John Deere 95 Series Self-Propelled Combines Parts Catalog PC0580
Brand: John Deere
Type of Machine: Self-Propelled Combines
Model: John Deere 95 Series Self-Propelled Combines
Part Number: PC0580
Number of Pages: 281 Pages
ALPHABETICAL INDEX
A
Angle, Frame, Seperator Side Sheet, L.H.
Angle, Frame, Seperator Side Sheet, R.H.
Angle, Guard
Arm, Reel
Arm, Reel Support, L.H.
Arm, Reel Support, R.H.
Auger, Clean Grain
Auger, Grain Tank Hinged Unloading
Auger, Grain Tank Loading
Auger, Lower Tailings
Auger, Platform
Auger, Upper Tailings
Auger, Weed Seed
Axle, Main Wheel
Axle, Rear
Axle Support, Main Wheel
B
Bar, Cylinder Stripper
Bar, Finger
Bar, Rasp
Bearing, Fan Shaft
Bearing, Wood, Straw Walker Crankshaft
Beater Behind Cylinder
Blade, Cleaning Fan
Blade, Fan, Straw Spreader
Blade, Straw Chopper
Box, Tool
Brace, Operator's Platform to Axle
Brake Control, Operator's Platform
Brake Control, Parking
Brake Lining, Main Wheel
Brake, Main Wheel
C
Chaffer
Choke Control
Chopper, Straw
Chute, Sack
Clean Grain Auger
Clean Grain Auger Housing
Clean Grain Elevator (Grain Tank)
Clean Grain Elevator (Sacker)
Clutch Control, Operator's Platform
Clutch, Electro-Magnetic Throw-Out
Clutch, Main Wheel
Concave Assembly
Concave Plate, Rasp-Bar Cylinder
Concave, Spike-Tooth
Concave Tooth
Control, Gear Shift
Control, Hydraulic, Platform Lift
Control, Hydraulic, Selective Ground Speed
Control Rod, Separator Belt Tightener Lever
Control, Steering, Operator's Platform
Conveyor Bottom, Grain
Conveyor, Feeder House
Crank, Shoe Pitman
Crankshaft, Straw Walker
Crawler Track
Cutter Bar Extension (Special)
Cutting Platform Support Stand
Cylinder, Hydraulic, Selective Ground Speed Control
Cylinder, Rasp-Bar
Cylinder, Spike-Tooth
Cylinder Sprockets
Cylinder Stripper Bar
Cylinder Tooth
Decalcomania Set
Differential Gears
Divider, Platform End Sheet, L.H.
Divider, Platform End Sheet, R.H.
Drive, Auger, Feeder House
Drive, Clean Grain Auger
Drive, Cooling Fan
Drive, Cylinder
Drive, Feed Roll, Lower
Drive, Feed Roll, Upper
Drive, Feeder Beater
Drive, Feeder Conveyor
Drive, Final (Grain)
Drive, Final (Rice and Rice Crawler)
Drive Gear, Final (Grain)
Drive Gear, Final (Rice and Rice Crawler)
Drive Gear Housing, Final (Grain)
Drive Gear Housing, Final (Rice and Rice Crawler)
Drive, Generator
Drive, Grain Conveyor
Drive, Grain Tank Loading Auger
Drive, Grain Tank Unloading Auger, Front
Drive, Grain Tank Unloading Auger, Rear
Drive, Hydraulic Unit
Drive, Main Wheel
Drive, Platform Auger
Drive, Reel, Front
Drive, Reel, Rear
Drive, Rotor (for Hart ScourKleen Model N)
Drive, Separator
Drive Shaft, Auger
Drive Shaft, Sickle
Drive, Sickle, Feeder House
Drive, Straw Chopper
Drive, Straw Chopper Reverse
Drive, Straw Spreader
Drive, Straw Walker
Drive, Tailing Auger, Lower
Drive, Tailing Auger, Upper
Drive, Weed Seed Auger (for Hart ScourKleen Model N)
E
Electro-Magnetic Throw-Out Clutch
Elevator, Clean Grain (Grain Tank)
Elevator, Clean Grain (Sacker)
Elevator, Tailing
End Sheet, Platform, L.H.
End Sheet, Platform, R.H.
Engine Shield, Sacking Platform
Extension, Cutter Bar (Special)
Extension Divider
Extension, Grain Tank (Special)
Extension, Ladder
F
Fan Housing
Fan Housing Shield
Fan Shaft
Fan Shaft Bearing
Feed Roll (Special)
Feed Roll Housing
Feeder Conveyor Chain Shield
Feeder Drum, Feeder House
Feeder House Bottom Sheets
Feeder House Side Sheet
Feeder House Top Sheet
Feeder House Conveyor Chain
Feeder House Feeder Drum
Final Drive (Grain)
Final Drive (Rice and Rice Crawler)
Finger Bar
Finger, Grain Grate
Finger, Platform Auger
Floorboard, Sacking Platform
Frame Angle, Separator Side Sheet, L.H.
Frame Angle, Separator Side Sheet, R.H.
G
Gasoline Tank
Gasoline Tank Support
Gear Shift Control
Gear, Steering
Grain Conveyor Bottom
Grain Conveyor Chain with Shafts
Grain Grate and Concaves
Grain Grate Fingers
Grain Tank
Grain Tank Extension (Special)
Grain Tank Hinged Unloading Auger
Grain Tank Unloading Auger Sheave
Grain Tank Unloading Auger Drive Sheave Throw-Out
Grain Tank Unloading Drive Shaft
Grate and Concaves
Guard for Transmission Sheave
Guards and Sickle
Handrails, Sacking Platform
Holders, Sack and Sacking Spout
Hood, Rear
Housing, Clean Grain Auger
Housing, Clean Grain Hinged Unloading Auger
Housing, Fan
Housing, Grain Tank Loading Auger
Housing, Lower Tailings Auger
Housing, Upper Tailings Auger
Housing, Weed Seed Auger (for Hart ScourKleen Model N) (Special)
Hydraulic Controls for Platform Lift
Hydraulic Controls for Selective Ground Speed
Hydraulic Cylinder, Hydraulic Steering
Hydraulic Cylinder, Platform Lift
Hydraulic Cylinder, Steering Oil Lines
Hydraulic Hoses, Hydraulic Oil Reservoir
Hydraulic Hoses, Platform Lift
Hydraulic Hoses, Steering Oil Lines
Hydraulic Oil Lines ( - 4100)
Hydraulic Oil Lines (4101 - )
Hydraulic Pumps
Hydraulic Unit Drive
Hydraulic Unit Drive Shaft and Mounting
Hydraulic Valve
I
ID VIEW
K
Knife Head
Knife Sections (for Straw Chopper)
L
Ladder on Separator
Ladder, Operator's Platform
Lever, Gear Shift
Lever, Grain Tank Unloading
Lever, Platform Hydraulic and Selective Ground Speed Control
Lever, Separator Belt Tightener
Lifting Guards (for Sickle)
Lighting Attachment
Lines, Oil ( - 4100)
Lines, Oil (4101 - )
Linings, Brake, Main Wheel
Lower Tailings Auger and Housing
M
Main Wheel
Main Wheel Brake and Linings
Main Wheel Clutch
Main Wheel Transmission Gears and Case
O
Oil Lines ( - 4100)
Oil Lines (4101 - )
Oil Reservoir, Hydraulic
Operator's Platform
Operator's Platform Hinged Ladder
Operator's Platform Ladder
Operator's Platform Seat
Operator's Seat, Sacking Platform
P
Paddles, Clean Grain Elevator (Grain Tank)
Paddles, Clean Grain Elevator (Sacker)
Paddles, Tailings Elevator
Pipe, Reel
Pipe, Sickle Drive Oscillating
Plates, Concave
Platform Angles and Braces
Platform Auger
Platform Bottom Sheets
Platform Bottom Shields
Platform End Sheet, L.H., and Divider
Platform End Sheet, R.H., and Divider
Platform Extension Divider
Platform, Operator's
Platform, Sacking
Powershaft on Engine
R
Rasp Bar
Rear Axle
Rear Beater, Behind Cylinder
Rear Hood
Rear Wheel and Stub Axle
Rear Wheel Supports
Reel
Reel Arm
Reel Drive Shaft at Rear of Platform
Reel Pipe
Reel Slat
Reel Slats End Shield
Reel Support Arms, L.H. and R.H.
Reflective Tape, Safety
Reverse Drive, Straw Chopper
Rod, Control, Separator Belt Tightener
Rotor Drive, Hart ScourKleen, Model N
S
Sack Chute and Supports
Sack Holders
Sack Shelf
Sacking Platform Floorboard
Sacking Platform Side Sheets and Engine Shields
Sacking Platform, Support Angles and Hand Rails
Sacking Spout
ScourKleen, Hart, Model N
ScourKleen, Hart, Weed Seed Auger and Housing
ScourKleen Weed Seed Spout and Box
Screens, Hart ScourKleen
Seat, Operator's Platform
Seat, Operator's Sacking Platform
Section, Sickle
Separator Belt Tightener Control
Separator Cross Tie
Separator Front End Sheets
Sepaator Side Sheets, L.H. and Frame Angles
Separator Side Sheets, R.H. and Frame Angles
Separator Top Sheet
Shield, End, Reel Slats
Shield, Variable Drive (Special)
Shields, Cleaning Fan Housing
Shields, Platform Bottom
Shifters and Housing, Transmission
Shoe
Shoe Pitman and Crank
Sickle
Sickle and Auger Drive Shaft on Rear of Platform
Sickle Drive Oscillating Pipe
Sieves and Chaffer
Slat, Reel
Speed Indicator, Variable Drive Releative (Special)
Spike-Tooth Concaves
Spike-Tooth Cylinder
Spout, Hinged Unloading Auger
Spreader, Straw
Stand, Support, cutting Platform (Special)
Steering Arms and Tie Rods
Steering Cable
Steering Controls on Operator's Platform
Steering Gear
Straw Chopper
Straw Chopper Housing, with Fins and Shields
Straw Spreader
Straw Walker
Straw Walker Crankshafts and Bearings
Support, Axle
Support, Rear Wheel
T
Tailings Auger Drive,, Lower
Tailings Auger Drive, Upper
Tailings Elevator
Tank, Gasoline and Supports
Tank, Grain
Tape, Reflective Safety
Throttle and Choke Controls
Throw-Out, Grain Tank Unloading Auger Drive Sheave
Tie Rods and Steering Arms
Tire and Tube, Main Wheel
Tool Box
Tooth, Concave
Tooth, Cylinder
Tracks, Crawler
Transmissioin Gears and Case
Transmission Sheave Guard
U
Upper Tailings Auger and Housing
V
Variable Drive Relative Speed Indicator (Special)
Variable Drive Shield (Special)
W
Walkers, Straw
Warning Lighting
Weed Bar
Weed Seed Auger and Housing for Hart ScourKleen
Weed Seed Spout and Box for Hart ScourKleen
Wheel, Main
Wheel, Rear
Wiper, Reel Slat
Wires, for Electromagnetic Throw-Out clutch for Platform
Wrench, Wheel
Brand: John Deere
Part Number: PC0580
ALPHABETICAL INDEX
A
Angle, Guard
Arm, Reel
Auger, Clean Grain
Auger, Platform
Auger, Weed Seed
Axle, Main Wheel
Axle, Rear
B
Bar, Finger
Bar, Rasp
Bearing, Fan Shaft
Blade, Cleaning Fan
Box, Tool
Brake, Main Wheel
C
Chaffer
Choke Control
Chopper, Straw
Chute, Sack
Clean Grain Auger
Clutch, Main Wheel
Concave Assembly
Concave Tooth
Control, Gear Shift
Crank, Shoe Pitman
Crawler Track
Cylinder, Rasp-Bar
Cylinder Sprockets
Cylinder Tooth
Decalcomania Set
Differential Gears
Drive, Cooling Fan
Drive, Cylinder
Drive, Generator
Drive, Main Wheel
Drive, Reel, Front
Drive, Reel, Rear
Drive, Separator
Drive Shaft, Auger
Drive Shaft, Sickle
Drive, Straw Walker
E
Elevator, Tailing
Extension Divider
Extension, Ladder
F
Fan Housing
Fan Housing Shield
Fan Shaft
Fan Shaft Bearing
Feed Roll (Special)
Feed Roll Housing
Final Drive (Grain)
Finger Bar
Finger, Grain Grate
G
Gasoline Tank
Gear Shift Control
Gear, Steering
Grain Grate Fingers
Grain Tank
Grate and Concaves
Guards and Sickle
Hood, Rear
Housing, Fan
Hydraulic Pumps
Hydraulic Valve
I
ID VIEW
K
Knife Head
L
Ladder on Separator
Lever, Gear Shift
Lighting Attachment
M
Main Wheel
Main Wheel Clutch
O
Oil Lines ( - 4100)
Oil Lines (4101 - )
Operator's Platform
P
Pipe, Reel
Plates, Concave
Platform Auger
Platform, Sacking
R
Rasp Bar
Rear Axle
Rear Hood
Rear Wheel Supports
Reel
Reel Arm
Reel Pipe
Reel Slat
S
Sack Holders
Sack Shelf
Sacking Spout
Section, Sickle
Separator Cross Tie
Separator Top Sheet
Shoe
Sickle
Sieves and Chaffer
Slat, Reel
Spreader, Straw
Steering Cable
Steering Gear
Straw Chopper
Straw Spreader
Straw Walker
Support, Axle
Support, Rear Wheel
T
Tailings Elevator
Tank, Grain
Tool Box
Tooth, Concave
Tooth, Cylinder
Tracks, Crawler
U
V
W
Walkers, Straw
Warning Lighting
Weed Bar
Wheel, Main
Wheel, Rear
Wiper, Reel Slat
Wrench, Wheel
- JOHN DEERE CODE DTC LIST
