Martin Welker
104
230,310
John Deere 985 Series Drawn Field Cultivator Operators Manual OMN200868
Format: HTML
Brand: John Deere
Type of Machine: Drawn Field Cultivator
Model: John Deere 980 Drawn Field Cultivator
Parts Number: OMN200868
Foreword
Look For Supplemental Information
Section : 05 - Safety
Recognize Safety Information
Understand Signal Words
Follow Safety Instructions
Operate Safely
Keep Riders Off Machine
Prepare for Emergencies
Wear Protective Clothing
Use Safety Lights and Devices
Use a Safety Chain
Transport Safely
Tow Loads Safely
Practice Safe Maintenance
Avoid High-Pressure Fluids
Check Hydraulic Hoses
Support Raised Equipment
Store Attachments Safely
Dispose of Waste Properly
Section : 10 - Safety Signs
Safety Signs
Section : 15 - Identification
Drawn Field Cultivator Views
Section : 20 - Preparing the Tractor
Use Your Tractor Operator's Manual
Determining Tractor Requirements
Preparing Hydraulic System-55 and 60 Series Tractors
Preparing Hydraulic System-8000 and 9000 Series Tractors
Securing 3-Point Hitch
Positioning Drawbar
Using a Safety Chain
Enable TouchSet™ Depth Control (If Equipped)
Section : 25 - Preparing the Machine
Checking and Lubricating Machine
Checking Tire Pressure
Checking Wheel Bolts and Bearings
Tightening Hardware
Section : 30 - Attaching and Detaching
Attaching Machine Safely
Making Proper Hose Connections
Attaching Cultivator to 55/60 Series Tractors
Attaching to 8000 and 9000 Series Tractors
Attach Safety Chain to Tractor
Attaching Warning Light Plug
Raising Parking Stand
Checking Wing-Fold Operation
Checking Depth-Control Operation Without TouchSet™ Depth Control
Checking TouchSet™ Depth Control Operations-8000 and 9000 Series
Detaching Cultivator From Tractor
Section : 35 - Transporting
Using Warning Lights and SMV
Positioning Tractor Drawbar for Transport (Four-Wheel Drive Tractors)
Positioning Hitch Jack for Transport
Raising Parking Stands
Locking Up Depth Control
Transporting the Machine
Section : 40 - Operating the Machine
Follow Safe Operating Procedures
Guidelines for Use
Using Operators Manual Holder
Tightening Hardware
Understanding the Hydraulic Depth-Control System (Series)
Operating Depth Consistency
Operating TOUCHSET™ Depth Control-8000 and 9000 Series Tractors
Preparing to Operate Cultivator In Field
Using Single-Point Depth-Stop Control
Adjusting TouchSet™ Raise and Lower Rates and Raise Limit-8000 and 9000 Series Tractors
Level-Adjustment Wrench
Leveling the Cultivator
Checking for Level Operation
Leveling Wings (Side-to-Side)
Adjusting Wing-Fold Operations
Adjusting Stabilizer Wheels
Installing Sweep Extender-Without DOUBLE-LOC™ Sweeps
Adjusting Sweep Pitch Angle-Without DOUBLE-LOC™ Sweeps
Unfolding, Leveling and Folding Coil Tine Harrow
Adjusting Coil Tine Harrow Angle
Adjusting Spike-Tooth Harrow Angle
Adjusting Spike Tooth Harrow Height
Adjusting Nozzle Height and Spacing (Spray Attachment)
Section : 45 - Lubrication
Lubricating and Maintaining Machine Safely
Grease
Lubricant Storage
Beginning and End of Season
Lubrication Symbols
Lubrication Intervals
Lubricate Hitch Jack
Lubricate Rockshaft Bearings
Lubricate Depth Control Castings
Lubricate Wheel Bearings
Lubricate Wing-Depth Adjustment Bolts
Lubricate Single-Point Actuator and Threaded Rod
Lubricate Stabilizer Wheels and Adjustment Ratchets
Repack Walking Beam Pivot Bearings-All
Section : 50 - Troubleshooting
Troubleshooting
Recommendations for Working Hard Soils
Prepare to Troubleshoot TouchSet™ Depth Control System-8000 and 9000 Series
TouchSet™ Troubleshooting Flow Chart
Troubleshooting TouchSet™ Depth Control System
Section : 55 - Service
Using Safe Service Procedures
Replacing Ground Engaging Tools
Keeping Service Area Clean
Service Tires Safely
Metric Bolt and Cap Screw Torque Values
Unified Inch Bolt and Cap Screw Torque Values
Checking C-Shank Assembly Tightness
Checking Standard Bushings
Replacing Split-Tension Bushings
Replacing DOUBLE-LOC™ Sweeps
Preventing Hydraulic System Contamination
Removing Hydraulic Cylinders
Installing and Bleeding Wing-Fold Cylinders
Adjusting Wing-Fold Sequence Valve
Checking Depth-Control Hydraulic System
Checking for Depth-Control Cylinder Leakage
Parallel/Series Cylinder Diagnostic Procedure
Installing Depth-Control Cylinders
Bleeding Depth-Control Cylinders
Adjust TouchSet™ Depth-Control Potentiometer
Section : 60 - Storage
Preparing for Storage
Removing From Storage
Section : 65 - Specifications
Machine Specifications
Tractor Horsepower Recommendations
Machine Dimensions
Record Product Identification Number (P.I.N.)
Section : 70 - Crime Prevention Tips
Help Prevent Crime
Record AG Identification Numbers
Keep Proof of Ownership
Park Indoors Out of Sight
When Parking Outdoors
Reduce Vandalism
Report Thefts Immediately
Section : SLIT - John Deere Service Literature Available
Technical Information
Section : IBC - John Deere Service Keeps You On The Job
John Deere Is At Your Service When You Need It
