John Deere Tractors 6135J 6150J 6170J 6190J 6210J Repair Technical Manual TM804919
Brand: John Deere
Type of Machine: Tractors
Model: John Deere 6135J 6150J 6170J 6190J 6210J Tractors
Part Number: TM804919
Publication Date: 2017
Number of Pages: 1108 Pages
Section 05—Safety
Group 05—Safety
Section 10—General Information
Group 05—Specifications
Group 10—Fuels, Lubricants, and Coolant
Group 15—Serial Numbers
Group 20—Adjustments, Checks, and General Service
Group 25—References for Technical Information
Section 20—Engine
Group 05—Remove and Install Components
Group 10—Monitoring Systems
Section 30—Fuel, Air Intake, Cooling, and
Exhaust System
Group 05—Speed Control
Group 10—Fuel System
Group 15—Air Intake System
Group 20—Cooling System
Group 25—Exhaust System
Group 30—Monitoring Systems
Section 40—Electrical System
Group 05—Connectors
Group 10—Wiring Harnesses
Group 15—Charging System
Group 20—Starter Motor Circuit
Group 25—Fuses, Relays, and Switches
Group 30—Electrical Components
Section 45—Electronic Control Units
Group 05—General Information
Group 10—Remove and Install Components
Section 50A—Drivetrain
Group 05—Remove and Install Components—6135J Tractor
Group 06—Remove and Install Components—6150J Tractor
Group 07—Remove and Install Components—6170J, 6190J, and 6210J Tractor
Group 10—Universal Joints, Driveshafts, and Torsional Damper
Group 15—Front-Wheel Drive Clutch—6135J Tractor
Group 16—Front-Wheel Drive Clutch—6150J Tractor
Group 17—Front-Wheel Drive Clutch—6170J, 6190J, and 6210J Tractors
Group 20—Rear Differential—6135J Tractor
Group 21—Rear Differential—6150J Tractor
Group 22—Rear Differential—6170J, 6190J, and 6210J Tractors
Group 25—Hydraulic Pump Drive
Group 30—Final Drives—6135J Tractors
Group 31—Final Drives—6150J, 6170J, 6190J, and 6210J Tractors
Group 35—Rear Power Take-Off—6135J Tractors
Group 36—Rear Power Take-Off—6150J, 6170J, 6190J, and 6210J Tractors
Group 40—Monitoring Systems
Section 50B—PowrQuad™ Transmission
Group 05—Remove and Install PowrQuad™ Module
Group 10—Transmission Selectors Control
Group 15—PowrQuad™ Module
Group 20—Remove and Install Range Box
Group 25—Range Box
Section 60A—Steering
Group 05—Hydrostatic Steering
Group 10—AutoTrac™ Integrated—6150J, 6170J, 6190J, and 6210J Tractors
Group 15—Monitoring Systems
Section 60B—Brakes
Group 05—Brake Valve
Group 10—Power-Fill Brake Valve
Group 15—Rear Wheel Brakes
Section 60C—Air Trailer Brake
Group 05—Air Brake System
Section 70—Hydraulic System Identification
Group 05—Hydraulic System Identification
Section 70A—PC Hydraulic System—6135J Tractors
Group 05—Rockshaft Controls
Group 10—Hydraulic Pump
Group 15—Valve Block
Group 20—Rockshaft
Group 25—Selective Control Valves and Quick Couplers
Section 70B—PFC Hydraulic System—6135J
and 6150J Tractors
Group 10—Charge Pump and Hydraulic Pump
Group 20—Rockshaft
Section 70C—PFC Hydraulic System—6170J, 6190J, and 6210J Tractors
Group 20—Rockshaft
Group 25—Selective Control Valves and Couplers
Section 80—Miscellaneous
Group 10—Main Frame
Group 15—Front Wheels, Rear Wheels, and Fenders
Group 20—Center Link Bracket and Swinging Drawbar
Group 25—Monitoring Systems
Section 90—Cab
Group 10—Air-Conditioning System
Group 15—Heating System
Group 20—Operator's Cab
Section 99—Tools
Group 05—Special Tools (Dealer-Fabricated)
Brand: John Deere
Section 05—Safety
Group 05—Safety
Section 20—Engine
Exhaust System
Group 05—Connectors
Group 25—Range Box
Section 60B—Brakes
Group 20—Rockshaft
and 6150J Tractors
Group 20—Rockshaft
Group 20—Rockshaft
Group 10—Main Frame
Section 90—Cab
Section 99—Tools
- JOHN DEERE CODE DTC LIST
