Momed80
150
35,046
John Deere Backhoe Loader 315P-Tier Parts Catalog PC15489
Brand: John Deere
Model: John Deere 315P-Tier Backhoe Loader
PIN: 1YN315PA__CA00001-, 1YN315PA_ _DA00001-
Part Number: PC15489
Number of Pages: 1385 Pages
Rim, 169-28 in and 125 X 80-18, 4WD, Galaxy Marathoner, R4 10 Ply
Rim, 169-28 in and 125 X 80-18, 14P Rear, 10P Front, Galaxy 4WD
Wheel and Rim Assembly, W9 x 18, 4WD
Rim, 169-28 in and 125 X 80-18, Advance 4WD
Rim, 169-28 in and 125 X 80-18, 2WD, Galaxy Marathoner, R4 10 Ply
Wheel and Rim Assembly, W9 x 18, 2WD
Rim, 169-28 in and 125 X 80-18, Advance 2WD
Front Axle with MFWD and Limited Slip Differential
Front Axle Housing with MFWD
Front Axle Planetary Gears and Carrier
Differential, Front Axle
Front Axle Housing Hubs, Shafts, and Universal Joints with MFWD
Spiral Bevel Input Pinion and Ring Gear, Front Differential
Steering Cylinder and Repair Kit with MFWD
Complete Rear Axle and Differential Assembly
Rear Axle Planetary Drive Pinion Carrier
Spiral Bevel Input Pinion and Ring Gear Set
Differential Case and Gears
Parking Brake Housing and Clutch Disc
Service Brake Clutch Disc and Disc Carrier
Differential and Rear Axle Housings
Differential Lock Control Switch
Front Drive Shaft
Universal Drive Shaft
Front Axle without MFWD
Swivel Housing and Steering Cylinder without MFWD
Standard Front Axle Housing without MFWD
Wheel Hub (w_o MFWD)
Axle Mounting Hardware
Differential Lock Plumbing
Multi-Functional Wheel Drive Switch On- Off
Transmission Control Lever with Multi-Function
Transmission, Dipstick and Tube, 2WD
Transmission Shift Control Solenoids
Second Speed Clutch Assembly (K2)
High Range Forward Clutch Assembly (K4)
Third Speed Clutch Assembly (K3)
Transmission Oil Filter
Transmission Output Yoke(4 x 3), Rear
Transmission Charge Pump
First Speed Clutch Assembly (K1)
Reverse Clutch and Input Shaft (KR)
Transmission Rear Housing and Oil Fill Tube
Torque Converter
Transmission Front Housing and Torque Converter Cover
Low Range Forward Clutch Assembly
Transmission Speed Sensor
Transmission, Dipstick and Tube, 4WD
Mechanical Front Wheel Drive Clutch Assembly
Transmission Mounting and Hardware
1160 Valve Cover
1229 Oil Filler Neck
1328 Crankshaft Pulley
1428 Flywheel Housing
1502 Flywheel
16E3 Fuel Injection System
1783 Air Intake
1903 Oil Pan
2001 Water Pump Pulley
2158 Thermostat Cover
2224 Engine Thermostat
2698 Engine Coolant Heater Fittings
28AU Exhaust Manifold
2915 Ventilating System
30AT Starter Motor
35B9 Fuel Filter
3612 Front Plate
3799 Fuel Transfer Pump Cover
3924 Thermostat Housing
4002 Engine Oil Dipstick
4446 Timing Gear Cover and Water Pump
4501 Balancer Shaft
4652 Cylinder Block
4715 Crankshaft and Bearings
4838 Connecting Rods and Pistons
4928 Value Actuating Mechanism
5001 Engine Oil Pump
5130 Cylinder Head with Valves
5738 Water Pump Inlet
5954 Engine Oil Cooler
6282 Alternator Mounting
63BC Low Pressure Fuel Lines
65U2 Turbocharger
6698 Temperature Switch
6730 Engine Sensors
8742 Belt Tensioner
8843 Engine Oil Filter
9801 Lift Straps
9901 Short Block Assembly
9901 Replacement Engine
1118 Valve Cover
1302 Crankshaft Pulley
16EY Fuel Injection Pump
17DZ Air Intake
2101 Thermostat Cover
2201 Engine Thermostat
2816 Exhaust Manifold
2901 Vent System
35EQ Final Fuel Filter
3618 Front Plate
3701 Fuel Transfer Pump
4429 Timing Gear Cover and Water Pump
4502 Balancer Shaft
4614 Cylinder Block
4706 Crankshaft and Bearings
4823 Connecting Rods and Pistons
4901 Valve Actuating Mechanism
5102 Cylinder Head with Valves
63AA Low Pressure Fuel Lines
65B7 Turbocharger
6710 Engine Sensors
7699 Oil Pressure Switch - Plug
8702 Belt Tensioner
8822 Engine Oil Filter
Engine Block Coolant Heater, 220 Volt
Cooling Package W_ Condenser, Tier 3 _Final Tier 4 Engines
Fan Shroud and Hoses (Engine 4045HT086-DZ123583)
Oil Coolers and Plumbing
Cooling Package, Tier 2 Engines
Fan Drive with Air Conditioning (Engine 4045TT096-DZ123593)
Fan Drive without Air Conditioning (Engine 4045TT096-DZ123593)
Fan Drive with Air Conditioning (Engine 4045HT086-DZ123583)
Foot Throttle Control
Air Intake System (Engine 4045HT086-DZ123583)
Air Intake System (Engine 4045TT096-DZ123593)
Exhaust System, Black Stack (Engine 4045HT086-DZ123583)
Exhaust System, Chrome Stack (Engine 4045HT086-DZ123583)
Exhaust System, Black Stack (Engine 4045TT096-DZ123593)
Exhaust System, Chrome Stack (Engine 4045TT096-DZ123593)
Engine Mounting Hardware
Fuel Filter and Lines (Engine 4045HT086-DZ123583)
Primary Fuel Filter Components
Fuel Filter and Lines without Preheater (Engine 4045TT096-DZ123593)
Valve, Dual Section, Pneumatic Controlled Closing Wheel
Fuel Filter and Lines with Preheater (Engine 4045TT096-DZ123593)
Fuel System
Engine Control Unit and Mounting (Engine 4045TT096-RE545793)
Engine Control Unit and Mounting (Engine 4045HT086-RE566132)
Steering Hydraulics without Mechanical Front Wheel Drive Components (2_2)
Steering Hydraulics with Mechanical Front Wheel Drive, (MFWD)
Steering Valve, Heavy Duty
Steering Column, Non Tilt
Steering Column
Steering Load Sense Hydraulics without Loader Auxiliary
Brake Valve Installation
Service Brake Hydraulics
Brake Valve Boost Hydraulics
Brake Plumbing Clamps
Parking Brake Hydraulics
Decal, Loader Control, Two Function without Auxiliary Lever
Decals, Loader Controls
Serial Number Plate, Vehicle
Labels and Decals, Portuguese
No Text Label, Two Lever SAE Backhoe Controls
Backhoe Spring Coupler Labels English, Spanish, and French
Backhoe Spring Coupler Labels, No Text
No Text Labels and Decals, Pilot
Warning and Control Labels
Decals and Labels, No Text
Label, Hydraulic Fluid
Fluid Sampling Plumbing
Battery Cable, Dual Positive With Disconnect
Battery Cable Single Positive With Disconnect
Single Battery and Negative Cable
Jump Start Cover and Bus Bar
Dual Battery and Negative Cable
Alternator 145A
Beacon Mounting Hardware
Drive and Turn Signal Lights
Strobe Beacon
Multifunction Lever, Cab
Boom And Side Shift Lock Harness
Rear Gear Pump
Main Cab Wiring Harness
Main Cab Wiring Harness Hardware
Main Cab Wiring Harness Components
Cab Fuse Box, Main Harness
Multifunction Lever, Canopy
Single Lever Wiring Harness, Components
Multi-Functional Controller Auxiliary Wiring Harness, Components
Ride Control Wiring Harness Components
Access Hole Decals without Engine Module
Horn Control Switch
Switch Plug without Horn
High Beam Indicator
Connector Cap Assemblies, without Pilot Enable Harness
Connector Cap
Air Conditioning Harness and Switch
Canopy Wiring Harness
Canopy Wiring Harness Hardware
Canopy Wiring Harness, Components
Canopy Wiring Harness, Fuse Box
Rear Lights and Harness
Rear Lights and Harness Hardware Pilot
Rear Light Harness Pilot
Gear Pump Rear Harness
Rear Gear Pump Wiring Harness Components
Rear Lights Harness, Mechanical Sideshift
Rear Lights Harness, Mechanical Sideshift, Hardware
Rear Lights Harness, Powered SideShift
Rear Lights Harness, Powered Side Shift, Hardware
Rear Lights and Harness Powered Sideshift - Manual
Rear Lights and Harness Powered Sideshift -Manual, Hardware
Front Wiring Harness (Engine 4045HT086-DZ123583)
Front Wiring Harness,Hardware (Engine 4045HT086-DZ123583)
Front Wiring Harness and Connectors, Level 16
Pilot Control Rear Wiring Harness, Standard
Front Wiring Harness, Level 12 (Engine 4045TT096-DZ123593)
Front Wiring Harness, Hardware (Engine 4045TT096-DZ123593)
Front Wiring Harness Components
Operators Station Wiring, Routing Hardware
Selective Flow Wiring Harness
Selective Flow Wiring Harness, Hardware
Harness Mounting Bracket, Canopy
Harness Mounting Bracket, Cab
Loader Coupler Harness
Loader Coupler Harness, Hardware
Toggle Rocker Switch, No Power Slider
Toggle Rocker Switch, Power Slider
Stabilizer and Overload Warning Wiring Harness
Stabilizer and Overload Warning Wiring Harness, Hardware
Stabilizer and Overload Warning Wiring Harness, Components
Stabilizer Warning Bracket
Loader, Controlled Load Lowering Valve Wiring Harness
Loader, Controlled Load Lowering Valve Wiring Harness Hardware
Loader, Controlled Load Lowering Valve, Wiring Harness Components
Overload Warning Harness
Overload Three Position Warning Switch Plug
Stabilizer Warning Wiring Harness
Stabilizer Warning Wiring Harness, Hardware
Anti-Theft Decals
Switch Plug without Start Aid (Engine 4045TT096-RE556068)
Switch Plug without Beacon
Flow Control Switch
Vehicle Control Unit (VCU)
Auxiliary Vehicle Controller (329328 - )
Standard Display Monitor (SDM)
Switch Plug without Air Seat (Engine 4045TBZ01-RE564738)
Mainframe Hardware
Stabilizer Cylinder
Cooler Hardwares
Full MFWD Drive Shaft Guard
Front Bumper
Front Counterweight Kit, 454 kg (1000 lbs)
Front Counterweight Kit, 340 kg (750 lbs)
Front Counterweight Kit, 204 kg (450 lbs)
Front Console Seal
Canopy ROPS
Cab ROPS
Cab Door, LH
Cab Door, RH
Rear Cab Windows Components
Floor Covers with Anti Slip Canopy
Floor Covers and Mats, Cab with Manual Controls
Canopy Floor Covers and Mats, Pilot Controls
Floor Covers and Mats, Cab with Pilot Controls
Cab Seals, Pilot Controls
Operator Enclosure Isolators
Headliner Without Radio
Headliner with Premium Radio
Roof with Lights
Roof Wiring Harness
Windshield Washer Nozzle
Front Windshield Wiper System
Rear Windshield Wiper System
Console, LH
Operators Manual Holder, Canopy
Tilt Steering Column Covers
Stabilizer Cover with Pilot Control, Cab
Cab Right Hand Console Covers
Canopy Right Hand Console Covers
HVAC and Stabilizer Cover, Pilot Canopy
Monitor Console
Console and Loader Control Covers, Cab
Front Console and Loader Control Covers, Cab
Instrument Panel Console Cab
Backhoe Console ( - 000461)
Backhoe Console (000462 - )
Backhoe Console, 2-Lever with Extended Dipperstick and Auxiliary ( - 000461)
Backhoe Console, 2-Lever with Extended Dipperstick and Auxiliary (000462 - )
Mechanical Suspension Seat, Vinyl
Fleet Mechanical Suspension Seat, Vinyl
Air Suspension Seat, Cloth
Air Suspension Seat, Cloth Components
Mechanical Suspension Seat, Cloth
Mechanical Suspension Seat, Cloth Components
Heater Plumbing (Engine 4045HT086-DZ123583 4045TT096-DZ123593-)
Plumbing without Heater
Heating and Air Conditioning Module
Heating and Air Conditioning Module Components
Air Conditioning and Refrigerant Lines (Engine 4045HT086-DZ123583-)
Air Conditioning and Refrigerant Hose (Engine 4045TT096-DZ123593-)
Air Conditioning Condenser and Refrigerant Hose (Engine 4045HT086-DZ123583)
Air Conditioning Condenser and Refrigerant Lines (Engine 4045TT096-DZ123593)
Hood and Side Panels
Guard, Finger ( - 00097)
Guard, Finger (00098 - )
Grille Frame
Operator Station Fenders, Extended
Front Fenders
Premium Radio
Mounting Parts Without Radio
Exterior Rear View Mirror
Interior Rear View Mirror, Front Mounted
Interior Front View Mirror, Rear Mounted
Horn
Horn Front
Back-Up Alarm
Battery Enclosure and Tool Box
Sun Visor
Emergency Exit Hammer
Loader Arm Service Lock
Main Hydraulic Pump
Auto Idle Pressure Sensor
Power Beyond Hose, Manual Controls
Power Beyond Hose, Four Function Pilot Controls
Main Hydraulic Plumbing
Hydraulic Oil Filter
Hydraulic Reservoir Windshield Washer
Hydraulic Reservoir
Windshield Washer Reservoir
Connector Plug, without JDLink™
JDLink™ Modular Telematics Gateway (MTG) Antenna 4G
JDLink™ 4G Without Satellite Modular Controller Wiring Harness
Antenna Harness Connector Covers without JDLink™
Interior Front View Mirror Hardware, Rear Mounted (Engine 4045TBZ01-ETN107410)
Loader Mounting Component without Bucket
Loader Bucket-3102, 10 m³ (131 yd³)
132 yd³, 10 m³, 92 in, 234 M, Wide, Multipurpose Bucket with Bolt on Teeth Hydraulic
Multi-Purpose Bucket with Bolt on Edge Flip Fork Hydraulic Lines, 130 yd³, 096 m³, 92 in
Multipurpose Flip Fork Ready Bucket Kit with Teeth 096 m³ 92 in
Multi-Purpose Loader Bucket Cylinder
Loader Bucket (100 Cubic Meter) (130 Cubic Yard) (115 Cubic Yard) (150 Cubic Yard)
Loader Bucket 10 m³ (131 yd³)
Loader Control, Single Lever with Auxiliary
Loader Control, Single Lever with Auxiliary Lever
Loader Control, without Auxiliary
Loader Bucket Pins
Loader Lift Arm
Power Side Shift Hydraulic Cylinder
Power Side Shift Hydraulic Cylinder Components
Loader Bucket Linkage
Stabilizer Valve Circuit, Loader Five Function Valve, Dual Lever Control
Loader Valve Linkage, Fifth Function with Electrohydraulic Auxiliary
Loader Valve Linkage, Fourth Function
Ride Control Valve
Bucket Valve Circuit, Loader Valve
Stabilizer Valve Circuit, Loader Valve
Boom Valve Circuit, Loader Valve
Auxiliary Manual Valve Circuit, Loader Valve
Auxiliary Electrohydraulic Valve Circuit, Loader Valve
Loader and Stabilizer System Relief Valve Plug
Ride Control Plumbing
Ride Control Plumbing, Front Loader
Loader Valve Linkage, Fifth Function with Electrohydraulic Auxiliary Float Switch
Loader Plumbing, Left Side Second and Third Function Mounting Location (1_2)
Loader Plumbing, Left Side Second and Third Function Components (2_2)
Loader Auxiliary Plugs
Bootstrap Valve and Plumbing
Loader Coupler Pressure Manifold
Single Lever Loader Control Plumbing with Pilot Control
Single Lever Loader Control Plumbing with Manual Control
Loader Plumbing, 3-Function Right Side (1 of 2)
Loader Plumbing, 3-Function Right Side (2 of 2)
Left Side Second and Third Function Loader Plumbing
Loader Plumbing, 2-Function Right Side (1 of 2)
Loader Plumbing, 2-Function Right Side (2 of 2)
Loader Plumbing, 3-Function Right Side Dual Lever (2 of 2)
Loader Plumbing, 3-Function Right Side Dual Lever (1 of 2)
Loader Boom Cylinders and Pins
Loader Bucket Cylinder Components
Return to Dig, Wiring Harness
Loader Bucket Leveling Linkage
Heavy Duty Bucket with TK Teeth 6086 cm (2400 in) (75 ft)
Quick Coupler
Decoupling Rod and Mounting Hardware, Backhoe Spring Coupler
Stabilizer Control Bracket
Two Lever Backhoe Control Valve Linkage, Powered Side Shift
Backhoe Control Levers, SAE Link Plus Two Leaver
Stabilizer Control, Side Shift
Fifth Function Pedal, Two- Lever
Fifth Function Pedal, Pilot
Pilot Controller Arm, Right Hand
Pilot Controller Arm, Left Hand
Swing Lock Pin
Boom Lock Switch
Swing Frame and Pins
Sliding Frame
Backhoe Boom Lock
Boom Lock
Boom Lock, Side Shift Pilot Control
Sliding Frame, Powered Side Shift
Boom Lock And Side Shift Control - Extended Dipper, Pilot
Boom Lock And Side Shift Control, Pilot
Backhoe Boom
Backhoe Bucket Pin Assembly
Backhoe Bucket Links
Standard Dipper Plumbing Lines (2_4)
Standard Dipper Plumbing Lines (4_4)
Standard Dipper Plumbing Lines, Mounting Location (1_4)
Standard Dipper Plumbing Lines (3_4)
Standard Dipperstick and Auxiliary Hydraulics W_ Side Shift, Mounting Location (1_4)
Standard Dipperstick and Auxiliary Hydraulics W_ Side Shift, Mounting Location (2_4)
Standard Dipperstick and Auxiliary Hydraulics W_ Side Shift (3_4)
Standard Dipperstick and Auxiliary Hydraulics W_ Side Shift (4_4)
Extendable Dipperstick Plumbing and Auxiliary Hydraulics Lines, Mounting Location
Extendable Dipperstick Plumbing and Auxiliary Hydraulics Lines (3_4)
Extendable Dipperstick Plumbing and Auxiliary Hydraulics Lines (4_4)
Extendable Arm and Locking Pin
Standard Stabilizer Pads
Stabilizer Foot
Stabilizer Dirt Feet
Stabilizer Mechanical Lock
Stabilizer Mechanical Lock Hardware
4-Function Backhoe Control Valve
4-Function Backhoe Valve, Pilot
6-Function Backhoe Valve
6-Function Backhoe Valve, Pilot
Side Shift Locking Valve
Pilot Controller Valves and Joysticks
Pilot Enable Pattern Select Valve (PEPS) (000129 - )
Port Plugs, Six Function Backhoe Valve
Standard Dipperstick Hydraulics with Overload Warning, Lower Section (1 of 2)
Standard Dipperstick Hydraulics with Overload Warning, Upper Section
Standard Dipperstick Hydraulics with Overload Warning, Lower Section (2 of 2)
Extendable Dipperstick Plumbing and Auxiliary Hydraulics with Overload Warning,
Extendable Dipperstick Plumbing and Auxiliary Hydraulics with Overload Warning, Lower
Boom and Slide Lock Hydraulic, Pilot Controls
Power Slider Valve
Boom And Slide Lock Plumbing Pilot Controls
Boom Slide Lock Plumbing, Manual Controls
Power Sliding Plumbing
Boom Slide Lock Plumbing, Manual Controls, Power Slider
Stabilizer Cylinder Plumbing Side Shift
Extendable Dipperstick Plumbing with Auxiliary Hydraulics, Lower Section
Extendable Dipperstick Plumbing with Auxiliary Hydraulics, Upper Section
Hydraulic Cylinder Stabilizer Plumbing (1 of 2)
Hydraulic Cylinder Stabilizer Plumbing (2 of 2)
Standard Dipperstick Hydraulics, Upper Section
Standard Dipperstick Hydraulics, Lower Section
Pilot Control Hydraulics
Standard Dipperstick Plumbing with Overload Warning, Lower Section (1 of 2)
Standard Dipperstick and Auxiliary Hydraulics with Overload Warning, Upper Section
Standard Dipperstick and Auxiliary Hydraulics with Overload Warning, Lower Section (2 of
Auto Ride Control Valve Components
Pilot Enable Pattern Select Valve Plumbing Pilot Control
Swing Cylinder Plumbing Side Shift Unit
Standard Dipperstick and Auxiliary Hydraulics, Lower Section
Standard Dipperstick and Auxiliary Hydraulics, Upper Section
Standard Duty Bucket Cylinder, Shims, and Fitting
Swing Cylinders and Trunnion Block
Swing Cylinder Components
Boom Cylinder
Replacement Boom Cylinder
Crowd Cylinder, Standard Dipperstick
Crowd Cylinder Components
Crowd Cylinder, Extendable Dipperstick
Crowd Cylinder Components, Extendable Dipperstick
Heavy Duty Bucket Cylinder, Shims, and Fitting
