Leonardobmt
140
1,146,792
John Deere Diesel Engine 4045 PowerTech OEM Tier 4F Technical Manual CTM120119
Brand: John Deere
Type of Machine: Diesel Engine
Type of document: Technical Manual
Model: 4045 PowerTech 4.5 L OEM Diesel Engines - Final Tier 4/Stage IV Platform
Number of Pages: 2376 pages
Date Modified: 14/2016
Part Number: CTM120119
Safety Engine Identification
Fuels, Lubricants, and coolant Repair and Adjustments N Engine Rebuild
Cylinder Head and Valve Repair and Adjustment
- Cylinder Block, Liners, Pistons, and Rods Repair and Adjustment
- Crankshaft, Main Bearings, and Flywheel Repair and Adjustment
- Camshaft, Balancing Shaft and Timing Gear Train Repair and Adjustment
- Lubrication System Repair and Adjustment
- Cooling System Repair and Adjustment
- Air Intake and Exhaust System Repair and Adjustment
- Dual Turbocharger - Air Intake and Exhaust System Repair and Adjustment
- Single Turbocharger - Electronic Fuel System Repair and Adjustment
- OEM Starting and Charging Systems Repair and Adjustment
- Electrical Engine Control Repair and Adjustment
- Connector Repair and Adjustment
- Fuel Dosing Aftertreatment Devices Repair and Adjustment
- DEF Dosing Aftertreatment Devices Repair and Adjustment
Theory of Operation - Base Engine - Cooling System - Lubrication System A Electronic Fuel System A Air Intake and Exhaust System A Aftertreatment System
Electrical Control System Diagnostics
Observable Diagnostics Checks, Tests, and Procedures Diagnostic Instructions and Information
DTC SPN-000001–000199 A DTC SPN-000200—000699 A DTC SPN-000700—001999
DTC SPN - 002000—002299 A DTC SPN-002300—002999 0 DTC SPN-003000–003999
DTC SPN-004000—529999 Tools and Other Materials
Special Tools
Lubricants, Sealants, and Other Materials Specifications A Repair and General OEM Specifications
Diagnostic Specifications
