John Deere Compact Utility Tractors 4120 4320 4520 4720 Technical Manual TM2137
Brand: John Deere
Type of Machine: Compact Utility Tractors
Type of Manual: Technical Manual
Model: John Deere 4120 4320 4520 4720 Compact Utility Tractors
Part Number: TM2137
Number of Pages: 1759 Pages
tm2137 - Compact Utility Tractors 4120 PIN (120101-610000), 4320 PIN (130101-620000), 4520 PIN (150101-650000), 4720 PIN (170101-670000) (Without Cab)
Table of Contents
Manual Description
Section : Safety
Section : Specifications & Information
Section : Engine - Diesel
Section : Electrical
Section : Electrical - European
Section : Power Train - PRT
Section : Power Train - Hydrostatic
Section : Power Train - Final Drive
Section : Hydraulics
Section : Steering
Section : Brakes
Section : Miscellaneous
Manual Description
Recognize Safety Information
Understand Signal Words
Replace Safety Signs
Handle Fluids Safely - Avoid Fires
Be Prepared For Emergencies
Use Care In Handling and Servicing Batteries
Prevent Battery Explosions
Prevent Acid Burns
Avoid acid burns by:
If you spill acid on yourself:
If acid is swallowed:
Wear Protective Clothing
Use Care Around High-pressure Fluid Lines
Avoid High-Pressure Fluids
Service Machines Safely
Use Proper Tools
Park Machine Safely
Before working on the machine:
Support Machine Properly and Use Proper Lifting Equipment
Work In Clean Area
Before starting a job:
Using High Pressure Washers
Illuminate Work Area Safely
Work In Ventilated Area
Warning: California Proposition 65 Warning
Avoid Harmful Asbestos Dust
Service Tires Safely
Avoid Injury From Rotating Blades, Augers and PTO Shafts
Service Cooling System Safely
Dispose Of Waste Properly
Live With Safety
Metric Fastener Torque Values
Metric Fastener Torque Values—Grade 7
Inch Fastener Torque Values
Gasket Sealant Application
Cleaning:
How to Dispense/Apply/Assemble Gasket Sealants:
Disassembly:
Face Seal Fittings with Inch Stud Ends Torque
Face Seal Fittings with Metric Stud Ends Torque
O-Ring Face Seal Fittings
O-Ring Boss Fittings
Diesel Fuel Specifications
Diesel Fuel Lubricity
Diesel Fuel Storage
Engine Oil
Engine Break–in Oil
Alternative Lubricants
Synthetic Lubricants
Lubricant Storage
Mixing Of Lubricants
Chassis Grease
Transaxle Oil
Engine Coolant
Engine Coolant
Engine Coolant Drain Interval
Machine Product Identification Number
Engine and Turbocharger Serial Numbers
Engine Specifications
Cylinder Head and Valves Specifications
Cylinder Block, Pistons, and Rods Specifications
Crankshaft, Main Bearings, and Flywheel Specifications
Camshaft, Balancer Shafts and Timing Gear Train Specifications
Lubrication System Specifications
Cooling System Specifications
Air Intake and Exhaust System Specifications
Starting and Charging Systems Specifications
Fuel System
Engine Mounting Specifications
Engine Rebuild Essential Tools
Engine Rebuild Service Equipment and Tools
Cylinder Head and Valves Essential Tools
Cylinder Head and Valves Other Materials
Cylinder Block, Pistons, and Rods Essential Tools
Crankshaft, Main Bearings and Flywheel Essential Tools
Crankshaft, Main Bearings and Flywheel Service Equipment and Tools
Crankshaft, Main Bearings and Flywheel Other Materials
Camshaft and Timing Gear Train Essential Tools
Lubrication System Essential Tools
Base Engine Diagnostic Tools
Fuel System Observable Diagnostic Tools
General Engine Operation
Lubrication System Operation
Coolant System Operation
Air Intake and Exhaust System Operation
Air Cleaner Operation
Turbocharger Operation
Turbocharger Lubrication
Fuel System Operation
Fuel Supply Pump
Fuel Filter/Water Separator Operation
Governor Operation
Integrated Fuel System (IFS) Operation
Light Load and Speed Advance Operation
Cold Start Advance Operation
Glow Plug Cold Start Aid Operation
About This Group of the Manual
Guideline for Acceptable Oil Consumption
L1 - Excessive Oil Consumption
Pistons, Rings, Cylinder Bore Check
L2 - Engine Oil Pressure Low
L3 - Engine Oil Pressure High
C1 - Coolant Temperature Above Normal
C2 - Coolant Temperature Below Normal
C3 - Coolant in Oil or Oil in Coolant
E1 - Engine Cranks/Won’t Start
E1 - Preliminary Check
E2 - Engine Misfires/Runs Irregularly
E2 - Preliminary Check
Piston Ring Check
E3 - Engine Does Not Develop Full Power
E3 - Preliminary Check
E4 - Excessive White Exhaust Smoke
E4 - Preliminary Check
E5 - Excessive Black Or Gray Exhaust Smoke
E5 - Preliminary Check
E6 - Engine Will Not Crank
E7 - Engine Idles Poorly
E7 - Preliminary Check
E8 - Abnormal Engine Noise
F1 - Fuel Supply System Check
Fuel Transfer Pump Check
Return Fuel Check
F2 - Excessive Fuel Consumption
F3 - Fuel in Oil
Test Engine Compression Pressure
Compression Test
Compression Test
Test Engine Cranking Speed
Dynamometer Test
Engine Oil Consumption
Check Engine Oil Pressure
Check for Excessive Engine Crankcase Pressure (Blow-By)
Check for Turbocharger Oil Seal Leak
Inspect Thermostat and Test Opening Temperature
Pressure Test Cooling System and Radiator Cap
Test Radiator Cap:
Test Cooling System:
Check for Head Gasket Failures
Check and Service Cooling System
Check Air Intake System
Measure Intake Manifold Pressure (Turbocharger Boost)
Check for Intake and Exhaust Restrictions
Test for Intake Air Leaks
Check for Exhaust Air Leaks (Turbocharger)
Glow Plug Operation
Cylinder Misfire Test
Check Fuel Supply Quality
Test for Fuel Drain Back
Test Air in Fuel
Bleed Fuel System
Measure Fuel Transfer Pump Pressure
Bench Test Fuel Transfer Pump
Vacuum/Pressure Test
Leakage Test
Check Cold Start Advance Operation
Check Fuel Shut-Off Solenoid Operation
Check and Adjust Fast Idle Speed
Check and Adjust Slow Idle Speed
Engine Removal and Installation
Special or Required Tools:
Prepare the Machine:
Remove Engine:
Installation and Assembly:
Remove Engine:
Engine Disassembly Sequence
Engine Assembly Sequence
Engine Break-In Guidelines
Perform Engine Break-In
Cylinder Head - Exploded View
Remove Rocker Arm Cover
Remove Cylinder Head
Disassemble and Inspect Rocker Arm Assembly
Inspect, Remove, and Install Glow Plugs and Wire Harness
Measure Valve Recess in Cylinder Head
Preliminary Cylinder Head and Valve Checks
Remove Valve Assembly
Inspect and Measure Valve Springs
Clean Valves
Inspect and Measure Valves
Grind Valves
Head Gasket Inspection and Repair Sequence
Inspect and Clean Cylinder Head
Check Cylinder Head Flatness
Knurl Valve Guides
Clean and Inspect Valve Seats
Grind Valve Seats
Install Valves
Inspect and Clean Exhaust Manifold
Install Cylinder Head
Install Rocker Arm Assembly
Connecting Rods - General Information
Preliminary Cylinder Block, Pistons, and Rod Checks
Scuffed or Scored Pistons:
Worn or Broken Compression Rings:
Clogged Oil Control Ring:
Stuck Rings:
Mottled, Grayish or Pitted Compression Rings:
Dull Satin Finish and Fine Vertical Scratches on Rings:
Piston Pin and Snap Ring Failure:
Broken Connecting Rod:
Cylinder Wear and Distortion:
Warped Cylinder Block:
Remove Pistons and Connecting Rod Assembly
Disassemble Piston and Rod Assembly
Clean Pistons
Visually Inspect Pistons
Check Piston Ring Groove Wear
Measure Piston Pin Bore
Measure Piston Skirt
Determine Piston-to-Cylinder Bore Clearance
Deglaze Cylinder Bores
Inspect and Measure Connecting Rod Bearings (Rods Removed from Engine)
Inspect and Measure Connecting Rod Bearings (Rod & Crankshaft in Engine)
Inspect Rod and Cap
Inspect Piston Pins and Bushings
Measure Rod Center-to-Center Bores
Inspect and Clean Cylinder Block
Measure Cylinder Block Main Bearing Bore
Measure Camshaft Follower Machined Bore
Measure Camshaft Bushing Bores in Block
Inspect and Measure Cylinder Bore
Measure Cylinder Block Top Deck Flatness
Remove, Inspect, and Install Piston Cooling Orifices
Assemble Piston and Connecting Rod
Install Piston Rings
Install Piston and Connecting Rod Assembly
Torque-Turn Connecting Rod Cap Screws
Using Engine Axis Method to Torque-Turn Connecting Rod Cap Screws:
Using JT05993 Torque Angle Gauge to Torque-Turn Connecting Rod Cap Screws:
Check Engine Rotation for Excessive Tightness
Measure Piston Protrusion
Complete Final Assembly
Crankshaft and Main Bearing Failure Analysis
Remove Crankshaft Pulley
Inspect Pulley and Wear Sleeve
Replace Front Crankshaft Oil Seal (Without Removing Timing Gear Cover)
Remove Front Crankshaft Oil Seal
Install Front Crankshaft Oil Seal
Install Crankshaft Pulley
Check Crankshaft End Play
Check Flywheel Face Flatness
Check Pilot Bearing Bore Concentricity
Remove Flywheel
Replace Flywheel Ring Gear
Remove Flywheel Housing
Remove Crankshaft Rear Oil Seal and Housing
Remove Rear Oil Seal Using JDG698A
Remove Rear Oil Seal Housing
Clean and Inspect Crankshaft Flange
Install Crankshaft Rear Oil Seal Housing
Handling Rear Oil Seal
Oil Seal Installation
Remove Crankshaft Main Bearings
Check Main Bearing Oil Clearance
Remove Crankshaft
Inspect Crankshaft
Measure Crankshaft Journals and Main Bearing ID
Measure Main Thrust Journal Width and Thrust Washers
Measure Assembled ID of Main Bearing Caps
Install Main Bearings, Thrust Washers and Crankshaft
Install Flywheel Housing
Install Flywheel
Remove Timing Gear Cover
Remove Balancer Shafts
Inspect and Measure Balancer Shaft Bushings and Journals
Inspect Balancer Shaft Gears and Thrust Plates
Remove, Inspect and Install Balancer Idler Gears and Shafts
Measure Idler Gear Bushing and Shaft
Remove Balancer Bushings
Install Balancer Bushings
Install Balancer Shafts
Remove Governor Assembly and Camshaft Drive Gear
Remove Camshaft
Visually Inspect Camshaft
Inspect and Measure Camshaft Bushing ID and Journal OD
Remove and Install Camshaft Bushings
Remove Camshaft Bushings
Measure Camshaft Lobe Height
Inspect Camshaft Followers
Install Camshaft
Install and Time Camshaft Drive Gear
Install Governor Assembly
Clean and Inspect Timing Gear Cover
Install Timing Gear Cover
General Lubrication System Information
Remove Oil Cooler
Install Oil Cooler
Remove and Install Oil Pan
Remove and Install Oil Pressure Regulating Valve
Remove, Inspect, and Install Oil Pick-up Tube Assembly
Remove, Inspect and Install Oil Pump
Removal
Installation
Remove and Install Oil Dipstick Tube with Oil Pan Installed
Remove and Install Thermostat
To Remove Thermostat
To Install Thermostat
Test Thermostat
Testing Thermostats Opening Temperature
Replacing Fan and Alternator Belt
Remove and Install Automatic (Spring) Belt Tensioner
Checking Belt Tensioner Spring Tension and Belt Wear (Automatic Tensioner)
Checking Belt Wear:
Checking Tensioner Spring Tension
Remove Coolant Pump
Inspect and Clean Coolant Pump Parts
Install Coolant Pump
Cooling System Deaeration
Inspect and Install Fan Assembly
Remove Fan Bearing
Install Fan Bearing
Extending Turbocharger Life
Lack of Lube Oil
Oil Contamination
Ingestion of Foreign Objects
Restricted Oil Drainage
Abnormally High Exhaust Temperatures
Lack of Lube Oil
Oil Contamination
Remove Turbocharger
Turbocharger Failure Analysis
Turbocharger Inspection
Compressor Housing Inlet and Compressor Wheel
Compressor Housing Outlet
Turbine Housing Inlet
Turbine Housing Outlet and Turbine Wheel
External Center Housing and Joints
Perform Axial Bearing End Play Test
Repair Turbocharger
Prelube Turbocharger
Install Turbocharger
Remove, Inspect, and Install Exhaust Manifold
Remove, Inspect, and Install Intake Manifold
Remove and Install Fuel Supply Pump
Remove and Inspect Integrated Fuel System (IFS)
Install Integrated Fuel System (IFS)
Remove and Install Fuel Rail Check Valve
Remove and Install Governor Lever Assembly
Remove Governor Lever Assembly
Remove and Install Throttle Control Assembly
Remove Throttle Assembly
Install Throttle Assembly
Throttle Assembly Adjustments
Remove and Install Full Load Stop Screw
Remove Full Load Stop Screw
Remove and Install Idle Bias Adjustment Screw
Remove and Install Fuel Shut-Off Solenoid
Remove and Install Aneroid
Remove and Install Starter
Remove and Install Alternator
Reading Electrical Schematics
Theory Of Operation Information
Diagnostic Information
Wire Color Abbreviation Chart
Common Circuit Tests
Shorted Circuit:
High Resistance or Open Circuit:
Grounded Circuit:
Conductors For 12 Volt Circuits
Tools
Other Materials
Main Machine
Main Machine
Load Center
Display Panel
Main Schematic and Wiring Harness Legend - PRT and eHydro
Connectors:
Wiring Harnesses:
Connectors:
Wiring Harnesses:
eHydro - Schematic and Wiring Harness Legend
Connectors:
Wiring Harnesses:
W1 Main Electrical Schematic
W1 Main Electrical Schematic (2 of 3)
W1 Main Electrical Schematic (3 of 3)
W9 eHydro and Cruise Control Electrical Schematic (1 of 2)
W9 eHydro and Cruise Control Electrical Schematic (2 of 2)
W1 Main Wiring Harness
W1 Main Wiring Harness Color Codes
W2 Headlight Wiring Harness
W2 Headlight Wiring Harness Color Codes
W3 and W4 Jumper Plug
W7 Right Rear Lights Wiring Harness
W7 Right Rear Lights Wiring Harness Color Codes
W8 Left Rear Lights Wiring Harness
W8 Left Rear Lights Wiring Harness Color Codes
W9 eHydro Wiring Harness
W9 eHydro Wiring Harness Color Codes
W10 Proportional Valve Wiring Harness
W10 Proportional Valve Wiring Harness Color Codes
W11 Cruise Control Wiring Harness (standard)
W11 eHydro Cruise Control Wiring Harness Color Codes (standard)
W12 Cruise Control Wiring Harness (optional)
W12 eHydro Cruise Control Wiring Harness Color Codes (optional)
Display Panel Fault Codes
Purpose:
Operation:
Purpose:
Operation:
Display Panel Fault Code Chart
Power Circuit Operation
Function:
Unswitched Power:
Switched Power:
Switched Power - eHydro specific Circuits:
Secondary Switched Power:
Secondary Switched Power - eHydro specific Circuits:
Function:
Unswitched Power:
Switched Power:
Power Circuit Electrical Schematic - W1 PRT and eHydro
Power Circuit Electrical Schematic - W9 eHydro
Power Circuit Diagnosis
Test Procedure A:
Test Procedure B:
Test Procedure C:
Cranking Circuit Operation
Function:
Operating Conditions:
Theory of Operation:
Cranking Circuit Electrical Schematic
Cranking Circuit Diagnosis
Test Conditions:
Glow Plug and Light Circuit Operation
Function:
Glow Plug and Light Circuit Electrical Schematic
Glow Plug and Light Circuit Diagnosis
Test Conditions:
Fuel Supply/Engine Shutoff Circuit Operation
Function:
Operating Conditions (Cranking):
Operating Conditions (Engine on, Operator ON Seat):
Operating Conditions (Engine On, Operator OFF Seat):
Operating Conditions (Engine On, Operator OFF Seat, Rear PTO Engaged):
Engine MUST STOP when:
Theory of Operation - Fuel Supply Logic:
Theory of Operation - Engine Shutoff:
Engine on, Operator ON Seat Logic:
Engine On, Operator OFF Seat Logic:
Engine On, Operator OFF Seat, Rear PTO Engaged Logic (Off Seat PTO Logic):
Fuel Supply/Engine Shutoff Circuit Electrical Schematic
Fuel Supply/Engine Shutoff Circuit Diagnosis
Test Procedure A:
Test Procedure B:
Charging Circuit Operation
Function:
Tachometer Circuit Operation
Function:
Hour Meter Circuit Operation
Function:
Charging, Tachometer and Hour Meter Circuit Electrical Schematic
Charging, Tachometer and Hour Meter Circuit Diagnosis
Test Conditions:
Rear PTO Circuit Operation
Function:
Rear PTO Circuit Electrical Schematic
Rear PTO Circuit Diagnosis
Test Conditions:
MFWD Circuit Operation
Function:
MFWD Circuit Electrical Schematic
MFWD Circuit Diagnosis
Test Conditions:
Function:
Light Switch Hazard Position:
Light Switch Road Position:
Light Switch Field Position:
Lights Circuit Electrical Schematic
Lights Circuit Diagnosis
Test Procedure A:
Test Procedure B:
Test Procedure C:
Turn Signal Lights Circuit Operation
Turn Signal Switch Function:
Operating Condition:
Turn Signal Switch Left Position:
Turn Signal Switch Right Position:
Turn Signal Lights Circuit Electrical Schematic
Turn Signal Lights Circuit Diagnosis
Test Procedure A:
Test Procedure B:
Display Panel Operation
Function:
Inputs:
Outputs:
Ground:
eHydro Communication:
Display Panel Diagnosis
Display Mode Switch Circuit Operation
Function:
Display Mode Switch Circuit Electrical Schematic
Display Mode Switch Circuit Diagnosis
Test Conditions:
eHydro - eMatchOS Electronic Drive Controller
Function:
General Theory:
Cruise Control - Standard:
Cruise Control - Optional:
Max Speed:
Motion Match Switch:
Load Match Switch:
Drive Controller Inputs and Outputs
eHydro - Forward Drive Circuit Operation
Function:
eHydro - Forward Drive Circuit Electrical Schematic
eHydro - Forward Drive Circuit Diagnosis
Test Conditions:
eHydro - Reverse Drive Circuit Operation
Function:
eHydro - Reverse Drive Circuit Electrical Schematic
eHydro - Reverse Drive Circuit Diagnosis
Test Conditions:
eHydro - Cruise Control Circuit Operation (standard)
Function:
eHydro - Cruise Control Circuit Electrical Schematic (standard)
eHydro - Cruise Control Circuit Diagnosis (standard)
Test Conditions:
eHydro - Cruise Control Circuit Operation (optional)
Function:
eHydro - Cruise Control Circuit Electrical Schematic (optional)
eHydro - Cruise Control Circuit Diagnosis (optional)
Test Conditions:
eHydro - Load Match and Motion Match Circuit Operation
Function, Load Match:
Operating Conditions, Load Match:
Theory of Operation, Load Match:
Function, Motion Match:
Operating Conditions, Motion Match:
Theory of Operation, Motion Match:
eHydro - Load Match and Motion Match Circuit Electrical Schematic
eHydro - Load Match and Motion Match Control Circuit Diagnosis
Diagnosis - Load Match:
Diagnosis - Motion Match:
Ground Circuit Test
Reason:
Equipment:
Ohmmeter Procedure:
Voltmeter Procedure:
Results:
Ground Circuit Test
Reason:
Equipment:
Ohmmeter Procedure:
Results:
Battery Voltage and Specific Gravity Test
Reason:
Equipment:
Procedure:
Results:
Battery - Charge
Reason:
Equipment:
Procedure:
Battery - Load Test
Reason:
Equipment:
1/2 CCA Load Test Procedure:
Results:
Alternator Regulated Voltage Test
Reason:
Equipment:
Procedure:
Results:
Alternator Test and Inspection
Inspection:
Regulated Amperage and Voltage Test
Reason:
Equipment:
Procedure:
Results:
Starting Motor Solenoid Test
Reason:
Equipment:
Procedure:
Results:
Results:
Starting Motor Amperage Draw Test
Reason:
Equipment:
Procedure:
Results:
Starting Motor No-Load Amperage Draw and RPM Test
Reason:
Equipment:
Procedure:
Results:
Fuse Test
Reason:
Equipment:
Procedure:
Results:
Glow Plug Test
Reason:
Equipment:
Procedure:
Results:
Procedure:
Results:
Engine Coolant Temperature Sensor Test
Reason:
Equipment:
Procedure:
Engine Oil Pressure Switch Test
Reason:
Equipment:
Procedure:
Results:
Results:
Relay Test
Results:
Equipment:
Procedure:
Results:
Results:
Key Switch Test
Reason:
Equipment:
Procedure:
Results:
Light Switch Test
Reason:
Equipment:
Procedure:
Results:
Sensing Switch Test
Reason:
Equipment:
Procedure:
Turn Signal Switch Test
Reason:
Equipment:
Procedure:
Results:
Hazard Switch Test
Reason:
Equipment:
Procedure:
Results:
Rear PTO Switch Test
Reason:
Equipment:
Procedure:
Results:
Rear PTO Solenoid Test
Reason:
Equipment:
Procedure:
Results:
Seat Switch Test
Reason:
Equipment:
Procedure:
Results:
Cruise/Max Speed Switch Test - eHydro
Reason:
Equipment:
Procedure:
Results:
Res/+, Set/- Switch Test - eHydro
Reason:
Equipment:
Procedure:
Results:
Brake and Park Brake Switch Test
Reason:
Equipment:
Test Procedure:
Results:
Air Filter Restriction Switch Test
Reason:
Equipment:
Procedure:
Results:
Fuel Gauge Sensor Test
Reason:
Equipment:
Test Procedure:
Results:
Fuel Shutoff Solenoid Test
Reason:
Equipment:
Procedure:
Results:
Load Match Switch Test - eHydro
Reason:
Equipment:
Procedure:
Results:
Motion Match Switch Test - eHydro
Reason:
Equipment:
Procedure:
Results:
Display Mode Switch Test
Reason:
Equipment:
Procedure:
Results:
Proportional Drive Solenoid Test - eHydro
Reason:
Equipment:
Procedure:
Horn Switch Test
Reason:
Equipment:
Procedure:
Results:
Configure the Display
Reason:
Equipment:
Procedure:
Editing Tire Size Value
Reason:
Equipment:
Procedure:
Editing Motion Match Settings - eHydro
Option 1 (without switch):
Option 2 (with switch):
Editing Load Match Settings - eHydro
Entering Diagnostic and Calibration Modes
Diagnostic Mode 1:
Diagnostic Mode 2 (eHydro only):
Diagnostic Mode 3 - System Calibration (eHydro only):
eHydro - Electronic Drive Controller System Calibration
Reason:
Test Conditions:
Procedure:
eHydro - Single Sensor Calibration
Reason:
Test Conditions:
Procedure:
Test Kit
Function:
Equipment:
Theory:
eHydro - Throttle Position Sensor Test and Adjustment
Purpose:
Procedure - Diagnostic Mode 2:
Procedure - Test Kit:
Throttle Sensor Adjustment:
eHydro - Forward and Reverse Pedal Sensor Test and Adjustment
Purpose:
Drive Pedal Sensor Adjustment:
eHydro - MFWD Speed Sensor Test
Purpose:
Throttle Position Sensor Removal and Installation
Removal:
Installation:
Removal:
Installation:
Electronic Drive Controller Removal and Installation
Removal:
Installation:
Alternator Removal and Installation
Removal:
Installation:
Alternator Disassembly and Assembly
Disassembly:
Assembly:
Fuel Gauge Sensor Removal and Installation
Removal:
Installation:
Tools
Other Materials
Main Machine
Main Machine
Load Center
Display Panel
Connectors:
Wiring Harnesses:
Connectors:
Wiring Harnesses:
Connectors:
Wiring Harnesses:
W1 Main Electrical Schematic (1 of 4)
W1 Main Electrical Schematic (2 of 4)
W1 Main Electrical Schematic (3 of 4)
W1 Main Electrical Schematic (4 of 4)
W2 Headlight/Horn Wiring Harness
W2 Headlight/Horn Wiring Harness Color Codes
W7 Left Rear Lights Wiring Harness
W7 Left Rear Lights Wiring Harness Color Codes
W8 Right Rear Lights Wiring Harness
W8 Right Rear Lights Wiring Harness Color Codes
Purpose:
Operation:
Purpose:
Operation:
Function:
Unswitched Power:
Switched Power:
Function:
Unswitched Power:
Switched Power:
Test Procedure A:
Test Procedure B:
Test Procedure C:
Function:
Test Conditions:
Function:
Test Conditions:
Function:
Test Procedure A:
Test Procedure B:
Charge Circuit Operation
Function:
Function:
Function:
Charge, Tachometer and Hour Meter Circuit Electrical Schematic
Charge, Tachometer and Hour Meter Circuit Diagnosis
Test Conditions:
Function:
Test Conditions:
Function:
Test Conditions:
Function:
Brake Lights Operation
Function:
Test Procedure A:
Test Procedure B:
Test Procedure C:
Hazard Lights Circuit Operation
Function:
Hazard Lights Circuit Electrical Schematic
Hazard Lights Circuit Diagnosis
Test Conditions:
Turn Signal Circuit Electrical Schematic
Test Procedure A:
Test Procedure B:
Function:
Inputs:
Outputs:
Ground:
Function:
Test Conditions:
Function:
General Theory:
Max Speed:
Load Match Switch:
Function:
Test Conditions:
Function:
Test Conditions:
Function:
Test Conditions:
Function:
Test Conditions:
General Specifications
Repair Specifications
PowrReverser Hydraulic Clutch:
Torque Specifications
PowrReverser Valve Block
Special or Essential Tools
Other Materials
Clutch Housing
Clutch Housing
PowrReverser Clutch
Main Shaft
Driven Shaft
Main Gear Shift
PRT Pedal and Shift Linkage
PRT Valve
PRT Control ValveOperation
Lever In Neutral, Clutch Pedal Up
Lever In Forward, Clutch Pedal Down
Lever In Forward, Clutch Pedal Up
Lever In Reverse, Clutch Pedal Up
PRT Clutch Operation - Forward
Function:
PRT Clutch Operation - Reverse
Function:
4 Speed Transmission Operation
Function:
Range Transmission Power Flow
Function:
PRT ClutchAdjustment
Reason:
Procedure:
Reason:
Procedure:
PRT Hydraulic Pressure Tests
Reason:
Procedure (Forward and Reverse Pressure):
Results:
Procedure (Lubrication Pressure):
Results:
Machine Splitting(Front)
Split the Machine:
Assemble Machine Sections:
Split the Machine:
Machine Splitting(Rear)
Procedure:
Split the Machine:
Reverse Case SealReplacement
Procedure:
PowrReverser TractionClutch
Removal:
TractionClutch Idler Gear Removal:
Traction Clutch Disassembly:
Transfer Shaft Disassembly:
Installation:
PowrReverser Clutch Valve
Removal:
Disassembly:
Installation:
4-Speed Transmission
Removal and Disassembly:
Transmission Top Shaft Removal:
Fork Shaft Detent Inspection:
Mid Shaft Disassembly, Inspect and Assembly:
Gear Shaft Disassembly and Inspection:
Synchromesh Gear Disassembly, Inspection and Reassembly:
4-Speed Transmission Assembly / Installation:
Hydrostatic Power Train Specifications
Other Materials
eHydro Machines Component Location
eHydro Transmission Components
eHydro Center Plate Components
Drive Shaft
Front Drive
Steering/Charge Pump Circuit Schematic, eHydro Transmission
Steering/Charge Pump Schematics, eHydro
eHydro Transmission Operation
Function:
Principles of Operation:
Charge Pump
Hydrostatic Pump
Hydrostatic Motor
Function:
Charge Pump
Hydrostatic Pump
Hydrostatic Motor
Function:
Troubleshooting Table
Hydrostatic High Pressure Relief Test
Reason:
Equipment:
Procedure:
Specifications:
Results:
Reason:
Equipment:
Procedure:
Specifications:
Results:
Charge Pump Pressure Test
Reason:
Equipment:
Procedure:
Results:
Hydraulic System Bleed Procedure
Reason:
Procedure:
Forward and Reverse Position Sensors
Removal:
Installation:
Removal:
Installation:
Forward and Reverse Pedals Assembly
Disassembly:
Assembly:
Forward and Reverse Pedals Components Explode
Machine Splitting (Front)
Split the Machine:
Machine Splitting (Rear)
Split the Machine:
Hydrostatic Transmission Removal and Installation
Special or Essential Tools:
Removal:
Installation:
Hydrostatic Transmission Disassembly
Disassembly:
Front Seal Replacement:
Transaxle Oil:
Capacity:
PTO Speeds (At 2396 Engine rpm):
MFWD Oil:
Transaxle Oil:
Capacity:
MFWD Oil:
Transaxle Oil:
Capacity:
MFWD Oil:
PTO Clutch/Brake Specifications:
Pinion and Ring Gear Specifications:
Front Wheel Alignment:
Steering Angle:
Front Axle MFWD:
Other Materials
Rear Axle and Final Drive
Differential Pinion Shaft (eHydro)
Differential Pinion Shaft (PRT)
Range Shift
Front Drive (For MFWD)
Differential Gear
Differential Lock
Brake
PTO Clutch/Brake Assembly
Rear PTO Shafts
Mid PTO Assembly
2-Speed Rear PTO
Transmission Housing (eHydro)
Transmission Housing - PRT
MFWD Front Axle Housing and Differential
MFWD Final Drive
Range Transmission
Operation:
MFWD Drive:
Range Transmission
Operation:
MFWD Drive:
MFWD Power Operation
Operation:
Differential Power Flow and Lock
Function:
Power Flow Operation:
Differential Operation:
MFWD Power Flow
PTO Diagnostics Table
Differential Pinion Shaft Adjustment
Reason:
Procedure:
Reason:
Procedure:
Differential Backlash Adjustment
Reason:
Procedure:
To Adjust Backlash:
MFWD Output Shaft
Removal:
Disassembly:
Installation:
MFWD Output Shaft
Removal:
Disassembly:
Installation:
Speed Range Transmission
Removal:
Disassembly:
Assembly:
Differential Pinion Shaft Removal & Disassembly:
Assembly:
Final Drive Removal
Left-Hand Final Drive Removal:
Right-Hand Final Drive Removal:
Final Drive Installation
Left-Hand Final Drive Installation:
Right-Hand Final Drive Installation:
Final Drive Disassembly, Inspection, and Assembly
Disassemble:
Planetary Pinions:
Assembly:
Differential Lock Fork
Removal:
Installation:
Differential Removal and Installation
Removal:
Disassembly:
Assembly:
MFWD Drive Shaft Removal and Installation
MFWD Removal and Installation
Removal:
Installation:
MFWD Final Drive Cover
Removal and Inspection:
Installation:
MFWD Spindle Shaft
Assembly and Installation:
MFWD Final Drive Housing
Disassembly:
Assembly:
Spindle Housing
MFWD Differential
Specification:
Pinion Depth Setup and Adjustment
Tools Required:
Procedure:
Determining Differential Bearing Preload:
Differential Backlash Adjustment:
Results:
PTO Clutch and Brake Theory of Operation
Function:
Theory:
Function:
Theory:
Power Transmission - Rear PTO
Function:
Theory:
Power Transmission - 2 Speed Rear PTO
Function:
Theory:
Power Transmission -Mid PTO
Function:
Theory:
Rear PTO Drive Shaft and Gears
Removal:
Installation:
Disassembly:
Assembly:
Removal:
Installation:
Disassembly:
Assembly:
2-Speed Rear PTO Drive Shaft and Gears
Removal:
Installation:
Disassembly:
Assembly:
Removal andInstallation:
Installation:
Disassembly:
Assembly:
Mid PTO
Removal:
Installation:
Assembly:
Hydraulic Specifications
Hydraulic Oil:
All Machines (Unless Noted):
Hydraulic Oil:
Hydraulic Oil:
Rockshaft Specifications:
Lift Arms:
SCV:
Rockshaft:
Other Materials
PRT Machines Component Location
Rockshaft Component Location
Dual SCV Components
Dual SCV Hydraulic Lines
Third SCV Components
Power Beyond Components
Hydraulic Pump Component Location
Rockshaft Piston, Rod, and Rate of Drop Valve
Rockshaft Control Valve, Plunger Assembly and Controls
Rockshaft and Lift Arms (Exploded View)
PTO Clutch Valve Component Location
SCV Valve Component Location
Diverter Assembly Front
Diverter 4th and 5th SCV Assembly Rear
Steering/Charge Pump Circuit Schematics, PRT Transmission
Steering System Schematics, PRT (continued)
Implement Pump Circuit Schematic, eHydro and PRT
Diverter Valve Schematic
Hydraulics (General)
Function:
Function:
Hydraulics (SCV) (Option)
Function:
Theory:
Operation:
Hydraulics (Rockshaft)
Function:
Theory:
Operation:
Diverter Valve (Option)
Function:
Theory:
Diagnostic Table
Diagnostic Table
Reason:
Procedure:
Reason:
Procedure:
Hydraulic Pump Flow Test
Reason:
Equipment:
Procedure:
Test Rockshaft/Hydraulic Pump (B) on machines without SCVs:
Machines with SCVS:
System Relief Pressure Test
Reason:
Procedure:
Machines without SCV:
Machines with SCV:
PTO Valve Pressure Test
Reason:
Equipment:
Procedure:
Hydraulic Oil Pressure Specification ±10%
Steering Pressure Check
Reason:
Equipment:
Procedure:
Specifications:
Results:
Rockshaft Lift Cycle Test
Reason:
Equipment:
Procedure:
Specifications
Results:
Rate of Drop/Stop Valve Adjustment
Reason:
Equipment:
Procedure:
Specifications:
Results:
Rockshaft Leakage Test
Reason:
Equipment:
Procedure:
Specifications
Results:
Rockshaft Position Feedback Linkage Adjustment
Reason:
Procedure:
Hydraulic Gear Pump
Gear Pump Disassembly and Inspection:
Assembly:
Hydraulic Gear Pump
Assembly:
Rockshaft Removal and Installation
Removal:
Installation:
Lift Arms
Removal:
Specifications:
Installation:
Specifications:
Lift Control Lever
Removal:
Installation:
Removal:
Installation:
Rockshaft Feedback Shaft
Removal:
Installation:
Rockshaft Piston
Removal:
Installation:
PTO Clutch Valve
Removal:
Installation:
Disassembly and Assembly:
Inspection:
Assembly:
Selective Control Valve (SCV)
Removal:
Installation:
Dual SCV Linkage Disassembly:
Dual SCV Linkage Assembly:
SCV Disassembly:
Valve Spools Assembly:
Load Check Valves:
Installation:
Relief Valve:
Steering
Steering
Steering
Steering Component Location
All Models:
All Models:
eHydro Model:
PowrReverser Model:
Steering Operation
Steering Operation
Diagnosis Table
Steering System Test
Reason:
Tools:
Procedure:
Results:
Procedure:
Results:
Reason:
Tools:
Procedure:
Results:
Procedure:
Results:
Reason:
Equipment:
Procedure:
Results:
Toe-in Adjustment MFWD
Steering Cylinder
Removal:
Installation:
Steering Cylinder
Removal:
Installation:
Steering Wheel Removal and Installation
Removal:
Installation:
Tilt Steering Mechanism Removal and Installation
Removal:
Installation:
Steering Control Unit (SCU) Removal and Installation
Removal:
Installation:
Tie Rod Removal and Installation- MFWD
Removal:
Installation:
Brakes
Brakes
Brakes
Transaxle Oil
Brake Housing
Brake Housing
Park Brake
Park Brake Components
Brake Pedals and Linkage - eHydro
Brake Pedals and Linkage - eHydro (Exploded View)
Brake Pedals and Linkage - PRT
Brake Pedals and Linkage - PRT (Exploded View)
Brakes
Brakes
Brakes
Brakes
Diagnosis
Brake Pedal Adjustment
Reason:
Tools:
Procedure:
Results:
Reason:
Tools:
Procedure:
Results:
Parking Brake Adjustment
Brake Disassembly and Inspection
Brake Actuator Inspection:
Brake Assembly
Brake Pedal Assembly Removal and Installation - eHydro
Removal:
Installation:
Brake Pedal Assembly Removal and Installation - PRT
Removal:
Installation:
Parking Brake Linkage Removal and Installation
Removal:
Installation:
Three Point Hitch Removal and Installation
Center Lift Link Removal:
Installation:
Draft Arm & Adjustable Sway Bar Removal:
Installation:
Adjustable (Right Side) and Fixed (Left Side) Lift Link Removal:
Installation:
Installation:
Installation:
Installation:
CenterLink Bracket Removal and Installation
Removal:
Installation:
Seatand Seat Support Removal and Installation
Removal:
Installation:
Seat Closeout Removal and Installation
Removal:
Installation:
Rear Fenders Removal and Installation
Removal:
Installation:
Roll Over Protection System (ROPS)
Removal:
Installation:
Front Wheel Removal and Installation
Removal:
Installation:
Rear Wheel Removal and Installation
Removal:
Installation:
Operator’s Platform Removal and Installation
Removal:
Installation:
Fuse Panel Cover Removal and Installation
Installation:
Battery Removal and Installation
Removal:
Installation:
Hood Removal and Installation
Removal:
Installation:
Cowl Panel Removal and Installation
Removal:
Installation:
ControlPanel and Removal and Installation
Removal:
Installation:
FuelTank Removal and Installation
Removal:
Installation:
Brand: John Deere
Part Number: TM2137
Table of Contents
Manual Description
Section : Safety
Section : Steering
Section : Brakes
Manual Description
Prevent Acid Burns
Use Proper Tools
Park Machine Safely
Work In Clean Area
Live With Safety
Cleaning:
Disassembly:
Diesel Fuel Storage
Engine Oil
Engine Break–in Oil
Lubricant Storage
Chassis Grease
Transaxle Oil
Engine Coolant
Engine Coolant
Fuel System
Fuel Supply Pump
Governor Operation
Piston Ring Check
Return Fuel Check
F3 - Fuel in Oil
Compression Test
Compression Test
Dynamometer Test
Test Radiator Cap:
Glow Plug Operation
Test Air in Fuel
Bleed Fuel System
Leakage Test
Remove Engine:
Remove Engine:
Clean Valves
Grind Valves
Knurl Valve Guides
Grind Valve Seats
Install Valves
Stuck Rings:
Clean Pistons
Inspect Rod and Cap
Remove Flywheel
Remove Crankshaft
Inspect Crankshaft
Install Flywheel
Remove Camshaft
Install Camshaft
Remove Oil Cooler
Install Oil Cooler
Removal
Installation
Test Thermostat
Checking Belt Wear:
Remove Coolant Pump
Remove Fan Bearing
Install Fan Bearing
Lack of Lube Oil
Oil Contamination
Lack of Lube Oil
Oil Contamination
Remove Turbocharger
Repair Turbocharger
Shorted Circuit:
Grounded Circuit:
Tools
Other Materials
Main Machine
Main Machine
Load Center
Display Panel
Connectors:
Wiring Harnesses:
Connectors:
Wiring Harnesses:
Connectors:
Wiring Harnesses:
Purpose:
Operation:
Purpose:
Operation:
Function:
Unswitched Power:
Switched Power:
Function:
Unswitched Power:
Switched Power:
Test Procedure A:
Test Procedure B:
Test Procedure C:
Function:
Test Conditions:
Function:
Test Conditions:
Function:
Test Procedure A:
Test Procedure B:
Function:
Function:
Function:
Test Conditions:
Function:
Test Conditions:
Function:
Test Conditions:
Function:
Test Procedure A:
Test Procedure B:
Test Procedure C:
Test Procedure A:
Test Procedure B:
Function:
Inputs:
Outputs:
Ground:
Function:
Test Conditions:
Function:
General Theory:
Max Speed:
Load Match Switch:
Function:
Test Conditions:
Function:
Test Conditions:
Function:
Test Conditions:
Function:
Test Conditions:
Ground Circuit Test
Reason:
Equipment:
Ohmmeter Procedure:
Results:
Ground Circuit Test
Reason:
Equipment:
Ohmmeter Procedure:
Results:
Reason:
Equipment:
Procedure:
Results:
Battery - Charge
Reason:
Equipment:
Procedure:
Battery - Load Test
Reason:
Equipment:
Results:
Reason:
Equipment:
Procedure:
Results:
Inspection:
Reason:
Equipment:
Procedure:
Results:
Reason:
Equipment:
Procedure:
Results:
Results:
Reason:
Equipment:
Procedure:
Results:
Reason:
Equipment:
Procedure:
Results:
Fuse Test
Reason:
Equipment:
Procedure:
Results:
Glow Plug Test
Reason:
Equipment:
Procedure:
Results:
Procedure:
Results:
Reason:
Equipment:
Procedure:
Reason:
Equipment:
Procedure:
Results:
Results:
Relay Test
Results:
Equipment:
Procedure:
Results:
Results:
Key Switch Test
Reason:
Equipment:
Procedure:
Results:
Light Switch Test
Reason:
Equipment:
Procedure:
Results:
Sensing Switch Test
Reason:
Equipment:
Procedure:
Reason:
Equipment:
Procedure:
Results:
Hazard Switch Test
Reason:
Equipment:
Procedure:
Results:
Reason:
Equipment:
Procedure:
Results:
Reason:
Equipment:
Procedure:
Results:
Seat Switch Test
Reason:
Equipment:
Procedure:
Results:
Reason:
Equipment:
Procedure:
Results:
Reason:
Equipment:
Procedure:
Results:
Reason:
Equipment:
Test Procedure:
Results:
Reason:
Equipment:
Procedure:
Results:
Reason:
Equipment:
Test Procedure:
Results:
Reason:
Equipment:
Procedure:
Results:
Reason:
Equipment:
Procedure:
Results:
Reason:
Equipment:
Procedure:
Results:
Reason:
Equipment:
Procedure:
Results:
Reason:
Equipment:
Procedure:
Horn Switch Test
Reason:
Equipment:
Procedure:
Results:
Reason:
Equipment:
Procedure:
Reason:
Equipment:
Procedure:
Diagnostic Mode 1:
Reason:
Test Conditions:
Procedure:
Reason:
Test Conditions:
Procedure:
Test Kit
Function:
Equipment:
Theory:
Purpose:
Purpose:
Purpose:
Removal:
Installation:
Removal:
Installation:
Removal:
Installation:
Removal:
Installation:
Disassembly:
Assembly:
Removal:
Installation:
Tools
Other Materials
Main Machine
Main Machine
Load Center
Display Panel
Connectors:
Wiring Harnesses:
Connectors:
Wiring Harnesses:
Connectors:
Wiring Harnesses:
Purpose:
Operation:
Purpose:
Operation:
Function:
Unswitched Power:
Switched Power:
Function:
Unswitched Power:
Switched Power:
Test Procedure A:
Test Procedure B:
Test Procedure C:
Function:
Test Conditions:
Function:
Test Conditions:
Function:
Test Procedure A:
Test Procedure B:
Function:
Function:
Function:
Test Conditions:
Function:
Test Conditions:
Function:
Test Conditions:
Function:
Function:
Test Procedure A:
Test Procedure B:
Test Procedure C:
Function:
Test Conditions:
Test Procedure A:
Test Procedure B:
Function:
Inputs:
Outputs:
Ground:
Function:
Test Conditions:
Function:
General Theory:
Max Speed:
Load Match Switch:
Function:
Test Conditions:
Function:
Test Conditions:
Function:
Test Conditions:
Function:
Test Conditions:
Other Materials
Clutch Housing
Clutch Housing
PowrReverser Clutch
Main Shaft
Driven Shaft
Main Gear Shift
PRT Valve
Function:
Function:
Function:
Function:
Reason:
Procedure:
Reason:
Procedure:
Reason:
Results:
Results:
Split the Machine:
Split the Machine:
Procedure:
Split the Machine:
Procedure:
Removal:
Installation:
Removal:
Disassembly:
Installation:
Other Materials
Drive Shaft
Front Drive
Function:
Charge Pump
Hydrostatic Pump
Hydrostatic Motor
Function:
Charge Pump
Hydrostatic Pump
Hydrostatic Motor
Function:
Reason:
Equipment:
Procedure:
Specifications:
Results:
Reason:
Equipment:
Procedure:
Specifications:
Results:
Reason:
Equipment:
Procedure:
Results:
Reason:
Procedure:
Removal:
Installation:
Removal:
Installation:
Disassembly:
Assembly:
Split the Machine:
Split the Machine:
Removal:
Installation:
Disassembly:
Transaxle Oil:
Capacity:
MFWD Oil:
Transaxle Oil:
Capacity:
MFWD Oil:
Transaxle Oil:
Capacity:
MFWD Oil:
Steering Angle:
Front Axle MFWD:
Other Materials
Range Shift
Differential Gear
Differential Lock
Brake
Rear PTO Shafts
Mid PTO Assembly
2-Speed Rear PTO
MFWD Final Drive
Range Transmission
Operation:
MFWD Drive:
Range Transmission
Operation:
MFWD Drive:
Operation:
Function:
MFWD Power Flow
Reason:
Procedure:
Reason:
Procedure:
Reason:
Procedure:
To Adjust Backlash:
MFWD Output Shaft
Removal:
Disassembly:
Installation:
MFWD Output Shaft
Removal:
Disassembly:
Installation:
Removal:
Disassembly:
Assembly:
Assembly:
Final Drive Removal
Disassemble:
Planetary Pinions:
Assembly:
Removal:
Installation:
Removal:
Disassembly:
Assembly:
Removal:
Installation:
Installation:
MFWD Spindle Shaft
Disassembly:
Assembly:
Spindle Housing
MFWD Differential
Specification:
Tools Required:
Procedure:
Results:
Function:
Theory:
Function:
Theory:
Function:
Theory:
Function:
Theory:
Function:
Theory:
Removal:
Installation:
Disassembly:
Assembly:
Removal:
Installation:
Disassembly:
Assembly:
Removal:
Installation:
Disassembly:
Assembly:
Installation:
Disassembly:
Assembly:
Mid PTO
Removal:
Installation:
Assembly:
Hydraulic Oil:
Hydraulic Oil:
Hydraulic Oil:
Lift Arms:
SCV:
Rockshaft:
Other Materials
Dual SCV Components
Function:
Function:
Function:
Theory:
Operation:
Function:
Theory:
Operation:
Function:
Theory:
Diagnostic Table
Diagnostic Table
Reason:
Procedure:
Reason:
Procedure:
Reason:
Equipment:
Procedure:
Machines with SCVS:
Reason:
Procedure:
Machines with SCV:
Reason:
Equipment:
Procedure:
Reason:
Equipment:
Procedure:
Specifications:
Results:
Reason:
Equipment:
Procedure:
Specifications
Results:
Reason:
Equipment:
Procedure:
Specifications:
Results:
Reason:
Equipment:
Procedure:
Specifications
Results:
Reason:
Procedure:
Hydraulic Gear Pump
Assembly:
Hydraulic Gear Pump
Assembly:
Removal:
Installation:
Lift Arms
Removal:
Specifications:
Installation:
Specifications:
Lift Control Lever
Removal:
Installation:
Removal:
Installation:
Removal:
Installation:
Rockshaft Piston
Removal:
Installation:
PTO Clutch Valve
Removal:
Installation:
Inspection:
Assembly:
Removal:
Installation:
SCV Disassembly:
Load Check Valves:
Installation:
Relief Valve:
Steering
Steering
Steering
All Models:
All Models:
eHydro Model:
PowrReverser Model:
Steering Operation
Steering Operation
Diagnosis Table
Reason:
Tools:
Procedure:
Results:
Procedure:
Results:
Reason:
Tools:
Procedure:
Results:
Procedure:
Results:
Reason:
Equipment:
Procedure:
Results:
Steering Cylinder
Removal:
Installation:
Steering Cylinder
Removal:
Installation:
Removal:
Installation:
Removal:
Installation:
Removal:
Installation:
Removal:
Installation:
Brakes
Brakes
Brakes
Transaxle Oil
Brake Housing
Brake Housing
Park Brake
Brakes
Brakes
Brakes
Brakes
Diagnosis
Reason:
Tools:
Procedure:
Results:
Reason:
Tools:
Procedure:
Results:
Brake Assembly
Removal:
Installation:
Removal:
Installation:
Removal:
Installation:
Installation:
Installation:
Installation:
Installation:
Installation:
Installation:
Removal:
Installation:
Removal:
Installation:
Removal:
Installation:
Removal:
Installation:
Removal:
Installation:
Removal:
Installation:
Removal:
Installation:
Removal:
Installation:
Installation:
Removal:
Installation:
Removal:
Installation:
Removal:
Installation:
Removal:
Installation:
Removal:
Installation:
- JOHN DEERE CODE DTC LIST
