John Deere Excavator E240 E240LC E260LC Operation Test Technical Manual TM14398X019 2021
Brand: John Deere
Type of Machine: Excavator
Type of Manual: Operation & Test Technical Manual
Model: John Deere E240 ; E240LC ; E260LC Excavator
PIN:
1YNE24BS_ _CXXXXXX— (1YNE24BS CXXXXXX-)
1YNE24BS_ _DXXXXXX— (1YNE24BS DXXXXXX-)
1YNE24BL_ _CXXXXXX— (1YNE24BL CXXXXXX-)
1YNE24BL_ _DXXXXXX— (1YNE24BL DXXXXXX-)
1YNE26BL_ _CXXXXXX— (1YNE26BL CXXXXXX-)
1YNE26BL_ _DXXXXXX— (1YNE26BL DXXXXXX-)
Date: 2021
Parts Number: TM14398X019
Number of Pages: 679 Pages
Introduction
Operational Checkout Procedure
Page Number
Brand: John Deere
PIN:
Date: 2021
Introduction
Foreword
Manual Identification—READ THIS FIRST!
Serial Number Listing Information
ContentsGeneral Information
Safety
Recognize Safety Information
Follow Safety Instructions
Operate Only If Qualified
Wear Protective Equipment
Protect Against Noise
Avoid Unauthorized Machine Modifications
Inspect Machine
Stay Clear of Moving Parts
Avoid High-Pressure Fluids
Avoid High-Pressure Oils
Work In Ventilated Area
Avoid Static Electricity Risk When Refueling
High Debris Applications
Prevent Fires
In Case of Machine Fire
Prevent Battery Explosions
Clean Debris from Machine
Handle Starting Fluid Safely
Prepare for Emergencies
Add Cab Guarding for Special Uses
Start Only From Operator′s Seat
Operating or Traveling On Public Roads
Use and Maintain Seat Belt
Heated and Ventilated Operator’s Seat
Prevent Unintended Machine Movement
Avoid Work Site Hazards
Keep Riders Off Machine
Avoid Backover Accidents
Avoid Machine Tip Over and Machine Damage
Use Special Care When Lifting Objects
Use Care When Swinging Machine
Operate Boom With Care
Avoid Power Lines
Use Special Care When Operating
Inspect and Maintain ROPS
Travel Safely
Add and Operate Attachments Safely
Park and Prepare for Service Safely
Service Machines Safely
Service Cooling System Safely
Make Welding Repairs Safely
Drive Metal Pins Safely
Use Proper Lifting Equipment
DiagnosticsOperational Checkout Procedure
EngineTheory of Operation
John Deere Engine Operation
Cooling System Operation
Cold Weather Starting Aid
System Diagrams
Engine Cooling System Component Location
Engine Fuel System Component Location
Engine Intake and Exhaust Component Location
Diagnostic Information
Engine Identification
Engine Model Number Identification
Engine Emissions Level Identification
Tests
Fluid Sampling Procedure—If Equipped
Machine Preparation
Priming Sample Valve
Obtaining Fluid Sample
Engine Speed Check
Air in Fuel Test
Engine Thermostat Test
Intake Manifold Pressure Test—Turbocharger Boost
Electrical SystemTheory of Operation
Engine Control Unit (ECU) Circuit Theory of Operation
Controller Area Network (CAN) Circuit Theory of Operation
Local Interconnect Network (LIN) Circuit Theory of Operation
Starting and Charging Circuit Theory of Operation
Cab Control Unit (CAB) Circuit Theory of Operation
Hydraulic Control Unit (HCU) Circuit Theory of Operation
Hydraulic Control Unit 2 (HC2) Circuit Theory of Operation
Primary Display Unit (PDU) Circuit Theory of Operation
Auxiliary Control Unit (XCU) Circuit Theory of Operation—If Equipped
JDLink™ Circuit Theory of Operation—If Equipped
Telematics Circuit Theory of Operation—If Equipped
Window Wiper Theory of Operation
System Diagrams
Electrical Diagram Information
System Functional Schematic Diagram
Wiring Diagram
Component Location Diagram
Connector End View Diagram
Electrical Schematic Symbols
Fuse and Relay Specifications
System Functional Schematic, Component Location, and Wiring Diagram Master Legend
Front Harness (W8) Component Location
Front Harness (W8) Wiring Diagram
Rear Harness (W9) Component Location
Rear Harness (W9) Wiring Diagram
Engine Harness (W11) Component Location
Engine Harness (W11) Wiring Diagram
Counterweight Camera Harness (W13) Component Location—If Equipped
Counterweight Camera Harness (W13) Wiring Diagram—If Equipped
Cab Harness (W14) Component Location
Cab Harness (W14) Wiring Diagram
Seat Harness (W15) Component Location
Seat Harness (W15) Wiring Diagram
Boom Light Harness (W17) Component Location
Boom Light Harness (W17) Wiring Diagram
Hydraulic Manifold Harness (W19) Component Location
Hydraulic Manifold Harness (W19) Wiring Diagram
Heating and Air Conditioning System Harness (W20) Component Location
Heating and Air Conditioning System Harness (W20) Wiring Diagram
Radio Harness (W22) Component Location
Standard Radio Harness (W22) Component Location
Premium Radio Harness (W22) Component Location
Radio Harness (W22) Wiring Diagram
Standard Radio Harness (W22) Wiring Diagram
Premium Radio Harness (W22) Wiring Diagram
Wiper Module Harness (W23) Component Location
Wiper Module Harness (W23) Wiring Diagram
Engine Control Unit (ECU) Harness (W27) Component Location
Engine Control Unit (ECU) Harness (W27) Wiring Diagram
Right Pod Harness (W28) Component Location
Right Pod Harness (W28) Wiring Diagram
Fuel Refill Harness (W29) Component Location—If Equipped
Fuel Refill Harness (W29) Wiring Diagram—If Equipped
Travel Alarm Harness (W30) Component Location—If Equipped
Travel Alarm Harness (W30) Wiring Diagram—If Equipped
Auxiliary Harness (W31) Component Location—If Equipped
Auxiliary Harness (W31) Wiring Diagram—If Equipped
Hammer Only Harness (W32) Component Location—If Equipped
Hammer Only Harness (W32) Wiring Diagram—If Equipped
Lower Wiper Harness (W33) Component Location—If Equipped
Lower Wiper Harness (W33) Wiring Diagram—If Equipped
Auxiliary 2 Harness (W34) Component Location—If Equipped
Auxiliary 2 Harness (W34) Wiring Diagram—If Equipped
Service ADVISOR™ Diagnostic Application
Service ADVISOR™ Connection Procedure
Service ADVISOR™ Controller Connectivity Check
Using Service ADVISOR™ Remote
Service ADVISOR™ Remote (SAR) Connection Procedure
Reading Diagnostic Trouble Codes With Service ADVISOR™ Diagnostic Application
Intermittent Diagnostic Trouble Code (DTC) Diagnostics
Diagnostic Trouble Codes—After Machine Repair
Electrical Component Specifications
Monitor Operation
Primary Display Unit (PDU)—Service Mode
Menu—Diagnostics—Codes
Menu—Diagnostics—Engine
Menu—Diagnostics—JDLink System Info—If Equipped
Menu—Diagnostics—OBD Tool
Menu—Diagnostics—OBD Tool—HCU
Menu—Diagnostics—OBD Tool—HC2
Menu—Diagnostics—OBD Tool—CAB
Menu—Diagnostics—OBD Tool—ATC
Menu—Diagnostics—OBD Tool—XCU—If Equipped
Menu—Maintenance
Menu—Aux Hydraulics—Flow Settings
Menu—Machine Setup—Two Function Aux Hardware
Menu—Machine Setup—Enable Options
Menu—Machine Fan—Commanded Fan Speed
Menu—Calibrations
Menu—Software Update
Tests
Controller Area Network (CAN) Circuit Test
Alternator Test
Fuse and Relay Test
Electrical Component Checks
Solenoid Test
Power TrainTheory of Operation
Track Adjuster and Recoil Spring Operation
Travel Gear Case Operation
Noisy or Loose Track Chain
Tight Track Chain
Frequent Track Tension Adjustment Required
Excessive Oil Leakage From Front Idler, Track Rollers, or Carrier Rollers
Bent Track Shoes
"Popping" Of Track
Cracked Track Link
Chipped Track Link Rails
Individual Undercarriage Component Wear
Hydraulic SystemTheory of Operation
Hydraulic System Operation
Pilot System Operation
Pilot Pump Operation
Pilot Control Valve Operation
Travel Pilot Control Valve Operation
Pilot Operation of Control Valve Operation
Pilot Combination Valve Manifold Operation
Pilot Transition Manifold Operation
Pump 1 and Pump 2 Operation
Pump 1 and Pump 2 Regulator Operation
Control Valve Check Valves Identification and Operation
Main Relief Valve Circuit Operation
Circuit Relief and Anticavitation Valve Operation
Flow Combiner Valve Operation
Arm Regenerative Valve Circuit Operation
Boom and Arm Reduced Leakage Valve Operation
Swing Reduction Gear Case Operation
Swing Motor, Crossover Relief Valve, and Make-Up Check Valve Operation
Swing Motor Park Brake Release Circuit Operation
Rotary Manifold Operation
Travel Motor and Park Brake Valve Operation
Travel Motor Speed Circuit Operation
Cylinder Operation
Return Filter Operation
Controlled Load Lowering Device (CLLD) Circuit Operation
System Diagrams
Hydraulic System Schematic Master Legend
Hydraulic System Component Location
Hydraulic System Line Identification
Pump 1, Pump 2, and Pilot Pump Line Identification
Control Valve Line Identification
Swing Motor Line Identification
Pilot Control Valve-to-Pilot Combination Valve Manifold Component Location
Pilot Transition Manifold-to-Control Valve Line Identification
Auxiliary Valves-to-Control Valve Line Identification
Travel Hydraulic System Line Identification
All Hydraulic Functions Slow
Hydraulic Oil Overheats
No Hydraulic Functions
Poor Combined Operation
Function Does Not Stop When Joystick is Released
Some Functions Cannot Be Operated, All Others Are Normal
Some Functions Slow
Function Moves in Opposite Direction
Load Drifts Down When Control Valve is in Neutral Position
Load Falls When Control Valve is Actuated To Raise Load With Engine Running at Slow Idle
H (High Power) Function Does Not Operate, S (Standard Power) and L (Low Power) Mode is Normal
Swing Speed Slow in Both Directions
Swing Speed Slow or Does Not Operate in One Direction
Upperstructure Drift With Swing Valve in Neutral
Swing Function Does Not Operate
Travel Park Brakes Do Not Apply
Track Will Not Move in One Direction
Track Will Not Move in Either Direction
Machine Mistracks at All Speeds in Both Directions
Slow Travel Speed or Low Power
Travel is "Jerky"
Machine Will Not Hold Back and Park Brakes Engage and Disengage When Traveling Down an Incline
Machine Will Not Turn Smoothly in One Direction or Park Brake Grabs
Adjustments
Accumulator Precharge
Pump Calibration
Tests
JT05800 Digital Thermometer Installation
JT02156A Digital Pressure and Temperature Analyzer Kit Installation
Hydraulic Oil Cleanup Procedure
Hydraulic Oil Tank Pressure Release Procedure
Hydraulic Oil Warm-Up Procedure
Pilot Pressure Regulating Valve Test and Adjustment
Control Valve Spool Actuating Pilot Pressure Test
Pressure Boost Solenoid Valve Test
Travel Speed Solenoid Valve Test and Adjustment
System Relief Valve Test and Adjustment
Reading Pressures With Test Equipment
Circuit Relief Valve Test and Adjustment
Auxiliary Circuit Relief Valve Test and Adjustment
Swing Motor Crossover Relief Valve Test and Adjustment
Travel Motor Crossover Relief Valve Test and Adjustment
Pump Regulator Test and Adjustment—Minimum Flow
Pump Regulator Test and Adjustment—Maximum Flow
Pump Regulator Pressure Test
Pump Flow Test
Swing Motor Leakage Test
Travel Motor Leakage Test
Cylinder Drift Test—Boom, Arm, and Bucket
Boom Cylinder Test
Bucket Cylinder Test
Arm Cylinder Test
Heating and Air ConditioningTheory of Operation
Air Conditioning System Cycle of Operation
System Diagrams
Heater and Air Conditioner Component Locations
Air Conditioning System Does Not Operate
Air Conditioner Does Not Cool Interior of Cab
Air Conditioning System Runs Constantly, Too Cold
Heating System Does Not Operate
Heating System Does Not Warm Interior of Cab
Interior Windows Continue to Fog
Tests
Refrigerant Cautions and Proper Handling
R134a Oil Charge Capacity
R134a Refrigerant Charge Capacity
Heater and Air Conditioner Operational Checks
Air Conditioner Compressor Clutch Test
R134a Refrigerant Leak Test
Refrigerant Hoses and Tubing Inspection
Air Conditioner Pressure Sensor Test
Evaporator Core Temperature Sensor Test
R134a Air Conditioning System Test
Operating Pressure Diagnostic Chart
APPENDIXPage Number
Section 9000
Group 01
Section 9001
Group 10
Group 20
Group 30
Group 40
Group 50
Group 60
Group 70
Group 80
Group 90
Group 100
Group 110
Section 9005
Group 10
Section 9010
Group 05
Group 10
Group 15
Group 25
Section 9015
Group 05
Group 10
Group 15
Group 16
Group 25
Section 9020
Group 05
Group 15
Section 9025
Group 05
Group 10
Group 15
Group 20
Group 25
Section 9031
Group 05
Group 10
Group 15
Group 25
