Hyundai
86
176,834
John Deere Tractor 6130 to 6930 Diagnostic Test Service Manual TM400419
Brand: John Deere
Type of Manual: Diagnostic Test Service Manual, Electrical & Hydraulic Diagram
Model: John Deere 6130, 6230, 6330, 6430, 6530, 6630, 6534, 6830, 6930
Part Number: TM400419
Number of Pages: 3661 Pages
Foreword
Serial Number Break 2009
Safety Measures​
General References​
Diagnostic Trouble Codes
BCU Control Unit​
ECU Control Unit​
EPC Control Unit​
PRC Control Unit​
TSC Control Unit​
Observable Symptoms
Electronics​
Electronic Control Units​
SyncroPlus Transmission​
PowrReverser Transmission​
PowrQuad Transmission​
Drive Train (without Transmission)​
Steering and Brakes​
Hydraulic System​
Miscellaneous​
Operator's Cab​
System Diagnosis
Electronics​
Hydraulic System​
General Information​
Operational Checks​
Test and Adjustments​
Fuel, Air Intake and Cooling Systems
Fuel System​
Air Intake System​
Cooling System​
Cold-Weather Starting Aids​
Starting Motor and Charging Circuit​
Fuel Preheater​
Electrical Starting Aid​
Instrument Unit​
Horn​
Operator's Seat and Cigarette Lighter​
Lights​
Worklights​
Radio, Dome Light and Console Light​
Air Conditioning and Fan​
Windshield Wiper and Washer​
Rear Window Wiper and Washer​
Beacon Light​
3-Terminal Power Outlet Socket (SAE)​
3-Terminal Power Outlet Socket (ECE)​
Plug for Accessories​
BCU Control Unit (Electronic Hitch Control)​
BCU Control Unit (Basic Functions)​
Signal Socket and Service Socket​
7-Terminal Power Outlet Socket (ECE)​
7-Terminal Power Outlet Socket (SAE)​
TSC Control Unit (Suspension)​
CAN BUS Terminating Resistor​
Level 16 ECU Control Unit (Electronic Engine Control) for 2-Valve Engine with HPCR​
Back-Up Alarm​
EPC Control Unit (Transmission Control with PowrQuad Plus Transmission)​
PRC Control Unit (Transmission Control with Electrically Actuated PowrReverser Transmission)​
Prewiring for GreenStar​
Component Information - Connectors and Contacts​
Component Information - Connectors (X001 to X249)​
Component Information - Connectors (X250 to X499)​
Component Information - Connectors (X500 to X749)​
Component Information - Connectors (X750 to X999)​
Component Information - Connectors (XGND)​
Component Information - Wiring Harnesses​
Component Information - Electrical Parts/Components​
Component Information - Electrical Parts/Components (Actuators)​
Component Information - Electrical Parts/Components (Sensors/Switches/Potentiometers)​
Component Information - Electrical Parts/Components (Fuses/Relays/Diodes)​
Component Information - Electrical Parts/Components (Headlamps/Lights)​
Component Information - Electrical Parts/Components (Other)​
Component Information - Ground Connections​
Component Information - CAN BUS System​
Operation and General Information on Diagnostics​
Interactive Test​
Interactive Calibrations​
Information on How to Reprogram Control Units​
Data BUS Systems​
BCU Control Unit​
ECU Control Unit​
EPC Control Unit​
PRC Control Unit​
TSC Control Unit​
Operational Checks​
Operation​
Operational Checks​
Operation​
Operational Checks​
Operation​
Operational Checks​
Front-Wheel Drive Clutch​
Differential​
Final Drives​
Rear PTO Options​
Steering and Brakes
Introductory Checks​
Operational Checks​
Hydrostatic Steering​
Brake Valve​
Rear Brakes​
Handbrake​
Hydraulic Trailer Brake​
Air-Brake System​
Operational Checks​
Operation​
Oil Filter, Charge Pump and Hydraulic Pump​
Hitch​
Selective Control Valves (SCVs)​
Independent Control Valves (ICVs)​
Hydraulic block​
Miscellaneous
Operational Checks​
Operation​
Operator's Cab
Operational Checks​
Ventilation/Heating​
Air Conditioning System​
Special Tools
Special Tools (Dealer-Fabricated)​
Special Tools (Available as Spare Parts)​
