John Deere LX172 LX176 LX178 LX188 Lawn Tractors Operators Manual OMM115211
- Download this document, you need 200 Gallons
Brand: John Deere
Type of Machine: Lawn Tractors
Model: John Deere LX172 LX176 LX178 LX188 Lawn Tractors
Serial Number: 040001-
Part Number: OMM115211
Number of Pages: 131 Pages
Safety
Controls
Operating the Engine
Checking Engine Oil Level
Filling Fuel Tank
Starting Engine (LX172)
Starting Engine (LX176, LX178 and
LX188)
Cold Weather Starting
Checking Indicator Lamps
Warming and Idling Engine
Stopping Engine
Driving the Tractor
Adjusting Seat
Using Park Brake
Using Gear Transmission Tractor (LX172)
Stopping Gear Transmission Tractor
(LX172)
Using and Stopping Hydrostatic
Transmission (LX176, LX178 and
LX188)
Using Weights and Tire Chains
Installing Tire Chains
Operating the Mower
Avoid Injury From Rotating Blades
Operate Mower Safely
Using Lift Lever to Raise and Lower
Mower
Adjusting Cutting Height
Adjusting Mower Wheels (38-Inch)
Adjusting Mower Wheels (48-Inch)
Adjusting Mower Level (Side-To-Side)
Adjusting Mower Level (Front-To-Rear)
Engaging Mower
Disengaging Mower
Using Correct Blades (38-Inch Mower)
Page
Dismounting to Inspect or Unplug Mower
Mowing, Bagging, and Mulching
Transporting
Fuels and Lubricants
Engine Oil
Grease
Handle Fuel Safely—Avoid Fires
Before Refueling Tractor
Refueling Tractor Safely
Fuel Recommendations
Filling Fuel Tank
Hydrostatic Transmission Oil
Troubleshooting
Service
John Deere Parts—Your Best Choice
Service Intervals
Service—Miscellaneous
Checking Tire Pressure
Testing Safety Systems
Adjusting Hood Latch
Lubricating Wheel Spindles
Service—Engine
Cleaning Air Intake Screen
Checking and Cleaning Precleaner and
Air Cleaner Element
Changing Engine Oil (LX172 and LX176)
Changing Engine Oil (LX178 and LX188)
Replacing Fuel Filter
Adjusting Carburetor Idle Mixture Screw
(LX172 and LX176)
Adjusting Carburetor Idle Mixture Screw (LX178 and
LX188)
Service—Electrical
Charge The Battery Safely
Charging Rates
Checking Battery Electrolyte Level
Checking Spark Plug
Cleaning or Replacing Battery
Using Booster Battery
Replacing Fuses
Replacing Headlight Bulb
Cleaning Headlight Lens
Replacing Indicator Light Bulb
Service—Transmission
Checking Hydrostatic Transmission Oil
Level (LX176, LX178 and LX188)
Service—Cooling System
Checking Coolant Level (LX178 and
LX188)
Draining Cooling System (LX178 and
LX188)
Flushing Cooling System (LX178 and
LX188)
Filling Cooling System (LX178 and
LX188)
Service—Mower and Blades
Lubricating Mower Blade Spindles
(38-Inch)
(48-Inch)
Lubricating Mower Rear Wheels (48-Inch)
Cleaning or Replacing Mower Drive Belt
Cleaning or Replacing Mower Deck Belt
(38-Inch)
(48-Inch)
Checking Mower Blades
Removing and Installing Mower Blades
Sharpening Blades
Balancing Blades
Removing Mower
Installing Mower
Storage
Page
Assembly
Specifications
Index
Brand: John Deere
Safety
Controls
Filling Fuel Tank
LX188)
Stopping Engine
Driving the Tractor
Adjusting Seat
Using Park Brake
(LX172)
LX188)
Operating the Mower
Mower
Engaging Mower
Disengaging Mower
Page
Transporting
Engine Oil
Grease
Filling Fuel Tank
Troubleshooting
Service
Service Intervals
Service—Engine
Air Cleaner Element
(LX172 and LX176)
LX188)
Service—Electrical
Charging Rates
Checking Spark Plug
Replacing Fuses
LX188)
LX188)
LX188)
LX188)
(38-Inch)
(48-Inch)
(38-Inch)
(48-Inch)
Sharpening Blades
Balancing Blades
Removing Mower
Installing Mower
Storage
Page
Assembly
Specifications
Index
- JOHN DEERE CODE DTC LIST
