John Deere PowerTech 8.1L Engine Components Technical Manual CTM86 06JUL06
Brand: John Deere
Type of Machine:
Type of Manual: Components Technical Manual
Model: John Deere PowerTech 8.1L Engine
Part Number: CTM86
Publication Date: 2006
Number of Pages: 507 Pages
General
Safety
Handle Starting Fluid Safely
Handling Batteries Safely
Prepare for Emergencies
Avoid High-Pressure Fluids
Wear Protective Clothing
Service Machines Safely
Work In Ventilated Area
Work in Clean Area
Install Fan Guards
Avoid Hot Parts
Illuminate Work Area Safely
Use Proper Lifting Equipment
Practice Safe Maintenance
Use Proper Tools
Dispose of Waste Properly
Live With Safety
Engine Identification
Engine Model Designation
Engine Serial Number Plate Information
Engine Option Code Label
Engine Application Chart (John Deere Agricultural Equipment)
Engine Application Chart (John Deere Construction Equipment)
Engine Application Chart (OEM) (Outside Equipment Manufacturers)
Fuels, Lubricants and Coolant
Diesel Fuel
Bio-Diesel Fuel
Lubricity of Diesel Fuel
Testing Diesel Fuel
Diesel Engine Break-In Oil
Diesel Engine Oil
Extended Diesel Engine Oil Service Intervals
Mixing of Lubricants
Oilscan and Coolscan
Grease
Diesel Engine Coolant
Diesel Engine Coolants, Supplemental Additive Information
Testing Diesel Engine Coolant
Replenishing Supplemental Coolant Additives (SCAs) Between Coolant Changes
Operating in Warm Temperature Climates
Flush and Service Cooling System
Disposing of Coolant
Repair and Adjustments
Engine Rebuild
Engine Overhaul Guidelines
Engine Repair Stand
Safety Precautions
Install Adapters on Engine Repair Stand
Engine Lifting Procedure
Clean Engine
Disconnect Turbocharger Oil Inlet Line
Mount Engine on Repair Stand
Engine Disassembly Sequence for Overhaul
Sealant Application Guidelines
6081 Engine Assembly Sequence After Overhaul
Engine Break-In Guidelines
Perform Engine Break-In
Check Crankcase Ventilation System
Check Air Intake System
Check Exhaust System
Check and Service Cooling System
Check Electrical System
General Tune-Up Recommendations
Cylinder Head and Valves Repair and Adjustment S. N. ( —199,999)
Check and Adjust Valve Clearance Serial Number ( —199,999)
Check Valve Lift Serial Number
Remove Cylinder Head Serial Number
Head Gasket Inspection and Repair Sequence Serial Number ( —199,999)
Disassemble and Inspect Rocker Arm Shaft Assembly Serial Number
Assemble Rocker Arm Shaft Assembly Serial Number ( —199,999)
Measure Valve Recess Serial Number
Preliminary Cylinder Head and Valve Checks Serial Number ( —199,999)
Remove Valve Assembly Serial Number
Inspect and Measure Valve Springs Serial Number ( —199,999)
Inspect Valve Spring Caps, Wear Caps, and Retainer Locks Serial Number
Clean Valves Serial Number ( —199,999)
Inspect and Measure Valves Serial Number
Grind (Reface) Valves Serial Number
Inspect and Clean Cylinder Head Serial Number ( —199,999)
Check Cylinder Head Combustion Face Flatness Serial Number ( —199,999)
Measure Cylinder Head Thickness Serial Number ( —199,999)
Clean Valve Guides Serial Number
Measure Valve Guides Serial Number
Knurl Valve Guides Serial Number
Clean and Inspect Valve Seats Serial Number ( —199,999)
Measure Valve Sears Serial Number
Grind Valve Seats Serial Number
Remove Valve Seat Inserts Serial Number
Install Valve Seat Inserts Serial Number
Inspect and Clean Cylinder Head Nozzle Bore Serial Number ( —199,999)
Clean and Inspect Push Rods Serial Number ( —199,999)
Inspect and Clean Ventilator Outlet Hose Serial Number ( —199,999)
Clean and Inspect Top Deck of Cylinder Block Serial Number ( —199,999)
Measure Cylinder Liner Standout (Height Above Block) Serial Number
Assemble Valve Assembly Serial Number
Install Cylinder Head and Cap Screws Serial Number ( —199,999)
Torque-to-Yield Flanged-Head Cap Screws—Grade 180 Marked "SPECIAL" Serial Number ( —199,999)
Install Rocker Arm Assembly Serial Number
Complete Final Assembly of Injection Pump Side of Engine Serial Number
Complete Final Assembly on Exhaust Manifold Side of Engine Serial Number
Perform Engine Break-In Serial Number
Cylinder Head and Valves Repair and Adjustment S. N. (200,000—˜)
Check Valve Clearance — Serial Number (200,000—˜)
Adjust Valve Clearance Serial Number (200,000—˜)
Check Valve Lift Serial Number (200,000—˜)
Remove Cylinder Head Serial Number (200,000—˜)
Diagnosing Head Gasket Joint Failures - Serial Number (200,000—˜)
Head Gasket Diagnostic Charts - Serial Number (200,000—˜)
Head Gasket Inspection and Repair Sequence - Serial Number (200,000—˜)
Inspect Rocker Arm Assembly - Serial Number (200,000—˜)
Disassemble and Assemble Rocker Arm Assembly - Serial Number (200,000—˜)
Measure Valve Recess - Serial Number (200,000—˜)
Preliminary Cylinder Head and Valve Checks - Serial Number (200,000—˜)
Remove Valve Assembly - Serial Number (200,000—˜)
Inspect and Measure Valve Springs - Serial Number (200,000—˜)
Clean Valves - Serial Number (200,000—˜)
Inspect and Measure Valves - Serial Number (200,000—˜)
Grind (Reface) Valves - Serial Number (200,000—˜)
Inspect and Clean Cylinder Head - Serial Number (200,000—˜)
Check Cylinder Head Combustion Face Flatness - Serial Number (200,000—˜)
Measure Cylinder Head Thickness - Serial Number (200,000—˜)
Clean Valve Guides - Serial Number (200,000—˜)
Measure Valve Guides - Serial Number (200,000—˜)
Knurl Valve Guides - Serial Number (200,000—˜)
Clean and Inspect Valve Seats - Serial Number (200,000—˜)
Measure Valve Seats - Serial Number (200,000—˜)
Grind Valve Seats - Serial Number (200,000—˜)
Remove Valve Seat Inserts and Measure Bores in Cylinder Head - Serial Number (200,000—˜)
Install Valve Seat Inserts - Serial Number (200,000—˜)
Inspect and Clean Cylinder Head Nozzle Bore - Serial Number (200,000—˜)
Clean and Inspect Push Rods - Serial Number (200,000—˜)
Clean and Inspect Top Deck of Cylinder Block - Serial Number (200,000—˜)
Assemble Valve Assembly - Serial Number (200,000—˜)
Install Cylinder Head and Cap Screws - Serial Number (200,000—˜)
Torque-to-Yield Flanged-Head Cap Screws—Grade 180 Marked "SPECIAL" - Serial Number (200,000—˜)
Install Rocker Arm Assembly - Serial Number (200,000—˜)
Inspect and Clean Ventilator Outlet Hose - Serial Number (200,000—˜)
Complete Final Assembly of Fuel Pump Side of Engine Serial Number
Complete Final Assembly on Exhaust Manifold Side of Engine - Serial Number (200,000—˜)
Perform Engine Break-In - Serial Number (200,000—˜)
Cylinder Block, Liners, Pistons, and Rods Repair and Adjustment
Preliminary Liner, Piston, and Rod Checks
Connecting Rods—General Information
Remove Pistons and Connecting Rod Assemblies
Remove Cylinder Liners
Deglaze Cylinder Liners
Clean Cylinder Liners
Disassemble Piston and Rod Assembly
Clean Pistons
Visually Inspect Pistons
Check Piston Ring Groove Wear
Inspect Piston Pin and Bore
Visually Inspect Cylinder Liners
Cylinder Liner Manufacturing Date Code Explanation
Determine Piston-to-Liner Clearance
Inspect Rod and Cap
Inspect Piston Pins and Bushings
Remove Piston Pin Bushing, Clean and Inspect Pin Bore
Measure Liner Flange
Inspect and Measure Connecting Rod Bearings
Install Piston Pin Bushing in Connecting Rod
Complete Disassembly of Cylinder Block (If Required)
Remove and Clean Piston Cooling Orifices
Inspect and Clean Cylinder Block
Measure Cylinder Block
Install Piston Cooling Orifices and Gallery Plugs
Recheck Cylinder Liner Standout
Install Liner Shims—If Required
Install Packing on Cylinder Liner and O-Rings in Block
Install Cylinder Liner in Block
Install Piston and Connecting Rod
Torque-Turn Connecting Rod Cap Screws
Check Engine Rotation for Excessive Tightness
Crankshaft, Main Bearings and Flywheel Repair and Adjustment
Crankshaft and Main Bearing Failure Analysis
Crankshaft Rear Oil Seal and Wear Sleeve General Information
Remove Crankshaft Rear Oil Seal and Wear Sleeve
Crankshaft Rear Oil Seal and Wear Sleeve Handling Precautions
Install Crankshaft Rear Oil Seal and Wear Sleeve
Inspect Vibration Damper
Check Crankshaft End Play
Remove Crankshaft Vibration Damper
Remove Crankshaft Front Oil Seal and Wear Sleeve
Remove and Install Timing Gear Cover—Engine Installed in Vehicle (8000 Series Tractors)
Remove Timing Gear Cover—Engine Removed
Inspect and Measure Flywheel
Check Flywheel Housing Face Runout
Check Flywheel Face Flatness
Check Pilot Bearing Bore Concentricity
Remove Flywheel
Remove SAE 1 Flywheel Housing
Remove SAE 2 and 3 Flywheel Housing
Replace Flywheel Ring Gear
Remove and Install Rear Oil Seal Housing—Engine Installed in Vehicle (8000 Series Tractors)
Remove Rear Oil Seal Housing—Engine Removed
Remove Main Bearing Caps
Check Main Bearing Oil Clearance
Remove Connecting Rod Caps and Remove Crankshaft
Inspect Crankshaft
Measure Assembled I.D. of Bearings and O.D. of Crankshaft Journals
Main Bearing Cap Line Bore Specifications
Thrust Bearing New Part Specifications
Crankshaft Grinding Guidelines
Crankshaft Grinding Specifications
Replace (Crankshaft) Oil Pump Drive Gear
Replace Crankshaft Gear
Inspect Thrust Bearings
Install Main Bearings and Crankshaft
Install Crankshaft Rear Oil Seal Housing
Check Crankshaft Rear Oil Seal Housing Runout
Install Crankshaft Rear Oil Seal and Wear Sleeve Assembly
Install Front Wear Sleeve
Install Crankshaft Front Oil Seal
Install Vibration Damper
Install SAE 2 and 3 Flywheel Housing
Install Flywheel & Flex Plates - Option Code 1502
Install Flywheel
Install SAE 1 Flywheel Housing
Camshaft and Timing Gear Train Repair and Adjustment
Check Camshaft End Play and Measure Gear Backlash
Remove Vibration Damper and Timing Gear Cover
Remove, Inspect, and Install Crankshaft Gear-Driven Auxiliary Drive—If Equipped
Remove Camshaft
Remove Camshaft Gears
Measure Thrust Washer Thickness
Inspect and Measure Camshaft Followers
Visually Inspect Camshaft
Measure Camshaft Journal O.D. and Bushing I.D.
Measure Camshaft Lobe Lift
Install Camshaft Gears
Service Camshaft Bushings Using JDG602 Adapter Set
Service Camshaft Bushings Using JDG606 Adapter Set
Install Camshaft
Install Thrust Washer and Timing Gear Cover
Lubrication System Repair and Adjustment
Diagnosing Lubrication System Malfunctions
Oil Filter Base and Oil Pressure Regulating Valve Housing Assembly
Top-Load Oil Filter Assembly
Remote Oil Filter Assembly
Changing Top-Load Oil Filter
Remove and Install Oil Filter Base and Oil Pressure Regulating Valve Housing
Engine Oil Cooler Assembly
Remove, Inspect, and Install Engine Oil Cooler
Remove, Inspect, and Install Oil Pressure Regulating Valve, Oil Filter Bypass Valve, and Oil Cooler Bypass Valve
Remove Engine from 8000 Tractors for Access to Engine Oil Pump
Remove Oil Pan
Check Crankshaft Gear-to-Oil Pump Drive Gear Backlash
Remove Engine Oil Pump
Inspect and Clean Oil Pump
Check Drive Shaft End Play
Check Drive Shaft Side Movement
Check Pumping Gear Backlash
Inspect Oil Pump Drive Gear
Adjust Oil Pump Set Screw
Install Engine Oil Pump
Remove and Install Oil Pump Outlet Tube and Oil Cooler Crossover Tube Adapter
Remove, Inspect, and Install Oil Pump Pickup Tube
Install Engine Oil Pan
Tighten Cap Screws on Front Frame/Oil Sump (8000 Series Tractors)
Cooling System Repair and Adjustment
Inspect Fan Hub & Replace Bearings in Heavy-Duty, Adjustable Fan Drive Assembly
Replace Bearings in Coolant Manifold-Mounted, Fixed Fan Drive Assembly
Fan Drive Assembly
Checking Belt Tensioner Spring Tension and Belt Wear
Inspect and Install Fan Assembly
Visually Inspect Coolant Pump
Remove Coolant Pump Assembly
Install Coolant Pump Assembly
Replace Bypass Tube Seal in Coolant Pump Cover
Remove and Test Thermostats
Remove Coolant Manifold
Install Thermostats
Install Coolant Manifold
Remove and Install Coolant Temperature Switch
Servicing of Engine Coolant Heater
Air Intake and Exhaust System Repair and Adjustment
Extending Turbocharger Life
Remove Turbocharger
Turbocharger Failure Analysis
Turbocharger Inspection
Repair Turbocharger
Prelube Turbocharger
Install Turbocharger
Remove, Inspect, and Install Exhaust Manifold
Remove, Inspect, and Install Intake Manifold (6081T and 6081H Engines)
Remove Vertically-Mounted Aftercooler and Intake Manifold (6081A Engines)
Remove and Disassemble Horizontally-Mounted Aftercooler (6081A Engines)
Inspect and Repair Aftercooler (6081A Engines)
Inspect and Repair Intake Manifold and Air Intake Cover (6081A Engines)
Install Intake Manifold and Vertically-Mounted Aftercooler (6081A Engines)
Assemble and Install Horizontally-Mounted Aftercooler Assembly (6081A Engines)
Servicing of Air Heater (If Equipped)
OEM Starting and Charging Systems Repair and Adjustment
Remove and Install Alternator (OEM Engines)
Remove and Install Starter Motor (OEM Engines)
Theory of Operation
Base Engine Operation
Engine Sectional View Serial Number
Engine Sectional View Serial Number (200,000—˜)
General Engine Operation
Lubrication System Operation
Cooling System Operation
Head Gasket Joint Construction and Operation
Air Intake and Exhaust System Operation
Turbocharger Operation
Wastegate Operation
How the Turbocharger is Lubricated
Diagnostics
Observable Diagnostics and Tests
About This Group of the Manual
8.1L - L1 - Excessive Oil Consumption
Engine Oil Consumption
8.1L - L2 - Engine Oil Pressure Low
8.1L - L3 - Engine Oil Pressure High
8.1L - C1 - Engine Coolant Temperature Above Normal
8.1L - C2 - Engine Coolant Temperature Below Normal
8.1L - C3 - Coolant In Oil or Oil In Coolant
Test Engine Compression Pressure
Check Engine Cranking Speed
Check Engine Oil Pressure
Check for Excessive Engine Crankcase Pressure (Blow-by)
Check for Turbocharger Oil Seal Leak
Inspect Thermostat and Test Opening Temperature
Pressure Test Cooling System and Radiator Cap
Check for Head Gasket Failures
Measure Intake Manifold Pressure (Turbo Boost)
Check for Intake and Exhaust Restrictions
Test for Intake Air Leaks
Check for Exhaust Air Leaks (Turbocharged Engines)
Test Turbocharger Wastegate Actuator
Adjust Turbocharger Wastegate Actuator
Tools and Other Materials
Repair Tools and Other Materials
Group 020 — Cylinder Head and Valves Essential Tools S. N. ( —199,999)
Group 020 — Cylinder Head and Valves Service Equipment and Tools
Group 020 — Cylinder Head and Valves Other Materials S. N. ( —199,999)
Group 021 — Cylinder Head and Valves S. N. (200,000— ) Essential Tools
Group 021 — Cylinder Head and Valves S. N. (200,000— ) Service Equipment and Tools
Group 021 — Cylinder Head and Valves S. N. (200,000— ) Other Materials
Group 030 — Cylinder Block, Liners, Pistons, and Rods Essential Tools
Group 030 — Cylinder Block, Liners, Pistons, and Rods Other Materials
Group 040 — Crankshaft, Main Bearings and Flywheel Essential Tools
Group 040 — Crankshaft, Main Bearings and Flywheel Service Equipment and Tools
Group 040 — Crankshaft, Main Bearings and Flywheel Other Materials
Group 050 — Camshaft and Timing Gear Train Essential Tools
Group 050 — Camshaft and Timing Gear Train Other Materials
Group 060 — Lubrication System Other Materials
Group 070 — Cooling System Essential Tools
Group 070 — Cooling System Other Materials
Group 080 — Air Intake and Exhaust System Essential Tools
Group 080 — Air Intake and Exhaust System Other Materials
Group 100 — Starting and Charging Systems Essential Tools
Diagnostic Service Tools
Base Engine Diagnostic Tools
Dealer Fabricated Service Tools
How to Make Tools
DFRG3—Cylinder Liner Holding Fixture
Specifications
Repair and General OEM Specifications
General OEM Engine Specifications
General OEM Engine Specifications--Continued
Group 020 — Cylinder Head and Valves S. N. ( —199,999) Repair Specifications
Group 021 — Cylinder Head and Valves S. N. (200,000— ) Repair Specifications
Group 030 — Cylinder Block, Liners, Pistons and Rods Repair Specifications
Group 040 — Crankshaft, Main Bearings and Flywheel Repair Specifications
Group 050 — Camshaft and Timing Gear Train Repair Specifications
Group 060 — Lubrication System Repair Specifications
Group 070 — Cooling System Repair Specifications
Group 080 — Air Intake and Exhaust System Repair Specifications
Group 100 — OEM Starting and Charging Systems Repair Specifications
Diagnostic Specifications
Group 150 — Base Engine Diagnostic Specifications (Includes Dynamometer Specifications (OEM) and Turbocharger Boost Specifications)
Dynamometer Test Specifications
Intake Manifold Pressure (Turbocharger Boost) Specifications
Effects of Altitude and Temperature on Engine Performance
Page Numbers
Brand: John Deere
Type of Machine:
Part Number: CTM86
General
Safety
Work in Clean Area
Install Fan Guards
Avoid Hot Parts
Use Proper Tools
Live With Safety
Diesel Fuel
Bio-Diesel Fuel
Testing Diesel Fuel
Diesel Engine Oil
Grease
Engine Rebuild
Engine Repair Stand
Safety Precautions
Clean Engine
Clean Pistons
Inspect Rod and Cap
Remove Flywheel
Inspect Crankshaft
Install Flywheel
Remove Camshaft
Install Camshaft
Remove Oil Pan
Fan Drive Assembly
Install Thermostats
Remove Turbocharger
Repair Turbocharger
Theory of Operation
Wastegate Operation
Diagnostics
How to Make Tools
Specifications
Page Numbers
- JOHN DEERE CODE DTC LIST
