Hyundai
86
176,834
John Deere Self-Propelled Windrower 4990 Repair Technical Manual TM1819
Brand: John Deere
Type of Machine: Self-Propelled Windrower
Model: John Deere 4990 Self-Propelled Windrower
Part Number: TM1819
Publication Date: 2001
Number of Pages: 521 Pages
General
Safety​
Recognize Safety Information​
Understand Signal Words​
Handle Fluids Safely-Avoid Fires​
Prevent Battery Explosions​
Prepare For Emergencies​
Prevent Acid Burns​
Handle Chemical Products Safely​
Avoid High-Pressure Fluids​
Park Windrower Safely​
Stay Clear of Rotating Driveline​
Support Machine Properly​
Wear Protective Clothing​
Work In Clean Area​
Service Machines Safely​
Work In Ventilated Area​
Illuminate Work Area Safely​
Replace Safety Signs​
Use Proper Lifting Equipment​
Remove Paint Before Welding or Heating​
Avoid Heating Near Pressurized Fluid Lines​
Service Tires Safely​
Avoid Harmful Asbestos Dust​
Practice Safe Maintenance​
Use Proper Tools​
Construct Dealer-Made Tools Safely​
Dispose of Waste Properly​
Live With Safety​
Practice Safe Service Procedures​
Specifications​
4990 (S.N. -163100) Self-Propelled Windrower Specifications [Specifications and design subject to change without notice.]​
4990 (S.N. 163101-) Self-Propelled Windrower Specifications [Specifications and design subject to change without notice.]​
Dimensions​
Metric Bolt and Cap Screw Torque Values​
Unified Inch Bolt and Cap Screw Torque Values​
Service Recommendations For O-Ring Boss Fittings​
Service Recommendations For Flat Face O-Ring Seal Fittings​
Service Recommendations For 37° Flare and 30° Cone Seat Connectors​
Service Recommendations For Flare-Type Tube Fittings​
SAE Four Bolt Flange Fitting Torque Chart​
Product Identification Number Plate​
Windrower Product Identification Number Plate Location​
Engine Serial Number​
Fuel Injection Pump Serial Number​
Cab Serial Number​
Fuel, Coolant and Lubricants​
Diesel Fuel​
Diesel Fuel Storage​
Lubricity of Diesel Fuel​
Diesel Engine Coolant​
Supplemental Coolant Additives​
Operating in Warm Temperature Climates​
Diesel Engine Coolants, Supplemental Additive Information​
Testing Diesel Engine Coolant​
Diesel Engine Oil​
Diesel Engine Break-In Oil​
Hydrostatic Drive System and Main Hydraulic System Oil​
Final Drive Oil​
Grease​
Alternative and Synthetic Lubricants​
Lubricant Storage​
Engine​
John Deere Engine Repair-Use CTM104​
Essential or Recommended Tools​
Service Equipment and Tools​
Specifications​
Remove and Install Engine​
Checking Vibration Damper​
Replace Vibration Damper​
Replace Engine Mount Isolators​
Remove and Install Serpentine Belt​
Cooling System​
Engine Water Pump Repair-Use CTM104​
Other Material​
Specifications​
Inspect Cooling System​
Remove and Install Radiator​
Disassemble, Inspect and Assemble Radiator Assembly​
Fill Radiator​
Winterize Cooling System​
Flush Out Cooling System​
Fuel and Air Systems
Air Intake and Exhaust​
Turbocharger Repair-Use CTM104​
Cleaning Bowl-Type Air Precleaner​
Cleaning Precleaner Screen​
Cleaning Air Precleaner​
Remove and Install Air Filters​
Clean and Inspect Primary Air Filter​
Remove and Install Air Precleaner and Intake Tube​
Remove and Install Exhaust Tube​
Diesel Fuel System​
Injection Pump, Nozzle, and Governor Repair-Use CTM207​
Specifications​
Shut Off Fuel Supply​
Drain Fuel Tank​
Remove and Install Fuel Tank​
Do Not Modify Fuel System​
Drain Water From Fuel Filter​
Bleed Fuel Filter​
Change Fuel Filter​
Bleed Fuel Injection Pump​
Bleed Fuel Lines to Injectors​
Check and Set Engine Speed​
Electrical
Batteries​
Specifications​
Remove and Install Battery(ies)​
Using Booster Batteries-12 Volt System​
Charging Battery(ies)​
Checking Specific Gravity​
Starter​
Starter Repair-Use CTM77​
Specifications​
Remove and Install Starter Motor​
Alternator​
Alternator Repair-Use CTM77​
Remove and Install Alternator​
Engine Electrical Components​
Other Material​
Replace Fuel Level Sensor​
Replace Air Restriction Switch​
Replace Engine Coolant Temperature Switch​
Replace Engine Coolant Temperature Sensor​
Replace Engine Oil Pressure Switch​
Replace Engine Speed Sensor​
Replace Throttle Motor​
Disassemble and Inspect Throttle Motor​
Remove Rotating Wand Motor​
Rotating Wand Motor-Exploded View​
Install Rotating Wand Motor​
Lighting and Accessory Components​
Specifications​
Halogen Bulb Safety Guidelines​
Replace and Adjust Cab Headlight Bulb​
Replace Flood Light Bulb​
Replace Rear Warning, Tail, and Side Marker Light Bulbs​
Replace Turn Signal Indicator Bulb​
Replace Dome and Console Light Bulb​
Replace Key Switch​
Replace Light Switch, Light Panel Dimmer, and Wiper Switch (S.N. -163100)​
Replace Light Switches and Wiper Switch (S.N. 163101-)​
Replace Turn Signal Switch (S.N. -163100)​
Replace Turn Signal Switch (S.N. 163101-)​
Replace Horn Switch​
Replace Horn​
Replace Overhead Console Horn​
Replace Seat Switch (S.N. -163100)​
Replace Seat Switch (S.N. 163101-)​
Replace Wiper Motor​
Adjust Windshield Wiper-Short Arm​
Adjust Windshield Wiper-Long Arm (Optional)​
Replace Radio (S.N. -163100)​
Replace Radio (S.N. 163101-)​
Replace Radio Speaker​
Replace Radio Antenna​
Mount Communications/CB Radio​
Install FM Radio​
Gauges and Monitors​
Replace Warning Panel or Light Bulbs​
Replace Gauges or Gauge Light Bulbs​
Replace Tachometer​
Program Tachometer​
Platform and Ground Speed Controls​
Specifications​
Replace Armrest Console Rocker Switches (S.N. -163100)​
Replace Armrest Console Rocker Switches (S.N. 163101-)​
Replace Armrest Console Toggle Switches (S.N. -163100)​
Replace Armrest Console Circuit Board (S.N. -163100)​
Replace Hydro Lever Switch Module​
Replace Hydro Lever Neutral Switch (S.N. -163100)​
Replace Hydro Lever Neutral Switch (S.N. 163101-)​
Remove and Install Hydro Lever (S.N. -163100)​
Remove and Install Hydro Lever (S.N. 163101-)​
Replace Platform Speed Control​
Disassemble and Inspect Platform Speed Control​
Replace Steering Neutral Start Switch​
Replace Hydraulic Filter Restriction Switch​
Replace Hydraulic Charge Pressure Switch​
Replace Hydraulic Oil Temperature Switch​
Replace Hydraulic Float Pressure Transducer​
Replace Ground Speed Sensor​
Adjust Ground Speed Sensor Magnetic Pickup​
Replace Solenoid Coils​
Cab Heat and A/C Electrical Components​
Other Material​
Replace Air Conditioning Switch (S.N. -163100)​
Replace Blower Motor Control Switch (S.N. -163100)​
Replace Blower Motor Control Switch (S.N. 163101-)​
Replace Air Conditioning Temperature Control Switch (S.N. 163101-)​
Replace Blower Motor​
Replace Blower Motor Resistor​
Replace Cab Pressurizer Motor​
Replace Air Conditioning Thermostat​
Replace Air Conditioning Low Pressure Switch​
Replace Air Conditioning High Pressure Switch​
Connector Repair​
Other Material​
Electrical Connector Handling​
Use Contact Cleaner and Di-electric Grease​
Replace WEATHER PACK Connector​
Install WEATHER PACK Terminal​
Remove Connector Body from Blade Terminals​
Replace METRI-PACK (Push Type) Connectors​
Replace CPC, Large MATE-N-LOK and METRIMATE™ Pin Type Connectors​
Replace DEUTSCH Connectors​
Flat Face O-Ring vs. Flare Hydraulic Fittings (S.N. 151107-)​
Power Train
Hydrostatic System Flushing and Start-Up​
Specifications​
Flush Hydrostatic Ground Drive System​
Hydrostatic Ground Drive System Start-Up​
Pump Drive Gear Case​
Other Material​
Remove and Install Pump Drive Gear Case​
Disassemble and Inspect Pump Drive Gear Case​
Assemble Pump Drive Gear Case​
Circulating Pump and Oil Cooler​
Other Material​
Remove and Install Circulating Pump​
Disassemble Circulating Pump​
Inspect Circulating Pump​
Assemble Circulating Pump​
Clean Pump Drive Gear Case Oil Cooler​
Replace Pump Drive Gear Case Oil Cooler​
Ground Drive Pumps​
Other Material​
Specifications​
Remove and Install Right-Hand Ground Drive Pump​
Disassemble Ground Drive Pump​
Inspect Ground Drive Pump​
Assemble Ground Drive Pump​
Ground Drive Motor​
Other Material​
Remove and Install Ground Drive Motor​
Disassemble Ground Drive Motor​
Inspect Ground Drive Motor​
Assemble Ground Drive Motor​
Final Drive (S.N. -163100)​
Other Material​
Specifications​
Remove and Install Final Drive​
Disassemble and Inspect Final Drive​
Assemble Final Drive​
Final Drive (S.N. 163101-)​
Essential Tools or Recommended Tools​
Other Material​
Specifications​
Disassemble Final Drive Hub​
Assemble Final Drive Hub​
Ground Drive Linkage (S.N. -163100)​
Remove and Install Ground Drive Control Cables​
Remove and Install Ground Drive Linkage Rods​
Ground Drive Linkage (S.N. 163101-)​
Remove and Install Ground Drive Control Cable​
Steering and Brakes
Steering System (S.N. -163100)​
Other Material​
Specifications​
Remove Steering Mechanism​
Disassemble and Inspect Steering Mechanism​
Assemble Steering Mechanism​
Install Steering Mechanism​
Disassemble and Assemble Steering Column​
Steering System (S.N. 163101-)​
Other Material​
Specifications​
Brakes​
Specifications​
Remove and Install Brake Disk and Caliper​
Inspect Brake Disk and Caliper Components​
Assemble Brake Disk and Caliper​
Auxiliary-Charge Pump​
Other Material​
Specifications​
Disassemble Auxiliary-Charge Pump​
Inspect Auxiliary-Charge Pump​
Assemble Auxiliary-Charge Pump​
Platform Drive Pump​
Other Material​
Specifications​
Disassemble Platform Drive Pump​
Inspect Platform Drive Pump​
Assemble Platform Drive Pump​
Repair Control Valve​
Disassemble and Assemble End Cover​
Check and Adjust Platform Drive Speed​
Platform Drive Motor​
Other Material​
Specifications​
Disassemble Platform Drive Motor​
Inspect Platform Drive Motor​
Assemble Platform Drive Motor​
Main Hydraulic Control Valve​
Specifications​
Remove and Install Main Hydraulic Control Valve​
Replace Solenoid Coils and Valve Cartridges​
Hydraulic Cylinders​
Other Material​
Remove and Install Lift and Tilt Cylinders, and Float Cylinders with Adjusters​
Disassemble and Inspect Float Cylinder​
Assemble Float Cylinder​
Replace Float Cylinder End Block Needle Bearings​
Repair Lift Cylinder​
Disassemble and Inspect Tilt Cylinder​
Assemble Tilt Cylinder​
Repair Steering Lock Cylinder​
Miscellaneous​
Specifications​
Clean Oil Cooler/Condenser​
Replace Oil Cooler/Condenser​
Replace Hydraulic Accumulator​
Drain and Fill Hydraulic Reservoir​
Remove and Install Hydraulic Reservoir​
Miscellaneous
Rear Axle​
Other Material​
Specifications​
Repair Caster Wheel Hub​
Remove and Install Axle Knee​
Remove and Inspect Rear Axle Assembly​
Install Rear Axle Assembly​
Replace Axle Knee Bushings​
Replace Rear Axle Bushings​
Adjust Caster Wheel Track Width​
Drive Wheels​
Specifications​
Remove and Install Drive Wheels​
Lift Arm​
Specifications​
Replace Lift Arm Bearings​
Operator Station
Air Conditioning Service​
Other Material​
Specifications​
General Information​
R134a Refrigerant Cautions​
Air Conditioning System-Diagram​
Proper Refrigerant Handling​
Refrigerant Hoses and Tubing Inspection​
Recover R134a System​
Flush Air Conditioning System​
Purge Air Conditioning System​
Evacuate R134a System​
Charge R134a System​
Refrigerant Oil Information​
Check Compressor Oil Charge​
Determine Correct Refrigerant Oil Charge​
Add Refrigerant Oil to Pressurized System​
Add Refrigerant Oil to System​
Air Conditioning Repair​
Other Material​
Service Parts Kits​
Specifications​
Remove and Install Compressor​
Remove and Install Compressor Clutch Assembly​
Check Clutch Hub Clearance​
Inspect Compressor Manifold​
Inspect Compressor Thermal Bypass Valve​
Disassemble and Inspect Compressor​
Assemble Compressor​
Replace Receiver-Dryer​
Remove and Install Compressor Relief Valve​
Remove Evaporator/Heater Core​
Install Evaporator/Heater Core​
Cleaning Condenser​
Repair Condenser​
Heater Controls​
Replace Heater Control Valve (S.N. -163100)​
Replace Heater Control Valve (S.N. 163101-)​
Cab (S.N. -163100)​
Specifications​
Remove and Install Windshield​
Replace Rear Window​
Remove and Install Cab Roof​
Remove Operator’s Seat Air Suspension Assembly​
Disassemble Operator’s Seat Air Suspension Assembly​
Inspect Operator′s Seat Air Suspension Assembly​
Assemble Operator’s Seat Air Suspension Assembly​
Install Operator’s Seat Air Suspension Assembly​
Replace Cab Mount Isolators​
Adjust Hydrostatic Ground Drive​
Cab (S.N. 163101- )​
Specifications​
Remove and Install Operator′s Seat​
Operator Seat Exploded View​
Operator Seat Air Suspension Assembly-Exploded View​
Disassemble Operator′s Seat Air Suspension Assembly​
Assemble Operator′s Seat Air Suspension Assembly​
Check Hydrostatic Ground Drive​
Dealer Fabricated Tools
Dealer Fabricated Tools​
DFEX1819A Spindle Retaining Tool (S.N. -163100)​
DFEX1819B Rolling Drag Torque Bar (S.N. -163100)​
DFEX1819C Guide​
DFEX1819D Compressor Holding Fixture​
DFEX1819E Support Plate​
Page Number
