John Deere Tractors 4044M - 4066R Diagnostic and Repair Manual TM131019
Brand: John Deere
Type of Machine: Tractors
Type of Manual: Diagnostic and Repair Manual
Model: John Deere 4044M 4044R 4049M 4049R 4052M 4052R 4066M 4066R Tractors
Serial Number: 010001-
Part Number: TM131019
Publication Date: 2015
Number of Pages: 2285 Pages
FOREWORD
Section 10 - GENERAL INFORMATION
Group 05A - Safety
Group 05B - General References
Group 05C - Technical Specific References
Group 05D - Fuel and Lubricants
Group 05E - Serial Number Locations
Section 20 - ENGINE REPAIR
Group 05 - Engine
Group 10 - Cooling System
Section 30 - FUEL, AIR INTAKE, AND EXHAUST REPAIR
Group 05 - Fuel
Group 10 - Air Intake
Group 20 - Exhaust
Section 40 - ELECTRICAL REPAIR
Group 05 - Battery, Starter and Alternator
Group 10 - Electrical System Components
Group 15 - Wiring Harnesses
Section 50 - TRANSMISSIONS REPAIR
Group 05 - Separation
Group 10 - Power Train—Hydrostatic
Group 15 - Power Train—Power Reverser
Section 55 - FINAL DRIVE REPAIR
Group 05 - MFWD
Group 10 - Differential
Group 15 - PTO
Section 60 - STEERING AND BRAKE REPAIR
Group 10 - Steering
Group 15 - Brake
Section 70 - HYDRAULICS REPAIR
Group 10 - Hydraulic Pump and Filter
Group 15 - Rockshaft
Group 20 - Range Control and Three Point Hitch
Group 25 - Selective Control Valve
Section 80 - MISCELLANEOUS REPAIR
Group 10 - Hood and Side Panels
Group 15 - Fenders
Group 20 - Wheels
Section 90 - CAB/OPEN OPERATOR’S STATION REPAIR
Group 10 - Seat and Support
Group 15 - Control Console
Group 25 - Roll-Gard
Group 30 - Cab Components
Group 35 - Open Operator Station Components
Group 40 - Heating System
Group 45 - Air Conditioning System
Group 50 - Temperature Control, Belts, and Blower Motor
Section 211 - DIAGNOSTIC TROUBLE CODES
Group 05 - General References
Group ECU - Engine Control Unit (ECU) Diagnostic Trouble Codes
Group ICC - Instrument Cluster Control (ICC) Diagnostic Trouble Codes
Group PTH - Power Train Hydrostatic (PTH) Control Unit Diagnostic Trouble Codes
Group PTR - Power Train Reverser (PTR) Control Unit Diagnostic Trouble Codes
Section 212 - OBSERVABLE SYMPTOMS AND SYSTEM DIAGNOSTICS
Group 20 - Engine Diagnostics
Group 30 - Fuel, Air Intake, Exhaust, and Cooling Diagnostics
Group 40 - Electrical Diagnostics
Group 45 - Electronic Control Unit Diagnostics
Group 50 - Drive Systems and Transmission Diagnostics
Group 60 - Steering and Brakes Diagnostics
Group 70 - Hydraulic Diagnostics
Group 90 - Cab/Open Operator′s Station Diagnostics
Section 220 - ENGINE OPERATION, TEST, AND ADJUSTMENTS
Group 10 - Calibrations, Preliminary Checks and Operational Checks
Group 20 - Theory of Operation
Group 50 - Tests and Adjustments
Section 230 - FUEL , AIR INTAKE, EXHAUST, AND COOLING OPERATION, TEST, AND ADJUSTMENTS
Group 40 - Component and Connector Information
Section 240A - ELECTRICAL GENERAL AND THEORY OF OPERATION
Group 20A - Key Switch, Starter, and Alternator
Group 20B - Accessory Power and Horn
Group 20C - Control Module, Headlights, Signal, Work Lighting, and Warning Lights
Group 20G - Hydraulics, Rockshaft, and Diverter
Group 20J - Heating and Air Conditioning
Group 20K - Cruise Control
Group 20L - Windshield Wiper and Washer
Group 20M - Dome Light, Door Switch, Air Seat, and Radio
Group 20N - Instrument Control Cluster (ICC)
Group 20P - MFWD, Brakes, PTO, and Speed Sensor
Group 20Q - Transmission Control Unit (TCU)
Group 20R - Engine Control Unit (ECU)
Section 240B - ELECTRICAL SCHEMATICS
Group 30A - Electrical Schematics
Group 30B - Circuit Diagrams
Section 240C - ELECTRICAL COMPONENTS AND CONNECTORS
Group 40A - (SE1) Key Switch, Starter, and Alternator
Group 40B - (SE3—SE4) Accessory Power and Horn
Group 40C - (SE5—SE7) Control Module, Headlights, Signal, Work Lighting, and Warning Lights
Group 40D - (SE9) Junction Block Power
Group 40E - (SE10—SE11) Rear Trailer Connector
Group 40F - (SE13) Back-Up Alarm and Beacon Light
Group 40G - (SE14) Hydraulics, Rockshaft, and Diverter
Group 40H - (SE15) Power Port
Group 40I - (SE16—SE17) Heating and Air Conditioning
Group 40J - (SE18) Cruise Control
Group 40K - (SE19—SE20) Windshield Wiper and Washer
Group 40L - (SE22—SE23) Dome Light, Door Switch, Air Seat, and Radio
Group 40M - (SE24) Instrument Control Cluster (ICC)
Group 40N - (SE25—SE28) MFWD, Brakes, PTO, and Speed Sensor
Group 40P - (SE29) Transmission Control Unit (TCU)
Group 40Q - (SE30) Engine Control Unit (ECU)
Group 40S - (SE32) Controller Area Network
Group 40T - Fuses and Relays
Group 40U - Ground Points
Group 40V - Interconnects
Section 240D - ELECTRICAL TESTS AND ADJUSTMENTS
Section 245 - ELECTRONIC CONTROL UNITS
Group 50 - Test and Adjustments
Section 250 - POWER TRAIN—TRANSMISSION OPERATION, TEST, AND ADJUSTMENTS
Group 05A - General References
Group 10A - Calibrations, Preliminary Checks and Operational Checks—PTH
Group 10B - Calibrations, Preliminary Checks and Operational Checks—PTR
Group 20A - Theory of Operation—PTH
Group 20B - Theory of Operation—PTR
Group 30A - Schematics—PTH
Group 30B - Schematics—PTR
Group 40A - Component and Connector Information—PTH
Group 40B - Component and Connector Information—PTR
Group 50A - Tests and Adjustments—PTH
Group 50B - Tests and Adjustments—PTR
Section 255 - FINAL DRIVE OPERATION, TEST, AND ADJUSTMENTS
Section 260 - STEERING AND BRAKES OPERATION, TEST, AND ADJUSTMENTS
Group 10A - Calibrations, Preliminary Checks and Operational Checks—Steering
Group 10B - Calibrations, Preliminary Checks and Operational Checks—Brakes
Group 20A - Theory of Operation—Steering
Group 20B - Theory of Operation—Brakes
Group 30A - Schematics—Steering
Group 40A - Component and Connector Information—Steering
Group 40B - Component and Connector Information—Brakes
Group 50A - Tests and Adjustments—Steering
Group 50B - Tests and Adjustments—Brakes
Section 270 - HYDRAULICS OPERATION, TEST, AND ADJUSTMENTS
Group 30 - Schematics
Section 290 - CAB/OPEN OPERATORS STATION OPERATION, TEST, AND ADJUSTMENTS
Group 20A - HVAC Theory of Operation
Group 20B - Seat Theory of Operation
Section 299 - SERVICE TOOLS
Group 05C - Dealer Fabricated and Service Tools
Brand: John Deere
FOREWORD
Group 05A - Safety
Group 05 - Engine
Group 05 - Fuel
Group 20 - Exhaust
Group 05 - MFWD
Group 15 - PTO
Group 10 - Steering
Group 15 - Brake
Group 15 - Fenders
Group 20 - Wheels
- JOHN DEERE CODE DTC LIST
