John Deere Rate Controller 2000 Installation Instructions Manual PFP18435
Brand: John Deere
Type of Machine: Controller
Type of Manual: Installation Instructions Manual
Model: John Deere Rate Controller 2000
Part Number: PFP18435
Publication Date: 2017
Number of Pages: 68 Pages
Recognize Safety Information
Understand Signal Words
Follow Safety Instructions
Replace Safety Signs
Practice Safe Maintenance
Handle Electronic Components and Brackets Safely
Electrical System — General Instructions on Safety
Use Technical Manuals
Use Proper Tools
Wear Protective Clothing
Park Machine Safely
Instruction for Wire Routing
Operate Safely
Read and Understand MSDS
Working With Anhydrous Ammonia
Emergency Procedure For Anhydrous Ammonia
To The Dealer
Overview
Parts Bundles
Parts List
Installation Guidelines
Install Master Foot Switch and Power Harness
Install Mounting Bracket
Install John Deere Rate Controller 2000, Harness, and Master Foot Switch
Install Front Extension, Center Extension, and CAN Terminator Harnesses
Install Implement Adapter or Harness
Install Auxiliary Adapters
Install Implement Height Switch
Recommended Wire Sizes
GreenStar™ Rate Controller Adapter—PFA10955
Goldacres Adapter—PFA10956
Raven 440 / 450 Adapter—PFA10966
AccuFlow HP™ Plus 6 Section Harness—PFA10964
AccuFlow HP™ Plus 3 Section Harness—PFA10965
Liquid 20 Section Harness—PFA10961
Liquid 10 Section Harness—PFA10962
Liquid 6 Section Harness—PFA10963
Tank Fill Flowmeter Adapter—PFA10957
Pressure Transducer Adapter—PFA10958
Pump RPM Adapter—PFA10959
4 Product 16 Section Harness—PFA10983
5 Product 10 Section Harness—PFA10984
Section Control 6 Section Adapter—PFA11094
Multi-Product Harness—PFA10985
Liquid Product Adapter—PFA10986
Dry Product Adapter—PFA10987
AccuFlow HP™ Anhydrous Ammonia Multi-Product Harness—PFA10978
Generic Spreader Harness—PFA10979
Air Cart / Applicator 2 Product 16 Section Harness—PFA10981
3 Product 20 Section Harness—PFA10982
GreenStar™ Rate Controller Dry Adapter—PFA11091
Generic Rate Controller 37-Pin Adapter—PFA11092
Section Control 10 Section Adapter—PFA11093
6 ft 47-Pin to 47-Pin Extension Harness—PFA11466
12 ft 47-Pin to 47-Pin Extension Harness—PFA11467
47-Pin to 22-Pin Raven Adapter—PFA11468
Single Product 10 Section Generic Harness—PFA11469
12 ft Single Product Manure Harness—PFA11470
47-Pin to Dual 37-Pin GreenStar™ Rate Controller Adapter—PFA11471
AccuFlow™ Anhydrous Ammonia Single Section Harness—PFA11472
5 Product Full Width Harness—PFA11811
Granular Dual Control Valve Harness—PFA11828
Sections
Outputs Table — Single Product
Outputs Table — Multiple Product
Inputs Table — Single Product
Inputs Table — Multiple Product
Brand: John Deere
Use Proper Tools
Park Machine Safely
Operate Safely
To The Dealer
Overview
Parts Bundles
Parts List
Sections
