John Deere Combines 9450 9550 9650 Diagnosis and Tests Manual TM2002
Brand: John Deere
Type of Machine: Combines
Type of Manual: Diagnosis and Tests Manual
Model: John Deere 9450 9550 9650 Combines
Serial Number: 695101-
Part Number: TM2002
Publication Date: 2014
Number of Pages: 3923 Pages
FOREWORD
Section 210 - GENERAL
Group 05 - Safety
Group 10 - Combine and Component Identification
Group 15 - General Specifications
Group 20 - Diagnostic and Testing Procedures
Section 211 - DIAGNOSTIC TROUBLE CODES
Group A00 - A00 - Engine Control Unit Diagnostic Trouble Codes
Group C00 - C00 - Armrest Control Unit Diagnostic Trouble Codes
Group C03 - C03 - Cornerpost Control Unit Diagnostic Trouble Codes
Group E00 - E00 - Tailing Master Sensor Diagnostic Trouble Codes
Group E01 - E01 - Header Control Unit Diagnostic Trouble Codes
Group E02 - E02 - Right Control Unit Diagnostic Trouble Codes
Group E03 - E03 - Left Control Unit Diagnostic Trouble Codes
Group AMS - GREENSTAR Display Warning Messages and Fault Codes
Group AMS - GREENSTAR KeyCard and PC Data Storage Card Warning Messages
Group AMS - GREENSTAR Mobile Processor Warning Messages
Group AMS - HARVEST DOC Warning Messages
Group AMS - Moisture Sensor Warning Messages
Group AMS - STARFIRE Receiver Warning Messages
Group AMS - Terrain Compensation Module Fault Codes
Section 212 - OBSERVABLE SYMPTOMS
Group 220 - Engine System
Group 230 - Air Intake and Cooling Systems
Group 240 - Electrical
Group 250 - Power Train System
Group 255 - Four Wheel Drive System
Group 260 - Brake System
Group 270 - Hydraulic System
Group 275 - Main Gearcase System
Group 280 - Steering System
Group 290 - CLIMATRAK System
Group 300 - Separator System
Section 220 - ENGINE SYSTEM
Group 05 - General Information
Group 10 - Test Procedures and Adjustments
Group 15A - Engine Type Identification
Group 15B - Engine Diagnostics - Type A
Group 15C - Engine Diagnostics - Type B
Group 15D - Engine Diagnostics - Type C
Group 15E - Engine Diagnostics - Type D
Group 15F - Engine Diagnostics - Type E
Group 20 - Component Identification and Location
Section 230 - AIR INTAKE AND COOLING SYSTEMS
Group 15A - Air Intake System Diagnostics
Group 15B - Engine Type Identification
Group 15C - Engine Cooling Package Diagnostics - Type A
Group 15D - Engine Cooling Package Diagnostics - Type B
Section 240 - ELECTRICAL SYSTEM
Group 05 - How To Use This Diagnostic Information
Group 10A - Accessing Diagnostic Trouble Codes and Addresses
Group 10B - Diagnostic Trouble Codes, Warning Messages and Fault Codes
Group 10C - Diagnostic Addresses By Function
Group 10D - Diagnostic Addresses By Controller
Group 10E - Quick Cal Procedures
Group 10F - Machine Setting Addresses
Group 15A - Active Header Height Control System - Type Identification
Group 15B - Active Header Height Control Diagnostics - Type A
Group 15C - Active Header Height Control Diagnostics - Type B
Group 15D - Active Header Height Control Diagnostics - Type C
Group 15E - Alternator and Battery - Type Identification
Group 15F - Alternator and Battery Diagnostics - Type A
Group 15G - Alternator and Battery Diagnostics - Type B
Group 15H - Armrest Control Unit - Overall Diagnostics
Group 15I - Auxiliary Power Strip Outlet Diagnostics
Group 15J - CAN Bus - Type Identification
Group 15K - CAN Bus Diagnostics - Type A
Group 15L - CAN Bus Diagnostics - Type B
Group 15M - CAN Bus Diagnostics - Type C
Group 15N - CAN Bus Diagnostics - Type D
Group 15O - CAN Bus Diagnostics - Type E
Group 15P - CAN Bus Diagnostics - Type F
Group 15Q - CAN Bus Diagnostics - Type G
Group 15R - CAN Bus Diagnostics - Type H
Group 15S - CAN Bus Diagnostics - Type I
Group 15T - Cleaning Fan Speed Adjust Diagnostics
Group 15U - CLIMATRAKCLIMATRAK is a trademark of Deere & Company - Type Identification
Group 15V - CLIMATRAKCLIMATRAK is a trademark of Deere & Company Diagnostics - Type A
Group 15W - CLIMATRAKCLIMATRAK is a trademark of Deere & Company Diagnostics - Type B
Group 15X - COMFORT COMMANDCOMFORT COMMAND is a trademark of Deere & Company Seat Diagnostics
Group 15Y - CONTOUR MASTERCONTOUR MASTER is a trademark of Deere & Company - Automatic Diagnostics
Group 15Z - CONTOUR MASTERCONTOUR MASTER is a trademark of Deere & Company - Manual Tilt Type Identification
Group 15AA - CONTOUR MASTER CONTOUR MASTER is a trademark of Deere & Company Diagnostics - Manual Tilt - Type A
Group 15AB - CONTOUR MASTER CONTOUR MASTER is a trademark of Deere & Company Diagnostics - Manual Tilt - Type B
Group 15AC - Cornerpost Control Unit - Overall Diagnostics
Group 15AD - Cornerpost - Cleaning Fan Speed Diagnostics
Group 15AE - Cornerpost - CONTOUR MASTERCONTOUR MASTER is a trademark of Deere & Company Position Diagnostics
Group 15AF - Cornerpost - Deck Plate Spacing Diagnostics
Group 15AG - Cornerpost - Engine Hourmeter Diagnostics
Group 15AH - Cornerpost - Engine Speed Type Identification
Group 15AI - Cornerpost - Engine Speed Diagnostics - Type A
Group 15AJ - Cornerpost - Engine Speed Diagnostics - Type B
Group 15AK - Cornerpost - Engine Speed Diagnostics - Type C
Group 15AL - Cornerpost - Engine Temperature Gauge Type Identification
Group 15AM - Cornerpost - Engine Temperature Gauge Diagnostics - Type A
Group 15AN - Cornerpost - Engine Temperature Gauge Diagnostics - Type B
Group 15AO - Cornerpost - Engine Temperature Gauge Diagnostics - Type C
Group 15AP - Cornerpost - Fuel Gauge Diagnostics
Group 15AQ - Cornerpost - Feeder House Speed Diagnostics
Group 15AR - Cornerpost - Ground Speed Diagnostics
Group 15AS - Cornerpost - HYDRAFLEXHYDRAFLEX is a trademark of Deere & Company Pressure Diagnostics
Group 15AT - Cornerpost - Separator Hours Diagnostics
Group 15AU - Cornerpost - Threshing Speed Diagnostics
Group 15AV - Cornerpost - Threshing Clearance Diagnostics
Group 15AW - Deck Plate Adjustment Type Identification
Group 15AX - Deck Plate Adjust Diagnostics - Type A
Group 15AY - Deck Plate Adjust Diagnostics - Type B
Group 15AZ - Delayed Power Type Identification
Group 15BA - Delayed Power Diagnostics - Type A
Group 15BB - Delayed Power Diagnostics - Type B
Group 15BC - Delayed Power Diagnostics - Type C
Group 15BD - Delayed Power Diagnostics - Type D
Group 15BE - DIAL-A-SPEEDDIAL-A-SPEED is a trademark of Deere & Company Diagnostics
Group 15BF - Draper Speed Adjust Diagnostics
Group 15BG - Engine Compartment Relay Panel Type Identification
Group 15BH - Engine Compartment Relay Panel Diagnostics - Type A
Group 15BI - Engine Compartment Relay Panel Diagnostics - Type B
Group 15BJ - Engine Compartment Relay Panel Diagnostics - Type C
Group 15BK - Engine Control Unit - Type Identification
Group 15BL - Engine Control Unit Overall Diagnostics - Type A
Group 15BM - Engine Control Unit Overall Diagnostics - Type B
Group 15BN - Engine and Fuel Control - Type Identification
Group 15BO - Engine and Fuel Control Diagnostics - Type A
Group 15BP - Engine And Fuel Control Diagnostics - Type B
Group 15BQ - Engine and Fuel Control Diagnostics - Type C
Group 15BR - Engine and Fuel Control Diagnostics - Type D
Group 15BS - Four Wheel Drive Diagnostics
Group 15BT - Fuel Transfer Pump Diagnostics
Group 15BU - Glow Plug Diagnostics
Group 15BV - GREENSTARGREENSTAR is a trademark of Deere & Company - Display Diagnostics
Group 15BW - GREENSTARGREENSTAR is a trademark of Deere & Company - GPS Receiver Type Identification
Group 15BX - GREENSTARGREENSTAR is a trademark of Deere & Company - GPS Receiver Diagnostics - Type A
Group 15BY - GREENSTARGREENSTAR is a trademark of Deere & Company - GPS Receiver Diagnostics - Type B
Group 15BZ - GREENSTARGREENSTAR is a trademark of Deere & Company - GPS Receiver Diagnostics - Type C
Group 15CA - GREENSTARGREENSTAR is a trademark of Deere & Company - GPS Receiver Diagnostics - Type D
Group 15CB - GREENSTARGREENSTAR is a trademark of Deere & Company - KeyCard and PC Data Storage Card Diagnostics
Group 15CC - GREENSTARGREENSTAR is a trademark of Deere & Company - Mass Flow Sensor Type Identification
Group 15CD - GREENSTARGREENSTAR is a trademark of Deere & Company - Mass Flow Sensor Diagnostics - Type A
Group 15CE - GREENSTARGREENSTAR is a trademark of Deere & Company - Mass Flow Sensor Diagnostics - Type B
Group 15CF - GREENSTARGREENSTAR is a trademark of Deere & Company - Mobile Processor Type Identification
Group 15CG - GREENSTARGREENSTAR is a trademark of Deere & Company - Mobile Processor Diagnostics - Type A
Group 15CH - GREENSTARGREENSTAR is a trademark of Deere & Company - Mobile Processor Diagnostics - Type B
Group 15CI - GREENSTARGREENSTAR is a trademark of Deere & Company - Moisture Sensor Type Identification
Group 15CJ - GREENSTARGREENSTAR is a trademark of Deere & Company - Moisture Sensor Diagnostics - Type A
Group 15CK - GREENSTARGREENSTAR is a trademark of Deere & Company - Moisture Sensor Diagnostics - Type B
Group 15CL - GREENSTARGREENSTAR is a trademark of Deere & Company System - Harvest/Yield/ Mapping/Monitor Type Identification
Group 15CM - GREENSTARGREENSTAR is a trademark of Deere & Company System - HARVEST DOCHARVEST DOC is a trademark of Deere & Company Diagnostics - Type A
Group 15CN - GREENSTARGREENSTAR is a trademark of Deere & Company System - HARVEST DOCHARVEST DOC is a trademark of Deere & Company Diagnostics - Type B
Group 15CO - GREENSTARGREENSTAR is a trademark of Deere & Company System - Harvest Monitor Diagnostics
Group 15CP - GREENSTARGREENSTAR is a trademark of Deere & Company System - Parallel Tracking Diagnostics
Group 15CQ - GREENSTARGREENSTAR is a trademark of Deere & Company System - Yield Mapping Diagnostics - Type A
Group 15CR - GREENSTARGREENSTAR is a trademark of Deere & Company System - Yield Mapping Diagnostics - Type B
Group 15CS - GREENSTARGREENSTAR is a trademark of Deere & Company System - Yield Monitor Diagnostics
Group 15CT - Header Control Unit Overall Diagnostics
Group 15CU - Header Engage Diagnostics
Group 15CV - Header Raise/Lower Type Identification
Group 15CW - Header Raise/Lower Type A Diagnostics
Group 15CX - Header Raise/Lower Type B Diagnostics
Group 15CY - Horn Diagnostics
Group 15CZ - HYDRAFLEXHYDRAFLEX is a trademark of Deere & Company Pressure Adjustment Diagnostics
Group 15DA - Left Control Unit Overall Diagnostics
Group 15DB - Left Control Unit - Control Relay Board Link Diagnostics
Group 15DC - Lighting System - Overall Diagnostics
Group 15DD - Lighting System - Daytime Running Lights Type Identification
Group 15DE - Lighting System - Daytime Running Lights Diagnostics - Type A
Group 15DF - Lighting System - Daytime Running Lights Diagnostics - Type B
Group 15DG - Lighting System - Dome Light Diagnostics
Group 15DH - Lighting System - Exit Lighting Diagnostics
Group 15DI - Lighting System - Field Lights Type Identification
Group 15DJ - Lighting System - Field Lights Diagnostics - Type A
Group 15DK - Lighting System - Field Lights Diagnostics - Type B
Group 15DL - Lighting System - Hazard/Turn Lights Type Identification
Group 15DM - Lighting System - Hazard/Turn Lights Diagnostics - Type A
Group 15DN - Lighting System - Hazard/Turn Lights Diagnostics - Type B
Group 15DO - Lighting System - Marker Lights Type Identification
Group 15DP - Lighting System - Marker Lights Diagnostics - Type A
Group 15DQ - Lighting System - Marker Lights Diagnostics - Type B
Group 15DR - Lighting System - Panel Lights Type Identification
Group 15DS - Lighting System - Panel Lights Diagnostics - Type A
Group 15DT - Lighting System - Panel Lights Diagnostics - Type B
Group 15DU - Lighting System - Rear Discharge Lights Type Identification
Group 15DV - Lighting System - Rear Discharge Lights Diagnostics - Type A
Group 15DW - Lighting System - Rear Discharge Lights Diagnostics - Type B
Group 15DX - Lighting System - Road Lights Type Identification
Group 15DY - Lighting System - Road Lights Diagnostics - Type A
Group 15DZ - Lighting System - Road Lights Diagnostics - Type B
Group 15EA - Lighting System - Service Lights - Engine Area Diagnostics
Group 15EB - Lighting System - Service Lighting - Gullwing Doors Diagnostics
Group 15EC - Lighting System - Service Lights - Shoe Area Diagnostics
Group 15ED - Lighting System - Side Finder Lights Type Identification
Group 15EE - Lighting System - Side Finder Lights Diagnostics - Type A
Group 15EF - Lighting System - Side Finder Lights Diagnostics - Type B
Group 15EG - Lighting System - Stubble Lights Type Identification
Group 15EH - Lighting System - Stubble Lights Diagnostics - Type A
Group 15EI - Lighting System - Stubble Lights Diagnostics - Type B
Group 15EJ - Lighting System - Unloading Auger Lights Type Identification
Group 15EK - Lighting System - Unloading Auger Light Diagnostics - Type A
Group 15EL - Lighting System - Unloading Auger Light Diagnostics - Type B
Group 15EM - Multifunction Control Handle Diagnostics
Group 15EN - Quick-Stop Diagnostics
Group 15EO - Radio System - Type Identification
Group 15EP - Radio System Diagnostics - Type A
Group 15EQ - Radio System Diagnostics - Type B
Group 15ER - Reel Fore/Aft Type Identification
Group 15ES - Reel Fore/Aft Diagnostics - Type A
Group 15ET - Reel Fore/Aft Diagnostics - Type B
Group 15EU - Reel Fore/Aft Resume Diagnostics
Group 15EV - Reel Raise/Lower Type Identification
Group 15EW - Reel Raise/Lower Diagnostics - Type A
Group 15EX - Reel Raise/Lower Diagnostics - Type B
Group 15EY - Reel Raise/Lower Resume Diagnostics
Group 15EZ - Reel/Belt Speed Adjust Diagnostics
Group 15FA - Right Control Unit - Overall Diagnostics
Group 15FB - Road/Field System Diagnostics
Group 15FC - Separator Engage Diagnostics
Group 15FD - Service Power Diagnostics
Group 15FE - Start Aid Diagnostics
Group 15FF - Starting Motor System Diagnostics
Group 15FG - Tailings Monitor Diagnostics
Group 15FH - Threshing Clearance Adjust Diagnostics
Group 15FI - Threshing Speed Adjust Type Identification
Group 15FJ - Threshing Speed Adjust Diagnostics - Type A
Group 15FK - Threshing Speed Adjust Diagnostics - Type B
Group 15FL - Unloading Auger Engage Diagnostics
Group 15FM - Unloading Auger Swing Type Identification
Group 15FN - Unloading Auger Swing Diagnostics - Type A
Group 15FO - Unloading Auger Swing Diagnostics - Type B
Group 15FP - Variable Speed Feeder House Adjust - Type Identification
Group 15FQ - Variable Speed Feeder House Adjust Diagnostics - Type A
Group 15FR - Variable Speed Feeder House Adjust Diagnostics - Type B
Group 15FS - VISIONTRAK VISIONTRAK is a trademark of Deere & Company Diagnostics
Group 15FT - Warning Display Panel - Overall Type Identification
Group 15FU - Warning Display Panel - Overall Diagnostics - Type A
Group 15FV - Warning Display Panel Overall Diagnostics - Type B
Group 15FW - Warning - Clean Grain Elevator Speed Low Type Identification
Group 15FX - Warning - Clean Grain Elevator Speed Diagnostics - Type A
Group 15FY - Warning - Clean Grain Elevator Speed Diagnostics - Type B
Group 15FZ - Warning - Conveyor Auger Speed Low Diagnostics
Group 15GA - Warning - Cylinder Speed Low Diagnostics
Group 15GB - Warning - Engine Air Filter Plugged Type Identification
Group 15GC - Warning - Engine Air Filter Plugged Diagnostics - Type A
Group 15GD - Warning - Engine Air Filter Plugged Diagnostics - Type B
Group 15GE - Warning - Engine Air Filter Plugged Diagnostics - Type C
Group 15GF - Warning - Engine Oil Pressure Low Type Identification
Group 15GG - Warning - Engine Oil Pressure Low Diagnostics - Type A
Group 15GH - Warning - Engine Oil Pressure Low Diagnostics - Type B
Group 15GI - Warning - Engine Oil Pressure Low Diagnostics - Type C
Group 15GJ - Warning - Engine Speed Low Type Identification
Group 15GK - Warning - Engine Speed Low Diagnostics - Type A
Group 15GL - Warning - Engine Speed Low Diagnostics - Type B
Group 15GM - Warning - Engine Speed Low Diagnostics - Type C
Group 15GN - Warning - Engine Temperature High Type Identification
Group 15GO - Warning - Engine Temperature High Diagnostics- Type A
Group 15GP - Warning - Engine Temperature High Diagnostics - Type B
Group 15GQ - Warning - Engine Temperature High Diagnostics - Type C
Group 15GR - Warning - Grain Separator Speed Low Diagnostics
Group 15GS - Warning - Grain Tank Full Type Identification
Group 15GT - Warning - Grain Tank Full Diagnostics - Type A
Group 15GU - Warning - Grain Tank Full Diagnostics - Type B
Group 15GV - Warning - Hydraulic Oil Temperature High Diagnostics
Group 15GW - Warning - Hydrostatic Charge Pressure Low Diagnostics
Group 15GX - Warning - Low Fuel Diagnostics
Group 15GY - Warning - Main Gearcase Filter Restricted Diagnostics
Group 15GZ - Warning - Main Gearcase Pressure Low Diagnostics
Group 15HA - Warning - Main Gearcase Temperature High Diagnostics
Group 15HB - Warning - Parking Brake Diagnostics
Group 15HC - Warning - Separator Plugged Diagnostics
Group 15HD - Warning - Straw Chopper Speed Low Diagnostics
Group 15HE - Warning - Tailings Elevator Speed Low Diagnostics
Group 15HF - Warning - Unloading Auger Engaged Diagnostics
Group 15HG - Warning - Voltage Low Diagnostics
Group 15HH - Wiper Diagnostics
Group 20A - Circuit Code Listing
Group 20B - Connector Information
Group 20C - Connector Repair Procedures
Section 250 - POWER TRAIN SYSTEM
Group 15A - Final Drive Diagnostics
Group 15B - Transmission Diagnostics
Group 15C - Hydrostatic Diagnostics
Section 255 - FOUR WHEEL DRIVE SYSTEM
Group 15 - Four Wheel Drive Two Speed Diagnostics
Section 260 - BRAKE SYSTEM
Group 15A - Park Brake Diagnostics
Group 15B - Service Brakes Diagnostics
Section 270 - HYDRAULIC SYSTEM
Group 10 - Test Procedures And Adjustments
Group 15A - Basic Hydraulic System Type Identification
Group 15B - Basic Hydraulic System Diagnostics - Type A
Group 15C - Basic Hydraulic System Diagnostics - Type B
Group 15D - Chaff Spreader Drive Diagnostics
Group 15E - CONTOUR MASTER™ Header Tilt Diagnostics
Group 15F - Deck Plate Adjust Type Identification
Group 15G - Deck Plate Adjust Diagnostics - Type A
Group 15H - Deck Plate Adjust Diagnostics - Type B
Group 15I - Draper Belt Drive Diagnostics
Group 15J - Feeder House Gearcase Cooler Diagnostics
Group 15K - Header Raise/Lower Diagnostics
Group 15L - HYDRAFLEX™ Pressure Adjust Diagnostics
Group 15M - Hydraulic System Overheating Type Identification
Group 15N - Hydraulic System Overheating Diagnostics - Type A
Group 15O - Hydraulic System Overheating Diagnostics - Type B
Group 15P - Reel/Belt Drive Type Identification
Group 15Q - Reel/Belt Drive Diagnostics - Type A
Group 15R - Reel/Belt Drive Diagnostics - Type B
Group 15S - Reel Fore/Aft Type Identification
Group 15T - Reel Fore/Aft Diagnostics - Type A
Group 15U - Reel Fore/Aft Diagnostics - Type B
Group 15V - Reel Raise/Lower Type Identification
Group 15W - Reel Raise/Lower Diagnostics - Type A
Group 15X - Reel Raise/Lower Diagnostics - Type B
Group 15Y - Reel Raise/Lower Diagnostics - Type C
Group 15Z - Reel Raise/Lower Diagnostics - Type D
Group 15AA - Threshing Speed Adjust Diagnostics
Group 15AB - Unloading Auger Swing Diagnostics
Group 15AC - Variable Speed Feeder House Type Identification
Group 15AD - Variable Speed Feeder House Diagnostics - Type A
Group 15AE - Variable Speed Feeder House Diagnostics - Type B
Section 275 - MAIN GEARCASE SYSTEM
Group 15A - Main Gearcase Diagnostics
Group 15B - Main Gearcase Pressure Low Diagnostics
Group 15C - Main Gearcase Temperature High Diagnostics
Group 15D - Main Gearcase Filter Restricted Diagnostics
Group 15E - Separator Engage Main Gearcase Diagnostics
Group 15F - Unloading Auger Engage Main Gearcase Diagnostics
Section 280 - STEERING SYSTEM
Group 15 - Steering Diagnostics
Section 290 - CLIMATRAK™ SYSTEM
Group 15 - CLIMATRAK™ Diagnostics
Section 300 - SEPARATOR SYSTEM
Group 15 - Separator Vibration Diagnostics
Brand: John Deere
Part Number: TM2002
FOREWORD
Group 05 - Safety
- JOHN DEERE CODE DTC LIST
