Martin Welker
104
230,310
John Deere Tractors 6120 - 6520L Repair Technical Manual TM4647
Brand: John Deere
Type of Machine: Tractors
Model: John Deere 6120 6220 6320 6420 6120L 6220L 6320L 6420L 6520L Tractors
Part Number: TM4647
Publication Date: 2005
Number of Pages: 1904 Pages
Cover Page
SEARCH
Contents
SAFETY
Safety Measures
Recognize Safety Information
"Important" Information
"Note" Information
Prevent Machine Runaway
Prevent Battery Explosions
Prepare for Emergencies
Prevent Acid Burns
Avoid High-Pressure Fluids
Service Cooling System Safely
Work In Ventilated Area
Wear Protective Clothing
Practice Safe Maintenance
Park Machine Safely
Use Proper Lifting Equipment
Support Machine Properly
Work in Clean Area
Illuminate Work Area Safely
Service Machines Safely
Use Proper Tools
Service Tires Safely
Service Front-Wheel Drive Tractor Safely
Avoid Eye Contact With Radar
Keep ROPS Installed Properly
Replace Safety Signs
Dispose of Waste Properly
Live With Safety
Safety Measures on Electronic Control Units
GENERAL INFORMATION
Specifications
References, Specifications
Engine Specifications
Injection pump (Lucas)
Injection pump (Bosch VP44)
Electronic Fuel System (Denso Injection Pump; TIER II Engines)
Electronic Fuel System (Stanadyne Injection Pump; TIER II Engines)
Air Intake System
Hydrostatic Steering System
AutoTrac
Clutch
AutoPowr/IVT transmission
PowrQuad and PowrQuad Plus Transmissions
AutoQuad Transmission
Power Reverser
SyncroPlus transmission
Creeper transmission
Rear PTO
Front PTO
Differential assembly
Differential lock
Final drives
Front-Wheel Drive
FWD Axle with TLS
Cab Suspension:
Hydraulic Brakes
Parking Lock
Hydraulic System with Axial Piston Pump
Rockshaft
Front Hitch
Ground Speeds
Front and Rear Wheels
Dimensions and Weights
Capacities
Diesel Fuel
Lubricity of Diesel Fuel
Diesel Engine Break-In Oil
Diesel Engine Oil (Engine Serial Number up to 799999)
Diesel Engine Oil (Engine Serial Number from 800000)
Transmission and Hydraulic Oil
Front-Wheel Drive Axle Oil
Diesel Engine Coolant
Supplemental Coolant Additives
Grease
Oil Filters
Mixing of Lubricants
Lubricant Storage
Operating in Warm Temperature Climates
Hydraulic system inch fitting torques
Hydraulic system metric fitting torques
Product Identification and Sub-Assembly Serial Numbers
Engine serial number
Transmission serial number
Front wheel drive axle serial number
Operator's cab serial number
Operator's seat serial number
Sub-assembly serial numbers
Tune-Up
Summary of References (Tune-Up)
Specifications
Using High-Pressure Washers
Preliminary Engine Test
Tractor Tune-Up
Removing and Cleaning the Primary Air Cleaner Element
Checking the Air Cleaner Safety Element
Installing the Primary Filter Element
Checking the Air Intake System Connections for Leaks
Checking the Crankcase Vent Hose for Clogging
Cleaning the Radiator Grille Screen
Keeping the Radiator Screen Clean
Checking the Caps on the Expansion Tank
Checking the Radiator for Leaks
Checking the Engine Thermostat
Checking the Operation of the Fuel Transfer Pump
Checking the Fuel Filter
Checking the Fuel Filter (Denso/Stanadyne Injection Pump; TIER II Engines)
Bleeding the Fuel System
Bleeding the Fuel System (Stanadyne Injection Pump; TIER II Engines)
Bleeding the Fuel System (Denso Injection Pump; TIER II Engines)
Clean the water trap
Run the engine until it is warm, and check engine speeds
Check setting of fuel injection pump
Check setting of speed control linkage
Cleaning the Battery, Cables and Battery Box with a Clean Cloth
Checking the Neutral Start Circuit
Check operation of starting motor
Checking the lighting circuit
Final engine check
Tractor Operation Check
Predelivery Inspection
ENGINE
Installing and Removing Components
Specifications
Removing the Engine
Installing the Engine
FUEL, AIR INTAKE, COOLING AND EXHAUST SYSTEMS
Speed Control
Summary of References (Speed Control)
Specifications
Adjusting the Hand Throttle Lever and Accelerator Pedal
Adjusting the Speed Control Linkage
Hand Throttle Lever—Exploded View
Accelerator Pedal on Tractors with Open Operator's Station
Accelerator Pedal, with Mechanical Speed Control
Accelerator Pedal, With Electronic Speed Control ("Cruise Control")
Changing the Accelerator Pedal's Potentiometer
Replacing the Accelerator Pedal Assembly (AutoPowr/IVT)
Removing the Accelerator Pedal's Potentiometer
Removing the Hand Throttle's Potentiometer
Fuel System
Summary of References (Fuel System)
Special Tool (Dealer-Fabricated)
Removing the Fuel Tank
Installing the Fuel Tank
Replacing the Fuel Gauge Sending Unit
Changing the Fuel Transfer Pump
Changing the Fuel Filter
Bleed the Air from the Fuel System (with Denso/Stanadyne Injection Pump)
Installing Check Valve in Fuel System
Installing Fuel System Check Valve (Denso/Stanadyne Injection Pump; TIER II Engines)
Air Intake System
Air Intake System (Summary of References)
Air filter - Exploded view
Replacing the Sending Unit for Air Cleaner Restriction (B02)
Cooling System (Summary of References)
Specifications
Removing and Installing the Ring-Shaped Cooler
Remove the Radiator
Change the Fan or the Viscous Fan Drive
Remove and Install the Intercooler
Remove/Install the Intercooler (with TIER II Engines)
Removing and Installing the Expansion Tank
Removing and Installing the Thermostat Valve
Installing the Radiator
Filling the Cooling System with Coolant
Relieving Tension on the Drive Belt
Change the Drive Belt
Replacing the Drive Belt Tensioner
Repairing the Fan Console
Remove and Install Fan Console (with Mechanical Coolant Pump)
Cold-Weather Starting Aid
Summary of References (Cold-Weather Starting Aids)
Fuel Preheater
Electrical Starting Aid
Coolant Heater
Exhaust System
Summary of References (Exhaust System)
Specifications
Exhaust to Top Right
Exhaust to Bottom Right
ELECTRICAL SYSTEM
Connectors
Connectors - Summary of References
Special Tools
General
Using high-pressure washers
Disconnecting electrical circuits
Stripping Wire Ends
Installing a Terminal
WEATHER PACK Connectors
METRI PACK Connector With Terminal Lock at the Rear
METRI PACK Connectors with Terminal Lock at the Front
Connector at CAN Bus Terminating Resistor
Connectors for Electronic Control Units
Connectors
CRIMP SNAP IN connectors
KOSTAL Connectors
DEUTSCH Connectors
Individual Terminals
Fuse and Relay Boxes
Fuse and Relay Box on Tractors with Open Operator's Station
Wiring Harnesses
Wiring Harnesses for Tractors with SyncroPlus or PowrQuad Transmissions and TIER I Engine — Recondition (Summary of References)
Wiring Harnesses for Tractors with SyncroPlus or PowrQuad Transmissions and TIER II Engine — Recondition (Summary of References)
Wiring Harnesses for Tractors with SyncroPlus or PowrQuad Transmission from Serial No. 398656 — Recondition (Summary of References)
Wiring Harnesses for Tractors with PowrQuad Plus Transmission and TIER I Engine — Recondition (Summary of References)
Wiring Harnesses for Tractors with AutoQuad Transmission and TIER I Engine — Recondition (Summary of References)
Wiring Harnesses for Tractors with PowrQuad Plus or AutoQuad Transmission and TIER II Engine — Recondition (Summary of References)
Wiring Harnesses for Tractors with PowrQuad Plus or AutoQuad Plus Transmission from Serial No. 398656 — Recondition (Summary of References)
Wiring Harnesses for Tractors with AutoPowr/IVT Transmission and TIER II Engine — Recondition (Summary of References)
Wiring Harnesses for Tractors with AutoPowr/IVT transmission from Serial No. 398656 — Recondition (Summary of References)
Wiring Harnesses for Tractors with Open Operator's Station and TIER I Engine — Repair (Summary of References)
Wiring Harnesses for Tractors with Open Operator's Station and TIER II Engine — Repair (Summary of References)
Ground Point Locations
Removing and Installing Harness W01 — Power Supply
Remove and Install Harness W01 — Power Supply (Open Operator's Station)
Removing and Installing Harness W02 — Tier I Engine Wiring Harness (without Engine Control or with Level 1 ECU)
Removing and Installing Harness W02 — Tier II Engine Wiring Harness (with Level 12 ECU)
Remove and Install Harness W02 — Engine (Level 12 ECU) from Serial No. 398656
Removing and Installing Harness W02 — Tier II Engine Wiring Harness (with Level 11 ECU) (AutoPowr/IVT Transmission)
Remove and Install Harness W02 — Engine (Level 11 ECU) (AutoPowr/IVT Transmission) from Serial No. 398656
Removing and Installing Harness W02 — TIER I Engine Wiring Harness (Open Operator's Station)
Removing and Installing Harness W02 — Tier II Engine Wiring Harness (with Level 12 ECU) (Open Operator's Station)
Removing and Installing Harness W03 — Starting Aid for TIER I and TIER II Engines (without Engine Control or with Level 1 or 12 ECUs)
Remove and Install Harness W03 — Starting Aid (Level 12 ECU) from Serial No. 398656
Removing and Installing Harness W03 — Starting Aid, for TIER II Engines (with Level 11 ECU) (AutoPowr/IVT Transmission)
Removing and Installing Harness W03 — Starting Aid (Level 11 ECU) (AutoPowr/IVT transmission) from Serial No. 398656
Removing and Installing Harness W04 — Headlights
Removing and Installing Harness W06 — Front-Wheel Drive Axle with TLS
Removing and Installing Harness W07 — Front PTO
Removing and Installing Harness W08 — Cab Harness, for TIER I Engine
Removing and Installing Harness W08 — Cab Harness, for TIER II Engine
Remove and Install Harness W08 — Cab from Serial No. 398656
Removing and Installing Harness W08 — Cab Wiring Harness, for TIER II Engine (AutoPowr/IVT Transmission)
Remove and Install Harness W08 — Cab (AutoPowr/IVT Transmission) from Serial No. 398656
Removing and Installing Harness W08 — Open Operator's Station, for TIER I Engine
Removing and Installing Harness W08 — Open Operator's Station, for TIER II Engine
Removing and Installing Harness W09 — Cab - Cowl, TIER I Engine
Removing and Installing Harness W09 — Cab - Cowl, TIER II Engine
Remove and Install Harness W09 — Cowl from Serial No. 398656
Removing and Installing Harness W09 — Cowl, for TIER II Engine (AutoPowr/IVT Transmission)
Remove and Install Harness W09 — Cowl (AutoPowr/IVT Transmission) from Serial No. 398656
Removing and Installing Harness W09 — Cab - Cowl, TIER I Engine (Open Operator's Station)"
Removing and Installing Harness W09 — Cab - Cowl, TIER II Engine (Open Operator's Station)
Removing and Installing Harness W10 — Shift Console
Removing and Installing Harness W11 — Transmission Shift and Hand Throttle
Removing and Installing Harness W11 — Speed Control Lever and Hand Throttle (AutoPowr/IVT transmission)
Removing and Installing Harness W12 — Command Arm (AutoPowr/IVT transmission)
Removing and Installing Harness W13 — Clutch Sending Unit
Removing and Installing Harness W14 — 3-Terminal Power Outlet Socket
Removing and Installing Harness W14 — 3-Terminal Power Outlet Socket (Open Operator's Station)
Removing and Installing Harness W15 — ECU, for TIER I Engine (without Engine Control)
Removing and Installing Harness W15 — ECU, for TIER I Engine (ECU Level 1)
Removing and Installing Harness W15 — ECU, for TIER II Engine (ECU Level 12)
Remove and Install Harness W15 — Engine Control Unit (Level 12 ECU) from Serial No. 398656
Removing and Installing Harness W15 — ECU, for TIER II Engine (ECU Level 11) (AutoPowr/IVT Transmission)
Remove and Install Harness W15 — ECU (Level 11 ECU) (AutoPowr/IVT Transmission) from Serial No. 398656
Removing and Installing Harness W16 — E-SCV / E-ICV Controller (SIC)
Removing and Installing Harness W17 — Multi-function Unit
Removing and Installing Harness W18 — Windshield Wiper Switch (Without Intermittent Wipe)
Removing and Installing Harness W18 — Windshield Wiper Switch (With Intermittent Wipe)
Removing and Installing Harness W19 — Cab Roof, for TIER I Engine
Removing and Installing Harness W19 — Cab Roof, for TIER II Engine
Removing and Installing Harness W20 — Headlights on Cab Frame
Removing and Installing Harness W21 — Worklights on Front of Cab Roof
Removing and Installing Harness W22 — Worklights on Rear of Cab Roof
Removing and Installing Harness W22 — Xenon (HID) Worklights on Rear of Cab Roof
Removing and Installing Harness W23 — Windshield Wiper
Removing and Installing Harness W24 — Rear Window Wiper
Removing and Installing Harness W25 — Rear Window Wiper Switch
Removing and Installing Harness W26 — Fan and Air-Conditioner
Removing and Installing Harness W26 — Fan and Air-conditioner from Serial No. 398656
Removing and Installing Harness W26 — ClimaTrak (Cab)
Removing and Installing Harness W27 — Turn Signal Lights
Removing and Installing Harness W28 — Front End of Transmission (SyncroPlus and PowrQuad Transmissions)
Removing and Installing Harness W28 — Front End of Transmission (PowrQuad Plus and AutoQuad Transmissions)
Removing and Installing Harness W28 — Front End of Transmission (AutoPowr/IVT transmission)
Remove and Install Harness W28 — Front End of Transmission (Open Operator's Station)
Removing and Installing Harness W29 — Valve Block (AutoPowr/IVT Transmission)
Remove and Install Harness W30 — Rear End of Transmission
Removing and Installing Harness W30 — Rear End of Transmission (Open Operator's Station)
Removing and Installing Harness W31 — 7-Terminal Power Outlet Socket
Removing and Installing Harness W32 — Stepper Motors
Removing and Installing Harness W33 — Service
Removing and Installing Harness W34 — Electric Rear-View Mirrors
Removing and Installing Harness W35 — Access Step Lighting and Battery Cut-off Switch (Version 1)
Removing and Installing Harness W35 — Access Step Lighting and Battery Cut-off Switch (Version 2)
Removing and Installing Harness W36 — GreenStar 60-amp Socket, for TIER I Engine
Removing and Installing Harness W36 — 60-amp GreenStar Implement Socket
Removing and Installing Harness W37 — GreenStar Connection, for TIER I Engine
Removing and Installing Harness W39 — GreenStar (Cab), for TIER I Engine
Removing and Installing Harness W39 — GreenStar with TEC Control Unit (Cab), for TIER I Engine
Removing and Installing Harness W39 — GreenStar with Tractor Equipment interface Controller (Cab)
Removing and Installing Harness W40 — GreenStar (Cab Roof), for TIER I Engine
Removing and Installing Harness W41 — JDLink
Removing and Installing Harness W42 — Battery Cut-Off Switch, Version 1
Removing and Installing Harness W42 — Battery Cut-Off Switch, Version 2
Removing and Installing Harness W43 — Back-Up Alarm
Removing and Installing Harness W43 — Back-Up Alarm (AutoPowr/IVT Transmission)
Removing and Installing Harness W44 — Back-Up Alarm / Switch for Power Reverser or PowrQuad Transmission
Removing and Installing Harness W45 — Back-Up Alarm / Switch for SyncroPlus Transmission
Removing and Installing Harness W47 — ClimaTrak (Cab Roof)
Removing and Installing Harness W48 — ClimaTrak (Cowl)
Removing and Installing Harness W49 — ClimaTrak (Evaporator Housing)
Removing and Installing Harness W50 — GreenStar (CAN BUS Terminator)
Removing and Installing Harness W51 — AutoTrac (Cab)
Removing and Installing Harness W52 — AutoTrac (Steering Angle Sensor)
Removing and Installing Harness W53 — AutoTrac (Command Arm)
Charging Circuit
Special Tools
Specifications
Repairing the Alternator
Disconnecting Electrical Circuits
Relieve Drive Belt Tension
Remove/Install the Alternator
Pulley Removal and Installation
Starter Motor Circuit
Repairing the Starter Motor
Specifications
Removing and Installing the Starting Motor
Fuses, Relays and Switches
Fuses, Relays and Switches - Recondition (Summary of References)
Special or Essential Tools
Specifications
Removing Trim Panels from Cowl
Fuse and Relay Boxes on Tractors with Operator's Cab up to Serial No. 398655
Fuse and Relay Boxes on Tractors with Operator's Cab from Serial No. 398656
Fuse and Relay Boxes on Tractors with Operator's Cab and AutoPowr/IVT Transmission up to Serial No. 398655
Fuse and Relay Boxes on Tractors with Operator's Cab and AutoPowr/IVT Transmission from Serial No. 398656
Replacing the Main Fuses
Replacing Fuses of Electrical Starting Aid, TIER I and TIER II Engine (without engine control or with Level 1 or 12 ECU)
Replacing Fuses of Electrical Starting Aid, TIER II Engine (Level 11 ECU) (AutoPowr/IVT Transmission)
Replacing the LTC Coolant Pump Fuse (AutoPowr/IVT Transmission)
Replace the Fuses for Power Supply to the Implement BUS (60-amp Implement Socket)
Replacing Starting Motor Relay, TIER I and TIER II Engine (without engine control or with Level 1 or 12 ECU)
Replacing Starting Motor Relay, TIER II Engine (Level 11 ECU) (AutoPowr/IVT Transmission)
Replacing Relay of Electrical Starting Aid, TIER I and TIER II Engine (without engine control or with Level 1 or 12 ECU)
Replacing Relay of Electrical Starting Aid, TIER II Engine (Level 11 ECU) (AutoPowr/IVT Transmission)
Replace the Power Supply Relays for the Implement BUS
Replacing the Main Switch
Replacing the Brake Switches
Replacing the Light Switch
Replacing Full/Dipped-Beam Switch
Replacing the Worklight Switches
Replace the Switch for Lights on Cab Frame
Replacing the Beacon Light Switch
Replacing the Hazard Warning Light Switch
Replacing the Turn Signal Switch
Replacing the Horn Switch
Replacing Switches on Multi-Function Unit
Replacing the Rear Window Wiper and Washer Switch
Replacing the Rear Window Switch
Replace the Dome Light Door Switch
Replacing the Front-Wheel Drive Switch
Replacing the Headland Management (HMS) Switch
Replacing the Record/Save Switch
Replace the Program Switch
Replacing the Switch for AutoQuad Transmission
Replace the Switch for Gear Selector and Auto-mode
Replacing the Park Lock Switch on Tractors with PowrQuad Plus, AutoQuad or AutoQuad Plus Transmissions
Replacing the Back-Up Alarm Switch
Replacing the Fan Switch
Replacing the Switch of the Air-Conditioning System Compressor
Replacing the Differential Lock Switch
Replace the PTO Switches
Replacing the Rockshaft Remote Control Switch
Replace the Switches for the Electrical Rear-View Mirrors
Replace the Switch for the Heated Rear-View Mirrors
Replace the Switch for the Heated Rear Window
Replace the AutoTrac Switch
Replacing the Cruise Control Potentiometer on Tractors with AutoQuad Transmission
Replace the Cruise Control Potentiometer on Tractors with AutoPowr/IVT Transmission
Replace the Auto-mode Potentiometer on Tractors with AutoQuad Plus Transmission
Rockshaft Control
Electrical Activators for Selective Control Valves (E-SCV)
Electrical Activators for Independent Control Valves (E-ICV)
Monitoring Systems
Monitoring Systems - Recondition (Summary of References)
Note
Note
Note
Replacing the Engine Speed Sending Unit (B01)
Replacing the Engine Oil Pressure Sending Unit (B04)
Replacing the Sending Unit for the Coolant Temperature Gauge (B08)
Replacing the Acoustic Alarm
Replacing the Acoustic Alarm (Park Lock) on Tractors with AutoPowr/IVT Transmission
Electrical Components
Electrical Components - Recondition (Summary of References)
Special Tools
Specifications
Replacing the 7-Terminal Power Outlet Socket
Replacing the 3-Terminal Power Outlet Socket
Replacing the Multiple Power-Outlet Socket Strip
Replacing the Service Socket
Removing the Wiper Motor
Adjusting the Headlights
Adjusting the Lights on the Cab Frame
Safety Instructions for Replacing a Halogen Bulb
Safety Instructions for Replacing Xenon (HID) Bulbs and Ballast Units
Replacing Xenon (HID) Worklights and Ballast Units
SYNCROPLUS TRANSMISSION
Dealer-Manufactured Special Tools
Specifications
Removing the Clutch Housing
Installing the Clutch Housing
Removing the Gear Transmission
Installing the Gear Transmission
Transmission Shift Controls
SyncroPlus Transmission Shift Units - Reconditioning (Summary of References)
Specifications
Reconditioning the Gear Shift Mechanism
Reconditioning the Range Shift Mechanism
Checking and Adjusting the Shift Units
Adjusting the Clutch Pedal
Perma Clutch II Module
SyncroPlus Transmission, Perma Clutch II Module - Reconditioning (Summary of References)
Specifications
Removing the Clutch
Reconditioning the Clutch
Removing the Transmission Oil Pump
Reconditioning the Transmission Oil Pump
Installing the Transmission Oil Pump
Valves and Other Hydraulic Components
Reconditioning the Engagement Override Valve
Reconditioning the Clutch Cooling Valve
Reconditioning the Cooling Pilot Valve
Reconditioning the Filter Relief Valve
Reconditioning the Pressure-Regulating Valve
Reconditioning the Lube Relief Valve
Reconditioning the Cooler Relief Valve
Reconditioning the Clutch Pedal Valve
Replacing the Temperature and Pressure Sending Units
Gear Transmission
SyncroPlus Transmission, Gear Transmission - Reconditioning (Summary of References)
Specifications
Gear Transmission - Sectional View
Disassembling the Gear Transmission
Reconditioning the Gear Transmission
Preparation for Installing the Gear Transmission
Reconditioning the Shift Cover
Adjusting the Gear Transmission Shift Mechanism
Adjusting the Neutral Start Switch
POWER REVERSER TRANSMISSION
Specifications
Removing the Power Reverser Module
Installing the Power Reverser Module
Removing and Installing the Gear Transmission
Power Reverser Shift Units - Reconditioning (Summary of References)
Specifications
Reconditioning the Forward/Reverse Control
Adjusting the Reverse Drive Lever
Adjusting the Reverse Drive Linkage
Power Reverser Transmission, Power Reverser Module - Reconditioning (Summary of References)
Specifications
Power Reverser Module - Sectional View
Components of Power Train
Removing the Disk Brake
Reconditioning the Disk Brake
Installing the Disk Brake
Removing the Clutch and Planetary Carrier
Reconditioning the Clutch and Planetary Carrier
Installing the Clutch and Planetary Carrier
Reconditioning the Sump Valve
Reconditioning the Accumulator Piston
Reconditioning the Forward/Reverse Valve
Reconditioning the Fwd/Rev Cooling Control Valve
Reconditioning the Modulator Valve
Reconditioning the Connecting Valve
Replacing the Oil Filter
Replacing the Neutral Start Switch
Gear Transmission
Power Reverser Transmission, Gear Transmission - Reconditioning (Summary of References)
Specifications
Adjusting the Shift Mechanism on the Gear Transmission
AUTOPOWR/IVT TRANSMISSION
Specifications
Removing the AutoPowr/IVT Transmission
Installing the AutoPowr/IVT Transmission
AutoPowr/IVT Transmission Shift Units - Reconditioning (Summary of References)
Reconditioning the Speed Control Lever
Reverser control, reconditioning
Reconditioning the Clutch Actuation Mechanism
Reconditioning the Manual Park Lock Release Mechanism
Releasing the Park Lock Manually
Input Housing
AutoPowr/IVT Transmission, Input Housing — Reconditioning (Summary of References)
Special Tools
Specifications
Replace Hydrostatic Unit Speed Sending Unit (B62) (Repair Level 1 and 2)
Replacing Pressure Sending Unit B87, S73, S74 (Repair Level 1 and 2)
Replacing Thermostat Valve (Repair Level 1 and 2)
Replacing Filter By-Pass Valve (Cold-Weather Starting) (Repair Level 1 and 2)
Replacing the Oil Filter (Repair Level 1 and 2)
Removing the System Pressure Control Block (Repair Level 1 and 2)
Installing System Pressure Control Block (Repair Level 1 and 2)
Removing the Transmission Oil Pump (Repair Level 1 and 2)
Reconditioning the Transmission Oil Pump (Repair Level 1 and 2)
Installing the Transmission Oil Pump (Repair Level 1 and 2)
Removing the Vibration Damper (Repair Level 1 and 2)
Reconditioning the Vibration Damper (Repair Level 1 and 2)
Installing the Vibration Damper (Repair Level 1 and 2)
Removing the Front Plate (Repair Level 1 and 2)
Installing the Front Plate (Repair Level 1 and 2)
Removing Clutch Control Block (Repair Level 1 and 2)
Reconditioning Clutch Control Block (Repair Level 1 and 2)
Installing the Clutch Control Block (Repair Level 1 and 2)
Separating the Input and Output Housings (Repair Level 2)
Joining the Input and Output Housings (Repair Level 2)
Removing BG Disk Brake (Repair Level 2)
Installing BG Disk Brake (Repair Level 2)
Removing Shift Turret (Repair Level 2)
Reconditioning the Shift Turret (Repair Level 2)
Installing the Shift Turret (Repair Level 2)
Removing the Hydrostatic Unit (Repair Level 2)
Installing the Hydrostatic Unit (Repair Level 2)
Reconditioning the Hydrostatic Unit Output Shaft (Repair Level 2)
Measuring the Gaps Between Transmission Shafts (Repair Level 2)
Replacing the Wiring Harness / Replacing the Fittings on the Housing (Repair Level 2)
Output Housing
AutoPowr/IVT Transmission, Output Housing — Reconditioning (Summary of References)
Specifications
Replacing Transmission Input Speed Sending Unit (B61) (Repair Level 1 and 2)
Replacing Transmission Output Speed Sending Unit (B63) (Repair Level 1 and 2)
Replace Pressure Sending Unit (B90) for Park Lock Control Block (Repair Level 1 and2)
Replacing the Bleed Valve (Repair Level 2)
Removing the Park Lock Control Block (Repair Level 1 and 2)
Reconditioning the Park Lock Control Block (Repair Level 1 and 2)
Reconditioning the Park Lock Cam (Repair Level 1 and 2)
Installing the Park Lock Control Block (Repair Level 1 and 2)
Removing the Pneumatic Pump (Repair Level 1 and 2)
Removing the Direction Turret and Reverse Intermediate Shaft (Repair Level 2)
Installing Direction Turret and Reverse Intermediate Shaft (Repair Level 2)
Removing the Drive Shaft for the Hydrostatic Unit (Repair Level 2)
Removing the Through-Drive Shaft (Repair Level 2)
Installing the Through-Drive Shaft (Repair Level 2)
Removing the Drive Gear for the Hydrostatic Unit (Repair Level 2)
Removing the Idler Gear with Pneumatic Pump Drive (Repair Level 2)
Installing the Idler Gear with Pneumatic Pump Drive (Repair Level 2)
Replacing the Screw Plugs (Repair Level 1 and 2)
Differential Drive Shaft Assembly
AutoPowr/IVT Transmission, Differential Drive Shaft — Reconditioning (Summary of References)
Specifications
Differential Drive Shaft — Sectional View
Disassembling the Differential Drive Shaft (without Bearings)
Reconditioning the Cover with the Park Lock Pawl
Assembling the Differential Drive Shaft (without Bearings)
Replacing the Differential Drive Shaft / Reconditioning the Bearings
POWRQUAD, POWRQUAD PLUS AND AUTOQUAD TRANSMISSIONS
Specifications
PowrQuad Plus Transmission, Removal and Installation
AutoQuad Transmission, Removal and Installation
Removing the PowrQuad Transmission
Installing the PowrQuad Transmission
Removing Creeper or Option Transmissions
Installing Creeper or Option Transmissions
Removing the Range Transmission
Installing the Range Transmission
PowrQuad Transmission Shift Units - Reconditioning (Summary of References)
Specifications
Gear Shift Linkage, Reconditioning (Reverser Control on Steering Column)
Range Shift Linkage, Reconditioning (Reverser Control on Steering Column)
Reconditioning the Reverser Control (on Steering Column)
Adjusting the Reverse Drive Lever (Reverser Control on Steering Column)
Checking and Adjusting the Shift Mechanisms/Linkages (Reverser Control on Steering Column)
Repairing the Range Shift Linkage (PowrQuad Plus and AutoQuad Transmissions)
Check and Adjust the Shift Controls/Linkages (PowrQuad Plus and AutoQuad transmissions)
Adjust the Clutch Pedal (PowrQuad Transmission)
Reconditioning the Clutch Actuation (PowrQuad Plus & AutoQuad Transm.)
PowrQuad Module
PowrQuad, PowrQuad Plus and AutoQuad Transmissions - Summary of References
Specifications
Transmission Components
Replacing the Neutral Start Circuit (with Mech. Actuated PowrQuad Module)
Replace Temperature Sensor and Pressure Switches
Removing and Installing the Oil Filter Housing
Removing and Installing the Front Valve Housing
Removing and Installing the Valves in the Front Valve Housing
Removing and Installing the Valves in the Front Valve Housing (with Mech. Actuated PowrQuad Module)
Remove and Install the Front Transmission Cover
Removing and Installing the Valves in the Front Transmission Cover
Removing and Installing the Valves in the Front Transmission Cover (with Mech. Actuated PowrQuad Module)
Replacing the Clutch Pedal Valve (with Mech. Actuated PowrQuad Module)
Removing and Installing the Shift Valve Housing
Remove and Install the Valves in the Shift Valve Housing
Removing and Installing the Shift Valve Housing (with Mech. Actuated PowrQuad Module)
Removing and Installing the Valves in the Shift Valve Housing (with Mech. Actuated PowrQuad Module)
Removing the Gear-Shift Planetary Drive
Repairing the Gear-Shift Planetary Drive
Install Gear-Shift Planetary Drive
Removing the B1 Brake Housing
Reconditioning the B1 Brake
Installing the B1 Brake Housing
Removing the B2-B3 Brake Housing
Reconditioning the B2 Brake
Reconditioning the B3 Brake
Installing the B2-B3 Brake Housing
Removing the C4 Clutch
Recondition the C4 Clutch
Installing the C4 Clutch
Removing the Reverse Brake
Reconditioning the Reverse Brake
Installing the Reverse Brake
Removing the Forward Clutch with Planetary Drive (Forward/Reverse)
Recondition Forward Clutch with Planetary Drive (Forward/Reverse)
Installing the Forward Clutch with Planetary Drive (Forward/Reverse)
Replacing the Output Shaft
Creeper Transmission
Creeper Transmission - Reconditioning (Summary of References)
Specifications
Removing the Creeper Transmission
Reconditioning the Creeper Transmission
Installing the Creeper Transmission
Option Transmission
Option Transmission - Reconditioning (Summary of References)
Specifications
Removing the Option Transmission
Reconditioning the Option Transmission
Installing the Option Transmission
Range Transmission
Range Transmission- Reconditioning (Summary of References)
Specifications
Range Transmission - Sectional View
Reconditioning the Range Transmission
Replacing the Transmission Speed Sensor (B104)
DRIVE SYSTEMS
Specifications
Removing the FWD Clutch
Installing the FWD Clutch
Removing the Differential Housing
Installing the Differential Housing
Removing the Final Drives
Installing the Final Drives
Removing the Rear PTO
Installing the Rear PTO
Removing the Front PTO
Installing the Front PTO
U-Jointed Shafts and Torsion Damper
Summary of References (U-Jointed Shafts and Torsion Damper)
Special Tools
Use of Special Tool KJD10426
Specifications
Remove U.J. Shaft (Front-Wheel Drive)
Reconditioning the U.j. Shaft (FWD)
Installing the U.j. Shaft (FWD)
Removing the U.j. Shaft (Engine)
Removing the Torsion Damper
Changing the Torsion Damper Bearings
Installing the Torsion Damper
Installing Engine U.J. Shaft
Front-Wheel Drive Clutch
Front-Wheel Drive Clutch - Reconditioning (Summary of References)
Special Tools
Other Material
Specifications
Replacing the Sending Unit for Front-Wheel Drive Axle Speed (B89)
Disassembling the Front Wheel Drive Clutch
Front-Wheel Drive Clutch — Exploded View
Assembling the Front-Wheel Drive Clutch
Differential - Reconditioning (Summary of References)
Specifications
Replacing the Sending Unit (B09 or B35 or B84)
Differential — Exploded View
Hydraulic Pump Drive
Specifications
Reconditioning the Hydraulic Pump Drive
Adjusting the Hydraulic Pump Drive
Final Drives
Specifications
Reconditioning the Final Drives
Rear PTO
Rear PTO Options — Summary of References
Special Tools
Dealer-Fabricated Special Tools
Other Material
Specifications
Replacing the Output Shaft Seal Ring
Changing the O-Ring on Reversible PTO
Removing the PTO Clutch
Reconditioning the PTO Clutch
Installing the PTO Clutch
Reconditioning the PTO Brake
Disassembling the PTO Drive Train
Reconditioning the Output Shaft (540/1000 rpm Reversible)
Reconditioning the Countershaft (540/1000 rpm)
Assembling the PTO Drive Train
Adjusting Taper Roller Bearing at Output Shaft
Adjusting the Taper Roller Bearing of the Countershaft
Installing the Support and Adjusting the Taper Roller Bearings
Installing the PTO Housing
Removing the PTO Modulating Valve
Reconditioning the PTO Modulating Valve
Installing the PTO Modulating Valve
Repairing the Solenoid Valve
Replacing the PTO Speed Sending Unit
Front PTO
Front PTO - Reconditioning (Summary of References)
Other Material
Specifications
General Repair Procedures
Replacing the Solenoid Valve
Replacing the Front PTO Speed Sending Unit (B58)
Cleaning and Replacing the Filter
Checking the Cooler Relief and Filter By-Pass Valves
Removing and Installing the Valve Plate
Front PTO — Sectional View
Disassembling the Front PTO
Reconditioning the Oil Pump
Reconditioning the Intermediate Gear Shaft (PTO Rotating Counterclockwise)
Reconditioning the Drive Shaft
Assembling the Front PTO
Front Implement Drive
Front Implement Drive (Summary of References)
Special Tools
Specifications
Summary of Torques
Preliminary work
Removing and Installing the Drive Shaft Adapter
STEERING AND BRAKES
Hydrostatic Steering (Summary of References)
Special Tools
Specifications
Preliminary Work
Disconnect/Connect Steering or Brake Hoses
Steering Valve - Removal (Tractors with Cab)
Steering Valve - Removal (Tractors without Cab)
Disassembling the Steering Valve
Exploded View of Steering Valve
Assembling the Steering Valve
Adjusting the Shock Valves
Steering Wheel and Steering Column (With Cab)
Steering Wheel and Steering Column (Tractors without Cab)
Recondition the Steering Column
Steering Valve - Installation (Tractors with Cab)
Steering Valve - Installation (Tractors without Cab)
Steering Cylinder
Steering Cylinder (Summary of References)
Specifications
Removing the Steering Cylinder
Disassembling the Steering Cylinder
Assembling the Steering Cylinder
Installing the Steering Cylinder
Brake Valve
Summary of References (Brake Valve)
Special Tools
Specifications
Accumulators - Remove and Install from Tractor Serial Number 440694
Brake Valve (With Power Fill)
Power-Fill Brake Valve with MFWD and Disk Brake
Rear Brakes
Summary of References (Rear Brakes)
Specifications
Removing the Rear Brakes
Installing the Rear Brake
Checking Brake Pistons for Return Movement and Leakage
Final assembly
Bleeding the Brakes (Brake Valve, Power-Fill Brakes/MFWD and Disk Brake)
AutoTrac
Summary of References (AutoTrac)
Removal and Installation of Steering Control Valve (Y49)
Removal and Installation of Steering Input Device (B138)
Controls
Hydraulic System — Controls (Summary of References)
Specifications
Selective Control Valves — Removing and Installing the Actuating Elements
Selective Control Valves — Adjusting the Bowden Cable
Removing and Installing the Multifunction Lever
Adjusting the Multi-Function Lever
Hydraulic Pump and Charge Oil Pump
Other Material
Specifications
Removing and Installing the Charge Pump
Reconditioning the Charge Pump
Charge Pump - Checking the Lube Oil Valve
Hydraulic Oil Reservoir — Restrictor
Hydraulic Pump — Removing and Installing the Pressure-and-Flow Controller
Hydraulic Pump — Reconditioning the Pressure-and-Flow Controller
Removing and Installing the Hydraulic Pump
Valves
Reconditioning the Hydraulic System Valves — Summary of References
Special Tools
Special Tools (Dealer Fabricated)
Specifications
Hydraulic System — General Instructions on Safety and Repair
Direct Control of Rockshaft
Rockshaft Valve (Narrow Version) — Removal and Installation of Spacer Housing
Removing the Rockshaft Valve
Recondition the Rockshaft Valve
Rockshaft Valve — Depth to Which Raising and Lowering Valves are Screwed In
Rockshaft Valve — Removing and Installing the Stepper Motor
Rockshaft Valve — Centering the Stepper Motor
Installing the Rockshaft Valve
Removing the Main Block
Reconditioning the Main Block
Installing the Main Block
Reconditioning the Hydraulic Oil Filter
Rockshaft
Other Material
Specifications
Rockshaft — Removing and Installing the Electronic Control Unit
Rockshaft — Removing and Installing the Position Sensor and Toothed Segment
Rockshaft — Removing and Installing the Rockshaft
Rockshaft — Removing the Rockshaft Cylinders
Rockshaft — Reconditioning the Rockshaft Cylinders
Rockshaft — Installing the Rockshaft Cylinders
Rockshaft — Removing and Installing the Draft Sensors and Draft Link Bearing Pins
Selective Control Valves and Couplers
Reconditioning the Selective Control Valves and Couplers — Summary of References
Special Tools
Other Material
Specifications
Reconditioning the Selective Control Valves and Couplers — General Instructions on Safety and Reconditioning
SCV Identification
Arrangement of the Shuttle Valves
Removing the Selective Control Valves
Series 200/300 Selective Control Valves — Replacing the Control Knobs
Series 200/300 Selective Control Valves — Inspecting the Check Valves
Series 200/300 Selective Control Valves — Inspecting the Inlet Check Valve and Metering Valve
Series 200 Selective Control Valves — Reconditioning
Series 300 Selective Control Valves — Inspecting the Pressure Compensator Valve
Series 300 Selective Control Valves — Reconditioning
Installing the Selective Control Valves
Selective Control Valves — Installing the Endplate
Selective Control Valves — Reconditioning the Couplers
Independent Control Valve (ICV)
Reconditioning Independent Control Valves — Summary of References
Other Material
Specifications
Removing the Independent Control Valve (M-ICV)
Recondition the Independent Control Valve (M-ICV)
Independent Control Valves — Reconditioning the Inlet Plate
Assemble the Independent Control Valve (M-ICV)
Installing the Independent Control Valve (M-ICV)
Independent Control Valve (E-ICV) — Removing and Installing the Stepper Motors
Removing the Independent Control Valve (E-ICV)
Recondition the Independent Control Valve (E-ICV)
Assembling the Independent Control Valves (E-ICV)
Installing the Independent Control Valve (E-ICV)
MISCELLANEOUS
Specifications
Removing and Installing the Main Frame (Summary of References)
Removing the Main Frame
Removing and Installing the Front Axle or Front-Wheel Drive Axle (Summary of References)
Removing the Front Axle
Removing the Front-Wheel Drive Axle
Installing the Front-Wheel Drive Axle
Removing the Front-Wheel Drive Axle With TLS
Installing the Front-Wheel Drive Axle With TLS
Removing and Installing the Front Axle Support (Summary of References)
Removing the Front Axle Support
Main Frame
Specifications
Recondition the Main Frame (with or without TLS front-wheel drive axle)
Front Axle
Specifications
Front Axle - Reconditioning (Summary of References)
Reconditioning the Front Axle
Checking and Adjusting Toe-In
Front Wheels, Rear Wheels and Fenders
Front Wheels, Rear Wheels and Fenders - Reconditioning (Summary of References)
Specifications
Pivoting Front Fender
Removing the Front and Rear Wheels
Reconditioning the Front and Rear Wheels
Installing the Front and Rear Wheels
Trailer Mounting and Swinging Drawbar
Tightening Torque On Center Link Bracket
Tightening Torques On Swinging Drawbar
Tightening Torques On High-Clearance Drawbar
Adjusting the High-Clearance Drawbar
Adjusting the Retaining Strap
Triple Link Suspension (TLS) of Front-Wheel Drive Axle
Triple Link Suspension (TLS) of FWD Axle (Summary of References)
Other Material
Specifications
Relieving Pressure in the Hydraulic System
Removing/Installing the Oscillation Limiter
Removing the Panhard Link
Installing the Panhard Link
Removing and Installing the Sensor Rod
Removing the Position Sensor
Reconditioning the Position Sensor
Removing the Hydraulic Cylinder
Repairing the Hydraulic Cylinder
Installing the Hydraulic Cylinder
Removing the Control Valve Block
Repairing the Valves in the Control Valve Block
Installing the Control Valve Block
Removing the Accumulator
Installing the Accumulator
Removing and Reconditioning the Bearing Support
Installing the bearing support
OPERATOR'S CAB
Special Tools
Specifications
Operator's Cab / Open Station, Tilting or Removing and Installing
Tilting the Operator's Cab Upward
Tilting the Operator's Cab Downward
Removing the Operator's Cab
Installing the Operator's Cab
Removing the Open Operator's Station
Installing the Open Operator's Station
Controls and Instruments
Controls and Instruments (Summary of References)
Replacing Bulbs on the Instrument Unit
Removing Control Unit
Removing Control Unit for the Lighting System
Instructions when Replacing a Control Unit
Replacing the UIM Control Unit
Replacing a VTI Display
Replacing a BCU Control Unit
Replacing a BCU Control Unit (Tractors without Cab)
Replacing a TCU Control Unit
Replacing an SFA Control Unit
Replacing an SIC Control Unit
Replacing an ECU Control Unit
Replacing an ECU Control Unit (Tractors without Cab)
Replacing an UIC/PLC Control Unit
Replacing the Terminating Resistors
Replacing the Performance Monitor (PRF)
Replace the Basic Informator (BIF)
Replacing Instrument Unit (Tractors without Cab)
Replace Operation Unit
Air Conditioning System
Air-Conditioning System (Summary of References)
Specifications
Torques for Tightening Refrigerant Hoses
Safety At Work
Handling Refrigerant
In an Emergency
Safety Equipment
Storage of Refrigerant Containers
R134A Refrigerant
Important Note
Other Materials Specifications
Lay-Out of Refrigerant Hoses
Discharging the Air-Conditioning System
Evacuating the Air-Conditioning System
Filling with Refrigerant Oil
Instructions for Starting Up the DENSO Air-Conditioning Compressor
Charging the Air-Conditioning System
Leak Test
Removing the Compressor
Checking Level in the Compressor
Disassembling the Compressor Clutch
Checking Clutch Hub Clearance
Checking the Compressor Manifold
Installing the Compressor
Removing and Installing the Condenser
Removing and Installing the Receiver-Drier
Removing and Installing the Evaporator and Expansion Valve
Replacing the Expansion Valve
Installing Condensation Water Drain Hoses
Removing and Installing the Thermostat Switch
Adjusting Thermostat Switch Bowden Cables
Removing and Installing the High/Low Pressure Switch
ClimaTrak
ClimaTrak - Summary of References
Removing and Installing the ATC Controller (ClimaTrak)
Removing and Installing the Driver Unit for Fan Motor (A59)
Removing and Installing the Sending Unit for Ambient Temperature (Front) (B125)
Removing and Installing the Sending Unit for Ambient Temperature (Rear) (B126)
Removing and Installing the Sending Unit for Inside Air Temperature (B127)
Removing and Installing the Sending Unit for Actual Outlet Air Temperature (B128)
Removing and Installing the Sending Unit for Evaporator Core Temperature (B129)
Removing and Installing Sending Unit for Refrigerant Pressure (B130)
Water Valve (B131) Removal and Installation
Mode Control for Position of Air Distribution Flaps (B132), Removal and Installation
Remove and Install the Defog sensor (B143)
Heating System
Heating System (Summary of References)
Removal and Installation of Components
Adjusting Air Flow Bowden Cables
Seats
Seats (Summary of References)
Specifications
Exploded View of Comfort Seat MSG44-A1
Super Comfort Seat MSG83
Comfort Seat MSG85
Air comfort seat MSG95, lower section
Exploded View of the Instructional Seat
Operator's Cab
Operator's Cab (Summary of References)
Removing Cab Frame
Torques for Hardware on Platform Mounting (2-Post ROPS, Standard Version)
Cab Mounting Torques
Removing the Outer Roof
Removing and Installing the Windshield
Removing and Installing the Rear Window
Removal and Installation of Panoramic Windshield
Installing Door Lock
Adjusting Windshield and Rear Window Contact Pressure
Operator's Cab Door Removal and Installation
Roller Sun-Visor Removal and Installation
Removing Inner Roof Trim
Low-Clearance Cab
Low-Clearance Cab (Summary of References)
Special Tools
Specifications
Removing the Cab Frame
Removal and installation of Cab Mountings
Removing Outer Roof
Remove Windshield
Install Windshield
Removing the Rear Window
Installing the Outer Roof
Removing Cab Frame Trim Panel and Speaker Panel
Removing the Cab Door
Installing the Cab Door
Replacing the Rear-View Mirror
Installing and Adjusting the Door Lock
Removing the Upper and Lower Side Panels From the Cab Door
Installing the Upper and Lower Side Panels In the Cab Door
Cab Suspension
Cab Suspension — Summary of References
Important Instructions
Specifications
Relieving Hydraulic System Pressure
Installing and Removing the Cab Suspension Shields
Adjusting the Sensor Rod
Removing Hydraulic Cylinder
Installing Hydraulic Cylinder
Reconditioning the Valves in the Control Valve Block
Panhard Link Removal and Installation
Bleeding Cab Suspension Hydraulic Cylinders
Special Tools (Dealer-Fabricated)
DFLX2 - Suspension Device
DFLX3 ł Suspension Device for PowrQuad Module
Lifting Device for Low Clearance Cab
DFLX13 - Holding Device
Suspension Eyes for Operator's Cab
Holding Device
Holding Tool
DFLX16 - Wooden Block
DFRW79 ł Piston Holding Tool
DFLX22 ł Socket Wrench Insert
DFLX24 - Seal Installer
DFLX25 ł Driver
DFLX17 - Assembly and Guide Mandrels
Turning Device
Bushing
DFLX27 ł Driver
DFLX23 ł Socket Wrench Insert
DFLX21 - Special Wrench
Special Tools (available from the dealer)
D01042AA ł Load-Positioning Sling
D05007ST ł Tractor Splitting Stand
JDE83 ł Flywheel Turning Tool
JDG19 ł Special Mounting Brackets
JDG18 - Snap Ring Tool
JDG23 ł Lifting Sling
JDG749 - 1.30 m (52 in.) Torque Extension
JDG750 ł Swivel Socket
JDG820 ł Flywheel Turning Tool
JT05723 ł Medium-Duty Rear Tractor Splitting Stand
JT05724 ł Medium-Duty Front Tractor Splitting Stand
JT05725 ł Universal Support Stand
JT02044 ł Support Stand
KJD10173 ł Shaft Puller
KJD10178B ł Cab Tilting Device (NA)
KJD10169 - Special Puller
KJD10293 ł Disconnecting Tool
Page Numbers
