John Deere Tractors 6130 - 6930 Diagnostic and Test Service Manual TM400419
Brand: John Deere
Type of Machine: Tractors
Type of Manual: Diagnostic and Test Service Manual
Model: John Deere 6130 6230 6330 6430 6530 6534 6630 6830 6930 Tractors
Part Number: TM400419
Publication Date: 2013
Number of Pages: 3661 Pages
FOREWORD
SERIAL NUMBER BREAK 2009
Section 210 - GENERAL INFORMATION
Group 05 - Safety Measures
Group 10 - General References
Section 211 - DIAGNOSTIC TROUBLE CODES
Group BCU - BCU Control Unit
Group ECU - ECU Control Unit
Group EPC - EPC Control Unit
Group PRC - PRC Control Unit
Group TSC - TSC Control Unit
Section 212 - OBSERVABLE SYMPTOMS
Group 40 - Electronics
Group 45 - Electronic Control Units
Group 50 - SyncroPlus Transmission
Group 51 - PowrReverser Transmission
Group 55 - PowrQuad Transmission
Group 56 - Drive Train (without Transmission)
Group 60 - Steering and Brakes
Group 70 - Hydraulic System
Group 80 - Miscellaneous
Group 90 - Operator′s Cab
Section 213 - SYSTEM DIAGNOSIS
Group 45 - Electronics
Section 220 - ENGINE
Group 05 - General Information
Group 10 - Operational Checks
Group 15 - Tests and Adjustments
Section 230 - FUEL, AIR INTAKE AND COOLING SYSTEMS
Group 20A - Fuel System
Group 20B - Air Intake System
Group 20C - Cooling System
Group 20D - Cold-Weather Starting Aids
Section 240 - ELECTRICAL SYSTEM
Group SE01 - Starting Motor and Charging Circuit
Group SE01A - Fuel Preheater
Group SE01C - Electrical Starting Aid
Group SE02 - Instrument Unit
Group SE03 - Horn
Group SE04 - Operator′s Seat and Cigarette Lighter
Group SE06 - Lights
Group SE07 - Worklights
Group SE09 - Radio, Dome Light and Console Light
Group SE10 - Air Conditioning and Fan
Group SE11 - Windshield Wiper and Washer
Group SE12 - Rear Window Wiper and Washer
Group SE13 - Beacon Light
Group SE14A - 3-Terminal Power Outlet Socket (SAE)
Group SE14B - 3-Terminal Power Outlet Socket (ECE)
Group SE14C - Plug for Accessories
Group SE15 - BCU Control Unit (Electronic Hitch Control)
Group SE16 - BCU Control Unit (Basic Functions)
Group SE17 - Signal Socket and Service Socket
Group SE17A - 7-Terminal Power Outlet Socket (ECE)
Group SE17B - 7-Terminal Power Outlet Socket (SAE)
Group SE20 - TSC Control Unit (Suspension)
Group SE22 - CAN BUS Terminating Resistor
Group SE23 - Level 16 ECU Control Unit (Electronic Engine Control) for 2-Valve Engine with HPCR
Group SE25 - Back-Up Alarm
Group SE26A - EPC Control Unit (Transmission Control with PowrQuad Plus Transmission)
Group SE26B - PRC Control Unit (Transmission Control with Electrically Actuated PowrReverser Transmission)
Group SE26C - SyncroPlus Transmission
Group SE32 - Prewiring for GreenStar
Group 105A - Component Information - Connectors and Contacts
Group 105B - Component Information - Connectors (X001 to X249)
Group 105C - Component Information - Connectors (X250 to X499)
Group 105D - Component Information - Connectors (X500 to X749)
Group 105E - Component Information - Connectors (X750 to X999)
Group 105F - Component Information - Connectors (XGND)
Group 110 - Component Information - Wiring Harnesses
Group 115 - Component Information - Electrical Parts/Components
Group 115A - Component Information - Electrical Parts/Components (Actuators)
Group 115B - Component Information - Electrical Parts/Components (Sensors/Switches/Potentiometers)
Group 115C - Component Information - Electrical Parts/Components (Fuses/Relays/Diodes)
Group 115D - Component Information - Electrical Parts/Components (Headlamps/Lights)
Group 115E - Component Information - Electrical Parts/Components (Other)
Group 120 - Component Information - Ground Connections
Group 125 - Component Information - CAN BUS System
Section 245 - ELECTRONIC CONTROL UNITS
Group 05 - Operation and General Information on Diagnostics
Group 10A - Interactive Tests
Group 10B - Interactive Calibrations
Group 15 - Information on How to Reprogram Control Units
Group 20 - Data BUS Systems
Section 250 - SYNCROPLUS TRANSMISSION
Group 20 - Operation
Section 251 - POWRREVERSER TRANSMISSION
Section 255 - POWRQUAD TRANSMISSION
Section 256 - DRIVE TRAIN (WITHOUT TRANSMISSION)
Group 20A - Front-Wheel Drive Clutch
Group 20B - Differential
Group 20C - Final Drives
Group 20D - Rear PTO Options
Section 260 - STEERING AND BRAKES
Group 05 - Introductory Checks
Group 20A - Hydrostatic Steering
Group 20B - Brake Valve
Group 20C - Rear Brakes
Group 20D - Handbrake
Group 20E - Hydraulic Trailer Brake
Group 20F - Air-Brake System
Section 270 - HYDRAULIC SYSTEM
Group 20A - Oil Filter, Charge Pump and Hydraulic Pump
Group 20B - Hitch
Group 20C - Selective Control Valves (SCVs)
Group 20D - Independent Control Valves (ICVs)
Group 20E - Hydraulic block
Section 280 - MISCELLANEOUS
Section 290 - OPERATOR′S CAB
Group 20A - Ventilation/Heating
Group 20B - Air Conditioning System
Section 299 - SPECIAL TOOLS
Group 05 - Special Tools (Dealer-Fabricated)
Group 10 - Special Tools (Available as Spare Parts)
Brand: John Deere
FOREWORD
Group SE03 - Horn
Group SE06 - Lights
Group 20B - Hitch
- JOHN DEERE CODE DTC LIST
