Martin Welker
104
230,310
John Deere Self-Propelled Sprayers 4630 Diagnostic and Test Manual TM106219
Brand: John Deere
Type of Machine: Self-Propelled Sprayers
Type of Manual: Diagnostic and Test Manual
Model: John Deere 4630 Self-Propelled Sprayers
Part Number: TM106219
Publication Date: 2014
Number of Pages: 1451 Pages
FOREWORDs
Section 210 - GENERAL INFORMATION
Group 05 - Safety
Group 10A - Machine Specifications
Group 10B - Torque Values
Group 20 - Identification Number Location
Section 211 - DIAGNOSTIC TROUBLE CODES
Group 1 - BHC — Boom Hydraulics Control Unit
Group 2 - CCU — Chassis Control Unit
Group 3 - ECU — Engine Control Unit
Group 4 - iTC — Integrated Terrain Compensation
Group 5 - SRC — Spray Rate Control Unit
Group 6 - SSU — Steering Control Unit
Group 8 - TEC — Tractor Equipment Control Unit
Group 9 - TEI — Tractor Equipment Interface
Section 212 - OBSERVABLE SYMPTOMS
Group 220 - Engine
Group 230 - Air Intake and Cooling Systems
Group 240 - Electrical Systems
Group 250 - Power Train Systems
Group 260 - Brake Systems
Group 270 - Hydraulic Systems
Group 275 - Tread Adjust System
Group 280 - Steering Systems
Group 290 - Operator′s Cab System
Group 300 - Solution System
Group 310 - Foam Marker
Group 320 - Automatic Suspension Leveling System
Section 220 - ENGINE
Group 05 - General Information
Group 10 - Test Procedures
Group 15 - Engine Diagnostics
Group 20 - Component Location
Section 230 - AIR INTAKE AND COOLING SYSTEMS
Group 15A - Air Intake System
Group 15B - Engine Cooling System
Group 15C - Intercooler and Hydraulic Oil Cooling System
Section 240 - ELECTRICAL SYSTEM
Group 05A - General Information
Group 05B - Component Identification
Group 10A - Accessing Diagnostic Code and Addresses
Group 10B - Calibration Procedures
Group 10C - Caution and Warning Messages
Group 10D - Diagnostic Trouble Codes
Group 10E - Diagnostic Addresses
Group 10F - Component Tests
Group 15A - Agitation System
Group 15B - Air Conditioning and Heating System
Group 15C - Air Intake Heater
Group 15D - Auxiliary Power
Group 15E - Backup Alarm
Group 15F - Boom Fold/Unfold Diagnostics
Group 15G - Boom Leveling
Group 15H - Boom Raise and Lower
Group 15I - Boom Return to Height
Group 15J - CAN Bus
Group 15K - Caution Light
Group 15L - Charging System
Group 15M - Control Unit Power — BHC (Boom Hydraulics Control Unit)
Group 15N - Control Unit Power — CCU/SRC
Group 15O - Control Unit Power — ECU (Engine Control Unit)
Group 15P - Control Unit Power — SSU (Steering System Control Unit)
Group 15Q - Dome Light
Group 15R - Egress Light
Group 15S - Electric Fuel Pump
Group 15T - Electrical Power Supply
Group 15U - Engine Air Filter Restriction Switch
Group 15V - Engine and Fuel Control
Group 15W - Engine Coolant Temperature Sensor
Group 15X - Engine Oil Pressure
Group 15Y - Engine Speed Sensor
Group 15Z - Foam Marker
Group 15AA - Fuel Level Sensor
Group 15AB - GreenStar Automatic Steering
Group 15AC - GreenStar Display
Group 15AD - GreenStar Receiver
Group 15AE - Horn
Group 15AF - Hydraulic Oil Temperature
Group 15AG - Ladder
Group 15AH - Lighter
Group 15AI - Lights
Group 15AJ - Multifunction Control Handle
Group 15AK - Multifunction Control Handle Position
Group 15AL - Operator Presence Switch
Group 15AM - Park Brake
Group 15AN - Radar
Group 15AO - Radio
Group 15AP - Seat Adjust
Group 15AQ - Solution Pressure
Group 15AR - Solution Pump
Group 15AS - Speed Range
Group 15AT - Spray Valve Control
Group 15AU - Spray Rate
Group 15AV - Starting System
Group 15AW - Stop Indicator Light
Group 15AX - Throttle
Group 15AY - Traction Control
Group 15AZ - Tread Adjust
Group 15BA - Wheel Speed
Group 15BB - Wiper
Group 20 - Connector Information
Section 250 - POWER TRAIN SYSTEM
Group 10 - Tests
Group 15A - Final Drive
Group 15B - Hydrostatic Drive
Group 15C - Traction Control
Group 20 - Power Train Components
Section 260 - BRAKE SYSTEM
Group 10 - Test Procedures and Adjustments
Group 15A - Park Brake Diagnostics
Group 15B - Service Brakes Diagnostics
Group 20 - Brake System Component Location
Section 270 - HYDRAULIC SYSTEM
Group 15A - Hydraulic System Basic Diagnostics
Group 15B - Boom Leveling Diagnostics
Group 15C - Boom Raise and Lower Diagnostics
Group 15D - Boom Unfold and Fold Diagnostics
Group 15E - Ladder Diagnostics
Group 15F - Solution Pump Motor Diagnostics
Section 275 - TREAD ADJUST SYSTEM
Group 15 - Tread Adjust Diagnostics
Section 280 - STEERING SYSTEM
Group 15 - Steering System Diagnostics
Section 290 - OPERATOR STATION
Group 10 - Test and Adjustment Procedures
Group 15A - Air Conditioning and Heating Diagnostics
Section 300 - SOLUTION SYSTEM
Group 15 - Solution System Diagnostics
Group 20 - Solution System Component Location
Section 310 - FOAM MARKER SYSTEM
Group 15 - Foam Marker Diagnostics
Group 20 - Foam Marker Component Location
Section 320 - AIR SUSPENSION SYSTEM
Group 15 - Air Suspension Diagnostics
Group 20 - Air Suspension Component Location
Section 399 - SERVICE TOOLS
Group 05 - Dealer Fabricated Tools
Group 10 - Service Tools and Kits
