Martin Welker
104
230,310
John Deere JD540-B Skidder and Grapple Skidder Repair Technical Manual TM1139
Brand: John Deere
Type of Machine: Skidder and Grapple Skidder
Model: John Deere JD540-B Skidder and Grapple Skidder
Part Number: TM1139
Number of Pages: 772 Pages
SECTION I - GENERAL INFORMATION
Group | - Contents
Group ll — Introduction and Safety Information
Group Ill — General Specifications
Group IV - Predelivery, Delivery and AfterSale Services
Group V — Lubrication
SECTION 1 - WHEELS
Group 0110 — Powered Wheels and Fastenings
Group 0149 — Weights
Group 0199 — Specifications and Special Tools
SECTION 2 - AXLES ANB SUSPENSION SYSTEMS
Group 0201 — Drive Axle Housing and Support
Group 0210 - Differential er Bevel Drive
Group 0225 - Input Drive Shafts and Joints
Group 0250 - Axle Shaft, Bearings,
Reduction Gears
Group 0299 - Specifications and Special aTools
SECTION 3 - TRANSMISSION
Group 0315 - Controls
Group 0341 - Housing and Covers
Group 0350 - Gears, Shafts, Bearings and Power Shift Clutch
Group 0360 - Hydraulic System
Group 0370 - Clutch Disconnect and Controls
Group 0399 - Specifications and Special Tools
SECTION 4 - ENGINE
Group 0400 - Engine Removal and Installation
Group 0401 - Crankshaft and Main Bearings
Group 0402 - Camshaft and Valve Actuating Means
Group 0403 — Connecting Rode and Pistons
Group 0404 - Cylinder Block
Group 0407 - Oiling System
Group 0408 - Ventilating System
Group 0409 — Cylinder Head and Valves
Group 0410 — Exhaust Manifold
Group 0413 - Fuel Injection System
Group 0415 - Engine Balancer
Group 0416 - Turbocharger
Group 0417 - Water Pump
Group 0418 - Thermostats, Hsgs. and Water Piping
Group 0419 — Oil Cooler
Group 0420 - Fuel Filter
Group 0421 - Fuel Transfer Pump
Group 0422 - Starting Motor and Fastenings
Group 0433 - Flywheel‚ Housing and Fastenings
Group 0499 - Specifications and Special Tools
SECTION 5 - ENGINE AUXILIARY SYSTEMS
Group 0505 - Cold Weather Starting Aids
Group 0510 - Cooling Systems
Group 0515 - Speed Controls
Group 0520 - Intake System
Group 0530 - External Exhaust Systems
Group 0540 — Mounting Frame
Group 0560 - External Fuel Supply Systems
Group 0599 — Specifications and Special Tools
SECTION 9 - STEERING SYSTEM
Group 0930 - Emergency Steering
Group 0960 — Hydraulic System
Group 0999 - Specifications and Special Tools
SECT ION 10 - SERVICE BRAKES
Group 1011 - Active Elements
Group 1015 - Controls Linkage
Group 1060 - Hydraulic System
Group 1099 - Specifications and Special Tools
SECT ION 11 - EMERGENCY BRAKES
Group 1111 — Active Elements
Group 1115 - Controls Linkage
Group 1199 - Specifications and Special Tools
SECTION 16 - ELECTRICAL SYSTEM
Group 1671 - Batteries, Supports and Cables
Group 1672 - Alternator, Regulator and Charging System Wiring
Group 1673 - Lighting System
Group 1674 - Wiring Harness and Switches
Group 1676 - Instruments and Indicators
Group 1699 — Specifications and Special Tools
SECTION 17 - FRAME, CHASSIS OR SUPPORTING STRUCTURE
Group 1740 — Frame Installation
Group 1746 - Frame Bottom Guards
Group 1799 - Specifications and Special Tools
SECTION 18 - OPERATOR'S STATION
Group 1807 - Special Noise Control Items
Group 1810 - Operator Enclosure
Group 1821 - Seat
Group 1830 - Heating and Air Conditioning
Group 1899 — Specifications and Special Tools
SECTION 19 - SHEET METAL
Group 1910 - Hood or Engine Enclosure
Group 1921 - Grille and Grille Housing
SECTION 20 — SAFETY, CONVENIENCE AND MISCELLANEOUS
Group 2003 — Fire Extinguisher
Group 2004 - Horn
Group 2006 - Cigar Lighter
SECT ION 21 - HYDRAULIC SYSTEM
Group 2160 — Hydraulic System
Group 2199 - Specifications and Special Tools
SECTION 30 - WINCI-l
Group 3041 - Winch Housing and Mounting Structure
Group 3050 - Winch Drive and Clutches
Group 3060 - Hydraulic System
Group 3099 - Specifications and Special Tools
SECTION 32 — BULLBOZERS
Group 3201 — Blades
Group 3215 - Controls Linkage
Group 3260 - Hydraulic System
Group 3299 - Specifications and Special Tools
SECTION 37 - ARCH OR BOOM, OR GRANES
Group 3740 — Frames
Group 3760 — Hydraulic System
Group 3799 - Specifications and Special Tools
SECTION 38 - GRAPPLE
Group 3803 — Grapple Mechanism
Group 3815 — Control Linkage
Group 3860 — Hydraulic System
Group 3899 - Specifications and Special Tools
SECTION 40 - PTO OR WINCH DRIVE
Group 4025 — Input Drive Shafts
Group 4051 - Gears. Shafts and Bearings
Group 4099 - Specifications and Special
Tools
