Martin Welker
104
230,310
John Deere Tractors 6105E 6120E 6135E Final Tier IV Repair Manual TM608619
Brand: John Deere
Type of Machine: Tractors
Type of Manual: Repair Manual
Model: John Deere 6105E 6120E 6135E Final Tier IV Tractors
Serial Number: 000001-
Part Number: TM608619
Publication Date: 2015
Number of Pages: 699 Pages
FOREWORD
Section 10 - GENERAL INFORMATION
Group 05 - Safety
Recognize Safety Information
Understand Signal Words
Replace Safety Signs
Follow Safety Instructions
Work In Ventilated Area
Practice Safe Maintenance
Avoid Backover Accidents
Prevent Machine Runaway
Avoid Contact with Agricultural Chemicals
Clean Vehicle of Hazardous Pesticides
Use a Safety Chain
Work in Clean Area
Dispose of Waste Properly
Avoid Harmful Asbestos Dust
Avoid Hot Exhaust
Clean Exhaust Filter Safely
Handle Fuel Safely—Avoid Fires
Prepare for Emergencies
Avoid High-Pressure Fluids
Install All Guards
Use Proper Lifting Equipment
Illuminate Work Area Safely
Live With Safety
Service Machines Safely
Support Machine Properly
Park Machine Safely
Stay Clear of Rotating Drivelines
Use Proper Tools
Service Tires Safely
Keep ROPS Installed Properly
Wear Protective Clothing
Handling Batteries Safely
Service Cooling System Safely
Deliver Safely
Transport Tractor Safely
Servicing Electronic Control Units
Welding Near Electronic Control Units
Keep Electronic Control Unit Connectors Clean
Service Front-Wheel Drive Tractor Safely
Do Not Open High-Pressure Fuel System
Group 10 - General Information
Sealants and Adhesives Cross-Reference Chart
Face Seal Fittings Assembly and Installation—All Pressure Applications
Metric Face Seal And O-Ring Stud End Fitting Torque Chart—Standard Pressures
Metric Face Seal and O-Ring Stud End Fitting Torque Chart—High Pressure Applications
SAE Face Seal and O-Ring Stud End Fitting Torque Chart—Standard Pressures
SAE Face Seal and O-Ring Stud End Fitting Torque Chart—High Pressure Applications
Four Bolt Flange Fittings Assembly and Installation—All Pressure Applications
SAE Four Bolt Flange Cap Screw Torque Values—Standard Pressure Applications
SAE Four Bolt Flange Cap Screw Torque Values—High Pressure Applications
External Hexagon Port Plug Torque Chart
Prevent Hydraulic System Contamination
Check Oil Lines and Fittings
Basic Electrical Component Handling / Precautions For Vehicles Equipped With Computer Controlled Systems
Identify Zinc-Flake Coated Fasteners
Use Torque Wrench Adapter
Glossary of Terms
Group 15 - Fuel and Lubricants
Filling Fuel Tank
Filling Diesel Exhaust Fluid (DEF) Tank
Diesel Engine Coolant (engine with wet sleeve cylinder liners)
Operating in Warm Temperature Climates
John Deere COOL-GARD™ II Coolant Extender
Water Quality for Mixing with Coolant Concentrate
Diesel Exhaust Fluid (DEF) — Use in Selective Catalytic Reduction (SCR) Equipped Engines
Disposal of Diesel Exhaust Fluid (DEF)
Refilling Diesel Exhaust Fluid (DEF) Tank
Storing Diesel Exhaust Fluid (DEF)
Testing Diesel Exhaust Fluid (DEF)
Testing Coolant Freeze Point
Extended Diesel Engine Oil Service Intervals
Diesel Engine Oil — Interim Tier 4, Final Tier 4, Stage IIIB, and Stage IV
Engine Oil and Filter Service Intervals — Interim Tier 4, Final Tier 4, Stage IIIB, and Stage IV Engines
John Deere Break-In Plus™ Engine Oil — Interim Tier 4, Final Tier 4, Stage IIIB, and Stage IV
Oil Filters
Fuel Filters
Diesel Fuel
Lubricity of Diesel Fuel
Testing Diesel Fuel
BioDiesel Fuel
Minimizing the Effect of Cold Weather on Diesel Engines
Supplemental Diesel Fuel Additives
Grease
Mixing of Lubricants
Lubricant Storage
Transmission, Steering, Brake, Hydraulic, and Gear Case Oil
Oilscan™ and CoolScan™
Group 20 - Serial Number Locations
Serial Numbers
Product Identification Number
MFWD Axle Serial Number (If Equipped)
Engine Serial Number
Fuel Injection Pump Serial Number
Transaxle Serial Number
Cab Serial Number
Selective Control Valve (SCV) Serial Number
Section 20 - ENGINE REPAIR
Group 05 - Engine
Essential or Recommended Tools
Other Material
Specifications
Remove Engine
Install Engine
Remove and Install Rocker Arm Cover
Repair Engine—Use CTM
Group 10 - Cooling System
Specifications
Test Radiator and Deaeration Tank
Test Radiator Cap
Drain Coolant
Remove and Install Radiator
Remove and Install Cooling Package
Remove and Install Deaeration Tank
Replace Belt Tensioner
Remove and Install Viscous Clutch
Cooling System Repair—Use CTM
Section 30 - FUEL, AIR INTAKE, AND EXHAUST SYSTEMS
Group 05 - Fuel System
Specifications
Remove and Install Fuel Tank
Remove and Install DEF Tank
Replace Fuel Level Sender
Remove and Install Fuel Supply Pump
Remove, Inspect and Install Fuel Cooler
Replace Fuel Strainer and In-Line Check Valve
Group 10 - Air Intake System
Specifications
Remove, Inspect and Install Air Cleaner Elements
Remove and Install Air Cleaner
Remove, Inspect and Install Charge Air Cooler (CAC)
Air Intake Pipe Connections
Group 15 - Exhaust System
Other Material
Specifications
Repair Engine Exhaust System Components—Use CTM
Remove and Install DEF Dosing Injector
Remove and Install After treatment Device
Remove and Install Decomposition Tube
Remove and Install Exhaust Pipe and Selective Catalyst Reduction (SCR) Assembly
Section 40 - ELECTRICAL SYSTEM
Group 05 - Charging Circuit
Specifications
Repair Alternator—Use CTM
Remove and Install Alternator
Group 10 - Starting Circuit
Specifications
Repair Starter—Use CTM
Remove and Install Starter Motor
Group 15 - Electrical System Components
General Repair Procedures
Repair Engine Electrical System Components—Use CTM
Remove and Install Battery
Remove and Install Instrument Panel
Replace Key Switch
Remove and Replace Light Switch
Replace Turn Signal Switch
Remove and Replace EH Directional Reverser Lever
Remove and Install Acceleration Potentiometer (Shuttle Control)
Replace Horn Switch
Replace Starter Relay
Replace Speakers
Replace Antenna
Replace Wiper Control Switch
Remove And Install Wiper Motor
Replace Blower Control Switch
Replace Air Conditioning Temperature Control Switch
Replace Blower Motor Resistor
Replace A/C High/Low Pressure Switch
Replace Dome Light
Replace Door Switch
Replace Electro-Hydraulic Control (EHC) Unit—OOS
Replace Electro-Hydraulic Control (EHC) Unit—Cab
Replace Engine Control Unit (ECU)
Group 20 - Wiring Harnesses
Other Material
Use Electrical Insulating Compound
Using High-Pressure Washers
Repair AMP™ Connector
Repair AMPSEAL 16™ Connectors
CAN Controlled SCV Connectors
Remove Connector Body from Blade Terminals
CINCH™ Control Unit Connectors
Exploded View—CINCH™ FlexBox Connectors
Repair CPC™ Blade Type Connectors
Repair CPC™, Large Mate-N-Loc™, and Metrimate™ Pin Type Connectors
Repair DEUTSCH™ Connectors
Repair ITT Connector
Repair Small Mate-N-Loc™ Socket Connector
Repair Small Mate-N-Loc™ Pin Connector
Repair (Pull Type) Metri-Pack™ Connectors
Repair (Push Type) Metri-Pack™ Connectors
Repair Molex™ Control Unit Connectors
Repair Molex™ Connector
Repair SUMITOMO™ Connectors
Repair Tyco™ Fuel Injector Connector
Repair WEATHER PACK™ Connector
Repair YAZAKI™ Connectors
Replace W010 Positive Battery Cable
Replace W011 Negative Battery Cable
Replace W012 Engine Power Cable
Replace W013 Cab Power Cable
Replace W014 OOS Power Cable
Replace W021 Operator Station Ground Cable
Replace W100 Hood Harness
Replace W300 Chassis Harness (PR, OOS)
Replace W320 Engine Harness
Replace W502 Cab Harness
Replace W572 Transmission Harness
Replace W600 DEF Harness
Replace W700 Mid-Mount SCV Harness (Cab)
Replace W701 Mid-Mount SCV Harness (OOS)
Replace W902 Front Console Harness
Replace W920 Roof Harness
Section 50 - DRIVE SYSTEMS AND TRANSMISSION
Group 00 - Towing
Towing Tractor (12 Speed Transmission)
Group 05 - Component Removal
Other Material
Specifications
Transaxle Separation and Repair
Transmission Component Identification
Transmission Drain Plug Locations
Remove and Install Rear PTO Drive Shaft Assembly
Remove and Install Final Drive Assembly
Remove, Inspect and Install MFWD Drive Shaft
EH-MFWD Component Identification
Remove and Install MFWD Drop Gearbox (If Equipped)
Remove and Install EH-MFWD Drop Gearbox (If Equipped)
Split Tractor
Group 10 - PTO
PTO Repair—Use CTM
PTO Component Identification
PTO Clutch Component Identification
Group 15 - Clutch
Other Material
Specifications
Remove, Inspect, and Repair Clutch Pedal and Linkage—PR Transmission
Remove and Install Clutch Pedal Position Sensor
Adjust Interlock Cable
Section 60 - STEERING AND BRAKES
Group 05 - Steering Repair
Other Material
Specifications
Remove and Install Steering Wheel
Remove and Install Tilt/Telescoping Steering Column
Remove and Install Steering Valve (Open Operator Station)
Remove and Install Steering Valve (Cab Tractors)
Disassemble and Inspect Steering Valve
Assemble Steering Valve
Start-Up Procedure After Hydraulic System Repairs
Group 10 - Front Axle—2WD
Other Material
Specifications
Remove Front Axle—2WD
Install Front Axle—2WD
Disassemble Front Axle—2WD
Assemble Front Axle—2WD
Adjust Knuckle and Spindle Assembly Axial Play—2WD
Assemble Wheel Hub—2WD
Adjust Wheel Bearings—2WD
Remove and Install Axle Pivot Pins/Bushings—2WD
Install Tie Rod—2WD
Check And Adjust Toe-In—2WD
Remove and Install Steering Cylinder—2WD
Disassemble, Inspect and Assemble Steering Cylinder—2WD
Group 15 - Front Axle—MFWD
Specifications
Remove, Inspect and Install Tie Rod Assembly—MFWD
Check And Adjust Toe-In—MFWD
Remove and Install Steering Cylinder—MFWD
Disassemble, Inspect and Assemble Steering Cylinder—MFWD
Remove Front Axle—MFWD
Install Front Axle—MFWD
Group 20 - Brake Repair
Specifications
Remove and Replace Brake Pedals and Linkage
Adjust Brake Linkage and Pedal Travel
Section 70 - HYDRAULICS
Group 05 - Hydraulic Pump
Specifications
Remove and Install Hydraulic Pumps
Disassemble, Inspect and Assemble Hydraulic Pumps
Group 10 - Hydraulic Oil Cooler
Remove, Inspect and Install Hydraulic Oil Cooler
Group 15 - Hitch Valve
Other Material
Specifications
Disassemble and Assemble Control Linkages and Levers—(OOS)
Disassemble and Assemble Control Cables and Levers—(Cab)
Inspect and Repair Hitch Control Box
Remove and Install Hitch Valve
Replace Main Relief Valve
Replace Shock Relief Valve
Remove, Inspect and Install Rate-of-Drop Valve
Remove, Inspect and Install Load Sense Relief Valve
Inspect and Repair Draft Sensing Assembly
Install Draft Link Shaft
Remove, Inspect and Install Lift Arms
Remove, Inspect and Install Lift Cylinders
Draft Control and Position Control Linkage Adjustment—OOS
Draft Control and Position Control Cable Adjustment—Cab
3-Point Hitch Position Feedback Linkage Adjustment
Draft Sensing Feedback Cable Adjustment
Group 20 - Hydraulic Rear Selective Control Valve
Other Material
Specifications
Inspect and Repair SCV Levers and Linkage (Cab)
Remove and Install Rear Selective Control Valve (SCV)
Disassemble, Inspect, and Assemble Dual Rear Selective Control Valve (SCV)
Disassemble, Inspect, and Assemble Triple Rear Selective Control Valve (SCV)
Rear SCV Control Cable Adjustment
Group 25 - Hydraulic Mid-Mount Selective Control Valve
Other Material
Specifications
Inspect and Repair Multi-Function Lever and Linkage
Remove and Install Mid-Mount Selective Control Valve (SCV)
Disassemble, Inspect, and Assemble Dual Mid-Mount Selective Control Valve (SCV)
Disassemble, Inspect, and Assemble Triple Mid-Mount Selective Control Valve (SCV)
Mid-Mount SCV Control Cable Adjustment
Section 80 - MISCELLANEOUS
Group 05 - Hood and Fenders
Remove and Install Fenders—Cab Tractors
Remove and Install Fenders—OOS Tractors
Remove and Install Hood
Group 10 - Hitch and Drawbar
Specifications
Remove and Install Drawbar and Support
Remove 3-Point Hitch Linkage
Inspect and Repair Stabilizer Chains (If Equipped)
Inspect and Repair Stabilizer Bars (If Equipped)
Inspect and Repair Lower Draft Links
Inspect and Repair Standard Lift Link
Inspect and Repair Adjustable Lift Link
Inspect and Repair Center Link
Remove and Install Trailer Hitch (If Equipped)
Checking the Manually Operated Hitch (EEC Type) for Wear (If Equipped)
Checking the Manually Operated Hitch (CUNA Type) for Wear (If Equipped)
Group 15 - Front Support
Specifications
Remove, Inspect, and Install Front Support
Section 90 - OPEN OPERATOR STATION REPAIR
Group 05 - Seat and Support
Specifications
Remove and Install Seat and Support
Group 10 - ROPS
Specifications
Check ROPS
Remove and Install ROPS
Group 15 - Operator Platform
Other Material
Specifications
Remove Operator Station
Install Operator Station
Group 20 - Cowl Repair
Remove and Install Cowl
Section 95 - CAB—OPERATOR STATION REPAIR
Group 05 - Removal and Installation of Components
Specifications
Remove, Inspect, and Install Cab Interior Recirculating Air Filters
Remove, Inspect, and Install Exterior Cab Intake Air Filters
Remove and Install Headliner
Remove and Install Right-Side Control Console
Remove and Install Left-Side Control Console
Remove and Install Left-Hand Upholstery
Remove and Install Right-Hand Upholstery
Remove and Install Windshield
Remove and Install Rear Window
Remove and Install Front Lower Windows
Remove and Install Rear Lower Window
Remove and Install Side Windows
Remove and Install Cab Doors
Remove and Install Cab Roof
Remove and Install Safety Exit Door (If Equipped)
Installing Door Lock
Remove Operator Cab
Install Operator Cab
Group 10 - Air Conditioning System
Other Material
Specifications
Recover/Recycle Air Conditioning Refrigerant
Replace Air Conditioning Receiver-Dryer
Remove, Inspect, and Install Air Conditioning Condenser
Remove, Inspect, and Install Air Conditioning Compressor
Test Volumetric Efficiency of Compressor
Test Compressor Shaft Seal Leakage
Disassemble and Assemble Compressor Clutch
Disassemble, Inspect, and Assemble Compressor
Check Compressor Clutch Hub Clearance
Inspect Compressor Manifold
Remove and Install the Evaporator and Expansion Valve
Arrangement of Condensation Water Drain Hoses
Remove and Install A/C Thermostat Switch
Adjust Thermostat Switch Bowden Cable
Refrigerant Oil Information
Check Compressor Oil Charge
Determine Correct Refrigerant Oil Charge
Add Refrigerant Oil to System
System Information
Flush Air Conditioning System
Evacuate Air Conditioning System
Charge Air Conditioning System
Group 15 - Heating System
Remove and Install Heater Core
Remove and Install Fan Motors
Remove and Install Fan Motor Resistors
Remove and Install Heater Valve
Adjust Heater Valve Bowden Cable
Group 20 - Seat
Remove and Install Instructional Seat
Section 99 - SPECIAL TOOLS
Group 05 - Dealer Fabricated Tools
DFRW20—Compressor Holding Fixture
DFRW242—Modification to KJD10539 Support Stand Adapter
DFRW243—Short Adapter
Group 10 - Service Tools
