Martin Welker
104
230,792
John Deere 9986 Cotton Picker Parts Catalog PC2843
Brand: John Deere
Type of Machine: Cotton Picker
Model: John Deere 9986 Cotton Picker
Part Number: PC2843
Publication Date: 2003
Number of Pages: 614 Pages
A
A/C COMPRESSOR (6081HN003)
A/C COMPRESSOR HARDWARE KIT (6081HN003)
ABSORBER, FUEL INJECTION LINES (6081HN003)
ACCESS COVER FUEL INJECTION PUMP (6081HN003)
ACCUMULATOR AND BASKET DOOR OPEN-CLOSE
ACTIVE CAN BUS DEVICE
ADAPTER, OIL COOLER (6081HN003)
ADAPTER, OIL COOLER BYPASS (6081HN003)
ADAPTOR, HYDROSTATIC TO HYDRAULIC PUMP
ADJUST, OPERATOR’S SEAT
ADJUSTER, DOFFER, UPPER
ADJUSTING STRAP, ALTERNATOR (6081HN003)
AID, COLD WEATHER STARTING
AIR CLEANER AND AIR INTAKE TUBES
AIR CONDITIONER COMPRESSOR FAN PULLEY (6081HN003)
AIR CONDITIONER COMPRESSOR HOSE (6081HN003)
AIR CONDITIONER COMPRESSOR IDLER PULLEY (6081HN003)
AIR CONDITIONER COMPRESSOR SUPPORT (6081HN003)
AIR CONDITIONING AND HEATER DUCTS
AIR CONDITIONING AND HEATER HOUSING, LOWER
AIR CONDITIONING AND HEATER HOUSING, UPPER
AIR CONDITIONING COMPRESSOR (6081HN003)
AIR CONDITIONING COMPRESSOR HARDWARE KIT (6081HN003)
AIR CONDITIONING CONDENSER
AIR CONDITIONING SYSTEM - RECEIVER-DRYER
AIR CONDITIONING SYSTEM, EVAPORATOR HEATER
AIR CONDITIONING SYSTEM, WATER VALVE
AIR CONDITIONING WIRING HARNESS
AIR COOLER
AIR DUCT, INTAKE
AIR MANIFOLD AND DUCTS
AIR TUBES AND NOZZLES
ALTERNATOR BRACKETS (6081HN003)
ANGLE, PICKING UNIT BOTTOM FRAME (PRO-12 UNIT)
ANGLE, PICKING UNIT BOTTOM FRAME (PRO-16 UNIT)
ANTENNA, SPEAKERS AND RADIO
ARM, PICKER BAR
ARM, STALKLIFTER PIVOT PRO-12 - 18S
ARMREST CONTROL PANEL, OPERATOR’S
ARMREST PANEL, OPERATOR’S
ARMREST ROCKER SWITCHES
ARMREST WIRING HARNESS
ARMREST, OPERATOR’S SEAT
ARMS, ROCKER (6081HN003)
ARMS, UNIT LIFT
ASHTRAY
ASHTRAY
ASSEMBLY, FINGER GRATES (S/N -14000)
ASSEMBLY, FINGER GRATES (S/N 14001- )
AUGER, COMPACTOR
AXLE KNEE AND KNUCKLE, REAR
AXLE PIVOT SUPPORT, FRONT
AXLE PIVOT SUPPORT, REAR
AXLE SPACERS
AXLE SPACERS
AXLE TIE RODS, REAR
AXLE, FINAL DRIVE
AXLE, FRONT
AXLE, REAR CENTER
B
BAR DRUM, STUD AND BEARING, PICKER
BAR, GRID, PICKING UNIT (PRO-12 18S)
BAR, GRID, PICKING UNIT (PRO-16 20S)
BAR, MIRROR
BAR, PICKER
BASE, FUEL FILTER (6081HN003)
BASE, OIL FILTER (6081HN003)
BASKET ASSEMBLY, LOWER FRONT
BASKET ASSEMBLY, LOWER REAR
BASKET ASSEMBLY, LOWER, RIGHT SIDE
BASKET DOOR CONVEYOR
BASKET DOOR CONVEYOR CHAIN PROTECTORS AND SUPPORTS
BASKET DOOR EXTENSION
BASKET DOOR FLAP AND SAFETY SWITCH
BASKET DOOR OPEN-CLOSE AND ACCUMULATOR HYDRAULIC LINES
BASKET DOOR OPENING, UPPER
BASKET DOOR STRUCTURE
BASKET EXTENSION HYDRAULICS
BASKET EXTENSION LATCH
BASKET EXTENSION LID ASSEMBLY
BASKET EXTENSION, FRONT
BASKET EXTENSION, LEFT
BASKET EXTENSION, REAR
BASKET EXTENSION, RIGHT
BASKET FLOOR
BASKET FLOOR BRUSHES
BASKET FLOOR CONVEYOR
BASKET FLOOR CONVEYOR CHAIN PROTECTORS AND SUPPORTS
BASKET FULL MONITORING SYSTEM
BASKET HOOD ASSEMBLY
BASKET LAMPS AND WIRING HARNESS
BASKET LID EXTENSION
BASKET LID HANDRAILS
BASKET RAISE HYDRAULICS
BASKET STAND, REAR
BASKET SUPPORT ASSEMBLY
BASKET WIPER FLAP
BATTERIES AND CABLES
BATTERY SUPPORT TRAY
BEAM, BASKET SUPPORT
BEARING CAP, FINAL DRIVE
BEARING, PICKER BAR DRUM
BEARINGS, FINAL DRIVE
BEARINGS, MAIN AND MAIN THRUST (6081HN003)
BELT TENSIONER, ALTERNATOR (6081HN003)
BELT, ALTERNATOR (6081HN003)
BELT, COTTON FAN DRIVE
BELT, ENGINE FAN DRIVE
BELT, HYDRAULIC PUMP DRIVE
BELT, INSTRUCTIONAL SEAT
BELT, OPERATOR’S ARMREST CONTROL PANEL
BELT, ROTARY SCREEN DRIVE
BELT, UNIT DRIVE COUNTERSHAFT
BELT, WATER PUMP DRIVE
BELTS, ENGINE DRIVE AND DRIVEN
BELTS, ENGINE FAN
BEVEL GEAR, COMPACTOR DRIVE
BLADE, VINE CUTTER
BLEED SCREW, BRAKE SLAVE CYLINDER
BLOCK HEATER
BLOCK, COMPLETE, ASSEMBLY(CBA) (BLOCK AND CYLINDER HEAD)
BLOCK, SHORT
BOLTS, CYLINDER HEAD (6081HN003)
BOOT, HYDROSTATIC CONTROL CABLE
BOTTOM FRAME, PICKING UNIT (PRO-12 UNIT)
BOTTOM FRAME, PICKING UNIT (PRO-16 UNIT)
BOX, MONITOR
BRACE, FEEDBACK SENSOR, ROW-TRAK
BRACKET, DOFFER IDLER GEAR
BRACKET, ETHER AID (6081HN003)
BRACKET, TRANSMISSION
BRACKET, WATER PUMP
BRACKETS, ALTERNATOR (6081HN003)
BRACKETS, FIRE EXTINGUISHER
BRACKETS, FLOOR BRUSHES
BRACKETS, MIRROR
BRAKE CYLINDER, MASTER
BRAKE LINES AND RESERVOIR
BRAKE PEDAL AND MASTER CYLINDER
BRAKE PEDAL AND SEAL, PARKING
BRAKE SHOES AND DRUM
BREAKERS, CIRCUIT
BREATHER, FUEL TANK
BRUSH BRACKETS, FLOOR
BRUSHES, BASKET FLOOR
BULB. INTERIOR CAB ROOF
BULB, ARMREST CONTROL PANEL
BULB, CAB ROOF LIGHT
BULB, OVERHEAD CONSOLE
BULB, STEERING COLUMN CONTROLS
BUSHING, CAMSHAFT (6081HN003)
BYPASS TUBES, OIL COOLER (6081HN003)
BYPASS VALVE, OIL FILTER (6081HN003)
C
CAB AIR FILTER AND HOUSING
CAB DOOR AND GLASS
CAB DOOR LATCH
CAB GLASS AND DOOR
CAB INTERIOR TRIM PANELS
CAB REAR AND SIDE SEALS
CAB ROOF
CAB ROOF LIGHTS
CAB, COMPLETE
CAB, MAIN WIRING HARNESS
CABINET, PLUGS AND GROMMETS
CABLE, HYDROSTATIC CONTROL
CABLE, REAR DRUM PRESSURE PLATE (PRO-12 18S)
CABLE, REAR DRUM PRESSURE PLATE (PRO-16 20S)
CABLE, WIRING
CABLES, BATTERY
CAM, PICKER DRUM
CAMSHAFT BUSHING (6081HN003)
CAMSHAFT FOLLOWER (6081HN003)
CAMSHAFT GEAR (6081HN003)
CAN BUS DEVICE, ACTIVE
CAN BUS DEVICE, PASSIVE
CAP, FUEL
CAP, HYDRAULIC RESERVOIR
CAP, HYDROSTATIC PUMP END
CAP, LUBRICATION TANK
CAP, REAR WHEEL BEARING
CAPS, MAIN BEARING (6081HN003)
CASE, GEAR, PICKING UNIT
CASE, MONITOR
CASE, TRANSMISSION
CHAIN PROTECTORS AND SUPPORTS, BASKET DOOR CONVEYOR
CHAIN PROTECTORS AND SUPPORTS, BASKET FLOOR CONVEYOR
CHAIN, BASKET DOOR EXTENSION
CHAIN, CONVEYOR, BASKET DOOR
CHAIN, CONVEYOR, BASKET FLOOR
CHAIN, LIFT ARM
CHAIN, LOW COTTON, PRO-12 - 18S
CHANNEL, BASKET DOOR EXTENSION
CHANNEL, PICKING UNIT BOTTOM FRAME (PRO-12 UNIT)
CHANNEL, PICKING UNIT BOTTOM FRAME (PRO-16 UNIT)
CHARGE AIR PIPING
CHARGE PUMP SHAFT, HYDROSTATIC
CHARGE PUMP, HYDROSTATIC DRIVE
CHARGE RELIEF VALVE, HYDROSTATIC PUMP
CHASSIS SIDE SHIELDING
CHASSIS WIRING HARNESS
CHECK VALVE, FUEL TANK
CHECK VALVE, HEATING AND AIR CONDITIONER
CHECK VALVE, HYDROSTATIC PUMP
CHECK VALVE, WATER SYSTEM
CHECK VALVE, WATER TANK
CIGARETTE LIGHTER
CIRCUIT BOARD, OPERATOR’S ARMREST CONTROL PANEL
CIRCUIT BOARD, OVERHEAD CONSOLE
CIRCUIT BOX, HEATER AND AIR CONDITIONER
CIRCUIT BREAKERS AND RELAYS
CLAMPS, FUEL INJECTION LINES (6081HN003)
CLEAN-OUT DOOR, COTTON DOOR
CLEANING SOLUTION, SPINDLE
CLUTCH, COMPRESSOR (6081HN003)
CLUTCH, FAN DRIVE
CLUTCH, SLIP, DRUM ( -16000)
CLUTCH, SLIP, DRUM (16001- )
CLUTCH, SLIP, LOWER GEAR CASE HUB
CLUTCH, STARTING MOTOR (6081HN003)
COIL, FAN
COLD WEATHER START BUTTON
COLD WEATHER STARTING AID
COLUMN, SPINDLE MOISTENER
COMPACTOR
COMPACTOR HYDRAULIC LINES
COMPACTOR SWITCH, FOOT CONTROL
COMPLETE BLOCK ASSEMBLY(CBA) (BLOCK AND CYLINDER HEAD)
COMPLETE CAB
COMPRESSOR HARDWARE KIT, AIR CONDITIONING (6081HN003)
COMPRESSOR PARTS (REFRIGERANT) (6081HN003)
COMPRESSOR, AIR CONDITION, HOSE (6081HN003)
COMPRESSOR, AIR CONDITIONING (6081HN003)
COMPRESSOR, CLUTCH (6081HN003)
CONNECTING RODS/CYLINDER LINER/PISTON (6081HN003)
CONNECTOR, CONSOLE SWITCH
CONNECTOR, ELECTRICAL, WEATHERPACK
CONNECTOR, ELECTRONIC CONTROLLER, ENGINE SPEED SENSOR AND HORN
CONNECTOR, FUEL INJECTION NOZZLE (6081HN003)
CONNECTOR, KEY SWITCH, CONSOLE LIGHT, ETHER SWITCH AND WARNING HORN
CONNECTOR, MONITOR LIGHT MODULE AND TACHOMETER
CONNECTORS, FUEL INJECTION PUMP HOUSING (6081HN003)
CONSOLE LIGHT CONNECTOR
CONSOLE SWITCH CONNECTOR
CONSOLE, OVERHEAD
CONTAINER, TRASH
CONTROL CABLE, HYDROSTATIC
CONTROL PANEL, OPERATOR’S ARMREST
CONTROL VALVE, CONVEYOR
CONTROL VALVE, UNIT LIFT
CONTROL VALVES AND MANIFOLD, WATER
CONTROLLER, ENGINE
CONVENIENCE OUTLET, KIT
CONVEYOR CHAIN PROTECTORS, BASKET DOOR
CONVEYOR CHAIN PROTECTORS, BASKET FLOOR
CONVEYOR CONTROL VALVE
CONVEYOR DOOR FRAME
CONVEYOR DOOR WING ASSEMBLIES
CONVEYOR EXTENSION, DOOR
CONVEYOR HYDRAULICS, FLOOR AND DOOR
COOLANT RECOVERY SYSTEM
COOLANT TEMPERATURE SENDER (6081HN003)
COOLER BYPASS TEE, HYDROSTATIC
COOLER, ENGINE OIL (6081HN003)
COOLER, HYDRAULIC OIL
COOLING PACKAGE SUPPORT
COTTON DOOR NUMBER 6 OFFSET
COTTON DOORS
COTTON FAN AND DRIVE
COUNTERSHAFT, UNIT DRIVE
COUPLING, HYDROSTATIC TO HYDRAULIC PUMP
COVER, ALTERNATOR (6081HN003)
COVER, CYLINDER HEAD TOP (6081HN003)
COVER, FUEL INJECTION PUMP ACCESS (6081HN003)
COVER, INSPECTION, HEAT EXCHANGER
COVER, OIL COOLER (6081HN003)
COVER, OIL DIPSTICK (ENGINE SERIAL NO. 209311- )
COVER, ROCKER ARM (6081HN003)
CRANKSHAFT (6081HN003)
CRANKSHAFT OIL SEAL AND HOUSING (6081HN003)
CRANKSHAFT PULLEY AND DAMPENERS (6081HN003)
CROSS SHAFT AND UNIVERSAL JOINT
CUSHION, OPERATOR’S SEAT
CUSHION, SEAT, PASSENGER
CUTTER, VINE
CYLINDER BLOCK FITTINGS (6081HN003)
CYLINDER BLOCK, HYDROSTATIC PUMP
CYLINDER HAD TOP COVER (6081HN003)
CYLINDER HEAD AND VALVES (6081HN003)
CYLINDER HEAD GASKET KIT (6081HN003)
CYLINDER LINER/CONNECTING RODS/PISTON (6081HN003)
CYLINDER SEAL KIT, STEERING
CYLINDER STOP, UNIT LIFT ARM
CYLINDER, ACCUMULATOR HYDRAULIC LINES
CYLINDER, BASKET DOOR OPEN-CLOSE AND ACCUM. HYDRAULIC
CYLINDER, BASKET EXTENSION HYDRAULIC
CYLINDER, BASKET RAISE HYDRAULIC
CYLINDER, BRAKE PEDAL
CYLINDER, BRAKE SLAVE
CYLINDER, BRAKE, MASTER
CYLINDER, HYDRAULIC, 2-1/2" X 12" (EATON)
CYLINDER, HYDRAULIC, 3-1/2" X 24" (BASKET RAISE-UNLOAD)
CYLINDER, HYDRAULIC, 3-3/4" X 8" (UNIT LIFT)
CYLINDER, MASTER BRAKE
CYLINDER, STEERING
CYLINDERS, HYDRAULIC (DUCT SUPPORT)
D
DAMPENER KEY (6081HN003)
DAMPENERS AND PULLEY, CRANKSHAFT (6081HN003)
DECALS
DECALS
DECALS
DECALS
DECALS - "IMPORTANT"
DECALS, FUSES
DECALS, INSTRUCTIONS
DECALS, SAFETY
DECALS, UNIT LOCATION
DIFFERENTIAL (TRANSMISSION)
DIODE, LOAD CENTER WIRING HARNESS
DIPSTICK COVER (ENGINE SERIAL NO. 209311- )
DIPSTICK COVER GASKET (ENGINE SERIAL NO. 209311- )
DIPSTICK, ENGINE OIL (6081HN003)
DISC, DOFFER
DISPLACEMENT CONTROL, HYDROSTATIC PUMP
DISTRIBUTOR ASSEMBLY, MOISTENER
DOFFER
DOFFER ADJUSTER AND STUB SHAFT
DOFFER DRIVE IDLER GEAR
DOFFER GAUGES
DOFFER IDLER GEARS
DOME LIGHT EXTENSION WIRING HARNESS
DOOR AND FLOOR CONVEYOUR HYDRAULIC LINES
DOOR ASSEMBLY, COTTON
DOOR CONTACT SWITCH WIRING HARNESS
DOOR EXTENSION, BASKET
DOOR HINGE, CONVEYOR
DOOR LATCH, CAB
DOOR OPEN-CLOSE HYDRAULIC LINES, BASKET
DOOR OPENING, BASKET, UPPER
DOOR SAFETY SWITCH AND FLAP
DOOR STRUCTURE, BASKET
DOOR WING ASSEMBLY, CONVEYOR
DOOR, CAB AND GLASS
DOOR, COTTON NUMBER 6 OFFSET
DOOR, ROTARY SCREEN
DOOR, ROTARY SCREEN
DOORS, HYDRAULIC MODULE
DOORS, UNIT
DOORS, UNIT, PRO-12 - 18S
DRIVE BELTS AND PULLEYS ARRANGEMENT
DRIVE GEAR, OIL PUMP (6081HN003)
DRIVE GEARS, UPPER HOUSING DRUM
DRIVE SHAFT, FINAL DRIVE
DRIVE SHAFT, SPLINED
DRIVE SHAFT, UNIT
DRIVE WHEELS, SINGLE
DRIVE, ENGINE FAN
DRIVE, FINAL
DRIVE, PUMP, HYDROSTATIC
DRUM DRIVE GEARS, UPPER HOUSING
DRUM HEAD AND CAM
DRUM SLIP CLUTCH AND IDLER GEARS ( -16000)
DRUM SLIP CLUTCH AND IDLER GEARS (16001- )
DRUM SPEED SENSOR
DRUM SPPED MONITOR FIRMWARE UPGRADE
DRUM, BRAKE
DRUM, PICKER BAR
DUAL WHEELS
DUCT SUPPORT
DUCT SUPPORT HYDRAULIC HOSES
DUCT, LADDER
DUCT, ROTARY SCREEN
DUCTS, AIR
DUCTS, HEATER AND AIR CONDITIONING
DUCTS, UNIT TO BASKET
DUCTS, UNIT TO BASKET (36"-38"-40")
E
ECU
ELBOW TRANSITION, JET POST
ELECTRICAL CONNECTOR SERVICE KIT
ELECTRICAL CONNECTOR, CONSOLE SWITCH
ELECTRICAL CONNECTOR, ELECTRONIC CONTROLLER, ENGINE SPEED SENSOR, HORN
ELECTRICAL CONNECTOR, KEY SWITCH, CONSOLE LIGHT, ETHER SWITCH, HORN
ELECTRICAL CONNECTOR, MONITOR LIGHT MODULE AND TACHOMETER
ELECTRICAL TERMINALS AND CONNECTORS, WEATHERPACK
ELECTRICAL WIRING HARNESS, CAB
ELECTRICAL WIRING SCHEMATIC
ELECTRICALLY OPERATED STARTING AID
ELECTRONIC CONTROL UNIT, (OPTIONAL ROWTRAK)
ELECTRONIC CONTROLLER CONNECTOR
ELEMENT, AIR CLEANER
END CAP, HYDROSTATIC PUMP
ENGINE CONTROLLER
ENGINE CONTROLLER, FOCUS
ENGINE COOLANT HEATER
ENGINE DRIVE AND DRIVEN BELTS & PULLEYS
ENGINE FAN AND DRIVES
ENGINE FAN DRIVE
ENGINE HOODS
ENGINE OIL COOLER (6081HN003)
ENGINE OIL DIPSTICK (6081HN003)
ENGINE OIL DIPSTICK TUBE (6081HN003)
ENGINE OIL FILTER (6081HN003)
ENGINE OIL PRESSURE SWITCH (6081HN003)
ENGINE OIL PUMP (6081HN003)
ENGINE OVERHAUL KIT
ENGINE REBUILD GASKET KIT (6081HN003)
ENGINE SIDE FRAMES
ENGINE SPEED SENSOR (6081HN003)
ENGINE SPEED SENSOR CONNECTOR
ENGINE WIRING HARNESS
ETHER AID BRACKET (6081HN003)
ETHER START BUTTON
ETHER STARTING FLUID
ETHER SWITCH CONNECTOR
EVAPORATOR HEATER, AIR CONDITIONER
EXHAUST MANIFOLDS (6081HN003)
EXHAUST PIPE
EXHAUST VALVES AND SHIELD (6081HN003)
EXTENSION AND GRATE, STALKLIFTERS PRO-12 - 18S
EXTENSION LID ASSEMBLY, BASKET
EXTENSION, BASKET DOOR
EXTENSION, BASKET LID
EXTENSION, BASKET, FRONT
EXTENSION, BASKET, LEFT
EXTENSION, BASKET, REAR
EXTENSION, BASKET, RIGHT
EXTENSION, PLATFORM FLOOR (38" & 40"/64" SKIP ROW)
EXTENSION, PLATFORM FLOOR (4 ROW 34" SINGLE WHL.)
EXTENSION, PLATFORM FLOOR (4 ROW)
EXTENSION, PLATFORM FLOOR (6 ROW)
EXTENSIONS, UNIT LIFT FRAME
EXTINGUISHER, FIRE
F
FAN
FAN DRIVE (6081HN003)
FAN DRIVE, ENGINE
FAN PULLEY, AIR CONDITIONER COMPRESSOR (6081HN003)
FAN, ALTERNATOR (6081HN003)
FAN, BLOWER, HEATER AND AIR CONDITIONER
FAN, ENGINE
FAN, HEATER AND AIR CONDITIONER
FEEDBACK LINK, HYDROSTATIC PUMP
FEEDBACK SENSOR BRACE, ROW-TRAK
FIELD OFFICE
FILL HOSE, LUBRICATION
FILTER/PRE-FUEL FILTER AND LINES, FUEL (6081HN003)
FILTER, AIR (ENGINE)
FILTER, AIR, RECIRCULATION
FILTER, CAB AIR
FILTER, ENGINE OIL (6081HN003)
FILTER, EVAPORATOR HEATER
FILTER, GREASE
FILTER, HYDRAULIC RESERVOIR
FILTER, WATER
FINAL DRIVE
FINAL DRIVE AXLE, GEAR AND BEARINGS
FINAL DRIVE HOUSING AND BEARING CAP
FINAL DRIVE PINION, DRIVE SHAFTS AND BEARINGS
FINGER GRATES ASSEMBLY (S/N -14000)
FINGER GRATES ASSEMBLY (S/N 14001- )
FIRE EXTINGUISHER
FIRMWARE, DRUM SPEED MONITOR UPGRADE
FITTINGS, CYLINDER BLOCK (6081HN003)
FITTINGS, HYDROSTATIC SOLENOID VALVE
FIXTURE, FEEDBACK SENSOR, ROW-TRAK
FLANGE, PICKER BAR DRUM
FLAP MONITOR
FLAP, BASKET DOOR
FLAP, BASKET WIPER
FLAP, LOWER BASKET
FLOOR AND DOOR CONVEYOR HYDRAULIC LINES
FLOOR BRUSH BRACKETS
FLOOR BRUSHES
FLOOR MAT
FLOOR PANELS
FLOOR, BASKET
FLOORS, OUTSIDE OF CAB (38" & 40"/64" SKIP ROW)
FLOORS, OUTSIDE OF CAB (4 ROW 34" SINGLE WHL.)
FLOORS, OUTSIDE OF CAB (4 ROW)
FLOORS, OUTSIDE OF CAB (6 ROW)
FLUIDS, SPINDLE CLEANER AND WETTING AGENT
FLUSH SYSTEM SWITCH, FOOT CONTROL
FLUSH WATER LINES AND FITTINGS
FLYWHEEL (6081HN003)
FLYWHEEL HUB (6081HN003)
FOCUS ENGINE CONTROLLER
FOLLOWER, CAMSHAFT (6081HN003)
FOOT CONTROL SWITCHES, COMPACTOR AND FLUSH SYSTEM
FRAME ASSEMBLY, HYDRO PUMP
FRAME SUPPORT, COOLING
FRAME, CONVEYOR DOOR
FRAME, DUCT SUPPORT
FRAME, ENGINE SIDE
FRAME, MAIN
FRAME, PICKING UNIT BOTTOM (PRO-12 UNIT)
FRAME, PICKING UNIT BOTTOM (PRO-16 UNIT)
FRAME, PLATFORM (S/N -14000)
FRAME, PLATFORM (S/N 14001- )
FRAMES, UNIT LIFT
FRONT AXLE
FRONT CHASSIS WIRING HARNESS
FRONT DRUM PRESSURE PLATE (PRO-12 18S)
FRONT DRUM PRESSURE PLATE (PRO-16 20S)
FRONT OIL SEAL AND TIMING GEAR COVER (6081HN003)
FRONT WHEEL SHIELD, LH, 4 ROW WITH DUAL WHEELS
FRONT WHEEL SHIELD, RH
FUEL CHECK VALVE (6081HN003)
FUEL COOLER KIT
FUEL FILTER/PRE-FUEL FILTER AND LINES (6081HN003)
FUEL GAUGE
FUEL INJECTION NOZZLES AND LINES (6081HN003)
FUEL INJECTION PUMP ACCESS COVER (6081HN003)
FUEL INJECTION PUMP AND LINES
FUEL INJECTION PUMP HOUSING CONNECTORS (6081HN003)
FUEL LEAK-OFF LINE (6081HN003)
FUEL SENDER AND REAR LIGHTS WIRING HARNESS
FUEL TANK WITH FUEL COOLER
FUEL TEMPERATURE SENSOR
FUEL TRANSFER PUMP (ROBERT BOSCH) (6081HN003)
FUSES, DECALS
FUSES, RELAYS AND CIRCUIT BREAKERS
G
GASKET KIT, CYLINDER HEAD (6081HN003)
GASKET KIT, ENGINE REBUILD (6081HN003)
GASKET KIT, SHORT BLOCK (6081HN003)
GASKET, CYLINDER HEAD (6081HN003)
GASKET, CYLINDER HEAD TOP COVER (6081HN003)
GASKET, DIPSTICK COVER (ENGINE SERIAL NO. 209311- )
GASKET, INTAKE MANIFOLD (6081HN003)
GASKET, OIL FILTER HOUSING (6081HN003)
GASKET, OIL PAN
GASKET, OIL PAN
GASKET, OIL PUMP INTAKE (ESN -209310)
GASKET, REAR OIL SEAL (6081HN003)
GASKET, ROCKER ARM COVER (6081HN003)
GASKET, WATER MANIFOLD (6081HN003)
GASKET, WATER PUMP (6081HN003)
GASKET,OIL PUMP (ESN 209311- )
GASKETS, EXHAUST MANIFOLD (6081HN003)
GASKETS, OIL PUMP (6081HN003)
GASKETS, TURBOCHARGER
GAUGES, DOFFER
GAUGES, MONITOR
GEAR BOX, SKIP ROW
GEAR CASE HUB, LOWER
GEAR CASE, PICKING UNIT
GEAR, CAMSHAFT (6081HN003)
GEAR, DOFFER
GEAR, DOFFER DRIVE IDLER
GEAR, DOFFER IDLER
GEAR, FINAL DRIVE
GEAR, FUEL INJECTION PUMP
GEAR, OIL PUMP DRIVE (6081HN003)
GEAR, STARTER (6081HN003)
GEAR, WATER PUMP (6081HN003)
GEARS, DIFFERENTIAL
GEARS, DRUM IDLER ( -16000)
GEARS, DRUM IDLER (16001- )
GEARS, PICKER BAR
GEARS, TRANSMISSION INPUT
GEARS, TRANSMISSION INTERMEDIATE
GEARS, UPPER HOUSING DRUM DRIVE
GEARSHIFT LEVER AND LINKAGE
GLASS, CAB AND DOOR
GRATE, FINGER, BASKET EXTENSION LID
GRATE, STALKLIFTER, PRO-12 - 18S
GREASE CHIME CONNECTOR
GREASE MANIFOLD
GREASE PUMP SYSTEM
GREASE TANK
GREEN FLUSH WATER LINES
GRID BARS AND SUPPORTS, PICKING UNIT (PRO-12 18S)
GRID BARS AND SUPPORTS, PICKING UNIT (PRO-16 20S)
GRILLE, RADIO SPEAKER
GRILLE, SPEAKER
GROMMETS, UNIT CABINET
GROUND WIRE, A/C ELECTRIC CLUTCH (6081HN003)
GUARD, TANK (S/N -14000)
GUARD, TANK (S/N 14001-)
GUIDANCE SYSTEM PROBE ASSEMBLY (S/N -14000)
GUIDANCE SYSTEM PROBE ASSEMBLY (S/N 14001-)
GUIDE, PLANT, PRO-12 - 18S
H
HANDLE BASKET RESET
HANDLE, CAB
HANDLE, CAB DOOR
HANDLE, OPERATORS CONTROL PANEL
HANDLE, UNIT DOOR
HANDLE, UNIT DOOR, PRO-12 - 18S
HANDRAILS, BASKET LID
HANDRAILS, PLATFORM (4 ROW)
HANDRAILS, PLATFORM (6 ROW)
HANGER, PICKING UNIT
HARDWARE KIT, AIR CONDITIONING COMPRESSOR (6081HN003)
HARNESS, BASKET LAMP WIRING
HARNESS, CHASSIS WIRING
HARNESS, DOOR CONTACT SWITCH WIRING
HARNESS, ENGINE WIRING
HARNESS, FRONT CHASSIS WIRING
HARNESS, HYDRO PUMP AND RESERVOIR WIRING
HARNESS, LOAD CENTER WIRING
HARNESS, MAIN CAB WIRING
HARNESS, PICKING UNIT WIRING
HARNESS, REAR LIGHTS AND FUEL SENDER WIRING
HARNESS, STEERING COLUMN
HARNESS, TETHER SWITCH (NO. 3 OR 4 UNIT)
HARNESS, UNIT SPEED SYNCHRONIZATION (SERVICE TOOL)
HARNESS, WIRING, PICKING UNIT
HEAD AND VALVES, CYLINDER (6081HN003)
HEAD, PICKER DRUM
HEADER, PRE-FUEL FILTER (6081HN003)
HEADLINER, CAB
HEAT EXCHANGER CORES
HEAT EXCHANGER HOODS
HEAT SHIELD, AIR TUBE
HEATER AND AIR CONDITIONING DUCTS
HEATER AND AIR CONDITIONING HOUSING, LOWER
HEATER AND AIR CONDITIONING HOUSING, UPPER
HEATER HOSES
HEATER, ENGINE COOLANT
HEIGHT SENSING LINKAGE AND SENSOR
HINGE, CONVEYOR DOOR
HINGE, PASSENGER SEAT CONSOLE
HOLDER, MOISTENER PAD
HOOD ASSEMBLY, BASKET
HOODS, ENGINE
HOODS, HEAT EXCHANGER
HORN
HORN BUTTON
HORN CONNECTOR
HORN CONNECTOR, 3-SECOND AND PULSING
HOSE, ACCUMULATOR HYDRAULIC LINES
HOSE, AIR CONDITIONER COMPRESSOR (6081HN003)
HOSE, BASKET DOOR OPEN-CLOSE HYDRAULIC
HOSE, BASKET EXTENSION HYDRAULIC
HOSE, BASKET RAISE HYDRAULIC
HOSE, FLOOR AND DOOR CONVEYOR HYDRAULIC
HOSE, LIFT ARM LUBRICATION
HOSE, LUBRICATION FILL
HOSE, LUBRICATION MANIFOLD
HOSE, LUBRICATION PUMP
HOSE, LUBRICATION TANK
HOSE, ROTARY SCREEN
HOSE, ROW-TRAK STEERING VALVE (S/N -14000)
HOSE, UNIT LUBRICATION
HOSE, WATER PUMP
HOSES, DUCT SUPPORT HYDRAULIC
HOSES, FLUSH WATER, GREEN
HOSES, HEATER
HOSES, HYDRAULIC OIL COOLER
HOSES, HYDRAULIC UNIT LIFT
HOSES, HYDRAULIC UNIT LIFT RETURN
HOSES, HYDROSTATIC
HOSES, LUBRICATION TRANSFER PUMP
HOSES, RADIATOR
HOSES, STEERING HYDRAULIC
HOSES, WATER TANK
HOSES, WATER VALVE
HOSES, WATER, MOISTENER COLUMN (CLEAR)
HOUSING CONNECTORS, FUEL INJECTION PUMP (6081HN003)
HOUSING, AIR CONDITIONER/HEATER, LOWER
HOUSING, AIR CONDITIONER/HEATER, UPPER
HOUSING, CAB AIR FILTER
HOUSING, FAN
HOUSING, FINAL DRIVE
HOUSING, HYDROSTATIC PUMP
HOUSING, MANIFOLD (WATER, GREASE AND HYDRAULIC)
HOUSING, MONITOR
HOUSING, OIL FILTER (6081HN003)
HOUSING, PICKING UNIT
HOUSING, PICKING UNIT UPPER (PRO-12 UNIT)
HOUSING, PICKING UNIT UPPER (PRO-16 UNIT)
HOUSING, REAR OIL SEAL (6081HN003)
HOUSING, THERMOSTAT (6081HN003)
HOUSING, TRANSMISSION
HOUSING, UPPER DOFFER ADJUSTING
HUB, FLYWHEEL (6081HN003)
HUB, LOWER GEAR CASE
HUB, REAR WHEEL
HYDRAULIC CONTROL VALVE, UNIT LIFT
HYDRAULIC CONTROL, CONVEYOR
HYDRAULIC CYLINDER, 2-1/2" X 12" (EATON)
HYDRAULIC CYLINDER, 3-1/2" X 24" (BASKET RAISE-UNLOAD)
HYDRAULIC CYLINDER, 3-3/4" X 8" (UNIT LIFT)
HYDRAULIC CYLINDERS (DUCT SUPPORT)
HYDRAULIC HOSE, ROW-TRAK STEERING VALVE (S/N -14000)
HYDRAULIC HOSES, DUCT SUPPORT
HYDRAULIC HOSES, LUBRICATION PUMP
HYDRAULIC HOSES, UNIT LIFT
HYDRAULIC LIFT RETURN HOSES
HYDRAULIC LINES, BASKET DOOR OPEN-CLOSE AND ACCUMULATOR
HYDRAULIC LINES, BASKET EXTENSION
HYDRAULIC LINES, BASKET RAISE
HYDRAULIC LINES, COMPACTOR
HYDRAULIC LINES, FLOOR AND DOOR CONVEYOR
HYDRAULIC MODULE PANELS AND DOORS
HYDRAULIC MOTOR ASSY., 100 CC SAUER-SUNDSTRAND (PROPULSION)
HYDRAULIC MOTOR ASSY., 75 CC SAUER-SUNDSTRAND (UNIT DRIVE)
HYDRAULIC MOTOR, TRANSMISSION DRIVE
HYDRAULIC OIL COOLER AND HOSES
HYDRAULIC OIL, HY-GARD
HYDRAULIC PUMP (45 CM3 (2.75 CU. IN.))
HYDRAULIC RESERVOIR
HYDRAULIC STEERING LINES AND HOSES
HYDRO PUMP MODULE ASSEMBLY
HYDRO PUMPS AND RESERVOIR WIRING HARNESS
HYDROSTATIC CIRCUIT
HYDROSTATIC DRIVE CHARGE PUMP
HYDROSTATIC PUMP
HYDROSTATIC PUMP AUXILIARY PUMP MOUNTING
HYDROSTATIC PUMP CONTROL LEVERS AND RODS
HYDROSTATIC PUMP DISPLACEMENT CONTROL
HYDROSTATIC PUMP DRIVE
HYDROSTATIC PUMP END CAP
HYDROSTATIC PUMP HOUSING, SWASHPLATE AND CYLINDER BLOCK
HYDROSTATIC PUMP SHAFT AND SERVO ASSY.
HYDROSTATIC PUMP VALVES, PLUGS AND SEALS
HYDROSTATIC SOLENOID VALVE FITTINGS
I
IDLER ARM, ROTARY SCREEN DRIVE
IDLER GEAR, DOFFER DRIVE
IDLER GEARS, DRUM ( -16000)
IDLER GEARS, DRUM (16001- )
IDLER PULLEY, AIR CONDITIONER COMPRESSOR (6081HN003)
IGNITION SWITCH
IMPELLER, WATER PUMP
IMPELLER, WATER PUMP (6081HN003)
INJECTION NOZZLES AND LINES, FUEL (6081HN003)
INJECTION PUMP AND LINES, FUEL
INPUT SHAFT, TRANSMISSION
INSERTS, VALVE SEAT (6081HN003)
INSIDE CAB MIRROR
INSTRUCTIONAL SEAT SEATBELT
INTAKE MANIFOLD GASKET (6081HN003)
INTAKE MANIFOLD TEMPERATURE SENSOR
INTAKE VALVES (6081HN003)
INTAKE, OIL PUMP (ESN -209310) (U/WRE508040)
INTAKE,OIL PUMP (ESN 209311- ) (U/W RE506166)
INTERMEDIATE SHAFT, TRANSMISSION
J
JACKSHAFT, UNIT DRIVE
JET POST TRANSITION ELBOW
JOURNAL, PICKER BAR
K
KEY SWITCH CONNECTOR
KEY, DAMPENER (6081HN003)
KIT, CONVENIENCE, OUTLET
KIT, ELECTRICAL CONNECTOR SERVICE
KIT, ENGINE OVERHAUL
KIT, HEAD BOLT (6081HN003)
KIT, LUBRICATION PUMP
KIT, SEAL, COMPRESSOR, REFRIGERANT (6081HN003)
KIT, STEERING CYLINDER SEAL (ADJUSTABLE AXLE)
KIT, TERMINAL AND WIRING
KIT, WATER PUMP SEAL (6081HN003)
KIT, WINDSHIELD
KNEE AND KNUCKLE, REAR AXLE
KNOB GEARSHIFT
KNOB, ARMREST CONTROL PANEL
KNOB, CAB AIR FILTER DOOR
KNOB, OFFSET, ROW-TRAK
KNOB, OVERHEAD CONSOLE
L
LADDER DUCT
LADDER, PLATFORM (4 ROW)
LADDER, PLATFORM FRAME (6 ROW)(S/N -14000)
LADDER, PLATFORM FRAME (6 ROW)(S/N 14001- )
LAMPS AND WIRING HARNESS, BASKET
LATCH, BASKET EXTENSION
LATCH, CAB DOOR
LATCH, MOISTENER COLUMN
LENS, CAB ROOF LIGHT
LEVELER ASSY., HYDROSTATIC PUMP
LEVER, GEARSHIFT
LEVERS, HYDROSTATIC PUMP CONTROL
LID ASSEMBLY, BASKET EXTENSION
LID EXTENSION, BASKET
LIFT ARMS, UNIT
LIFT BRACKET, HYDROSTATIC PUMP
LIFT FRAMES, UNIT
LIFT HOSES
LIFT RETURN HYDRAULIC HOSES
LIFT STRAPS, ENGINE (6081HN003)
LIGHT, CAB ROOF
LIGHTER, CIGARETTE
LIGHTS - HALOGEN (CAB) (OPTIONAL) (S/N 14001- )
LINE, BRAKE
LINE, UNIT LUBRICATION
LINER, CYLINDER/CONNECTING RODS/PISTON (6081HN003)
LINES, FUEL FILTER/PRE-FUEL FILTER (6081HN003)
LINES, FUEL INJECTION (6081HN003)
LINES, FUEL INJECTION PUMP
LINES, HYDROSTATIC
LINES, TURBOCHARGER OIL
LINES, WATER SYSTEM CONTROL
LINES, WATER, MOISTENER COLUMN (CLEAR)
LINKAGE, GEARSHIFT
LINKAGE, HEIGHT SENSING
LOWER GEAR CASE HUB
LUBRICATION FILL HOSE
LUBRICATION HOSE, LIFT ARM
LUBRICATION PUMP
LUBRICATION PUMP KIT
LUBRICATION PUMP SYSTEM
LUBRICATION TANK
M
MAGNETIC PICK-UP (6081HN003)
MAIN AND MAIN THRUST BEARINGS (6081HN003)
MAIN BEARING CAPS (6081HN003)
MAIN CAB WIRING HARNESS
MAIN FRAME
MANIFOLD, AIR
MANIFOLD, AIR CONDITIONING COMPRESSOR (6081HN003)
MANIFOLD, INTAKE (6081HN003)
MANIFOLD, LUBRICATION
MANIFOLD, THERMOSTAT AND WATER (6081HN003)
MANIFOLD, UNIT LUBRICATION
MANIFOLD, WATER
MANIFOLDS, EXHAUST (6081HN003)
MASTER BRAKE CYLINDER
MASTER CYLINDERS
MAT, CAB FLOOR
MDC KIT, HYDROSTATIC PUMP
MINI ARMREST WIRING HARNESS
MIRROR SUPPORTS
MIRROR, REAR VIEW (INSIDE AND OUTSIDE)
MIRRORS AND LIGHT BAR (OPTIONAL) (S/N 14001- )
MIRRORS, REAR VIEW (CAB)(OPTIONAL) (S/N 14001- )
MODULE, MONITOR LIGHT
MOISTENER COLUMN
MOISTENER COLUMN WATER LINES (CLEAR)
MOISTENER COLUMN WATER LINES, FLUSH (GREEN)
MONITOR ASSEMBLY
MONITOR CONSOLE (HEADER HEIGHT)
MONITOR CONSOLE (VEHICLE)
MONITOR GAUGES
MONITOR LIGHT MODULES AND TACHOMETER CONNECTORS
MONITOR, FLAP
MONITORING SYSTEM, BASKET FULL
MOTOR ASSY., HYDRAULIC, SAUER-SUNDSTRAND 100 CC (PROPULSION)
MOTOR ASSY., HYDRAULIC, SAUER-SUNDSTRAND 75 CC (UNIT DRIVE)
MOTOR, COMPACTOR DRIVE
MOTOR, FLOOR AND DOOR CONVEYOR HYDRAULIC
MOTOR, HEATER AND AIR CONDITIONER
MOTOR, PRESSURE BLOWER
MOTOR, RECIRCULATION BLOWER, HEATER AND AIR CONDITIONER
MOTOR, STARTING (6081HN003)
MOTOR, UNIT DRIVE
MOTOR, WIPER (SHORT)
MOUNTING FLANGE, AUXILIARY, HYDROSTATIC PUMP
MUD SCRAPERS
MUFFLER
N
NO(ZLE, PICKING UNIT BOTTOM FRAME (PRO-16 UNIT)
NOZZLE, DUCT
NOZZLE, DUCT (36"-38"-40")
NOZZLE, FUEL INJECTION (6081HN003)
NOZZLE, PICKING UNIT BOTTOM FRAME (PRO-12 UNIT)
NOZZLES AND LINES, FUEL INJECTION (6081HN003)
NOZZLES, AIR DUCT
NUMBER 6 OFFSET COTTON DOOR
O
OFFSET CONTROL, ROW-TRAK
OFFSET COTTON DOOR NUMBER 6
OIL COOLER
OIL COOLER BYPASS ADAPTER (6081HN003)
OIL COOLER BYPASS TUBES (6081HN003)
OIL COOLER, ENGINE (6081HN003)
OIL COOLER, HYDRAULIC
OIL FILTER BASE (6081HN003)
OIL FILTER BYPASS VALVE (6081HN0030
OIL FILTER HOUSING GASKET (6081HN003)
OIL FILTER, ENGINE (6081HN003)
OIL LINES AND TURBOCHARGER
OIL PAN (ENGINE SERIAL NO. -209310)
OIL PAN(ENGINE SERIAL NO. 209311- )
OIL PRESSURE REGULATING VALVE (ENGINE OIL COOLER)(6081HN003)
OIL PRESSURE REGULATING VALVE (6081HN003)
OIL PRESSURE SWITCH, ENGINE (6081HN003)
OIL PUMP DRIVE GEAR (6081HN003)
OIL PUMP INTAKE (ESN -209310) (U/WRE508040)
OIL PUMP INTAKE (ESN 209311- ) (U/W RE506166)
OIL PUMP, ENGINE (6081HN003)
OIL RESERVOIR, HYDRAULIC
OIL SEAL AND HOUSING, CRANKSHAFT (6081HN003)
OIL SEAL, FRONT AND TIMING GEAR COVER (6081HN003)
OIL SEAL, WATER PUMP (6081HN003)
OIL, ENGINE (6081HN003)
OIL, HY-GARD HYDRAULIC/TRANSMISSION
OPERATOR’S ARMREST PANEL
OPERATOR’S SEAT
OPERATOR’S SEAT ADJUST AND PIVOT ASSEMBLIES
OPERATOR’S SEAT CUSHION, ARMREST, AND MOUNTING
OPERATOR’S SEAT PIVOT AND ADJUST
ORIFICE, UNIT LUBRICATION
OUTLET, CONVENIENCE, KIT
OUTSIDE MIRRORS
OUTTEXT
OVERFLOW TANK, RADIATOR
OVERHAUL KIT, ENGINE
OVERHEAD CONSOLE
P
PAD, MOISTENER
PAN, OIL(ENGINE SERIAL NO. -209310)
PAN,OIL(ENGINE SERIAL NO. 209311- )
PANEL, ARMREST
PANEL, CAB INTERIOR TRIM
PANEL, FLOOR
PANEL, OPERATOR’S ARMREST CONTROL
PANEL, OVERHEAD CONSOLE
PANELS, CHASSIS SIDE SHIELDING
PANELS, HYDRAULIC MODULE
PANELS, TUNNEL BOTTOM, CENTER (S/N -14000)
PANELS, TUNNEL BOTTOM, CENTER (S/N 14001-)
PANELS, TUNNEL BOTTOM, FRONT
PANELS, TUNNEL BOTTOM, REAR (S/N -14000)
PANELS, TUNNEL BOTTOM, REAR (S/N 14001- )
PARKING BRAKE PEDAL AND SEAL
PASSIVE CAN BUS DEVICE
PEDAL, BRAKE
PICK-UP, MAGNETIC (6081HN003)
PICKER BAR DRUM, STUD AND BEARING
PICKER BAR JOURNAL
PICKER BAR SPINDLE DRIVE SHAFT
PICKER BAR, SPINDLE AND WRENCH
PICKER DRUM HEAD AND CAM
PICKING UNIT GEAR CASE
PICKING UNIT GRID BARS AND SUPPORTS (PRO-12 18S)
PICKING UNIT GRID BARS AND SUPPORTS (PRO-16 20S)
PICKING UNIT HANGER
PICKING UNIT HOUSING
PICKING UNIT POSTS (PRO-12, 18S)
PICKING UNIT POSTS (PRO-16 20S)
PICKING UNIT UPPER HOUSING (PRO-12 UNIT)
PICKING UNIT UPPER HOUSING (PRO-16 UNIT)
PICKING UNIT WIRING HARNESS
PIN, REAR AXLE PIVOT
PINION, FINAL DRIVE
PINION, PICKING UNIT GEAR CASE
PIPE, EXHAUST
PISTON KIT, HYDROSTATIC PUMP SERVO
PISTON/CONNECTING RODS/CYLINDER LINER (6081HN003)
PISTON, HYDROSTATIC PUMP
PIVOT PLATE, DUCT
PIVOT PLATE, DUCT (36"-38"-40")
PIVOT SUPPORT, REAR AXLE (FRONT)
PIVOT SUPPORT, REAR AXLE (REAR)
PIVOT, OPERATOR’S SEAT
PLANT GUIDE, PRO-12 - 18S
PLATE, FRONT DRUM PRESSURE (PRO-12 18S)
PLATE, FRONT DRUM PRESSURE (PRO-16 20S)
PLATE, PICKING UNIT BOTTOM FRAME (PRO-12 UNIT)
PLATE, PICKING UNIT BOTTOM FRAME (PRO-16 UNIT)
PLATE, REAR DRUM PRESSURE (PRO-12 18S)
PLATE, REAR DRUM PRESSURE (PRO-16 20S)
PLATFORM FLOORS, AROUND CAB (38" & 40"/64" SKIP ROW)
PLATFORM FLOORS, AROUND CAB (4 ROW 34" SINGLE WHL.)
PLATFORM FLOORS, AROUND CAB (4 ROW)
PLATFORM FLOORS, AROUND CAB (6 ROW)
PLATFORM FRAME (S/N -14000)
PLATFORM FRAME (S/N 14001- )
PLATFORM HANDRAILS (4 ROW)
PLATFORM HANDRAILS (6 ROW)
PLATFORM LADDER (4 ROW)
PLUGS AND SEALS, HYDROSTATIC PUMP
PLUGS, UNIT CABINET
PLUS-50 ENGINE OIL (6081HN003)
POINT, STALKLIFTER, PRO-12 - 18S
POPPET, HYDROSTATIC PUMP
POST, BASKET SUPPORT
POSTS, PICKING UNIT (PRO-12, 18S)
POSTS, PICKING UNIT (PRO-16 20S)
POTENTIOMETER
POTENTIOMETER, CONSOLE, ROW-TRAK
POWER STEERING VALVE
PRESSURE PLATE, FRONT DRUM (PRO-12 18S)
PRESSURE PLATE, FRONT DRUM (PRO-16 20S)
PRESSURE PLATE, REAR DRUM (PRO-12 18S)
PRESSURE PLATE, REAR DRUM (PRO-16 20S)
PROBE ASSEMBLY, ROW-TRAK GUIDANCE SYSTEM (S/N -14000)
PROBE ASSEMBLY, ROW-TRAK GUIDANCE SYSTEM (S/N 14001-)
PROTECTORS AND SUPPORTS, BASKET FLOOR CONVEYOR CHAIN
PULLEY AND BELT ARRANGEMENT
PULLEY AND DAMPENERS, CRANKSHAFT (6081HN003)
PULLEY, AIR CONDITIONER COMPRESSOR FAN (6081HN003)
PULLEY, COTTON FAN DRIVE
PULLEY, FAN (6081HN003)
PULLEY, HYDRAULIC PUMP DRIVE
PUMP AND LINES, FUEL INJECTION
PUMP CONTROL LEVERS AND RODS, HYDROSTATIC
PUMP DISPLACEMENT CONTROL, HYDROSTATIC
PUMP DRIVE, HYDROSTATIC
PUMP END CAP, HYDROSTATIC
PUMP FRAME ASSEMBLY, HYDRO
PUMP HOUSING, SWASHPLATE AND CYLINDER BLOCK, HYDROSTATIC
PUMP MOUNTING, AUX. PUMP TO HYDROSTATIC PUMP
PUMP SHAFT AND LEVELER ASSY., HYDROSTATIC
PUMP VALVES, HYDROSTATIC
PUMP WIRING HARNESS, HYDRO
PUMP, CHARGE, HYDROSTATIC DRIVE
PUMP, ENGINE OIL (6081HN003)
PUMP, FUEL TRANSFER (ROBERT BOSCH) (6081HN003)
PUMP, HYDRAULIC (45 CM3 (2.75 CU. IN.))
PUMP, HYDROSTATIC
PUMP, LUBRICATION
PUMP, LUBRICATION
PUMP, LUBRICATION TRANSFER
PUMP, SOLUTION
PUMP, WATER
PUMP, WATER (6081HN003)
PUMP, WATER, SUPPORT AND FITTINGS
PUSH RODS (6081HN003)
R
RADIATOR
RADIATOR HOODS
RADIATOR HOSES
RADIATOR OVERFLOW TANK
RADIATOR SIDE PANELS
RADIO, SPEAKERS AND ANTENNA
RADIUS GAUGES, DOFFER
RAIL AND SHIFTER, TRANSMISSION HOUSING
RAILS, BASKET LID
RAKE BAR, ROTARY SCREEN
REAR AND SIDE CAB SEALS
REAR AXLE CENTER
REAR AXLE FRONT PIVOT SUPPORT
REAR AXLE KNEE AND KNUCKLE
REAR AXLE REAR PIVOT SUPPORT
REAR AXLE TIE RODS
REAR LIGHTS AND FUEL SENDER WIRING HARNESS
REAR OIL SEAL AND HOUSING (6081HN003)
REAR VIEW MIRROR (CAB)(OPTIONAL) (S/N 14001- )
REAR VIEW MIRRORS
REAR WHEEL
RECEIVER-DRYER, AIR CONDITIONER
REFLECTORS
RELAYS, LOAD CENTER WIRING HARNESS
RESERVOIR WIRING HARNESS, HYDRO
RESERVOIR, BRAKE
RESET HANDLE, BASKET
RIMS, SINGLE DRIVE WHEELS
RING, REAR WHEEL BOLT
RING, WATER PUMP RETAINING (6081HN003)
ROCKER ARM SHAFT (6081HN003)
ROCKER ARMS (6081HN003)
ROD, HEIGHT SENSING LINKAGE
ROD, PISTON/CYLINDER LINER/CONNECTING (6081HN003)
RODS, HYDROSTATIC PUMP CONTROL LEVER
RODS, PUSH (6081HN003)
RODS, STALKLIFTER
ROLLER, PICKING UNIT HANGER
ROOF, INTERIOR CAB
ROTARY SCREEN
ROTARY SCREEN DOOR
ROTARY SCREEN DOOR TRASH SHIELD
ROTARY SCREEN DRIVE AND IDLER ARMS
ROTOR, FAN
ROW-TRAK FEEDBACK SENSOR AND WRENCH
ROW-TRAK FEEDBACK SENSOR BRACE
ROW-TRAK OFFSET CONTROL
ROW-TRAK PROBE ASSEMBLY (S/N -14000)
ROW-TRAK PROBE ASSEMBLY (S/N 14001-)
S
SADDLE, WATER TANK
SAFETY DECALS
SCHEMATIC, ELECTRICAL WIRING
SCRAPER, FRONT DRUM PRESSURE PLATE (PRO-12 18S)
SCRAPER, FRONT DRUM PRESSURE PLATE (PRO-16 20S)
SCRAPERS, MUD
SCREEN AND TUBE, TRANSMISSION OIL
SCREEN, BASKET EXTENSION LID
SCREEN, BASKET EXTENSION, FRONT
SCREEN, BASKET EXTENSION, LEFT
SCREEN, BASKET EXTENSION, REAR
SCREEN, BASKET EXTENSION, RIGHT
SCREEN, BASKET, LOWER RIGHT SIDE
SCREEN, CONTROL FILTER, HYDROSTATIC PUMP
SCREEN, ROTARY
SCREEN, ROTARY, DOOR ASSEMBLY
SCREENS, BASKET LID EXTENSION
SEAL AND BRAKE PEDAL, PARKING
SEAL KIT, STEERING CYLINDER
SEAL, CAB SIDE AND REAR
SEAL, FRONT OIL AND TIMING GEAR COVER (6081HN003)
SEAL, REAR OIL (6081HN003)
SEAL, WATER PUMP OIL (6081HN003)
SEALS, STARTING MOTOR (6081HN003)
SEAT CONSOLE, PASSENGER
SEAT CUSHIONS, PASSENGER
SEAT SUSPENSION
SEAT, OPERATOR’S
SEATBELT, INSTRUCITONAL SEAT
SENDER, COOLANT TEMPERATURE (6081HN003)
SENDER, FUEL GAUGE
SENDER, FUEL TEMPERATURE
SENDER, LUBRICATION PRESSURE
SENSOR, BASKET FULL MONITORING SYSTEM
SENSOR, DIFFERENTIAL
SENSOR, DRUM SPEED
SENSOR, ENGINE SPEED (6081HN003)
SENSOR, EVAPORATOR TEMPERATURE
SENSOR, FAN
SENSOR, FEEDBACK, ROW-TRAK
SENSOR, FUEL TEMPERATURE
SENSOR, HEIGHT SENSING
SENSOR, OPERATOR’S ARMREST CONTROL PANEL
SENSOR, OVERHEAD CONSOLE
SENSOR, ROW-TRAK PROBE (S/N -14000)
SENSOR, ROW-TRAK PROBE (S/N 14001-)
SENSOR, TEMPERATURE, HEATER AND A/C
SEPARATOR, WATER (6081HN003)
SERVICE KIT, ELECTRICAL CONNECTORS
SERVO ASSY., HYDROSTATIC PUMP
SHAFT, COMPACTOR DRIVE
SHAFT, CONVEYOR SPROCKET, BASKET DOOR
SHAFT, CONVEYOR SPROCKET, BASKET FLOOR
SHAFT, CROSS
SHAFT, DOFFER
SHAFT, DOFFER STUB
SHAFT, DRIVE, AXLE
SHAFT, DRUM SLIP CLUTCH AND IDLER GEARS ( -16000)
SHAFT, DRUM SLIP CLUTCH AND IDLER GEARS (16001- )
SHAFT, ENGINE FAN DRIVE
SHAFT, FAN DRIVE
SHAFT, FAN DRIVE PULLEY (6081HN003)
SHAFT, HYDROSTATIC CHARGE PUMP
SHAFT, HYDROSTATIC PUMP
SHAFT, LOWER GEAR CASE HUB
SHAFT, PICKER BAR
SHAFT, PICKING UNIT GEAR CASE
SHAFT, ROCKER ARM (6081HN003)
SHAFT, TRANSMISSION INPUT
SHAFT, TRANSMISSION INTERMEDIATE
SHAFT, UNIT DRIVE (COUNTERSHAFT)
SHAFT, UPPER HOUSING DRUM DRIVE GEAR
SHEAVE, ENGINE COOLING FAN
SHEAVE, HYDRAULIC PUMP DRIVE
SHEAVE, HYDROSTATIC PUMP DRIVE
SHEAVE, ROTARY SCREEN DRIVE
SHEAVE, UNIT DRIVE COUNTERSHAFT
SHEAVE, WATER PUMP DRIVE
SHEAVES, ENGINE DRIVE AND DRIVEN
SHIELD, EXHAUST VALVE (6081HN003)
SHIELD, FRONT WHEEL, RH
SHIELD, LH FRONT WHEEL, 4 ROW WITH DUAL WHEELS
SHIELD, PICKING UNIT GEAR CASE
SHIELD, STALKLIFTER, PRO-12 - 18S
SHIELD, WIRING HARNESS
SHIELDING, CHASSIS SIDE
SHIFTER AND RAIL, TRANSMISSION HOUSING
SHOE, HEIGHT SENSING
SHOE, STALKLIFTER POINT, PRO-12 - 18S
SHOES, BRAKE
SHORT BLOCK
SHORT BLOCK GASKET KIT (6081HN003)
SIDE AND REAR CAB SEALS
SIDE FRAMES, ENGINE
SIDE PANELS, CHASSIS
SKIP ROW GEAR BOX
SLAVE CYLINDER, BRAKE
SLIP CLUTCH AND IDLER GEARS, DRUM ( -16000)
SLIP CLUTCH AND IDLER GEARS, DRUM (16001- )
SLIP CLUTCH, LOWER GEAR CASE HUB
SOLENOID VALVE ( -16001)
SOLENOID VALVE (16001- )
SOLENOID VALVE, HYDROSTATIC FITTINGS
SOLENOID VALVE, UNIT LIFT CONTROL
SPACER, AXLE
SPACERS, AXLE
SPEAKER GRILLE
SPEAKER, ANTENNA AND RADIO
SPIDER ASSEMBLY, ENGINE FAN
SPINDLE
SPINDLE MOISTENER COLUMN
SPLINED COUPLING, DRIVE AXLE
SPRING, BRAKE PEDAL
SPRING, DRUM SLIP CLUTCH ( -16000)
SPRING, DRUM SLIP CLUTCH (16001- )
SPRING, LATCH, CAB DOOR
SPRING, LOWER GEAR CASE HUB
SPRING, PARKING BRAKE PEDAL
SPRING, STEERING COLUMN
SPROCKETS, CONVEYOR, BASKET DOOR
SPROCKETS, CONVEYOR, BASKET FLOOR
SPUR GEAR, DRUM IDLER ( -16000)
SPUR GEAR, DRUM IDLER (16001- )
SPUR GEAR, LOWER GEAR CASE HUB
STABILIZER, TOP LINK
STALKLIFTER RODS
STALKLIFTERS, EXTENSION AND GRATE PRO-12 - 18S
STAND, REAR BASKET
STARTER GEAR (6081HN003)
STARTING AID, COLD WEATHER
STARTING SWITCH
STEERING ARM, REAR AXLE
STEERING COLUMN (LOWER)
STEERING COLUMN (UPPER)
STEERING COLUMN HARNESS
STEERING CYLINDER
STEERING CYLINDER SEAL KIT (ADJUSTABLE AXLE)
STEERING LINES, HYDRAULIC
STEERING PUMP - STEERING SHAFT
STEERING VALVE (ROW TRAK) (S/N 14001- )
STEERING VALVE, POWER
STEERING VALVE, ROW-TRAK (S/N -14000)
STEERING WHEEL
STEERING WHEEL ADJUSTER PEDAL
STEPS, LADDER DUCT
STRAINER, GREASE
STRAINER, MOISTENER COLUMN
STRAINER, WATER
STRAINER, WATER TANK
STRAP, FUEL INJECTION LINES (6081HN003)
STRAPS, ENGINE LIFT (6081HN003)
STUD, PICKER BAR DRUM
SUN VISOR
SUPPLEMENTARY TERMINALS AND CONNECTORS
SUPPORT ASSEMBLY, BASKET
SUPPORT, AIR CONDITIONER COMPRESSOR (6081HN003)
SUPPORT, ALTERNATOR (6081HN003)
SUPPORT, COOLING FRAME
SUPPORT, DUCT
SUPPORT, MOISTENER COLUMN
SUPPORT, REAR AXLE PIVOT (FRONT)
SUPPORT, REAR AXLE PIVOT (REAR)
SUPPORT, TRANSMISSION
SUPPORT, WATER PUMP
SUSPENSION, SEAT
SWASHPLATE, HYDROSTATIC PUMP
SWITCH AND HARNESS, TETHER (NO. 3 OR 4 UNIT)
SWITCH CONNECTOR, CONSOLE
SWITCH WIRING HARNESS, DOOR CONTACT
SWITCH, AIR CONDITIONER
SWITCH, ARMREST ROCKER
SWITCH, COMPACTOR FOOT CONTROL
SWITCH, DOOR LIGHT
SWITCH, DOOR SAFETY
SWITCH, ENGINE OIL PRESSURE (6081HN003)
SWITCH, FLUSH SYSTEM FOOT CONTROL
SWITCH, INTERIOR CAB ROOF
SWITCH, LUBRICATION PRESSURE
SWITCH, OVERHEAD CONSOLE
SWITCH, PARKING BRAKE PEDAL
SWITCH, PRESSURE, ROW-TRAK STEERING VALVE (S/N -14000)
SWITCH, STARTING MOTOR (6081HN003)
SWITCH, STEERING COLUMN
SWITCH, TRANSMISSION SAFETY
T
TACHOMETER
TANK GUARD (S/N -14000)
TANK GUARD (S/N 14001- )
TANK, COOLANT RECOVERY
TANK, FUEL
TANK, LUBRICATION
TEMPERATURE GAUGE, ENGINE
TEMPERATURE SENDER, COOLANT (6081HN003)
TEMPERATURE SENSOR, INTAKE MANIFOLD
TENSIONER, ALTERNATOR BELT (6081HN003)
TERMINAL AND WIRING KIT
TERMINAL, CONSOLE SWITCH CONNECTOR
TERMINAL, ELECTRICAL, WEATHERPACK
TERMINAL, ELECTRONIC CONTROLLER, ENGINE SPEED SENSOR AND HORN CONNECTORS
TERMINAL, KEY SWITCH, CONSOLE LIGHT, ETHER SWITCH & WARNING HORN CONNECTORS
TERMINAL, MONITOR LIGHT MODULE AND TACHOMETER CONNECTORS
TETHER SWITCH AND HARNESS (NO. 3 OR 4 UNIT)
THERMOSTAT AND WATER MANIFOLD (6081HN003)
THRUST BEARINGS, MAIN (6081HN003)
TIE RODS, REAR AXLE
TIMING GEAR COVER AND FRONT OIL SEAL (6081HN003)
TONE WHEEL, FAN
TOP LINK STABILIZER
TORQ-GARD ENGINE OIL (6081HN003)
TRANSFER PUMP, FUEL (ROBERT BOSCH) (6081HN003)
TRANSFER PUMP, LUBRICATION
TRANSITION DUCTS
TRANSITION DUCTS (36"-38"-40")
TRANSMISSION AND MOTOR
TRANSMISSION CASE
TRANSMISSION DIFFERENTIAL
TRANSMISSION GEARSHIFT
TRANSMISSION INPUT SHAFT
TRANSMISSION INTERMEDIATE SHAFT
TRASH CONTAINER
TRASH SHIELD, ROTARY SCREEN
TRAY, BATTERY SUPPORT
TRIM PANELS, CAB INTERIOR
TUBE ASSEMBLIES, HYDROSTATIC
TUBE, DOOR OPENING, UPPER
TUBE, ENGINE OIL DIPSTICK (6081HN003)
TUBE, UNIT LUBRICATION
TUBES, AIR
TUBES, BASKET SUPPORT
TUBES, CHARGE AIR COOLER
TUBES, ENGINE AIR INTAKE
TUBES, OIL COOLER BYPASS (6081HN003)
TUNNEL BOTTOM PANELS, CENTER (S/N -14000)
TUNNEL BOTTOM PANELS, CENTER (S/N 14001-)
TUNNEL BOTTOM PANELS, FRONT
TUNNEL BOTTOM PANELS, REAR (S/N -14000)
TUNNEL BOTTOM PANELS, REAR (S/N 14001- )
TURBOCHARGER AND OIL LINES
TURN SIGNAL SWITCH
TURNBUCKLE, TOP LINK STABILIZER
U
UNIT CABINET PLUGS AND GROMMETS
UNIT DOORS
UNIT DOORS, PRO-12 - 18S
UNIT DRIVE
UNIT DRIVE HYDRAULIC MOTOR
UNIT LIFT ARMS
UNIT LIFT CONTROL VALVE
UNIT LIFT FRAMES
UNIT LIFT HYD. HOSES
UNIT LIFT RETURN HYDRAULIC HOSES
UNIT LOCATION DECALS
UNIT LUBRICATION MANIFOLD AND FITTINGS
UNIT SPEED SYNCHRONIZATION HARNESS (SERVICE TOOL)
UNIT TO BASKET DUCTS
UNIT TO BASKET DUCTS (36"-38"-40")
UNIT WIRING HARNESS
UNIVERSAL JOINT, CROSS SHAFT
UPGRADE, DRUM SPEED MONITOR FIRMWARE
UPPER DOFFER ADJUSTING HOUSING
UPPER DOOR OPENING, BASKET
UPPER HOUSING DRUM DRIVE GEARS
UPPER HOUSING, PICKING UNIT (PRO-12 UNIT)
UPPER HOUSING, PICKING UNIT (PRO-16 UNIT)
V
VALVE SEAT INSERTS (6081HN003)
VALVE, CONVEYOR CONTROL
VALVE, FUEL CHECK (6081HN003)
VALVE, OIL FILTER BYPASS (6081HN003)
VALVE, OIL PRESSURE REGULATING (ENGINE OIL COOLER)(6081HN003)
VALVE, OIL PRESSURE REGULATING (6081HN003)
VALVE, POWER STEERING
VALVE, SOLENOID ( -16001)
VALVE, SOLENOID (16001- )
VALVE, STEERING (ROW TRAK) (S/N 14001- )
VALVE, STEERING, ROW-TRAK (S/N -14000)
VALVE, WATER FILTER
VALVE, WATER TANK SHUTOFF
VALVE, WATER, AIR CONDITIONING
VALVES, COMPRESSOR (6081HN003)
VALVES, HYDROSTATIC PUMP
VALVES, INTAKE AND EXHAUST (6081HN003)
VALVES, WATER SYSTEMS CONTROL
VINE CUTTER
VINE CUTTERS
VOLTMETER
W
WASHERS, MAIN AND MAIN THRUST (6081HN003)
WATER FILTER
WATER LINES, MOISTENER COLUMN (CLEAR)
WATER MANIFOLD AND THERMOSTAT (6081HN003)
WATER PUMP (SOLUTION)
WATER PUMP AND INLET (6081HN003)
WATER PUMP FITTINGS AND SUPPORTS
WATER SEPARATOR (6081HN003)
WATER TANK AND SADDLE
WATER TANK HOSES AND FITTINGS
WATER VALVE ASSEMBLY, AIR CONDITIONING
WEATHERPACK CONNECTORS
WEATHERPACK TERMINALS
WETTING AGENT AND SPINDLE CLEANER
WHEEL SHIELD, FRONT RH
WHEEL SHIELD, LH FRONT, 4 ROW WITH DUAL WHEELS
WHEEL, REAR
WHEEL, STEERING
WHEELS, DRIVE (SINGLE)
WHEELS, DUAL
WINDSHIELD
WING ASSEMBLY, CONVEYOR DOOR
WIPER (SHORT)
WIPER FLAP, BASKET
WIPER MOTOR (SHORT)
WIPER, WINDSHIELD (SHORT)
WIRE, A/C ELECTRIC CLUTCH GROUND (6081HN003)
WIRING AND TERMINAL KIT
WIRING CONNECTOR, CONSOLE SWITCH
WIRING CONNECTOR, ELECTRONIC CONTROLLER, ENGINE SPEED SENSOR, AND HORN
WIRING CONNECTOR, KEY SWITCH, CONSOLE LIGHT, ETHER SWITCH, WARNING HORN
WIRING CONNECTOR, MONITOR LIGHT MODULE AND TACHOMETER
WIRING CRIMPING TOOL
WIRING HARNESS (CAB LAMPS) (OPTIONAL) (S/N 14001- )
WIRING HARNESS (CAB REAR) (OPTIONAL) (S/N 14001- )
WIRING HARNESS, AIR CONDITIONING
WIRING HARNESS, ARMREST
WIRING HARNESS, BASKET LAMP
WIRING HARNESS, CHASSIS
WIRING HARNESS, DOME LIGHT EXTENSION
WIRING HARNESS, DOOR CONTACT SWITCH
WIRING HARNESS, ENGINE
WIRING HARNESS, FRONT CHASSIS
WIRING HARNESS, HYDRO PUMPS AND RESERVOIR
WIRING HARNESS, MAIN CAB
WIRING HARNESS, MINI ARMREST
WIRING HARNESS, PICKING UNIT
WIRING HARNESS, REAR LIGHTS AND FUEL SENDER
WIRING HARNESS, TRANSMISSION SWITCH
WIRING HARNESS, UNIT SPEED SYNCHRONIZATION (SERVICE TOOL)
WIRING LEAD, ROTARY SCREEN
WIRING SCHEMATIC, ELECTRICAL
WIRING STRIPPING TOOL
WISHBONE ASSEMBLY, ROW-TRAK (S/N -14000)
WISHBONE ASSEMBLY, ROW-TRAK (S/N 14001-)
WOOD SLATS, BASKET DOOR CONVEYOR
WOOD SLATS, BASKET FLOOR CONVEYOR
WRENCH, FEEDBACK SENSOR, ROW-TRAK
WRENCH, PICKING UNIT HANGER
WRENCH, SPINDLE
