John Deere Compact 4WD Loader 204L & 304L Service Repair Manual TM14272X19
Brand: John Deere
Type of Machine: Loader
Type of Manual: Service Repair Manual
Model: John Deere 204L 304L
Part Number: TM14272X19
Publication Date: 2020
Number of Pages: 204 Pages
Introduction
Brand: John Deere
Introduction
Foreword
Manual Identification—READ THIS FIRST!
ContentsGeneral Information
Safety Information
Recognize Safety Information
Follow Safety Instructions
Operate Only If Qualified
Wear Protective Equipment
Protect Against Noise
Avoid Unauthorized Machine Modifications
Inspect Machine
Stay Clear of Moving Parts
Avoid High-Pressure Fluids
Avoid High-Pressure Oils
Work In Ventilated Area
Avoid Static Electricity Risk When Refueling
High Debris Applications
Prevent Fires
In Case of Machine Fire
Prevent Battery Explosions
Handle Starting Fluid Safely
Exhaust Filter Ash Handling and Disposal
Prepare for Emergencies
Clean Debris from Machine
Add Cab Guarding for Special Uses
Start Only From Operator′s Seat
Use and Maintain Seat Belt
Prevent Unintended Machine Movement
Avoid Work Site Hazards
Use Special Care When Operating Loader
Keep Riders Off Machine
Avoid Backover Accidents
Avoid Machine Tip Over and Machine Damage
Avoid Power Lines
Operating on Slopes
Operating or Traveling On Public Roads
Inspect and Maintain ROPS
Travel Safely
Prevent Acid Burns
Add and Operate Attachments Safely
Park and Prepare for Service Safely
Service Machines Safely
Service Cooling System Safely
Make Welding Repairs Safely
Drive Metal Pins Safely
Service Tires Safely
Use Proper Lifting Equipment
Clean Exhaust Filter Safely
Torque Values
Metric Bolt and Cap Screw Torque Values
Additional Metric Cap Screw Torque Values
Unified Inch Bolt and Cap Screw Torque Values
Service Recommendations for 37° Flare and 30° Cone Seat Connectors
Service Recommendations for O-Ring Boss Fittings
O-Ring Boss Fittings in Aluminum Housing Service Recommendations—Excavators
Service Recommendations for Flared Connections—Straight or Tapered Threads
Service Recommendations for Flat Face O-Ring Seal Fittings
O-Ring Face Seal Fittings With SAE Inch Hex Nut and Stud End for High-Pressure Service Recommendations
O-Ring Face Seal Fittings With Metric Hex Nut and Stud End for Standard Pressure Service Recommendations
O-Ring Face Seal Fittings With Metric Hex Nut and Stud End for High-Pressure Service Recommendations
Service Recommendations for Metric Series Four Bolt Flange Fitting
Service Recommendations For Inch Series Four Bolt Flange Fittings
Inch Series Four Bolt Flange Fitting for High-Pressure Service Recommendations
Service Recommendations For Non-Restricted Banjo (Adjustable) Fittings
Service Recommendations For O-Ring Boss Fittings With Shoulder
Metric 24° O-Ring Seal DIN 20078 Service Recommendations
WheelsWheels and Fasteners
Wheel Remove and Install
Tire Remove and Install
Axles and Suspension SystemsRemoval and Installation
Front Axle Remove and Install
Rear Axle Remove and Install
Axle Shafts and U-Joints
Drive Shaft Remove and Install
Axle Shaft, Bearings, and Rear Axle Reduction Gears
Front and Rear Axle Disassemble and Assemble
Rear Axle Reduction Gear Case Remove and Install
Rear Axle Reduction Gear Case Disassemble and Assemble
TransmissionHydrostatic Components Removal and Installation
Hydrostatic Pump Valves Remove and Install
Directional Control Valve Remove and Install
Charge Pump Remove and Install
Hydrostatic Pump Remove and Install
Hydrostatic Motor Remove and Install
Creep Control Valve Remove and Install
Hydrostatic Start-Up Procedure
Hydrostatic Components Repair
Hydraulic Component Failure Cleanup Procedure
Hydrostatic Pump Disassemble and Assemble
Hydrostatic Motor Disassemble and Assemble
EngineRemoval and Installation
Yanmar Engine
Engine Remove and Install
Starter Motor Remove and Install
Engine Auxiliary SystemsCooling System
Fan Remove and Install
Cooling Package Remove and Install
Fuel Cooler Remove and Install
Intake System
Air Intake System Remove and Install
External Exhaust System
Diesel Particulate Filter (DPF) Remove and Install
Exhaust Filter Remove and Install
External Fuel Supply Systems
Fuel Tank Remove and Install
Damper DriveRemoval and Installation
Damper Plate Remove and Install
Steering SystemHydraulic System
Orbital Steering Valve Remove and Install
Orbital Steering Valve Disassemble and Inspect
Orbital Steering Valve Assemble
Canopy Steering Column Remove and Install
Cab Steering Column Remove and Install
Steering Cylinder Remove and Install
Steering Cylinder Disassemble and Assemble
Service BrakesActive Elements
Drum Brake Remove and Install
Service Brakes (Wet Disc) Remove and Install
Brake/Inching Valve Assembly Remove and Install
Drum Brake Bleed
Park BrakeHydraulic System
Park Brake Valve Remove and Install
Electrical SystemRemoval and Installation
Connector Repair Information
Monitor Display Remove and Install
Frame or Supporting StructureFrame Installation
Welding Repair of Major Structures
Loader and Rear Frames Separation
Upper Pivot Bushing Assembly Remove and Install
Lower Pivot Bushing Assembly Remove and Install
Rear Link and Bushing Assembly Remove and Install
Chassis Weights
Counterweight Remove and Install
Operator`s StationRemoval and Installation
Canopy Remove and Install
Cab Remove and Install
Operator Enclosure
Windowpanes Remove and Install
Windshield Wiper Motor Remove and Install
Rear Wiper Motor Remove and Install
Seat and Seat Belt
Seat Remove and Install
Heating and Air Conditioning System
Refrigerant Cautions and Proper Handling
R134a Refrigerant Oil Information
R134a Refrigerant Recovery, Recycling, and Charging Station Installation Procedure
Recover R134a Refrigerant
Flush and Purge Air Conditioning System
Evacuate R134a System
Charge R134a System
Air Conditioner Compressor Remove and Install
Receiver-Dryer Remove and Install
Condenser Remove and Install
Air Conditioner/Heater Module Remove and Install
Heater Core Remove and Install
Evaporator Coil Remove and Install
Expansion Valve Remove and Install
Heater Control Valve Remove and Install
Air Conditioner High/Low-Pressure Switch Remove and Install
Air Conditioner Freeze Control Switch Remove and Install
Blower Motor Remove and Install
Sheet Metal and StylingHood or Engine Enclosure
Hood Remove and Install
Miscellaneous Shields
Rear Fenders Remove and Install
Main Hydraulic SystemHydraulic System
General Hydraulic Oil Cleanup Procedure
Hydraulic Pump/Priority Valve Remove and Install
Hydraulic Pump/Priority Valve Disassemble and Assemble
Hydraulic Oil Reservoir Remove and Install
Hydraulic Start-Up Procedure
LoaderBucket
Welded-On Bucket Cutting Edge Remove and Install
Bolt-On Cutting Edge Remove and Install
Cracked Cutting Edge Repair
Attachment Coupler
Quik-Tatch™ Coupler Remove and Install
Quik-Tatch™ Actuator Remove and Install
Frames
Boom and Bucket Linkage Remove and Install
Bucket Linkage Bushings Remove and Install
Loader Boom Bushings Remove and Install
Loader Control Valve Remove and Install
Boom Cylinder Remove and Install
Bucket Cylinder Remove and Install
Boom and Bucket Cylinders Disassemble and Assemble
Ride Control Valve Remove and Install
Page Number
- JOHN DEERE CODE DTC LIST
