John Deere Excavator 35C ZTS Parts Catalog PC9221
Brand: John Deere
Type of Machine: Excavator
Model: John Deere 35C ZTS Excavator
Part Number: PC9221
Publication Date: 2019
Number of Pages: 484 Pages
01 WHEELS & TIRES & TRACKS
Brand: John Deere
Part Number: PC9221
0130 Track Systems
0131 Track Frames
0133 Rollers
02 AXLES, DIFFERENTIALS & SUSPENSION SYSTEMS0263 LINES, HOSE & FITTINGS
0267 Hydraulic Drive Motor
04 Engine0401 Crankshaft And Main Bearing
0402 Camshaft And Valve Actuating Means
0404 Cylinder Block
0407 Engine Oiling System
0408 Ventilating System
0409 Cylinder Head and Valves
0410 Exhaust Manifold
0413 Fuel Injection System
0414 Intake Manifold
0417 Water Pump
0418 THERMOSTATS, HOUSINGS AND WATER PIPING
0422 Starting Motor And Fastenings
0423 Alternator And Generator Mounting
0433 FLYWHEEL, HOUSING AND FASTENINGS
0452 Gasket Replacement Kits
05 Engine Auxiliary System0510 Engine Cooling Systems
0511 RADIATOR AND FAN SHROUD
0515 Engine Speed Controls
0521 AIR CLEANER AND PIPING
0531 MUFFLER & EXHAUST PIPE
0540 Engine Mounting
0560 EXTERNAL FUEL SUPPLY SYSTEM
0564 Fuel Tank
0578 Sensors
13 Miscellaneous Vehicle1322 DECALS & TRADEMARKS
16 Vehicle Electrical Systems1671 BATTERIES, SUPPORT & CABLES
1673 Vehicle Lighting System
1674 WIRING HARNESS & SWITCHES
17 FRAME, CHASSIS OR SUPPORTING STRUCTURE1742 EQUIPMENT OR SECONDARY FRAME (VEHICLE)
1749 Chassis Weights
18 Operator's Station1807 Special Noise Control Items
1810 Operator Enclosure
1811 ROPS, FOPS, OPS OR BODY FRAME
1812 Platform
1813 Body Sides, Doors, Shields And Glazing
1814 WINDSHIELD & WIPERS
1821 Seat And Seat Belts
1830 HEATING AND AIR CONDITIONING
1831 HEATER HOSES & CONTROLS
19 SHEET METAL & STYLING1912 HOOD & HOOD SUPPORTS
1913 Miscellaneous Shields
20 SAFETY, CONVENIENCE & MISCELLANEOUS2001 Radio
2004 Warning Devices
21 Vehicle Main Hydraulic System2161 Hyd Pumps & Drives
2163 HYD LINES & HOSES
2164 HYD RESERVOIR, FILTER & COOLER
33 Excavator3301 BLADES & SIDE CUTTERS
3302 Bucket With Teeth
3315 Controls Linkage
3344 Boom
3346 Dipperstick
3362 CONTROL & LOAD HOLDING VALVES
3363 LINES, HOSES & FITTINGS
3365 Hydraulic Cylinders
43 Swing, Rotation Or Pivoting System4353 SWING BEARING & MOUNTING
4365 Cylinders
4367 Motors
