John Deere Compact Utility Tractors 670 770 790 870 970 1070 Technical Manual TM1470
Brand: John Deere
Type of Machine: Compact Utility Tractors
Type of Manual: Technical Manual
Model: John Deere 670 770 790 870 970 1070 Compact Utility Tractors
Part Number: TM1470
Number of Pages: 1020 Pages
SECTION 10 — GENERAL INFORMATION
Group 05 — Safety
Group 10 — General Specifications
Group 15 — Repair Specifications
Group 20 — Fuel and Lubricants
Group 25 — Serial Number Locations
SECTION 20 — ENGINE REPAIR
Group 05 — 670/770
Group 06 — 870/970/1070
Group 07 — 790
Group 10 — Cooling System
Group 15 — Throttle and Governor Control Linkage
Group 20 — Fuel System
SECTION 40 — ELECTRICAL SYSTEM
Group 05 — Alternator
Group 10 — Starter
Group 15 — Sender, Switches and Gauges
SECTION 50 — POWER TRAIN REPAIR — 670/770/790
Group 05 — Clutch Housing
Group 06 — Single Stage Clutch
Group 07 — Dual Stage Clutch
Group 10 — Transmission
Group 15 — Rear PTO Drive Shaft
Group 20 — Differential
Group 25 — Final Drive
Group 30 — Mechanical Front Wheel Drive
Group 35 — Throttle and Governor Control Linkage
Section 55 — POWER TRAIN REPAIR — 870/970/1070
Group 06 — Dual Stage Clutch
Group 30 — Mechanical Front Wheel Drive — 870
Group 35 — Mechanical Front Wheel Drive — 970/1070
Group 40 — Mid Mount PTO
SECTION 60 — STEERING AND BRAKE REPAIR
Group 05 — Manual Steering
Group 10 — Power Steering
Group 15 — Brake Repair — 670/770/790
Group 20 — Brake Repair — 870/970/1070
SECTION 70 — HYDRAULIC REPAIR
Group 05 — Hydraulic Pump and Filter
Group 10 — Rockshaft — 670/770/790
Group 11 — Rockshaft — 870/970/1070
Group 15 — Selective Control Valve
Group 20 — Rear Auxiliary Hydraulic Lines
SECTION 80 — MISCELLANEOUS REPAIR
Group 05 — Wheels
Group 10 — Front Axle
Group 15 — Hood
Group 20 — 3-Point Hitch
Group 25 — Seat and Support
Group 30 — Roll-Gard
Group 35 — Mower Spindles
Group 40 — Mower Gearbox
SECTION 210 — OPERATIONAL CHECKOUT PROCEDURE AND SPECIFICATIONS
Group 05 — Test and Adjustment Specifications
Group 10 — Operational Checkout Procedures
SECTION 220 — ENGINE OPERATION, TESTS, AND ADJUSTMENTS
Group 05 — Component Locations
Group 10 — Theory of Operation
Group 15 — Engine System Diagnosis
SECTION 240 — ELECTRICAL SYSTEM OPERATION AND TESTS
Group 15 — Diagnosis and Test
Group 20 — Schematic
SECTION 250 — POWER TRAIN — 670/770/790
SECTION 255 — POWER TRAIN — 870/970/1070
SECTION 260 — STEERING AND BRAKES
SECTION 270 — HYDRAULIC SYSTEM
Brand: John Deere
Part Number: TM1470
Group 05 — Safety
Group 05 — 670/770
Group 07 — 790
Group 10 — Starter
Group 05 — Wheels
Group 15 — Hood
- JOHN DEERE CODE DTC LIST
