Hyundai
86
176,834
John Deere Loader 524K-II Parts Catalog PC15081
Brand: John Deere
Type of Machine: Loader
Model: John Deere 524K-II Loader
PIN:1DW524K_ _ _F677549-
Part Number: PC15081
Publication Date: 2019
Number of Pages: 960 Pages
01 Wheels, Tires and Tracks
0110 Powered Wheels, Tires and Fastenings​
02 Axles, Differentials and Suspension Systems
0201 Drive Axle Housing and Support (Including Final Drives)​
0242 Axle Mounting Parts​
0263 Lines, Hoses and Fittings​
0278 Axle Temperature Sensor​
02B Front Axle with Differential Lock – 1200 Series TeamMate™ IV (Metric) DZ106248​
0200B Front Axle with Differential Lock – 1200 Series TeamMate™ IV (Metric)​
02C Rear Axle with Standard Differential – 1200 Series TeamMate™ IV (Metric) DZ106249​
0200C Rear Axle with Standard Differential – 1200 Series TeamMate™ IV (Metric)​
02D Rear Axle with Differential Lock – 1200 Series TeamMate™ IV (Metric) DZ106250​
0200D Rear Axle with Differential Lock – 1200 Series TeamMate™ IV (Metric)​
03 Transmission
0325 Input Drive Shafts and U-Joints​
0341 Housing, Covers and Complete Transmissions​
0350 Gears, Shafts & Power Shift Clutches​
0363 Transmission Oil Lines​
04A Engine 6068DW401-DZ104598​
0400A Engine 6068DW401​
05 Engine Auxiliary System
0505 Cold Weather Starting Aids​
0510 Engine Cooling Systems​
0512 Fan​
0515 Engine Speed Controls​
0522 Air Pre-cleaner​
0531 Muffler and Exhaust Pipe​
0534 Exhaust Aftertreatment​
0540 Engine Mounting​
0563 Fuel Lines and Fittings​
0564 Fuel Tank​
09 Steering System
0930 Emergency Steering​
0962 Steering Valve and Control​
0963 Steering Lines, Hoses and Fittings​
0965 Steering Cylinders​
10 Service Brakes
1062 Service Brake Valve​
1063 Service Brake Links, Hoses and Fittings​
1064 Reservoir and Accumulator​
13 Miscellaneous Vehicle
1322 Labels and Trademarks​
1369 Greases, Oils, Fuels and Coolants​
1370 Lubrication Systems​
15 Equipment Attaching
1520 Hitches and Hitch Pins​
16 Vehicle Electrical Systems
1671 Batteries, Support and Cables​
1672 Alternator, Regulator And Charging System Wiring​
1673 Vehicle Lighting System​
1674 Wiring Harness and Switches (If Not Included Elsewhere)​
1675 System Controls​
1676 Instruments And Indicators​
17 Frame Chassis or Supporting Structure
1741 Engine or Main Frame​
1746 Frame Bottom Guards (If Special)​
1749 Chassis Weights​
18 Operator's Station
1807 Special Noise Control Items​
1810 Operator Enclosure​
1811 ROPS, FOPS, OPS, Or Body Frame​
1812 Platform​
1813 Body Sides, Doors, Shields and Glazing​
1814 Windshield and Wipers​
1816 Instruments And Control Mounting Structure​
1821 Seat And Seat Belts​
1822 Steps and Handholds​
1831 Heater, Hoses and Controls​
1832 Air Conditioning System Compressor and Drive​
1833 Condenser, Evaporator and Lines​
19 Sheet Metal and Styling
1911 Hood and Hood Supports​
1912 Engine Sideshields​
1913 Miscellaneous Shields​
1927 Fenders​
20 Safety, Convenience and Miscellaneous
2001 Radio​
2002 Mirror​
2003 Fire Extinguisher​
2004 Warning Devices Including Horn and Reverse Alarm​
2007 Sun Visor​
2008 Reflectors And Slow Moving Vehicle Sign​
2013 Anti-Theft​
2014 Locking Bar​
21 Vehicle Main Hydraulic System
2161 Hydraulic Pumps And Drives​
2162 Hydraulic Selective Control and Load Holding Valves​
2163 Hydraulic Lines and Hoses​
2164 Hydraulic Reservoir, Filter and Cooler​
26 Global Vehicle Communication
2601 Communication Controller​
2602 Antennas and Cables​
2603 Wiring Harnesses and Switches​
31 Loader
3101 Cutting Edge​
3102 Bucket (Including Teeth)​
3103 Forks​
3104 Attachment Coupler​
3145 Bucket Loader Linkage​
3141 Main Frame​
3143 Moveable Frame (Lift Arm, Etc)​
3162 Control and Load Holding Valves​
3163 Lines, Hoses and Fittings​
3165 Hydraulic Cylinders​
3166 Automatic Control Function​
