John Deere Tractor 6800 6900 Service Repair Manual TM4516
Brand: John Deere
Type of Manual: Service Repair Manual
Model: John Deere 6800 6900 Tractor
Part Number: TM4516
Publication Date: 2000
Number of Pages: 980 Pages
Section 05 - SAFETY
Group 05 - Safety Measures
Group 05 - Specifications
Group 00 - Engine Removal and Installation
Group 05 - Speed Control Linkage
Group 05 - Connectors
Group 00 - Removal and Installation of Transmission Components
Group 00 - Component Removal and Installation
Group 05 - Hydrostatic Steering
Group 05 - Controls
Group 00 - Tilting or Removing/Installing Operator′s Cab
Group 05 - Special Tools (Dealer-Fabricated)
Brand: John Deere
Part Number: TM4516
Section 05 - SAFETY
Safety Information
‘Important” - Information
‘Note” - Information
Handle Fluids Safely-Avoid Fires
Prevent Battery Explosions
Prepare for Emergencies
Prevent Acid Burns
Avoid High-Pressure Fluids
Park Machine Safely
Support Machine Properly
Wear Protective Clothing
Work in Clean Area
Service Machines Safely
Work In Ventilated Area
Illuminate Work Area Safely
Replace Safety Signs
Use Proper Lifting Equipment
Keep ROPS Installed Properly
Service Tires Safely
Practice Safe Maintenance
Use Proper Tools
Dispose of Waste Properly
Live With Safety
Service Front-Wheel Drive Tractor Safely
Section 10 - GENERAL INFORMATIONGroup 05 - Specifications
Specifications
Diesel Engine Oil
Transmission and Hydraulic Oil
Front Wheel Drive Axle Oil
Engine Coolant
Grease
Oil Filters
Mixing of Lubricants
Lubricant Storage
Unified Inch Bolt and Cap Screw Torque Values
Metric Bolt and Cap Screw Torque Values
Serial Number Plates
Product Identification Number and Component Serial Numbers
Group 10 - Tune-UpSpecifications
Preliminary Engine Test
Tractor Tune-Up
Final Engine Check
Tractor Operation Check
Group 15 - Predelivery InspectionPredelivery Inspection
Section 20 - ENGINEGroup 00 - Engine Removal and Installation
Special or Essential Tools
Specifications
Removing Engine
Installing Engine
Replacing Engine Mountings
Front Engine Mountings
Rear Engine Mountings
Section 30 - FUEL, AIR INTAKE AND COOLING SYSTEMSGroup 05 - Speed Control Linkage
Specifications
Adjusting Throttle Hand Lever and Pedal
Adjusting Speed Control Linkage
Group 10 - Fuel SystemGeneral Information
Removing Fuel Tank
Installing Fuel Tank
Replacing Fuel Gauge Sending Unit
Replacing Fuel Transfer Pump
Bleeding Fuel System
Changing Fuel Filter
Group 15 - Air Intake SystemGeneral Information
Air Intake System
Group 20 - Cooling SystemGeneral Information
Specifications
Removing Radiator
Replacing Fan and Viscous Fan Drive
Installing Radiator
Relieving Drive Belt
Replacing Drive Belt
Replacing Drive Belt Tensioner
Repairing Drive Belt Tensioning Device
Hydraulic Drive Belt Tensioner Up to tractor serial no. 159438 - Exploded View
Group 25 - Cold Weather Starting AidsFuel Preheater
Electric Starting Aid
Coolant Heater
Section 40 - ELECTRICAL SYSTEMGroup 05 - Connectors
Disconnecting Electrical Circuit
METRI PACK Connector
WEATHER PACKWEATHER PACK is a trademark of Packard Electric. Connector
CRIMP SNAP IN Connector
CPCCPC is a trademark of AMP Inc. Connector
Replace Load Center Connector
Replace Power Distribution Center Connectors
Replacing Female Terminal on 45-Pin Plug
Installing Terminal
Changing Terminals
Stripping Wire Ends
Installing Terminal
Group 10 - Wiring HarnessesGround Point Locations
Removing and Installing Engine Wiring Harness
Removing and Installing Cab Wiring Harness
Removing and Installing Wiper and Air Conditioning Harness
Removing and Installing Cab Roof Wiring Harness
Removing and Installing Transmission Wiring Harness
Group 15 - Charging CircuitRepair Alternator-Use CTM
General
Specifications
Removing Alternator
Group 20 - Starting Motor CircuitSpecial or Essential Tools
Specifications
Repair Starter-Use CTM
Removing Starting Motor
Group 25 - Switches, Relays and SolenoidsDisconnecting Electrical Circuit
Specifications
Replace Stop Light Switches
Adjusting the Stop Light Switch
Removing and Installing the Thermostat Switch
Removing and and Installing the High/Low Pressure Switch
Replacing Blower Switch
Replacing Air Conditioning Switch
Removing HMS (Headland Management System) Switch
Replace MFWD Solenoid
Replace MFWD Switch
Replace Differential Lock and Rear PTO Solenoids
Differential Lock Switch
Replace PTO Switch
Replace Load/Depth Controller
Replace Hitch Control Potentiometer and Switch
Replacing Draft Sensor
Replacing Rockshaft Remote Control Switch
Replace and Install Hitch Position Sensor
Location of Hitch Position Sensor
Replace Fuel Shut-Off Solenoid
Replace Main Switch
Replace Light Switch and Hazard Warning Light Switch
Replace Wiper/Washer Switch
Main Fuses
Fuse Box (Load Center) 1 (Up to Serial No. 139832)
Fuse Box (Load Center) 2 (Up to Serial No. 139832)
Fuse Box (Load Center) 1 (From Serial No. 139833)
Fuse Box (Load Center) 2 (From Serial No. 139833)
Group 30 - Monitoring SystemDisconnecting Electrical Circuit
Replacing PTO Speed Sending Unit
Replacing Engine Oil Pressure Sending Unit
Replacing Engine Speed Sending Unit
Replacing Air Cleaner Sending Unit
Replacing Coolant Temperature Sending Unit
Replace Speed Sending Unit
Replacing Overvoltage Protection
Temperature and Pressure Sending Units in Transmission Oil Circuit
Removing Instrument Unit
Group 40 - Auxiliary Lighting and Electrical ComponentsReplace Seven-Terminal Outlet Socket
Group 45 - Convenience and Accessory ComponentsDisconnecting Electrical Circuit
Removing and Installing Fan and Radiator
Replace Wiper Motor
Replace Dome Light Switch
Section 55 - POWRQUADPOWRQUAD IS A TRADEMARK OF DEERE & COMPANY. TRANSMISSIONGroup 00 - Removal and Installation of Transmission Components
Special Or Essential Tools
Specifications
Removing the PowrQuad PowrQuad is a trademark of Deere & Company. Module
Installing the PowrQuad PowrQuad is a trademark of Deere & Company. Module
Removing the Creeper Transmission
Installing Creeper Transmission
Removing the Range Transmission
Installing the Range Transmission
Group 05 - Transmission ControlsSpecifications
Gear Shift Linkage
Range Shift Linkage
Installing Bowden Cables
Adjusting Reverser Drive Linkage
Adjusting Shift Linkage
Adjusting Parking Lock
Group 10 - PowrQuadPowrQuad is a trademark of Deere & Company. ModuleSpecial or Essential Tools
Service Equipment and Tools
Other Material
Specifications
Repair Instructions
Install Transmission in Repair Stand
Remove Transmission Front Cover/Front Valve Housing
Remove Front Valve Housing
Front Valve Housing Valves
Transmission Front Cover Valves
Traction Clutch Valve
Replace Traction Clutch Valve Shifter Lever/Shaft Seal
Replace Traction Clutch Valve Inner Arm/Shaft
Transmission Pump-Cross-Sectional View
Repair Transmission Pump
Install Front Valve Housing
Install Transmission Front Cover/Front Valve Housing
Remove Shift Control Valve Housing
Replace Forward-Reverse/Speed Selector Shifter Levers/Shaft Seals
Replace Forward-Reverse/Speed Selector Shifter Shafts/Shifter Arms
Shift Control Valve Housing Valves
Modulator Valve-Cross-Sectional View
Planetary Housing Valves
Forward/Reverse Control Valve-Cross-Sectional View
Speed Selector Valve-Cross-Sectional View
Assemble and Install Shift Valve Housing
Disassemble Planetary/Reverse Brake Housing Assembly
Recondition Input Planetary Carrier
Input Planetary Assembly-Cross-Sectional View
Disassemble Reverse Brake Housing Components
Reverser Carrier/Traction Clutch Assembly-Cross-Sectional View
Recondition Reverser Carrier/Traction Clutch Assembly
Disassemble Planetary Housing Components
Direct Drive Clutch Assembly-Cross-Sectional View
Recondition Direct Drive Clutch Assembly
Assemble Planetary Housing Components
Assemble Reverse Brake Housing Components
Assemble Planetary/Reverse Brake Housing Assembly
Group 15 - Creeper TransmissionService Equipment and Tools
Specifications
Preliminary Work
Creeper Transmission-Cross-Sectional View
Shifter Components-Cross-Sectional View
Removing Shifter Components
Input/Output Drive Shaft - Components
Countershaft and Housing - Components
Remove Input/Output Drive Shaft Assembly
Disassemble and Assemble Drive Shaft/Snubber Brake
Remove and Install Countershaft
Install Input/Output Shaft Assembly
Final Assembly
Group 20 - Range TransmissionSpecial or Essential Tools
Specifications
Repair Instructions
Preliminary Work
Range Box Up to Transmission Serial No. 024698 corresponding tractor serial no. is 135080
Range Box From Transmission Serial No. 024699 corresponding tractor serial no. is 135081
Shifting Mechanism - Cross-Sectional View
Removing Differential Drive Shaft
Removing Drive Shaft
Differential Drive Shaft - Exploded View
Drive Shaft (30 KM/H; 18.5 MPH Version) - Exploded View
Drive Shaft (40 KM/H; 25 MPH Version) - Exploded View
Shifting Mechanism - Exploded View
Parking Lock - Exploded View
Repairing Drive Shaft
Installing Drive Shaft
Adjusting Drive Shaft End Play
Installing Differential Drive Shaft and Adjusting Cone Point
Adjusting End Play of Differential Drive Shaft
Adjusting Shifting Mechanism
Repairing and Installing Shift Cover
Final Assembly
Section 56 - DRIVE SYSTEMSGroup 00 - Component Removal and Installation
Specifications
Removing Differential Housing
Installing Differential Housing
Removing PTO Housing
Installing PTO Housing
Removing Final Drives
Installing Final Drives
Removing Front Wheel Drive Clutch
Installing Front-Wheel Drive Clutch
Removing Front PTO
Installing Front PTO
Group 05 - U-Jointed Shafts and Torsion DamperSpecifications
Removing U.J. Shaft (FWD)
Installing U.J. Shaft (FWD)
Removing U.J. Shaft (Engine)
Removing the Torsion Damper
Changing the Torsion Damper Bearing
Installing the Torsion Damper
Installing the U.J. Shaft (Engine)
Disassemble Universal Jointed Drive Shaft
Assembling Jointed Shaft
Group 10 - Front Wheel Drive ClutchSpecial or Essential Tools
Specifications
Repair Instructions
Preliminary Work
Front Wheel Drive Clutch - Cross Sectional View
Removing Clutch
Disassemble MFWD Clutch
Front Wheel Drive Clutch Components
Assembling Clutch
Installing Clutch
Adjusting End Play
Adjusting the Brake Band
Final Assembly
Group 15 - DifferentialSpecial or Essential Tools
Specifications
Repair Instructions
Preliminary Work
Removing the Differential
Disassembling the Differential
Exploded View
Assembling the Differential
Installing the Differential
Adjusting Differential Preload
Adjusting Backlash
Final Assembly
Group 20 - Final DrivesSpecial or Essential Tools
Other Material
Specifications
Repair Instructions
Preliminary Work
Final Drive-Cross-Sectional View
Disassemble Planet Pinion Carrier
Planet Pinion Carrier-Exploded View
Assemble Planet Pinion Carrier
Remove Axle Housing
Disassemble and Assemble Axle Housing
Disassemble and Assemble Axle Shaft
Install Axle Housing
Install Planet Pinion Carrier and Check Rolling Drag Torque
Final Assembly
Group 25 - Rear PTOSpecial or Essential Tools
Specifications
Repair Instructions
Repair PTO
PTO Clutch-Cross-Sectional View
Remove and Disassemble PTO Clutch
Assemble and Install PTO Clutch
Remove and Disassemble Countershaft
PTO Countershaft-Cross-Sectional View
Shiftable PTO Output Shaft-Cross-Sectional View
Remove and Disassemble Output Shaft
Assemble and Install PTO Output Shaft
Shiftable PTO Shifter - Exploded View
Remove PTO Shifter
Install PTO Shifter
Replace PTO Brake
Replacing Oil Seal on PTO Output Shaft
Remove Valve Housing
Disassemble and Assemble Valve Housing
Install Valve Housing
PTO Shifting Parts
Changing and Adjusting the Bowden Cable
Adjusting the Indicator Light Switch
Group 30 - Front PTOSpecial or Essential Tools
Specifications
Front PTO (Running Clockwise)
Front PTO (Running Counterclockwise)
Front PTO - Sectional View
Removing Front PTO Shaft
Disassembling Front PTO Shaft
PTO (Clockwise Running) - Exploded View
PTO (Counterclockwise Running) - Exploded View
PTO Clutch and Brake - Clockwise Running PTO
PTO Clutch and Brake - Counterclockwise Running PTO
Front PTO Housing
Assembling Front PTO
Determining Preload of Input Shaft and PTO Shaft Taper Roller Bearings
Installing Front PTO Shaft
Repairing Solenoid Valve
Layout of Oil Lines
Group 35 - Hydraulic Pump DriveSpecial or Essential Tools
Specifications
Hydraulic Pump Drive-Cross-Sectional View
Remove and Disassemble Pump Drive Pinion Gear
Remove and Disassemble Pump Drive Gear
Assemble and Install Pump Drive Gear
Assemble and Install Pump Drive Pinion
Group 40 - Front Implement DriveSpecial or Essential Tools
Specifications
Exploded View
Replacing Damper
Section 60 - STEERING AND BRAKESGroup 05 - Hydrostatic Steering
Specifications
Removing Steering Valve
Removing Steering Column and Steering Valve
Steering Valve- Exploded View
Repairing Steering Valve
Disassembling the Steering Valve
Exploded View of Steering Valve
Assembling the Steering Valve
Adjusting Double-Acting Shock Valves
Steering Wheel and Steering Column
Repairing the Steering Column
Installing Steering Valve
Installing Steering Column and Steering Valve
Group 10 - Brake ValveSpecifications
Repair Instructions
Removing Brake Valve
Repair Brake Valve
Installing Brake Valve
Group 15 - Rear Wheel BrakesSpecifications
Preliminary Work
Removing the Rear Wheel Brakes
Rear Wheel Brakes - Exploded View
Repairing the Brakes
Installing the Rear Brakes
Final Assembly
Bleeding the Brakes
Checking the Brakes
Group 20 - HandbrakeSpecifications
Preliminary Work
Removing the Handbrake
Exploded View of Handbrake - 6800 Tractor
Exploded View of Handbrake - 6900 Tractor
Installing the Handbrake
Final Assembly
Handbrake Components
Replacing the Handbrake Cable
Adjusting the Handbrake
Group 25 - Hydraulic Trailer BrakeSpecial or Essential Tools
Specifications
Replacing Trailer Brake Valve
Replacing the Check Valve
Bleeding Trailer Brake Valve
Checking Trailer Brake Valve
Cleaning Trailer Brake Valve
Cleaning Sieve
Group 30 - Air BrakesSpecial or Essential Tools
Specifications
Installing the Screw Unions
Changing the Compressor
Changing the Compressed Air Tank
Changing the Pressure Control Valve
Changing the Pressure-Limiting Valve
Changing the Trailer Control Valve
Changing the Pressure Gauge
Changing the Coupling Ends
Visual and Operational Checks
Leak Test
Checking the Handbrake (Dual-Line Brakes)
Checking the Handbrake (Single-Line Brakes)
Checking the ‘Supply” Coupling End
Section 70 - HYDRAULIC SYSTEMGroup 05 - Controls
Connecting Bowden Cable
SCV Actuating Elements
Adjusting Bowden Cable
Installing Multi-Function Lever
Adjusting Multi-Function Lever
Group 10 - Hydraulic Pump and Charge PumpService Equipment and Tools
Other Material
Specifications
Repair Instructions
Removing Charge Pump
Disassembling Charge Pump
Assembling Charge Pump
Installing Charge Pump
Checking Lube Oil Valve
Restrictor in Oil Tank
Check Valve in Oil Leak-Off Line
Changing the Hydraulic Pump Controller
Hydraulic Pump Controller-Exploded View
Disassemble, Inspect, and Assemble Hydraulic Controller
Adjusting the Controller
Removing the Hydraulic Pump
Installing the Hydraulic Pump
Hydraulic Pump 40 cm3 (2.4 cu.in) - Exploded View
Hydraulic Pump 25 cm3 (1.5 cu.in) - Exploded View
Disassemble, Inspect and Assemble Hydraulic Pump
Adjust Swashplate Bearing Preload
Adjust Shaft Bearing Preload-40 cm 3 (2.4 cu.in) Pump
Group 15 - ValvesSpecial or Essential Tools
Special Tools (Dealer Fabricated)
Specifications
Repair Instructions
Direct Control of Rockshaft
Removing the Rockshaft Valve
Repairing Rockshaft Valve
Depth to Which Pressure and Discharge Valves are Screwed In
Changing the Stepper Motor
Centering the Stepper Motor
Installing the Rockshaft Valve
Installing Shuttle Valves
Repairing the Inlet Priority Valve - Exploded View
Removing the Inlet Priority Valve
Installing the Inlet Priority Valve
Checking Oil Filter Head
Filter Relief Valve
Power Beyond Application Valve - Exploded View (New Version)
Power Beyond Application Valve - Exploded View (Old Version)
Connecting the Power Beyond Application Valve
Adjusting the Power Beyond Application Valve
Converting the Power Beyond Application Valve
Group 20 - Three-Point HitchOther Material
Specifications
Changing the Position Sensor
Draft Sensor and Draft Link Support - Exploded View
Changing the Draft Sensor and Draft Link Support
Removing and Installing the Lift Cylinders
Cross-Section and Exploded View - Lift Cylinder
Replacing the Bushings on the Rockshaft Housing
Automatic Stabilizer Rod (Left-Hand)
Adjustable Stabilizer Rod (Left or Right)
Adjustable Stabilizer Rod (Right-Hand)
Group 25 - Selective Control Valves and CouplersSpecial Tools (Dealer Fabricated)
Other Material
Specifications
Repair Instructions
SCV Identification
Removing Selective Control Valves
Series 100 Selective Control Valve - Exploded View
Disassemble, Inspect and Assemble the Control Valve-Series 100
Series 200 Selective Control Valve-Exploded View
Series 300 Selective Control Valve-Exploded View
Replace Control Knobs
Inspect Poppet Load-Check Valves
Inspect Pressure Compensator Valve-300 Series
Inspect Metering Valve-Three-Position SCV
Inspect Metering Valve-200 Series
Disassemble, Inspect, and Assemble Control Valve-300 Series
Disassemble, Inspect, and Assemble Control Valve-200 Series
Installing Selective Control Valves
Installing the Endplate
Adjustment of Pressure Limit at Selective Control Valves (300 Series)
Changing Couplers
Deluxe Coupler - Exploded View
Repairing the Deluxe Coupler
Checking Couplers for Leaks
Section 80 - MISCELLANEOUSGroup 00 - Component Removal and Installation
Specifications
Removing Main Frame Halves
Installing Main Frame Halves
Removing Front Wheel Drive Axle
Installing Front Wheel Drive Axle
Removing Front Axle Support
Installing Front Axle Support
Group 05 - Main FrameSpecifications
Removing and Installing the Main Frame
Group 10 - Front and Rear WheelsSpecial or Essential Tools
Specifications
Removing a Wheel (Front or Rear)
Attaching the Front Wheels
Attaching the Rear Wheels
Group 15 - Trailer HitchSpecifications
Installing the Trailer Mounting
Installing the Guide Rails
Trailer Mounting (Height-Adjustable, 4-Position)
Trailer Mounting (Height-Adjustable, 9-Position)
Repairing the Automatic Trailer Hitch
Remote Control for Automatic Trailer Hitch
Adjusting the Remote Control
Functional Check
Group 20 - Pick-Up HitchSpecifications
Installing Upper Frame
Frame Assembly - Exploded View
Operating Lever and Lift Links - Exploded View
Hydraulic Parts
Repairing Hydraulic Cylinder
Adjusting Lift Links
Adjusting Guide Stop
Changing the Bowden Cable
Operational Check
Group 25 - Swinging DrawbarTorques for Hardware - Swinging Drawbar
Torques for Hardware - Swinging Drawbar with Pick-Up Trailer Hitch
Section 90 - OPERATOR′S CAB AND 4-POST ROPSGroup 00 - Tilting or Removing/Installing Operator′s Cab
Specifications
Tilting the Cab Upward
Tilting the Cab Downward
Removing the Operator′s Cab
Group 05 - Controls and InstrumentsDisconnecting Electrical Circuit
Specifications
Replacing Bulbs
Removing the Control Panel
Replacing a Bulb
Adjusting Digital Control
Adjusting Analog Control
Removing Multi-Function Unit
Replacing Multi-Function Unit Components
Installing Steering Wheel
Replacing Basic Control Module
Group 10 - Electronic Hitch Control ComponentsDisconnecting Electrical Circuit
Replacing Electronic Control Unit
Activating Quick-Lower or Hitch Dampening Functions
Replacing Operation Unit
Group 15 - Air Conditioning SystemSpecial or Essential Tools
Specifications
Safety at Work
Handling Refrigerant
In an Emergency
Safety Equipment
Storage of Refrigerant Containers
R134A Refrigerant
Discharging the System
Evacuating the System
Filling With Refrigerant Oil
Filling the System
Topping Up a Partly Discharged System
Leak Test
Removing the Compressor
Checking Level in the Compressor
Disassembling the Compressor Clutch
Checking Clutch Hub Clearance
Checking the Compressor Manifold
Installing the Compressor
Removing and Installing the Condenser
Removing and Installing the Receiver-Drier
Removing and Installing the Evaporator and Expansion Valve
Installing Condensation Water Drain Hoses
Group 20 - Heating SystemVentilator and Heater, Exploded View
Removing and Installing Heating Regulator
Removing the Air Filter
Group 25 - Operator′ CabSpecifications
Removing Cab Frame
Removing and Installing Mounting Brackets
Installing Windshield
Installing Rear Window
Adjusting Window Contact Pressure
Removing Cab Door
Installing Cab Door
Installing Door Lock
Installing Door Holding Bracket
Replacing Handrail or Rear View Mirror
Removing Hatch
Removing Outer Roof
Removing Inner Roof
Installing Inner Roof
Group 30 - SeatsSpecifications
Comfort Seat DS44-07, Exploded View
Comfort Seat DS44-06, Exploded View
Super Comfort Seat S85/90-05, Exploded View - Upper Section
Super Comfort Seat DS85H1-02, Exploded View - Lower Section
Air Comfort Seat MSG95A-00, Lower Section
Passenger Seat, Exploded View
Group 35 - Radio InstallationRadio, Loudspeakers and Aerial, Exploded View
Section 99 - SPECIAL TOOLS (DEALER-FABRICATED)Group 05 - Special Tools (Dealer-Fabricated)
DFRW29-Final Drive Housing Adapter
DFRW30-Axle Jacking Tool
DFRW79-Piston Holding Tool
Holding Device
Shifter Rail Detent Holding Tool
Socket Wrench Insert
Suspension Eyes for Operator′s Cab
- JOHN DEERE CODE DTC LIST
