John Deere Excavator 85D Operation And Test Manual TM10754
Brand: John Deere
Type of Machine: Excavator
Type of Manual: Operation And Test Manual
Model: John Deere 85D Excavator
Part Number: TM10754
Publication Date: 2015
Number of Pages: 719 Pages
Section 9000 - GENERAL INFORMATION
Group 01 - Safety
Group 10 - Main Controller (MCF) Diagnostic Trouble Codes
Group 10 - Operational Checkout Procedure
Group 05 - Theory of Operation
Group 05 - System Information
Group 05 - Terminology Cross Reference Chart
Brand: John Deere
Group 01 - Safety
Recognize Safety Information
Follow Safety Instructions
Operate Only If Qualified
Wear Protective Equipment
Avoid Unauthorized Machine Modifications
Add Cab Guarding for Special Uses
Inspect Machine
Stay Clear of Moving Parts
Avoid High-Pressure Fluids
Avoid High-Pressure Oils
Beware of Exhaust Fumes
Prevent Fires
Prevent Battery Explosions
Dispose of Waste Properly
Prepare for Emergencies
Start Only From Operator′s Seat
Use and Maintain Seat Belt
Prevent Unintended Machine Movement
Avoid Work Site Hazards
Keep Riders Off Machine
Avoid Backover Accidents
Avoid Machine Tip Over
Use Special Care When Lifting Objects
Add and Operate Attachments Safely
Prevent Unintended Detonation of Explosive Devices
Park and Prepare for Service Safely
Service Cooling System Safely
Make Welding Repairs Safely
Drive Metal Pins Safely
Section 9001 - DIAGNOSTICSGroup 10 - Main Controller (MCF) Diagnostic Trouble Codes
Controller Hardware Diagnostics
Abnormal Sensor Voltage Diagnostic Procedure
Controller Area Network (CAN) Diagnostics
Engine Speed Diagnostics
Engine Speed Dial Diagnostics
Travel Pilot Pressure Sensor Diagnostics
Front Attachment Pilot Pressure Sensor Diagnostics
Torque Control Solenoid Diagnostics
Power Dig Solenoid Diagnostics
Travel Speed Solenoid Diagnostics
Group 20 - Engine Control Module (ECF) Diagnostic Trouble CodesEngine Control Module (ECF) Diagnostic Trouble Codes
Harness Diagnostics
Engine Control Motor Sensor Voltage High Diagnostics
Engine Control Motor Sensor Voltage Low Diagnostics
Target Engine Speed From Main Controller Missing Diagnostics
Group 30 - Information Controller (ICF) Diagnostic Trouble CodesInformation Controller (ICF) Diagnostic Trouble Codes
14006.02 - ICF: Satellite Communication Terminal: Communication Error
14100.02 - Satellite Communication Terminal: Abnormal EEPROM
14101.02 - Satellite Communication Terminal: Abnormal IB / OB Queue
14102.02 - Satellite Communication Terminal: Abnormal Local Loop Back
14103.02 - Satellite Communication Terminal: The Satellite is not found
14104.02 - Satellite Communication Terminal: Fail 1 of Remote Loop Back
14105.02 - Satellite Communication Terminal: Tail 2 of Remote Loop Back
14106.02 - Satellite Communication Terminal: Sending and Receiving Data are Mismatched
Group 40 - Air Conditioner Controller (ACF) Diagnostic Trouble CodesAir Conditioner Controller (ACF) Diagnostic Trouble Codes
Harness Diagnostics
Harness Diagnostics
Harness Diagnostics
Harness Diagnostics
Harness Diagnostics
Harness Diagnostics
Harness Diagnostics
Harness Diagnostics
Harness Diagnostics
Harness Diagnostics
Harness Diagnostics
Group 50 - Monitor Controller (MON) Diagnostic Trouble CodesMonitor Controller (MON) Diagnostic Trouble Codes
Monitor Temperature Diagnostics
Alternator Output Diagnostics
Information Controller Diagnostics
Controller Area Network Diagnostics
Coolant Temperature Sensor Diagnostics
Fuel Level Sensor Diagnostics
Hydraulic Oil Filter Restriction Alarm Diagnostic Procedure
Section 9005 - OPERATIONAL CHECKOUT PROCEDUREGroup 10 - Operational Checkout Procedure
Operational Checks—Key Switch On, Engine On Checks
Section 9010 - ENGINEGroup 05 - Theory of Operation
Engine Component Location
Engine Fuel System Operation
Cooling System Operation
Engine Lubrication System Operation
Engine Intake and Exhaust System Operation
Engine Turbocharger Operation
Exhaust Gas Recirculation (EGR) Operation
Quick On System Operation
Engine Speed Control System Operation
Group 15 - Diagnostic Information4LE2 Isuzu Diesel Engine
Diagnose Engine Malfunctions
Engine Cranks But Will Not Start Diagnostic Procedure
Engine Misfires Or Runs Irregularly Diagnostic Procedure
Engine Does Not Develop Full Power Diagnostic Procedure
Engine Overheats Diagnostics Procedure
Auto-Idle Does Not Work Diagnostics Procedure
Coolant Temperature Too Low Diagnostics Procedure
Coolant in Oil or Oil in Coolant Diagnostics Procedure
Low Engine Oil Pressure Diagnostics Procedure
High Engine Oil Pressure Diagnostics Procedure
Engine Uses Too Much Oil Diagnostics
Engine Uses Too Much Fuel Diagnostic Procedure
Engine Emits Excessive White Exhaust Smoke Diagnostic Procedure
Engine Emits Excessive Black or Gray Exhaust Smoke Diagnostic Procedure
Turbocharger Excessively Noisy or Vibrates Diagnostics Procedure
Oil Dripping From Turbocharger Adapter Diagnostics Procedure
Excessive Drag in Turbocharger Rotating Members Diagnostics Procedure
Group 25 - TestsSerpentine Belt Check and Adjust
Fuel Injector Pressure Test
Engine Valve Lash (Clearance) Check and Adjust
Engine Compression Pressure Test
Air Filter Restriction Indicator Switch Test
Engine Power Test Using Turbocharger Boost Pressure
Engine Oil Pressure Test
Exhaust Gas Recirculation (EGR) Valve Test
Glow Plug Test
Engine Learning Procedure
Section 9015 - ELECTRICAL SYSTEMGroup 05 - System Information
Electrical Diagram Information
Group 10 - System DiagramsExplanation of Wire Markings
Fuse and Relay Specifications
System Functional Schematic, Component Location, and Wiring Diagram Master Legend
Cab Harness (W1) Component Location
Cab Harness (W1) Wiring Diagram
Machine Harness (W2) Component Location
Machine Harness (W2) Wiring Diagram
Monitor Harness (W3) Component Location
Monitor Harness (W3) Wiring Diagram
Heater and Air Conditioner Harness (W6) Component Location
Heater and Air Conditioner Harness (W6) Wiring Diagram
Auxiliary Fuse Box Harness (W9) Component Location
Auxiliary Fuse Box Harness (W9) Wiring Diagram
Pilot Shutoff Switch Harness (W11) Component Location
Pilot Shutoff Switch Harness (W11) Wiring Diagram
Speaker Harness (W14) Component Location
Speaker Harness (W14) Wiring Diagram
Travel Alarm Cancel Switch Harness (W15) Component Location
Travel Alarm Cancel Switch Harness (W15) Wiring Diagram
Pilot Shutoff Valve Harness (W17) Component Location
Pilot Shutoff Valve Harness (W17) Wiring Diagram
Key Switch Harness (W18) Component Location
Key Switch Harness (W18) Wiring Diagram
Lighter Harness (W19) Component Location
Lighter Harness (W19) Wiring Diagram
Service Advisor Connector Harness (W22) Component Location
Service Advisor Connector Harness (W22) Wiring Diagram
12-Volt Power Converter Harness (W23) Component Location
12-Volt Power Converter Harness (W23) Wiring Diagram
Right Multi-Function Pilot Control Lever Harness (W24) Component Location
Right Multi-Function Pilot Control Lever Harness (W24) Wiring Diagram
Left Multi-Function Pilot Control Lever Harness (W25) Component Location
Left Multi-Function Pilot Control Lever Harness (W25) Wiring Diagram
Travel Alarm Harness (W26) Component Location
Travel Alarm Harness (W26) Wiring Diagram
Engine Coolant Overheat Switch Harness (W27) Component Location
Engine Coolant Overheat Switch Harness (W27) Wiring Diagram
Boom Light Harness (W28) Component Location
Boom Light Harness (W28) Wiring Diagram
Engine Learning and Stop Switch Harness (W35) Component Location
Engine Learning and Stop Switch Harness (W35) Wiring Diagram
Service Advisor Sub Harness (W36) Component Location
Service Advisor Sub Harness (W36) Wiring Diagram
Auxiliary Solenoid Harness (W61) Component Location
Auxiliary Solenoid Harness (W61) Wiring Diagram
Group 15 - Sub-System DiagnosticsController Area Network (CAN) Theory of Operation
Starting and Charging Circuit Theory of Operation
Monitor Controller Circuit Theory of Operation
Main Controller (MCF) Circuit Theory of Operation
Information Controller (ICF) Circuit Theory of Operation
Travel Alarm Circuit Theory of Operation
Windshield Wiper and Washer Circuit Theory of Operation
Pilot Shutoff Circuit Theory of Operation
Group 16 - Monitor OperationMonitor Menu Operation
Monitor Service Menu Operation
Group 20 - ReferencesMonitor Data Items
Reading Diagnostic Trouble Codes with Monitor Display
JDLink™ Connection Procedure—If Equipped
Service ADVISOR™ Diagnostic Application
Service ADVISOR™ Connection Procedure
Reading Diagnostic Trouble Codes with Service ADVISOR™ Diagnostic Application
Information Controller (ICF) Recorded Data
Fuse Test
Relay Test
Pressure Sensor Test
Solenoid Test
Proportional Solenoid Test
Temperature Sensor Test
Alternator Test
Component Checks
Battery Remove and Install
Rear Cover Remove and Install
Main Controller (MCF) Remove and Install
Engine Control Module (ECF) Remove and Install
Information Controller (ICF) Remove and Install
Monitor Controller Remove and Install
Key Switch Remove and Install
Switch Panel Remove and Install
Travel Alarm Remove and Install
Left Console Switch Remove and Install
Disconnect Tab Retainer Connectors
Disconnecting Spring Wire Clip Connectors
Replace DEUTSCH DEUTSCH is a trademark of the Deutsch Co. Connectors
Replace DEUTSCH DEUTSCH is a trademark of Deutsch Co. Rectangular or Triangular Connectors
Install DEUTSCH DEUTSCH is a trademark of the Deutsch Co. Contact
Replace WEATHER PACK WEATHER PACK is a trademark of Packard Electric. Connector
Install WEATHER PACK WEATHER PACK is a trademark of Packard Electric. Contact
Replace (Pull Type) Metri-Pack™ Connectors
Replace (Push Type) Metri-Pack™ Connectors
Replace CINCH CINCH is a trademark of the Cinch Co. Connectors
Install CINCH CINCH is a trademark of the Cinch Co. Contact
Repair 32 and 48 Way CINCH CINCH is a trademark of the Cinch Co. Connectors
Remove Connector Body from Blade Terminals
Section 9020 - POWER TRAINGroup 05 - Theory of Operation
Track Adjuster and Recoil Spring Operation
Travel Gearbox Operation
Group 15 - Diagnostic InformationIndividual Undercarriage Component Wear
Measure Swing Bearing Wear
Section 9025 - HYDRAULIC SYSTEMGroup 05 - Theory of Operation
Hydraulic System Operation
Pilot System Operation
Pilot Pump, Pressure Regulating Valve and Filter Operation
Pilot Shutoff Solenoid Valve Operation
Pilot Control Valve Operation
Control Lever Pattern Selector—If Equipped
Travel Pilot Control Valve Operation
Pilot Operation of Control Valve Operation
Flow Regulator Valve Operation
Swing Shockless Valve
Hydraulic Pump 1, 2, and 3 Operation
Hydraulic Pump Regulator Operation
Engine Speed Sensing Control Circuit Operation
Control Valve Check Valves Identification and Operation
Main Relief Valve Circuit Operation
Circuit Relief and Anticavitation Valve Operation
Flow Combiner Valve Operation
Auxiliary Flow Combiner Valve Operation
Travel and Arm In Combined Operation
Swing and Boom Up Combined Operation
Boom Reduced Leakage Valve Operation
Swing Reduction Gearbox Operation
Swing Motor, Crossover Relief Valve, and Make-Up Check Valve Operation
Swing Motor Park Brake Release Circuit Operation
Center Joint Operation
Travel Motor and Park Brake Valve Operation
Travel Motor Speed Circuit Operation
Cylinder Operation
Return Filter Operation
Group 15 - Diagnostic InformationPoor Combined Operation
Function Moves in Opposite Direction
Load Falls When Control Valve Is Actuated To Raise Load With Engine Running At Slow Idle
Engine Stops During Combined Operation of Swing and Front Attachment
Machine Will Not Turn Smoothly In One Direction Or Park Brake Grabs
Pump 1, Pump 2, Pump 3 and Pilot Pump Line Identification
Control Valve Line Identification
Pilot Control Valve Line Identification—Excavator and Backhoe Pattern
Swing Motor Line Identification
Travel System Component Location
Travel Hydraulic System Line Connection
Hydraulic System Schematic
Hydraulic System Component Location
Hydraulic System Line Connections
Group 25 - TestsJT05800 Digital Thermometer Installation
JT02156A Digital Pressure/Temperature Analyzer Installation
General Oil Cleanup Procedure Using Portable Filter Caddy
Hydraulic Component Failure Cleanup Procedure Using Portable Filter Caddy
Hydraulic Oil Warm-Up Procedure
Pilot Pressure Regulating Valve Test and Adjustment
Control Valve Spool Actuating Pilot Pressure Test
Travel Speed Solenoid Valve Test and Adjustment
Torque Control Solenoid Valve Test and Adjustment
Main Relief Valve Test and Adjustment
Circuit Relief Valve Test and Adjustment
Swing Motor Crossover Relief Valve Test and Adjustment
Travel Motor Crossover Relief Valve Test and Adjustment
Pump Flow Test
Swing Motor Leakage Test
Travel Motor Leakage Test
Cylinder Drift Test—Boom, Arm, Bucket, and Blade
Section 9031 - HEATING AND AIR CONDITIONINGGroup 05 - Theory of Operation
Air Conditioning System Cycle of Operation
Group 15 - Diagnostic InformationDiagnose Air Conditioner System Malfunctions
Diagnose Heating System Malfunctions
Heater and Air Conditioner Diagnostic Trouble Code Check
Heater and Air Conditioner Component Location
Group 25 - TestsRefrigerant Cautions and Proper Handling
Visual Inspection of Components
Air Conditioner Compressor Clutch Test
Refrigerant Leak Test
Refrigerant Hoses and Tubing Inspection
Air Conditioner Compressor Belt Check and Adjustment
Operating Pressure Diagnostic Chart
Section 9050 - REFERENCE MATERIALGroup 05 - Terminology Cross Reference Chart
