John Deere Inboard Planetary Axle AR15MTL Component Technical Manual CTM128919
Brand: John Deere
Type of Machine: Inboard Planetary Axle
Type of Manual: Component Technical Manual
Model: John Deere AR15MTL Inboard Planetary Axle
Part Number: CTM128919
Publication Date: 2023
Number of Pages: 165 Pages
Brand: John Deere
Safety
Recognize Safety Information
Understand Signal Words
Follow Safety Instructions
Replace Safety Signs
Illuminate Work Area Safely
Work in Clean Area
Use Proper Tools
Work In Ventilated Area
Service Machines Safely
Wear Protective Clothing
Prevent Acid Burns
Park Machine Safely
Support Machine Properly
Use Proper Lifting Equipment
Stay Clear of Rotating Drivelines
Install All Guards
Practice Safe Maintenance
Avoid High-Pressure Fluids
Prevent Battery Explosions
Live With Safety
General
General Inboard Planetary Axle Specifications
Axle Identification
Serial Number Plate
Specification and Configuration Code Plate
General Repair Procedures
Sealing Instructions
Transmission, Steering, Brake, Hydraulic, and Gear Case Oil
Service and Maintenance Schedule
Drain, Refill, and Check Axle Oil
Lubricant Storage
Mixing of Lubricants
Multipurpose Extreme Pressure (EP) Grease
Hydraulic Connections
Repair and AdjustmentsOscillation Support
Oscillation Support — Components
Oscillation Support — Assemble
Oscillation Support Seal — Installation
Oscillation Support — Lubrication
Oscillation Support — Installation
Oscillation Support — Removal
Axle Repair Stand
Repair Stand — Installation
Repair Stand — Removal
Input Housing
Input Housing — Components
Input Housing — Assemble
Input Housing — Installation
Input Housing — Removal
Input Housing — Disassemble
Input Yoke — Installation
Input Yoke — Removal
Input Yoke Seal — Installation
Input Yoke Seal — Removal
Input Pinion Shaft — Cone Point Adjustment
Input Pinion Shaft — Bearing Adjustment
Axle Housing and Final Drive
Axle Housing and Final Drive (Cartridge Axle Shaft Seal) — Components
Axle Housing and Final Drive (Metal Face Axle Shaft Seal) — Components
Axle Housing and Final Drive — Assemble
Axle Housing and Final Drive — Installation
Axle Housing and Final Drive — Removal
Axle Housing and Final Drive — Disassemble
Axle Shaft Seal (Cartridge Seal) — Installation
Axle Shaft Seal (Metal Face Seal) — Installation
Axle Bearing — Adjustment
Planetary Carrier
Planetary Carrier — Components
Planetary Carrier — Assemble
Planetary Carrier — Installation
Planetary Carrier — Removal
Planetary Carrier — Disassemble
Single Disk Service Brake
Single Disk Service Brake — Components
Single Disk Service Brake — Installation
Single Disk Service Brake — Removal
Differential Case
Differential Case Fixed — Components
Differential Case Oscillation — Components
Differential Case — Assemble
Differential Case — Disassemble
Differential Bearing Preload — Adjustment
Differential Backlash — Adjustment
Differential — Components
Differential — Assemble
Differential — Installation
Differential — Removal
Differential — Disassemble
Theory of OperationAxle Operation
Inboard Planetary Axle Operation
Differential Operation
Standard Differential Operation
Final Drive — Axle Operation
Service Brake Operation
DiagnosticsBrake Inspection, Adjustments, Tests, and Bleeding
Brake Disk Inspection (External)
Brake Piston Inspection
Service Brake Leak Test
Operational Checks
Axle — Air Test
Axle Vertical Movement Check
Check Carrier Backlash
Check Ring Gear and Pinion Tooth Contact Pattern
Troubleshooting
Troubleshoot Axle and Differential
Tools and Other MaterialsSpecial Tools
27489
D01398AA
D05223ST
DFYZ50
DFYZ94
DFYZ95
DFYZ96
DFYZ98
DFYZ99
DFYZ100
DFYZ104
DFYZ105
DFYZ106
DFYZ107
DFYZ108
DFYZ124
JDG923A
JDG924A
JDG1367
JDG10193A
JDG10627
JDG11002
JDG15000P1
JDG15001
JDG15007
JDG15010
JDG15011
JDG15012
JDG15013
JDG15019
JDG15036
JDG22
JT01748
JT02044
JT03527
JT05706
JT07250
Other Materials
Other Material
SpecificationsBolts and Cap Screws Specifications
Sealants and Adhesives Cross-Reference
Sealants and Adhesives Cross-Reference Chart
Page Number
