Hyundai
86
176,684
John Deere Gator Utility Vehicle TX and TX Turf Technical Manual TM2241
Brand: John Deere
Type of Machine: Gator Utility Vehicle
Type of Manual: Technical Manual
Model: John Deere TX and TX Turf Gator Utility Vehicle
Part Number: TM2241
Publication Date: 2008
Number of Pages: 340 Pages
TM2241 TX and TX Turf Gators
Introduction
Safety
Recognize Safety Information​
Understand Signal Words​
Replace Safety Signs​
Handle Fluids Safely - Avoid Fires​
Use Care In Handling and Servicing Batteries​
Prevent Battery Explosions​
Prevent Acid Burns​
Wear Protective Clothing​
Use Care Around High-pressure Fluid Lines​
Service Machines Safely​
Use Proper Tools​
Parking Safely​
Work In Clean Area​
Support Machine Properly and Use Proper Lifting Equipment​
Using High Pressure Washers​
Illuminate Work Area Safely​
Work In Ventilated Area​
Warning: California Proposition 65 Warning​
Remove Paint Before Welding or Heating​
Avoid Harmful Asbestos Dust​
Service Tires Safely​
Avoid Injury From Rotating Blades, Augers and PTO Shafts​
Service Cooling System Safely​
Handle Chemical Products Safely​
Dispose of Waste Properly​
Live With Safety​
Specifications and Information
Table of Contents​
Fastener Torques​
O-Ring Seal Service Recommendations​
General Information​
Serial Number Locations​
Engine FJ400D
Table of Contents​
Specifications​
Component Location​
Theory of Operation​
Diagnostics​
Tests and Adjustments - General​
Tests and Adjustments - TX​
Tests and Adjustments - TX Turf​
Repair​
Electrical
Table of Contents​
Specifications​
Component Location​
Schematics and Harnesses​
Operation and Diagnostics​
Tests and Adjustments​
Repair​
Attachments Theory of Operation​
Optional Light Kits​
Optional Deluxe Light Kit​
Front Blade Kit​
Optional Gauges Kit​
Horn Kit​
Backup Alarm​
Cargo Box Lift Kit​
Power Train - Gear
Table of Contents​
Specifications​
Component Location​
Diagnostics​
Repair​
Steering
Table of Contents​
Specifications​
Component Location​
Diagnostics​
Repair​
Brakes
Table of Contents​
Specifications​
Component Location​
Diagnostics​
Repair​
Miscellaneous
Table of Contents​
Specifications​
Repair​
Index
