Martin Welker
104
230,310
John Deere 9570STS 9670STS 9770STS 9870STS Combine Repair Technical Manual TM101919
Brand: John Deere
Type of Machine: Combine
Model: John Deere 9570STS 9670STS 9770STS 9870STS Combine
Part Number: TM101919
Number of Pages: 2310 Pages
tm101919 - 9570 STS™, 9670 STS™, 9770 STS™ and 9870 STS™ Combine Repair
Table of Contents
Foreword
General
Fuel And Air Repair
Power Train Repair
Power Steering And Brakes
Hydraulic Repair
Separator Shell
Operator Station Repair
Feeder House Repair
Separator
Grain Tank And Unloading System Repair
Engine Gear Case And Control Valve Repair
Dealer Fabricated Tools
Main Sections
Foreword
General
Fuel And Air Repair
Power Train Repair
Hydraulic Repair
Separator Shell
Feeder House Repair
Separator
Table of Contents
Foreword
General
Fuel And Air Repair
Power Train Repair
Hydraulic Repair
Separator Shell
Feeder House Repair
Separator
Required Fuel Properties
E-Diesel fuel
Sulfur content for Interim Tier 4, Final Tier 4, Stage III B, and Stage IV Engines
Sulfur Content for Tier 3 and Stage III A Engines
Sulfur Content for Tier 2 and Stage II Engines
Sulfur Content for Other Engines
Coolant Test Strips
When Using John Deere COOL-GARD II
When Using Nitrite-Containing Coolants
Coolant Analysis
Coolant Specifications
Replenish Coolant Additives
Why use John Deere LIQUID COOLANT CONDITIONER?
Avoid Automotive-type Coolants
Water Quality
Freeze Protection
Preferred Coolants
Additional Recommended Coolants
Other Coolants
Water Quality
Coolant Drain Intervals
Face Seal O-Ring to Stud End Installation
Face Seal Adjustable Stud End O-Ring Installation
Face Seal Straight Stud End O-Ring Installation
Fitting Installation
Assembly Torque
Remove Contact From Connector Body
Install New Contact
Belt Replacement
Belt Installation
Belt Tension Adjustment
Belt Care
Belt Storage
DE18569 Separator Gear Set Information (Engine Gear Case)
DE19182 Hydrostatic Gear Set Information (Engine Gear Case)
Install New Contact
Install New Contact
Install New Contact
Install New Contact
Install New Contact
Install New Contact
Preliminary Engine Testing
Engine Tune-Up
Install New Contact
Install New Contact
Install New Contact
Remove Contact from Connector Body
Install New Contact
FLUSHING:
When to flush the air conditioning system:
PRIMARY FLUSH:
FINAL FLUSH:
PURGING:
When to purge an air conditioning system:
EVACUATING:
SOLVENTS
All John Deere Engines with Exhaust Filter (Released 2011 and After)
All John Deere Engines Excluding Exhaust Filter (Primarily Released Prior to 2012)
BioDiesel Use Requirements and Recommendations
Pulled Out Stud
Ribs Cracked Or Broken Out Stud
Style (A) Drive Sheave
Style (B) Drive Sheave
Inspect Battery for Any Obvious Problems
Determine the Battery State of Charge
Recharge the Battery
Battery Storage
John Deere Plus-50™ II oil is preferred.
Install New Contact
Install New Contact
Install New Contact
Install New Contact
Install New Contact
Install New Contact
Install New Contact
Disassembly and Assembly:
Cleaning Parts:
Inspection:
Install New Contact
Narrow Body Machine
Wide Body Machines
Check For Leaks in System
Add Dye To System
Header Float Accumulator Precharge Pressures
Optional Accumulator Precharge Pressures
Obtain Software Payload
Program Control Unit
Chaffer Frame Clevis
Sieve Frame Clevis
