John Deere Compact Utility Tractors 870 970 1070 Operators Manual OMM95327
Brand: John Deere
Type of Machine: Compact Utility Tractors
Model: John Deere 870 970 1070 Compact Utility Tractors
Part Number: OMM95327
Number of Pages: 140 Pages
Safety
Controls
Operating Engine
Before Starting Engine
Starting Engine
Cold Weather Starting
Jump-Starting Engine
Observing Engine Work And Idle Speeds
Determining Correct Pto Speeds
Changing Engine Speeds
Warming Engine
Idling Engine
Restart Stalled Engine
Stopping Engine
Driving Machine
Operator Training Required
Operating On Slopes And Rough Terrain
Adjusting Seat
Seat Weight Adjustment
Using Seat Belt
Selecting Light Switch Positions
Using Park Brake
Using Turn Brake Pedals
Operating Transmission
Selecting A Gear
Determining Travel Speed
Using Differential Lock
Operating Optional Front-Wheel Drive
Using Power-Take-Off (Pto)
Using Stationary Rear Pto
Operating Mid Power-Take-Off Pto
Warming Hydraulic System Oil
Using Optional (Scv) Selective Control
Valve
Connecting Attachment Hydraulic Cylinder
Hoses
Using Drawbar Hitch
Page
Using 3-Point Hitch
Adjusting Sway Links
Using Draft Sensing Control (1070)
Using Draft Sensing Lockout
Positioning Upper Link (1070)
Adjusting Rockshaft Feedback Linkage
(1070)
Lever Neutral Adjust Procedure
Adjusting Draft Control Neutral Position
Using Speed Of Drop/Lock Valve
Determining Maximum Rear Ballast
Using Optional Rear Cast Iron Wheel
Weights
Using Optional Rear Ballast Box
Using Liquid Weight In Rear Tires
Selecting Front Ballast
Using Front Weights
Using Implement Codes
Selecting Front Tire Rolling Direction
Changing Rear Tread
Selecting Rear Tread Width
Transporting Tractor
Fuels And Lubricants
Troubleshooting
Periodic Service
Break-In
Cap Screw Torque Chart
Engine Break-In
Hour Meter/Tachometer
Opening And Closing Hood
Removing And Installing Engine Shields
Tractor Break-In
10 Hours
Checking Engine Oil Level
Checking Hydraulic Oil Level
Checking Optional Air Restriction
Indicator
Checking Coolant Level
Cleaning Grille And Radiator Screen
Checking Fuel Filter Sediment Bowl
Checking Fuel/Water Separator Sediment
Bowl
Safety Interlock System Checkout
Procedurre
50 Hours
Checking Wheel Bolt Torque
Checking Optional Mfwd Oil Level
Lubricating Grease Fittings
Checking Battery Electrolyte Level
Check Tire Inflation
Lubricating Tractor Grease Fittings
200 Hours
Changing Engine Oil And Filter
Checking Fan Belt Tension
Lubricating 3-Point Hitch
Replace Fuel Filters
Cleaning Radiator Cooling Fins
400 Hours
Servicing Air Cleaner
500 Hours
Changing Hydraulic Oil And Filter
Changing Optional Mfwd Oil
Checking Engine Speeds
Tightening Hose Clamps
Every 2 Years
Draining, Flushing, And Filling Cooling
System
As Required
Replacing Thermostat
Bleeding Fuel System
Cleaning Or Replacing Battery
Adjusting Throttle
Replacing Fuses
Replacing Hood Headlight Bulb
Replacing Taillight Bulb
Page
Replacing Warning Light Bulb
Adjusting Front Axle
Adjusting Toe-In
Adjusting Brakes
Adjusting Clutch
Injection Nozzles
Storage
Crime Prevention Tips
Specifications
Index
Brand: John Deere
Safety
Controls
Operating Engine
Starting Engine
Warming Engine
Idling Engine
Stopping Engine
Driving Machine
Adjusting Seat
Using Seat Belt
Using Park Brake
Selecting A Gear
Valve
Hoses
Using Drawbar Hitch
Page
Using 3-Point Hitch
(1070)
Weights
Using Front Weights
Changing Rear Tread
Troubleshooting
Periodic Service
Break-In
Engine Break-In
Tractor Break-In
10 Hours
Indicator
Bowl
Procedurre
50 Hours
200 Hours
400 Hours
500 Hours
Every 2 Years
System
As Required
Adjusting Throttle
Replacing Fuses
Page
Adjusting Toe-In
Adjusting Brakes
Adjusting Clutch
Injection Nozzles
Storage
Specifications
Index
- JOHN DEERE CODE DTC LIST
