John Deere MX8 MX10 HX10 HX14 Multi-Spindle Rotary Cutters Operators Manual OMFH337995
- Download this document, you need 200 Gallons
Brand: John Deere
Type of Machine: Multi-Spindle Rotary Cutters
Model: John Deere Multi-Spindle Rotary Cutters
MX8 (S.N. 020000 - )
MX10 (S.N. 019000 - )
HX10 (S.N. 011500 - )
HX14 (S.N. 012510 - )
Part Number: OMFH337995
Number of Pages: 92 Pages
Introduction
Foreword
Machine Identification
Trademarks
Glossary of Terms
Preliminary Checks
Regions and Country Versions
Machine Overview
Record Rotary Cutter Serial Number
Keep Proof of Ownership
Keep Machines Secure
Safety
Recognize Safety Information
Understand Signal Words
Follow Safety Instructions
Protect Bystanders
Stay Clear of Rotating Blades
Operate Tractor and Cutter Safely
Back up Safely
Park Machine Safely
Keep Riders Off Machine
Prepare for Emergencies
Wear Protective Clothing
Stay Clear of Rotating Drivelines
Use Safety Lights and Devices
Tow Loads Safely
Observe Maximum Transport Speed
Tire Maximum Transport Speeds
Transport Safely
Use a Safety Chain
Avoid Serious Injury or Death from Accidental Lowering of Cutter
Practice Safe Maintenance
Check Hoses for Damage
Avoid High-Pressure Fluids
Store Attachments Safely
Safety Features
Safety Signs
Replace Safety Signs
Safety Signs—Drivelines
Safety Signs—Driveline Shields
Safety Signs—Hitch
Safety Signs—Deck
Safety Signs—Deck
Preparing the Tractor
Selecting Tractor PTO Speed
Positioning Tractor Drawbar—Pull-Type
Positioning Tractor Drawbar—Lift-Type and Semi-Mount
Adjusting Tractor Hitch—Pull-Type
Adjusting Tractor Hitch—Lift-Type and Semi-Mount
Recommended Tractor Hydraulic Outlets (Pull-Type and Semi-Mount)
Checking Ballast, Wheel Spacing, and Tire Inflation
Determining Front Ballast (Lift-Type and Semi-Mount)
Preparing the Machine
Prestarting Checklist
Positioning Hitch Pins—Lift-Type (MX8 & MX10)
Positioning Hitch Pins—Lift-Type (HX10 & HX14)
Checking Tailwheel Support V-Bolt Torque
Positioning Hitch Pins—Semi-Mount
Checking Tailwheel Support V-Bolt Torque (Pull-Type and Semi-Mount)
Adjusting Tailwheel Spacing (Pull-Type and Semi-Mount)
Adjusting Tailwheel Spacing (HX10 & HX14)
Adjusting Cutting Height/Tailwheel Position (Lift-Type)
Installing Rubber Deflectors - MX8 Models
Installing Rubber Deflectors - MX10 Models
Installing Rubber Deflectors - HX10 Models
Installing Rubber Deflectors - HX14 Models
Attaching and Detaching
Attach Lift-Type or Semi-Mount Cutter to Tractor with Quick Coupler Hitch
Attach Lift-Type or Semi-Mount Cutter to Tractor with Three-Point Hitch
Adjusting Hitch Clevis (Pull-Type)
Attaching Pull-Type Cutter to Tractor Drawbar
Attach PTO Driveline
Attaching to Tractor Hydraulic System (Pull-Type or Semi-Mount)
Connecting Tail/Warning Light Wiring Harness to Tractor (If Equipped)
Detach Cutter from Tractor
Transporting
Prepare Cutter for Transport
Follow Safe Transport Procedures
Lighting Enhancement Module Operation (If Equipped)
Driving Cutter in Turns
Keep Riders off Machine
Operating the Machine
Preparing Cutter for Operation—Lift-Type
Prepare Cutter for Operation—Pull-Type and Semi-Mount
Adjust Cutting Height—Lift-Type (MX8 & MX10)
Adjusting Cutting Height—Lift-Type (HX10 & HX14)
Adjust Cutting Height—Pull-Type
Adjust Cutting Height—Semi-Mount
Positioning Cutter (Semi-Mount with Hydraulic Offset)
Follow Safe Operating Procedures
Operating the Cutter for Best Performance
Turning Cutter—Lift-Type and Semi-Mount
Turning Cutter—Pull-Type
Attachments Available
Lubrication and Maintenance
Lubricating and Maintaining Machine Safely
Multipurpose Extreme Pressure (EP) Grease
Gear Case Oil
Mixing of Lubricants
Lubricant Storage
Perform Lubrication and Maintenance
Observe Lubrication Symbols
Service Intervals Chart
Keep Cutter Clean
Check Gear Case Oil Level
Axle Beam Pivots—Pull-Type and Semi-Mount (MX8 & MX10)
Axle Beam Pivots—Pull-Type, Left, and Right-Hand Side (HX10 & HX14)
Lubricate PTO Driveline—Pull-Type, Lift-Type, and Semi-Mount (MX8 & MX10)
Lubricate PTO Driveline—Pull-Type (HX10 & HX14)
Lubricate PTO Driveline—Lift-Type (HX10 & HX14)
Lubricate Intermediate Driveline—Pull-Type (HX10 & HX14)
Cross Shaft Driveline, Left, and Right-Hand Side (HX14)
Checking Tailwheel Nut Torque
Checking Tire Inflation Pressure (Severe Duty Ag Tires)
Swivel Hitch—If Equipped (Pull-Type) (MX8/MX10 & HX10 /HX14)
Bellcrank (Pull-Type) (MX8 & MX10)
Bellcrank (Pull-Type) (Left and Right-Hand Side) (HX10 & HX14)
Hitch Arms, Semi-Mount with Hydraulic Offset (Left and Right-Hand Side) (MX8 & MX10)
Tailwheel Spindles (Lift-Type and Semi-Mount) (MX8 & MX10)
Tailwheel Bearings (MX8/MX10 & HX10 /HX14)
Tighten Gear Case Mounting Hardware (MX8/MX10 & HX10 /HX14)
Tighten Blade Holder Hardware (MX8 & MX10)
Check Blade Hardware Torque (MX8/MX10 & HX10 /HX14)
Driveline Inner Shaft
Changing Gear Case Oil Level
Checking Driveline Shields
Freeing Slip Clutch (MX8 & MX10)
Freeing Slip Clutch (HX10 & HX14)
Service
Practice Safe Service Procedures
Work in Clean Area
Service Tires Safely
Service Severe Duty Ag Tires Safely
Disassembling and Inspecting Slip Clutch
Assembling Slip Clutch (MX8 & MX10)
Assembling Slip Clutch (HX10 & HX14)
Removing and Installing PTO Driveline—Lift-Type and Semi-Mount (MX8 & MX10)
Removing and Installing PTO Driveline—Lift-Type (HX10 & HX14)
Removing and Installing PTO Drivelines—Pull-Type (MX8 & MX10)
Removing and Installing PTO Drivelines—Pull-Type (HX10 & HX14)
Checking Blade Wear
Replacing Blades
Installing Blades (Blade Bolt and Bushing Hardware Equipped Only)
Direction of Blade Rotation (MX8 & MX10)
Timing Blade Holders
Replacing Skid Shoes
Assembly
Assembly Instructions
Specifications
MX8 Specifications
MX10 Specifications
HX10 Specifications
HX14 Specifications
Technical Information
John Deere Is At Your Service
Brand: John Deere
Introduction
Foreword
Trademarks
Glossary of Terms
Preliminary Checks
Machine Overview
Safety
Protect Bystanders
Back up Safely
Park Machine Safely
Tow Loads Safely
Transport Safely
Use a Safety Chain
Safety Features
Safety Signs
Safety Signs—Hitch
Safety Signs—Deck
Safety Signs—Deck
Transporting
Gear Case Oil
Lubricant Storage
Keep Cutter Clean
Service
Work in Clean Area
Checking Blade Wear
Replacing Blades
Assembly
Specifications
MX8 Specifications
MX10 Specifications
HX10 Specifications
HX14 Specifications
- JOHN DEERE CODE DTC LIST
