John Deere QuikTrak 648R to 661R EFI Mower Diagnostic And Tests Manual TM127719
Brand: John Deere
Type of Machine: Mower
Type of Manual: Diagnostic And Tests Manual
Model: John Deere 652R MOD, 652R EFI MOD, 648R, 661R, 652B, 661R EFI Mower
Serial Number:
Part Number: TM127719
Publication Date: 2015
Number of Pages: 756 Pages
FOREWORD
Section 10 - SAFETY
Group 05 - Safety
Recognize Safety Information
Understand Signal Words
Replace Safety Signs
Prepare for Emergencies
Prevent Battery Explosions
Prevent Acid Burns
Wear Protective Clothing
Avoid High-Pressure Fluids
Service Machines Safely
Use Proper Tools
Park Machine Safely
Support Machine Properly
Use Proper Lifting Equipment
Work in Clean Area
Using High-Pressure Washers
Protect Against High Pressure Spray
Illuminate Work Area Safely
Work In Ventilated Area
WARNING: California Proposition 65 Warning
Avoid Harmful Asbestos Dust
Service Tires Safely
Stay Clear of Rotating Drivelines
Service Cooling System Safely
Dispose of Waste Properly
Live With Safety
Section 20 - SPECIFICATIONS AND INFORMATION
Group 05 - Fastener Torques
Metric Cap Screw Torque Values—Grade 7
Group 10 - O-Ring Seal Service Recommendations
Face Seal Fittings With Inch Stud Ends Torque
Face Seal Fittings With Metric Stud Ends Torque
Group 15 - O-Ring Seal Service Recommendations
Service Recommendations For Flat Face O-Ring Seal Fittings
Service Recommendations for O-Ring Boss Fittings
Group 20 - General Information
Gasoline
Gasoline Storage
Engine Oil
Hydrostatic Transmission and Hydraulic Oil
Synthetic Lubricants
Alternative Lubricants
Anti-Corrosion Grease
Mower Spindle Grease
Lubricant Storage
Mixing of Lubricants
Oil Filters
Group 25 - Specifications
General Specifications
Group 30 - Serial Number Locations
Machine PIN
Engine Serial Number
Section 30 - ENGINE ECV740V (EFI)
Group 05 - Specifications
Specifications
Other Material
Service Equipment and Tools
Essential or Recommended Tools
Group 10 - Theory of Operation
Summary of References
General Engine Operation
Air Intake System
Lubrication System
Crankcase Breather System
Engine Control Module (ECM)
Fuel System
Throttle Body
Governor System
Ignition System
Group 15 - Engine Diagnosis
Engine Troubleshooting
Group 20 - Tests and Adjustments
Specifications
Adjust Governor
Adjust Low Idle Speed
Spark Test
Adjust Spark Plug Gap
Test Cylinder Leak-Down
Test Fuel Pump, Pulse
Test Fuel Pump, Module
Adjust Crankshaft Position Sensor Air Gap
Test Fuel Injector and Wires
Test Starter Solenoid
Group 25 - Repair
Remove Engine (EFI)
Install Engine (EFI)
Remove and Install Air Cleaner Element (EFI)
Remove and Install Air Cleaner Assembly (EFI)
Remove and Install Muffler (EFI)
Remove and Install Grass Screen (EFI)
Remove and Install Throttle Control Panel Assembly (EFI)
Remove and Install External Governor Controls (EFI)
Remove and Install Oil Cooler (EFI)
Remove and Install Oil Separator (EFI)
Remove Blower Housing and Outer Baffle (EFI)
Install Blower Housing and Outer Baffle (EFI)
Remove Inner Baffles and Breather Cover (EFI)
Install Inner Baffles and Breather Cover (EFI)
Remove Intake Manifold (EFI)
Install Intake Manifold (EFI)
Remove Lift Fuel Pump (EFI)
Install Lift Fuel Pump (EFI)
Remove and Install Fuel Pump Module (EFI)
Remove Fuel Injector (EFI)
Install Fuel Injector (EFI)
Remove and Install Throttle Body (EFI)
Remove and Install Throttle Position Sensor TPS (EFI)
Remove and Install Electronic Control Module ECM (EFI)
Remove and Install Oxygen Sensor (EFI)
Remove and Install Ignition Coil (EFI)
Remove and Install Oil Temperature Sensor (EFI)
Remove and Install Crankshaft Position Sensor (EFI)
Remove and Install Manifold Absolute Pressure (MAP) Sensor (EFI)
Remove and Install Intake Air Sensor (EFI)
Remove and Install Oil Sentry Switch (EFI)
Remove and Install Voltage Regulator/Rectifier (EFI)
Remove and Install Starting Motor (EFI)
Disassemble Starting Motor (EFI)
Starting Motor Armature (EFI)
Assemble Starting Motor (EFI)
Remove Valve Cover (EFI)
Install Valve Cover (EFI)
Remove Cylinder Head (EFI)
Install Cylinder Head (EFI)
Inspect Cylinder Head (EFI)
Remove and Install Rocker Arms (EFI)
Remove and Install Valves and Springs (EFI)
Inspect Valves (EFI)
Recondition Valve Seats (EFI)
Lap Valves (EFI)
Inspect Push Rods (EFI)
Inspect Valve Guides (EFI)
Inspect Hydraulic Valve Lifters (EFI)
Inspect Crankcase Breather Reed Valve (EFI)
Remove and Install Flywheel (EFI)
Remove and Install Stator (EFI)
Remove Oil Pan (EFI)
Install Oil Pan (EFI)
Remove and Install Oil Pan Crankshaft Seal (EFI)
Remove and Install Governor (EFI)
Remove Governor Cross Shaft (EFI)
Install Governor Cross Shaft (EFI)
Remove and Install Oil Pump (EFI)
Remove Camshaft (EFI)
Install Camshaft (EFI)
Inspect Cam Shaft (EFI)
Camshaft End Play (EFI)
Remove Piston (EFI)
Disassemble Piston (EFI)
Inspect Piston Pin (EFI)
Inspect Piston (EFI)
Assemble Piston (EFI)
Measure Piston Ring End Gap (EFI)
Piston Ring Side Clearance (EFI)
Measure Piston to Bore (EFI)
Remove and Install Crankcase Crankshaft Oil Seal (EFI)
Inspect Block (EFI)
Deglaze Cylinder Bore (EFI)
Measure Crankshaft and Connecting Rod (EFI)
Section 30A - ENGINE FX691V AND FX730V
Specifications
Group 10 - Tools and Materials
Other Material
Group 15 - Component Location
External Engine Components
Engine Block
Valves and Governor
Carburetor
Group 20 - Theory of Operation
Engine Oil Flow Chart
Lubrication System Operation
Governor Operation
Crankcase Breather Operation
Automatic Compression Release (ACR) Operation
Cooling System Operation
Carburetor Operation
Ignition System Operation
Group 25 - Diagnostics
System: Engine Troubleshooting
Symptom: Engine Does Not Crank
Step 1
Step 2
Step 3
Step 4
Step 5
Step 6
Step 7
Step 8
Step 1
Step 2
Step 3
Step 4
Step 5
Step 6
Step 7
Step 8
Symptom: Engine Cranks but Will Not Start
Step 1
Step 2
Step 3
Step 4
Step 1
Step 2
Step 3
Step 4
Symptom: Engine Hard to Start, Backfires, or Misses
Step 1
Step 2
Step 3
Step 4
Step 5
Step 6
Step 7
Step 8
Step 9
Step 10
Step 11
Step 12
Step 1
Step 2
Step 3
Step 4
Step 5
Step 6
Step 7
Step 8
Step 9
Step 10
Step 11
Step 12
Symptom: Engine Runs Erratically
Step 1
Step 2
Step 3
Step 4
Step 5
Step 1
Step 2
Step 3
Step 4
Step 5
Symptom: Engine Dies After Running
Step 1
Step 2
Step 1
Step 2
Symptom: Engine Malfunctions at Low RPM
Step 1
Step 2
Step 3
Step 4
Step 5
Step 1
Step 2
Step 3
Step 4
Step 5
Symptom: Engine Malfunctions at High RPM
Step 1
Step 2
Step 3
Step 4
Step 1
Step 2
Step 3
Step 4
Symptom: Excessive Oil Consumption
Step 1
Step 2
Step 1
Step 2
Symptom: Low Oil Pressure
Step 1
Step 2
Step 3
Step 4
Step 5
Step 6
Step 7
Step 8
Step 9
Step 1
Step 2
Step 3
Step 4
Step 5
Step 6
Step 7
Step 8
Step 9
Symptom: Engine Overheats
Step 1
Step 2
Step 3
Step 4
Step 5
Step 1
Step 2
Step 3
Step 4
Step 5
Symptom: Excessive Fuel Consumption
Step 1
Step 2
Step 3
Step 4
Step 1
Step 2
Step 3
Step 4
Symptom: Contamination in Crankcase
Step 1
Step 2
Step 1
Step 2
Starting Motor Rotates Slowly
Step 1
Step 2
Step 3
Step 4
Step 5
Step 1
Step 2
Step 3
Step 4
Step 1
Step 2
Step 3
Step 4
Step 5
Step 1
Step 2
Step 3
Step 4
Group 30 - Tests and Adjustments
Choke Cable Check and Adjustment
Throttle Cable Check and Adjustment
Governor Static Adjustment
Slow Idle Speed Adjustment
Fast Idle Speed Adjustment
Cylinder Compression Pressure Test
Cylinder Leak-Down Test
Valve Clearance Check and Adjustment
Fan Screen Check and Adjustment
Ignition Coil Air Gap Check and Adjustment
Spark Test
Test Engine Oil Pressure
Engine Oil Pressure Test
Fuel Pump Test
Crankcase Vacuum Test
Checking Carbon Canister and Fuel Lines
No-Load Amperage Draw and RPM Test
Group 35 - Repair
Replacing Fuel Filter
Remove and Install Throttle Cable
Remove and Install Choke Cable
Remove and Install Engine
Air Cleaner Service
Remove and Install Throttle Control Plate Assembly
Remove and Install Governor Lever Arm
Remove and Install Carburetor
Carburetor Repair
Carburetor Cleaning and Inspection
Float Level Check
Remove and Install Intake Manifold
Remove and Install Crankcase Breather
Remove and Install Blower Housing
Remove and Install Rocker Arm Cover
Remove and Install Rocker Arm and Push Rod
Rocker Arm and Push Rod Inspection
Disassemble and Assemble Cylinder Head
Cylinder Head and Valves Inspection
Analyze Valves
Lap Valves
Remove and Install Crankcase Cover
Crankcase Cover Disassembly, Inspection, and Assembly
Disassemble and Assemble Governor
Remove and Install Camshaft and Tappets
Camshaft and Tappets Inspection
Remove and Install Piston and Connecting Rod
Disassemble Piston and Connecting Rod
Piston and Connecting Rod Inspection
Check Piston Ring End Gap
Assemble and Install Piston and Connecting Rod
Analyze Piston Ring Wear
Analyze Piston Wear
Crankshaft Inspection
Check Connecting Rod-to-Crankshaft Clearance
Analyze Crankshaft and Connecting Rod Wear
Oil Seal Replacement
Resize Cylinder Bore
Disassemble and Assemble Starting Motor
Section 40 - ELECTRICAL
Specifications
Other Material
Group 15 - General Information
Theory of Operation Information
Diagnostic Information
Wire Color Abbreviation Chart
Reading Electrical Schematics
Group 25 - Schematics and Wiring Harnesses
Component ID Legend
Main Electrical Schematic—FX691V & FX730V Engines
Main Electrical Schematic—ECV740 EFI Engine
W1 Main Wiring Harness
W1 Main Wiring Harness Wire Codes
W2 Engine Wiring Harness—FX691V & FX730V
W4 Engine Interface Harness—ECV740 EFI
W5 Engine Wiring Harness—ECV740 EFI
W5 Engine Wiring Harness Wire Codes—ECV740 EFI
W6 Fuel Shutoff Wiring Harness—FX691V & FX730V
W7 Ignition Coil Wiring Harness—FX691V & FX730V
W8 Fuse Link Wiring Harness—FX691V & FX730V
Group 30 - Operation and Diagnostics
Use of Dielectric Grease
Power Circuit Operation - Unswitched Power
Power Circuit Operation - Switched Power
Power Circuit Schematic - FX691V & FX730V Engines
Power Circuit Schematic - ECV740 EFI Engine
Switched Power Checks
Battery
Starting Motor
Voltage Regulator
Main Fuse (voltage in)
Main Fuse (voltage out)
Key Switch
Key Switch
Unswitched Power Check
Key Switch
PTO Switch
Accessory Connector
OPC Switch
Main Harness/Engine Harness Connector
Fuel Shutoff/Engine Harness Connector (FX691V & FX730V)
Fuel Shutoff Solenoid
Hour Meter
OPC Relay
Battery
Starting Motor
Voltage Regulator
Key Switch
Key Switch
Key Switch
PTO Switch
Accessory Connector
OPC Switch
Hour Meter
OPC Relay
Cranking Circuit Operation
Cranking Circuit Schematic - FX691V & FX730V Engines
Cranking Circuit Schematic - ECV740 EFI Engine
Cranking Circuit Checks
Unswitched Power
Key Switch
PTO Switch (voltage in)
PTO Switch (voltage out)
Park Brake Switch (voltage in)
Park Brake Switch (voltage out)
Starting Motor Solenoid
Unswitched Power
Key Switch
Run Circuit Operation - Operator On Operator Platform
Run Circuit Operation—Operator Off Operator Platform
Run Circuit Schematic - FX691V & FX730V Engines
Run Circuit Schematic - ECV740 EFI Engine
Ground Circuit Checks
Switched Power
Fuel Shutoff Solenoid Ground (FX691V & FX730V)
OPC Switch
OPC Time Delay Module
OPC Relay
OPC Relay
PTO Switch
PTO Switch
Key Switch
OPC Relay
Ignition Coil/Engine Harness Connector (FX691V & FX730V engines)
Ignition Coils (FX691V & FX730V engines)
Accessory Connector
PTO Switch
Key Switch
Hour Meter
OPC Relay
Switched Power
OPC Switch
OPC Relay
OPC Relay
PTO Switch
PTO Switch
Key Switch
OPC Relay
Accessory Connector
PTO Switch
Key Switch
Hour Meter
OPC Relay
Charge Circuit Operation
Charge Circuit Checks
Unswitched Power
Starting Motor
Voltage Regulator/ Rectifier
Battery
Unswitched Power
Starting Motor
Battery
PTO Clutch Circuit Operation
PTO Clutch Circuit Schematic
PTO Clutch Circuit Check
Switched Power
PTO Switch
PTO Clutch
PTO Clutch Diode
OPC Switch
OPC Relay
OPC Relay
PTO Clutch Connector
PTO Clutch Diode
Switched Power
PTO Switch
PTO Clutch
PTO Clutch Diode
OPC Switch
OPC Relay
OPC Relay
PTO Clutch Diode
Hour Meter Circuit Operation
Hour Meter Circuit Schematic
Hour Meter Circuit Checks
Key Switch
Hour Meter
Hour Meter
Key Switch
Hour Meter
Hour Meter
Group 35 - Tests and Adjustments
Test Common Circuit
Test Ground Circuit
Test Battery
Charge Battery
Load Test Battery
Regulated Voltage Output Test
Unregulated Voltage Output Test
Stator Test
Starting Motor Solenoid Test
Starting Motor Cranking Amperage Test
Starting Motor No-Load Amperage Test
Spark Test
Fuse Test
Diode Test
Relay Test
Key Switch Test
PTO Switch Test
Park Brake Switch and Operator Presence (OPC) Switch Test
Ignition Coil Test - FX691V & FX730V
Flywheel Magnet Test - FX691V & FX730V
Fuel Shutoff Solenoid Test - FX691V & FX730V
Group 40 - Theory of Operation (ECV740 EFI Engine)
Engine Control Module (ECM) and General Sensor Circuit Operation
Crankshaft Position Sensor Operation
Throttle Position Sensor (TPS) Operation
Oil Temperature Sensor Operation
Intake Air Temperature Sensor Operation
Oxygen Sensor Operation
Manifold Absolute Pressure (MAP) Sensor Operation
Fuel Injector Operation
Ignition Coil Operation
Fuel Pump Operation
Group 45 - Diagnostic Trouble Codes (ECV740 EFI Engine)
Engine Diagnostic Trouble Codes (DTC) List
0031 - Oxygen Sensor Heater Circuit High Voltage
0032 - Oxygen Sensor Heater Circuit Low Voltage
0107 - Manifold Absolute Pressure Sensor Circuit Low Voltage or Open
0108 - Manifold Absolute Pressure Sensor Circuit High Voltage
0112 - Intake Air Temperature Sensor Circuit Low Voltage
0113 - Intake Air Temperature Sensor Circuit High Voltage or Open
0117 - Oil Temperature Sensor Circuit Low Voltage
0118 - Oil Temperature Sensor Circuit High Voltage or Open
0122 - Throttle Position Sensor Circuit Low Voltage or Open
0123 - Throttle Position Sensor Circuit High Voltage
0131 - Oxygen Sensor Circuit Low Voltage or Open
0132 - Oxygen Sensor Circuit High Voltage
0171 - Maximum Adaptation Limit Exceeded
0172 - Minimum Adaptation Limit Exceeded
0174 - Lean Fuel Condition at High Load (Open Loop)
0201 - Injector 1 Circuit Malfunction
0202 - Injector 2 Circuit Malfunction
0230 - Fuel Pump Module Circuit Low Voltage or Open
0232 - Fuel Pump Module Circuit High Voltage
0336 - Crankshaft Position Sensor Noisy Signal
0337 - Crankshaft Position Sensor No Signal
0351 - Cylinder 1 Ignition Coil Malfunction
0352 - Cylinder 2 Ignition Coil Malfunction
0562 - System Voltage Low
0563 - System Voltage High
61 - End of Code Transmission
Group 50 - Tests and Adjustments (ECV740 EFI Engine)
EFI Crankshaft Position Sensor Test
EFI Throttle Position Sensor Test
EFI Engine Oil Temperature Sensor Test
EFI Intake Air Temperature Sensor Test
EFI Manifold Absolute Pressure Sensor Test
EFI Oxygen Sensor Test
EFI Fuel Injector Electrical Test
EFI Ignition Coil Test
EFI Fuel Pump Module Electrical Test
EFI ECM Reset and TPS Learn Procedures
Group 55 - Repair
Remove and Install Battery
Clean Battery
Remove and Install PTO Clutch
Electric PTO Clutch Break-In Procedure
METRI-PACK™ Connector Removal
METRI-PACK™ Connector Replacement
Section 50 - POWER TRAIN
Specifications
Other Material
Group 10 - Component Location
Hydraulic System Hose Routing
Group 15 - Theory of Operation
JIC Hydraulic Circuit Symbols
Power Train Operation
Hydrostatic Power Train Schematic
Group 20 - Diagnostics
Hydrostatic System Diagnosis
Group 25 - Tests and Adjustments
Bleed Air from Hydraulic System
Check and Adjust Creep
Check and Adjust Transmission Tracking
Test Hydrostatic Pump Flow
Group 30 - Repair
Remove and Install Pump Drive Belt
Hydrostatic Pump Drive Belt Tension Arm Assembly Repair
Checking Hydraulic Oil Level
Hydrostatic Pump Removal and Installation - Fixed Deck Models
Hydrostatic Pump Removal and Installation - Floating Deck
Disassemble and Inspect Hydrostatic Pump
Assemble Hydrostatic Pump
Remove and Install Wheel Motor
Wheel Motor Disassembly and Inspection
Wheel Motor Assembly
Control Linkage Repair
Section 60 - BRAKES
General specifications
Specifications
Brake Operation
Group 15 - Diagnostics
Check and Adjust Park Brake - Floating Deck Models
Check and Adjust Park Brake - Fixed Deck Models
Group 25 - Repair
Park Brake Lever and Linkage
Section 70 - ATTACHMENTS
Specifications
Other Material
PTO Clutch Operation
Mower Drive Checks
Mower Drive Checks (Engine Running)
Mower Deck Will Not Run
Mower Excessive Noise
PTO Clutch Noisy or Vibration
Group 20 - Component Location
Mower Deck
Check and Adjust Mower Deck Drive Belt Tension
Level Mower Deck
Check and Adjust Cutting Height - Floating Deck
Check and Adjust Cutting Height - Fixed Deck
Check and Adjust Anti-Scalp Wheel Clearance
Adjusting Mulch-On-Demand (MOD) Linkages If Equipped
Group 30 - Repair
Remove and Install Mower Deck Drive Belt Shields - Floating Deck
Remove and Install Mower Deck Drive Belt Shields - Fixed Deck
Remove and Install Mower Deck Drive Belts
Remove and Install Mower Deck Drive Belt Tension Idler Arm
Disassemble and Assemble Mower Deck Drive Belt Tension Idler Arm
Remove and Install Mower Deck - Floating Deck Models
Remove and Install Mower Deck - Fixed Deck Models
Remove and Install Mower Blade
Sharpen and Balance Mower Blade
Remove and Install Spindle
Disassemble and Inspect Spindle
Spindle Components
Assemble Spindle
Remove and Install Push Arm - Floating Deck Models
Repair Push Arm
Repair Mower Deck Lift Linkage - Floating Deck Models
Repair Anti-Scalp Wheels and Rollers
Section 80 - MISCELLANEOUS
Specifications
Other Material
Group 10 - Tests and Adjustments
Tire Pressure Adjustment
Check and Adjust Operator Presence Switch
Group 15 - Repair
Remove and Install Thigh Pad
Remove and Install Rear (Drive) Wheels
Remove and Install Front Caster Wheel
Replace Caster Wheel Pivot Bushings - Fixed Deck Models
Replace Caster Wheel Pivot Bearings - Floating Deck Models
Repair Caster Wheel
Remove and Install Caster Wheel Yoke Assembly - Fixed Deck Models
Remove and Install Caster Wheel Yoke Assembly - Floating Deck Models
Adjust Caster Shimmy - Floating Deck Models
Service Caster Wheel Roller Bearings
Remove and Install Operator Platform
Connect Battery
Fuel System Operation
Remove and Install Fuel Tank
Brand: John Deere
Serial Number:
FOREWORD
Section 10 - SAFETY
Group 05 - Safety
Prevent Acid Burns
Use Proper Tools
Park Machine Safely
Work in Clean Area
Live With Safety
Gasoline
Gasoline Storage
Engine Oil
Lubricant Storage
Oil Filters
Machine PIN
Specifications
Other Material
Air Intake System
Lubrication System
Fuel System
Throttle Body
Governor System
Ignition System
Specifications
Adjust Governor
Spark Test
Group 25 - Repair
Remove Engine (EFI)
Lap Valves (EFI)
Remove Piston (EFI)
Inspect Block (EFI)
Specifications
Other Material
Engine Block
Valves and Governor
Carburetor
Governor Operation
Step 1
Step 2
Step 3
Step 4
Step 5
Step 6
Step 7
Step 8
Step 1
Step 2
Step 3
Step 4
Step 5
Step 6
Step 7
Step 8
Step 1
Step 2
Step 3
Step 4
Step 1
Step 2
Step 3
Step 4
Step 1
Step 2
Step 3
Step 4
Step 5
Step 6
Step 7
Step 8
Step 9
Step 10
Step 11
Step 12
Step 1
Step 2
Step 3
Step 4
Step 5
Step 6
Step 7
Step 8
Step 9
Step 10
Step 11
Step 12
Step 1
Step 2
Step 3
Step 4
Step 5
Step 1
Step 2
Step 3
Step 4
Step 5
Step 1
Step 2
Step 1
Step 2
Step 1
Step 2
Step 3
Step 4
Step 5
Step 1
Step 2
Step 3
Step 4
Step 5
Step 1
Step 2
Step 3
Step 4
Step 1
Step 2
Step 3
Step 4
Step 1
Step 2
Step 1
Step 2
Step 1
Step 2
Step 3
Step 4
Step 5
Step 6
Step 7
Step 8
Step 9
Step 1
Step 2
Step 3
Step 4
Step 5
Step 6
Step 7
Step 8
Step 9
Step 1
Step 2
Step 3
Step 4
Step 5
Step 1
Step 2
Step 3
Step 4
Step 5
Step 1
Step 2
Step 3
Step 4
Step 1
Step 2
Step 3
Step 4
Step 1
Step 2
Step 1
Step 2
Step 1
Step 2
Step 3
Step 4
Step 5
Step 1
Step 2
Step 3
Step 4
Step 1
Step 2
Step 3
Step 4
Step 5
Step 1
Step 2
Step 3
Step 4
Spark Test
Fuel Pump Test
Group 35 - Repair
Air Cleaner Service
Carburetor Repair
Float Level Check
Analyze Valves
Lap Valves
Analyze Piston Wear
Specifications
Other Material
Component ID Legend
Battery
Starting Motor
Voltage Regulator
Key Switch
Key Switch
Key Switch
PTO Switch
Accessory Connector
OPC Switch
Hour Meter
OPC Relay
Battery
Starting Motor
Voltage Regulator
Key Switch
Key Switch
Key Switch
PTO Switch
Accessory Connector
OPC Switch
Hour Meter
OPC Relay
Unswitched Power
Key Switch
Unswitched Power
Key Switch
Switched Power
OPC Switch
OPC Relay
OPC Relay
PTO Switch
PTO Switch
Key Switch
OPC Relay
Accessory Connector
PTO Switch
Key Switch
Hour Meter
OPC Relay
Switched Power
OPC Switch
OPC Relay
OPC Relay
PTO Switch
PTO Switch
Key Switch
OPC Relay
Accessory Connector
PTO Switch
Key Switch
Hour Meter
OPC Relay
Unswitched Power
Starting Motor
Battery
Unswitched Power
Starting Motor
Battery
Switched Power
PTO Switch
PTO Clutch
PTO Clutch Diode
OPC Switch
OPC Relay
OPC Relay
PTO Clutch Diode
Switched Power
PTO Switch
PTO Clutch
PTO Clutch Diode
OPC Switch
OPC Relay
OPC Relay
PTO Clutch Diode
Key Switch
Hour Meter
Hour Meter
Key Switch
Hour Meter
Hour Meter
Test Common Circuit
Test Ground Circuit
Test Battery
Charge Battery
Load Test Battery
Stator Test
Spark Test
Fuse Test
Diode Test
Relay Test
Key Switch Test
PTO Switch Test
Fuel Pump Operation
Group 55 - Repair
Clean Battery
Specifications
Other Material
Group 30 - Repair
Section 60 - BRAKES
Specifications
Brake Operation
Group 25 - Repair
Specifications
Other Material
Mower Drive Checks
Mower Deck
Level Mower Deck
Group 30 - Repair
Spindle Components
Assemble Spindle
Repair Push Arm
Specifications
Other Material
Group 15 - Repair
Repair Caster Wheel
Connect Battery
- JOHN DEERE CODE DTC LIST
