Brake Pressure Sensor Status
XSC 150—Control Unit Configuration
XSC 153—Brake Pedal Status
XSC 155—Switched Power Status
XSC 156—Engine Information
XSC 157—Harness ID Status
XSC 158—Operator Presence Status
XSC 159—Steering Oil Temperature
XSC 160—Transmission Information
XSC 161—GPS-based Vehicle Speed
XSC 162—Buffered Wheel Speed
XSC 163—Wheel-based Vehicle Speed
XSC 164—Vehicle Stopped State
XSC 167—GreenStar™ Yaw Rate
XSC 168—Steering Control Mode
XSC 169—Front Braking Control Mode
XSC 170—Secondary Braking Control Mode
XSC 171—Air Trailer Pre-Braking Control Mode
XSC 172—Auxiliary Steering Exit Code
XSC 178—AutoTrac™ Valve Deadband Offset
XSC 180—AutoTrac™ Faster Speed Threshold
XSC 185—GreenStar™ Lateral Error
XSC 186—GreenStar™ Heading Error
XSC 187—GreenStar™ Curvature
XSC 188—AutoTrac™ Lateral Integrator
XSC 189—AutoTrac™ Information
XSC 190—AutoTrac™ Exit Code
XSC 191—AutoTrac™ Hours
XSC 192—GPS-based Wheel Slip
XSC 193—AutoTrac™ Sensitivity
XSC 194—AutoTrac™ Heading Lead
XSC 195—AutoTrac™ Heading Gain
XSC 196—AutoTrac™ Curve Sensitivity
XSC 197—AutoTrac™ Acquisition Sensitivity
XSC 198—AutoTrac™ Lateral Gain
XSC 199—AutoTrac™ Inner Loop Scale Factor
Electrical Component Information
Electrical Component Information General Information—Summary of References
Electrical Assemblies—Summary of References
Sensors—Summary of References
Condensors/Capacitors—Summary of References
Lights—Summary of References
Fuses—Summary of References
Charging—Summary of Reference
Monitoring Devices—Summary of References
Relays—Summary of References
Motors—Summary of References
Switches—Summary of References
Diodes—Summary of References
Wiring Harnesses—Summary of References
Interconnects—Summary of References
Electronically Actuated Mechanical Devices—Summary of References
A012X1 Armrest Control Unit Connector (12 Pin)
A012X2A Armrest Control Unit Connector (16 Pin)
A012X2B Armrest Control Unit Connector (10 Pin)
A012X3A Armrest Control Unit Connector (12 Pin)
A012X3B Armrest Control Unit Connector (10 Pin)
A012X4 Armrest Control Unit Connector (16 Pin)
A012X5 Armrest Control Unit Connector (10 Pin)
A046 Armrest SCV Lock Module
A047 Armrest Engine Speed Control Module
A048 Armrest Navigation Bar Module
A050 Armrest Front Left Module
A051 Armrest Front Middle Module
A052 Armrest Rear Right Module
A053 Armrest Middle Right Module
A054 Armrest Front Right Module
A057 Armrest Hitch Controls Module
A064 Armrest Multi-Function Lever Module
A065 Armrest Rear Hitch Setup Controls Module
A066 Cab Controls Module
A65 XM Satellite Radio Module
A65X1 SiriusXM® Satellite Radio Module Connector
A85X1 Radio Connector
A85X2 Radio Connector
A85X3 Radio Connector
A85X4 Radio Connector
A100 Implement Power Relay Module
A100X1 Implement Power Relay Module Connector
A100X2 Implement Power Relay Module Connector
A100X3 Implement Power Relay Module Connector
A100X4 Implement Power Relay Module Top Right Terminal
A107X1 Cab Control Unit Connector
A107X2 Cab Control Unit Connector
A107X3 Cab Control Unit Connector
A107X4 Cab Control Unit Connector
A120X2 Roof Control Unit Connector
A120X3 Roof Control Unit Connector
A120X4 Roof Control Unit Connector
A127 Stereo Auxiliary Input
A128 Subwoofer
A129 Premium Processor
A129X1/A133X1 Processor Connector
A129X2 Processor Connector (4600 Processor Only)
A129X4/A133X4 Processor Connector
A129X5 Processor Connector (4600 Processor Only)
A129X6/A133X6 Processor Connector
A129X7/A133X7 Processor Connector
A132 Premium Vehicle Monitor
A133 Value Processor
A134 Satellite Module
A189 Inverter Backlighting Steering Column
A220X1 Automatic Temperature Control Unit (ATC) Connector
A5505X1 Engine Control Unit Connector
A5505X2 Engine Control Unit Connector
A5505X3 Engine Control Unit Connector
A5507 DEF Tank Header Assembly (—114999)
A570X1 Rear Chassis Control Unit Connector
A570X2 Rear Chassis Control Unit Connector
A570X3 Rear Chassis Control Unit Connector
A570X4 Rear Chassis Control Unit Connector
A574 Left-Hand Reverser
A577 Foot Throttle
A578 Clutch Pedal Position Sensor
A580X1 Front Chassis Control Unit Connector
A580X2 Front Chassis Control Unit Connector
A701 Selective Control Valve Unit I (SV1)
A702 Selective Control Valve Unit II (SV2)
A703 Selective Control Valve Unit III (SV3)
A704 Selective Control Valve Unit IV (SV4)
A705 Selective Control Valve Unit V (SV5)
A706 Selective Control Valve Unit VI (SV6)
A710 Front Hitch Selective Control Valve Unit (SVJ)
A714 Front Selective Control Valve Unit XIV (SVN)
A715 Front Selective Control Valve Unit XV (SVO)
A800 Rear Hitch Control Valve Unit (HV1)
A900 Refrigerator Compressor Control Module
A901X1 Generation 4 CommandCenter™ Connector
A903X1 Corner Post Display Connector
A903X2 Corner Post Display Connector (4600 Processor Only)
A908X1 GPS Receiver Connector
A909 ActiveSeat™ Compressor Assembly
A911 Vehicle Cab CAN Bus Terminator
A912 Vehicle Chassis CAN Bus Terminator
A913 Implement CAN Bus Passive Terminator
A914 Implement CAN Bus Active Terminator
A915 Front Implement CAN Bus Passive Terminator
A916 Engine Aftertreatment CAN Bus Terminator
A943X1 Heated Seat Elements Connector
A943X4 Heated Seat Power Connector
A943X5 Heated Seat Switch Connector
A980X1 Steering System Control Unit Connector
A980X2 Steering System Control Unit Connector
A980X3 Steering System Control Unit Connector
A985X1 ActiveCommand Steering A-Box Connector
A985X2 ActiveCommand Steering A-Box Connector
A985X3 ActiveCommand Steering A-Box Connector
A986X1 ActiveCommand Steering B-Box Connector
A986X2 ActiveCommand Steering B-Box Connector
A986X3 ActiveCommand Steering B-Box Connector
A990X2 JDLink™ (MTG) Control Unit Connector
A990X3 JDLink™ (MTG) Control Unit Connector
A990X7 JDLink™ (MTG) Control Unit Connector
Sensors
B068 Speed Control Lever Sensor
B210 Seat Accelerometer Sensor
B212 Right Front Speaker
B213 Left Front Speaker
B214 Right Rear Speaker
B215 Left Rear Speaker
B217 Evaporator Temperature Sensor
B218 Outlet Air Temperature Sensor
B219 Ambient Temperature Sensor
B220 Cab Temperature Sensor
B224 Refrigerant Pressure Sensor
B231 Rear Hitch Draft Sensor
B237 Steering Wheel Position Sensor
B249 Brake Pedal Sensor Module
B252 Left Wheel Angle Sensor
B253 Gyro (ACS™ Only)
B254 Front Brake Pressure Sensor
B255 Right Rear Brake Pressure Sensor
B256 Left Rear Brake Pressure Sensor
B257 Air Trailer Pre-Brake Pressure Sensor
B258 Steering Wheel Module (ACS™)
B259 Secondary Brake Lever Sensor
B260 Secondary Brake Pressure Sensor (Eur Only)
B261 Main Hydraulic Pump Pressure Sensor 1
B262 Main Hydraulic Pump Pressure Sensor 2
B263 Backup Hydraulic Pump Pressure Sensor
B264 Right Wheel Angle Sensor (ACS™ Only)
B304 Front Suspension Left Position Sensor
B305 Front Suspension Right Position Sensor
B306 Front Suspension Pressure Sensor
B308 Cab Suspension Position Sensor
B514 CU Idler Speed Sensor
B515 Carrier Speed Sensor
B516 Transmission Secondary Speed Sensor
B517 Transmission Primary Speed Sensor
B518 Ring Gear 2 Primary Speed Sensor (AutoPowr™/IVT™ Only)
B520 MFWD Speed Sensor (AutoPowr™/IVT™ Only)
B526 Clutch Enable Pressure Sensor
B530 Front PTO Return Oil Pressure Sensor
B531 Front PTO Clutch Pressure Sensor
B532 Front PTO Oil Temperature Sensor
B535 Front Hitch Position Sensor
B537 Front PTO Speed Sensor
B548 Counter Shaft C Speed Sensor (e23™ Only)
B549 Counter Shaft B Speed Sensor (e23™/16 Speed PST)
B552 Hydraulic Oil Filter Restriction Sensor
B555 Hydraulic Oil Level Presence Sensor (100001— )
B640 R2 Clutch Pressure Sensor
B692 Fuel Level Sensor
B694 Hydraulic Oil Temperature Sensor
B696 Rear PTO Speed Sensor
B698 Rear Hitch Position Sensor
B707 Park Brake Pressure Sensor
B717 Hydraulic Charge Pump Pressure Sensor
B718 System 1 Pressure Sensor (AutoPowr™/IVT™) (—100000)
B721 Lube Pressure Sensor (e23™ Only)
B727 System 2 Pressure Sensor (e23™/16 Speed PST)
B760 Steer Left Valve 1 Position Sensor (ACS™)
B761 Steer Right Valve 1 Position Sensor (ACS™)
B762 Steer Left Valve 2 Position Sensor (ACS™)
B763 Steer Right Valve 2 Position Sensor (ACS™)
B900 Refrigerator Thermostat
B921 Radar Sensor
B922 Air Trailer Brake Pressure Sensor
B924 Horn
B941 Seat Position Sensor
B5009 Engine Coolant Loss Sensor
B5010 Engine Coolant Level Sensor
B5109 Diesel Particulate Filter Delta Pressure Sensor
B5111 Air Filter Restriction Sensor
B5204 After Treatment Temperature Module
B5212 Selective Catalyst Reduction Temperature Module
B5303 Fan Speed Sensor
B5501 SCR Supply Module
B5502 Aftertreatment Inlet NOx Sensor
B5503 Aftertreatment Outlet NOx Sensor
B5506 DEF Tank Header Assembly (CAN Based) (115000—)
C910 GPS and Cellular Antenna
C911 Machine Communication Radio Antenna
C912 Machine Communication Radio
C913 Ethernet Switch
C914 Satellite Antenna
C915 Antenna Filter
Lights
E101 Right-Hand Console Lamp
E102 Key Switch Control
E103 Left Fender Turn Signal
E104 Right Fender Turn Signal
E106 Map Lamp
E109 Right Rear Fender Flood Light
E110 Left Rear Fender Flood Light
E113 Left Tail/Brake Light
E114 Right Tail/Brake Light
E115 Left Extremity Transport Light
E116 Right Extremity Transport Light
E119 Right Side Lighter
E120 Left Front Headlights
E121 Right Front Headlights
E124 Left Low-Beam Driving Light
E125 Right Low-Beam Driving Light
E128 Right Front Inner Roof Flood Light
E129 Left Front Inner Roof Flood Light
E138 Right Rear Inner Roof Flood Light
E139 Left Rear Inner Roof Flood Light
E140 Right Front Side Roof Flood Light
E141 Left Front Side Roof Flood Light
E142 Right Rear Side Roof Flood Light
E143 Left Rear Side Roof Flood Light
E144 Beacon Light 1
E145 Beacon Light 2
E146 Microphone
E147 Right Loader Flood Light
E148 Left Loader Flood Light
E176 Left Front Clearance and Warning Light (Eur Only)
E177 Right Front Clearance and Warning Light (Eur Only)
E198 Left Side Lighter
E200 Right Front Corner Roof Light
E201 Left Front Corner Roof Light
E202 Right Rear Corner Roof Light
E203 Left Rear Corner Roof Light
E223 Right License Plate Light (Eur Only)
E224 Left License Plate Light (Eur Only)
E225 Right Mid Body Flood Light
E226 Left Mid Body Flood Light
E227 Right Front Clearance and Warning Light (Eur Only Without 3 Meter Extremity Arm Light Kit)
E228 Left Front Clearance and Warning Light (Eur Only Without 3 Meter Extremity Arm Light Kit)
E229 Right Extremity Transport Light (Eur Only With 3 Meter Extremity Arm Light Kit)
E230 Left Extremity Transport Light (Eur Only With 3 Meter Extremity Arm Light Kit)
E231 CIS Trailer Light 1
E232 CIS Trailer Light 2
E233 CIS Trailer Light 3
E234 Auxiliary Power Outlet
E500 Refrigerator
E502 Battery Disconnect LED
E5601 DEF Dosing Unit Pressure Line Heater
E5602 DEF Dosing Unit Supply Line Heater
E5603 DEF Dosing Unit Return Line Heater
E947 Backrest Heating Element
Fuses
FL1 Master Fuse
FL2 Alternator/Battery Relay Fuse
FL3 Backup Hydraulic Pump Fuse
FX5 Implement Power Switched Fuse
FX6 Implement Power Unswitched Fuse
FEXX Front Load Center Panel—Fuses
FEXX-1 Front Load Center Panel Eyelet
FE12 Alternator Fuse
Charging
G001 Battery
G002 Battery
G301 Alternator
Monitoring Devices
H201 Backup Alarm
Relays
Load Center Panel—Relays
KX6 ActiveSeat™ Compressor Relay
K924 ISO 11783 Relay Box
KST Starter Relay
KSW1 Backup Hydraulic Pump Relay
KSW2 Alternator/Battery Relay
Motors
M01 Front Washer Pump
M02 Rear Washer Pump
M03 Right Washer Pump
M101 Backup Hydraulic Pump Motor
M102 Standard Seat Compressor Motor
M103 ATC Circulation Blower Motor
M104 Power Extend Left Mirror Motors
M105 Power Extend Right Mirror Motors
M106 Power Standard Right Mirror Motor
M107 Power Standard Left Mirror Motor
M211 Pressurizer Blower Motor
M220 Water Valve Motor
M240 Front Wiper Motor
M241 Rear Wiper Motor
M244 Right Wiper Motor
M301 Starter Motor
Switches
SPK01 Circuit 0050 Splice Connector
SPK02 Circuit 0010 Splice Connector
SPK03 Circuit 0050 Cab Splice Connector
SPK04 Circuit 0010 Splice Connector
S001 Key Switch
S002 Battery Disconnect Switch
S060 Rear PTO Switch
S061 Front PTO Switch
S070 AutoPowr™/IVT™ Drive Lever
S075 e23™/16 Speed PST Drive Lever
S100 Dome Lamp Switch
S102 Road Light Switch
S103 Turn Signal Switch Assembly
S104 Right-Hand Console Lamp Switch
S105 Door Switch
S128 CIS Trailer Lights Switch
S201 Front Wiper Switch
S241 Right Window Wiper Switch
S242 Rear Wiper Switch
S301 Start Aid Switch
S302 Neutral Start Switch
S304 Standard Seat Height Control Switch
S305 Operator Presence Switch
S306 Mirror Heat Switch
S308 Mirror Adjustment Switch
S310 Rear Hitch Center External Switch
S311 Rear Hitch Right External Switch
S312 Rear Hitch Left External Switch
S313 SCV Left External Switch
S314 SCV Right External Switch
S501 A/C Compressor Clutch
S503 Differential Lock Switch
S549 Implement Switch
S560 Front PTO External Switch
S561 Front Hitch External Switch
S660 Rear PTO Left External Switch
S661 Rear PTO Right External Switch
S910 ActiveSeat™ Height Control Switch
S911 ActiveSeat™ Firmness Control Switch
S943 Heated Seat Switch
Diodes
V3 Standard Seat Diode
V101 Alternator/Battery Relay Diode
V750 Power Module Relay Diode
V751 Power Module Relay Diode
Wiring Harnesses
W001 Cab Chassis Ground
W002 Convenience Outlet #2 Harness (Eur Only)
W003 Convenience Outlet #2 Harness (NA Only)
W004 Convenience Outlet #1 Harness (Eur Only)
W005 Convenience Outlet #1 Harness (NA Only)
W006 RLC Power Cable
W007 CLC Power Cable
W009 9.0L Alternator Harness
W010 Positive Battery Cable
W011 Negative Battery Cable
W012 Cab Power Cable
W013 VLC Power Cable
W016 Auxiliary Power Strip
W020 Power Module Relay Harness (Backup Pump)
W100 Hood Light Harness
W101 Key Switch Control Antenna
W103 Immobilizer Control Device Harness
W106 Dual Power Mirror Harness
W107 Extremity Light Harness (NA Only)
W108 Extremity Light Harness (Eur Only)
W110 Front Console Harness (AutoTrac™)
W112 Front Console Harness (ACS™)
W113 Steering Column Harness
W114 Radio to XM Satellite Harness
W115 ATC Roof Harness
W117 Auxiliary Audio Harness
W119 USB and Auxiliary Harness
W122 Left Extended Fender Harness
W123 Right Extended Fender Harness
W125 XM Satellite Radio Antenna
W150 Key Switch Control Harness
W155 CIS Trailer Lights Bracket Harness
W156 CIS Trailer Lights Cab Harness
W161 Rear Implement Lighting and Accessory Harness (NA Only)
W162 Rear Implement Lighting and Accessory Harness (Eur Only)
W163 Front Implement Lighting and Accessory Harness (NA Only)
W164 Front Implement Lighting and Accessory Harness (Eur Only)
W170 Optional Roof Lighting Harness
W200 Radar Harness
W201 Backup Alarm Harness
Chassis Harnesses
W300 Final Tier 4/Stage 4 Emissions Chassis Harness (MFWD, AutoTrac™)
W301 Final Tier 4/Stage 4 Emissions Chassis Harness (ILS™, AutoTrac™)
W302 Final Tier 4/Stage 4 Emissions Chassis Harness (ILS™, AutoTrac™, Front Hitch, Front PTO)
W303 Final Tier 4/Stage 4 Emissions Chassis Harness (MFWD, ACS™)
W304 Final Tier 4/Stage 4 Emissions Chassis Harness (ILS™, ACS™)
W305 Final Tier 4/Stage 4 Emissions Chassis Harness (ILS™, ACS™, Front Hitch, Front PTO)
W306 Stage 2 Emissions Chassis Harness (MFWD, AutoTrac™)
W307 Stage 2 Emissions Chassis Harness (ILS™, AutoTrac™)
W308 Stage 2 Emissions Chassis Harness (ILS™, AutoTrac™, Front Hitch, Front PTO)
W309 Stage 2 Emissions Chassis Harness (MFWD, ACS™)
W310 Stage 2 Emissions Chassis Harness (ILS™, ACS™)
W311 Stage 2 Emissions Chassis Harness (ILS™, ACS™, Front Hitch, Front PTO)
W312 Interim Tier 4 and Stage 3B Emissions Chassis Harness (MFWD, AutoTrac™)
W313 Interim Tier 4 and Stage 3B Emissions Chassis Harness (ILS™, AutoTrac™)
W314 Interim Tier 4 and Stage 3B Emissions Chassis Harness (ILS™, AutoTrac™, Front Hitch, Front PTO)
W315 Interim Tier 4 and Stage 3B Emissions Chassis Harness (MFWD, ACS™)
W316 Interim Tier 4 and Stage 3B Emissions Chassis Harness (ILS™, ACS™)
W317 Interim Tier 4 and Stage 3B Emissions Chassis Harness (ILS™, ACS™, Front Hitch, Front PTO)
W321 CHINA Tier 3 / Stage 3A Emissions Chassis Harness (ILS™, AutoTrac™)
W322 CHINA Tier 3 / Stage 3A Emissions Chassis Harness (MFWD™, AutoTrac™)
W323 BRAZIL Tier 3 / Stage 3A Emissions Chassis Harness (ILS™, AutoTrac™)
W324 BRAZIL Tier 3 / Stage 3A Emissions Chassis Harness (MFWD™, AutoTrac™)
W331 AutoPowr™/IVT™ Transmission Harness
W332 e23™ Transmission Harness
W333 16 Speed PST Transmission Harness
W334 AutoPowr™/IVT™ MFWD Speed Sensor Extension Harness
W400 Engine Harness
W401 SCR DEF Extension Harness
W402 Engine Harness (Stage 3A Emissions Only)
W403 Engine Extension Harness (Stage 3A Emissions Only)
W500 Cab Harness (Value 4100 Processor)
W501 Cab Harness (Premium 4600 Processor)
W570 Main Armrest Control Unit Harness
W572 Generation 4 CommandCenter™ Display Harness
W575 Armrest Control Unit Harness (AutoPowr™/IVT™)
W576 Armrest Control Unit Harness (e23™/16 Speed PST)
W577 Armrest Navigation Bar Module Extension Harness
W721 Draft Sensor Harness
W750 1300 Wheel Angle Sensor Harness (AutoTrac™/ACS™)
W751 1500 Wheel Angle Sensor Harness (AutoTrac™/ACS™)
W752 ILS™ Right Wheel Angle Sensor Harness (ACS™)
W753 ILS™ Left Wheel Angle Sensor Harness (AutoTrac™/ACS™)
W754 ILS™ Left side Extension Harness (AutoTrac™)(Brazil)
W800 Front Hitch Harness (Front PTO)
W801 Front Hitch Harness
W805 Center Hitch Switch Harness
W810 ILS™ Manifold Harness
W811 ILS™ Manifold Harness (Front PTO)
W812 ILS™ Manifold Harness (Front Hitch)
W850 Backup Hydraulic Pump Harness
W880 Secondary Brake Valve Harness
W881 Secondary Brake Valve and Air Trailer Brake Harness
W890 Front ISO Implement Connector Harness
W900 Ethernet Cable to 4100/4600 Processor
W901 Ethernet Cable to Reconfigurable Display
W902 Ethernet Cable to JDLink™ (MTG) Control Unit
W903 Machine Communication Radio Harness
W904 Machine Communication Radio Antenna
W905 Machine Communication Radio to JDLink™ (MTG) Ethernet Cable Extension
W906 Machine Communication Radio to JDLink™ (MTG) Control Unit Ethernet Cable
W907 Cab to Generation 4 CommandCenter™ Display Extension Harness
W908 4600 Processor to Corner Post Display Harness
W909 Processor to USB Harness
W910 Ethernet Cable to JDLink™ (MTG) Control Unit (No Ethernet Switch)
W911 Ethernet Cable From Machine Communication Radio to Ethernet Switch
W920 Roof Lighting Harness (NA Only)
W921 Roof Lighting Harness (Eur Only)
W922 ISO 11786 Cornerpost Harness
W930 Air Trailer Brake Harness
W940 ActiveSeat™ Harness
W941 Standard Seat Harness
W945 Heated Seat Power Harness
W946 Heated Seat Switch Harness
W947 Heated Seat Heater Element Harness
W950 Power Standard Mirror Harness
W951 Power Extend Mirror Harness
Interconnects and Ground Points
XGND1 Single Point Ground
XGND2 Chassis Ground
XGND3 Fuel Tank Neck Ground
XGND5 Cab Ground 1
XGND7 Roof Cab Ground
XGND8 Main Cab Ground
X002 Chassis to Right ILS Position Sensor Harness Interconnect
X003 Chassis to SCR Harness Interconnect
X004 Chassis to Left ILS Position Sensor Harness Interconnect
X005 Chassis to Right Wheel Angle Sensor Harness Interconnect
X006 Chassis to Left Wheel Angle Sensor Harness Interconnect
X008 Power Module to Alternator/Battery Relay Interconnect
X009 Battery Power Junction Block
X014 Chassis to Backup Alarm Harness Interconnect
X015 Key Switch Control Antenna to Immobilizer Interconnect
X016 Chassis to Trailer Extension Harness Interconnect
X017 Chassis to Front Trailer Extension Harness Interconnect
X020 Chassis to Front Hitch or ILS™ Harness Interconnect
X021 Front ISO Implement Interconnect
X023 Chassis to Front Trailer Light Extension Harness
X024 Front Hitch (Front PTO) Harness to Front ISO Implement Harness Interconnect
X025 Chassis to Front Hitch or ILS™ Harness Interconnect 1
X026 Chassis to Front Hitch or ILS™ Harness Interconnect 2
X059 Chassis to Air Trailer Brake Harness Interconnect
X075 Drive Lever Set Speed Connector
X100 Rear Implement Lighting and Accessory Connector (NA Only)
X101 Front Console to Steering Column Harness Interconnect
X102 Front Implement Lighting and Accessory Connector (NA Only)
X103 Convenience Outlet #1
X104 Convenience Outlet #2
X105 Right Junction Block
X108 Cab to Right Fender Harness Interconnect 2
X109 Cab to Left Fender Harness Interconnect 2
X110 Cab to Roof HVAC Harness Interconnect
X111 ISO 11783 Console Connector
X112 Rear Implement Flood Light Connector (Eur Only)
X113 Roof HVAC Harness to Business Band Device
X114 Service ADVISOR™ Connector
X115 Roof HVAC to Roof Lighting Harness Interconnect
X116 Rear Option Configuration Connector
X117 Front Option Configuration Connector
X118 Cab to Right Fender Harness Interconnect 1
X119 Cab to Left Fender Harness Interconnect 1
X120 Cab to Front Console Harness Interconnect 1
X121 Cab to Front Console Harness Interconnect 2
X131 Left Extremity Light Interconnect 2 (Eur Only)
X132 Left Extremity Light Interconnect 1
X133 Right Extremity Light Interconnect 1
X134 Right Extremity Light Interconnect 2 (Eur Only)
X135 Processor USB
X140 Cab to Video Camera 1 Harness Interconnect
X141 Cab to Video Camera 2 Harness Interconnect
X142 Cab to Video Camera 3 Harness Interconnect
X143 Cab to Video Camera 4 Harness Interconnect
X145 Camera Power and Ground Connector
X150 Cab to Key Switch Control Harness Interconnect 1 (Eur Only)
X151 Cab to Key Switch Control Harness Interconnect 2 (Eur Only)
X155 CIS Trailer Lights Cab to Bracket Harness Interconnect
X160 Rear Implement Lighting and Accessory Connector (Eur Only)
X161 Front Implement Flood Light Connector (Eur Only)
X162 Front Implement Lighting and Accessory Connector (Eur Only)
X170 Roof Lighting to Optional Roof Lighting Harness Interconnect
X174 Inner Roof Harness to Dual Power Mirror Harness Interconnect
X180 Chassis to Hood Light Harness Interconnect
X201 Transmission to Radar Harness Interconnect
X221 ISO Implement Connector
X222 ISO 11786 Cornerpost Connector
X224 Front ISO Implement Connector
X244 Cab to Convenience Outlet #1 Harness Interconnect
X249 Cab to Convenience Outlet #2 Harness Interconnect
X280 Auxiliary Power Strip
X289 Diagnostic Hydraulic Pressure Connector
X290 Front Diagnostic Hydraulic Pressure Connector
X330 Chassis to Transmission Harness Interconnect
X500 Cab to Chassis Harness Interconnect
X501 Cab to Chassis Harness Interconnect 2
X502 Engine to Rear Chassis Harness Interconnect
X5002 Engine to Chassis Harness Interconnect
X5015 Engine Extension Harness Interconnect 1 (Stage 3A Emissions Only)
X5016 Engine Extension Harness Interconnect 2 (Stage 3A Emissions Only)
X5037 SCR Supply Module to Engine Harness Interconnect
X5038 DEF Header Assembly to Engine Harness Interconnect
X5039 Chassis to Engine Harness Interconnect
X5046 Fuel Transfer Pump Power Connector
X5071 Fan Speed Interconnect
X564 Cab to Power Assisted PTO Control Unit Harness Interconnect (7R Only)
X570 Chassis to Power Module Relay Harness Interconnect
X571 Cab to Generation 4 CommandCenter™ Display Harness Interconnect
X721 Rear Chassis to Draft Sensor Extension Harness Interconnect
X722 Armrest Navigation Bar Module Interconnect
X750 Cab to Main Armrest Harness Interconnect
X780 Cab to Chassis Harness Interconnect
X800 Selective Control Valve Pilot Solenoid Connector
X801 Selective Control Valve Position Sensor Connector
X900 Machine Communications Radio Satellite Option Connector
X901 Machine Communications Radio Interconnect
X902 Ethernet Cable Connection
X903 Ethernet Cable Connection
X905 Wheel Speed Signal Connector
X906 Wheel Speed Signal Connector (Radar)
X907 Wheel Speed Signal Connector (GPS)
X908 Ethernet Cable Connection
X909 Ethernet Cable Connection
X910 Ethernet Cable Connection
X911 Ethernet Cable Connection
X912 Ethernet Cable Connection
X913 Ethernet Power and Ground Connector
X914 Machine Communications Radio Data and Power Connector
X915A Cab Implement Connector (2 pin)
X915B Cab Implement Connector (2 pin)
X916A Cab Implement Connector (4 pin)
X916B Cab Implement Connector (4 pin)
X917 Ethernet Cable Connection
X920 MFWD Interconnect
X922 Cab to ISO 11786 Cornerpost Harness Interconnect
X923 Reconfigurable Display Connector
X925 Ethernet Cable Connection
X926 Processor Connector
X930 Seat to Cab Harness Interconnect 1
X944 Seat to Heated Seat Harness Interconnect
X950 Right Power Mirror Interconnect
X951 Left Power Mirror Interconnect
X981 Chassis to Front Console Harness Interconnect
Y101 Ether Solenoid
Y102 ActiveSeat™ Raise / Lower Solenoid
Y103 ActiveSeat™ Pressure Control Solenoid
Y220 Air Flow Mode Motor
Y221 ATC Blower Motor Driver
Y499 Rear PTO Speed Select Solenoid
Y500 Rear PTO Solenoid
Y506 Front Suspension Raise Solenoid
Y507 Front Suspension Lower Solenoid
Y508 Front Suspension Spring Rate Increase Solenoid
Y509 Front Suspension Spring Rate Decrease Solenoid
Y510 Front Suspension Dampening Solenoid A
Y511 Front Suspension Dampening Solenoid B
Y613 Cab Suspension Raise Solenoid
Y614 Cab Suspension Lower Solenoid
Y615 Cab Suspension Damping Solenoid
Y616 Loop Flush Cutoff Solenoid (AutoPowr™/IVT™ Only)
Y624 Hydraulic Oil Cooler Control Solenoid
Y628 R1 Proportional Solenoid Valve (e23™ Only)
Y629 Clutch Enable Solenoid (AutoPowr™/IVT™ Only)
Y633 Park Brake Supply Solenoid
Y635 Lube Priority Solenoid Valve (e23™ Only)
Y637 S3 Proportional Solenoid Valve (e23™ Only)
Y638 S1 Proportional Solenoid Valve (e23™ Only)
Y639 R3 Proportional Solenoid Valve (e23™ Only)
Y640 R2 Proportional Solenoid Valve (e23™ Only)
Y641 Forward Low Proportional Solenoid Valve (e23™ Only)
Y642 Forward High Proportional Solenoid Valve (e23™ Only)
Y643 S2 Proportional Solenoid Valve (e23™ Only)
Y644 S4 Proportional Solenoid Valve (e23™ Only)
Y649 Front Hitch Mode Select Solenoid
Y653 Reverse Clutch (CR) Solenoid
Y654 Ring Unit (RU) Hydro Control Solenoid
Y655 Hydro Clutch Unit (CU) Solenoid
Y656 High Clutch Solenoid
Y657 Low Clutch Solenoid
Y658 Reverse Brake Solenoid
Y659 Clutch 1 (C1) Solenoid
Y660 Clutch 2 (C2) Solenoid
Y661 Clutch 3 (C3) Solenoid
Y664 Air Trailer Brake Enable Solenoid
Y665 MFWD Solenoid
Y666 Rear Differential Lock Solenoid
Y670 Park Sump Block Solenoid
Y673 Reverse Proportional Solenoid Valve (e23™ Only)
Y683 Front Differential Lock Solenoid
Y685 Clutch 2 (C2) Solenoid
Y686 Clutch 4 (C4) Solenoid
Y687 Clutch 1 (C1) Solenoid
Y688 Clutch 3 (C3) Solenoid
Y689 A Brake (AB) Solenoid
Y690 B Clutch (BC) Solenoid
Y691 C Clutch (CC) Solenoid
Y693 D Clutch (DC) Solenoid
Y694 Front PTO Solenoid
Y695 Lube Cutoff Solenoid (16 Speed PST Only)
Y702 Secondary Brake Solenoid
Y703 Secondary Brake Enable Solenoid
Y705 Front Brake Solenoid
Y706 Front Brake Enable Solenoid
Y707 Air Trailer Pre-Brake Solenoid
Y708 Air Trailer Pre-Brake Enable Solenoid
Y747 AutoTrac™ Steer Enable Solenoid (Non ACS™)
Y748 AutoTrac™ Steer Left Solenoid (Non ACS™)
Y749 AutoTrac™ Steer Right Solenoid (Non ACS™)
Y750 Steer Enable Solenoid 1 (ACS™)
Y751 Steer Left Solenoid 1 (ACS™)
Y752 Steer Right Solenoid 1 (ACS™)
Y753 Steer Enable Solenoid 2 (ACS™)
Y754 Steer Left Solenoid 2 (ACS™)
Y755 Steer Right Solenoid 2 (ACS™)
Y800 Hitch Control Valve Pilot Solenoid
Y801 Selective Control Valve I Pilot Solenoid
Y802 Selective Control Valve II Pilot Solenoid
Y803 Selective Control Valve III Pilot Solenoid
Y804 Selective Control Valve IV Pilot Solenoid
Y805 Selective Control Valve V Pilot Solenoid
Y806 Selective Control Valve VI Pilot Solenoid
Y5014 Fan Increase Solenoid
Y5015 Fan Decrease Solenoid
Y5019 DEF Tank Coolant Control Valve (115000—)
Y5020 SCR Dosing Control Valve
AutoPowr™ / IVT™ Operational and Preliminary Checks—Summary of References
AutoPowr™ / IVT™ Theory of Operation—Summary of References
AutoPowr™ / IVT™ Schematic—Summary of References
AutoPowr™ / IVT™ Diagnostic Tests and Adjustments—Summary of References
AutoPowr™ / IVT™—Preliminary Checks
AutoPowr™ / IVT™—Operational Checks
Theory of Operation
AutoPowr™ / IVT™—Transmission Overview
AutoPowr™ / IVT™—Transmission Start-up Theory of Operation
AutoPowr™ / IVT™—PowerZero™ Theory of Operation
AutoPowr™ / IVT™—Forward Mode 1 Theory of Operation
AutoPowr™ / IVT™—Forward Mode 2 Theory of Operation
AutoPowr™ / IVT™—Forward Mode 3 Theory of Operation
AutoPowr™ / IVT™—Forward Mode 4 Theory of Operation
AutoPowr™ / IVT™—Reverse Mode Theory of Operation
AutoPowr™ / IVT™—Transmission Hydraulic Circuit Overview
AutoPowr™ / IVT™—Hydrostatic Module Theory of Operation
AutoPowr™ / IVT™—Hydrostatic Control Circuit Theory of Operation
AutoPowr™ / IVT™—Hydrostatic Closed Loop Circuit Theory of Operation
AutoPowr™ / IVT™—Planetary Unit Theory of Operation
AutoPowr™ / IVT™—Reverse Brake and Forward Clutch Circuits Theory of Operation
AutoPowr™ / IVT™—Synchronizer Theory of Operation
AutoPowr™ / IVT™—Synchronizer Circuits Theory of Operation
AutoPowr™ / IVT™—Park Brake Theory of Operation
AutoPowr™ / IVT™—Park Brake Circuit Theory of Operation
AutoPowr™ / IVT™—Transmission Tandem Pump Assembly Theory of Operation
AutoPowr™ / IVT™—Scavenge Pump Theory of Operation
Schematic
AutoPowr™ / IVT™—Schematic
AutoPowr™ / IVT™—Hydrostatic Control Circuit (30 bar) Pressure Test
AutoPowr™ / IVT™—Hydrostatic Control Circuit (30 bar) Leak Isolation Test
AutoPowr™ / IVT™—P8 AutoPowr™/IVT™ Transmission Hydro Control Circuit Pump Flow Test
AutoPowr™ / IVT™—Hydrostatic Control Circuit (30 bar) Pressure Regulating Valve Test
AutoPowr™ / IVT™—System 2 Pressure Test
AutoPowr™ / IVT™—Transmission Lube Pressure Test
AutoPowr™ / IVT™—Transmission Elements Leak Test
AutoPowr™ / IVT™—Hydrostatic Charge Circuit (20 bar) Leak Isolation Test
AutoPowr™ / IVT™—P4 AutoPowr™/IVT™ Transmission Pump Flow Test
AutoPowr™ / IVT™—2000 kPa (20 bar) (290 psi) Pressure Regulating Valve Test
AutoPowr™ / IVT™—Hydrostatic Closed Loop Leak Test
AutoPowr™ / IVT™—Park Brake Pressure Test
AutoPowr™ / IVT™—Low Clutch, High Clutch, and Reverse Brake Pressure Test
AutoPowr™ / IVT™—C1/C3 Pressure Test
AutoPowr™ / IVT™—C2 Pressure Test
AutoPowr™ / IVT™—MFWD Pressure Test
AutoPowr™ / IVT™—Clutch Enable Valve Test
AutoPowr™ / IVT™—System 2 Accumulator Test
AutoPowr™ / IVT™—Loop Flush Cut Off Valve Test
AutoPowr™ / IVT™—Cooler Relief Valve and Supply Flow Test
AutoPowr™ / IVT™—Shift Performance Test
AutoPowr™ / IVT™—Clutch Unit and Ring Unit Hydro Control Test
AutoPowr™ / IVT™—RU and CU Start-up Pressure Test
AutoPowr™ / IVT™—RU and CU Hydro Control Circuit Leak Test
AutoPowr™ / IVT™—Hydraulic Oil Temperature Test
AutoPowr™ / IVT™—Hydrostatic Module Inspection
AutoPowr™ / IVT™—Transmission Record Sheet
e23 Transmission
e23™ Transmission Operational and Preliminary Checks—Summary of References
e23™ Transmission Theory of Operation—Summary of References
e23™ Transmission Schematics —Summary of References
e23™ Transmission Diagnostic Tests and Adjustments—Summary of References
e23™—Preliminary Checks
e23™—Operational Checks
Theory of Operation
e23™—Transmission Overview
e23™—Electronic Control System Theory of Operation
e23™—Transmission Calibration Theory of Operation
e23™—Transmission Element Engagement Chart
e23™—System 1 Theory of Operation
e23™—System 2 Theory of Operation
e23™—Boost Circuit Theory of Operation
e23™—Transmission Lube Circuit Theory of Operation
e23™—Hydraulic Oil Cooling Circuit Theory of Operation
e23™—Park Brake Theory of Operation
e23™—7th Speed Forward Theory of Operation
e23™—2nd Speed Reverse Theory of Operation
e23™—MFWD Clutch Circuit Theory of Operation
Schematic
e23™—Hydraulic System Schematic
e23™—Park Brake Pressure Test
e23™—Transmission System Pressure Test and Adjustment
e23™—Element Leak Test
e23™—Element Pressure Test
e23™—Transmission Pump (P4) Flow Test
e23™—Lube Pressure Test
e23™—Lube 2 Pressure Test
e23™—Boost Pump (P5) Pressure Test
e23™—Boost Pump (P5) Flow Test
e23™—Hydraulic Oil Temperature Test
e23™—Hydraulic Oil Cooler Flow Test
16-Speed PowerShift Transmission (PST)
16-Speed PowerShift Transmission (PST) Operational and Preliminary Checks—Summary of References
16-Speed PowerShift Transmission (PST) Theory of Operation—Summary of References
16-Speed PowerShift Transmission (PST) Schematics—Summary of References
16-Speed PowerShift Transmission (PST) Diagnostic Tests and Adjustments—Summary of References
PST—Preliminary Checks (16 Speed)
PST—Operational Checks (16 Speed)
Theory of Operation
PST—Power Flow Theory of Operation (16 Speed)
PST—System 1 Oil Theory of Operation (16 Speed)
PST—System 2 Oil Theory of Operation (16 Speed)
PST—7th Speed Forward Theory of Operation (16 Speed)
PST—2nd Speed Reverse Theory of Operation (16 Speed)
PST—Park Brake Theory of Operation (16 Speed)
PST—Neutral Theory of Operation (16 Speed)
PST—Planetary Lube Valve Theory of Operation (16 Speed)
PST—Park Brake Release Valve Theory of Operation (16 Speed)
PST—Clutch Theory of Operation (16 Speed)
PST—Output Clutch Check Valve Orifice Theory of Operation (16 Speed)
PST—Lube Cut-Off Valve Theory of Operation (16 Speed)
PST—Lube Relief Valve Theory of Operation (16 Speed)
PST—Cooler Relief Valve Theory of Operation (16 Speed)
PST—Scavenge Pump Theory of Operation (16 Speed)
PST—Automatic PowerShift (APS) Theory of Operation (16 Speed)
PST—Transmission Shift Logic Theory of Operation (16 Speed)
PST—Selecting Gear Theory of Operation (16 Speed)
PST—Transmission Shifting Features Theory of Operation (16 Speed)
Cold Weather Starting
Shifting - Without Using Clutch Pedal
Shifting - Using Clutch Pedal
Shifting From Reverse
Rapid Shift
Double Shift
Shuttle Shifting (Direction Change)
Ground Speed Matching
PST—Shifting Characteristics Theory of Operation (16 Speed)
PST—Electrohydraulic Solenoid Valve Theory of Operation (16 Speed)
PST—Analog Shift Valve Theory of Operation (16 Speed)
Analog Shift Valve (Clutch Disengaged)
Analog Shift Valve (Clutch Engaged)
Analog Valve Commands for ON-Coming Clutch
Schematic
16 Speed Powershift Transmission Hydraulic System Schematic
PST—Element Engagement Chart (16 Speed)
PST—System Pressure Test
PST—PTO, Park Brake, Differential Lock, and MFWD Leak Check
PST—PTO, Park Brake, and MFWD Pressure Test
PST—Shift Valve Test
PST—Duty Cycle Test
PST—Transmission Element Leak Test
PST—Transmission Element Pressure Test
PST—Shift Accumulator Test
PST—Pump Flow Test
PST—Lube Valve Test
PST—Lube Oil Pressure Test
PST—Cooler Relief Valve and Flow Test
PST—Park Brake Pressure Test
PST—Transmission Record Sheet
Drivetrain
Axles and Differential Lock Operation and Preliminary Checks—Summary of References
Axles and Differential Lock Theory of Operation—Summary of References
Axles and Differential Lock Schematic—Summary of References
Axles and Differential Lock Diagnostic Tests and Adjustments—Summary of References
MFWD Operational and Preliminary Checks—Summary of References
MFWD Theory of Operation—Summary of References
MFWD Schematics—Summary of References
MFWD Diagnostic Tests and Adjustments—Summary of References
PTO Operational and Preliminary Checks—Summary of References
PTO Theory of Operation—Summary of References
PTO Schematics—Summary of References
PTO Diagnostic Tests and Adjustments—Summary of References
Axles and Differential Lock—Preliminary Check
Differential Lock—Operational Check
Axle—MFWD Axle Theory of Operation
Axle—ILS™ Axle Theory of Operation
Axle—MFWD Limited Slip Differential Theory of Operation
Axle—Rear Axle Theory of Operation
Axle—Differential Lock Theory of Operation
Axle—Rear Differential Lube Theory Of Operation
Differential Lock—Differential Lock Leak Test
Differential Lock—Differential Lock Pressure Test, ILS™ Front Axles
Differential Lock—Differential Lock Pressure Test, 1500 Front Axle
Differential Lock—Fault Isolation on 1500 Front Axle
Differential Lock—Fault Isolation on ILS™ Front Axle
MFWD Operation and Preliminary Checks
MFWD—Preliminary Check
MFWD—Operational Check
MFWD—MFWD Clutch Theory of Operation
MFWD Schematic
MFWD—MFWD System Schematic
MFWD—MFWD Driveline Test
MFWD—MFWD Pressure Leak Test
MFWD—MFWD Clutch Test
PTO Operation and Preliminary Checks
PTO—Preliminary Check
PTO—Operational Check
PTO—Front PTO Theory of Operation
Front PTO solenoid valve operation
Normal PTO operation
Scavenge pump operation
PTO Supply Oil
PTO—Rear PTO Clutch and Brake Theory of Operation
PTO—Rear PTO Solenoid Valve Theory of Operation
Rear PTO solenoid valve operation
PTO—Single Speed PTO Theory of Operation
PTO—1000 rpm / 1000E Theory of Operation
PTO—540 rpm / 1000 rpm Theory of Operation
PTO Schematic
PTO—Front PTO Schematic
PTO—Rear PTO Schematic
PTO—Rear PTO Clutch And Brake Pressure Test
PTO—Rear PTO Modulating Valve Test
PTO—Rear PTO Speed Select Pressure Test
PTO—Front PTO Supply Pressure Test
PTO—Front PTO Clutch and Brake Pressure Test
PTO—Front PTO Modulating Valve Test
PTO—Front PTO Return Oil Pressure Test
Drivetrain Component Information
AutoPowr™ / IVT™ Transmission (IVT) Component Location—Summary of References
e23™ Transmission Component Location—Summary of References
16-Speed PowerShift Transmission (PST) Component Location—Summary of References
Drivetrain Component Location—Summary of References
AutoPowr / IVT Transmission Components
AutoPowr™/IVT™ Transmission Mechanical Components
Externally Accessed Jumper Tube Locations
Internal Jumper Tube Locations
G401 Rear AutoPowr™/IVT™ Transmission Manifold
G520 AutoPowr™/IVT™ Hydro Module
P8 AutoPowr™/IVT™ Hydrostatic Control Circuit Pump
V12 System Pressure Regulating Valve
V522 Hydrostatic Control Circuit Pressure Regulating Valve
X11 System 2 Pressure DR
X103 AutoPowr™/IVT™ Lube Pressure DR
X522 Hydro Control Pressure DR
X633 AutoPowr™/IVT™ Park Brake Pressure DR
X718 System 1 Pressure DR
Z104 Cooler Supply Test Port
Z654 RU Test Port
Z655 CU Test Port
Z656 High Clutch Test Port
Z657 Low Clutch Test Port
Z658 Reverse Brake Test Port
Z659 C1 Test Port
Z660 C2 Test Port
Z661 C3 Test Port
Z667 MFWD Test Port
e23 Transmission Components
A628 R1 Clutch Accumulator
A640 R2 Clutch Accumulator
e23™ Transmission Mechanical Components
G201 Lower Rear Transmission Manifold
G202 Upper Rear Transmission Manifold
P4 e23™ Transmission Pump
P5 e23™ Transmission Boost Pump
V633 e23™ Park Brake Pressure Relief Valve
X98 e23™ Transmission System 1 DR
X99 e23™ Transmission System 2 DR
X635 Lube 2 Pressure DR
Z50 Boost Pump Pressure Test Port
Z628 R1 Element Test Port
Z633 e23™ Transmission Park Brake Pressure Test Port
Z637 S3 Element Test Port
Z638 S1 Element Test Port
Z639 R3 Element Test Port
Z641 Forward Low Element Test Port
Z642 Forward High Element Test Port
Z643 S2 Element Test Port
Z644 S4 Element Test Port
Z665 e23™ Transmission MFWD Clutch Test Port
Z673 Reverse Element Test Port
16-Speed PowerShift Transmission (PST) Components
16-Speed PowerShift Transmission Mechanical Componets
A2 System 2 Accumulator (16 Speed)
A690 B Clutch Accumulator (16 Speed)
A691 C Clutch Accumulator (16 Speed)
A693 D Clutch Accumulator (16 Speed)
G301 Rear Transmission Manifold (16 Speed)
P4 PowerShift Transmission Pump (16 Speed)
V12 Pressure Regulating Valve (16 Speed)
V640 Hydraulic Oil Cooler Relief Valve (16 Speed)
V650 Planetary Lube Valve (16 Speed)
V721 Lube Pressure Relief Valve (16 Speed)
X104 Transmission System 1 Pressure DR (16 Speed)
Z653 CR Clutch Test Port (16 Speed)
Z665 MFWD Clutch Test Port (16 Speed)
Z685 C2 Clutch Test Port (16 Speed)
Z686 C4 Clutch Test Port (16 Speed)
Z687 C1 Clutch Test Port (16 Speed)
Z688 C3 Clutch Test Port (16 Speed)
Z689 A Brake (AB) Test Port (16 Speed)
Z690 B Clutch (BC) Test Port (16 Speed)
Z691 C Clutch (CC) Test Port (16 Speed)
Z693 D Clutch (DC) Test Port (16 Speed)
Drivetrain Components
C665 MFWD Clutch
C666 Rear Differential Lock Clutch
C667 Front Differential Lock Clutch
G694 Front PTO Assembly
W1 Front Axle Assembly
W2 Rear Axle Assembly
W5 Pump Drive Housing
W6 ILS™ Axle Housing
W500 Rear PTO Clutch / Brake Assembly
Z6 Rear PTO Clutch Pressure Port
Z7 Rear PTO Brake Pressure Port
Z20 Rear Differential Lube Port
Z21 Rear Differential Lock Pressure Port
Z22 Rear PTO Speed Select 1000 rpm Pressure Port (1000E PTO Only)
Z23 Rear PTO Speed Select 1000E rpm Pressure Port (1000E PTO Only)
Z694 Front PTO Clutch Pressure Port
Z695 Front PTO Brake Pressure Port
Z696 Front PTO System Pressure Port
Z697 Front PTO Lube Pressure Port
Brakes
Brakes Operational and Preliminary Checks—Summary of References
Brakes Theory of Operation—Summary of References
Brake Schematics—Summary of References
Brakes Diagnostic Tests and Adjustments—Summary of References
Brake—Rear Brakes Preliminary Check
Brake—Front Brakes Preliminary Check
Brakes—Rear Brake Operational Check
Brakes—Front Brake Operational Check
Theory of Operations
Brake—System Theory of Operation
Brake—Brake Valve Theory Of Operation
Brake—Rear Brake Pilot Signal Manifold Theory of Operation
Brake—Pistons, Plates, and Disks Theory of Operation
Brake Retractors
Brake—Front Brake Theory of Operation
Brake—Secondary Brake Theory of Operation (EUR Only)
Brake—Air Trailer Brake Theory Of Operation
Brake—Hydraulic Trailer Brake Theory Of Operation
Schematic
Brake—Rear Brake Valve Schematic
Brake—Front Brakes Schematic
Brake—Secondary Brake Valve Schematic
Brake—Air Trailer Brake Schematic
Brake—Hydraulic Trailer Brake Schematic
Brakes—Rear Brake Pressure Test
Brakes—Rear Brake Circuit Leak Test
Brakes—Rear Brake Supply Pressure Test
Brakes—Front Brake Pressure Test
Brakes—Front Brake Circuit Leak Test
Brakes—Secondary Brake Pressure Test
Brakes—Hydraulic Trailer Brake Pressure Test
Brakes—Air Trailer Brake Pressure Test
Brakes—Air Trailer Pre-Brake Pressure Test
Steering
Steering Operational and Preliminary Checks—Summary of References
Steering Theory of Operation—Summary of References
Steering Schematics—Summary of References
Steering Diagnostic Tests and Adjustments—Summary of References
Steering—AutoTrac™ Preliminary Check
Steering—Preliminary Check
Steering—AutoTrac™ Operational Check
Steering—Operational Check
Steering—ActiveCommand Operational Check
Theory of Operation
Steering—System Identification
Steering—ActiveCommand Steering System Theory of Operation
Steering—ActiveCommand Steering Valve Theory of Operation
Steering —AutoTrac™ Steering System Theory of Operation
Steering—AutoTrac™ Valve Theory of Operation
Steering—Valve Theory of Operation
Gerotor Steering Valve Assembly
Steering—Cylinder Theory of Operation
Front Axle Steering
Steering—Gerotor Theory of Operation
Steering Valve Operation
Gerotor Operation
Gerotor Component Description
Steering—Steering/Brakes Backup System Theory of Operation
Schematic
Steering—Manual Steering Valve Schematic
Steering—AutoTrac™ Schematic
Steering—ActiveCommand Steering (ACS™) Schematic
Steering—AutoTrac™ Backup Pump Schematic
Steering—ActiveCommand (ACS™) Backup Pump Schematic
Steering—AutoTrac™ Steering Accuracy Check
Steering—AutoTrac™ Accuracy Factors
Steering—AutoTrac™ Valve Manual Control Test
Steering—ACS™ Valve Manual Control Test
Steering—Stall and Standby Pressure Test
Steering—Leak Test
Steering—Supply Circuit Leak Test
Steering—Cylinder Leak Test
Steering—Priority Load Sense Relief Pressure Test
Steering—Standard Steering Circuit Leak Test
Steering—ActiveCommand Steering Circuit Leak Test
Steering—Standard Steering Priority Load Sense Leak Test
Steering—ActiveCommand Steering Priority Load Sense Leak Test
Steering—Wheel Angle Sensor Test
Steering—Backup Hydraulic Pump Pressure Test
Steering—Load Sense Blocking Valve Inspection
Steering—AutoTrac™ Valve Isolation Leak Test
Steering and Brakes Component Information
Brake Component Information—Summary of References
Steering Component Information—Summary of References
Brake Components
Brake Component Location Overview
A50 Rear Brake Accumulator
C10 Front Axle Brake Piston (2)
C20 Rear Axle Brake Piston (2)
D50 Rear Brake Load Sense Screened Check Valve
D53 Left Rear Secondary Brake Shuttle Check Valve
D54 Right Rear Secondary Brake Shuttle Check Valve
D55 Rear Brake Accumulator Check Valve
D80 Hydraulic Trailer Brake Load Sense Screened Check Valve
F72 Air Trailer Brakes Dryer
G26 Rear Brake Pilot Signal Manifold
P11 Air Trailer Brake Compressor
R70 Air Trailer Brake Dual Tank Reservoir
R72 Air Trailer Brake Purge Tank
V51 Secondary Brake Valve (EUR Only)
V53 Rear Brake Valve
V54 Secondary Brake and Air Trailer Pre-Brake Valve (EUR Only)
V70 Air Trailer Brake Control Valve
V71 Air Trailer Pre-Brake Valve
V72 Air Trailer Brake Pressure Regulating Valve Assembly
V73 Air Trailer Brake Purge Tank Charge Valve
V74 Air Trailer Brake Reservoir Automatic Drain Valve
V75 Single Line Air Trailer Brake Control Valve
V80 Hydraulic Trailer Brake Valve
X7 Left Rear Brake Bleed Pressure DR
X8 Right Rear Brake Bleed Pressure DR
X70 Rear Brake Pilot Signal DR
X71 Air Trailer Brake Control Coupler (Yellow)
X72 Air Trailer Brake Supply Coupler (Red)
X73 Air Trailer Brake Single Line Coupler (Black)
X80 Hydraulic Trailer Brake Coupler
X707 Pre-Brake Pilot Signal DR
Z8 Hydraulic Trailer Brake Valve Bleed Port
Steering Components
D62 Steering Backup Check Valve
F103 Steering Priority Load Sense Relief Valve Screen
G10 Priority Valve and AutoTrac™ Steering Assembly
G11 Priority Valve and ACS™ Steering Assembly
P101 Backup Hydraulic Pump
R3 COR (Backup Pump Reservoir)
V60 Steering Valve
V62 Steering Load Sense Blocking Valve
V63 ACS™ Backup Pilot Pressure Reducing Valve
V64 ACS™ Left/Right Turn Shock Valve
V69 Steering Valve 1300 Axle
V100 Park Brake Pump-Off Manifold
V102 Park Brake Pressure Limiting Valve
V103 Steering Priority Load Sense Relief Valve
Hydraulics
Hydraulics Operational and Preliminary Checks—Summary of References
Hydraulics Theory of Operation—Summary of References
Hydraulic Schematics—Summary of References
Hydraulics Diagnostics Tests and Adjustments—Summary of References
Standard Hydraulic Symbols
Hydraulic Designators
Hydraulic System Testing Precautions
Visually Inspect Hydraulic System
Hydraulic Troubleshooting Tips
Aeration and Cavitation
Hydraulic Components
Oil Storage and Filling
Oil Filtration
Hydraulics—Hydraulic System Preliminary Checks
Hydraulics—Hydraulic System Operational Check
Hydraulics—Rear Hitch Operational Check
Hydraulics—Front Hitch Operational Check
Theory of Operation
Hydraulics—Hydraulic System Theory of Operation
Hydraulics—Transmission Scavenge Pump and Hydraulic Oil Reservoir Theory of Operation
Auxiliary Hydraulic Oil Reservoir Theory
Hydraulics—Hydraulic Charge System Theory of Operation
Charge System Overview
Charge Pump P1
Hydraulic Oil Filter F2
Hydraulics—Main Hydraulic Pump and Pump Compensator Theory of Operation
Pump Compensator
Hydraulics—High Flow Pump Theory of Operation
Hydraulics—Priority Valve and Load Sense Theory of Operation
Load Sense Operation
Hydraulics—SCV and Hitch Oil Management
Hydraulics—SCV Theory of Operation
Hydraulics—SCV Neutral Position Theory of Operation
Hydraulics—SCV Retract Position Theory of Operation
Hydraulics—SCV Load Sense Shuttle System Theory of Operation
Hydraulics—SCV Extend Position Theory of Operation
Hydraulics—SCV Float Position Theory of Operation
Hydraulics—Rear Hitch System Theory of Operation
Hydraulics—Rear Hitch Valve Neutral Position Theory of Operation
Hydraulics—Rear Hitch Valve Raise Position Theory of Operation
Hydraulics—Rear Hitch Valve Lower Position Theory of Operation
Hydraulics—Hitch Return Compensation Theory of Operation
Hydraulics—Front SCV and Front Hitch System Overview
Hydraulics—Front SCV and Hitch Valve Theory of Operation
Hydraulics—Front SCV Neutral Position Theory of Operation
Hydraulics—Front SCV Retract Position Theory of Operation
Hydraulics—Front SCV Extend Position Theory of Operation
Hydraulics—Front SCV Float Position Theory of Operation
Hydraulics—Front Hitch System Theory of Operation
Schematic
Hydraulics—AutoPowr™ / IVT™ with ActiveCommand Steering and High Flow Pump Schematic
Hydraulics—e23™ Transmission with ActiveCommand Steering and High Flow Pump Schematic
Hydraulics—AutoPowr™ / IVT™ with Standard Steering Schematic
Hydraulics—e23™ Transmission with Standard Steering Schematic
Hydraulics—PowerShift Transmission with Standard Steering Schematic (16 Speed)
Hydraulics—Priority Valve and AutoTrac™ Steering Assembly Schematic
Hydraulics—Priority Valve and ACS™ Steering Assembly Schematic
Hydraulics—Rear SCV Diagram and Schematic
Hydraulics—Rear Hitch Diagram and Schematic
Hydraulics—Front SCV / Hitch Diagram and Schematic
Hydraulics—High Flow Neutral Load Sense Schematic
Hydraulics—System Diagnosis Record Sheet
Hydraulics—SCV—Hitch System Diagnosis Record Sheet
Hydraulics—Heating Hydraulic Oil
Hydraulics—Filter Differential Pressure Test
Hydraulics—Charge Pump Test
Hydraulics—Main Hydraulic Pump Pressure Test
Hydraulics—High Flow Hydraulic Pump Pressure Test
Hydraulics—Air Bleed Procedure
Hydraulics—Neutral Load Sense Pressure Test
Hydraulics—High Flow Pump Neutral Load Sense Pressure Test
Hydraulics—Load Sense Differential Pressure Test
Hydraulics—High Flow Pump Load Sense Differential Pressure Test
Hydraulics—Load Sense Isolation Test
Hydraulics—Load Sense Bypass Test
Hydraulics—High Flow Pump Load Sense Bypass Test
Hydraulics—Load Sense Leak Test
Hydraulics—Priority Valve Operational Pressure Test
Hydraulics—Stall Pressure Adjustment
Hydraulics—High Flow Pump Stall Pressure Adjustment
Hydraulics—Main Hydraulic Pump Flow Test
Hydraulics—High Flow Hydraulic Pump Flow Test
Hydraulics—Pilot Oil Pressure Test
Hydraulics—SCV Shuttle Valve Leak Test
Hydraulics—Rear Hitch—SCV Valve Leak Test
Hydraulics—Rear SCV Flow Resolution Test
Hydraulics—Front SCV Flow Resolution Test
Hydraulics—Front Hitch Pressure Test
Hydraulics—Front Hitch Cylinder Leak Test
Hydraulics—Front SCV Valve Leak Test
Hydraulics—Rear SCV Calibration
Hydraulics—Front SCV Stepper Motor Test
Hydraulics Component Information
Hydraulics Component Information—Summary of References
D3 High Flow Pump Supply Check Valve
D6 Rear SCV / Suspension Load Sense Shuttle Check Valve
D100 Final Load Sense Damping Valve
F1 Charge Pump Inlet Screen
F2 Hydraulic Oil Filter
F7 Transmission Scavenge Pump Inlet Screen
F700 SCV Pilot Screen
G7 Rear SCV / Hitch Valve Assembly
G21 Hydraulic Filter Manifold
G700 Front SCV / Hitch Valve Assembly
H1 Hydraulic Oil Cooler
J2 Auxiliary Hydraulic Reservoir Vent (2)
P1 Hydraulic Charge Pump
P2 Main Hydraulic Pump
P3 High Flow Hydraulic Pump
P7 Transmission Scavenge Pump
R1 Hydraulic Oil Reservoir
R2 Auxiliary Hydraulic Oil Reservoir
V1 Priority Valve
V2 Main Hydraulic Pump Compensator Valve
V3 High Flow Hydraulic Pump Compensator Valve
V701 Selective Control Valve Unit I (SV1)
V702 Selective Control Valve Unit II (SV2)
V703 Selective Control Valve Unit III (SV3)
V704 Selective Control Valve Unit IV (SV4)
V705 Selective Control Valve Unit V (SV5)
V706 Selective Control Valve Unit VI (SV6)
V710 Front Hitch Selective Control Valve Unit (SVJ)
V714 Front Selective Control Valve Unit XIV (SVN)
V715 Front Selective Control Valve Unit XV (SVO)
V800 Hitch Control Valve Unit (HV1)
V801 Rear Hitch Manual Drain Valve
W700 Front Hitch Assembly
W710 SCV Breakaway Coupler Assembly
W800 Rear Hitch Assembly
X1 CF Priority Circuit DR
X2 Main Hydraulic Pump Outlet DR
X3 Pump Resolved Load Sense DR
X4 Rear SCV/ Hitch Pilot Supply DR
X5 Rear SCV / Hitch Supply Pressure DR
X6 Rear SCV / Hitch Return Pressure DR
X15 Front SCV / Hitch Pump Pressure DR
X16 Front SCV / Hitch Load Sense DR
X20 Hydraulic Oil Filter Inlet DR
X21 Hydraulic Oil Filter Outlet DR
X25 Evac DR/Service Oil Fill Port
X30 High Flow Pump Outlet DR
X100 Transmission System 1 Pressure DR
X101 Transmission Lube Pressure DR
Z1 Rear Power Beyond Case Drain Port
Z2 Rear Power Beyond Pressure Ports
Z3 Rear Power Beyond Return Ports
Z4 Rear Auxiliary Load Sense Port
Z31 High Flow Pump Load Sense Port
Z101 Park Brake Pump-Off Port
Suspension
Suspended Front Axle Operational and Preliminary Checks—Summary of References
Suspended Front Axle Theory of Operation—Summary of References
Suspended Front Axle Schematic—Summary of References
Suspended Front Axle Diagnostic Tests and Adjustments—Summary of References
Cab Suspension Operational and Preliminary Checks—Summary of References
Cab Suspension Theory of Operation—Summary of References
Cab Suspension Schematic—Summary of References
Cab Suspension Diagnostic Tests and Adjustments—Summary of References
Suspended Front Axle-Operational and Preliminary Checks
ILS™—Preliminary Check
ILS™—Operational Check
Suspended Front Axle-Theory of Operation
SFA—ILS™ System Theory of Operation
SFA—ILS™ Manifold Theory of Operation
SFA—ILS™ Hydraulic Circuit Theory of Operation—Neutral
SFA—ILS™ Hydraulic Circuit Theory of Operation—Raise
SFA—ILS™ Hydraulic Circuit Theory of Operation—Lower
SFA—ILS™ Hydraulic Circuit Theory of Operation—Spring Rate Control
SFA—ILS™ Hydraulic Circuit Theory of Operation—Damping
Suspended Front Axle—Schematic
Suspended Front Axle-Diagnostic Tests and Adjustments
SFA—ILS™ Preliminary Nitrogen Charge Pressure Test
SFA—ILS™ Cylinder Leak Test
SFA—Pressure Test for ILS™ Cylinder Head-Side Circuit
SFA—ILS™ Solenoid Valve Leak Test
SFA—ILS™ Spring Rate Valve Test
SFA—ILS™ Auxiliary Port Stall Pressure Test
Cab Suspension-Operational and Preliminary Checks
Cab Suspension—Preliminary Checks
Cab Suspension—Operational Checks
Cab Suspension-Theory of Operation
Cab Suspension - System Overview
Cab Suspension (Raise)
Cab Suspension (Lower)
Cab Suspension (Damping Control)
Cab Suspension—Schematic
Cab Suspension-Diagnostic Tests and Adjustments
Cab Suspension—Depressurize System
Cab Suspension—Bleeding the System
Suspension Component Information
Suspension Component Information--Summary of References
Suspension Components
A500 Front Suspension Rod Side Accumulators
A510 Front Suspension Head Side Accumulators
B730 Cab Suspension Position Sensor
C510 Left Front Suspension Cylinder
C511 Right Front Suspension Cylinder
C614 Left Cab Suspension Cylinder Assembly
C615 Right Side Cab Suspension Cylinder
D7 Cab Suspension Load Sense Shuttle Check Valve
D9 Pickup Hitch Load Sense Shuttle Check Valve
D502 Front Suspension Rod Side Spring Rate Increase Check Valve
D503 Front Suspension Head Side Raise Check Valve
D504 Front Suspension Rod Side Load Sense Check Valve
D505 Front Suspension Head Side Load Sense Check Valve
F501 Front Suspension Valve Manifold Inlet Screen
G500 Front Suspension Valve Manifold
O510 Front Suspension Damping Valve Orifice
V510 Front Suspension Damping Valve Assembly
V613 Cab Suspension Raise / Lower Valve Assembly
X500 Front Suspension Head Side Pressure DR
X501 Front Suspension Rod Side Pressure DR
Z9 Cab Suspension Drain Port
Cab and Open Operator`s Station
HVAC Operational and Preliminary Checks—Summary of References
Air Conditioning Theory of Operation—Summary of References
HVAC Schematic—Summary of References
HVAC Diagnostic Tests and Adjustments—Summary of References
Seat Operational and Preliminary Checks—Summary of References
Seat Theory of Operation—Summary of References
Seat Schematic—Summary of References
Seat Diagnostic Tests and Adjustments—Summary of References
Air Conditioning—Preliminary Checks
Air Conditioning—ATC Operational Check
HVAC System Theory of Operation
Air Conditioning—Theory of Operation
HVAC-Schematic
HVAC System Schematic
Air Conditioning—System Static Pressure Test
Air Conditioning—System Pressure Test
Air Conditioning—Temperature Drop Test
Seat—Standard Seat Operational Check
Seat—ActiveSeat™ Operational Check
Seat—Standard Seat Theory Of Operation
Seat—ActiveSeat™ Theory of Operation
Seat Schematic
Seat—Standard Seat Schematic
Seat—ActiveSeat™ Schematic
Seat—ActiveSeat™ Actuator Check
Seat—ActiveSeat™ Pressure and Accumulator Check
Cab and Open Operator`s Station Component Information
Cab and Open Operator’s Station—Summary of References
Cab and Open Operator`s Station Components
A901 ActiveSeat™ Accumulator
A902 ActiveSeat™ Suspension Air Spring Accumulator
A943 Seat Heating Element Controller
C901 ActiveSeat™ Cylinder
C902 Seat Suspension Air Spring
F220 Fresh Air Filter
F221 Circulation Filter
F222 AC Receiver/Dryer
H220 AC Condenser Core
H221 AC Evaporator Core
H222 Heater Core
J901 Standard Seat Shock Absorber
M103 Cab Circulation Fan
M211 Cab Pressurizer Fan
P220 AC Compressor
P901 Seat Suspension Air Compressor
V220 Air Flow Valve
V221 AC Expansion Valve
V222 Heater Valve
V901 ActiveSeat™ Control Valve
V902 ActiveSeat™ Pressure Reducing Valve
X901 ActiveSeat™ Test Port
X220 AC Low Pressure Service Port
X221 AC High Pressure Service Port
Tools
Tools—Summary of References
Dealer Fabricated Tools
DFRW126—Modified Tap Out Harness
DFRW171 — Coupler for Test Gauge
DFRW181—Test Hose Kit
DFRW183—Coupler DR Assembly
DFRW191—Red Glad Hand Assembly
DFRW192—Yellow Glad Hand Assembly
DFRW213—Hydraulic Trailer Brake Test / Bleed Assembly
DFRW221
DFRW247—Female DR Adapter
DFRW251—Rear SCV Calibration Tool
DFRW260—K924 Implement CAN Jumper
Fuel, Air Intake, Exhaust, and Cooling-Install Test Equipment
Install Test Equipment 30—1
AutoPowr / IVT Transmission-Install Test Equipment
JDG1753 Service Jumper Harness Kit Assembly Procedure
Install Test Equipment 50A—1
Install Test Equipment 50A—2
Install Test Equipment 50A—3
Install Test Equipment 50A—4
e23 Transmission - Install Test Equipment
Install Test Equipment 50B—1
Install Test Equipment 50B—2
Install Test Equipment 50B—3
16-Speed PowerShift Transmission (PST)-Install Test Equipment
Install Test Equipment 50C—1
Install Test Equipment 50C—2
Install Test Equipment 50C—3
Hydraulics-Install Test Equipment
Install Test Equipment 70—1
Install Test Equipment 70—2
Install Test Equipment 70—3
Install Test Equipment 70—4
Install Test Equipment 70—5
Install Test Equipment 70—6
Install Test Equipment 70—7
Install Test Equipment 70—8
Install Test Equipment 70—9
Suspension-Install Test Equipment
Install Test Equipment 80—1
Install Test Equipment 80—2
Install Test Equipment 80—3
Install Test Equipment 80—4
Cab and Open Operator`s Station-Install Test Equipment
Install Test Equipment 90A-1
Install Test Equipment 90B—1
Install Test Equipment 90B—2
Page Number
Support
Cleaner
199
94,406,749
#2
John Deere Tractors 8R RW Series 8245R to 8400R Diagnosis and Tests Service Manual TM119019
Brand: John Deere
Type of Machine: Tractors
Type of Manual: Diagnosis and Tests Service Manual, Circuit Diagrams
Model: John Deere 8R RW Series 8245R 8270R 8295R 8320R 8335R 8345R 8370R 8400R Tractors
Serial Number: (090001-119999), Russia (055001-058000), Brazil (000100-)
Number of Page: 7081 pages
Parts Number: TM119019
