Hyundai
86
176,834
John Deere EZtrak Mower Z445 Z465 Technical Manual TM1499
Brand: John Deere
Type of Machine: EZtrak Mower
Type of Manual: Technical Manual
Model: John Deere Z445 Z465 EZtrak Mower
Part Number: TM1499
Publication Date: 2023
Number of Pages: 265 Pages
Safety
Safety​
Recognize Safety Information​
Replace Safety Signs​
Handle Fluids Safely - Avoid Fires​
Use Care in Handling and Servicing Batteries​
Use Safe Service Procedures​
Park Machine Safely​
Service Tires Safely​
Avoid Injury from Rotating Blades and Drive Shafts​
Handle Chemical Products Safely​
Specifications & Information
General Specifications-​
Metric Fastener Torque Values​
Inch Fastener Torque Values​
Metric Fastener Torque Value - Grade 7 (Special)​
Gasket Sealant Application​
Ring Seal Service Recommendations​
Face Seal Fittings - Inch Stud Ends Torque​
Face Seal Fittings - Metric Stud Ends Torque​
O-Ring Face Seal Fittings​
O-Ring Boss Fittings​
Fuels and Lubricants​
Gasoline​
Gasoline Storage​
4 - Cycle Gasoline Engine Oil​
Break-In Engine Oil - 4-Cycle Gasoline​
Alternative Lubricants​
Synthetic Lubricants​
Lubricant Storage​
Mixing of Lubricants​
Chassis Grease​
Mower Spindle Grease​
Hydrostatic Transmission and Hydraulic Oil​
Serial Number Locations​
Product Identification Numbers​
Engine - Kawasaki (FH721V)
Specifications​
General Specifications​
Test and Adjustment Specifications​
Repair Specifications​
Torque Specifications​
Tools and Materials​
Tools​
Other Materials​
Service Parts Kits​
Component Location​
Engine Components​
Engine Block​
Engine Valves and Governor​
Carburetor​
Theory of Operation​
Engine Oil Flow Chart​
Lubrication System Operation​
Diagnostics​
Engine Troubleshooting Guide​
Starting Motor Troubleshooting Guide​
Tests and Adjustments​
Throttle Cable Check and Adjustment​
Choke Plate Check and Adjustment​
Throttle/Choke Cable Check and Adjustment​
Governor Adjustment​
Slow Idle Speed Adjustment​
Fast Idle Speed Adjustment​
Valve Clearance Check and Adjustment​
Cylinder Leak-Down Test​
Cylinder Compression Pressure Test​
Crankcase Vacuum Test​
Engine Oil Pressure Test​
Fuel Pump Test​
Spark Test​
Spark Plug Gap Adjustment​
Ignition Coil Air Gap Adjustment​
Repair​
Muffler Removal and Installation​
Carburetor Removal and Installation​
Carburetor Repair​
Fuel Pump Replacement​
Blower Housing Removal and Installation​
Flywheel Removal and Installation​
Intake Manifold Removal and Installation​
Breather Removal and Installation​
Engine Removal and Installation​
Rocker Arm Removal and Installation​
Cylinder Head Removal and Installation​
Cylinder Head Inspection​
Recondition Valve Seats​
Lap Valves​
Crankcase Cover Removal and Installation​
Piston and Connecting Rod​
Analyze Crankshaft and Connecting Rod Wear​
Camshaft and Tappets​
Crankshaft and Main Bearings​
Crankshaft Oil Seals​
Deglaze Cylinder Bore​
Resize Cylinder Bore​
Governor Inspection and Replacement​
Governor Shaft Inspection and Replacement​
Oil Pump Disassembly and Assembly​
Oil Cooler Removal and Installation​
Stator Removal and Installation​
Armature Removal and Installation​
Starting Motor Removal and Installation​
Starting Motor​
Electrical
Information​
Reading Electrical Schematics​
Theory Of Operation Information​
Diagnostic Information​
Wire Color Abbreviation Chart​
Common Circuit Tests​
Conductors For 12 Volt Circuits​
Specifications​
System Specifications​
Component Location​
Electrical Component Location​
Schematics and Harnesses​
Schematic and Wiring Harness Legend - Z445​
Schematic and Wiring Harness Legend - Z465​
Main Schematic - Z445​
Main Schematic - Z465​
W1 Main Wiring Harness - Z445​
W1 Main Wiring Harness Color Codes - Z445​
W1 Main Wiring Harness - Z465​
W1 Main Wiring Harness Color Codes - Z465​
W2 Engine Wiring Harness​
W2 Engine Wiring Harness Color Codes​
W3 Headlight Wiring Harness (SN -60000)​
W3 Headlight Wiring Harness Color Codes - Z445 (SN -60000)​
W3 Headlight Wiring Harness Color Codes - Z465 (SN -60000)​
W4 Lighting Power Adaptor Wiring Harness (SN 60001-)​
W4 Lighting Wiring Harness (SN 60001-)​
W4 Lighting Wiring Harness Color Codes (SN60001-)​
G2 Stator​
Power Circuit Operation - Z445​
Power Circuit Schematic - Z445​
Power Circuit Diagnostics - Z445​
Power Circuit Operation - Z465​
Power Circuit Schematic - Z465​
Power Circuit Diagnostics - Z465​
Cranking Circuit Operation - Z445​
Cranking Circuit Schematic - Z445​
Cranking Circuit Diagnostics - Z445​
Cranking Circuit Operation - Z465​
Cranking Circuit Schematic - Z465​
Cranking Circuit Diagnostics - Z465​
Ignition Interlock Circuit Operation - Z445​
Ignition Interlock Circuit Schematic - Z445​
Ignition Interlock Circuit Diagnostics - Z445​
Ignition Interlock Circuit Operation - Z465​
Ignition Interlock Circuit Schematic - Z465​
Ignition Interlock Circuit Diagnostics - Z465​
Fuel Shutoff Solenoid Circuit Operation - Z445​
Fuel Shutoff Solenoid Circuit Schematic - Z445​
Fuel Shutoff Solenoid Circuit Diagnostics - Z445​
Fuel Shutoff Solenoid Circuit Operation - Z465​
Fuel Shutoff Solenoid Circuit Schematic - Z465​
Fuel Shutoff Solenoid Circuit Diagnostics - Z465​
PTO Circuit Operation - Z445​
PTO Circuit Schematic - Z445​
PTO Circuit Diagnostics - Z445​
PTO Circuit Operation - Z465​
PTO Circuit Schematic - Z465​
PTO Circuit Diagnostics - Z465​
Charging Circuit Operation​
Charging Circuit Schematic​
Charging Circuit Diagnostics​
Headlight Circuit Operation (optional)​
Headlight Circuit Schematic (optional)​
Headlight Circuit Diagnostics (optional)​
Hour Meter Circuit Operation​
Hourmeter Circuit Schematic​
Hour Meter Circuit Diagnosis​
Common Circuit Test​
Ground Circuit Test​
Battery Test​
Charge Battery​
Battery Load Test​
Regulated Voltage Test​
Regulated Amperage Test​
Voltage Regulator/Rectifier Test​
Stator Output Test​
Flywheel Stator Magnets Test​
Flywheel Ignition Magnet Test​
Spark Test​
Starting Solenoid Test​
Starter Amperage Draw Test - Loaded​
Starter Amperage Draw Test - No-Load​
Fuel Shutoff Solenoid Test​
PTO Switch Test​
PTO Clutch Test​
Headlight Switch Test​
Fuse Test​
Park Brake and Neutral Switch Test​
Seat Switch Test​
Key Switch Test​
Relay Test​
Diode Test​
Repair​
Stator Replacement​
Ignition Coil Replacement and Adjustment​
Power Train - Hydraulic
Specifications​
Special or Essential Tools​
Other Materials​
Service Parts Kits​
Component Location​
Hydraulic System Components​
Control Linkage​
Power Train Operation​
Schematics​
Hydraulic Schematic​
Diagnostics​
Hydrostatic System Diagnosis​
Check and Adjust Speed Control Lever Neutral Position​
Adjusting Motion Control Levers​
Tracking Adjustment​
Using the Bypass Valves​
Bleed Hydraulic System​
Removing Hydraulic Lock​
Test Hydrostatic Pump Flow​
Repair​
Replacing Transmission Drive Belt​
Changing Hydraulic Oil and Filter​
Wheel Motor Removal and Installation​
Hydrostatic Pump Removal and Installation​
Hydrostatic Pump Disassembly​
Assemble Hydrostatic Pump​
Specifications​
Specifications​
Special or Required Tools​
Component Location​
Deck and Lift Assembly​
Spindle Section 54 and 62 Decks​
Spindle Section 54 High Capacity Deck​
Deck Spindles and Sheaves - 54 Deck​
Deck Spindles and Sheaves - 54 High Capacity Deck​
Deck Spindles and Sheaves - 62 Deck​
Lift Assembly - (SN -40000)​
Lift Assembly - (SN 40001-)​
Deck Lift Control and Linkage (SN 60001-)​
Diagnostics​
Mower Deck Troubleshooting​
Mower Drive Belt Tension - 54 Inch Deck​
Adjusting Mower Wheels​
Adjusting Mower Level​
Repair​
Cleaning Grass and Debris From Machine​
Mower Deck Removal and Installation - 54 in Deck(SN -60000)​
Mower Deck Removal and Installation - 54 in, 54 in High Capacity, and 62 in Deck (SN 60001-)​
Mower Deck Removal and Installation (62 Deck SN -60000)​
Replacing Mower Drive Belt (54 inch Deck)​
Replacing Mower Drive Belt (54 inch High Capacity Deck)​
Replacing Mower Drive Belt (62 inch Deck)​
Mower Blade Removal and Installation​
Sharpen and Balance Blades​
Spindle Repair​
Idlers​
Deck Lift Assist Spring​
Miscellaneous
Specifications​
Component Location​
Park Brake Control and Linkage​
Deck Lift Control and Linkage (SN -60000)​
Park Brake Adjustment​
Repair​
Mower Deck Foot Plate​
Seat Removal and Installation​
Seat Adjustment Platform Removal and Installation​
Control Console Removal and Installation​
Engine Guard Removal​
Muffler Heat Shield Removal and Installation​
Front Caster Wheels​
Page Number
Group O​
Group​
