John Deere CC CC-147 Field Cultivators Parts Catalog PC0231
- Download this document, you need 250 Gallons
Brand: John Deere
Type of Machine: Field Cultivators
Model: John Deere CC CC-147 Field Cultivators
Part Number: PC0231
Number of Pages: 67 Pages
ALPHABETICAL INDEX
F
Frame (5-Ft., 6-1/2-Ft., 8-Ft., 10-Ft., 11-1/2-Ft. Sizes)
Frame (14-1/2-Ft. Size)
Frame Extension
Hand Lever
I
ID VIEW
P
Power Lift
Power Lift, Jackshaft
Power Lift, Screw Depth Regulator (5-Ft., 6-1/2-Ft., 8-Ft., 10-Ft., 11-1/2-Ft. Sizes)
Power Lift, Screw Depth Regulator (14-1/2-Ft. Size)
Powr-Trol Adapter (5-Ft., 6-1/2-Ft., 8-Ft. Sizes)
Powr-Trol Adapter (10-Ft., 11-1/2-Ft. Sizes)
Powr-Trol Adapter (14-1/2-Ft. Size)
Powr-Trol Hose Support (48-50)
Powr-Trol Hose Support (50- )
Pressure Shaft (One-Piece) (5-Ft., 6-1/2-Ft., 8-Ft. Sizes)
Pressure Shaft (Two-Piece) (10-Ft., 11-1/2 Ft., 14-1/2-Ft. Sizes)
Pressure Shaft (One-Piece Stiff Tooth) (5-Ft., 6-1/2-Ft., 8-Ft. Sizes)
Pressure Shaft (Two-Piece Stiff-Tooth) (10-Ft., 11-1/2 Ft., 14-1/2-Ft. Sizes)
Pressure Shaft, Helper Spring
S
Shield
Spring Tooth Cultivator Bar Back of Wheel
Spring Tooth Cultivator Bar, Long
Spring Tooth Cultivator Bar, Short
Spring Tooth Shovel Equipment
Stiff Tooth Cultivator Bar Back of Wheel (35-49)
Stiff Tooth Cultivator Bar Back of Wheel (49-54)
Stiff Tooth Cultivator Bar Back of Wheel (54- )
Stiff Tooth Cultivator Bar, Long (35-49)
Stiff Tooth Cultivator Bar, Long (49-54)
Stiff Tooth Cultivator Bar, Long (54- )
Stiff Tooth Cultivator Bar, Short (35-49)
Stiff Tooth Cultivator Bar, Short (49-54)
Stiff Tooth Cultivator Bar, Short (54- )
Stiff Tooth Shovel Equipment
T
Tractor Hitch and Draw Angles (5-Ft., 6-1/2-Ft. Sizes)
Tractor Hitch and Draw Angles (8-Ft., 10-Ft., 11-1/2-Ft. Sizes)
Tractor Hitch and Draw Angles (14-Ft. Size)
Trailer Hitch (6-1/2-Ft., 11-1/2-Ft., 14-1/2-Ft. Sizes)
Trailer Hitch (8-Ft., 10-Ft. Sizes)
Two-Unit Hitch, Caster Wheel and Axle
Two-Unit Hitch, Drawbar, Rub Disk and Tie Rod
Two-Unit Hitch, Large
Two-Unit Hitch, Small
W
Warning Lamp Bracket and Socket
Wheel Assembly
Brand: John Deere
Part Number: PC0231
ALPHABETICAL INDEX
F
Frame Extension
Hand Lever
I
ID VIEW
P
Power Lift
S
Shield
T
W
Wheel Assembly
- JOHN DEERE CODE DTC LIST
