John Deere Premium Tractors 7130 to 7530 Diagnostic Technical Manual TM400019
Brand: John Deere
Type of Machine: Premium Tractors
Type of Document: Technical Manual
Model: John Deere 7130 to 7530 Premium Tractors
Part Number: TM400019
Number of Pages: 5433 Pages
Section 210—General Information
Group 05—Safety Information
Group 10—General References
Section 211—Diagnostic Trouble Codes
Group ATC—ATC Control Unit
Group BCU—BCU Control Unit
Group BIF—BIF Control Unit
Group DSM—DSM Control Unit
Group DTI—DTI Control Unit
Group ECU—ECU Control Unit
Group EPC—EPC Control Unit
Group ETC—ETC Control Unit
Group JDL—JDL Control Unit
Group PLC—PLC Control Unit
Group SIC—SIC Control Unit
Group SSU—SSU Control Unit
Group TCU—TCU Control Unit
Group TEC—TEC Control Unit
Group TEI—TEI Control Unit
Group TSC—TSC Control Unit
Group UIC—UIC Control Unit
Group UIM—UIM Control Unit
Group VTI—VTI Control Unit
Section 212—Observable Symptoms
Group 40—Electronics
Group 45—Electronic Control Units
Group 53—AutoPowr/IVT Transmission
Group 55—PowrQuad Transmission
Group 56—Drive Systems
Group 60—Steering and Brakes
Group 70—Hydraulic System
Group 80—Miscellaneous
Group 90—Operator’s Cab
Section 213—System Diagnostics
Group 45—Electronics
Group JDL—JDL System Diagnostics
Group VTI—VTI (GreenStar) System Diagnostics
Section 220—Engine
Group 05—General Information
Group 10—Operational Checks
Group 15—Tests and Adjustments
Section 230—Fuel, Air Intake and Cooling
Systems
Group 20A—Fuel System
Group 20B—Air Intake System
Group 20C—Cooling System
Group 20D—ColdWeather Starting Aids
Section 240—Electrical System
Group SE01—Starting Motor and Charging Circuit
Group SE01A—Fuel Preheater
Group SE01B—Electrical Starting Aid
Group SE02—BIF Control Unit (Basic Informator)
Group SE03—Horn
Group SE04—Operator’s Seat and Cigarette Lighter
Group SE06—Lights
Group SE08—Plug for Accessories
Group SE09—Radio Light, Dome Light, Console Light
and Access Step Lights
Group SE10—ATC/ETC/HTC Control Units
(AirConditioning, Fan and Heater)
Group SE14—3 and 7Terminal Power Outlet Sockets
(SAE)
Group SE15—BCU Control Unit (Electronic Hitch
Control)
Group SE16—BCU Control Unit (Basic Functions)
Group SE17—Signal Socket and Service Socket
Group SE20—TSC Control Unit (Suspension)
Group SE21—SIC Control Unit (Selective Control
Valves)
Group SE22—CAN BUS Terminating Resistor
Group SE23A—Level 14 ECU Control Unit (Electronic
Engine Control) for 4Valve Engine with
HPCR
Group SE23B—Level 16 ECU Control Unit (Electronic
Engine Control) for 2Valve Engine with
HPCR
Group SE26—TCU Control Unit (Transmission Control
with AutoPowr/IVT Transmission)
Group SE26A—EPC Control Unit (Transmission
Control with PowrQuad Plus or AutoQuad
Plus Transmission)
Group SE27—UIC Control Unit (Transmission Control
Group SE28—PLC Control Unit (Electronic Park Lock
Group SE29—Electrical RearView Mirrors
Group SE30—JDL Control Unit (JDLink)
Group SE32—TEC Control Unit (ISOBUS)
Group SE33—GreenStar (AMS)
Group SE35—SSU Control Unit (AutoTrac)
Group SE36—UIM/VTI Control Units (GreenStar
Display)
Group SE37—ElectroHydraulic PickUp Hitch
Group SE39—PC6 Power Module (HF)
Group SE40—PC0 Power Module
Group SE41—PC5 Power Module
Group SE42—DTI Control Unit (CommandCenter)
Group 105A—Component Information Connectors
and Contacts
Group 105B—Component Information Connectors
(X001 to X249)
Group 105C—Component Information Connectors
(X250 to X499)
Group 105D—Component Information Connectors
(X500 to X749)
Group 105E—Component Information Connectors
(X750 to X999)
Group 105F—Component Information Connectors
(XGND)
Group 110—Component Information Wiring
Harnesses
Group 115—Component Information Electrical
Parts/Components
Group 115A—Component Information Electrical
Parts/Components (Actuators)
Group 115B—Component Information
Electrical Parts/Components
(Sensors/Switches/Potentiometers)
Group 115C—Component Information Electrical
Parts/Components (Fuses/Relays/Diodes)
Group 115D—Component Information Electrical
Parts/Components (Headlamps/Lights)
Group 115E—Component Information Electrical
Parts/Components (Other)
Group 120—Component Information Ground
Connections
Group 125—Component Information CAN BUS
Systems
Section 245—Electronic Control Units
Group 05—Operation and General Information on
Diagnostics
Group 10A—Interactive Tests
Group 10B—Interactive Calibrations
Group 15—Information on How to Reprogram Control
Units
Group 20—Data BUS Systems
Group PC0—PC0 Power Module
Group PC5—PC5 Power Module
Group PC6—PC6 Power Module (HF)
Section 253—AutoPowr/IVT Transmission
Group 20—Theory of Operation
Section 255—PowrQuad Transmission
Section 256—Drive Systems
Group 20A—FrontWheel Drive Clutch
Group 20B—Differential
Group 20C—Final Drives
Group 20D—Rear PTO Options
Section 260—Steering and Brakes
Group 05—Introductory Checks
Group 20A—Hydrostatic Steering
Group 20B—Brake Valve
Group 20C—Rear Brakes
Group 20G—AutoTrac
Section 270—Hydraulic System
Group 20A—Oil Filter, Charge Pump and Hydraulic
Pump
Group 20B—Hitch
Group 20C—Selective Control Valves (SCVs)
Group 20D—Independent Control Valves (ICVs)
Group 20E—Hydraulic Block
Section 280—Miscellaneous
Section 290—Operator’s Cab
Group 20A—Ventilation/Heating
Group 20B—AirConditioning System
Group 20C—ClimaTrak
Group 20D—Cab Suspension
Section 299—Special Tools
Group 05—Special Tools (DealerFabricated)
Group 10—Special Tools (Available as Spare Parts)
Brand: John Deere
Section 220—Engine
Systems
Group SE03—Horn
Group SE06—Lights
(SAE)
Control)
Valves)
HPCR
HPCR
Plus Transmission)
Display)
and Contacts
(X001 to X249)
(X250 to X499)
(X500 to X749)
(X750 to X999)
(XGND)
Harnesses
Parts/Components
Connections
Systems
Diagnostics
Units
Group 20G—AutoTrac
Pump
Group 20B—Hitch
Group 20C—ClimaTrak
- JOHN DEERE CODE DTC LIST
