John Deere Excavator 160GLC 180GLC Operation Manual OMT306200
Brand: John Deere
Type of Machine: Excavator
Model: John Deere 160GLC 180GLC Excavator
(PIN: 1FF160GX_ _E055001— )
(PIN: 1FF180GX_ _E020001— )
Part Number: OMT306200
Number of Pages: 286 Pages
Brand: John Deere
Safety—Safety and Operator Conveniences
Safety and Operator Convenience Features
Safety—General Precautions
Recognize Safety Information
Follow Safety Instructions
Operate Only If Qualified
Wear Protective Equipment
Avoid Unauthorized Machine Modifications
Control Pattern Selector—If Equipped
Add Cab Guarding for Special Uses
Inspect Machine
Stay Clear of Moving Parts
Avoid High-Pressure Fluids
Avoid High-Pressure Oils
Work In Ventilated Area
Avoid Static Electricity Risk When Refueling
Prevent Fires
Prevent Battery Explosions
Dispose of Waste Properly
Exhaust Filter Ash Handling and Disposal
Prepare for Emergencies
Clean Debris from Machine
Safety—Operating Precautions
Start Only From Operator's Seat
Use and Maintain Seat Belt
Prevent Unintended Machine Movement
Avoid Work Site Hazards
Keep Riders Off Machine
Avoid Backover Accidents
Inspect and Maintain ROPS
Avoid Machine Tip Over
Use Special Care When Lifting Objects
Use Special Care When Operating
Travel Safely
Prevent Acid Burns
Add and Operate Attachments Safely
Safety—Maintenance Precautions
Park and Prepare for Service Safely
Service Cooling System Safely
Make Welding Repairs Safely
Drive Metal Pins Safely
Clean Exhaust Filter Safely
Safety—Safety Signs
Safety Signs
Hydraulic Coupler Safety Signs—If Equipped
Operation—Operator's Station
Pedals, Levers, and Panels
Switch Panel
Switch Panel Functions
Rear Left Panel
Horn
Power Dig Button
Pilot Shutoff Lever
Left Console
Travel Alarm and Travel Alarm Cancel Switch
Seat Heater Switch—If Equipped
Reversing Fan Switch—If Equipped
Right Console
Exhaust Filter Parked Cleaning Switch
Right Enable Switch
Service ADVISOR™ Remote (SAR) Switch
Cab Heater and Air Conditioner
Selecting Display Between Celsius and Fahrenheit
Operating the AM/FM Radio
Fire Extinguisher Mounting Location
Secondary Exit Tool
Cab Dome Light Switch
Opening Upper Front (Secondary Exit) Window
Removing and Storing the Lower Front Window
Opening Cab Door Window
Opening and Closing the Polycarbonate Type Roof Exit Cover
Adjusting the Mechanical Suspension Seat
Adjusting the Air Suspension Seat—If Equipped
Adjusting Pilot Control Lever Console Height
Operation—Monitor Operation
Monitor
Monitor Functions
Monitor Start-Up
Main Menu
Main Menu—Alarm List
Main Menu—Air Conditioner
Main Menu—Radio
Main Menu—Work Mode
Main Menu—Setting Menu
Main Menu—Setting Menu—Date and Time
Main Menu—Setting Menu—Attachment Name Input
Main Menu—Setting Menu—Auto Shutdown
Main Menu—Setting Menu—Auto Exhaust Filter Cleaning
Main Menu—Setting Menu—Sub Meter Selection
Main Menu—Setting Menu—Rear View Camera Monitor
Main Menu—Setting Menu—Display Item Selection
Main Menu—Setting Menu—Brightness Adjustment
Main Menu—Setting Menu—Language
Main Menu—Setting Menu—Unit Selection
Main Menu—Setting Menu—Main Menu Sequence Change
Main Menu—Information Menu
Main Menu—Information Menu—Operation
Main Menu—Information Menu—Maintenance
Main Menu—Information Menu—Troubleshooting
Main Menu—Information Menu—Monitoring
Operation—Operating the Machine
Before Starting Work
Operator's Daily Machine Check Before Starting
Engine Break-In Period
Starting Engine
Cold Weather Start Aid
Cold Weather Warmup
Travel Pedals and Levers
Exhaust Filter
Service ADVISOR™ Remote (SAR) Software Delivery Process
Service ADVISOR™ Remote (SAR) Operation
Locking the Hydraulic Coupler to the Attachment—If Equipped
Unlocking the Hydraulic Coupler From the Attachment—If Equipped
Control Lever Pattern Operation
Mechanical Control Lever Pattern Selector—If Equipped
Control Lever Pattern Conversion
Operating in Water and Mud
Driving Up a Steep or Slippery Slope
Lifting
Lower Boom With Engine Stopped
Parking the Machine
Loading and Unloading for Transport
Towing Machine
Lifting the Machine
Maintenance—Machine
Diesel Fuel
Diesel Fuel Specifications
Lubricity of Diesel Fuel
Biodiesel Fuel
Testing Diesel Fuel
Fuel Filters
Minimizing the Effect of Cold Weather on Diesel Engines
Mixing of Lubricants
Lubricant Storage
John Deere Break-In Plus™ Engine Oil
Diesel Engine Oil—Interim Tier 4 and Stage III B Engines
Engine Oil and Filter Service Intervals — Interim Tier 4, Final Tier 4, Stage IIIB, and Stage IV Engines
Oil Filters
Hydraulic Oil
Swing Gear Case and Travel Gear Case Oils
Pump Drive Gear Case Oil
Track Adjuster, Working Tool Pivot, Swing Bearing, and Swing Bearing Gear Grease
Diesel Engine Coolant (engine with wet sleeve cylinder liners)
Drain Intervals for Diesel Engine Coolant
John Deere COOL-GARD™ II Coolant Extender
Supplemental Coolant Additives
Operating in Warm Temperature Climates
Additional Information About Diesel Engine Coolants and John Deere COOL-GARD™ II Coolant Extender
Testing Diesel Engine Coolant
Disposing of Coolant
Maintenance—Periodic Maintenance
Service Machine at Specified Intervals
Check the Hour Meter Regularly
Prepare Machine for Maintenance
Open Access Doors for Service
Open Engine Cover for Service
Hydraulic Breaker and Crusher Attachments
Fluid Analysis Program Test Kits and 3-Way Coolant Test Kit
Service Intervals
Required Parts
Maintenance—As Required
Remove and Clean Fuel Tank Inlet Screen
Check Windshield Washer Fluid Level
Check and Clean Air Cleaner Dust Unloader Valve
Check and Adjust Track Sag
Clean Rear Camera Lens—If Equipped
Check Coolant
Service Exhaust Filter
Maintenance—10 Hours or Daily
Check Engine Oil Level
Check Engine Coolant Level
Check Hydraulic Tank Oil Level
Lubricate Hydraulic Coupler—If Equipped
Maintenance—Every 50 Hours or Weekly
Drain Water and Sediment from Fuel Tank Sump
Drain Primary Fuel Filter and Water Separator
Drain Final Fuel Filter
Drain Auxiliary Fuel Filter and Water Separator—If Equipped
Maintenance—Every 100 Hours
Lubricate Working Tool Pivots
Inspect and Re-Torque Track Hardware
Maintenance—Every 250 Hours
Check Swing Gear Case Oil Level
Drain Water and Sediment from Hydraulic Tank
Check Pump Drive Gear Case Oil Level
Check Battery Electrolyte Level and Terminals
Check Travel Gear Case Oil Level
Take Engine Oil Sample
Maintenance—Every 500 Hours
Lubricate Front End Pin Joints
Lubricate Swing Bearing
Lubricate Swing Bearing Gear
Replace Primary Fuel Filter and Water Separator
Replace Final Fuel Filter
Replace Auxiliary Fuel Filter and Water Separator—If Equipped
Check Air Intake Hoses
Drain and Refill Engine Oil and Replace Filter
Clean Cab Fresh Air and Cab Recirculating Air Filters
Take Fluid Samples
Maintenance—Every 1000 Hours
Drain and Refill Swing Gear Case Oil
Replace Hydraulic Tank Oil Filter
Replace Pilot Oil Filter
Drain and Refill Pump Drive Gear Case Oil
Remove and Clean Open Crankcase Ventilation (OCV) Hose
Inspect Serpentine Belt
Replace Air Cleaner Elements
Replace Air Cleaner Dust Unloader Valve
Check Coolant
Maintenance—Every 2000 Hours
Check and Adjust Engine Valve Lash
Drain and Refill Travel Gear Case Oil
Replace Open Crankcase Ventilation (OCV) Filter
Maintenance—Every 5000 Hours
Drain and Refill Hydraulic Tank Oil
Replace Hydraulic Tank Vent Cap Filter
Maintenance—Every 6000 Hours
Drain Cooling System
Cooling System Fill and Deaeration Procedure
Miscellaneous—Machine
Bleed Fuel System
Clean Radiator, Oil Cooler, Charge Air Cooler, and Fuel Cooler
Do Not Service or Adjust Injection Nozzles or High-Pressure Fuel Pump
Do Not Service Control Valves, Cylinders, Pumps, or Motors
Precautions for Alternator and Regulator
Handling, Checking, and Servicing Batteries Carefully
Using Battery Charger
Using Booster Batteries—24-Volt System
Replacing Batteries
Fluid Sampling Test Ports—If Equipped
Welding On Machine
Clean the Machine Regularly
Adding 12—Volt Accessories
JDLink™ Machine Monitoring System (MMS)—If Equipped
Replacing Fuses
Replacing Bucket Teeth
Replacing Bucket Tooth Tip—Heavy-Duty Bucket
Replacing Bucket Teeth—TK Series
Removing the Bucket
Track Sag General Information
Check Track Shoe Hardware
Hardware Torque Specifications
Miscellaneous—Operational Checkout
Miscellaneous—Troubleshooting
Troubleshooting Procedure
Miscellaneous—Storage
Prepare Machine for Storage
Monthly Storage Procedure
Miscellaneous—Machine Numbers
Record Product Identification Number (PIN)
Record Engine Serial Number
Record Travel Motor Serial Numbers
Record Swing Motor Serial Number
Record Hydraulic Coupler Serial Number—If Equipped
Hydraulic Pump Serial Number
Keep Proof of Ownership
Keep Machines Secure
Miscellaneous—Specifications
160GLC Engine Specifications
180GLC Engine Specifications
160GLC and 180GLC Drain and Refill Capacities
160GLC Machine Specifications
180GLC Machine Specifications
160GLC Working Ranges
180GLC Working Ranges
160GLC Lift Capacity—Arm: 2.60 m (8 ft. 6 in.); Bucket: 528 kg (1164 lb.); Shoe: 600 mm (24 in.)
160GLC Lift Capacity—Arm: 2.60 m (8 ft. 6 in.); Bucket: 528 kg (1164 lb.); Shoe: 700 mm (28 in.)
160GLC Lift Capacity—Arm: 3.10 m (10 ft. 2 in.); Bucket: 528 kg (1164 lb.); Shoe: 600 mm (24 in.)
160GLC Lift Capacity—Arm: 3.10 m (10 ft. 2 in.); Bucket: 528 kg (1164 lb.); Shoe: 700 mm (28 in.)
180GLC Lift Capacity—Arm: 2.71 m (8 ft. 10 in.); Bucket: 600 kg (1323 lb.); Shoe: 600 mm (24 in.)
180GLC Lift Capacity—Arm: 2.71 m (8 ft. 10 in.); Bucket: 600 kg (1323 lb.); Shoe: 700 mm (28 in.)
180GLC Lift Capacity—Arm: 2.71 m (8 ft. 10 in.); Bucket: 600 kg (1323 lb.); Shoe: 800 mm (32 in.)
180GLC Lift Capacity—Arm: 3.21 m (10 ft. 6 in.); Bucket: 600 kg (1323 lb.); Shoe: 600 mm (24 in.)
180GLC Lift Capacity—Arm: 3.21 m (10 ft. 6 in.); Bucket: 600 kg (1323 lb.); Shoe: 700 mm (28 in.)
180GLC Lift Capacity—Arm: 3.21 m (10 ft. 6 in.); Bucket: 600 kg (1323 lb.); Shoe: 800 mm (32 in.)
Page Number
