John Deere Computer Trak 150 350 450 Monitors Operators Manual OMA77221
Format: HTML
Brand: John Deere
Type of Machine: Computer
Model: John Deere Computer Trak™ 150 350 450 Monitors
Parts Number: OMA77221
Foreword
Identification Views
To the Dealer
Section 05 - Safety
Recognize Safety Information
Understand Signal Words
Follow Safety Instructions
Prevent Machine Runaway
Welding Near Electronic Control Units
Prepare for Emergencies
Store Attachments Safely
Prevent Battery Explosions
Do Not Modify the Monitor or Radar Sensor
Section 10 - Safety Signs
Safety Signs
Section 15 - Attaching and Detaching
Attaching and Detaching Monitor
Section 20 - COMPUTER TRAK™ 150 Monitor
COMPUTER TRAK™ 150 Row Configuration For 4, 6, and 8 Row Monitor
COMPUTER TRAK™ 150 Row Configuration For 10 and 12 Row Monitor
Switches
Tuning Alarm Point
Row Elimination
Section 25 - COMPUTER TRAK 350/450 Monitor Setup
Monitor Display Representation
Preparing Monitors
Turning Console On
English/Metric Selection
Distance Calibration
Speed Set Mode
Row Spacing
Number of Rows
Turning Rows On/Off
Implement Width
Setting High Population Limit
Setting Low Population Limit
Area Counters 1 and 2
Split On/Off
PA (Population Adjust)
PA Chart — Small Soybeans — 8972 seeds/kg (4070 seeds/lb)
PA Chart — Large Soybeans — 4564 seeds/kg (2070 seeds/lb)
F-AVG (Fast Average)
Resetting Constants
Section 30 - Operating COMPUTER TRAK™ 350/450 Monitor
Powering Monitor On
Monitoring Population and Seed Spacing
Area/Speed
Seed Counter Mode
Distance Counter Mode
Row Failed Messages
Distance Failed Message
Display During Transporting or Turning Around
High or Low Population Warnings
Point Row Planting
Seed Spacing
Monitor History (Planter Mode)
Section 35 - Troubleshooting
Monitors
Section 40 - Service
Monitor Fuse
Lamps
Regular, Regular Straight, Small Straight and Large Seed Tubes (MaxEmerge™ Plus Row Units)
Sugar Beet Seed Tube (Plate Meter)
Clean Seed Tube Sensor
Section 45 - Monitor and Radar Installation
Assemble COMPUTER TRAK™
30-55 Series Utility Tractors—Console Installation
30—55 Series Utility Tractor—Radar and Bracket Installation
30-60 Series Row Crop Tractors (with Cab)—Console Installation
30—60 Series Open Station Tractors—Console Installation
Install Radar Signal Adapter Harness—30 and 60 Series Tractors
30-60 Series Row Crop Tractors—Radar and Bracket Installation
30-50 Series Four-Wheel Drive Tractors—Radar and Bracket Installation
60-70 Series Four-Wheel Drive Tractors—Console Installation
Install Radar Signal Adapter Harness—60 and 70 Series Tractors
Modification and Installation of Radar Bracket (60 Series Four-Wheel Drive Tractors)
Modification and Installation of Radar Bracket (70 Series Four-Wheel Drive Tractors)
6000 Series Tractors—Console Installation
6000 Series Tractors with Exhaust Attached to Cab—Radar and Bracket Installation
6000 Series Tractors with Exhaust on Hood—Radar and Bracket Installation
7000 Series Tractors—Console Installation
Install Radar Signal Adapter Harness 7000 Series Tractors Produced Prior to January 1993
Install Radar Signal Adapter Harness—7000 Series Tractors Produced After January 1993
7000 Series Tractors—Radar and Bracket Installation
8000 Series Tractors—Console Installation
Install Radar Signal Adapter Harness—8000 and 8000T Series Tractor
8000 Series Tractors—Radar and Bracket Installation
Install Radar—8000T Series Tractors
9000 and 9000T Series Tractors—Console Installation
Install Radar Signal Adapter Harness—9000 and 9000T Series Tractor
9000 and 9000T Series Tractor—Radar and Bracket Installation
Section 50 - Seed Sensors
Installing Monitor Sensors—455, 1520, and 1530
Install Monitor Sensors—1560, 1590
Installing Seed Sensors—CCS Machines
Install Seed Tubes—MAXEMERGE™ Plus Row Units
Install Seed Tubes—PRO-SERIES™ Row Units
Section 55 - Specifications
Specifications
Record Monitor Serial Number
The EC Declaration of Conformity applies only to machines which bear the CE mark.
Keep Proof of Ownership
Keep Machines Secure
Section IBC - John Deere Service Keeps You on the Job
John Deere Is At Your Service
Format: HTML
Brand: John Deere
Foreword
To the Dealer
Section 05 - Safety
Safety Signs
Switches
Tuning Alarm Point
Row Elimination
Preparing Monitors
Turning Console On
Speed Set Mode
Row Spacing
Number of Rows
Turning Rows On/Off
Implement Width
Split On/Off
Resetting Constants
Powering Monitor On
Area/Speed
Seed Counter Mode
Row Failed Messages
Point Row Planting
Seed Spacing
Monitors
Monitor Fuse
Lamps
Specifications
- JOHN DEERE CODE DTC LIST
