Hyundai
86
176,834
John Deere Tractor 3640 Parts Catalog PC4200
Brand: John Deere
Model: John Deere 3640 (Europe Edition) Tractor
Part Number: PC4200
Publication Date: 2025
Number of Pages: 1043 Pages
SHORT BLOCK ASSEMBLY
CYLINDER BLOCK-FRONT RH
CYLINDER BLOCK-REAR LH
OIL FILTER AND DIPSTICK
FRONT PLATE
ROCKER ARM COVER
VENT TUBE
ROCKER ARM_SHAFT_TAPPET_PUSH ROD
Rocker Arm_Shaft_Tappet_Push Rod
CYLINDER HEAD
VALVE_VALVE SEAT_SPRING_RETAINER
CYLINDER HEAD - CONVERSION PARTS
CAMSHAFT
IDLE GEARS
IDLE GEARS
IDLE GEARS
TIMING GEAR COVER
TIMING GEAR COVER
MAGNETIC PICK-UP
MAGNETIC PICK-UP
MAGNETIC PICK-UP
OIL FILLER
CRANKSHAFT _ BEARINGS - KIT
BEARINGS , THRUST BEARING (CRANKSHAFT)
PULLEY WITH DAMPER
PULLEY WITH DAMPENER_COUPLING (WITH FRONT PTO)
PISTON _ CONNECTING ROD _ LINER
FLYWHEEL HOUSING
FLYWHEEL
COOLANT TEMP. GAUGE_ENGINE OIL PRESSURE SENDING UNIT, PILOT BEARING
OIL PAN
OIL PAN MOUNTING PARTS
OIL PUMP
OIL PUMP, KIT
ENGINE OIL COOLER
RADIATOR_COOLANT HOSES
ENGINE COOLANT HEATER 220V, 750W
ENGINE COOLANT HEATER 220V, 650W
THERMOSTAT_THERMOSTAT HOUSING
WATER PUMP
WATER PUMP_FAN
ENGINE GASKET SET
9901 Complete Block Assembly
DRY AIR CLEANER
AIR PRE-CLEANER (FOR DRY AIR CLEANER)
AIR INTAKE MANIFOLD
EXHAUST MANIFOLD
EXHAUST SYSTEM
EXHAUST SYSTEM
FUEL TANK
Additional Fuel Tank
ADDITIONAL FUEL TANK-MOUNTING SUPPORT
FUEL LINES
WATER TRAP
FUEL FILTER
FUEL PREHEATER
FUEL PUMP _SOFABEX_
FUEL TRANSFER PUMP _CORONA_
FUEL TRANSFER PUMP _AIRTEX_ (REPLACEMENT PUMP)
FUEL INJECTION NOZZLE
FUEL INJECTION PUMP
FUEL LINES FOR FUEL INJECTION PUMP
SPEED CONTROL LINKAGE
SHUT-OFF KNOB
BOWDEN CABLE FOR ENGINE SPEED CONTROL
_THERMOSTART_ STARTING AID
ETHER COLD WEATHER STARTING AID
ALTERNATOR ATTACHING PARTS
ALTERNATOR (55A)
ALTERNATOR (55A)
ALTERNATOR (55A)
ALTERNATOR 70A_95A
ALTERNATOR 85A,95A
ALTERNATOR 85A_95A
Battery
Battery
STARTING MOTOR KIT
STARTING MOTOR
STARTING MOTOR
INSTRUMENT HOUSING, LEFT-HAND
INSTRUMENT HOUSING-RIGHT-HAND
SPEED-HOUR METER
SPEED-HOUR METER
ELECTRICAL INSTRUMENTS
HEADLIGHTS
HEADLIGHTS
H4 HEADLIGHTS
HEADLIGHTS ON CAB ROOF
TURN-SIGNAL AND CLEARANCE LIGHTS
TAIL LIGHTS_REGISTRATION PLATE LIGHT
Rear Work Light
Rear Work Light
LIGHT BRACKETS AT ROOF (SG2 AND RG2)
DOME LIGHT-CONSOLE LIGHT (SGB)
DOME AND CONSOLE LIGHT-SG2 CAB WITH LOW PROFILE CAB
DONE AND CONSOLE LIGHT (RG2 ROLL GUARD)
Horn _ Trailer Socket
RADIO AND LOUDSPEAKER COVERS
WIRING HARNESSES ENGINE
WIRING HARNESSES-DASH
WORKLIGHT WIRING HARNESS AT ROOF (SG2 AND RG2)
Wiring Harness Roof Headlights
WIRING HARNESS-DASH-FRONT PTO
WIRING HARNESS
Wiring Harness for Handshift PTO
Control Unit - Automatic Engagement Of Front Wheel Drive
WIRING HARNESS-SG2 CAB
WIRING HARNESS-SG2 LOW PROFILE CAB
WIRING HARNESS RG2 ROLL GUARD
WIRING HARNESS ROOF HEADLIGHTS
AERIAL_LOUDSPEAKER WIRING HARNESS SG2 CAB
CONVERSION KIT - FUSE PRINTED CIRCUIT BOARD (SG2 CAB)
REPAIR KIT-ROOF WIRING HARNESS_WINDSHIELD WIPER LH
CABLE CLIPS CONNECTORS AND PLUGS
CLUTCH HOUSING
CLUTCH HOUSING
Engine Clutch
SLAVE CYLINDER WITH THROW-OUT BEARING_INDIVIDUAL PARTS
Conversion Kit for Engine Clutch
Clutch Operating Parts
Reservoir for Clutch
REPAIR KIT FOR CLUTCH MASTER CYLINDER (AL40974)
OIL PUMP_PTO DRIVE SHAFT_CLUTCH SHAFT
Transmission Oil Pump - Oil Lines
SHIFT COVER (WITH IND. PTO AND HI-LO SHIFT UNIT)
Shift Cover (With Ind. PTO and Hi-Lo Shift Unit)
HI-LO SHIFT UNIT-LOCKING DEVICE PARTS
Control Valve _ Sending Unit
HI-LO SHIFT LINKAGE
HI-LO SHIFT LINKAGE
HI-LO CLUTCH
COVER_LEVER (WITH INDEPENDENT PTO)
PTO Control Linkage
PTO CLUTCH
FWD-DRIVE ELEMENTS (OUTPUT)
FWD Multi-Disk Clutch
FWD Cover _ Solenoid Valve
FWD Solenoid ( - 569295)
FWD Solenoid (569296 - 607857)
FWD Solenoid (607858 - )
Oil Manifold _ Oil LInes
Transmission Case _ End Cover
TRANSMISSION CASE-CONVERSION KIT
TRANSMISSION CASE
DIPSTICK
PTO BEARING QUILL CONVERSION KIT
TRANSMISSION DRIVE SHAFT AND SYNCHRONIZING PARTS
HOLLOW DRIVE SHAFT
REVERSE RANGE CONVERSION KIT (WITH HI-LO SHIFT UNIT_FWD)
PINION SHAFT_GROUP SHAFT
Console Shift
Console Shift Linkage
Shifter Shaft Housing
Cover For Shift Linkage
TRANSMISSION OIL LINES_OIL CUP
LUBRICATING LINES_OIL CUP
TRANSMISSION OIL FILTER
DIFFERENTIAL LOCK MECHANISM
DIFFERENTIAL
FINAL DRIVE_REAR AXLE
PTO SHIFT LINKAGE
PTO SHIFT LINKAGE
SHIFTER FORK AND SHAFT FOR PTO
INDEPENDENT PTO 540-1000 RPM (HANDSHIFT)
PTO COUNTERSHAFT
FRONT AND REAR PTO GUARDS
FRONT PTO - DRIVE AND SOLENOID (ROTATES CLOCKWISE-SEEN FROM OP. SEAT)
FRONT PTO - DRIVE AND SOLENOID (ROTATES ANTI-CLOCKWISE-SEEN FROM OP. SEAT)
FRONT PTO_SOLENOID VALVE
FRONT PTO - CLUTCH (ROTATES ANTI-CLOCKWISE-SEEN FROM OP. SEAT)
FRONT PTO_HOUSING AND CLUTCH
FRONT PTO_SHIFT LINKAGE AND BEARING COVER
FRONT PTO-OIL LINES
FWD - UNIVERSAL JOINTED SHAFT
FWD - ANTI-WRAP GUARD
FWD-STEERING AXLE (APL 350)
FWD-DRIVE ELEMENTS (INPUT)
FWD-MULTIPLE DISK SELF-LOCK. DIFFERENTIAL
FWD-AXLE BRIDGE
FRONT WHEEL DRIVE-AXLE SUSPENSION
FRONT AXLE DRIVE TIE ROD
FWD-KNUCKLE HOUSING
Front Double Universal Joint (APL 350)
FWD-PLANETARY DRIVE
HYDROSTATIC STEERING-STEERING COLUMN
HYDROSTATIC STEERING UNIT WITH FWD
STEERING UNIT-SEAL KIT
PRESSURE REDUCTION VALVE
HYDROSTATIC STEERING OIL LINES
OIL LINES AND ATTACHING PARTS FOR HYDROSTATIC STEERING
STEERING CYLINDER
BRAKE DISK
BRAKE VALVE
BRAKE VALVE
RETURN LINE STEERING UNIT_BRAKE VALVE
FIELD INSTALLATION KIT-OIL RETURN (SG2 CAB)
SEQUENCE VALVE AND BRAKE LINES
HANDBRAKE (SG2 CAB)
HANDBRAKE LINKAGE (SG2 CAB)
HANDBRAKE-BAND
DISK BRAKE FOR UNIVERSAL JOINTED DRIVE SHAFT
HYDRAULIC TRAILER BRAKES
HYDRAULIC TRAILER BRAKE, BRAKE VALVE
HYDRAULIC PUMP DRIVE (23CM3=1.4 CU.IN.)
HYDRAULIC PUMP DRIVE PARTS (23CM3=1.4 CU.IN.) WITH FRONT PTO
HYDRAULIC PUMP DRIVE (40 CM3-2.4 CU.IN.)
HYDRAULIC PUMP (23CM3=1.4 CU.IN.)
HYDRAULIC PUMP SEALING SET (23CM3=1.4 CU.IN.)
HYDRAULIC PUMP REPAIR SET (23CM3=1.4 CU.IN.)
SHUT-OFF SCREW FOR HYDRAULIC PUMP (23CM3)
HYDRAULIC PUMP (23CM3=1.4 CU.IN.) WITH FRONT PTO
CONNECTING PARTS FOR HYDRAULIC PUMPS (12CM3=0.7 CU.IN._23CM3=1.4 CU.IN.)
HYDRAULIC PUMP (40CM3=2.4 CU.IN.)
HYD. PUMP COVER AND VALVES (40CM3=2.4 CU.IN.)
HYDRAULIC PUMP KIT (40CM3=2.4 CU.IN.) MODEL NO. EA1
FLOW CONTROL VALVE
HYDRAULIC OIL LINES
HYDRAULIC OIL RESERVOIR_OIL COOLER
TRANSMISSION CASE OIL FILLER NECK
PARTS FOR RATE-OF-DROP ADJUSTMENT
START SAFETY SWITCH
ROCKSHAFT HOUSING
ROCKSHAFT CYLINDER AND VALVE HOUSING
ROCKSHAFT_PISTON_LIFT ARMS
ROCKSHAFT CYLINDER AND VALVE HOUSING-LINKAGE
ADDITIONAL LIFT CYLINDER_ATTACHING PARTS
ADDITIONAL LIFT CYLINDER SEAL KIT
BRACKET FOR SHIFT LINKAGE
ROCKSHAFT CONTROL LEVER
ROCKSHAFT REMOTE CONTROL
Selector Lever
ROCKSHAFT-SEALING KIT
PARTS FOR LOAD CONTROL
THREE POINT HITCH CENTER LINK
THREE POINT HITCH-HOOK DRAFT LINKS
BALL JOINTS FOR HOOK-TYPE DRAFT LINKS
THREE POINT HITCH LIFT LINK, LEFT-HAND
THREE POINT HITCH LIFT LINKS RH
THREE POINT HITCH - LIFT LINK ADJUSTMENT
LATERAL STABILIZING CHAIN
SWAY BLOCKS AND SUPPORTS
IMPLEMENT DRAWBAR
DOUBLE ACTING SELECTIVE CONTROL VALVE
SCV Valve Block
BRACKET FOR SELECTIVE CONTROL VALVES
OIL LINES FOR SELECTIVE CONTROL VALVES
SELECTIVE CONTROL VALVE LINKAGE
QUICK DISCONNECT COUPLERS CENTER
OIL LINES FOR REAR QUICK COUPLERS
OIL LINES FOR QUICK DISCONNECT COUPLERS, REAR
Oil Lines_Quick-Disconnect Couplers, Rear (For 3 SCV Control)
COUPLER FOR QUICK COUPLER
CONNECTING PARTS FOR HYDRAULIC MOTOR
REMOTE CONTROL CYLINDER WITH HYDRAULIC STOP (MODEL 6RC1)
REMOTE CONTROL CYLINDER WITH MECHANICAL STOP (MODEL 7RC1)
FRONT HITCH FRAME
OIL LINES_SHUT-OFF VALVE (FRONT HITCH)
HYDRAULIC HOSES_LIFTING CYLINDER WITH FRONT HITCH
LIFT CYLINDER_SEAL KIT (FRONT HITCH)
FRONT TRAILER HITCH (FRONT HITCH)
FRONT HITCH CENTER LINK
OIL LINES_QUICK-DISCONNECT COUPLERS FRONT (FRONT HITCH)
HEIGHT ADJUSTABLE TRAILER HITCH
TRAILER HITCH _ROCKINGER_ CONTROL LEVER
HITCH _AXLA_
_AXLA_ HITCH-CONTROL LEVER
DRAWBAR
DRAWBAR FOR _AXLA_ TRAILER HITCH
SIDE FRAMES
LUBRICATION - FRONT AXLE PIN
FRONT SUPPORT
FRAME WEIGHTS
FRONT WHEELS
REAR WHEELS
WEIGHTS FOR REAR WHEELS
VALVE FOR TUBELESS TIRES
FRONT FENDERS (WIDTH 440MM)
FRONT FENDER
FENDERS
FENDER FOR SNOW CHAINS
REFLECTORS_BRACKETS
REFLECTOR_BRACKET FOR SNOW CHAINS
FRONT PLATE
HOOD_GRILLE
BATTERY BOX (WITH SG2 CAB)
STEPS
STEP ON FRONT AXLE
PLASTIC TOOL BOX AND ATTACHING BRACKET
TOOL BOX BRACKET (WITH RH DOOR)
SHEET METAL TOOL BOX AND ATTACHING BRACKET
TOOLS
NAME PLATES_DECALS
NAME PLATES_DECALS
CHOCK BLOCK
ACCESSORY PARTS
ACCESSORY PARTS
PLASTIC PLUG
SUPPORT BRACKET
RG2 ROLL GUARD FRAME
SG2 CAB-FRAME
SG2 CAB FRAME WITH LEFT AND RIGHT-HAND DOORS
DOOR LH
INDIVIDUAL PARTS-FIELD KIT FOR REMOTE CYLINDER LINES
DOOR HANDLES_LATCH
FRONT WINDSHIELDS
FRONT WINDSHIELDS WITH RIGHT-HAND DOOR
REAR FIXED SIDE SWING WINDOW
REAR WINDOW (SWINGS OUT 90 DEGREES)
RUBBER SURROUNDS FOR WINDOW-LEFT HAND DOOR-SERVICE DOOR
RUBBER SURROUNDS-RIGHT HAND DOOR
FRAME STRIPS
RG2 ROLLGARD CANOPY
SG2 CAB-ROOF
SG2 CAB ROOF WITH HATCH
HATCH
SG2 CAB - LOW PROFILE
LOW PROFILE SG2 CAB-INNER LINING
CAB ROOF HEADLINER
CAB ROOF HEADLINER WITH HATCH
AIR CIRCULATION FILTER PARTS
FAN AND HEATER PARTS FOR LOW PROFILE CAB
AIR CLEANER FOR LOW PROFILE CAB
AIR CIRCULATION PARTS-BLOWER
HEATER PARTS (WITH SG2 CAB)
COMPRESSOR MOUNTING PARTS (WITH AIR CONDITIONING)
COMPRESSOR-AIR CONDITIONING, SYSTEM
EVAPORATOR AND REAR PIPES
AIR CONDITIONING LINES
CONVERSION KIT-AIR CONDITIONING FROM R12 TO R134A (SG2)
GUARD FOR HEATER AND AIR CONDITIONING SYSTEM LINES
CONDENSER
CAB ROOF HEADLINER COVER
CAB ROOF HEADLINER COVER FOR LOW PROFILE CAB
ROOF PANEL FOR LOW PROFILE CAB
AIR LOUVERS AND HEADLINER
CAB LINING
PLATFORM MATS AND COVER
SUN VISOR
CONTROL SUPPORT_COWL
INSTRUMENT PANEL
DASH INSULATION
ASHTRAY
GEAR SHIFT CONSOLE
FRONT WINDSHIELD WIPER LEFT-HAND
FRONT WINDSHIELD WIPER, RIGHT-HAND
FRONT DOOR WINDSHIELD WIPER_REAR WIPER WITH BRACKET
WINDSHIELD WIPER MOTOR-INDIVIDUAL PARTS-REPAIR KIT
WINDSHIELD WASHER
REAR VIEW MIRROR
REAR VIEW MIRROR
REAR VIEW MIRROR (TELESCOPIC)
Deluxe Seat (With Rg2 Roll Guard)
DELUXE SEAT (INDIVIDUAL PARTS)
Deluxe Seat
SWIVEL-TYPE ARM RESTS FOR SEATS DS44_1H-4G AND DS44_1HA-4G
SAFETY BELT FOR DELUXE SEAT DS44_2H-4G
OPERATORS SEAT (WITH CAB)
OPERATORS SEAT (WITH CAB) INDIVIDUAL PARTS
Super Deluxe Seat (With Sg2 Cab And Rg2 Roll Guard)
SUPER DELUXE SEAT, CUSHIONS AND ADJUSTMENT
SUPER DELUXE SEAT, INDIVIDUAL PARTS
SUPER DELUXE SEAT, ADJUSTMENT AND COVER FOR GRAMMER DS85H_90A
SUPER DELUXE SEAT, ADJUSTMENT AND COVER FOR GRAMMER DS85H1_90A
SUPER DELUXE SEAT BASE FOR GRAMMER DS85H_90A
SUPER DELUXE SEAT BASE FOR GRAMMER DS85H1_90A
FOOT SUPPORT
PASSENGER SEAT
SAFETY BELT FOR SUPER DELUXE SEAT
PASSENGER SEAT WITH BOX (WITH SG2 CAB)
Comfort Seat DS44_1HBA
Mounting Parts, Comfort Seat DS44_1HBA
Seat Cushion, Comfort Seat DS44_1HBA
Backrest Extension DS44_1HBA
Seat Belt, Comfort Seat DS44_1HBA
