John Deere Rate Controller 2000 Operators Manual OMPFP19621
Brand: John Deere
Type of Machine: Controller
Model: John Deere Rate Controller 2000
Part Number: OMPFP19621
Publication Date: 2019
Number of Pages: 116 Pages
Introduction
Foreword
John Deere Technical Information Bookstore
Safety
Recognize Safety Information
Understand Signal Words
Follow Safety Instructions
Practice Safe Maintenance
Handle Electronic Components and Brackets Safely
Use Electronic Display Properly
Operate Guidance Systems Safely
Use Seat Belt Properly
Wear Protective Clothing
Operate Safely
Read and Understand MSDS
Working With Anhydrous Ammonia
Emergency Procedure For Anhydrous Ammonia
Prevent Electrical Shock and Fires
Avoid Exposure to High Radio Frequency Fields
Safety Signs
Malfunction of Implement Height Switch Detected
Unexpected NH3 Flow Detected
Unexpected Chemical Flow Detected
NH3 Diagnostic Tests
Diagnostic Tests
Unexpected Conveyor Movement Detected
Unexpected Meter Movement Detected
Unexpected Fan Movement Detected
Unexpected Spinner Movement Detected
Diagnostic Tests or Calibration Procedures
Regulatory and Compliance Information
Information to User
United States—Federal Communications Commission (FCC) Notifications to User
Canada—Industry Canada Notifications to User
System Overview
Theory of Operation
Rate Controller Requirements
Sections
Configuration Overview
John Deere Rate Controller 2000 Button
Help Button
Component Overview
Component Overview and Compatibility
Control Valves and Sensors
Pressure Sensor Configuration
Implement Height Indicator
StarFire™ Receiver
GreenStar™ Display or Generation 4 Display
Foot Switch
Setting Up
Configure Offsets
Setup Overview
Setup Wizard—Sprayer and Liquid Fertilizer Tool
Setup Wizard—NH3 Tool and a Raven Sidekick ICD Direct Injection Pump
Setup Wizard—Planter
Setup Wizard—Air Cart, Generic, and Spreader Tools
Set Up Section Groups
Set Up Dual Control Valve
Set Up Implement Height Indicator
Adjust Settings
Set Up Bin Chaining
Adjust Control Valve
Set Up NH3+ Boost Pump
Calibrate Flowmeter — Liquid Catch Test
Calibrate Flowmeter—Liquid Catch Test
Calibrate Rate Sensor — Dry Catch Test
Calibrate Rate Sensor—Dry Catch Test
Calibrate Flowmeter—Applied Liquid Product
Calibrate Rate Sensor—Applied Dry Product
Calibrate Pressure Sensor
Adjust Alarms
Adjust Rates
Operating
Run Page Overview — Sprayer and Liquid Fertilizer Tool
Run Page Overview — NH3 Tool
Run Page Overview — Planter
Run Page Overview — Spreader
Run Page Overview — Air Cart
Run Page Overview — Multiple Products
Activate System
Adjust Rate Control
Charge Tank / Bin
Disable or Enable Sections
Refill Tank / Bin
Quick Start
Tiered Boom Operation
Deactivate System
Review Totals
Troubleshooting
Diagnostic Trouble Codes (DTCs) — John Deere Rate Controller 2000
Observable Symptoms
Diagnostic Readings
System Summary
Product Summary
Test Speed
Tests
Configuration Test
Nozzle Flow Check
Rinse Cycle
Control / Section Test
Control Valve Test
Calibrate PWM Limits
Energize System
Bleed System Test
Spreader / Air Cart Check
Granular Flow Check
Bin / Tank Cleanout
Diagnostic LEDs
Data Cleanup
Specifications
Main Harness (47-Pin Connector) Table
John Deere Rate Controller 2000 Multi-Product Connector
Recommended Wire Sizes
Dual Control Valve
Driver Table—Single Product
Driver Table—Multiple Products
Inputs Table—Single Product
Inputs Table—Multiple Products
Maintenance
Preseason Checklist
Daily Checklist
Postseason Checklist
John Deere Service Literature Available
John Deere Service Keeps You on The Job
John Deere Is At Your Service
Brand: John Deere
Introduction
Foreword
Safety
Operate Safely
Safety Signs
Diagnostic Tests
Information to User
System Overview
Theory of Operation
Sections
Help Button
Component Overview
StarFire™ Receiver
Foot Switch
Setting Up
Configure Offsets
Setup Overview
Adjust Settings
Set Up Bin Chaining
Adjust Alarms
Adjust Rates
Operating
Activate System
Adjust Rate Control
Charge Tank / Bin
Refill Tank / Bin
Quick Start
Deactivate System
Review Totals
Troubleshooting
Observable Symptoms
Diagnostic Readings
System Summary
Product Summary
Test Speed
Tests
Configuration Test
Nozzle Flow Check
Rinse Cycle
Control Valve Test
Energize System
Bleed System Test
Granular Flow Check
Bin / Tank Cleanout
Diagnostic LEDs
Data Cleanup
Specifications
Dual Control Valve
Maintenance
Preseason Checklist
Daily Checklist
