Martin Welker
104
230,792
John Deere Combines S540 S550 S660 S670 S680 S690 Repair Technical Manual TM805519
Brand: John Deere
Type of Machine: Combines
Model: John Deere S540 S550 S660 S670 S680 S690 SN. 120100— Combines
Part Number: TM805519
Publication Date: 2018
Number of Pages: 1371 Pages
Introduction
Foreword
Contents
Safety
Safety
General
Specifications
Machine Identification Numbers
Tune-Up and Adjustment
Fuels and Lubricants
Engine
Remove and Install Components
Cooling System
Fuel and Air
Air Intake System
Diesel Fuel System
Electrical System
Batteries
Harness and Connector Repair
Wire Harness Routing
Controllers and Power Distribution
Lighting
Operators Station
Sensors and Switches
Wiper
Alternator
Starting Motor
GreenStar Components
Power Train
Transmission and Differential-Three Speed Transmission
Hydrostatic System-Three Speed Transmission
Transmission and Differential-Two-Range Automatic Transmission
Hydrostatic Drive Pump-Two-Range Automatic Transmission
Hydrostatic Drive Motor-Two-Range Automatic Transmission
Single Reduction Final Drive
Cam Lobe Motor
Tires and Wheels
Steering and Brakes
Steering
Brakes
Brakes-Two-Range Automatic Transmission
Hydraulic System
Hydraulic Reservoir
Hydraulic Motors and Pumps
Hydraulic Valves
Hydraulic Cylinders
Accumulators
Separator Shell
Gull Wing Doors
Fiberglass Repair
Operator Station
Air Conditioning System (R-134a)
System Components
Cab
Feeder House
Conveyor
Top Shaft and Slip Clutch
Feeder House Drives and Reverser Gear Case
Fore/Aft and Lateral Tilt Frame
Five Speed Feeder House Drive Gear Case
Separator
Separator Repair
Separator Drives
Residue Disposal
Conveyor Augers, Cleaning Fan and Chaffer and Sieve Frame
Tailings Elevator and Augers
Primary Countershaft Gear Case
Header Electromagnetic Clutch
Grain Tank and Unloading System
Grain Tank Cross Augers
Unloading Auger System Drives
Vertical Unloading Auger and Lower Gear Case
Horizontal Unloading Auger and Gear Case
Clean Grain Elevator
Grain Tank and Extensions
Engine Gear Case and Control Valve
Engine Gear Case and Valve
Dealer Fabricated Tools
Page Number
