John Deere Series 300 3029 4039 4045 6059 6068 OEM Diesel Engine Operators Manual OMRG18293
- Download this document, you need 200 Gallons
Brand: John Deere
Type of Machine: Engines
Model: John Deere Series 300 3029,4039,4045,6059, and 6068 OEM Diesel Engines
Serial Number: 237946
Part Number: OMRG18293
Number of Pages: 123 Pages
Record Keeping
Engine Serial Number Plate
Record Engine Serial Number
Engine Option Codes
Record PTa Serial Number
Record Fuel Injection Pump Model
Number
Safety
Fuels, Lubricants, and Coolant
Diesel Fuel
Diesel Fuel Storage
Filling Fuel Tank
Minimizing the Effect of Cold Weather on
Diesel Engines
Engine Break-in Oil
Engine Oil
OILSCANTM and COOLSCANTM
Grease
Lubricant Storage
Engine Coolant Requirements
Recommended Engine Coolant
Engine Coolant Specifications
Replenishing Supplemental Coolant
Additives Between Coolant Changes
Disposing Of Coolant
Engine Operating Guidelines
Instrument (Gauge) Panel
Break-In Service
Daily Prestarting Checks
Auxiliary Gear Drive Limitations
Standby Power Units
Starting the Engine
Cold Weather Operation
Warming Engine
Changing Engine Speed-Standard
(Mechanical) Governor
Idling Engine
Page
Stopping the Engine
USing A Booster Battery or Charger
Lubrication and Maintenance
Observe Service Intervals
Use Correct Fuels, Lubricants, and
Coolant
Lubrication and Maintenance Service
Interval Chart
Lubrication and Maintenance/100 Hour
Lubricate PTa Clutch Shaft Bearings
Service Fire Extinguisher
Lubrication and Maintenancel250 Hour
Service Battery
Change Engine Oil and Filter
Fan and Alternator Belts Tension or
Replacement
Check PTa Clutch Adjustment
Lubrication and Maintenance/400 Hour
Check and Adjust Engine Valve
Clearance
Lubrication and Maintenance/SOO Hr/1-Yr
Lubricate PTa Clutch Internal Levers and
Linkage
Clean Crankcase Vent Tube
Check Air Intake Hoses
Replace Fuel Filter Element
Check Effectiveness of Coolant Solution
Replace Air Cleaner Elements
Check Air Intake System
Check Cooling System
Lubrication and Maintenance/1200 Hr/2-Yr
Check and Adjust Engine Speeds
Adjust Variable Speed on Generator Set
Engines
Adjust Engine Valve Clearance
Check Fuel Injection System
Inspect Turbocharger
Check Crankshaft Vibration Damper
Flush Cooling System and Replace
Thermostats
Pressure Test Cooling System and
Radiator Cap
Perform Engine Tune-Up
Service/As Required
Additional Service Information
Do Not Modify Fuel System
Bleed the Fuel System
Checking Coolant Level
Adding Coolant
Remove and Inspect Air Cleaner
Elements
Cleaning Primary Filter Element
Washing Primary Filter Element
Inspecting Primary Filter Element
Element Storage
Replace Fan and Alternator Belts
Power Take-Off (PTO) Clutch
Check Instrument (Gauge) Panel Fuses
Troubleshooting
General Troubleshooting Information
Engine Wiring Diagram Legend
Wiring Diagram-North American Series
300 Engines
Wiring Diagram-European (Saran)
Series 300 Engines
Diagnosing Engine Malfunctions
Diagnosing Electrical System Malfunctions
Storage
Use AR41785 Engine Storage Kit
Storing the Engine
Removing Engine From Storage
Specifications
General OEM Engine Specifications
Fuel Injection Pump Specifications
Engine Crankcase Oil Fill Quantities
Unified Inch Bolt and Cap Screw Torque
Values
Metric Bolt and Cap Screw Torque
Values
Lubrication and Maintenance Records 99
Index
Brand: John Deere
Record Keeping
Engine Option Codes
Number
Safety
Diesel Fuel
Diesel Fuel Storage
Filling Fuel Tank
Diesel Engines
Engine Break-in Oil
Engine Oil
Grease
Lubricant Storage
Break-In Service
Standby Power Units
Starting the Engine
Warming Engine
Idling Engine
Page
Stopping the Engine
Coolant
Interval Chart
Service Battery
Replacement
Clearance
Linkage
Engines
Thermostats
Radiator Cap
Service/As Required
Adding Coolant
Elements
Element Storage
Troubleshooting
300 Engines
Series 300 Engines
Storage
Storing the Engine
Specifications
Values
Values
Index
- JOHN DEERE CODE DTC LIST
